[U-Boot] [PATCH] imx: serial: Wait for ongoing transmission to finish before serial reset
It may happen that the MXC serial IP block is performing some ongoing transmission (started at e.g. board_init()) when the "initr_serial" is called.
As a result the serial port IP block is reset, so transmitted data is corrupted:
I2C: ready DRAM: 1 GiB jSS('HH��SL_SDHC: 04 rev 0x0
This patch prevents from this situation, by waiting for transmission complete bit set (UART Status Register 2 (UARTx_USR2), bit TXDC):
I2C: ready DRAM: 1 GiB ID: unit type 0x4 rev 0x0
Signed-off-by: Lukasz Majewski lukma@denx.de ---
drivers/serial/serial_mxc.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/drivers/serial/serial_mxc.c b/drivers/serial/serial_mxc.c index cce80a8..ef4eb12 100644 --- a/drivers/serial/serial_mxc.c +++ b/drivers/serial/serial_mxc.c @@ -141,6 +141,13 @@ struct mxc_uart {
static void _mxc_serial_init(struct mxc_uart *base) { + /* + * Wait for any ongoing transmission to finish - for example + * from pre-relocation enabled UART + */ + while (!(readl(&base->sr2) & USR2_TXDC)) + ; + writel(0, &base->cr1); writel(0, &base->cr2);
- while (!(readl(&base->sr2) & USR2_TXDC))
Yes, the same is in kernel, too.
Reviewed-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Loops that poll for HW activated bits should always have a timeout. Hardware will definitely break some day and deliver unexpected results. Software should cope with this as best as it can!
Lothar Waßmann
HI Lothar,
In principle yes.
Please find below rationale for this patch:
1. According to imx6q this bit shows emptiness of TxFIFO and Shift register [1]. It seems like a purely HW controlled bit.
2. Having timeout here would require first initialization of timer. However, this code is also used in a very early console initialization.
3. In Linux kernel [2] the same check is performed with:
while (!(readl(sport->port.membase + USR2) & USR2_TXDC)) barrier();
[1] - Transmitter Complete. Indicates that the transmit buffer (TxFIFO) and Shift Register is empty; therefore the transmission is complete. TXDC is cleared automatically when data is written to the TxFIFO.
[2] - http://elixir.free-electrons.com/linux/v4.2/source/drivers/tty/serial/imx.c#...
Lothar Waßmann
Hi Lukasz,
Is it possible to use driver model to do this in a generic way for all serial drivers? The pending() method allows you to check if there are any characters in the output FIFO.
Hi Simon,
Hi Lukasz,
Please correct me if I'm wrong.
Do you mean to define pre_init() callback in serial-uclass.c file, which would utilize ->pending callback if available?
In that way we would have the generic facility for above check available on all platforms.
Hi Lucasz,
On 9 October 2017 at 12:46, Łukasz Majewski lukma@denx.de wrote:
Hi Simon,
Hi Lukasz,
Yes that is what I am hoping.
participants (5)
Lothar Waßmann
Lukasz Majewski
Stefano Babic
Łukasz Majewski
