[PATCH] rockchip: make_fit_atf: explicitly use python3
On a distribution with no python2 installed and no python->python3 symlink the script will fail to execute. Specify python3 explicitly as it's already a requirement to build u-boot.
Signed-off-by: Jack Mitchell ml@embed.me.uk --- arch/arm/mach-rockchip/make_fit_atf.py | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-rockchip/make_fit_atf.py b/arch/arm/mach-rockchip/make_fit_atf.py index 3c045a5e17..c79317d6c5 100755 --- a/arch/arm/mach-rockchip/make_fit_atf.py +++ b/arch/arm/mach-rockchip/make_fit_atf.py @@ -1,4 +1,4 @@ -#!/usr/bin/env python +#!/usr/bin/env python3 """ # SPDX-License-Identifier: GPL-2.0+ #
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
Kever Yang
ml@embed.me.uk
