[U-Boot] [PATCH v2] gpio: lpc32xx: Use priv_data instead of platdata
The LPC32XX GPIO driver platdata currently contains GPIO state information, which should go into priv_data. Thus rename lpc32xx_gpio_platdata to lpc32xx_gpio_priv and convert to use dev_get_priv() instead.
Signed-off-by: Axel Lin axel.lin@ingics.com --- v2: Update commit log to mention that using priv_data for runtime state which was stored in platdata. drivers/gpio/lpc32xx_gpio.c | 39 +++++++++++++++++++-------------------- 1 file changed, 19 insertions(+), 20 deletions(-)
diff --git a/drivers/gpio/lpc32xx_gpio.c b/drivers/gpio/lpc32xx_gpio.c index 96b3125..8a9826e 100644 --- a/drivers/gpio/lpc32xx_gpio.c +++ b/drivers/gpio/lpc32xx_gpio.c @@ -37,7 +37,7 @@
#define LPC32XX_GPIOS 128
-struct lpc32xx_gpio_platdata { +struct lpc32xx_gpio_priv { struct gpio_regs *regs; /* GPIO FUNCTION: SEE WARNING #2 */ signed char function[LPC32XX_GPIOS]; @@ -60,8 +60,8 @@ struct lpc32xx_gpio_platdata { static int lpc32xx_gpio_direction_input(struct udevice *dev, unsigned offset) { int port, mask; - struct lpc32xx_gpio_platdata *gpio_platdata = dev_get_platdata(dev); - struct gpio_regs *regs = gpio_platdata->regs; + struct lpc32xx_gpio_priv *gpio_priv = dev_get_priv(dev); + struct gpio_regs *regs = gpio_priv->regs;
port = GPIO_TO_PORT(offset); mask = GPIO_TO_MASK(offset); @@ -83,7 +83,7 @@ static int lpc32xx_gpio_direction_input(struct udevice *dev, unsigned offset) }
/* GPIO FUNCTION: SEE WARNING #2 */ - gpio_platdata->function[offset] = GPIOF_INPUT; + gpio_priv->function[offset] = GPIOF_INPUT;
return 0; } @@ -95,8 +95,8 @@ static int lpc32xx_gpio_direction_input(struct udevice *dev, unsigned offset) static int lpc32xx_gpio_get_value(struct udevice *dev, unsigned offset) { int port, rank, mask, value; - struct lpc32xx_gpio_platdata *gpio_platdata = dev_get_platdata(dev); - struct gpio_regs *regs = gpio_platdata->regs; + struct lpc32xx_gpio_priv *gpio_priv = dev_get_priv(dev); + struct gpio_regs *regs = gpio_priv->regs;
@@ -130,8 +130,8 @@ static int lpc32xx_gpio_get_value(struct udevice *dev, unsigned offset) static int gpio_set(struct udevice *dev, unsigned gpio) { int port, mask; - struct lpc32xx_gpio_platdata *gpio_platdata = dev_get_platdata(dev); - struct gpio_regs *regs = gpio_platdata->regs; + struct lpc32xx_gpio_priv *gpio_priv = dev_get_priv(dev); + struct gpio_regs *regs = gpio_priv->regs;
port = GPIO_TO_PORT(gpio); mask = GPIO_TO_MASK(gpio); @@ -162,8 +162,8 @@ static int gpio_set(struct udevice *dev, unsigned gpio) static int gpio_clr(struct udevice *dev, unsigned gpio) { int port, mask; - struct lpc32xx_gpio_platdata *gpio_platdata = dev_get_platdata(dev); - struct gpio_regs *regs = gpio_platdata->regs; + struct lpc32xx_gpio_priv *gpio_priv = dev_get_priv(dev); + struct gpio_regs *regs = gpio_priv->regs;
port = GPIO_TO_PORT(gpio); mask = GPIO_TO_MASK(gpio); @@ -208,8 +208,8 @@ static int lpc32xx_gpio_direction_output(struct udevice *dev, unsigned offset, int value) { int port, mask; - struct lpc32xx_gpio_platdata *gpio_platdata = dev_get_platdata(dev); - struct gpio_regs *regs = gpio_platdata->regs; + struct lpc32xx_gpio_priv *gpio_priv = dev_get_priv(dev); + struct gpio_regs *regs = gpio_priv->regs;
port = GPIO_TO_PORT(offset); mask = GPIO_TO_MASK(offset); @@ -231,7 +231,7 @@ static int lpc32xx_gpio_direction_output(struct udevice *dev, unsigned offset, }
/* GPIO FUNCTION: SEE WARNING #2 */ - gpio_platdata->function[offset] = GPIOF_OUTPUT; + gpio_priv->function[offset] = GPIOF_OUTPUT;
return lpc32xx_gpio_set_value(dev, offset, value); } @@ -251,8 +251,8 @@ static int lpc32xx_gpio_direction_output(struct udevice *dev, unsigned offset,
static int lpc32xx_gpio_get_function(struct udevice *dev, unsigned offset) { - struct lpc32xx_gpio_platdata *gpio_platdata = dev_get_platdata(dev); - return gpio_platdata->function[offset]; + struct lpc32xx_gpio_priv *gpio_priv = dev_get_priv(dev); + return gpio_priv->function[offset]; }
static const struct dm_gpio_ops gpio_lpc32xx_ops = { @@ -265,7 +265,7 @@ static const struct dm_gpio_ops gpio_lpc32xx_ops = {
static int lpc32xx_gpio_probe(struct udevice *dev) { - struct lpc32xx_gpio_platdata *gpio_platdata = dev_get_platdata(dev); + struct lpc32xx_gpio_priv *gpio_priv = dev_get_priv(dev); struct gpio_dev_priv *uc_priv = dev->uclass_priv;
if (dev->of_offset == -1) { @@ -274,12 +274,11 @@ static int lpc32xx_gpio_probe(struct udevice *dev) }
/* set base address for GPIO registers */ - gpio_platdata->regs = (struct gpio_regs *)GPIO_BASE; + gpio_priv->regs = (struct gpio_regs *)GPIO_BASE;
/* all GPIO functions are unknown until requested */ /* GPIO FUNCTION: SEE WARNING #2 */ - memset(gpio_platdata->function, GPIOF_UNKNOWN, - sizeof(gpio_platdata->function)); + memset(gpio_priv->function, GPIOF_UNKNOWN, sizeof(gpio_priv->function));
return 0; } @@ -289,5 +288,5 @@ U_BOOT_DRIVER(gpio_lpc32xx) = { .id = UCLASS_GPIO, .ops = &gpio_lpc32xx_ops, .probe = lpc32xx_gpio_probe, - .priv_auto_alloc_size = sizeof(struct lpc32xx_gpio_platdata), + .priv_auto_alloc_size = sizeof(struct lpc32xx_gpio_priv), };
Hello Axel,
Tested-by: Albert ARIBAUD albert.aribaud@3adev.fr
Amicalement,
Hello Axel,
- struct lpc32xx_gpio_priv *gpio_priv = dev_get_priv(dev);
- return gpio_priv->function[offset];
- .priv_auto_alloc_size = sizeof(struct lpc32xx_gpio_priv),
1.9.1
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
Albert ARIBAUD
Axel Lin
