[PATCH] doc: board: freescale: advise to use newer atf and firmware
Update branch and version information of ATF and DDR firmware files to point to latest releases provided by NXP.
This is especially critical for imx8mp evk, as the ATF support for that SoC is only available in latest releases.
Align all SoCs from imx8m family to use identical revisions of ATF and DDR firmware.
Signed-off-by: Andrey Zhizhikin andrey.zhizhikin@leica-geosystems.com --- doc/board/freescale/imx8mm_evk.rst | 10 +++++----- doc/board/freescale/imx8mn_evk.rst | 10 +++++----- doc/board/freescale/imx8mp_evk.rst | 16 ++++++++-------- doc/board/freescale/imx8mq_evk.rst | 12 ++++++------ 4 files changed, 24 insertions(+), 24 deletions(-)
diff --git a/doc/board/freescale/imx8mm_evk.rst b/doc/board/freescale/imx8mm_evk.rst index f75190227c..a9ccdb7850 100644 --- a/doc/board/freescale/imx8mm_evk.rst +++ b/doc/board/freescale/imx8mm_evk.rst @@ -18,7 +18,7 @@ Get and Build the ARM Trusted firmware
Note: builddir is U-Boot build directory (source directory for in-tree builds) Get ATF from: https://source.codeaurora.org/external/imx/imx-atf -branch: imx_4.19.35_1.0.0 +branch: imx_5.4.47_2.2.0
.. code-block:: bash
@@ -30,10 +30,10 @@ Get the ddr firmware
- $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.0.bin - $ chmod +x firmware-imx-8.0.bin - $ ./firmware-imx-8.0 - $ cp firmware-imx-8.0/firmware/ddr/synopsys/lpddr4*.bin $(builddir) + $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.9.bin + $ chmod +x firmware-imx-8.9.bin + $ ./firmware-imx-8.9 + $ cp firmware-imx-8.9/firmware/ddr/synopsys/lpddr4*.bin $(builddir)
Build U-Boot ------------ diff --git a/doc/board/freescale/imx8mn_evk.rst b/doc/board/freescale/imx8mn_evk.rst index c3e92cecee..375e0bb761 100644 --- a/doc/board/freescale/imx8mn_evk.rst +++ b/doc/board/freescale/imx8mn_evk.rst @@ -18,7 +18,7 @@ Get and Build the ARM Trusted firmware
Note: srctree is U-Boot source directory Get ATF from: https://source.codeaurora.org/external/imx/imx-atf -branch: imx_4.19.35_1.1.0 +branch: imx_5.4.47_2.2.0
- $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.5.bin - $ chmod +x firmware-imx-8.5.bin - $ ./firmware-imx-8.5 - $ cp firmware-imx-8.5/firmware/ddr/synopsys/ddr4*.bin $(srctree) + $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.9.bin + $ chmod +x firmware-imx-8.9.bin + $ ./firmware-imx-8.9 + $ cp firmware-imx-8.9/firmware/ddr/synopsys/ddr4*.bin $(srctree)
Build U-Boot ------------ diff --git a/doc/board/freescale/imx8mp_evk.rst b/doc/board/freescale/imx8mp_evk.rst index 96df6d470f..ccffcf7257 100644 --- a/doc/board/freescale/imx8mp_evk.rst +++ b/doc/board/freescale/imx8mp_evk.rst @@ -18,7 +18,7 @@ Get and Build the ARM Trusted firmware
Note: $(srctree) is the U-Boot source directory Get ATF from: https://source.codeaurora.org/external/imx/imx-atf -branch: imx_5.4.3_2.0.0 +branch: imx_5.4.47_2.2.0
@@ -30,13 +30,13 @@ Get the ddr firmware
- $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.7.bin - $ chmod +x firmware-imx-8.7.bin - $ ./firmware-imx-8.7.bin - $ cp firmware-imx-8.7/firmware/ddr/synopsys/lpddr4_pmu_train_1d_dmem_201904.bin $(srctree)/lpddr4_pmu_train_1d_dmem.bin - $ cp firmware-imx-8.7/firmware/ddr/synopsys/lpddr4_pmu_train_1d_imem_201904.bin $(srctree)/lpddr4_pmu_train_1d_imem.bin - $ cp firmware-imx-8.7/firmware/ddr/synopsys/lpddr4_pmu_train_2d_dmem_201904.bin $(srctree)/lpddr4_pmu_train_2d_dmem.bin - $ cp firmware-imx-8.7/firmware/ddr/synopsys/lpddr4_pmu_train_2d_imem_201904.bin $(srctree)/lpddr4_pmu_train_2d_imem.bin + $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.9.bin + $ chmod +x firmware-imx-8.9.bin + $ ./firmware-imx-8.9.bin + $ cp firmware-imx-8.9/firmware/ddr/synopsys/lpddr4_pmu_train_1d_dmem_201904.bin $(srctree)/lpddr4_pmu_train_1d_dmem.bin + $ cp firmware-imx-8.9/firmware/ddr/synopsys/lpddr4_pmu_train_1d_imem_201904.bin $(srctree)/lpddr4_pmu_train_1d_imem.bin + $ cp firmware-imx-8.9/firmware/ddr/synopsys/lpddr4_pmu_train_2d_dmem_201904.bin $(srctree)/lpddr4_pmu_train_2d_dmem.bin + $ cp firmware-imx-8.9/firmware/ddr/synopsys/lpddr4_pmu_train_2d_imem_201904.bin $(srctree)/lpddr4_pmu_train_2d_imem.bin
Build U-Boot ------------ diff --git a/doc/board/freescale/imx8mq_evk.rst b/doc/board/freescale/imx8mq_evk.rst index 0a64ecc5ba..c269fdebe3 100644 --- a/doc/board/freescale/imx8mq_evk.rst +++ b/doc/board/freescale/imx8mq_evk.rst @@ -18,7 +18,7 @@ Get and Build the ARM Trusted firmware
Note: srctree is U-Boot source directory Get ATF from: https://source.codeaurora.org/external/imx/imx-atf -branch: imx_4.19.35_1.0.0 +branch: imx_5.4.47_2.2.0
@@ -30,11 +30,11 @@ Get the ddr and hdmi firmware
- $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-7.9.bin - $ chmod +x firmware-imx-7.9.bin - $ ./firmware-imx-7.9.bin - $ cp firmware-imx-7.9/firmware/hdmi/cadence/signed_hdmi_imx8m.bin $(builddir) - $ cp firmware-imx-7.9/firmware/ddr/synopsys/lpddr4*.bin $(builddir) + $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.9.bin + $ chmod +x firmware-imx-8.9.bin + $ ./firmware-imx-8.9.bin + $ cp firmware-imx-8.9/firmware/hdmi/cadence/signed_hdmi_imx8m.bin $(builddir) + $ cp firmware-imx-8.9/firmware/ddr/synopsys/lpddr4*.bin $(builddir)
Hi Andrey,
On Sun, Dec 13, 2020 at 5:36 PM Andrey Zhizhikin andrey.zhizhikin@leica-geosystems.com wrote:
Reviewed-by: Fabio Estevam festevam@gmail.com
On Mon, Dec 21, 2020 at 06:31:08PM -0300, Fabio Estevam wrote:
Hi Andrey,
Is this something that should get pulled in for v2021.01? It kinda sounds like yes. Should I take this directly if so?
Hello Tom,
-----Original Message----- From: Tom Rini trini@konsulko.com Sent: Monday, December 21, 2020 10:41 PM To: Fabio Estevam festevam@gmail.com; Stefano Babic sbabic@denx.de Cc: ZHIZHIKIN Andrey andrey.zhizhikin@leica-geosystems.com; U-Boot-Denx u-boot@lists.denx.de; Peng Fan peng.fan@nxp.com Subject: Re: [PATCH] doc: board: freescale: advise to use newer atf and firmware
Hi Andrey,
I'd suggest this docs update to be taken, as the combination of ATF and DDR firmware recorded there is known to be working for those i.MX8M derivatives.
I've also realized that there is a newer version of ATF available from NXP on codeaurora, but according to the last mail from Fabio - it is not bootable, and I haven't tried it myself yet.
I guess for the upcoming 2021.01 this documentation update would be quite helpful, as there has been few reports on the list that people tried to use outdated instructions and were not able to produce a boot container for i.MX8M Nano and Plus SOCs due to a newer version of ATF was required.
-- Tom
-- andrey
Hi Tom,
Yes, it would be nice to have this pulled in for v2021.01.
Thanks
Subject: [PATCH] doc: board: freescale: advise to use newer atf and firmware
Thanks for the effort.
Reviewed-by: Peng Fan peng.fan@nxp.com
Note: builddir is U-Boot build directory (source directory for in-tree builds) Get ATF from: https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fsource .codeaurora.org%2Fexternal%2Fimx%2Fimx-atf&data=04%7C01%7Cpen g.fan%40nxp.com%7C17ea116c2ca44f3ee06008d89fa6bf7d%7C686ea1d3bc 2b4c6fa92cd99c5c301635%7C0%7C0%7C637434885818043019%7CUnknow n%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1ha WwiLCJXVCI6Mn0%3D%7C1000&sdata=JB5DHy0ymYFYB3JN4J%2FWS3 WNBtwIIi7Zj0uNgu793fc%3D&reserved=0 -branch: imx_4.19.35_1.0.0 +branch: imx_5.4.47_2.2.0
- $ wget
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww. nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2Ffirmware-imx-8.0.bin&a mp;data=04%7C01%7Cpeng.fan%40nxp.com%7C17ea116c2ca44f3ee06008d 89fa6bf7d%7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0%7C0%7C6374348 85818043019%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJ QIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=TsZF LW7w5c2tOeaB9kK5RC5V9%2BvvTfMTI7fidA1kH%2Bc%3D&reserved=0
- $ wget
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww. nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2Ffirmware-imx-8.9.bin&a mp;data=04%7C01%7Cpeng.fan%40nxp.com%7C17ea116c2ca44f3ee06008d 89fa6bf7d%7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0%7C0%7C6374348 85818043019%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJ QIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=5vP4 2YnY58cCWV5cIc3X8eQJ%2F%2FACKikIrRxPXjaweSQ%3D&reserved=0
- $ chmod +x firmware-imx-8.9.bin
- $ ./firmware-imx-8.9
- $ cp firmware-imx-8.9/firmware/ddr/synopsys/lpddr4*.bin $(builddir)
Build U-Boot
Note: srctree is U-Boot source directory Get ATF from: https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fsource .codeaurora.org%2Fexternal%2Fimx%2Fimx-atf&data=04%7C01%7Cpen g.fan%40nxp.com%7C17ea116c2ca44f3ee06008d89fa6bf7d%7C686ea1d3bc 2b4c6fa92cd99c5c301635%7C0%7C0%7C637434885818043019%7CUnknow n%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1ha WwiLCJXVCI6Mn0%3D%7C1000&sdata=JB5DHy0ymYFYB3JN4J%2FWS3 WNBtwIIi7Zj0uNgu793fc%3D&reserved=0 -branch: imx_4.19.35_1.1.0 +branch: imx_5.4.47_2.2.0
- $ wget
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww. nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2Ffirmware-imx-8.5.bin&a mp;data=04%7C01%7Cpeng.fan%40nxp.com%7C17ea116c2ca44f3ee06008d 89fa6bf7d%7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0%7C0%7C6374348 85818043019%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJ QIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=2fTO 1XnVhcrXUIjNnP%2Bblgx7BB%2FuqUECFZjZeaPg9Xo%3D&reserved=0
- $ wget
- $ cp firmware-imx-8.9/firmware/ddr/synopsys/ddr4*.bin $(srctree)
Build U-Boot
Note: $(srctree) is the U-Boot source directory Get ATF from: https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fsource .codeaurora.org%2Fexternal%2Fimx%2Fimx-atf&data=04%7C01%7Cpen g.fan%40nxp.com%7C17ea116c2ca44f3ee06008d89fa6bf7d%7C686ea1d3bc 2b4c6fa92cd99c5c301635%7C0%7C0%7C637434885818043019%7CUnknow n%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1ha WwiLCJXVCI6Mn0%3D%7C1000&sdata=JB5DHy0ymYFYB3JN4J%2FWS3 WNBtwIIi7Zj0uNgu793fc%3D&reserved=0 -branch: imx_5.4.3_2.0.0 +branch: imx_5.4.47_2.2.0
- $ wget
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww. nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2Ffirmware-imx-8.7.bin&a mp;data=04%7C01%7Cpeng.fan%40nxp.com%7C17ea116c2ca44f3ee06008d 89fa6bf7d%7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0%7C0%7C6374348 85818043019%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJ QIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=gh07 U0uSMCibDEyXoaRxd%2Fb1c5gPTDWH7fveAMZWF8Q%3D&reserved=0
- $ cp
firmware-imx-8.7/firmware/ddr/synopsys/lpddr4_pmu_train_1d_dmem_201 904.bin $(srctree)/lpddr4_pmu_train_1d_dmem.bin
- $ cp
firmware-imx-8.7/firmware/ddr/synopsys/lpddr4_pmu_train_1d_imem_2019 04.bin $(srctree)/lpddr4_pmu_train_1d_imem.bin
- $ cp
firmware-imx-8.7/firmware/ddr/synopsys/lpddr4_pmu_train_2d_dmem_201 904.bin $(srctree)/lpddr4_pmu_train_2d_dmem.bin
- $ cp
firmware-imx-8.7/firmware/ddr/synopsys/lpddr4_pmu_train_2d_imem_2019 04.bin $(srctree)/lpddr4_pmu_train_2d_imem.bin
- $ wget
- $ ./firmware-imx-8.9.bin
- $ cp
firmware-imx-8.9/firmware/ddr/synopsys/lpddr4_pmu_train_1d_dmem_201 904.bin $(srctree)/lpddr4_pmu_train_1d_dmem.bin
- $ cp
firmware-imx-8.9/firmware/ddr/synopsys/lpddr4_pmu_train_1d_imem_2019 04.bin $(srctree)/lpddr4_pmu_train_1d_imem.bin
- $ cp
firmware-imx-8.9/firmware/ddr/synopsys/lpddr4_pmu_train_2d_dmem_201 904.bin $(srctree)/lpddr4_pmu_train_2d_dmem.bin
- $ cp
firmware-imx-8.9/firmware/ddr/synopsys/lpddr4_pmu_train_2d_imem_2019 04
- .bin $(srctree)/lpddr4_pmu_train_2d_imem.bin
Build U-Boot
Note: srctree is U-Boot source directory Get ATF from: https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fsource .codeaurora.org%2Fexternal%2Fimx%2Fimx-atf&data=04%7C01%7Cpen g.fan%40nxp.com%7C17ea116c2ca44f3ee06008d89fa6bf7d%7C686ea1d3bc 2b4c6fa92cd99c5c301635%7C0%7C0%7C637434885818043019%7CUnknow n%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1ha WwiLCJXVCI6Mn0%3D%7C1000&sdata=JB5DHy0ymYFYB3JN4J%2FWS3 WNBtwIIi7Zj0uNgu793fc%3D&reserved=0 -branch: imx_4.19.35_1.0.0 +branch: imx_5.4.47_2.2.0
- $ wget
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww. nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2Ffirmware-imx-7.9.bin&a mp;data=04%7C01%7Cpeng.fan%40nxp.com%7C17ea116c2ca44f3ee06008d 89fa6bf7d%7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0%7C0%7C6374348 85818053014%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJ QIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=PESa EwYork7GTo%2Fw8dqpB85yntYvhpu4R26bW40Au8U%3D&reserved=0
$(builddir)
- $ wget
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww. nxp.com%2Flgfiles%2FNMG%2FMAD%2FYOCTO%2Ffirmware-imx-8.9.bin&a mp;data=04%7C01%7Cpeng.fan%40nxp.com%7C17ea116c2ca44f3ee06008d 89fa6bf7d%7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0%7C0%7C6374348 85818053014%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJ QIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=W1v eu%2BLnADW6VxKEMxai%2FFxQXfRibSIn%2B3mD0WnCtyA%3D&reserv ed=0
- $ cp
Build U-Boot
-- 2.17.1
Signed-off-by: Andrey Zhizhikin andrey.zhizhikin@leica-geosystems.com Reviewed-by: Fabio Estevam festevam@gmail.com Reviewed-by: Peng Fan peng.fan@nxp.com
participants (5)
Andrey Zhizhikin
Fabio Estevam
Peng Fan
ZHIZHIKIN Andrey
