[U-Boot] [GIT PULL] Pull request: u-boot-imx
Hi Albert,
please pull from u-boot-imx, thanks.
The following changes since commit 8abcd8ab962cd5fb2a4c025e7c7b62a9faf4aa08:
DaVinci DA8xx: fix set_cpu_clk_info() (2012-08-05 22:02:40 +0200)
git://www.denx.de/git/u-boot-imx.git master
for you to fetch changes up to c031cea4c7f5af2aba58e8883eb5cca871213d1b:
MX28: Add SchulerControl SC_SPS_1 platform (2012-08-07 17:49:55 +0200)
---------------------------------------------------------------- Fabio Estevam (3): mx28evk: Turn on caches mx51evk: do not overwrite the console vision2: do not overwrite the console
Marek Vasut (9): MX28: SPI: Refactor spi_xfer a bit MX28: SPI: Pull out the PIO transfer function MX28: SPI: Add DMA transfer support MX28: Fix up the MMC driver DMA mode MX28: Split out the PIO and DMA transfer functions MX28: Transfer small blocks via PIO in MXS MMC MX28: Fix MXS MMC DMA issues MX28: Move the u-boot.bd info CPUDIR/SOCDIR MX28: Add SchulerControl SC_SPS_1 platform
Otavio Salvador (9): imx: Use a clear identification of an unidentified CPU type MX28: extend print_cpuinfo() to use chip information MX28: use a clear name for DDR2 initialization mxs: reorganize source directory for easy sharing of code in i.MXS SoCs mxs: prefix register acessor macros with 'mxs' prefix mxs: prefix register structs with 'mxs' prefix mxs: Reowork SPL to use 'mxs' prefix for methods mxs: Clarify why we poweroff in case of brownout in 5v conflict mxs: rename mx28.c to mxs.c as it is common to i.MX233 and i.MX28 SoCs
Stathis Voukelatos (1): i.MX28: bug fixes in PMU configuration code
Stefano Babic (1): MX5: mx53loco: do not overwrite the console
Veli-Pekka Peltola (1): Add support for Bluegiga APX4 Development Kit
MAINTAINERS | 5 + Makefile | 2 +- arch/arm/cpu/arm926ejs/{mx28 => mxs}/Makefile | 2 +- arch/arm/cpu/arm926ejs/{mx28 => mxs}/clock.c | 40 +-- arch/arm/cpu/arm926ejs/{mx28 => mxs}/iomux.c | 6 +- arch/arm/cpu/arm926ejs/{mx28/mx28.c => mxs/mxs.c} | 72 +++-- .../arm926ejs/{mx28/mx28_init.h => mxs/mxs_init.h} | 14 +- arch/arm/cpu/arm926ejs/{mx28 => mxs}/spl_boot.c | 20 +- .../cpu/arm926ejs/{mx28 => mxs}/spl_lradc_init.c | 10 +- .../arm/cpu/arm926ejs/{mx28 => mxs}/spl_mem_init.c | 64 ++--- .../cpu/arm926ejs/{mx28 => mxs}/spl_power_init.c | 274 ++++++++++---------- arch/arm/cpu/arm926ejs/{mx28 => mxs}/start.S | 0 arch/arm/cpu/arm926ejs/{mx28 => mxs}/timer.c | 8 +- .../arm/cpu/arm926ejs/{mx28 => mxs}/u-boot-spl.lds | 2 +- .../arm/cpu/arm926ejs/mxs}/u-boot.bd | 0 arch/arm/cpu/armv7/imx-common/cpu.c | 4 +- .../include/asm/{arch-mx28 => arch-mxs}/clock.h | 0 arch/arm/include/asm/{arch-mx28 => arch-mxs}/dma.h | 0 .../arm/include/asm/{arch-mx28 => arch-mxs}/gpio.h | 0 .../include/asm/{arch-mx28 => arch-mxs}/imx-regs.h | 0 .../asm/{arch-mx28 => arch-mxs}/iomux-mx28.h | 0 .../include/asm/{arch-mx28 => arch-mxs}/iomux.h | 0 .../asm/{arch-mx28 => arch-mxs}/regs-apbh.h | 256 +++++++++--------- .../asm/{arch-mx28 => arch-mxs}/regs-base.h | 0 .../include/asm/{arch-mx28 => arch-mxs}/regs-bch.h | 44 ++-- .../asm/{arch-mx28 => arch-mxs}/regs-clkctrl.h | 60 ++--- .../asm/{arch-mx28 => arch-mxs}/regs-common.h | 34 +-- .../asm/{arch-mx28 => arch-mxs}/regs-digctl.h | 56 ++-- .../asm/{arch-mx28 => arch-mxs}/regs-gpmi.h | 28 +- .../include/asm/{arch-mx28 => arch-mxs}/regs-i2c.h | 30 +-- .../asm/{arch-mx28 => arch-mxs}/regs-lcdif.h | 66 ++--- .../asm/{arch-mx28 => arch-mxs}/regs-lradc.h | 50 ++-- .../asm/{arch-mx28 => arch-mxs}/regs-ocotp.h | 88 +++---- .../asm/{arch-mx28 => arch-mxs}/regs-pinctrl.h | 170 ++++++------ .../asm/{arch-mx28 => arch-mxs}/regs-power.h | 30 +-- .../include/asm/{arch-mx28 => arch-mxs}/regs-rtc.h | 30 +-- .../include/asm/{arch-mx28 => arch-mxs}/regs-ssp.h | 42 +-- .../asm/{arch-mx28 => arch-mxs}/regs-timrot.h | 40 +-- .../include/asm/{arch-mx28 => arch-mxs}/regs-usb.h | 2 +- .../asm/{arch-mx28 => arch-mxs}/regs-usbphy.h | 22 +- .../asm/{arch-mx28 => arch-mxs}/sys_proto.h | 10 +- board/bluegiga/apx4devkit/Makefile | 47 ++++ board/bluegiga/apx4devkit/apx4devkit.c | 150 +++++++++++ board/bluegiga/apx4devkit/spl_boot.c | 164 ++++++++++++ board/denx/m28evk/m28evk.c | 4 +- board/denx/m28evk/spl_boot.c | 2 +- board/freescale/mx28evk/iomux.c | 2 +- board/freescale/mx28evk/mx28evk.c | 4 +- board/freescale/mx28evk/u-boot.bd | 14 - board/freescale/mx51evk/mx51evk.c | 10 +- board/freescale/mx53loco/mx53loco.c | 12 +- board/schulercontrol/sc_sps_1/Makefile | 47 ++++ board/schulercontrol/sc_sps_1/sc_sps_1.c | 113 ++++++++ board/schulercontrol/sc_sps_1/spl_boot.c | 165 ++++++++++++ board/ttcontrol/vision2/vision2.c | 11 +- boards.cfg | 6 +- doc/README.m28 | 4 +- doc/README.mx28evk | 4 +- drivers/dma/apbh_dma.c | 32 +-- drivers/gpio/mxs_gpio.c | 16 +- drivers/i2c/mxs_i2c.c | 12 +- drivers/mmc/mxsmmc.c | 202 ++++++++------- drivers/mtd/nand/mxs_nand.c | 12 +- drivers/rtc/mxsrtc.c | 6 +- drivers/spi/mxs_spi.c | 200 +++++++++++--- drivers/usb/host/ehci-mxs.c | 24 +- include/configs/apx4devkit.h | 238 +++++++++++++++++ include/configs/m28evk.h | 4 +- include/configs/mx28evk.h | 6 +- include/configs/mx51evk.h | 2 + include/configs/mx53loco.h | 2 + include/configs/sc_sps_1.h | 208 +++++++++++++++ include/configs/vision2.h | 2 + 73 files changed, 2324 insertions(+), 982 deletions(-) rename arch/arm/cpu/arm926ejs/{mx28 => mxs}/Makefile (97%) rename arch/arm/cpu/arm926ejs/{mx28 => mxs}/clock.c (89%) rename arch/arm/cpu/arm926ejs/{mx28 => mxs}/iomux.c (94%) rename arch/arm/cpu/arm926ejs/{mx28/mx28.c => mxs/mxs.c} (79%) rename arch/arm/cpu/arm926ejs/{mx28/mx28_init.h => mxs/mxs_init.h} (81%) rename arch/arm/cpu/arm926ejs/{mx28 => mxs}/spl_boot.c (90%) rename arch/arm/cpu/arm926ejs/{mx28 => mxs}/spl_lradc_init.c (91%) rename arch/arm/cpu/arm926ejs/{mx28 => mxs}/spl_mem_init.c (83%) rename arch/arm/cpu/arm926ejs/{mx28 => mxs}/spl_power_init.c (81%) rename arch/arm/cpu/arm926ejs/{mx28 => mxs}/start.S (100%) rename arch/arm/cpu/arm926ejs/{mx28 => mxs}/timer.c (95%) rename arch/arm/cpu/arm926ejs/{mx28 => mxs}/u-boot-spl.lds (97%) rename {board/denx/m28evk => arch/arm/cpu/arm926ejs/mxs}/u-boot.bd (100%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/clock.h (100%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/dma.h (100%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/gpio.h (100%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/imx-regs.h (100%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/iomux-mx28.h (100%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/iomux.h (100%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/regs-apbh.h (77%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/regs-base.h (100%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/regs-bch.h (92%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/regs-clkctrl.h (88%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/regs-common.h (78%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/regs-digctl.h (77%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/regs-gpmi.h (95%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/regs-i2c.h (94%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/regs-lcdif.h (84%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/regs-lradc.h (96%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/regs-ocotp.h (71%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/regs-pinctrl.h (93%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/regs-power.h (97%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/regs-rtc.h (91%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/regs-ssp.h (95%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/regs-timrot.h (90%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/regs-usb.h (99%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/regs-usbphy.h (94%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/sys_proto.h (89%) create mode 100644 board/bluegiga/apx4devkit/Makefile create mode 100644 board/bluegiga/apx4devkit/apx4devkit.c create mode 100644 board/bluegiga/apx4devkit/spl_boot.c delete mode 100644 board/freescale/mx28evk/u-boot.bd create mode 100644 board/schulercontrol/sc_sps_1/Makefile create mode 100644 board/schulercontrol/sc_sps_1/sc_sps_1.c create mode 100644 board/schulercontrol/sc_sps_1/spl_boot.c create mode 100644 include/configs/apx4devkit.h create mode 100644 include/configs/sc_sps_1.h
Best regards, Stefano
Hi Albert,
an update pull request, please pull from u-boot-imx, thanks.
for you to fetch changes up to 42abce776222a5d5cb2b355e77539cabb705b04a:
sc_sps_1: Adjust board config to use 'mxs' SoC code (2012-08-10 08:48:24 +0200)
---------------------------------------------------------------- Benoît Thébaudeau (1): rtc: imxdi: Initial support
Otavio Salvador (10): imx: Use a clear identification of an unidentified CPU type MX28: extend print_cpuinfo() to use chip information MX28: use a clear name for DDR2 initialization mxs: reorganize source directory for easy sharing of code in i.MXS SoCs mxs: prefix register acessor macros with 'mxs' prefix mxs: prefix register structs with 'mxs' prefix mxs: Reowork SPL to use 'mxs' prefix for methods mxs: Clarify why we poweroff in case of brownout in 5v conflict mxs: rename mx28.c to mxs.c as it is common to i.MX233 and i.MX28 SoCs sc_sps_1: Adjust board config to use 'mxs' SoC code
MAINTAINERS | 5 + Makefile | 2 +- arch/arm/cpu/arm926ejs/{mx28 => mxs}/Makefile | 2 +- arch/arm/cpu/arm926ejs/{mx28 => mxs}/clock.c | 40 +-- arch/arm/cpu/arm926ejs/{mx28 => mxs}/iomux.c | 6 +- arch/arm/cpu/arm926ejs/{mx28/mx28.c => mxs/mxs.c} | 72 +++-- .../arm926ejs/{mx28/mx28_init.h => mxs/mxs_init.h} | 14 +- arch/arm/cpu/arm926ejs/{mx28 => mxs}/spl_boot.c | 20 +- .../cpu/arm926ejs/{mx28 => mxs}/spl_lradc_init.c | 10 +- .../arm/cpu/arm926ejs/{mx28 => mxs}/spl_mem_init.c | 64 ++--- .../cpu/arm926ejs/{mx28 => mxs}/spl_power_init.c | 274 ++++++++++---------- arch/arm/cpu/arm926ejs/{mx28 => mxs}/start.S | 0 arch/arm/cpu/arm926ejs/{mx28 => mxs}/timer.c | 8 +- .../arm/cpu/arm926ejs/{mx28 => mxs}/u-boot-spl.lds | 2 +- .../arm/cpu/arm926ejs/mxs}/u-boot.bd | 0 arch/arm/cpu/armv7/imx-common/cpu.c | 4 +- .../include/asm/{arch-mx28 => arch-mxs}/clock.h | 0 arch/arm/include/asm/{arch-mx28 => arch-mxs}/dma.h | 0 .../arm/include/asm/{arch-mx28 => arch-mxs}/gpio.h | 0 .../include/asm/{arch-mx28 => arch-mxs}/imx-regs.h | 0 .../asm/{arch-mx28 => arch-mxs}/iomux-mx28.h | 0 .../include/asm/{arch-mx28 => arch-mxs}/iomux.h | 0 .../asm/{arch-mx28 => arch-mxs}/regs-apbh.h | 256 +++++++++--------- .../asm/{arch-mx28 => arch-mxs}/regs-base.h | 0 .../include/asm/{arch-mx28 => arch-mxs}/regs-bch.h | 44 ++-- .../asm/{arch-mx28 => arch-mxs}/regs-clkctrl.h | 60 ++--- .../asm/{arch-mx28 => arch-mxs}/regs-common.h | 34 +-- .../asm/{arch-mx28 => arch-mxs}/regs-digctl.h | 56 ++-- .../asm/{arch-mx28 => arch-mxs}/regs-gpmi.h | 28 +- .../include/asm/{arch-mx28 => arch-mxs}/regs-i2c.h | 30 +-- .../asm/{arch-mx28 => arch-mxs}/regs-lcdif.h | 66 ++--- .../asm/{arch-mx28 => arch-mxs}/regs-lradc.h | 50 ++-- .../asm/{arch-mx28 => arch-mxs}/regs-ocotp.h | 88 +++---- .../asm/{arch-mx28 => arch-mxs}/regs-pinctrl.h | 170 ++++++------ .../asm/{arch-mx28 => arch-mxs}/regs-power.h | 30 +-- .../include/asm/{arch-mx28 => arch-mxs}/regs-rtc.h | 30 +-- .../include/asm/{arch-mx28 => arch-mxs}/regs-ssp.h | 42 +-- .../asm/{arch-mx28 => arch-mxs}/regs-timrot.h | 40 +-- .../include/asm/{arch-mx28 => arch-mxs}/regs-usb.h | 2 +- .../asm/{arch-mx28 => arch-mxs}/regs-usbphy.h | 22 +- .../asm/{arch-mx28 => arch-mxs}/sys_proto.h | 10 +- board/bluegiga/apx4devkit/Makefile | 47 ++++ board/bluegiga/apx4devkit/apx4devkit.c | 150 +++++++++++ board/bluegiga/apx4devkit/spl_boot.c | 164 ++++++++++++ board/denx/m28evk/m28evk.c | 4 +- board/denx/m28evk/spl_boot.c | 2 +- board/freescale/mx28evk/iomux.c | 2 +- board/freescale/mx28evk/mx28evk.c | 4 +- board/freescale/mx28evk/u-boot.bd | 14 - board/freescale/mx51evk/mx51evk.c | 10 +- board/freescale/mx53loco/mx53loco.c | 12 +- board/schulercontrol/sc_sps_1/Makefile | 47 ++++ board/schulercontrol/sc_sps_1/sc_sps_1.c | 113 ++++++++ board/schulercontrol/sc_sps_1/spl_boot.c | 165 ++++++++++++ board/ttcontrol/vision2/vision2.c | 11 +- boards.cfg | 6 +- doc/README.m28 | 4 +- doc/README.mx28evk | 4 +- drivers/dma/apbh_dma.c | 32 +-- drivers/gpio/mxs_gpio.c | 16 +- drivers/i2c/mxs_i2c.c | 12 +- drivers/mmc/mxsmmc.c | 202 ++++++++------- drivers/mtd/nand/mxs_nand.c | 12 +- drivers/rtc/Makefile | 1 + drivers/rtc/imxdi.c | 244 +++++++++++++++++ drivers/rtc/mxsrtc.c | 6 +- drivers/spi/mxs_spi.c | 200 +++++++++++--- drivers/usb/host/ehci-mxs.c | 24 +- include/configs/apx4devkit.h | 238 +++++++++++++++++ include/configs/m28evk.h | 4 +- include/configs/mx28evk.h | 6 +- include/configs/mx51evk.h | 2 + include/configs/mx53loco.h | 2 + include/configs/sc_sps_1.h | 208 +++++++++++++++ include/configs/vision2.h | 2 + 75 files changed, 2569 insertions(+), 982 deletions(-) rename arch/arm/cpu/arm926ejs/{mx28 => mxs}/Makefile (97%) rename arch/arm/cpu/arm926ejs/{mx28 => mxs}/clock.c (89%) rename arch/arm/cpu/arm926ejs/{mx28 => mxs}/iomux.c (94%) rename arch/arm/cpu/arm926ejs/{mx28/mx28.c => mxs/mxs.c} (79%) rename arch/arm/cpu/arm926ejs/{mx28/mx28_init.h => mxs/mxs_init.h} (81%) rename arch/arm/cpu/arm926ejs/{mx28 => mxs}/spl_boot.c (90%) rename arch/arm/cpu/arm926ejs/{mx28 => mxs}/spl_lradc_init.c (91%) rename arch/arm/cpu/arm926ejs/{mx28 => mxs}/spl_mem_init.c (83%) rename arch/arm/cpu/arm926ejs/{mx28 => mxs}/spl_power_init.c (81%) rename arch/arm/cpu/arm926ejs/{mx28 => mxs}/start.S (100%) rename arch/arm/cpu/arm926ejs/{mx28 => mxs}/timer.c (95%) rename arch/arm/cpu/arm926ejs/{mx28 => mxs}/u-boot-spl.lds (97%) rename {board/denx/m28evk => arch/arm/cpu/arm926ejs/mxs}/u-boot.bd (100%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/clock.h (100%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/dma.h (100%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/gpio.h (100%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/imx-regs.h (100%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/iomux-mx28.h (100%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/iomux.h (100%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/regs-apbh.h (77%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/regs-base.h (100%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/regs-bch.h (92%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/regs-clkctrl.h (88%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/regs-common.h (78%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/regs-digctl.h (77%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/regs-gpmi.h (95%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/regs-i2c.h (94%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/regs-lcdif.h (84%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/regs-lradc.h (96%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/regs-ocotp.h (71%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/regs-pinctrl.h (93%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/regs-power.h (97%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/regs-rtc.h (91%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/regs-ssp.h (95%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/regs-timrot.h (90%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/regs-usb.h (99%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/regs-usbphy.h (94%) rename arch/arm/include/asm/{arch-mx28 => arch-mxs}/sys_proto.h (89%) create mode 100644 board/bluegiga/apx4devkit/Makefile create mode 100644 board/bluegiga/apx4devkit/apx4devkit.c create mode 100644 board/bluegiga/apx4devkit/spl_boot.c delete mode 100644 board/freescale/mx28evk/u-boot.bd create mode 100644 board/schulercontrol/sc_sps_1/Makefile create mode 100644 board/schulercontrol/sc_sps_1/sc_sps_1.c create mode 100644 board/schulercontrol/sc_sps_1/spl_boot.c create mode 100644 drivers/rtc/imxdi.c create mode 100644 include/configs/apx4devkit.h create mode 100644 include/configs/sc_sps_1.h
Hi Stefano,
On Fri, 10 Aug 2012 08:54:06 +0200, Stefano Babic sbabic@denx.de wrote:
Hi Albert,
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
Stefano Babic
