[RFC PATCH 0/1] env: introduce variable value ranges
This series extends the flags-variable with ranges for environment variables. The range is appended to the variable flags using the '@'-character. A range can be decimal (min/max), bitmask or regular expression (64 byte).
Value ranges for variables can be used to make the environment more robust against faults such as invalid user input or attacks.
Decimal-range: foo:da@<min>-<max> Hexadecimal-range(bitmask): bar:xa@0xdeadbeed Regex-range: mystring:sa@r"klaus|haus|maus"
Example:
"decimalvalue:dw@100-200," ...
=> env set decimalvalue 1 1 < 100 || 1 > 200 => env set decimalvalue 150 =>
Lukas Funke (1): env: introduce variable ranges
cmd/nvedit.c | 30 +++--- env/flags.c | 217 +++++++++++++++++++++++++++++++++++++- include/configs/sandbox.h | 5 + include/env_flags.h | 27 ++++- include/search.h | 1 + test/env/Makefile | 1 + test/env/range.c | 113 ++++++++++++++++++++ 7 files changed, 377 insertions(+), 17 deletions(-) create mode 100644 test/env/range.c
This commit extends the flags-variable with ranges for environment variables. The range is appended to the variable flags using the '@'-character. A range can be decimal (min/max), bitmask or regular expression (64 byte).
Example:
Signed-off-by: Lukas Funke lukas.funke@weidmueller.com ---
diff --git a/cmd/nvedit.c b/cmd/nvedit.c index 98a687bcabb..f02545c7a55 100644 --- a/cmd/nvedit.c +++ b/cmd/nvedit.c @@ -352,10 +352,13 @@ static int print_static_flags(const char *var_name, const char *flags, { enum env_flags_vartype type = env_flags_parse_vartype(flags); enum env_flags_varaccess access = env_flags_parse_varaccess(flags); + struct env_flags_range *range = env_flags_parse_varrange(flags);
- printf("\t%-20s %-20s %-20s\n", var_name, + printf("\t%-20s %-20s %-20s %-20s\n", var_name, env_flags_get_vartype_name(type), - env_flags_get_varaccess_name(access)); + env_flags_get_varaccess_name(access), + env_flags_get_varrange_name(range, type)); + free(range);
return 0; } @@ -364,6 +367,7 @@ static int print_active_flags(struct env_entry *entry) { enum env_flags_vartype type; enum env_flags_varaccess access; + struct env_flags_range *range;
if (entry->flags == 0) return 0; @@ -371,9 +375,11 @@ static int print_active_flags(struct env_entry *entry) type = (enum env_flags_vartype) (entry->flags & ENV_FLAGS_VARTYPE_BIN_MASK); access = env_flags_parse_varaccess_from_binflags(entry->flags); - printf("\t%-20s %-20s %-20s\n", entry->key, + range = (struct env_flags_range *)entry->range; + printf("\t%-20s %-20s %-20s %-20s\n", entry->key, env_flags_get_vartype_name(type), - env_flags_get_varaccess_name(access)); + env_flags_get_varaccess_name(access), + env_flags_get_varrange_name(range, type));
return 0; } @@ -401,19 +407,19 @@ int do_env_flags(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[])
/* Print the static flags that may exist */ puts("Static flags:\n"); - printf("\t%-20s %-20s %-20s\n", "Variable Name", "Variable Type", - "Variable Access"); - printf("\t%-20s %-20s %-20s\n", "-------------", "-------------", - "---------------"); + printf("\t%-20s %-20s %-20s %-20s\n", "Variable Name", "Variable Type", + "Variable Access", "Variable Range"); + printf("\t%-20s %-20s %-20s %-20s\n", "-------------", "-------------", + "---------------", "---------------"); env_attr_walk(ENV_FLAGS_LIST_STATIC, print_static_flags, NULL); puts("\n");
/* walk through each variable and print the flags if non-default */ puts("Active flags:\n"); - printf("\t%-20s %-20s %-20s\n", "Variable Name", "Variable Type", - "Variable Access"); - printf("\t%-20s %-20s %-20s\n", "-------------", "-------------", - "---------------"); + printf("\t%-20s %-20s %-20s %-20s\n", "Variable Name", "Variable Type", + "Variable Access", "Variable Range"); + printf("\t%-20s %-20s %-20s %-20s\n", "-------------", "-------------", + "---------------", "---------------"); hwalk_r(&env_htab, print_active_flags); return 0; } diff --git a/env/flags.c b/env/flags.c index 233fd460d84..dc0a9c5764f 100644 --- a/env/flags.c +++ b/env/flags.c @@ -20,6 +20,9 @@ #else #include <linux/kernel.h> #include <env_internal.h> +#include <vsprintf.h> +#include <malloc.h> +#include <slre.h> #endif
#ifdef CONFIG_NET @@ -34,6 +37,8 @@ #define ENV_FLAGS_WRITEABLE_VARACCESS_REPS "" #endif
+#define ENV_FLAGS_RANGE_SEPERATOR '@' + static const char env_flags_vartype_rep[] = "sdxb" ENV_FLAGS_NET_VARTYPE_REPS; static const char env_flags_varaccess_rep[] = "aroc" ENV_FLAGS_WRITEABLE_VARACCESS_REPS; @@ -115,6 +120,35 @@ const char *env_flags_get_varaccess_name(enum env_flags_varaccess access) { return env_flags_varaccess_names[access]; } + +const char *env_flags_get_varrange_name(struct env_flags_range *range, + enum env_flags_vartype type) +{ + static char range_str[64]; + + if (!range) + return ""; + + switch (type) { + case env_flags_vartype_decimal: { + snprintf(range_str, sizeof(range_str), "%lld-%lld", + range->u.int_range.min, range->u.int_range.max); + break; + } + case env_flags_vartype_hex: { + snprintf(range_str, sizeof(range_str), "0x%llx", range->u.bitmask); + break; + } + case env_flags_vartype_string: { + strlcpy(range_str, range->u.re, sizeof(range_str)); + break; + } + default: + return ""; + } + + return range_str; +} #endif /* CONFIG_CMD_ENV_FLAGS */
/* @@ -151,6 +185,9 @@ enum env_flags_varaccess env_flags_parse_varaccess(const char *flags) if (strlen(flags) <= ENV_FLAGS_VARACCESS_LOC) return va_default;
+ if (flags[ENV_FLAGS_VARACCESS_LOC] == ENV_FLAGS_RANGE_SEPERATOR) + return va_default; + access = strchr(env_flags_varaccess_rep, flags[ENV_FLAGS_VARACCESS_LOC]);
@@ -211,6 +248,138 @@ static void skip_num(int hex, const char *value, const char **end, *end = value; }
+struct env_flags_range *env_flags_parse_varrange(const char *flags) +{ + char *range; + struct env_flags_range *r; + enum env_flags_vartype type; + + if (!flags) + return NULL; + + range = strchr(flags, ENV_FLAGS_RANGE_SEPERATOR); + if (!range) + return NULL; + + range++; + + r = (struct env_flags_range *)malloc(sizeof(struct env_flags_range)); + if (!r) + return NULL; + + type = env_flags_parse_vartype(flags); + + /* parse regex range r"someregex" */ + if (!strncmp(range, "r"", 2)) { + if (IS_ENABLED(CONFIG_REGEX)) { + if (type != env_flags_vartype_string) { + free(r); + return NULL; + } + + char *rstart = strchr(range, '"'); + char *rend = strrchr(range, '"'); + + memset(r->u.re, 0, sizeof(r->u.re)); + + if (rstart == rend) /* invalid format r" */ + return NULL; + + rstart++; + if (rstart == rend) /* empty regex is okay */ + return r; + + if ((rend - rstart) < sizeof(r->u.re)) + strlcpy(r->u.re, rstart, rend - rstart); + else + return NULL; /* too big */ + } + } else if (is_hex_prefix(range)) { + /* parse bitmask range 0x[a-fA-F0-9]+ */ + if (type != env_flags_vartype_hex) { + free(r); + return NULL; + } + r->u.bitmask = (u64)simple_strtol(range, NULL, 16); + } else { + /* parse integer range [0-9]+-[0-9]+ */ + s64 min, max; + + if (type != env_flags_vartype_decimal) { + free(r); + return NULL; + } + + char *lhs = strcpy(r->u.re, range); /* exploit regex buffer */ + char *rhs = strchr(lhs[0] == '-' ? lhs + 1 : lhs, '-'); + + if (!rhs) { + free(r); + return NULL; + } + + *rhs++ = '\0'; + min = simple_strtol(lhs, NULL, 10); + max = simple_strtol(rhs, NULL, 10); + r->u.int_range.min = min; + r->u.int_range.max = max; + } + + return r; +} + +static int _env_flags_validate_range(const struct env_flags_range *range, + enum env_flags_vartype type, + const char *newval) +{ + if (!range) + return -1; + + switch (type) { + case env_flags_vartype_decimal: { + s64 value = simple_strtol(newval, NULL, 10); + s64 min = range->u.int_range.min; + s64 max = range->u.int_range.max; + + if (value < min || value > max) { + printf("## Error: value out of bounds\n" + "%lld < %lld || %lld > %lld\n", value, min, value, max); + return -1; + } + break; + } + case env_flags_vartype_hex: { + u64 value = (u64)simple_strtoll(newval, NULL, 16); + u64 mask = range->u.bitmask; + + if ((value | mask) != mask) { + printf("## Error: value out of bounds\n" + "value = 0x%llx, mask 0x%llx\n", value, mask); + return -1; + } + break; + } + case env_flags_vartype_string: { +#if defined(CONFIG_REGEX) + struct slre slre; + + if (slre_compile(&slre, range->u.re)) { + if (slre_match(&slre, newval, strlen(newval), NULL) == 0) { + printf("## Error: value does not match regex\n" + "value = %s, re = %s\n", newval, range->u.re); + return -1; + } + } +#endif + break; + } + default: + return -1; + } + + return 0; +} + #ifdef CONFIG_NET int eth_validate_ethaddr_str(const char *addr) { @@ -241,7 +410,7 @@ int eth_validate_ethaddr_str(const char *addr) * with that format */ static int _env_flags_validate_type(const char *value, - enum env_flags_vartype type) + enum env_flags_vartype type) { const char *end; #ifdef CONFIG_NET @@ -360,6 +529,20 @@ enum env_flags_varaccess env_flags_get_varaccess(const char *name) return env_flags_parse_varaccess(flags); }
+/* + * Look up the range of a variable directly from the .flags var. + */ +struct env_flags_range *env_flags_get_range(const char *name) +{ + const char *flags_list = env_get(ENV_FLAGS_VAR); + char flags[ENV_FLAGS_ATTR_MAX_LEN + 1]; + + if (env_flags_lookup(flags_list, name, flags)) + return NULL; + + return env_flags_parse_varrange(flags); +} + /* * Validate that the proposed new value for "name" is valid according to the * defined flags for that variable, if any. @@ -395,6 +578,25 @@ int env_flags_validate_varaccess(const char *name, int check_mask) return (check_mask & access_mask) != 0; }
+/* + * Validate that the variable "name" is valid according to + * the defined range for that variable, if any. + */ +int env_flags_validate_range(const char *name, const char *newval) +{ + int r; + enum env_flags_vartype type; + struct env_flags_range *range; + + type = env_flags_get_type(name); + range = env_flags_get_range(name); + + r = _env_flags_validate_range(range, type, newval); + + free(range); + return r; +} + /* * Validate the parameters to "env set" directly */ @@ -460,8 +662,10 @@ void env_flags_init(struct env_entry *var_entry) ret = env_flags_lookup(flags_list, var_name, flags);
/* if any flags were found, set the binary form to the entry */ - if (!ret && strlen(flags)) + if (!ret && strlen(flags)) { var_entry->flags = env_parse_flags_to_bin(flags); + var_entry->range = env_flags_parse_varrange(flags); + } }
/* @@ -489,11 +693,13 @@ static int set_flags(const char *name, const char *value, void *priv) /* does the env variable actually exist? */ if (ep != NULL) { /* the flag list is empty, so clear the flags */ - if (value == NULL || strlen(value) == 0) + if (value == NULL || strlen(value) == 0) { ep->flags = 0; - else + } else { /* assign the requested flags */ ep->flags = env_parse_flags_to_bin(value); + ep->range = env_flags_parse_varrange(value); + } }
return 0; @@ -547,6 +753,9 @@ int env_flags_validate(const struct env_entry *item, const char *newval, name, newval, env_flags_vartype_rep[type]); return -1; } + if (item->range && + _env_flags_validate_range(item->range, type, newval) < 0) + return -1; }
/* check for access permission */ diff --git a/include/configs/sandbox.h b/include/configs/sandbox.h index 2372485c84e..8dec2b2cc89 100644 --- a/include/configs/sandbox.h +++ b/include/configs/sandbox.h @@ -21,4 +21,9 @@ /* Unused but necessary to build */ #define CFG_SYS_UBOOT_BASE CONFIG_TEXT_BASE
+#define CFG_ENV_FLAGS_LIST_STATIC \ + "decimalvalue:da@100-200," \ + "regexvalue:sa@r"foo|bar"," \ + "bitmaskvalue:xa@0xf00f" + #endif diff --git a/include/env_flags.h b/include/env_flags.h index 2476043b0e3..dfe45ce04d5 100644 --- a/include/env_flags.h +++ b/include/env_flags.h @@ -32,8 +32,19 @@ enum env_flags_varaccess { env_flags_varaccess_end };
+struct env_flags_range { + union { + char re[64]; + u64 bitmask; + struct { + s64 min; + s64 max; + } int_range; + } u; +}; + #define ENV_FLAGS_VAR ".flags" -#define ENV_FLAGS_ATTR_MAX_LEN 2 +#define ENV_FLAGS_ATTR_MAX_LEN 64 #define ENV_FLAGS_VARTYPE_LOC 0 #define ENV_FLAGS_VARACCESS_LOC 1
@@ -108,6 +119,11 @@ const char *env_flags_get_vartype_name(enum env_flags_vartype type); * Return the name of the access. */ const char *env_flags_get_varaccess_name(enum env_flags_varaccess access); +/* + * Return the range of the access. + */ +const char *env_flags_get_varrange_name(struct env_flags_range *range, + enum env_flags_vartype type); #endif
/* @@ -118,6 +134,10 @@ enum env_flags_vartype env_flags_parse_vartype(const char *flags); * Parse the flags string from a .flags attribute list into the varaccess enum. */ enum env_flags_varaccess env_flags_parse_varaccess(const char *flags); +/* + * Parse the flags string from a .flags attribute list into the varaccess enum. + */ +struct env_flags_range *env_flags_parse_varrange(const char *flags); /* * Parse the binary flags from a hash table entry into the varaccess enum. */ @@ -154,6 +174,11 @@ int env_flags_validate_access(const char *name, int check_mask); * the defined flags for that variable, if any. */ int env_flags_validate_varaccess(const char *name, int check_mask); +/* + * Validate that the variable "name" is valid according to + * the defined range for that variable, if any. + */ +int env_flags_validate_range(const char *name, const char *newval) /* * Validate the parameters passed to "env set" for type compliance */ diff --git a/include/search.h b/include/search.h index 7faf23f4aca..c3de3109a4d 100644 --- a/include/search.h +++ b/include/search.h @@ -34,6 +34,7 @@ struct env_entry { int flags); #endif int flags; + void *range; };
/* diff --git a/test/env/Makefile b/test/env/Makefile index 9a98fd47966..717cbc5555e 100644 --- a/test/env/Makefile +++ b/test/env/Makefile @@ -6,3 +6,4 @@ obj-y += cmd_ut_env.o obj-y += attr.o obj-y += hashtable.o obj-$(CONFIG_ENV_IMPORT_FDT) += fdt.o +obj-y += range.o diff --git a/test/env/range.c b/test/env/range.c new file mode 100644 index 00000000000..ed2cf27ef91 --- /dev/null +++ b/test/env/range.c @@ -0,0 +1,113 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * (C) Copyright 2024 + * Lukas Funke, Weidmueller GmbH, lukas.funke@weidmueller.com + */ + +#include <vsprintf.h> +#include <command.h> +#include <env_attr.h> +#include <env_flags.h> +#include <test/env.h> +#include <test/ut.h> + +/* + * Set values according to their range + */ +static int env_test_env_set_range(struct unit_test_state *uts) +{ + int r; + char *value; + + r = env_set("decimalvalue", "100"); + ut_asserteq(0, r); + value = env_get("decimalvalue"); + ut_asserteq_str("100", value); + r = env_set("decimalvalue", "500"); + ut_asserteq(1, r); + + r = env_set("regexvalue", "foo"); + ut_asserteq(0, r); + value = env_get("regexvalue"); + ut_asserteq_str("foo", value); + r = env_set("regexvalue", "klaus"); + ut_asserteq(1, r); + + r = env_set("bitmaskvalue", "0xf00f"); + ut_asserteq(0, r); + value = env_get("bitmaskvalue"); + ut_asserteq_str("0xf00f", value); + r = env_set("bitmaskvalue", "0x0110"); + ut_asserteq(1, r); + + return 0; +} + +ENV_TEST(env_test_env_set_range, 0); + +static int env_test_range_to_str(struct unit_test_state *uts) +{ + struct env_flags_range range; + + range.u.int_range.min = 123; + range.u.int_range.max = 456; + ut_asserteq_str("123-456", + env_flags_get_varrange_name(&range, + env_flags_vartype_decimal)); + + strcpy(&range.u.re[0], "^(some|value)_[0-9a-zA-Z]"); + ut_asserteq_str("^(some|value)_[0-9a-zA-Z]", + env_flags_get_varrange_name(&range, + env_flags_vartype_string)); + + range.u.bitmask = 0x12300000; + ut_asserteq_str("0x12300000", + env_flags_get_varrange_name(&range, + env_flags_vartype_hex)); + return 0; +} + +ENV_TEST(env_test_range_to_str, 0); + +static int env_test_range_parse(struct unit_test_state *uts) +{ + char str[64]; + struct env_flags_range *range; + + range = env_flags_parse_varrange("s@r"somevalue""); + ut_assertnonnull(range); + free(range); + + range = env_flags_parse_varrange("sw"); + ut_assertnull(range); + + snprintf(str, sizeof(str), "d@%ld-%ld", LONG_MIN, LONG_MAX); + range = env_flags_parse_varrange(str); + ut_assertnonnull(range); + ut_assert(range->u.int_range.min == LONG_MIN); + ut_assert(range->u.int_range.max == LONG_MAX); + free(range); + + snprintf(str, sizeof(str), "d@0-%ld", LONG_MAX); + range = env_flags_parse_varrange(str); + ut_assertnonnull(range); + ut_assert(range->u.int_range.min == 0); + ut_assert(range->u.int_range.max == LONG_MAX); + free(range); + + snprintf(str, sizeof(str), "d@%ld-0", LONG_MIN); + range = env_flags_parse_varrange(str); + ut_assertnonnull(range); + ut_assert(range->u.int_range.min == LONG_MIN); + ut_assert(range->u.int_range.max == 0); + free(range); + + range = env_flags_parse_varrange("x@0xff0000ff"); + ut_assertnonnull(range); + ut_assert(range->u.bitmask == 0xff0000ff); + free(range); + + return 0; +} + +ENV_TEST(env_test_range_parse, 0);
Example:
Can you put this behind a Kconfig? We should avoid the code-size increase for existing boards.
Also please add doc/
Unfortunately I have a lot of minor comments about this patch, partly due to the existing env code.
This is too long. Perhaps we need to rename the env_flags_get_... functions to envf_get_...
free(range); return 0;
struct env_flags_range *range; if (entry->flags == 0) return 0;
env_flags_get_varrange_name(range, type)); return 0;
"Variable Access");
"---------------", "---------------"); env_attr_walk(ENV_FLAGS_LIST_STATIC, print_static_flags, NULL); puts("\n"); /* walk through each variable and print the flags if non-default */ puts("Active flags:\n");
"Variable Access");
Please check include ordering.
#endif
Too long... how about ENVF_RANGE_SEP ?
Eek, best to avoid statics. How about the caller passes in the buffer?
if (!range)
return "";
switch (type) {
break;
Please drop {} around these
"%#llx"
Do we really want 64-bit values?
Also see simple_xtoa(), simple_itoa()
break;
break;
default:
return "";
return range_str;
return va_default;
char *range;
if (!flags)
return NULL;
if (!range)
return NULL;
range++;
if (!r)
return NULL;
Isn't that an error?
if (!strncmp(range, "r\"", 2)) {
free(r);
return NULL;
return NULL;
rstart++;
return r;
else
free(r);
return NULL;
} else {
s64 min, max;
This supports a signed range, but might someone want unsigned?
free(r);
return NULL;
if (!rhs) {
free(r);
return NULL;
*rhs++ = '\0';
return r;
In general, this function should likely return an error code, with r returned as a pointer argument.
const char *newval)
if (!range)
return -1;
switch (type) {
return -1;
break;
return -1;
break;
Can you use: if IS_ENABLED() ?
struct slre slre;
return -1;
break;
default:
return -1;
- with that format
- Look up the range of a variable directly from the .flags var.
Needs a proper comment...what does it return?
return NULL;
- Validate that the proposed new value for "name" is valid according to the
- defined flags for that variable, if any.
- Validate that the variable "name" is valid according to
- the defined range for that variable, if any.
same
int r;
free(range);
return r;
- Validate the parameters to "env set" directly
error handling?
Should be: if !value || !strlen(value)
or even !value || !*value to maybe save code space
ep->flags = 0;
else
} } return 0;
if (item->range &&
return -1; } /* check for access permission */
"regexvalue:sa@r\"foo|bar\"," \
Please comment the struct
union {
char re[64];
u64 bitmask;
struct {
s64 min;
s64 max;
} int_range;
} u;
Please comment this item. I don't know what it means.
- Return the name of the access.
- Return the range of the access.
That is too vague, please add a proper function comment in the normal U-Boot style.
#endif
- Parse the flags string from a .flags attribute list into the varaccess enum.
same here
I know you are just following the existing code, but please try to improve it :-)
- Parse the binary flags from a hash table entry into the varaccess enum.
- the defined flags for that variable, if any.
- Validate the parameters passed to "env set" for type compliance
void *range;
Please add comment...also why is this void * ?
- (C) Copyright 2024
- Lukas Funke, Weidmueller GmbH, lukas.funke@weidmueller.com
This should go below env_flags
- Set values according to their range
int r;
char *value;
ut_asserteq(0, r);
ut_assertok(env_set("decimalvalue", "100"));
ut_asserteq(1, r);
please combine the line pairs into a single line
ut_asserteq(0, r);
ut_asserteq(1, r);
ut_asserteq(0, r);
ut_asserteq(1, r);
Drop blank line (convention we use in tests)
Please add UTF_CONSOLE and assert_nextline() calls above, so you can check the error output.
blank line before final return
char str[64];
range = env_flags_parse_varrange("s@r\"somevalue\"");
free(range);
ut_asserteq(LONG_MIN, range->u.int_range.min)
free(range);
free(range);
free(range);
free(range);
You could check there are no memory leaks here. See for example lib_test_abuf_set().
2.30.2
