[PATCH v2] Cubieboard2:SUN7I:Add LED BOOT support
This feature makes it possible to assign one of LED1(PH20) and LED2(PH21) to BOOT process LED. User should activates the "Enable status LED API" in "Device Drivers -> LED Support"
Signed-off-by: Javad Rahimi javad321javad@gmail.com --- This is my first contributation in open source world. I'm sorry if I have mistakes in my commits and versioning. I do my best to learn fast.
Changes in v2: - Missed braces added - Unnecessary debug removed - Some typo fixed
board/sunxi/board.c | 49 +++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 49 insertions(+)
diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 4f5747c34a..5e2f6ae902 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -1002,3 +1002,52 @@ int board_fit_config_name_match(const char *name) return ret; } #endif + +#if defined(CONFIG_LED_STATUS) && defined(CONFIG_LED_STATUS_BOOT) && defined(CONFIG_LED_STATUS_BOARD_SPECIFIC) + +#define CUBIE2_LED_BOOT_GPIO "PH20" +static int gpio_boot_led; + +void __led_init(led_id_t mask, int state) +{ + int ret; + + if (mask != CONFIG_LED_STATUS_BOOT) + return; + + ret = gpio_lookup_name(CUBIE2_LED_BOOT_GPIO, NULL, NULL, &gpio_boot_led); + + if (ret) + return; + + ret = gpio_request(gpio_boot_led, "boot_led"); + if (ret == -1) { + debug("[gpio_request] Error:%d\n", ret); + return; + } + + ret = gpio_direction_output(gpio_boot_led, 1); + if (ret == -1) { + debug("[gpio_direction_output] Error:%d\n", ret); + return; + } + __led_set(mask, state); +} + +void __led_set(led_id_t mask, int state) +{ + if (mask != CONFIG_LED_STATUS_BOOT) + return; + + gpio_set_value(gpio_boot_led, state); +} + +void __led_toggle(led_id_t mask) +{ + if (mask != CONFIG_LED_STATUS_BOOT) + return; + + gpio_set_value(gpio_boot_led, !gpio_get_value(gpio_boot_led)); +} + +#endif
you should add maintainer email for your patch
$ scripts/get_maintainer.pl board/sunxi/board.c Jagan Teki jagan@amarulasolutions.com (maintainer:ARM SUNXI) Andre Przywara andre.przywara@arm.com (maintainer:ARM SUNXI) u-boot@lists.denx.de (open list)
regards Frank
Gesendet: Mittwoch, 08. Dezember 2021 um 15:22 Uhr Von: "Javad Rahimi" javad321javad@gmail.com An: u-boot@lists.denx.de Cc: "Javad Rahimi" javad321javad@gmail.com Betreff: [PATCH v2] Cubieboard2:SUN7I:Add LED BOOT support
Changes in v2:
- Some typo fixed
- int ret;
- if (mask != CONFIG_LED_STATUS_BOOT)
return;
- ret = gpio_lookup_name(CUBIE2_LED_BOOT_GPIO, NULL, NULL, &gpio_boot_led);
- if (ret)
return;
- ret = gpio_request(gpio_boot_led, "boot_led");
- if (ret == -1) {
return;
- ret = gpio_direction_output(gpio_boot_led, 1);
- if (ret == -1) {
return;
- __led_set(mask, state);
return;
- gpio_set_value(gpio_boot_led, state);
return;
- gpio_set_value(gpio_boot_led, !gpio_get_value(gpio_boot_led));
2.25.1
On Wed, 8 Dec 2021 15:25:54 +0100 Frank Wunderlich frank-w@public-files.de wrote:
Thanks Frank!
Please have a look at the current pinephone_defconfig, because that uses the boot LED already in a much easier fashion: https://source.denx.de/u-boot/u-boot/-/commit/0534153fd1
Cheers, Andre
Changes in v2:
- Some typo fixed
- int ret;
return;
- if (ret)
return;
- if (ret == -1) {
return;
- if (ret == -1) {
return;
return;
return;
2.25.1
Thanks Frank!
Hi Andre, Thanks for your comments. I studied the pinephone_defconfig. By default, when activating the same options on Cubieboard2_defconfig it shows linker error for `__led_init` and `__led_set`. In other words, they are not defined. So, in this patch, I added the implementation for these functions for this board.
Regards, Javad
Cheers, Andre
Changes in v2:
- Some typo fixed
- int ret;
return;
- if (ret)
return;
- if (ret == -1) {
return;
- if (ret == -1) {
return;
return;
return;
2.25.1
Andre Przywara
Frank Wunderlich
Javad Rahimi
