[U-Boot] [PATCH] image-fit: Fix compiler warning in fit_conf_print()
This fixes the following compiler warning:
In file included from tools/common/image-fit.c:1:0: ./tools/../common/image-fit.c: In function ‘fit_conf_print’: ./tools/../common/image-fit.c:1470:27: warning: logical not is only applied to the left hand side of comparison [-Wlogical-not-parentheses] (const char **)&uname) > 0;
Signed-off-by: Hans de Goede hdegoede@redhat.com --- common/image-fit.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/common/image-fit.c b/common/image-fit.c index 4bd8fea..28f7aa8 100644 --- a/common/image-fit.c +++ b/common/image-fit.c @@ -1464,10 +1464,10 @@ void fit_conf_print(const void *fit, int noffset, const char *p)
/* Print out all of the specified loadables */ for (loadables_index = 0; - !fdt_get_string_index(fit, noffset, + fdt_get_string_index(fit, noffset, FIT_LOADABLE_PROP, loadables_index, - (const char **)&uname) > 0; + (const char **)&uname) == 0; loadables_index++) { if (loadables_index == 0) {
Hi All,
ping? it would be nice to get this fixed, as it is the only compiler warning I see when building u-boot.
Tom, can you pick this one up directly perhaps?
Regards,
Hans
loadables_index++) { if (loadables_index == 0) {(const char **)&uname) == 0;
Hans de Goede
