[U-Boot] Establishing connection via Ethernet
Hi all, Is it feasible to send u-boot commands via Ethernet instead of UART? I know that there is no such support right now. But can it be added? Moreover how am I supposed to transmit UDP or TCP packets from u-boot?
-- -PIYUSH
Hi Piyush,
Look into netconsole for control over Ethernet. I haven't used it personally, but it's supported in U-boot.
What kind of UDP or TCP packets do you want to send? Many of the common UDP-based protocols have some support (NFS, TFTP and some others), but keep in mind that U-boot is not a multitasking environment and so there is no concept of 'servers'. Apart from netconsole, all network communications must start from the target.
regards, Ben
Hi Ben
On Thu, Jan 29, 2009 at 2:03 PM, Ben Warren biggerbadderben@gmail.com wrote:
Hi Piyush,
This is what I wanted Thanks a lot
regards, Ben
Dear Piyush Shah,
In message ad27f3010901290022l2957affex8256b7f34b1190e6@mail.gmail.com you wrote:
yes it it.
You are wrong. The support is right there, and has been there for a long, long time.
UDP only. There is no TCP capable stack in U-Boot.
Ben Warren
Piyush Shah
