[U-Boot] [PATCH 00/10] Blackfin updates for 2010.06
New board port and a few random updates. Nothing crazy here.
Brent Kandetzki (1): Blackfin: IP04: new board port
Harald Krapfenbauer (1): Blackfin: cm-bf561: update network/env settings
Mike Frysinger (8): Blackfin: disable NetBSD bootm support by default Blackfin: drop reference to gd->reloc_off Blackfin: relax .data alignment Blackfin: bf537-stamp: add board test defines Blackfin: sync ptrace headers with linux Blackfin: link with normal ABI target Blackfin: call watchdog_init() for external watchdogs Blackfin: drop bfin #undef in linker script
MAINTAINERS | 4 + MAKEALL | 1 + Makefile | 2 +- board/cm-bf561/cm-bf561.c | 4 +- board/ip04/Makefile | 54 +++++++ board/ip04/config.mk | 35 +++++ board/ip04/ip04.c | 42 +++++ include/asm-blackfin/config-pre.h | 3 + include/asm-blackfin/ptrace.h | 297 ++++++++++++++----------------------- include/asm-blackfin/traps.h | 62 ++------ include/configs/bf537-stamp.h | 9 + include/configs/cm-bf561.h | 11 +- include/configs/ip04.h | 157 +++++++++++++++++++ lib_blackfin/board.c | 14 ++- lib_blackfin/config.mk | 4 +- lib_blackfin/u-boot.lds.S | 5 +- 16 files changed, 453 insertions(+), 251 deletions(-) create mode 100644 board/ip04/Makefile create mode 100644 board/ip04/config.mk create mode 100644 board/ip04/ip04.c create mode 100644 include/configs/ip04.h
There is no Blackfin/NetBSD port, so enabling support for it by default doesn't make any sense.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- include/asm-blackfin/config-pre.h | 3 +++ 1 files changed, 3 insertions(+), 0 deletions(-)
diff --git a/include/asm-blackfin/config-pre.h b/include/asm-blackfin/config-pre.h index 1170a2a..4531519 100644 --- a/include/asm-blackfin/config-pre.h +++ b/include/asm-blackfin/config-pre.h @@ -71,6 +71,9 @@ static inline const char *get_bfin_boot_mode(int bfin_boot) # define BFIN_BOOT_SPI_SSEL 1 #endif
+/* There is no Blackfin/NetBSD port */ +#undef CONFIG_BOOTM_NETBSD + /* We rarely use interrupts, so favor throughput over latency */ #define CONFIG_BFIN_INS_LOWOVERHEAD
The reloc_off member no longer exists, so drop it. Also change this function so that it is always compiled and prevents latent issues like this in the future.
Reported-by: Peter Meerwald pmeerw@pmeerw.net Signed-off-by: Mike Frysinger vapier@gentoo.org --- lib_blackfin/board.c | 8 +++++--- 1 files changed, 5 insertions(+), 3 deletions(-)
diff --git a/lib_blackfin/board.c b/lib_blackfin/board.c index 21fff33..b0b52b2 100644 --- a/lib_blackfin/board.c +++ b/lib_blackfin/board.c @@ -73,8 +73,12 @@ static int init_baudrate(void)
static void display_global_data(void) { -#ifdef CONFIG_DEBUG_EARLY_SERIAL bd_t *bd; + +#ifndef CONFIG_DEBUG_EARLY_SERIAL + return; +#endif + bd = gd->bd; printf(" gd: %p\n", gd); printf(" |-flags: %lx\n", gd->flags); @@ -82,7 +86,6 @@ static void display_global_data(void) printf(" |-baudrate: %lu\n", gd->baudrate); printf(" |-have_console: %lx\n", gd->have_console); printf(" |-ram_size: %lx\n", gd->ram_size); - printf(" |-reloc_off: %lx\n", gd->reloc_off); printf(" |-env_addr: %lx\n", gd->env_addr); printf(" |-env_valid: %lx\n", gd->env_valid); printf(" |-jt(%p): %p\n", gd->jt, *(gd->jt)); @@ -95,7 +98,6 @@ static void display_global_data(void) printf(" |-bi_flashstart: %lx\n", bd->bi_flashstart); printf(" |-bi_flashsize: %lx\n", bd->bi_flashsize); printf(" \-bi_flashoffset: %lx\n", bd->bi_flashoffset); -#endif }
#define CPLB_PAGE_SIZE (4 * 1024 * 1024)
The strictest alignment on Blackfin systems is 32bits (since that is the largest load instruction), so don't force 256byte alignment here.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- lib_blackfin/u-boot.lds.S | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/lib_blackfin/u-boot.lds.S b/lib_blackfin/u-boot.lds.S index 3be341f..9a757c6 100644 --- a/lib_blackfin/u-boot.lds.S +++ b/lib_blackfin/u-boot.lds.S @@ -100,7 +100,7 @@ SECTIONS
.data : { - . = ALIGN(256); + . = ALIGN(4); *(.data .data.*) *(.data1) *(.sdata)
We tweak the configs a little when doing automated hardware tests.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- include/configs/bf537-stamp.h | 9 +++++++++ 1 files changed, 9 insertions(+), 0 deletions(-)
diff --git a/include/configs/bf537-stamp.h b/include/configs/bf537-stamp.h index de2add7..d3159e5 100644 --- a/include/configs/bf537-stamp.h +++ b/include/configs/bf537-stamp.h @@ -277,6 +277,15 @@ #define FLASH_END_POST_BLOCK 71 /* Should < = 71 */ #endif
+/* These are for board tests */ +#if 0 +#define CONFIG_BOOTCOMMAND "bootldr 0x203f0100" +#define CONFIG_AUTOBOOT_KEYED +#define CONFIG_AUTOBOOT_PROMPT \ + "autoboot in %d seconds: press space to stop\n", bootdelay +#define CONFIG_AUTOBOOT_STOP_STR " " +#endif +
/* * Pull in common ADI header for remaining command/environment setup
From: Harald Krapfenbauer Harald.Krapfenbauer@bluetechnix.at
Switch to the SMC911X driver by default now, and fix LDR env settings.
Signed-off-by: Harald Krapfenbauer Harald.Krapfenbauer@bluetechnix.at Signed-off-by: Mike Frysinger vapier@gentoo.org --- board/cm-bf561/cm-bf561.c | 4 ++-- include/configs/cm-bf561.h | 11 ++++------- 2 files changed, 6 insertions(+), 9 deletions(-)
diff --git a/board/cm-bf561/cm-bf561.c b/board/cm-bf561/cm-bf561.c index 80cfff7..5741f64 100644 --- a/board/cm-bf561/cm-bf561.c +++ b/board/cm-bf561/cm-bf561.c @@ -18,9 +18,9 @@ int checkboard(void) return 0; }
-#ifdef CONFIG_SMC91111 +#ifdef CONFIG_SMC911X int board_eth_init(bd_t *bis) { - return smc91111_initialize(0, CONFIG_SMC91111_BASE); + return smc911x_initialize(0, CONFIG_SMC911X_BASE); } #endif diff --git a/include/configs/cm-bf561.h b/include/configs/cm-bf561.h index 1741ed4..c60401c 100644 --- a/include/configs/cm-bf561.h +++ b/include/configs/cm-bf561.h @@ -63,14 +63,10 @@ * Network Settings */ #define ADI_CMDS_NETWORK 1 -/* The next 2 lines are for use with DEV-BF5xx */ #define CONFIG_NET_MULTI -#define CONFIG_SMC91111 1 -#define CONFIG_SMC91111_BASE 0x28000300 -/* The next 3 lines are for use with EXT-BF5xx-USB-ETH2 */ -/* #define CONFIG_DRIVER_SMC911X 1 */ -/* #define CONFIG_DRIVER_SMC911X_BASE 0x24080000 /! AMS1 */ -/* #define CONFIG_DRIVER_SMC911X_32_BIT 1 */ +#define CONFIG_SMC911X 1 +#define CONFIG_SMC911X_BASE 0x24008000 /* AMS1 */ +#define CONFIG_SMC911X_16_BIT #define CONFIG_HOSTNAME cm-bf561 /* Uncomment next line to use fixed MAC address */ /* #define CONFIG_ETHADDR 02:80:ad:20:31:cf */ @@ -94,6 +90,7 @@ #define CONFIG_ENV_OFFSET 0x20000 #define CONFIG_ENV_SECT_SIZE 0x20000 #define CONFIG_ENV_SIZE 0x10000 +#define CONFIG_ENV_IS_EMBEDDED_IN_LDR
Scrub a lot of dead cruft in the process.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- include/asm-blackfin/ptrace.h | 297 ++++++++++++++++------------------------- include/asm-blackfin/traps.h | 62 ++------- 2 files changed, 126 insertions(+), 233 deletions(-)
diff --git a/include/asm-blackfin/ptrace.h b/include/asm-blackfin/ptrace.h index f1b7d00..251d5e6 100644 --- a/include/asm-blackfin/ptrace.h +++ b/include/asm-blackfin/ptrace.h @@ -1,31 +1,11 @@ /* - * U-boot - ptrace.h + * Copyright 2004-2008 Analog Devices Inc. * - * Copyright (c) 2005-2007 Analog Devices Inc. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, - * MA 02110-1301 USA + * Licensed under the GPL-2 or later. */
-#ifndef _BLACKFIN_PTRACE_H -#define _BLACKFIN_PTRACE_H - -#define NEW_PT_REGS +#ifndef _BFIN_PTRACE_H +#define _BFIN_PTRACE_H
/* * GCC defines register number like this: @@ -35,128 +15,30 @@ * 16 - 31 dsp registers I/B/L0 -- I/B/L3 & M0--M3 * 32 - 33 A registers A0 & A1 * 34 - status register + * ----------------------------- * * We follows above, except: * 32-33 --- Low 32-bit of A0&1 * 34-35 --- High 8-bit of A0&1 */
-#if defined(NEW_PT_REGS) - -#define PT_IPEND 0 -#define PT_SYSCFG (PT_IPEND+4) -#define PT_SEQSTAT (PT_SYSCFG+4) -#define PT_RETE (PT_SEQSTAT+4) -#define PT_RETN (PT_RETE+4) -#define PT_RETX (PT_RETN+4) -#define PT_RETI (PT_RETX+4) -#define PT_PC PT_RETI -#define PT_RETS (PT_RETI+4) -#define PT_RESERVED (PT_RETS+4) -#define PT_ASTAT (PT_RESERVED+4) -#define PT_LB1 (PT_ASTAT+4) -#define PT_LB0 (PT_LB1+4) -#define PT_LT1 (PT_LB0+4) -#define PT_LT0 (PT_LT1+4) -#define PT_LC1 (PT_LT0+4) -#define PT_LC0 (PT_LC1+4) -#define PT_A1W (PT_LC0+4) -#define PT_A1X (PT_A1W+4) -#define PT_A0W (PT_A1X+4) -#define PT_A0X (PT_A0W+4) -#define PT_B3 (PT_A0X+4) -#define PT_B2 (PT_B3+4) -#define PT_B1 (PT_B2+4) -#define PT_B0 (PT_B1+4) -#define PT_L3 (PT_B0+4) -#define PT_L2 (PT_L3+4) -#define PT_L1 (PT_L2+4) -#define PT_L0 (PT_L1+4) -#define PT_M3 (PT_L0+4) -#define PT_M2 (PT_M3+4) -#define PT_M1 (PT_M2+4) -#define PT_M0 (PT_M1+4) -#define PT_I3 (PT_M0+4) -#define PT_I2 (PT_I3+4) -#define PT_I1 (PT_I2+4) -#define PT_I0 (PT_I1+4) -#define PT_USP (PT_I0+4) -#define PT_FP (PT_USP+4) -#define PT_P5 (PT_FP+4) -#define PT_P4 (PT_P5+4) -#define PT_P3 (PT_P4+4) -#define PT_P2 (PT_P3+4) -#define PT_P1 (PT_P2+4) -#define PT_P0 (PT_P1+4) -#define PT_R7 (PT_P0+4) -#define PT_R6 (PT_R7+4) -#define PT_R5 (PT_R6+4) -#define PT_R4 (PT_R5+4) -#define PT_R3 (PT_R4+4) -#define PT_R2 (PT_R3+4) -#define PT_R1 (PT_R2+4) -#define PT_R0 (PT_R1+4) -#define PT_ORIG_R0 (PT_R0+4) -#define PT_SR PT_SEQSTAT - -#else -/* - * Here utilize blackfin : dpregs = [pregs + imm16s4] - * [pregs + imm16s4] = dpregs - * to access defferent saved reg in stack - */ -#define PT_R3 0 -#define PT_R4 4 -#define PT_R2 8 -#define PT_R1 12 -#define PT_P5 16 -#define PT_P4 20 -#define PT_P3 24 -#define PT_P2 28 -#define PT_P1 32 -#define PT_P0 36 -#define PT_R7 40 -#define PT_R6 44 -#define PT_R5 48 -#define PT_PC 52 -#define PT_SEQSTAT 56 /* so-called SR reg */ -#define PT_SR PT_SEQSTAT -#define PT_ASTAT 60 -#define PT_RETS 64 -#define PT_A1w 68 -#define PT_A0w 72 -#define PT_A1x 76 -#define PT_A0x 80 -#define PT_ORIG_R0 84 -#define PT_R0 88 -#define PT_USP 92 -#define PT_FP 96 -#define PT_SP 100 - -/* Added by HuTao, May26 2003 3:18PM */ -#define PT_IPEND 100 - -/* Add SYSCFG register for single stepping support */ -#define PT_SYSCFG 104 - -#endif - #ifndef __ASSEMBLY__
-#if defined(NEW_PT_REGS) +struct task_struct; + /* this struct defines the way the registers are stored on the - * stack during a system call. - */ + stack during a system call. */ + struct pt_regs { + long orig_pc; long ipend; - long syscfg; long seqstat; long rete; long retn; long retx; - long pc; + long pc; /* PC == RETI */ long rets; - long reserved; + long reserved; /* Used as scratch during system calls */ long astat; long lb1; long lb0; @@ -201,69 +83,116 @@ struct pt_regs { long r1; long r0; long orig_r0; -}; - -#else -/* now we don't know what regs the system call will use */ -struct pt_regs { - long r3; - long r4; - long r2; - long r1; - long p5; - long p4; - long p3; - long p2; - long p1; - long p0; - long r7; - long r6; - long r5; - unsigned long pc; - unsigned long seqstat; - unsigned long astat; - unsigned long rets; - long a1w; - long a0w; - long a1x; - long a0x; - long orig_r0; - long r0; - long usp; - long fp; -/* - * Added for supervisor/user mode switch. - * - * HuTao May26 03 3:23PM - */ - long ipend; + long orig_p0; long syscfg; };
-#endif - /* Arbitrarily choose the same ptrace numbers as used by the Sparc code. */ -#define PTRACE_GETREGS 12 -#define PTRACE_SETREGS 13 /* ptrace signal */ +#define PTRACE_GETREGS 12 +#define PTRACE_SETREGS 13 /* ptrace signal */ + +#define PTRACE_GETFDPIC 31 /* get the ELF fdpic loadmap address */ +#define PTRACE_GETFDPIC_EXEC 0 /* [addr] request the executable loadmap */ +#define PTRACE_GETFDPIC_INTERP 1 /* [addr] request the interpreter loadmap */ + +#define PS_S (0x0002)
#ifdef __KERNEL__
-#ifndef PS_S -#define PS_S (0x0c00) +/* user_mode returns true if only one bit is set in IPEND, other than the + master interrupt enable. */ +#define user_mode(regs) (!(((regs)->ipend & ~0x10) & (((regs)->ipend & ~0x10) - 1))) +#define instruction_pointer(regs) ((regs)->pc) +#define user_stack_pointer(regs) ((regs)->usp) +#define profile_pc(regs) instruction_pointer(regs) +extern void show_regs(struct pt_regs *); + +#define arch_has_single_step() (1) +extern void user_enable_single_step(struct task_struct *); +/* see arch/blackfin/kernel/ptrace.c about this redirect */ +#define user_disable_single_step(child) ptrace_disable(child)
-/* Bit 11:10 of SEQSTAT defines user/supervisor/debug mode - * 00: user - * 01: supervisor - * 1x: debug +/* + * Get the address of the live pt_regs for the specified task. + * These are saved onto the top kernel stack when the process + * is not running. + * + * Note: if a user thread is execve'd from kernel space, the + * kernel stack will not be empty on entry to the kernel, so + * ptracing these tasks will fail. */ +#define task_pt_regs(task) \ + (struct pt_regs *) \ + ((unsigned long)task_stack_page(task) + \ + (THREAD_SIZE - sizeof(struct pt_regs)))
-#define PS_M (0x1000) /* I am not sure why this is required here Akbar */ -#endif +#endif /* __KERNEL__ */
-#define user_mode(regs) (!((regs)->seqstat & PS_S)) -#define instruction_pointer(regs) ((regs)->pc) -extern void show_regs(struct pt_regs *); +#endif /* __ASSEMBLY__ */ + +/* + * Offsets used by 'ptrace' system call interface. + */
-#endif -#endif -#endif +#define PT_R0 204 +#define PT_R1 200 +#define PT_R2 196 +#define PT_R3 192 +#define PT_R4 188 +#define PT_R5 184 +#define PT_R6 180 +#define PT_R7 176 +#define PT_P0 172 +#define PT_P1 168 +#define PT_P2 164 +#define PT_P3 160 +#define PT_P4 156 +#define PT_P5 152 +#define PT_FP 148 +#define PT_USP 144 +#define PT_I0 140 +#define PT_I1 136 +#define PT_I2 132 +#define PT_I3 128 +#define PT_M0 124 +#define PT_M1 120 +#define PT_M2 116 +#define PT_M3 112 +#define PT_L0 108 +#define PT_L1 104 +#define PT_L2 100 +#define PT_L3 96 +#define PT_B0 92 +#define PT_B1 88 +#define PT_B2 84 +#define PT_B3 80 +#define PT_A0X 76 +#define PT_A0W 72 +#define PT_A1X 68 +#define PT_A1W 64 +#define PT_LC0 60 +#define PT_LC1 56 +#define PT_LT0 52 +#define PT_LT1 48 +#define PT_LB0 44 +#define PT_LB1 40 +#define PT_ASTAT 36 +#define PT_RESERVED 32 +#define PT_RETS 28 +#define PT_PC 24 +#define PT_RETX 20 +#define PT_RETN 16 +#define PT_RETE 12 +#define PT_SEQSTAT 8 +#define PT_IPEND 4 + +#define PT_ORIG_R0 208 +#define PT_ORIG_P0 212 +#define PT_SYSCFG 216 +#define PT_TEXT_ADDR 220 +#define PT_TEXT_END_ADDR 224 +#define PT_DATA_ADDR 228 +#define PT_FDPIC_EXEC 232 +#define PT_FDPIC_INTERP 236 + +#endif /* _BFIN_PTRACE_H */ diff --git a/include/asm-blackfin/traps.h b/include/asm-blackfin/traps.h index b90ceda..7422d3d 100644 --- a/include/asm-blackfin/traps.h +++ b/include/asm-blackfin/traps.h @@ -1,42 +1,14 @@ /* - * U-boot - traps.h + * Copyright 2004-2009 Analog Devices Inc. + * 2001 Lineo, Inc + * Tony Kou + * 1993 Hamish Macdonald * - * Copyright (c) 2005-2007 Analog Devices Inc. - * - * This file is based on - * linux/include/asm/traps.h - * Copyright (C) 1993 Hamish Macdonald - * Lineo, Inc Jul 2001 Tony Kou - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, - * MA 02110-1301 USA + * Licensed under the GPL-2 */
-/* - */ - -#ifndef _BLACKFIN_TRAPS_H -#define _BLACKFIN_TRAPS_H - -#ifndef __ASSEMBLY__ -typedef void (*e_vector) (void); -extern e_vector vectors[]; -#endif +#ifndef _BFIN_TRAPS_H +#define _BFIN_TRAPS_H
#define VEC_SYS (0) #define VEC_EXCPT01 (1) @@ -64,23 +36,15 @@ extern e_vector vectors[]; #define VEC_CPLB_M (38) #define VEC_CPLB_MHIT (39) #define VEC_WATCH (40) -#define VEC_ISTRU_VL (41) +#define VEC_ISTRU_VL (41) /*ADSP-BF535 only (MH) */ #define VEC_MISALI_I (42) #define VEC_CPLB_I_VL (43) #define VEC_CPLB_I_M (44) #define VEC_CPLB_I_MHIT (45) #define VEC_ILL_RES (46) /* including unvalid supervisor mode insn */ +/* The hardware reserves (63) for future use - we use it to tell our + * normal exception handling code we have a hardware error + */ +#define VEC_HWERR (63)
-#define VECOFF(vec) ((vec)<<2) - -#ifndef __ASSEMBLY__ - -/* Status register bits */ -#define PS_T (0x8000) -#define PS_S (0x0c00) /* Supervisor mode = 0b01 */ -#define PS_D (0x0c00) /* Debug mode = 0b1x */ -#define PS_M (0x1000) -#define PS_C (0x0001) - -#endif -#endif +#endif /* _BFIN_TRAPS_H */
If someone uses the FDPIC toolchain to compile U-Boot, make sure the linker knows to use the normal ABI target rather than the FDPIC one. This wasn't needed with older toolchains, but when we fixed the linker such that the default target changed based on tuple, this broke.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- lib_blackfin/config.mk | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/lib_blackfin/config.mk b/lib_blackfin/config.mk index 323d28f..1b5cbba 100644 --- a/lib_blackfin/config.mk +++ b/lib_blackfin/config.mk @@ -23,7 +23,7 @@
CROSS_COMPILE ?= bfin-uclinux-
-STANDALONE_LOAD_ADDR = 0x1000 +STANDALONE_LOAD_ADDR = 0x1000 -m elf32bfin
CONFIG_BFIN_CPU := $(strip $(subst ",,$(CONFIG_BFIN_CPU))) CONFIG_BFIN_BOOT_MODE := $(strip $(subst ",,$(CONFIG_BFIN_BOOT_MODE))) @@ -33,7 +33,7 @@ CONFIG_ENV_SIZE := $(strip $(subst ",,$(CONFIG_ENV_SIZE))) PLATFORM_RELFLAGS += -ffixed-P3 -fomit-frame-pointer -mno-fdpic PLATFORM_CPPFLAGS += -DCONFIG_BLACKFIN
-LDFLAGS += --gc-sections +LDFLAGS += --gc-sections -m elf32bfin PLATFORM_RELFLAGS += -ffunction-sections -fdata-sections
ifneq (,$(CONFIG_BFIN_CPU))
Signed-off-by: Mike Frysinger vapier@gentoo.org --- lib_blackfin/board.c | 6 ++++++ 1 files changed, 6 insertions(+), 0 deletions(-)
diff --git a/lib_blackfin/board.c b/lib_blackfin/board.c index b0b52b2..4e9bb19 100644 --- a/lib_blackfin/board.c +++ b/lib_blackfin/board.c @@ -199,6 +199,7 @@ void init_cplbtables(void) * "continue" and != 0 means "fatal error, hang the system". */
+extern int watchdog_init(void); extern int exception_init(void); extern int irq_init(void); extern int timer_init(void); @@ -229,6 +230,11 @@ void board_init_f(ulong bootflag) dcache_enable(); #endif
+#ifdef CONFIG_WATCHDOG + serial_early_puts("Setting up external watchdog\n"); + watchdog_init(); +#endif + #ifdef DEBUG if (CONFIG_SYS_GBL_DATA_SIZE < sizeof(*gd)) hang();
Now that the linker script is preprocessed with -ansi, there is no need to manually undef the bfin define.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- lib_blackfin/u-boot.lds.S | 3 +-- 1 files changed, 1 insertions(+), 2 deletions(-)
diff --git a/lib_blackfin/u-boot.lds.S b/lib_blackfin/u-boot.lds.S index 9a757c6..2b23d8b 100644 --- a/lib_blackfin/u-boot.lds.S +++ b/lib_blackfin/u-boot.lds.S @@ -1,7 +1,7 @@ /* * U-boot - u-boot.lds.S * - * Copyright (c) 2005-2008 Analog Device Inc. + * Copyright (c) 2005-2010 Analog Device Inc. * * (C) Copyright 2000-2004 * Wolfgang Denk, DENX Software Engineering, wd@denx.de. @@ -29,7 +29,6 @@ #include <asm/blackfin.h> #undef ALIGN #undef ENTRY -#undef bfin
#ifndef LDS_BOARD_TEXT # define LDS_BOARD_TEXT
A low cost 4 port IP-PBX board.
Signed-off-by: Brent Kandetzki BrentK@teleco.com Signed-off-by: Mike Frysinger vapier@gentoo.org --- MAINTAINERS | 4 + MAKEALL | 1 + Makefile | 2 +- board/ip04/Makefile | 54 ++++++++++++++++ board/ip04/config.mk | 35 +++++++++++ board/ip04/ip04.c | 42 +++++++++++++ include/configs/ip04.h | 157 ++++++++++++++++++++++++++++++++++++++++++++++++ 7 files changed, 294 insertions(+), 1 deletions(-) create mode 100644 board/ip04/Makefile create mode 100644 board/ip04/config.mk create mode 100644 board/ip04/ip04.c create mode 100644 include/configs/ip04.h
diff --git a/MAINTAINERS b/MAINTAINERS index bb03f17..b617953 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -1008,6 +1008,10 @@ Anton Shurpin shurpin.aa@niistt.ru
BF561-ACVILON BF561
+Brent Kandetzki brentk@teleco.com + + IP04 BF532 + ######################################################################### # End of MAINTAINERS list # ######################################################################### diff --git a/MAKEALL b/MAKEALL index a88c31e..3e64748 100755 --- a/MAKEALL +++ b/MAKEALL @@ -905,6 +905,7 @@ LIST_blackfin=" \ cm-bf548 \ cm-bf561 \ ibf-dsp561 \ + ip04 \ tcm-bf518 \ tcm-bf537 \ " diff --git a/Makefile b/Makefile index 4532550..0ab67bb 100644 --- a/Makefile +++ b/Makefile @@ -3554,7 +3554,7 @@ BFIN_BOARDS += cm-bf527 cm-bf533 cm-bf537e cm-bf537u cm-bf548 cm-bf561 \ tcm-bf518 tcm-bf537
# Misc third party boards -BFIN_BOARDS += bf537-minotaur bf537-srv1 bf561-acvilon blackstamp +BFIN_BOARDS += bf537-minotaur bf537-srv1 bf561-acvilon blackstamp ip04
# I-SYST Micromodule BFIN_BOARDS += ibf-dsp561 diff --git a/board/ip04/Makefile b/board/ip04/Makefile new file mode 100644 index 0000000..e7ce304 --- /dev/null +++ b/board/ip04/Makefile @@ -0,0 +1,54 @@ +# +# U-boot - Makefile +# +# Copyright (c) 2005-2010 Analog Device Inc. +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS-y := $(BOARD).o + +SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS-y)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/ip04/config.mk b/board/ip04/config.mk new file mode 100644 index 0000000..bc14257 --- /dev/null +++ b/board/ip04/config.mk @@ -0,0 +1,35 @@ +# +# Copyright (c) 2005-2008 Analog Device Inc. +# +# (C) Copyright 2001 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +# This is not actually used for Blackfin boards so do not change it +#TEXT_BASE = do-not-use-me + +CFLAGS_lib_generic += -O2 +CFLAGS_lzma += -O2 + +# Set some default LDR flags based on boot mode. +LDR_FLAGS-BFIN_BOOT_PARA := --bits 16 --dma 8 +LDR_FLAGS-BFIN_BOOT_UART := --port g --gpio 6 +LDR_FLAGS += $(LDR_FLAGS-$(CONFIG_BFIN_BOOT_MODE)) diff --git a/board/ip04/ip04.c b/board/ip04/ip04.c new file mode 100644 index 0000000..c8ae512 --- /dev/null +++ b/board/ip04/ip04.c @@ -0,0 +1,42 @@ +/* + * U-boot - main board file + * + * Copyright (c) 2007 David Rowe, + * (c) 2006 Ivan Danov + * + * (C) Copyright 2000-2004 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * Licensed under the GPL-2 or later. + */ + +#include <common.h> +#include <net.h> +#include <netdev.h> +#include <asm/net.h> + +int checkboard(void) +{ + printf("Board: IP04 IP-PBX\n"); + printf(" http://www.rowetel.com/ucasterisk/ip04.html%5Cn"); + return 0; +} + +#ifdef CONFIG_DRIVER_DM9000 +int board_eth_init(bd_t *bis) +{ + return dm9000_initialize(bis); +} + +int misc_init_r(void) +{ + uchar enetaddr[6]; + if (!eth_getenv_enetaddr("ethaddr", enetaddr)) { + puts("Warning: Generating 'random' MAC address\n"); + bfin_gen_rand_mac(enetaddr); + eth_setenv_enetaddr("ethaddr", enetaddr); + } + + return 0; +} +#endif diff --git a/include/configs/ip04.h b/include/configs/ip04.h new file mode 100644 index 0000000..425a745 --- /dev/null +++ b/include/configs/ip04.h @@ -0,0 +1,157 @@ +/* + * U-boot - Configuration file for IP04 board (having BF532 processor) + * + * Copyright (c) 2006 Intratrade Ltd., Ivan Danov, idanov@gmail.com + * + * Copyright (c) 2005-2010 Analog Devices Inc. + * + * (C) Copyright 2000-2004 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * Licensed under the GPL-2 or later. + */ + +#ifndef __CONFIG_IP04_H__ +#define __CONFIG_IP04_H__ + +#include <asm/config-pre.h> + + +/* + * Processor Settings + */ +#define CONFIG_BFIN_CPU bf532-0.5 +#define CONFIG_BFIN_BOOT_MODE BFIN_BOOT_NAND + + +/* + * Clock Settings + * CCLK = (CLKIN * VCO_MULT) / CCLK_DIV + * SCLK = (CLKIN * VCO_MULT) / SCLK_DIV + */ +/* CONFIG_CLKIN_HZ is any value in Hz */ +#define CONFIG_CLKIN_HZ 10000000 +/* CLKIN_HALF controls the DF bit in PLL_CTL 0 = CLKIN */ +/* 1 = CLKIN / 2 */ +#define CONFIG_CLKIN_HALF 0 +/* PLL_BYPASS controls the BYPASS bit in PLL_CTL 0 = do not bypass */ +/* 1 = bypass PLL */ +#define CONFIG_PLL_BYPASS 0 +/* VCO_MULT controls the MSEL (multiplier) bits in PLL_CTL */ +/* Values can range from 0-63 (where 0 means 64) */ +#define CONFIG_VCO_MULT 40 +/* CCLK_DIV controls the core clock divider */ +/* Values can be 1, 2, 4, or 8 ONLY */ +#define CONFIG_CCLK_DIV 1 +/* SCLK_DIV controls the system clock divider */ +/* Values can range from 1-15 */ +#define CONFIG_SCLK_DIV 3 + + +/* + * Memory Settings + */ +#define CONFIG_MEM_ADD_WDTH 10 +#define CONFIG_MEM_SIZE 64 + +#define CONFIG_EBIU_SDRRC_VAL 0x408 +#define CONFIG_EBIU_SDGCTL_VAL 0x9111cd + +#define CONFIG_EBIU_AMGCTL_VAL 0xFF +#define CONFIG_EBIU_AMBCTL0_VAL 0xffc2ffc2 +#define CONFIG_EBIU_AMBCTL1_VAL 0xffc2ffc2 + +#define CONFIG_SYS_MONITOR_LEN (256 * 1024) +#define CONFIG_SYS_MALLOC_LEN (128 * 1024) + + +/* + * Network Settings + */ +#define ADI_CMDS_NETWORK 1 +#define CONFIG_NET_MULTI 1 +#define CONFIG_HOSTNAME IP04 + +#define CONFIG_DRIVER_DM9000 1 +#define CONFIG_DM9000_NO_SROM +#define CONFIG_DM9000_BASE 0x20100000 +#define DM9000_IO CONFIG_DM9000_BASE +#define DM9000_DATA (CONFIG_DM9000_BASE + 2) + + +/* + * Flash Settings + */ +#define CONFIG_ENV_OVERWRITE 1 +#define CONFIG_SYS_NO_FLASH /* we have only NAND */ + + +/* + * SPI Settings + */ +#define CONFIG_BFIN_SPI +#define CONFIG_ENV_SPI_MAX_HZ 30000000 +#define CONFIG_SF_DEFAULT_SPEED 30000000 +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_STMICRO +#define CONFIG_SPI_FLASH_WINBOND + + +/* + * Env Storage Settings + */ +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_PREBOOT "echo starting from spi flash" +#define CONFIG_ENV_OFFSET 0x30000 +#define CONFIG_ENV_SIZE 0x10000 +#define CONFIG_ENV_SECT_SIZE 0x10000 + + +/* + * NAND Settings + */ +#define CONFIG_NAND_PLAT +#define CONFIG_SYS_NAND_BASE 0x20000000 +#define CONFIG_SYS_MAX_NAND_DEVICE 1 + +#define BFIN_NAND_CLE(chip) ((unsigned long)(chip)->IO_ADDR_W | (1 << 2)) +#define BFIN_NAND_ALE(chip) ((unsigned long)(chip)->IO_ADDR_W | (1 << 1)) +#define BFIN_NAND_READY PF10 +#define BFIN_NAND_WRITE(addr, cmd) \ + do { \ + bfin_write8(addr, cmd); \ + SSYNC(); \ + } while (0) + +#define NAND_PLAT_WRITE_CMD(chip, cmd) BFIN_NAND_WRITE(BFIN_NAND_CLE(chip), cmd) +#define NAND_PLAT_WRITE_ADR(chip, cmd) BFIN_NAND_WRITE(BFIN_NAND_ALE(chip), cmd) +#define NAND_PLAT_DEV_READY(chip) (bfin_read_FIO_FLAG_D() & BFIN_NAND_READY) +#define NAND_PLAT_INIT() \ + do { \ + bfin_write_FIO_DIR(bfin_read_FIO_DIR() & ~BFIN_NAND_READY); \ + bfin_write_FIO_INEN(bfin_read_FIO_INEN() | BFIN_NAND_READY); \ + bfin_write_FIO_EDGE(bfin_read_FIO_EDGE() & ~BFIN_NAND_READY); \ + bfin_write_FIO_POLAR(bfin_read_FIO_POLAR() & ~BFIN_NAND_READY); \ + } while (0) + + +/* + * Misc Settings + */ +#define CONFIG_BAUDRATE 115200 +#define CONFIG_MISC_INIT_R /* needed for MAC address */ +#define CONFIG_UART_CONSOLE 0 + +#undef CONFIG_SHOW_BOOT_PROGRESS +/* Enable this if bootretry required; currently it's disabled */ +#define CONFIG_BOOT_RETRY_TIME -1 +#define CONFIG_BOOTCOMMAND "run nandboot" +#define CONFIG_AUTOBOOT_PROMPT "autoboot in %d seconds\n" + + +/* + * Pull in common ADI header for remaining command/environment setup + */ +#include <configs/bfin_adi_common.h> + +#endif
Mike Frysinger
