[U-Boot] [PATCH v6 0/4] OMAP: SPL networking support
These series provides support for networking in SPL. In this version some effort is done to minimize the resulting SPL size and now Net-only SPL is <50KB in size. So theoretically it can be used on boards with enough SRAM space like AM3517. But real testing was done only on AM335x.
Changes in v3: - use BOOTP in SPL regardless of CONFIG_CMD_DHCP - add support for setting different VCI in SPL - set Vendor Class Identifier for SPL
Changes in v4: - used strlen instead of sizeof - moved vci_strlen var inside macro - fix compilation of SPL's libcommon with CONFIG_HUSH_PARSER and CONFIG_BOOTD defined - rename spl_eth.c to spl_net.c - set ethact variable if device name is passed - SPL_BOARD_INIT is not needed anymore
Changes in v5: - set up guards in cmd_nvedit.c more carefully - now we don't need command.c and only need main.c for show_boot_progress() so defined it to be noop and remove both files from SPL sources - SPL guards in command.c and main.c are no longer needed - add some guards in env_common.c - qsort.c is no longer needed - add guard to hashtable.c to save some space - undefine unneeded CONFIG_CMD_* while building SPL to save space
Changes in v6: - fix typo in patch name - remove some unneeded changes introduced by earlier versions - switch clauses and use ifdef instead of ifndef - create new header config_uncmd_spl.h which undefines CONFIG_CMD_* options unneeded in SPL and include it last from config.h - remove explicit undefs from net/net.c and net/bootp.c
Ilya Yanok (4): net/bootp: add VCI support for BOOTP also OMAP: spl: call timer_init() from SPL OMAP: networking support for SPL am335x_evm: enable networking in SPL
arch/arm/cpu/armv7/omap-common/Makefile | 3 ++ arch/arm/cpu/armv7/omap-common/spl.c | 11 +++++++ arch/arm/cpu/armv7/omap-common/spl_net.c | 52 ++++++++++++++++++++++++++++++ arch/arm/include/asm/omap_common.h | 4 +++ common/Makefile | 4 +++ common/cmd_nvedit.c | 8 +++++ common/env_common.c | 7 ++-- include/bootstage.h | 6 +++- include/config_uncmd_spl.h | 24 ++++++++++++++ include/configs/am335x_evm.h | 5 ++- lib/Makefile | 9 ++++-- lib/hashtable.c | 2 ++ lib/vsprintf.c | 2 +- mkconfig | 1 + net/bootp.c | 27 ++++++++++++---- net/tftp.c | 4 +++ spl/Makefile | 3 ++ 17 files changed, 159 insertions(+), 13 deletions(-) create mode 100644 arch/arm/cpu/armv7/omap-common/spl_net.c create mode 100644 include/config_uncmd_spl.h
Vendor Class Identifier option is common to BOOTP and DHCP and can be useful without PXE. So send VCI in both BOOTP and DHCP requests if CONFIG_BOOTP_VCI_STRING is defined.
Signed-off-by: Ilya Yanok ilya.yanok@cogentembedded.com
--- Changes in v4: - used strlen instead of sizeof - moved vci_strlen var inside macro
net/bootp.c | 22 ++++++++++++++++------ 1 file changed, 16 insertions(+), 6 deletions(-)
diff --git a/net/bootp.c b/net/bootp.c index c9b8349..35b2e77 100644 --- a/net/bootp.c +++ b/net/bootp.c @@ -341,6 +341,15 @@ BootpTimeout(void) } }
+#define put_vci(e, str) \ + do { \ + size_t vci_strlen = strlen(str); \ + *e++ = 60; /* Vendor Class Identifier */ \ + *e++ = vci_strlen; \ + memcpy(e, str, vci_strlen); \ + e += vci_strlen; \ + } while (0) + /* * Initialize BOOTP extension fields in the request. */ @@ -352,7 +361,6 @@ static int DhcpExtended(u8 *e, int message_type, IPaddr_t ServerID, u8 *cnt; #if defined(CONFIG_BOOTP_PXE) char *uuid; - size_t vci_strlen; u16 clientarch; #endif
@@ -437,12 +445,10 @@ static int DhcpExtended(u8 *e, int message_type, IPaddr_t ServerID, printf("Invalid pxeuuid: %s\n", uuid); } } +#endif
- *e++ = 60; /* Vendor Class Identifier */ - vci_strlen = strlen(CONFIG_BOOTP_VCI_STRING); - *e++ = vci_strlen; - memcpy(e, CONFIG_BOOTP_VCI_STRING, vci_strlen); - e += vci_strlen; +#ifdef CONFIG_BOOTP_VCI_STRING + put_vci(e, CONFIG_VCI_STRING); #endif
#if defined(CONFIG_BOOTP_VENDOREX) @@ -529,6 +535,10 @@ static int BootpExtended(u8 *e) *e++ = (576 - 312 + OPT_FIELD_SIZE) & 0xff; #endif
+#ifdef CONFIG_BOOTP_VCI_STRING + put_vci(e, CONFIG_VCI_STRING); +#endif + #if defined(CONFIG_BOOTP_SUBNETMASK) *e++ = 1; /* Subnet mask request */ *e++ = 4;
We need to initialize timer properly, otherwise all delays inside SPL will be wrong.
--- Changes in v6: - fix typo in patch name
arch/arm/cpu/armv7/omap-common/spl.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/cpu/armv7/omap-common/spl.c b/arch/arm/cpu/armv7/omap-common/spl.c index 4d1ac85..f0d766c 100644 --- a/arch/arm/cpu/armv7/omap-common/spl.c +++ b/arch/arm/cpu/armv7/omap-common/spl.c @@ -152,6 +152,8 @@ void board_init_r(gd_t *id, ulong dummy) mem_malloc_init(CONFIG_SYS_SPL_MALLOC_START, CONFIG_SYS_SPL_MALLOC_SIZE);
+ timer_init(); + #ifdef CONFIG_SPL_BOARD_INIT spl_board_init(); #endif
This patch adds support for networking in SPL. Some devices are capable of loading SPL via network so it makes sense to load the main U-Boot binary via network too. This patch tries to use existing network code as much as possible. Unfortunately, it depends on environment which in turn depends on other code so SPL size is increased significantly. No effort was done to decouple network code and environment so far.
--- Changes in v3: - use BOOTP in SPL regardless of CONFIG_CMD_DHCP - add support for setting different VCI in SPL
Changes in v4: - fix compilation of SPL's libcommon with CONFIG_HUSH_PARSER and CONFIG_BOOTD defined - rename spl_eth.c to spl_net.c - set ethact variable if device name is passed
Changes in v6: - remove some unneeded changes introduced by earlier versions - switch clauses and use ifdef instead of ifndef - create new header config_uncmd_spl.h which undefines CONFIG_CMD_* options unneeded in SPL and include it last from config.h - remove explicit undefs from net/net.c and net/bootp.c
arch/arm/cpu/armv7/omap-common/Makefile | 3 ++ arch/arm/cpu/armv7/omap-common/spl.c | 9 ++++++ arch/arm/cpu/armv7/omap-common/spl_net.c | 52 ++++++++++++++++++++++++++++++ arch/arm/include/asm/omap_common.h | 4 +++ common/Makefile | 4 +++ common/cmd_nvedit.c | 8 +++++ common/env_common.c | 7 ++-- include/bootstage.h | 6 +++- include/config_uncmd_spl.h | 24 ++++++++++++++ lib/Makefile | 9 ++++-- lib/hashtable.c | 2 ++ lib/vsprintf.c | 2 +- mkconfig | 1 + net/bootp.c | 7 +++- net/tftp.c | 4 +++ spl/Makefile | 3 ++ 16 files changed, 138 insertions(+), 7 deletions(-) create mode 100644 arch/arm/cpu/armv7/omap-common/spl_net.c create mode 100644 include/config_uncmd_spl.h
diff --git a/arch/arm/cpu/armv7/omap-common/Makefile b/arch/arm/cpu/armv7/omap-common/Makefile index d37b22d..f042078 100644 --- a/arch/arm/cpu/armv7/omap-common/Makefile +++ b/arch/arm/cpu/armv7/omap-common/Makefile @@ -53,6 +53,9 @@ endif ifdef CONFIG_SPL_YMODEM_SUPPORT COBJS += spl_ymodem.o endif +ifdef CONFIG_SPL_NET_SUPPORT +COBJS += spl_net.o +endif endif
ifndef CONFIG_SPL_BUILD diff --git a/arch/arm/cpu/armv7/omap-common/spl.c b/arch/arm/cpu/armv7/omap-common/spl.c index f0d766c..53b9261 100644 --- a/arch/arm/cpu/armv7/omap-common/spl.c +++ b/arch/arm/cpu/armv7/omap-common/spl.c @@ -178,6 +178,15 @@ void board_init_r(gd_t *id, ulong dummy) spl_ymodem_load_image(); break; #endif +#ifdef CONFIG_SPL_ETH_SUPPORT + case BOOT_DEVICE_CPGMAC: +#ifdef CONFIG_SPL_ETH_DEVICE + spl_net_load_image(CONFIG_SPL_ETH_DEVICE); +#else + spl_net_load_image(NULL); +#endif + break; +#endif default: printf("SPL: Un-supported Boot Device - %d!!!\n", boot_device); hang(); diff --git a/arch/arm/cpu/armv7/omap-common/spl_net.c b/arch/arm/cpu/armv7/omap-common/spl_net.c new file mode 100644 index 0000000..cbb3087 --- /dev/null +++ b/arch/arm/cpu/armv7/omap-common/spl_net.c @@ -0,0 +1,52 @@ +/* + * (C) Copyright 2000-2004 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * (C) Copyright 2012 + * Ilya Yanok ilya.yanok@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc. + */ +#include <common.h> +#include <net.h> +#include <asm/omap_common.h> + +DECLARE_GLOBAL_DATA_PTR; + +void spl_net_load_image(const char *device) +{ + int rv; + + env_init(); + env_relocate(); + setenv("autoload", "yes"); + load_addr = CONFIG_SYS_TEXT_BASE - sizeof(struct image_header); + rv = eth_initialize(gd->bd); + if (rv == 0) { + printf("No Ethernet devices found\n"); + hang(); + } + if (device) + setenv("ethact", device); + rv = NetLoop(BOOTP); + if (rv < 0) { + printf("Problem booting with BOOTP\n"); + hang(); + } + spl_parse_image_header((struct image_header *)load_addr); +} diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index 71ef9b0..dcccb94 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -69,6 +69,7 @@ void preloader_console_init(void); #define BOOT_DEVICE_MMC1 8 #define BOOT_DEVICE_MMC2 9 /* eMMC or daughter card */ #define BOOT_DEVICE_UART 65 +#define BOOT_DEVICE_CPGMAC 70 #define BOOT_DEVICE_MMC2_2 0xFF #endif
@@ -107,6 +108,9 @@ void spl_mmc_load_image(void); /* YMODEM SPL functions */ void spl_ymodem_load_image(void);
+/* Ethernet SPL functions */ +void spl_net_load_image(const char *device); + #ifdef CONFIG_SPL_BOARD_INIT void spl_board_init(void); #endif diff --git a/common/Makefile b/common/Makefile index 57da76f..cfa7401 100644 --- a/common/Makefile +++ b/common/Makefile @@ -189,6 +189,10 @@ endif
ifdef CONFIG_SPL_BUILD COBJS-$(CONFIG_SPL_YMODEM_SUPPORT) += xyzModem.o +COBJS-$(CONFIG_SPL_NET_SUPPORT) += cmd_nvedit.o +COBJS-$(CONFIG_SPL_NET_SUPPORT) += env_common.o +COBJS-$(CONFIG_SPL_NET_SUPPORT) += env_nowhere.o +COBJS-$(CONFIG_SPL_NET_SUPPORT) += miiphyutil.o endif COBJS-y += console.o COBJS-y += dlmalloc.o diff --git a/common/cmd_nvedit.c b/common/cmd_nvedit.c index fd05e72..09ea72c 100644 --- a/common/cmd_nvedit.c +++ b/common/cmd_nvedit.c @@ -103,6 +103,7 @@ int get_env_id(void) return env_id; }
+#ifndef CONFIG_SPL_BUILD /* * Command interface: print one or all environment variables * @@ -196,6 +197,7 @@ static int do_env_grep(cmd_tbl_t *cmdtp, int flag, return rcode; } #endif +#endif /* CONFIG_SPL_BUILD */
/* * Set a new environment variable, @@ -394,6 +396,7 @@ int setenv_addr(const char *varname, const void *addr) return setenv(varname, str); }
+#ifndef CONFIG_SPL_BUILD int do_env_set(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { if (argc < 2) @@ -493,6 +496,7 @@ int do_env_edit(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return setenv(argv[1], buffer); } #endif /* CONFIG_CMD_EDITENV */ +#endif /* CONFIG_SPL_BUILD */
/* * Look up variable from environment, @@ -578,6 +582,7 @@ ulong getenv_ulong(const char *name, int base, ulong default_val) return str ? simple_strtoul(str, NULL, base) : default_val; }
+#ifndef CONFIG_SPL_BUILD #if defined(CONFIG_CMD_SAVEENV) && !defined(CONFIG_ENV_IS_NOWHERE) int do_env_save(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { @@ -592,6 +597,7 @@ U_BOOT_CMD( "" ); #endif +#endif /* CONFIG_SPL_BUILD */
/* @@ -613,6 +619,7 @@ int envmatch(uchar *s1, int i2) return -1; }
+#ifndef CONFIG_SPL_BUILD static int do_env_default(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { @@ -1038,3 +1045,4 @@ U_BOOT_CMD_COMPLETE( var_complete ); #endif +#endif /* CONFIG_SPL_BUILD */ diff --git a/common/env_common.c b/common/env_common.c index d9e990d..fdd40b0 100644 --- a/common/env_common.c +++ b/common/env_common.c @@ -199,6 +199,7 @@ void set_default_env(const char *s) gd->flags |= GD_FLG_ENV_READY; }
+#ifndef CONFIG_SPL_BUILD /* * Check if CRC is valid and (if yes) import the environment. * Note that "buf" may or may not be aligned. @@ -229,6 +230,7 @@ int env_import(const char *buf, int check)
return 0; } +#endif
void env_relocate(void) { @@ -236,7 +238,8 @@ void env_relocate(void) env_reloc(); #endif if (gd->env_valid == 0) { -#if defined(CONFIG_ENV_IS_NOWHERE) /* Environment not changable */ +#if defined(CONFIG_ENV_IS_NOWHERE) || defined(CONFIG_SPL_BUILD) + /* Environment not changable */ set_default_env(NULL); #else bootstage_error(BOOTSTAGE_ID_NET_CHECKSUM); @@ -247,7 +250,7 @@ void env_relocate(void) } }
-#ifdef CONFIG_AUTO_COMPLETE +#if defined(CONFIG_AUTO_COMPLETE) && !defined(CONFIG_SPL_BUILD) int env_complete(char *var, int maxv, char *cmdv[], int bufsz, char *buf) { ENTRY *match; diff --git a/include/bootstage.h b/include/bootstage.h index a000538..db94a95 100644 --- a/include/bootstage.h +++ b/include/bootstage.h @@ -210,6 +210,7 @@ enum bootstage_id { */ ulong timer_get_boot_us(void);
+#ifndef CONFIG_SPL_BUILD /* * Board code can implement show_boot_progress() if needed. * @@ -217,8 +218,11 @@ ulong timer_get_boot_us(void); * has occurred. */ void show_boot_progress(int val); +#else +#define show_boot_progress(val) do {} while (0) +#endif
-#ifdef CONFIG_BOOTSTAGE +#if defined(CONFIG_BOOTSTAGE) && !defined(CONFIG_SPL_BUILD) /* This is the full bootstage implementation */
/* diff --git a/include/config_uncmd_spl.h b/include/config_uncmd_spl.h new file mode 100644 index 0000000..8ad6045 --- /dev/null +++ b/include/config_uncmd_spl.h @@ -0,0 +1,24 @@ +/* + * We don't use any commands in SPL, but generic networking code + * has some features enabled/disabled based on CONFIG_CMD_* + * options. As we want a minimal set of features included + * into network SPL image, we undefine some config options here. + */ + +#ifndef __CONFIG_UNCMD_SPL_H__ +#define __CONFIG_UNCMD_SPL_H__ + +#ifdef CONFIG_SPL_BUILD +/* SPL needs only BOOTP + TFTP so undefine other stuff to save space */ +#undef CONFIG_CMD_CDP +#undef CONFIG_CMD_DHCP +#undef CONFIG_CMD_DNS +#undef CONFIG_CMD_LINK_LOCAL +#undef CONFIG_CMD_NFS +#undef CONFIG_CMD_PING +#undef CONFIG_CMD_RARP +#undef CONFIG_CMD_SNTP +#undef CONFIG_CMD_TFTPPUT +#undef CONFIG_CMD_TFTPSRV +#endif /* CONFIG_SPL_BUILD */ +#endif /* __CONFIG_UNCMD_SPL_H__ */ diff --git a/lib/Makefile b/lib/Makefile index c60c380..ee10738 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -52,12 +52,17 @@ COBJS-$(CONFIG_SHA1) += sha1.o COBJS-$(CONFIG_SHA256) += sha256.o COBJS-y += strmhz.o COBJS-$(CONFIG_RBTREE) += rbtree.o -else -COBJS-$(CONFIG_SPL_SPI_FLASH_SUPPORT) += display_options.o endif
ifdef CONFIG_SPL_BUILD COBJS-$(CONFIG_SPL_YMODEM_SUPPORT) += crc16.o +COBJS-$(CONFIG_SPL_NET_SUPPORT) += crc32.o +ifneq ($(CONFIG_SPL_SPI_FLASH_SUPPORT)$(CONFIG_SPL_NET_SUPPORT),) +COBJS-y += display_options.o +endif +COBJS-$(CONFIG_SPL_NET_SUPPORT) += errno.o +COBJS-$(CONFIG_SPL_NET_SUPPORT) += hashtable.o +COBJS-$(CONFIG_SPL_NET_SUPPORT) += net_utils.o endif COBJS-y += crc32.o COBJS-y += ctype.o diff --git a/lib/hashtable.c b/lib/hashtable.c index abd61c8..755f8b3 100644 --- a/lib/hashtable.c +++ b/lib/hashtable.c @@ -431,6 +431,7 @@ int hdelete_r(const char *key, struct hsearch_data *htab) * hexport() */
+#ifndef CONFIG_SPL_BUILD /* * Export the data stored in the hash table in linearized form. * @@ -597,6 +598,7 @@ ssize_t hexport_r(struct hsearch_data *htab, const char sep,
return size; } +#endif
/* diff --git a/lib/vsprintf.c b/lib/vsprintf.c index e38a4b7..6bb819c 100644 --- a/lib/vsprintf.c +++ b/lib/vsprintf.c @@ -784,7 +784,7 @@ void panic(const char *fmt, ...) vprintf(fmt, args); putc('\n'); va_end(args); -#if defined (CONFIG_PANIC_HANG) +#if defined (CONFIG_PANIC_HANG) || defined(CONFIG_SPL_BUILD) hang(); #else udelay (100000); /* allow messages to go out */ diff --git a/mkconfig b/mkconfig index d3363c6..7c9aa74 100755 --- a/mkconfig +++ b/mkconfig @@ -185,6 +185,7 @@ cat << EOF >> config.h #include <configs/${CONFIG_NAME}.h> #include <asm/config.h> #include <config_fallbacks.h> +#include <config_uncmd_spl.h> EOF
exit 0 diff --git a/net/bootp.c b/net/bootp.c index 35b2e77..61c9c9f 100644 --- a/net/bootp.c +++ b/net/bootp.c @@ -535,9 +535,14 @@ static int BootpExtended(u8 *e) *e++ = (576 - 312 + OPT_FIELD_SIZE) & 0xff; #endif
-#ifdef CONFIG_BOOTP_VCI_STRING +#if defined(CONFIG_BOOTP_VCI_STRING) || \ + (defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_NET_VCI_STRING)) +#ifdef CONFIG_SPL_BUILD + put_vci(e, CONFIG_SPL_NET_VCI_STRING); +#else put_vci(e, CONFIG_VCI_STRING); #endif +#endif
#if defined(CONFIG_BOOTP_SUBNETMASK) *e++ = 1; /* Subnet mask request */ diff --git a/net/tftp.c b/net/tftp.c index 59a8ebb..baba8f3 100644 --- a/net/tftp.c +++ b/net/tftp.c @@ -7,6 +7,10 @@ */
#include <common.h> +#ifdef CONFIG_SPL_BUILD +#undef CONFIG_CMD_TFTPPUT +#undef CONFIG_CMD_TFTPSRV +#endif #include <command.h> #include <net.h> #include "tftp.h" diff --git a/spl/Makefile b/spl/Makefile index 476a5e6..f252e9b 100644 --- a/spl/Makefile +++ b/spl/Makefile @@ -56,6 +56,9 @@ LIBS-$(CONFIG_SPL_NAND_SUPPORT) += drivers/mtd/nand/libnand.o LIBS-$(CONFIG_SPL_ONENAND_SUPPORT) += drivers/mtd/onenand/libonenand.o LIBS-$(CONFIG_SPL_DMA_SUPPORT) += drivers/dma/libdma.o LIBS-$(CONFIG_SPL_POST_MEM_SUPPORT) += post/drivers/memory.o +LIBS-$(CONFIG_SPL_NET_SUPPORT) += net/libnet.o +LIBS-$(CONFIG_SPL_ETH_SUPPORT) += drivers/net/libnet.o +LIBS-$(CONFIG_SPL_ETH_SUPPORT) += drivers/net/phy/libphy.o
ifneq ($(CONFIG_AM33XX)$(CONFIG_OMAP34XX)$(CONFIG_OMAP44XX)$(CONFIG_OMAP54XX),) LIBS-y += $(CPUDIR)/omap-common/libomap-common.o
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
[snip]
Please add a GPLv2+ header to the file, thanks.
Oh no, this change... Do we still really need this?
Missed this.
Also I saw a few manual inclusions of <config_uncmd_spl.h>, please fix those since mkconfig adds it always. Thanks.
- -- Tom
Changes in v7: - remove explicit cmd undef from net/tftp.c also - add GPLv2 header to config_uncmd_spl.h - remove CONFIG_SPL_BUILD clause at hang() (not needed)
arch/arm/cpu/armv7/omap-common/Makefile | 3 ++ arch/arm/cpu/armv7/omap-common/spl.c | 9 ++++++ arch/arm/cpu/armv7/omap-common/spl_net.c | 52 ++++++++++++++++++++++++++++++ arch/arm/include/asm/omap_common.h | 4 +++ common/Makefile | 4 +++ common/cmd_nvedit.c | 8 +++++ common/env_common.c | 7 ++-- include/bootstage.h | 6 +++- include/config_uncmd_spl.h | 44 +++++++++++++++++++++++++ lib/Makefile | 9 ++++-- lib/hashtable.c | 2 ++ mkconfig | 1 + net/bootp.c | 7 +++- spl/Makefile | 3 ++ 14 files changed, 153 insertions(+), 6 deletions(-) create mode 100644 arch/arm/cpu/armv7/omap-common/spl_net.c create mode 100644 include/config_uncmd_spl.h
return 0; } +#endif
/* diff --git a/include/config_uncmd_spl.h b/include/config_uncmd_spl.h new file mode 100644 index 0000000..bab3ddf --- /dev/null +++ b/include/config_uncmd_spl.h @@ -0,0 +1,44 @@ +/* + * (C) Copyright 2012 + * Ilya Yanok, ilya.yanok@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc. + * + * We don't use any commands in SPL, but generic networking code + * has some features enabled/disabled based on CONFIG_CMD_* + * options. As we want a minimal set of features included + * into network SPL image, we undefine some config options here. + */ + +#ifndef __CONFIG_UNCMD_SPL_H__ +#define __CONFIG_UNCMD_SPL_H__ + +#ifdef CONFIG_SPL_BUILD +/* SPL needs only BOOTP + TFTP so undefine other stuff to save space */ +#undef CONFIG_CMD_CDP +#undef CONFIG_CMD_DHCP +#undef CONFIG_CMD_DNS +#undef CONFIG_CMD_LINK_LOCAL +#undef CONFIG_CMD_NFS +#undef CONFIG_CMD_PING +#undef CONFIG_CMD_RARP +#undef CONFIG_CMD_SNTP +#undef CONFIG_CMD_TFTPPUT +#undef CONFIG_CMD_TFTPSRV +#endif /* CONFIG_SPL_BUILD */ +#endif /* __CONFIG_UNCMD_SPL_H__ */ diff --git a/lib/Makefile b/lib/Makefile index c60c380..ee10738 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -52,12 +52,17 @@ COBJS-$(CONFIG_SHA1) += sha1.o COBJS-$(CONFIG_SHA256) += sha256.o COBJS-y += strmhz.o COBJS-$(CONFIG_RBTREE) += rbtree.o -else -COBJS-$(CONFIG_SPL_SPI_FLASH_SUPPORT) += display_options.o endif
/* diff --git a/mkconfig b/mkconfig index d3363c6..7c9aa74 100755 --- a/mkconfig +++ b/mkconfig @@ -185,6 +185,7 @@ cat << EOF >> config.h #include <configs/${CONFIG_NAME}.h> #include <asm/config.h> #include <config_fallbacks.h> +#include <config_uncmd_spl.h> EOF
#if defined(CONFIG_BOOTP_SUBNETMASK) *e++ = 1; /* Subnet mask request */ diff --git a/spl/Makefile b/spl/Makefile index 476a5e6..f252e9b 100644 --- a/spl/Makefile +++ b/spl/Makefile @@ -56,6 +56,9 @@ LIBS-$(CONFIG_SPL_NAND_SUPPORT) += drivers/mtd/nand/libnand.o LIBS-$(CONFIG_SPL_ONENAND_SUPPORT) += drivers/mtd/onenand/libonenand.o LIBS-$(CONFIG_SPL_DMA_SUPPORT) += drivers/dma/libdma.o LIBS-$(CONFIG_SPL_POST_MEM_SUPPORT) += post/drivers/memory.o +LIBS-$(CONFIG_SPL_NET_SUPPORT) += net/libnet.o +LIBS-$(CONFIG_SPL_ETH_SUPPORT) += drivers/net/libnet.o +LIBS-$(CONFIG_SPL_ETH_SUPPORT) += drivers/net/phy/libphy.o
Hi Ilya,
On Tue, Sep 18, 2012 at 5:22 AM, Ilya Yanok ilya.yanok@cogentembedded.com wrote:
Changes in v3:
Changes in v4:
Changes in v5:
Changes in v6:
Changes in v7:
Hi Tom,
Done.
Seems like it's not needed anymore. I've removed it.
Missed this.
Yes, sorry.
Hm, I can't see any.
I reposted only this patch. Hope it's ok now.
Regards, Ilya.
This patch adds support for networking in SPL on TI AM335x based boards. Vendor Class Identifier used by SPL during BOOTP is "AM335x U-Boot SPL".
--- Changes in v3: - set Vendor Class Identifier for SPL
Changes in v4: - SPL_BOARD_INIT is not needed anymore
include/configs/am335x_evm.h | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index a3752bc..1d69125 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -194,7 +194,7 @@ /* Defines for SPL */ #define CONFIG_SPL #define CONFIG_SPL_TEXT_BASE 0x402F0400 -#define CONFIG_SPL_MAX_SIZE (46 * 1024) +#define CONFIG_SPL_MAX_SIZE (101 * 1024) #define CONFIG_SPL_STACK CONFIG_SYS_INIT_SP_ADDR
#define CONFIG_SPL_BSS_START_ADDR 0x80000000 @@ -214,6 +214,9 @@ #define CONFIG_SPL_SERIAL_SUPPORT #define CONFIG_SPL_GPIO_SUPPORT #define CONFIG_SPL_YMODEM_SUPPORT +#define CONFIG_SPL_NET_SUPPORT +#define CONFIG_SPL_NET_VCI_STRING "AM335x U-Boot SPL" +#define CONFIG_SPL_ETH_SUPPORT #define CONFIG_SPL_LDSCRIPT "$(CPUDIR)/omap-common/u-boot-spl.lds"
Ilya Yanok
Joe Hershberger
