[U-Boot] U-Boot Operation on Xilinx Zynq SoC with Micro C
Hello, I have a rather specific question about u-boot. I am working with a Xilinx Zynq SoC, and am running a MicroC OS executable file. It is running on UCOS kernel II. I notice different behavior when I hand off from the first stage boot loader to the UCOS application directly than when I hand off to u-boot and then use it to load the image. I am sure my methodology is correct as for other images it works fine, but not this one. I am concerned that the problem is related to the actual memory that u-boot is loading the application which has hard-coded memory blocks. Is there a way to ensure that u-boot hands off to the application the same way as the FSBL? For example, when I tell u-boot to load to address 0x0, is it the same 0x0 that the FSBL loads to? Any help is appreciated.
Nelson Silva
