[U-Boot-Users] [FIX] FDT bug - MPC83xx
HI,
I look at FDT and I found small bug in cpu.c file
Signed-off-by: Michal Simek monstr@monstr.eu
Best regards, Michal Simek
On Mon, 09 Jul 2007 13:42:00 +0200 (CEST) Michal Simek Monstr@seznam.cz wrote:
HI,
Hi Michal, gvb has already fixed this in his fdt branch on the fdt tree on denx.de. Please pull the fdt branch from the fdt tree.
Kim
p.s. gvb, I haven't gotten to review your patches yet, but will very soon now.
HI,
Hi Michal,
Just to tag onto Kim's reply, if you do $ git pull git://www.denx.de/git/u-boot-fdt fdt you will pull my latest version into your repository. If you are the cautious type, you can create a branch and pull into the branch before you pull it into your mainline.
Testing is appreciated!
Kim
Thanks, Michal & Kim, gvb
I looked at http://www.denx.de/cgi-bin/gitweb.cgi to Jerry's FDT repository to u-boot/u-boot-fdt.git]/ cpu / mpc83xx / cpu.c file Lines are below. I don't see these changes.
437 #ifdef CONFIG_TSEC1 438 { "/" OF_SOC "/ethernet@24000, 439 "mac-address", 440 fdt_set_eth0 441 }, 442 { "/" OF_SOC "/ethernet@24000, 443 "local-mac-address", 444 fdt_set_eth0 445 }, 446 #endif 447 #ifdef CONFIG_TSEC2 448 { "/" OF_SOC "/ethernet@25000, 449 "mac-address", 450 fdt_set_eth1 451 }, 452 { "/" OF_SOC "/ethernet@25000, 453 "local-mac-address", 454 fdt_set_eth1 455 }, 456 #endif
Hi Michal,
The gitweb display is the "master" branch, you need to scroll to the bottom of the page and select the "fdt" branch (under the heading "heads") to see the changes you are interested in.
http://www.denx.de/cgi-bin/gitweb.cgi?p=u-boot/u-boot-fdt.git;a=shortlog;h=fdt
It is the top patch in the list. (Unfortunately the diff is suboptimal for reading because of the way diff handled the repeated pattern.) http://www.denx.de/cgi-bin/gitweb.cgi?p=u-boot/u-boot-fdt.git;a=commitdiff;h=a565569208b048fb973751389487a744e3e31e2f
gvb
Hi, thanks for explanation. Do you have any documentation about FDT? I would like to test it. I have proprietary board with MPC8343 like a testing platform and if is useful for Microblaze, I will try to port it.
Hi Michal,
gvb
Documentation? We don't need no steeenkin' documentation!
I'm NOT a fdt expert. I simply stood on the experts' shoulders. To be specific, I took David Gibson's libfdt interface library and created a "fdt" command on top of that. As part of that, I adapted some board, etc, munging that was done as part of the "bootm" command to use David's libfdt as well, instead of the older set of utilities (the older utility routines have a kinda funky interface).
If you look at the custodians' page http://www.denx.de/wiki/UBoot/Custodians you will see a pointer to my Work In Progress page http://www.denx.de/wiki/UBoot/UBootFdtInfo
I've just added a background section that is a lot of jump-off links for more information. http://www.denx.de/wiki/view/UBoot/UBootFdtInfo#Background_Information_on_Flatte
Note that it's a wiki -- please add improvements!
gvb
Jerry Van Baren
Jerry Van Baren
Kim Phillips
Michal Simek
