[U-Boot] [PATCH] arm64: zynqmp: Enable CDC ethernet gadget for zcu100/Ultra96
Ethernet is not present on this board that's why there are two other options how to wire the board to ethernet. The first is asix_eth usb host converter which is already enabled by default. The second option is to use USB CDC/RNDIS ethernet gadget.
This patch is enabling CDC which is working with Linux. With new bind/unbind command there is no need to call usb_ether_init() from platform code and use for example these commands:
bind /amba/usb0@ff9d0000/dwc3@fe200000 usb_ether dhcp unbind /amba/usb0@ff9d0000/dwc3@fe200000
configs/avnet_ultra96_rev1_defconfig | 5 +++++ configs/xilinx_zynqmp_zcu100_revC_defconfig | 5 +++++ 2 files changed, 10 insertions(+)
diff --git a/configs/avnet_ultra96_rev1_defconfig b/configs/avnet_ultra96_rev1_defconfig index 3d073670075f..c49c9f23465d 100644 --- a/configs/avnet_ultra96_rev1_defconfig +++ b/configs/avnet_ultra96_rev1_defconfig @@ -21,6 +21,7 @@ CONFIG_SPL_ATF=y CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_CMD_BOOTMENU=y CONFIG_CMD_MEMTEST=y +CONFIG_CMD_BIND=y CONFIG_CMD_CLK=y CONFIG_CMD_DFU=y # CONFIG_CMD_FLASH is not set @@ -65,6 +66,8 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_DM_ETH=y +# CONFIG_NETDEVICES is not set CONFIG_DEBUG_UART_ZYNQ=y CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ZYNQ_SERIAL=y @@ -83,6 +86,8 @@ CONFIG_USB_ULPI=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_USB_ETHER=y +CONFIG_USB_ETH_CDC=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_WDT=y diff --git a/configs/xilinx_zynqmp_zcu100_revC_defconfig b/configs/xilinx_zynqmp_zcu100_revC_defconfig index d21abe253a26..dc1e7cd8240f 100644 --- a/configs/xilinx_zynqmp_zcu100_revC_defconfig +++ b/configs/xilinx_zynqmp_zcu100_revC_defconfig @@ -21,6 +21,7 @@ CONFIG_SPL_ATF=y CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_CMD_BOOTMENU=y CONFIG_CMD_MEMTEST=y +CONFIG_CMD_BIND=y CONFIG_CMD_CLK=y CONFIG_CMD_DFU=y # CONFIG_CMD_FLASH is not set @@ -65,6 +66,8 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_DM_ETH=y +# CONFIG_NETDEVICES is not set CONFIG_DEBUG_UART_ZYNQ=y CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ZYNQ_SERIAL=y @@ -83,6 +86,8 @@ CONFIG_USB_ULPI=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_USB_ETHER=y +CONFIG_USB_ETH_CDC=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_WDT=y
Michal Simek
