Re: [U-Boot] [PATCH] riscv: image: save space on the magic number field
On Mon, 2019-07-08 at 11:27 +0000, Chester Lin wrote:
Change the symbol from "RISCV" to "RSCV" so the magic number can be 32-bit long, which is consistent with other architectures. This change can also be compatible with grub because grub defines this field as 32-bit long.
It is incompatible with Linux kernel header. So booti will fail to work with this patch unless a corresponding patch is sent to Linux kernel.
The kernel patch should be part of 5.3-rc1 (which also includes some compatible field updates). We can revisit all of the changes together once the kernel patch is merged.
Signed-off-by: Chester Lin clin@suse.com
arch/riscv/lib/image.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/riscv/lib/image.c b/arch/riscv/lib/image.c index d063beb7df..e8a8cb7190 100644 --- a/arch/riscv/lib/image.c +++ b/arch/riscv/lib/image.c @@ -14,8 +14,8 @@
DECLARE_GLOBAL_DATA_PTR;
-/* ASCII version of "RISCV" defined in Linux kernel */ -#define LINUX_RISCV_IMAGE_MAGIC 0x5643534952 +/* ASCII version of "RSCV" defined in Linux kernel */ +#define LINUX_RISCV_IMAGE_MAGIC 0x56435352
struct linux_image_h { uint32_t code0; /* Executable code */ @@ -25,8 +25,8 @@ struct linux_image_h { uint64_t res1; /* reserved */ uint64_t res2; /* reserved */ uint64_t res3; /* reserved */
- uint64_t magic; /* Magic number */
- uint32_t res4; /* reserved */
- uint64_t res4; /* reserved */
- uint32_t magic; /* Magic number */ uint32_t res5; /* reserved */
Atish Patra
