[PATCH 1/3] tpm: update tpm hash algorithm according to tpm2.0 spec 1.59
The hash algorithm structure shall reflect the TCG specification for TPM2.0 With vesion 1.59, the SHA3 algorithm has been added and shall be reflected in this structure. The fact that U-Boot does or does not support SHA3 algo yet is not relevant for this structure. It's up to the end user to configure the active PCR bank to supported hash algorithm by all boot chain component. Also, by default, TPM2.0 shall support at least SHA256 and SHA384, in practice dTPM support 2 actives banks with this 2 hash algorithms
Signed-off-by: Benjamin BARATTE mailto:benjamin.baratte@st.com ---
include/tpm-v2.h | 35 ++++++++++++++++++++++++++++++----- 1 file changed, 30 insertions(+), 5 deletions(-)
diff --git a/include/tpm-v2.h b/include/tpm-v2.h index 4fd19c52fd..9848e1fd10 100644 --- a/include/tpm-v2.h +++ b/include/tpm-v2.h @@ -253,6 +253,9 @@ enum tpm2_algorithms { TPM2_ALG_SHA512 = 0x0D, TPM2_ALG_NULL = 0x10, TPM2_ALG_SM3_256 = 0x12, + TPM2_ALG_SHA3_256 = 0x27, + TPM2_ALG_SHA3_384 = 0x28, + TPM2_ALG_SHA3_512 = 0x29, };
/** @@ -271,11 +274,15 @@ struct digest_info { };
/* Algorithm Registry */ -#define TCG2_BOOT_HASH_ALG_SHA1 0x00000001 -#define TCG2_BOOT_HASH_ALG_SHA256 0x00000002 -#define TCG2_BOOT_HASH_ALG_SHA384 0x00000004 -#define TCG2_BOOT_HASH_ALG_SHA512 0x00000008 -#define TCG2_BOOT_HASH_ALG_SM3_256 0x00000010 +#define TCG2_BOOT_HASH_ALG_SHA1 0x00000001 +#define TCG2_BOOT_HASH_ALG_SHA256 0x00000002 +#define TCG2_BOOT_HASH_ALG_SHA384 0x00000004 +#define TCG2_BOOT_HASH_ALG_SHA512 0x00000008 +#define TCG2_BOOT_HASH_ALG_SM3_256 0x00000010 +#define TCG2_BOOT_HASH_ALG_SHA3_256 0x00000020 +#define TCG2_BOOT_HASH_ALG_SHA3_384 0x00000040 +#define TCG2_BOOT_HASH_ALG_SHA3_512 0x00000080 +
static const struct digest_info hash_algo_list[] = { #if IS_ENABLED(CONFIG_SHA1) @@ -310,6 +317,24 @@ static const struct digest_info hash_algo_list[] = { TPM2_SHA512_DIGEST_SIZE, }, #endif + { + "sha3_256", + TPM2_ALG_SHA3_256, + TCG2_BOOT_HASH_ALG_SHA3_256, + TPM2_SHA256_DIGEST_SIZE, + }, + { + "sha3_384", + TPM2_ALG_SHA3_384, + TCG2_BOOT_HASH_ALG_SHA3_384, + TPM2_SHA384_DIGEST_SIZE, + }, + { + "sha3_512", + TPM2_ALG_SHA3_512, + TCG2_BOOT_HASH_ALG_SHA3_512, + TPM2_SHA512_DIGEST_SIZE, + }, };
/* NV index attributes */ -- 2.34.1
ST Restricted
Hi Benjamin,
Apologies for the late reply, but I wasn't cc'ed in the series. Did you use get_maintainer.pl for the recipients?
It's not, but I don't see why we should add more algorithms if we don't plan to support them. Any plans of adding actual support for the SHA3 family?
Thanks /Ilias
"sha3_256",
TPM2_ALG_SHA3_256,
"sha3_384",
TPM2_ALG_SHA3_384,
"sha3_512",
TPM2_ALG_SHA3_512,
2.34.1
ST Restricted
Hi @Ilias Apalodimas,
ST Restricted
-----Original Message----- From: Ilias Apalodimas ilias.apalodimas@linaro.org Sent: Monday, July 29, 2024 3:55 PM To: Benjamin BARATTE benjamin.baratte@st.com Cc: u-boot@lists.denx.de; eajames@linux.ibm.com; sjg@chromium.org; tharvey@gateworks.com; trini@konsulko.com Subject: Re: [PATCH 1/3] tpm: update tpm hash algorithm according to tpm2.0 spec 1.59
Hi Benjamin,
I have tried but due to the corporate setup, I'm not able to use the script to format and send the message automatically...
The main issue here is that the new version of hardware TPM are now using default PCR configuration with SHA256 and SHA384 as per the TCG specifications and U-boot can't support them and generate error at boot time.
For the SHA3 family support, they are supported in the Linux Kernel already, therefore, this should be supported in the U-boot to ensure consistency in the full boot chain.
Also, TPM API offer hash interface, therefore if the PCR is using SHA3, the hash calculation could be done by the TPM regardless of the software support in U-boot.
Best Regards,
Benjamin
Thanks /Ilias
/* Algorithm Registry */ -#define TCG2_BOOT_HASH_ALG_SHA1 0x00000001 -#define TCG2_BOOT_HASH_ALG_SHA256 0x00000002 -#define TCG2_BOOT_HASH_ALG_SHA384 0x00000004 -#define TCG2_BOOT_HASH_ALG_SHA512 0x00000008 -#define TCG2_BOOT_HASH_ALG_SM3_256 0x00000010 +#define TCG2_BOOT_HASH_ALG_SHA1 0x00000001 +#define TCG2_BOOT_HASH_ALG_SHA256 0x00000002 +#define TCG2_BOOT_HASH_ALG_SHA384 0x00000004 +#define TCG2_BOOT_HASH_ALG_SHA512 0x00000008 +#define TCG2_BOOT_HASH_ALG_SM3_256 0x00000010 #define +TCG2_BOOT_HASH_ALG_SHA3_256 0x00000020 #define +TCG2_BOOT_HASH_ALG_SHA3_384 0x00000040 #define +TCG2_BOOT_HASH_ALG_SHA3_512 0x00000080
"sha3_256",
TPM2_ALG_SHA3_256,
"sha3_384",
TPM2_ALG_SHA3_384,
"sha3_512",
TPM2_ALG_SHA3_512,
2.34.1
ST Restricted
Hi Benjamin
On Fri, 23 Aug 2024 at 15:25, Benjamin BARATTE benjamin.baratte@st.com wrote:
ST Restricted
Hi Benjamin,
Why? e7505b3b8bcd1b introduced the errors but sha256,384 are already supported. Unless you mean sha3-256?
You are just adding the defines here. The commit above has the reasoning of why we block measurements, and just adding the defines to bypass the check is not the right thing to do.
I am not exactly sure what you mean here. Is that part of the API in U-Boot?
Thanks /Ilias
Best Regards,
Benjamin
Thanks /Ilias
"sha3_256",
TPM2_ALG_SHA3_256,
"sha3_384",
TPM2_ALG_SHA3_384,
"sha3_512",
TPM2_ALG_SHA3_512,
2.34.1
ST Restricted
Hi Ilas,
Could you comment my last mail on this topic ?
Thanks,
Benjamin
-----Original Message----- From: Benjamin BARATTE Sent: Friday, August 23, 2024 2:25 PM To: 'Ilias Apalodimas' ilias.apalodimas@linaro.org Cc: u-boot@lists.denx.de; eajames@linux.ibm.com; sjg@chromium.org; tharvey@gateworks.com; trini@konsulko.com Subject: RE: [PATCH 1/3] tpm: update tpm hash algorithm according to tpm2.0 spec 1.59
Hi Benjamin,
family?
Also, TPM API offer hash interface, therefore if the PCR is using SHA3, the hash calculation could be done by the TPM regardless of the software support in U- boot.
Best Regards,
Benjamin
Thanks /Ilias
"sha3_256",
TPM2_ALG_SHA3_256,
"sha3_384",
TPM2_ALG_SHA3_384,
"sha3_512",
TPM2_ALG_SHA3_512,
2.34.1
ST Restricted
Benjamin BARATTE
Ilias Apalodimas
