[U-Boot] [PATCH] armv8: ls2080a: Remove debug server support
Debug server feature has been dropped from roadmap.
Signed-off-by: York Sun york.sun@nxp.com ---
README | 6 - arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 5 - .../include/asm/arch-fsl-layerscape/immap_lsch3.h | 9 - board/freescale/ls2080a/ls2080a.c | 5 - board/freescale/ls2080aqds/ls2080aqds.c | 4 - board/freescale/ls2080ardb/ls2080ardb.c | 4 - drivers/misc/Makefile | 1 - drivers/misc/fsl_debug_server.c | 250 --------------------- include/configs/ls2080a_common.h | 8 +- include/fsl_debug_server.h | 32 --- 10 files changed, 1 insertion(+), 323 deletions(-) delete mode 100644 drivers/misc/fsl_debug_server.c delete mode 100644 include/fsl_debug_server.h
diff --git a/README b/README index cadb571..37c19c6 100644 --- a/README +++ b/README @@ -4946,12 +4946,6 @@ The Freescale Layerscape Debug Server Support supports the loading of "Debug Server firmware" and triggering SP boot-rom. This firmware often needs to be loaded during U-Boot booting.
-- CONFIG_FSL_DEBUG_SERVER - Enable the Debug Server for Layerscape SoCs. - -- CONFIG_SYS_DEBUG_SERVER_DRAM_BLOCK_MIN_SIZE - Define minimum DDR size required for debug server image - - CONFIG_SYS_MC_RSV_MEM_ALIGN Define alignment of reserved memory MC requires
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index e12b773..5fbd848 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -18,7 +18,6 @@ #include <asm/arch/mp.h> #endif #include <fm_eth.h> -#include <fsl_debug_server.h> #include <fsl-mc/fsl_mc.h> #ifdef CONFIG_FSL_ESDHC #include <fsl_esdhc.h> @@ -457,10 +456,6 @@ phys_size_t board_reserve_ram_top(phys_size_t ram_size) #ifdef CONFIG_SYS_MEM_TOP_HIDE #error CONFIG_SYS_MEM_TOP_HIDE not to be used together with this function #endif -/* Carve the Debug Server private DRAM block from the end of DRAM */ -#ifdef CONFIG_FSL_DEBUG_SERVER - ram_top -= debug_server_get_dram_block_size(); -#endif
/* Carve the MC private DRAM block from the end of DRAM */ #ifdef CONFIG_FSL_MC_ENET diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h index 93e26c1..7acba27 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h @@ -33,15 +33,6 @@ #define CONFIG_SYS_FSL_WRIOP1_MDIO2 (CONFIG_SYS_FSL_WRIOP1_ADDR + 0x17000) #define CONFIG_SYS_FSL_LSCH3_SERDES_ADDR (CONFIG_SYS_IMMR + 0xEA0000)
-/* SP (Cortex-A5) related */ -#define CONFIG_SYS_FSL_SP_ADDR (CONFIG_SYS_IMMR + 0x00F00000) -#define CONFIG_SYS_FSL_SP_VSG_GIC_ADDR (CONFIG_SYS_FSL_SP_ADDR) -#define CONFIG_SYS_FSL_SP_VSG_GIC_VIGR1 (CONFIG_SYS_FSL_SP_ADDR) -#define CONFIG_SYS_FSL_SP_VSG_GIC_VIGR2 \ - (CONFIG_SYS_FSL_SP_ADDR + 0x0008) -#define CONFIG_SYS_FSL_SP_LOOPBACK_DUART \ - (CONFIG_SYS_FSL_SP_ADDR + 0x1000) - #define CONFIG_SYS_FSL_DCSR_DDR_ADDR 0x70012c000ULL #define CONFIG_SYS_FSL_DCSR_DDR2_ADDR 0x70012d000ULL #define CONFIG_SYS_FSL_DCSR_DDR3_ADDR 0x700132000ULL diff --git a/board/freescale/ls2080a/ls2080a.c b/board/freescale/ls2080a/ls2080a.c index 00337d7..d0a88d4 100644 --- a/board/freescale/ls2080a/ls2080a.c +++ b/board/freescale/ls2080a/ls2080a.c @@ -12,7 +12,6 @@ #include <asm/io.h> #include <fdt_support.h> #include <libfdt.h> -#include <fsl_debug_server.h> #include <fsl-mc/fsl_mc.h> #include <environment.h> #include <asm/arch/soc.h> @@ -60,10 +59,6 @@ int dram_init(void) #if defined(CONFIG_ARCH_MISC_INIT) int arch_misc_init(void) { -#ifdef CONFIG_FSL_DEBUG_SERVER - debug_server_init(); -#endif - return 0; } #endif diff --git a/board/freescale/ls2080aqds/ls2080aqds.c b/board/freescale/ls2080aqds/ls2080aqds.c index 7d95deb..ca4a2e5 100644 --- a/board/freescale/ls2080aqds/ls2080aqds.c +++ b/board/freescale/ls2080aqds/ls2080aqds.c @@ -12,7 +12,6 @@ #include <asm/io.h> #include <fdt_support.h> #include <libfdt.h> -#include <fsl_debug_server.h> #include <fsl-mc/fsl_mc.h> #include <environment.h> #include <i2c.h> @@ -265,9 +264,6 @@ int dram_init(void) #if defined(CONFIG_ARCH_MISC_INIT) int arch_misc_init(void) { -#ifdef CONFIG_FSL_DEBUG_SERVER - debug_server_init(); -#endif #ifdef CONFIG_FSL_CAAM sec_init(); #endif diff --git a/board/freescale/ls2080ardb/ls2080ardb.c b/board/freescale/ls2080ardb/ls2080ardb.c index a65cd4a..7d8a711 100644 --- a/board/freescale/ls2080ardb/ls2080ardb.c +++ b/board/freescale/ls2080ardb/ls2080ardb.c @@ -13,7 +13,6 @@ #include <hwconfig.h> #include <fdt_support.h> #include <libfdt.h> -#include <fsl_debug_server.h> #include <fsl-mc/fsl_mc.h> #include <environment.h> #include <i2c.h> @@ -229,9 +228,6 @@ int dram_init(void) #if defined(CONFIG_ARCH_MISC_INIT) int arch_misc_init(void) { -#ifdef CONFIG_FSL_DEBUG_SERVER - debug_server_init(); -#endif #ifdef CONFIG_FSL_CAAM sec_init(); #endif diff --git a/drivers/misc/Makefile b/drivers/misc/Makefile index fff6f0c..4ddbdb3 100644 --- a/drivers/misc/Makefile +++ b/drivers/misc/Makefile @@ -16,7 +16,6 @@ obj-$(CONFIG_CROS_EC_LPC) += cros_ec_lpc.o obj-$(CONFIG_CROS_EC_I2C) += cros_ec_i2c.o obj-$(CONFIG_CROS_EC_SANDBOX) += cros_ec_sandbox.o obj-$(CONFIG_CROS_EC_SPI) += cros_ec_spi.o -obj-$(CONFIG_FSL_DEBUG_SERVER) += fsl_debug_server.o endif obj-$(CONFIG_FSL_IIM) += fsl_iim.o obj-$(CONFIG_GPIO_LED) += gpio_led.o diff --git a/drivers/misc/fsl_debug_server.c b/drivers/misc/fsl_debug_server.c deleted file mode 100644 index 98d9fbe..0000000 --- a/drivers/misc/fsl_debug_server.c +++ /dev/null @@ -1,250 +0,0 @@ -/* - * Copyright (C) 2014 Freescale Semiconductor - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <errno.h> -#include <asm/io.h> -#include <asm/system.h> - -#include <fsl-mc/fsl_mc.h> -#include <fsl_debug_server.h> - -DECLARE_GLOBAL_DATA_PTR; -static int debug_server_ver_info_maj, debug_server_ver_info_min; - -/** - * Copying Debug Server firmware to DDR - */ -static int debug_server_copy_image(const char *title, u64 image_addr, - u32 image_size, u64 debug_server_ram_addr) -{ - debug("%s copied to address %p\n", title, - (void *)debug_server_ram_addr); - memcpy((void *)debug_server_ram_addr, (void *)image_addr, image_size); - - return 0; -} - -/** - * Debug Server FIT image parser checks if the image is in FIT - * format, verifies integrity of the image and calculates - * raw image address and size values. - * - * Returns 0 if success and -1 if any of the above mentioned - * task fail. - **/ -int debug_server_parse_firmware_fit_image(const void **raw_image_addr, - size_t *raw_image_size) -{ - int format; - void *fit_hdr; - int node_offset; - const void *data; - size_t size; - const char *uname = "firmware"; - char *desc; - char *debug_server_ver_info; - char *debug_server_ver_info_major, *debug_server_ver_info_minor; - - /* Check if the image is in NOR flash */ -#ifdef CONFIG_SYS_DEBUG_SERVER_FW_IN_NOR - fit_hdr = (void *)CONFIG_SYS_DEBUG_SERVER_FW_ADDR; -#else -#error "CONFIG_SYS_DEBUG_SERVER_FW_IN_NOR not defined" -#endif - - /* Check if Image is in FIT format */ - format = genimg_get_format(fit_hdr); - if (format != IMAGE_FORMAT_FIT) { - printf("Debug Server FW: Not a FIT image\n"); - goto out_error; - } - - if (!fit_check_format(fit_hdr)) { - printf("Debug Server FW: Bad FIT image format\n"); - goto out_error; - } - - node_offset = fit_image_get_node(fit_hdr, uname); - if (node_offset < 0) { - printf("Debug Server FW:Can not find %s subimage\n", uname); - goto out_error; - } - - /* Verify Debug Server firmware image */ - if (!fit_image_verify(fit_hdr, node_offset)) { - printf("Debug Server FW: Bad Debug Server firmware hash"); - goto out_error; - } - - if (fit_get_desc(fit_hdr, node_offset, &desc) < 0) { - printf("Debug Server FW: Failed to get FW description"); - goto out_error; - } - - debug_server_ver_info = strstr(desc, "Version"); - debug_server_ver_info_major = strtok(debug_server_ver_info, "."); - debug_server_ver_info_minor = strtok(NULL, "."); - - debug_server_ver_info_maj = - simple_strtoul(debug_server_ver_info_major, NULL, 10); - debug_server_ver_info_min = - simple_strtoul(debug_server_ver_info_minor, NULL, 10); - - /* Debug server version checking */ - if ((debug_server_ver_info_maj < DEBUG_SERVER_VER_MAJOR) || - (debug_server_ver_info_min < DEBUG_SERVER_VER_MINOR)) { - printf("Debug server FW mismatches the min version required\n"); - printf("Expected:%d.%d, Got %d.%d\n", - DEBUG_SERVER_VER_MAJOR, DEBUG_SERVER_VER_MINOR, - debug_server_ver_info_maj, - debug_server_ver_info_min); - goto out_error; - } - - /* Get address and size of raw image */ - fit_image_get_data(fit_hdr, node_offset, &data, &size); - - *raw_image_addr = data; - *raw_image_size = size; - - return 0; - -out_error: - return -1; -} - -/** - * Return the actual size of the Debug Server private DRAM block. - * - * NOTE: For now this function always returns the minimum required size, - * However, in the future, the actual size may be obtained from an environment - * variable. - */ -unsigned long debug_server_get_dram_block_size(void) -{ - return CONFIG_SYS_DEBUG_SERVER_DRAM_BLOCK_MIN_SIZE; -} - -int debug_server_init(void) -{ - struct ccsr_gur __iomem *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); - int error, timeout = CONFIG_SYS_DEBUG_SERVER_TIMEOUT; - int debug_server_boot_status; - u64 debug_server_ram_addr, debug_server_ram_size; - const void *raw_image_addr; - size_t raw_image_size = 0; - - debug("debug_server_init called\n"); - /* - * The Debug Server private DRAM block was already carved at the end of - * DRAM by board_init_f() using CONFIG_SYS_MEM_TOP_HIDE: - */ - debug_server_ram_size = debug_server_get_dram_block_size(); - if (gd->bd->bi_dram[1].start) - debug_server_ram_addr = - gd->bd->bi_dram[1].start + gd->bd->bi_dram[1].size; - else - debug_server_ram_addr = - gd->bd->bi_dram[0].start + gd->bd->bi_dram[0].size; - -#ifdef CONFIG_FSL_MC_ENET - debug_server_ram_addr += mc_get_dram_block_size(); -#endif - - error = debug_server_parse_firmware_fit_image(&raw_image_addr, - &raw_image_size); - if (error != 0) - goto out; - - debug("debug server (ram addr = 0x%llx, ram size = 0x%llx)\n", - debug_server_ram_addr, debug_server_ram_size); - /* - * Load the Debug Server FW at the beginning of the Debug Server - * private DRAM block: - */ - debug_server_copy_image("Debug Server Firmware", - (u64)raw_image_addr, raw_image_size, - debug_server_ram_addr); - - /* flush dcache */ - flush_dcache_range((unsigned long)debug_server_ram_addr, - (unsigned long)debug_server_ram_addr + - (unsigned long)debug_server_ram_size); - - /* - * Tell SP that the Debug Server FW is about to be launched. Before that - * populate the following: - * 1. Write the size allocated to SP Memory region into Bits {31:16} of - * SCRATCHRW5. - * 2. Write the start address of the SP memory regions into - * SCRATCHRW5 (Bits {15:0}, contain most significant bits, Bits - * {47:32} of the SP Memory Region physical start address - * (SoC address)) and SCRATCHRW6 (Bits {31:0}). - * 3. To know the Debug Server FW boot status, set bit 0 of SCRATCHRW11 - * to 1. The Debug Server sets this to 0 to indicate a - * successul boot. - * 4. Wakeup SP by writing 0x1F to VSG GIC reg VIGR2. - */ - - /* 512 MB */ - out_le32(&gur->scratchrw[5 - 1], - (u32)((u64)debug_server_ram_addr >> 32) | (0x000D << 16)); - out_le32(&gur->scratchrw[6 - 1], - ((u32)debug_server_ram_addr) & 0xFFFFFFFF); - - out_le32(&gur->scratchrw[11 - 1], DEBUG_SERVER_INIT_STATUS); - /* Allow the changes to reflect in GUR block */ - mb(); - - /* - * Program VGIC to raise an interrupt to SP - */ - out_le32(CONFIG_SYS_FSL_SP_VSG_GIC_VIGR2, 0x1F); - /* Allow the changes to reflect in VIGR2 */ - mb(); - - dmb(); - debug("Polling for Debug server to launch ...\n"); - - while (1) { - debug_server_boot_status = in_le32(&gur->scratchrw[11 - 1]); - if (!(debug_server_boot_status & DEBUG_SERVER_INIT_STATUS_MASK)) - break; - - udelay(1); /* throttle polling */ - if (timeout-- <= 0) - break; - } - - if (timeout <= 0) { - printf("Debug Server FW timed out (boot status: 0x%x)\n", - debug_server_boot_status); - error = -ETIMEDOUT; - goto out; - } - - if (debug_server_boot_status & DEBUG_SERVER_INIT_STATUS_MASK) { - printf("Debug server FW error'ed out (boot status: 0x%x)\n", - debug_server_boot_status); - error = -ENODEV; - goto out; - } - - printf("Debug server booted\n"); - printf("Detected firmware %d.%d, (boot status: 0x0%x)\n", - debug_server_ver_info_maj, debug_server_ver_info_min, - debug_server_boot_status); - -out: - if (error != 0) - debug_server_boot_status = -error; - else - debug_server_boot_status = 0; - - return debug_server_boot_status; -} - diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index ebe1415..903f6dd 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -153,11 +153,6 @@ unsigned long long get_qixis_addr(void); #define CONFIG_SYS_NAND_BASE 0x530000000ULL #define CONFIG_SYS_NAND_BASE_PHYS 0x30000000
-/* Debug Server firmware */ -#define CONFIG_FSL_DEBUG_SERVER -/* 2 sec timeout */ -#define CONFIG_SYS_DEBUG_SERVER_TIMEOUT (2 * 1000 * 1000) - /* MC firmware */ #define CONFIG_FSL_MC_ENET /* TODO Actual DPL max length needs to be confirmed with the MC FW team */ @@ -175,8 +170,7 @@ unsigned long long get_qixis_addr(void); * It will be used by MC and Debug Server. The MC region must be * 512MB aligned, so the min size to hide is 512MB. */ -#if defined(CONFIG_FSL_MC_ENET) || defined(CONFIG_FSL_DEBUG_SERVER) -#define CONFIG_SYS_DEBUG_SERVER_DRAM_BLOCK_MIN_SIZE (254UL * 1024 * 1024) +#ifdef CONFIG_FSL_MC_ENET #define CONFIG_SYS_LS_MC_DRAM_BLOCK_MIN_SIZE (512UL * 1024 * 1024) #define CONFIG_SYS_MC_RSV_MEM_ALIGN (512UL * 1024 * 1024) #endif diff --git a/include/fsl_debug_server.h b/include/fsl_debug_server.h deleted file mode 100644 index 28d8adb..0000000 --- a/include/fsl_debug_server.h +++ /dev/null @@ -1,32 +0,0 @@ -/* - * Copyright (C) 2014 Freescale Semiconductor - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __FSL_DBG_SERVER_H__ -#define __FSL_DBG_SERVER_H__ - -#include <asm/io.h> -#include <common.h> - -/* - * Define Debug Server firmware version information - */ - -/* Major version number: incremented on API compatibility changes */ -#define DEBUG_SERVER_VER_MAJOR 0 - -/* Minor version number: incremented on API additions (backward - * compatible); reset when major version is incremented. - */ -#define DEBUG_SERVER_VER_MINOR 1 - -#define DEBUG_SERVER_INIT_STATUS (1 << 0) -#define DEBUG_SERVER_INIT_STATUS_MASK (0x00000001) - -int debug_server_init(void); -unsigned long debug_server_get_dram_block_size(void); - -#endif /* __FSL_DBG_SERVER_H__ */ -
Applied to fsl-qoriq master. Awaiting upstream.
York
York Sun
york sun
