Re: [PATCH v2][ 1/3] tbs2910: disable fuse command
Sorry, sent with wrong sender address. Please only use this address here.
Soeren
On 28.01.20 18:13, Soeren Moch wrote:
On 28.01.20 18:07, Fabio Estevam wrote:
On Tue, Jan 28, 2020 at 2:04 PM Denis 'GNUtoo' Carikli GNUtoo@cyberdimension.org wrote:
The fuse command is not needed for booting or during usual users interactions with u-boot.
As that the resulting u-boot.imx image is already very close to the size limit, removing the fuse command shouldn't hurt.
With arm-linux-gnueabi-gcc 9.2.0-1 from the Parabola GNU/Linux distribution, it shrinks the image from 392192 to 388096 bytes.
I think it would be more readable if you put the delta value instead of initial versus final.
Which is 4k, surprise, surprise, the alignment of imx files. Actually you only shrink the binary by a few bytes, which is not worth the pain it you need fuses.
Tom today merged a patch with much bigger size reduction (mentioned earlier), so this should not be required.
Soeren
Soeren Moch
