[v2 UBOOT PATCH 1/3] xilinx: common: Fix static checker warnings
Avoid signed extension for uuid and byte.
Eliminate the below smatch warnings: board/xilinx/common/board.c:128 xilinx_eeprom_legacy_cleanup() warn: impossible condition '(byte == 255) => ((-128)-127 == 255)'
board/xilinx/common/board.c:466 board_late_init_xilinx() warn: argument 3 to %02x specifier has type 'char' board/xilinx/common/board.c:466 board_late_init_xilinx() warn: argument 4 to %02x specifier has type 'char'
Signed-off-by: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com --- board/xilinx/common/board.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/board/xilinx/common/board.c b/board/xilinx/common/board.c index 9b4aded466..2b6ead5269 100644 --- a/board/xilinx/common/board.c +++ b/board/xilinx/common/board.c @@ -119,7 +119,7 @@ struct xilinx_legacy_format { static void xilinx_eeprom_legacy_cleanup(char *eeprom, int size) { int i; - char byte; + unsigned char byte;
for (i = 0; i < size; i++) { byte = eeprom[i]; @@ -458,8 +458,8 @@ int board_late_init_xilinx(void) desc->serial);
if (desc->uuid[0]) { - char uuid[UUID_STR_LEN + 1]; - char *t = desc->uuid; + unsigned char uuid[UUID_STR_LEN + 1]; + unsigned char *t = desc->uuid;
memset(uuid, 0, UUID_STR_LEN + 1);
Please ignore this patch.
Thanks Venkatesh
-----Original Message----- From: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com Sent: Monday, September 26, 2022 11:55 AM To: u-boot@lists.denx.de Cc: Simek, Michal michal.simek@amd.com; git@xilinx.com Subject: [v2 UBOOT PATCH 1/3] xilinx: common: Fix static checker warnings
- char byte;
unsigned char byte;
unsigned char *t = desc->uuid; memset(uuid, 0, UUID_STR_LEN + 1);
-- 2.17.1
Abbarapu, Venkatesh
