[U-Boot] [PATCH v2 0/3] AM335x: Add USB support in u-boot.
These patches add usb support in u-boot for AM335x. I have tested this code on AM335x evm and beaglebone in the host mode using mass storage class.
Gene Zarkhin (1): AM335x : Add USB support for AM335x in u-boot
Harman Sohanpal (2): AM335x : Configs to add USB host support. musb_udc : Fix compile warning.
drivers/usb/musb/Makefile | 1 + drivers/usb/musb/am335x.c | 121 ++++++++++++++++++++++++++++++++++++++++++ drivers/usb/musb/am335x.h | 113 +++++++++++++++++++++++++++++++++++++++ drivers/usb/musb/musb_core.h | 2 + drivers/usb/musb/musb_hcd.h | 3 - include/configs/am335x_evm.h | 41 ++++++++++++++ include/usb.h | 3 +- 7 files changed, 280 insertions(+), 4 deletions(-) create mode 100644 drivers/usb/musb/am335x.c create mode 100644 drivers/usb/musb/am335x.h
This patch adds USB support in uboot for AM335x. By default the USB 1 module is enabled. The support for USB 0 can be enabled by changing the USB base address and the phy control register address in the header file am335x.h.
Signed-off-by: Gene Zarkhin gene_zarkhin@bose.com Signed-off-by: Harman Sohanpal harman_sohanpal@ti.com --- Changes for v2: - none
drivers/usb/musb/Makefile | 1 + drivers/usb/musb/am335x.c | 121 +++++++++++++++++++++++++++++++++++++++++++++ drivers/usb/musb/am335x.h | 113 ++++++++++++++++++++++++++++++++++++++++++ include/usb.h | 3 +- 4 files changed, 237 insertions(+), 1 deletions(-) create mode 100644 drivers/usb/musb/am335x.c create mode 100644 drivers/usb/musb/am335x.h
diff --git a/drivers/usb/musb/Makefile b/drivers/usb/musb/Makefile index 20b5503..d00ec40 100644 --- a/drivers/usb/musb/Makefile +++ b/drivers/usb/musb/Makefile @@ -32,6 +32,7 @@ COBJS-$(CONFIG_USB_DAVINCI) += davinci.o COBJS-$(CONFIG_USB_OMAP3) += omap3.o COBJS-$(CONFIG_USB_DA8XX) += da8xx.o COBJS-$(CONFIG_USB_AM35X) += am35x.o +COBJS-$(CONFIG_USB_AM335X) += am335x.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/usb/musb/am335x.c b/drivers/usb/musb/am335x.c new file mode 100644 index 0000000..4b59769 --- /dev/null +++ b/drivers/usb/musb/am335x.c @@ -0,0 +1,121 @@ +/* + * am335x.c - TI's AM335x platform specific usb wrapper functions. + * + * Author: gene Zarkhin gene_zarkhin@bose.com + * Modified by: Harman Sohanpal harman_sohanpal@ti.com + * + * Based on drivers/usb/musb/da8xx.c + * + * Copyright (c) 2012 Texas Instruments Incorporated + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ +#include <common.h> +#include "am335x.h" + +/* MUSB platform configuration */ +struct musb_config musb_cfg = { + .regs = (struct musb_regs *)(AM335X_USB_OTG_CORE_BASE), + .timeout = AM335X_USB_OTG_TIMEOUT, + .musb_speed = 0, +}; + +/* + * Enable the USB phy + */ +static u8 phy_on(void) +{ + u32 timeout; + u32 regAddr = CM_REGISTERS + USB_CTRL0_REG_OFFSET; + u32 usb_ctrl_reg; + + usb_ctrl_reg = readl(regAddr); + usb_ctrl_reg &= ~(CM_PHY_PWRDN | CM_PHY_OTG_PWRDN); + usb_ctrl_reg |= (OTGVDET_EN | OTGSESSENDEN); + writel(usb_ctrl_reg, regAddr); + + timeout = musb_cfg.timeout; + writel(0x1, &am335x_usb_regs->ctrl); + udelay(6000); + while (timeout--) { + if ((readl(&am335x_usb_regs->ctrl) & SOFT_RESET_BIT) == 0) + return 1; + } + /* USB phy was not turned on */ + return 0; +} + +/* + * Disable the USB phy + */ +static void phy_off(void) +{ + u32 regAddr = CM_REGISTERS + USB_CTRL0_REG_OFFSET; + u32 usb_ctrl_reg; + + usb_ctrl_reg = readl(regAddr); + usb_ctrl_reg |= (CM_PHY_PWRDN | CM_PHY_OTG_PWRDN); + writel(usb_ctrl_reg, regAddr); + + /* Disable the USB module */ + writel(PRCM_MODULE_DSBL, CM_PER_USB0_CLKCTRL); +} + +/* + * This function performs platform specific initialization for usb0. + */ +int musb_platform_init(void) +{ + u32 timeout; + u32 revision; + + /* USB */ + /* PLL Gate set up */ + writel(DPLL_CLKDCOLDO_GATE_CTRL, CM_CLKDCOLDO_DPLL_PER); + + /* CLOCK */ + writel(PRCM_MOD_EN, CM_PER_USB0_CLKCTRL); + timeout = musb_cfg.timeout; + while (timeout--) { + if (readl(CM_PER_USB0_CLKCTRL) != PRCM_MOD_EN) + continue; + else + break; + } + if (timeout == 0) { + printf("\nUSB module not enabled\nAborting"); + return -1; + } + + /* USB module fully functional */ + /* start the on-chip usb phy and its pll */ + if (phy_on() == 0) + return -1; + /* Returns zero if e.g. not clocked */ + revision = readl(&am335x_usb_regs->revision); + if (revision == 0) + return -1; + + return 0; +} + +/* + * This function performs platform specific deinitialization for usb0. + */ +void musb_platform_deinit(void) +{ + /* Turn off the phy */ + phy_off(); +} diff --git a/drivers/usb/musb/am335x.h b/drivers/usb/musb/am335x.h new file mode 100644 index 0000000..790531e --- /dev/null +++ b/drivers/usb/musb/am335x.h @@ -0,0 +1,113 @@ +/* + * am335x.h - TI's AM335x platform specific usb wrapper definitions. + * + * Author: Gene Zarkhin gene_zarkhin@bose.com + * Modified by: Harman Sohanpal harman_sohanpal@ti.com + * + * Based on drivers/usb/musb/da8xx.h + * + * Copyright (c) 2012 Texas Instruments Incorporated + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#ifndef __AM335X_USB_H__ +#define __AM335X_USB_H__ + +#include "musb_core.h" +/* PRCM Definitions */ +#define CM_CLKDCOLDO_DPLL_PER (CM_WKUP + 0x7c) +#define CM_PER_USB0_CLKCTRL (CM_PER + 0x1c) +#define PRCM_MOD_EN 0x2 +#define PRCM_MODULE_DSBL 0x0 + + +/* Control Module Registers */ +#define CM_REGISTERS CTRL_BASE +#define USB_CTRL0_REG_OFFSET (0x628) +#define USB_CTRL1_REG_OFFSET (0x680) + +#define PRCM_IDLEST 0x30000 +#define DPLL_CLKDCOLDO_GATE_CTRL 0x300 + +/* Base address of musb wrapper */ +#define AM335X_USB_OTG_BASE 0x47401800 + +/* Base address of musb core */ +#define AM335X_USB_OTG_CORE_BASE (AM335X_USB_OTG_BASE + 0x400) + +/* Timeout for AM35x usb module */ +#define AM335X_USB_OTG_TIMEOUT 0x3FFFFFF + +/* + * AM335x platform USB wrapper register overlay. + */ +struct am335x_usb_regs { + u32 revision; /* 0x00 */ + u32 reserved0[4]; + u32 ctrl; /* 0x14 */ + u32 status; /* 0x18 */ + u32 reserved1[1]; + u32 irqmstat; /* 0x20 */ + u32 irqeoi; /* 0x24 */ + u32 irqstatraw0; /* 0x28 */ + u32 irqstatraw1; /* 0x2c */ + u32 irqstat0; /* 0x30 */ + u32 irqstat1; /* 0x34 */ + u32 irqenableset0; /* 0x38 */ + u32 irqenableset1; /* 0x3c */ + u32 irqenableclr0; /* 0x40 */ + u32 irqenableclr1; /* 0x44 */ + u32 reserved2[10]; + u32 txmode; /* 0x70 */ + u32 rxmode; /* 0x74 */ + u32 reserved3[2]; + u32 genrndisep1; /* 0x80 */ + u32 genrndisep2; /* 0x84 */ + u32 genrndisep3; /* 0x88 */ + u32 genrndisep4; /* 0x8c */ + u32 genrndisep5; /* 0x90 */ + u32 genrndisep6; /* 0x94 */ + u32 genrndisep7; /* 0x98 */ + u32 genrndisep8; /* 0x9c */ + u32 genrndisep9; /* 0xa0 */ + u32 genrndisep10; /* 0xa4 */ + u32 genrndisep11; /* 0xa8 */ + u32 genrndisep12; /* 0xac */ + u32 genrndisep13; /* 0xb0 */ + u32 genrndisep14; /* 0xb4 */ + u32 genrndisep15; /* 0xb8 */ + u32 reserved4[5]; + u32 autoreq; /* 0xd0 */ + u32 srpfixtime; /* 0xd4 */ + u32 tdown; /* 0xd8 */ + u32 reserved5[1]; + u32 utmi; /* 0xe0 */ + u32 utmilb; /* 0xe4 */ + u32 mode; /* 0xe8 */ +}; + +#define am335x_usb_regs ((struct am335x_usb_regs *)AM335X_USB_OTG_BASE) + +/* USB 2.0 PHY Control */ +#define CM_PHY_PWRDN (1 << 0) +#define CM_PHY_OTG_PWRDN (1 << 1) +#define OTGVDET_EN (1 << 19) +#define OTGSESSENDEN (1 << 20) + +/* USB CTRL REG FIELDS */ +#define SOFT_RESET_BIT (1 << 0) + +#endif /* __AM335X_USB_H__ */ diff --git a/include/usb.h b/include/usb.h index 6da91e7..13f5434 100644 --- a/include/usb.h +++ b/include/usb.h @@ -141,7 +141,8 @@ struct usb_device { defined(CONFIG_USB_SL811HS) || defined(CONFIG_USB_ISP116X_HCD) || \ defined(CONFIG_USB_R8A66597_HCD) || defined(CONFIG_USB_DAVINCI) || \ defined(CONFIG_USB_OMAP3) || defined(CONFIG_USB_DA8XX) || \ - defined(CONFIG_USB_BLACKFIN) || defined(CONFIG_USB_AM35X) + defined(CONFIG_USB_BLACKFIN) || defined(CONFIG_USB_AM35X) || \ + defined(CONFIG_USB_AM335X)
int usb_lowlevel_init(void); int usb_lowlevel_stop(void);
iirc this is because USB 1 has a full size connector and USB 0 has a mini connector so 1 is used as "host" and 0 as "gadget". We need to make this clear in the commit message and think about how to easily build for one port or the other. Thanks!
-----Original Message----- From: Tom Rini [mailto:tom.rini@gmail.com] On Behalf Of Rini, Tom Sent: Friday, June 22, 2012 9:34 PM To: Sohanpal, Harman Cc: u-boot@lists.denx.de; sr@denx.de; Gene Zarkhin Subject: Re: [U-Boot] [PATCH v2 1/3] AM335x : Add USB support for AM335x in u-boot
Tom, Yes, you have mentioned the correct reason for this. I will clearly mention this thing in the commit message of the new set of patches I will be sending. Thanks, Harman
This patch adds required configs in config file for am335x_evm to add support for usb host mode. To enable USB device mode, add CONFIG_MUSB_UDC in place of CONFIG_MUSB_HCD
Signed-off-by: Harman Sohanpal harman_sohanpal@ti.com --- Changes for v2: - #define cleanups
include/configs/am335x_evm.h | 41 +++++++++++++++++++++++++++++++++++++++++ 1 files changed, 41 insertions(+), 0 deletions(-)
diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index d0fbc88..9cb4825 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -165,6 +165,47 @@ #define CONFIG_SKIP_LOWLEVEL_INIT #endif
+ +/* + * USB configuration + * Enable CONFIG_MUSB_HCD for Host functionalities MSC, keyboard + * Enable CONFIG_MUSB_UDC for Device functionalities. + */ +#define CONFIG_USB_AM335X +#define CONFIG_MUSB_HCD + +#ifdef CONFIG_USB_AM335X + +#ifdef CONFIG_MUSB_HCD +#define CONFIG_CMD_USB + +#define CONFIG_USB_STORAGE +#define CONGIG_CMD_STORAGE +#define CONFIG_CMD_FAT + +#ifdef CONFIG_USB_KEYBOARD +#define CONFIG_SYS_USB_EVENT_POLL +#define CONFIG_PREBOOT "usb start" +#endif /* CONFIG_USB_KEYBOARD */ + +#endif /* CONFIG_MUSB_HCD */ + +#ifdef CONFIG_MUSB_UDC +/* USB device configuration */ +#ifndef CONFIG_SPL_BUILD +#define CONFIG_USB_DEVICE +#define CONFIG_USB_TTY +#define CONFIG_SYS_CONSOLE_IS_IN_ENV +#endif /* CONFIG_SPL_BUILD */ +/* Change these to suit your needs */ +#define CONFIG_USBD_VENDORID 0x0451 +#define CONFIG_USBD_PRODUCTID 0x5678 +#define CONFIG_USBD_MANUFACTURER "Texas Instruments" +#define CONFIG_USBD_PRODUCT_NAME "AM335xEVM" +#endif /* CONFIG_MUSB_UDC */ + +#endif /* CONFIG_USB_AM335X */ + /* Unsupported features */ #undef CONFIG_USE_IRQ
But you haven't tested / added support for device mode yet, so please remove those references.
[snip]
- USB configuration
- Enable CONFIG_MUSB_HCD for Host functionalities MSC, keyboard
- Enable CONFIG_MUSB_UDC for Device functionalities.
We don't need an extra test of CONFIG_USB_AM335X around this, just CONFIG_MUSB_HCD and later MUSB_UCD.
[snip]
You didn't add nor test keyboard so please remove these bits until U-Boot support is at the point where you could use one of these boards over a display rather than USB console :) Thanks.
-----Original Message----- From: Tom Rini [mailto:tom.rini@gmail.com] On Behalf Of Rini, Tom Sent: Friday, June 22, 2012 9:25 PM To: Sohanpal, Harman Cc: u-boot@lists.denx.de; sr@denx.de Subject: Re: [U-Boot] [PATCH v2 2/3] AM335x : Configs to add USB host support.
[snip]
- USB configuration
[snip]
Tom, Thanks for the review. I have tested the device mode using usbtty on beaglebone. Although I have not tested keyboard so will remove those configs and would add it when tested. Also would remove the extra test of CONFIG_USB_AM335X in next set of patches. Thanks, Harman
This patch fix the compile warning : implicit declaration of musb_platform_init when CONFIG_MUSB_UDC is defined. The extern musb_platform_init was declared in musb_hcd.h but no such extern function was declared for musb_udc. So a common function has been declared in musb_core.h which can be used for both host mode and device mode.
drivers/usb/musb/musb_core.h | 2 ++ drivers/usb/musb/musb_hcd.h | 3 --- 2 files changed, 2 insertions(+), 3 deletions(-)
diff --git a/drivers/usb/musb/musb_core.h b/drivers/usb/musb/musb_core.h index a8adcce..14253f0 100644 --- a/drivers/usb/musb/musb_core.h +++ b/drivers/usb/musb/musb_core.h @@ -360,6 +360,8 @@ extern void musb_start(void); extern void musb_configure_ep(const struct musb_epinfo *epinfo, u8 cnt); extern void write_fifo(u8 ep, u32 length, void *fifo_data); extern void read_fifo(u8 ep, u32 length, void *fifo_data); +extern int musb_platform_init(void); +extern void musb_platform_deinit(void);
#if defined(CONFIG_USB_BLACKFIN) /* Every USB register is accessed as a 16-bit even if the value itself diff --git a/drivers/usb/musb/musb_hcd.h b/drivers/usb/musb/musb_hcd.h index dde7d37..5621f7e 100644 --- a/drivers/usb/musb/musb_hcd.h +++ b/drivers/usb/musb/musb_hcd.h @@ -105,8 +105,5 @@ extern unsigned char new[]; #define RH_REQ_ERR -1 #define RH_NACK 0x00
-/* extern functions */ -extern int musb_platform_init(void); -extern void musb_platform_deinit(void);
#endif /* __MUSB_HCD_H__ */
Harman Sohanpal
Sohanpal, Harman
