[U-Boot] [PATCH] asm-offsets: generate bd_t size
Some ports set up the board info structure at the same time as the global data structure, and largely keep them together. So generate a define for the board info struct too.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- lib/asm-offsets.c | 3 +++ 1 files changed, 3 insertions(+), 0 deletions(-)
diff --git a/lib/asm-offsets.c b/lib/asm-offsets.c index 2209561..6f253a6 100644 --- a/lib/asm-offsets.c +++ b/lib/asm-offsets.c @@ -25,5 +25,8 @@ int main(void) DEFINE(GENERATED_GBL_DATA_SIZE, (sizeof(struct global_data)+15) & ~15);
+ DEFINE(GENERATED_BD_INFO_SIZE, + (sizeof(struct bd_info)+15) & ~15); + return 0; }
Dear Mike Frysinger,
Applied, thanks.
Hi Wolfgang and Mike,
Applied, thanks.
I am little bit confused. 1. Mike's patch has broken coding style in his patch ("space"+"space"15)
2. I sent that patch 3 days before Mike. (It is the longer story) http://lists.denx.de/pipermail/u-boot/2010-December/084095.html
I like that the patch is in mainline tree because I need it for Microblaze but I don't quite understand that you beat me about coding style and then you apply patch which has broken coding style.
I don't care if that patch is Mike's or mine I would like to be sure what are that acceptance rules.
Can you please tell me how this can happen?
Best regards, Michal
Applied, thanks.
- Mike's patch has broken coding style in his patch ("space"+"space"15)
i retained existing style on purpose. i figured Wolfgang preferred that since he wrote it that way. doesnt matter to me either way.
- I sent that patch 3 days before Mike. (It is the longer story)
i hadnt noticed that. probably because i had already punted the e-mail a few days before i noticed i needed it. otherwise i would have s-o-b your version. -mike
In message AANLkTim+t7jCzD2pdYACs9bpCiaDA-CGico1coz7vu0f@mail.gmail.com you wrote:
I think you should rather send "Acked-by" in such cases.
" The Signed-off-by: tag indicates that the signer was involved in the development of the patch, or that he/she was in the patch's delivery path.
If a person was not directly involved in the preparation or handling of a patch but wishes to signify and record their approval of it then they can arrange to have an Acked-by: line added to the patch's changelog. "
Applied, thanks.
I wanted to do it in the same way but based on my experience Wolfgang would beat me that the patch has broken coding style that's why I wanted to fix it.
No problem. I like that you find out that you need the some parameter as I.
Michal
Dear Michal Simek,
Indeed. Sorry for missing this. The existing code had the same issue. If you want, then please submit a patch to clean this up for the whole file.
Usually I try to process incoming patches sequentially, but this is not always possible; even if I follow all mail threads this is unreliable as many people submit new versions of their patches without proper linking back to the existing threads. So even when trying to work mostly sequentially, I will frequently jump forward and backward in time.
In cases like this (different patches for the same thing, submitted independently by separate people using different Subjects) it is pretty much pure chance which of the submitted patches gets picked up. For me the only important thing is that no patches get dropped unintentionally.
If I remember correctly Mike's patch was part of my todo list in patchwork, which was what I processed first, completely independent of submission date. I don't remember if I moved the patch there myself, or if somebody else (Mike?) bestowed it upon me.
Dear Wolfgang,
Dear Michal Simek,
You don't need to "apologize". I really appreciate your work and it is not easy to handle everything. For me is important to fix microblaze code and doesn't matter who has done that patch.
My point was that you always look at coding style and would be nice to check it all the time and doesn't matter who send it even you. I understand that it is hard to check your own work.
Michal Simek
Mike Frysinger
