[PATCH v3 0/4] Support SiFive Composable cache driver
This patch set contains the SiFive composable cache support, and indroduce an interface to do cache initialization, each platform can overwrite it by their own implementation.
Changed in v3: - Combine some patches - Drop the subdirectories of vendor in lib/ - Rebase codebase
Changed in v2: - Refine the ccache driver by Sean's suggestions - Introduce a common interface for cache initialization
Zong Li (4): cache: add sifive composable cache driver riscv: lib: introduce a cache_init interface board: sifive: use ccache driver instead of helper function riscv: lib: modify the indent
arch/riscv/Kconfig | 5 ++ arch/riscv/cpu/fu540/Kconfig | 2 + arch/riscv/cpu/fu540/Makefile | 1 - arch/riscv/cpu/fu540/cache.c | 55 ----------------- arch/riscv/cpu/fu740/Kconfig | 2 + arch/riscv/cpu/fu740/Makefile | 1 - arch/riscv/cpu/fu740/cache.c | 55 ----------------- arch/riscv/include/asm/arch-fu540/cache.h | 14 ----- arch/riscv/include/asm/arch-fu740/cache.h | 14 ----- arch/riscv/include/asm/cache.h | 3 +- arch/riscv/lib/Makefile | 1 + arch/riscv/lib/cache.c | 5 ++ arch/riscv/lib/sifive_cache.c | 27 ++++++++ board/sifive/unleashed/unleashed.c | 12 +--- board/sifive/unmatched/unmatched.c | 11 +--- drivers/cache/Kconfig | 7 +++ drivers/cache/Makefile | 1 + drivers/cache/cache-sifive-ccache.c | 75 +++++++++++++++++++++++ 18 files changed, 131 insertions(+), 160 deletions(-) delete mode 100644 arch/riscv/cpu/fu540/cache.c delete mode 100644 arch/riscv/cpu/fu740/cache.c delete mode 100644 arch/riscv/include/asm/arch-fu540/cache.h delete mode 100644 arch/riscv/include/asm/arch-fu740/cache.h create mode 100644 arch/riscv/lib/sifive_cache.c create mode 100644 drivers/cache/cache-sifive-ccache.c
This driver is currently responsible for enabling all ccache ways. Composable cache could be configure as RAM or cache, we will use it as RAM at the beginning to put the u-boot SPL there. In u-boot proper phrase, we will use the composable cache as cache, and try to enable the cache ways.
Signed-off-by: Zong Li zong.li@sifive.com Reviewed-by: Sean Anderson seanga2@gmail.com --- drivers/cache/Kconfig | 7 +++ drivers/cache/Makefile | 1 + drivers/cache/cache-sifive-ccache.c | 75 +++++++++++++++++++++++++++++ 3 files changed, 83 insertions(+) create mode 100644 drivers/cache/cache-sifive-ccache.c
diff --git a/drivers/cache/Kconfig b/drivers/cache/Kconfig index 1e452ad6d9..40f41a817c 100644 --- a/drivers/cache/Kconfig +++ b/drivers/cache/Kconfig @@ -39,4 +39,11 @@ config NCORE_CACHE controller. The driver initializes cache directories and coherent agent interfaces.
+config SIFIVE_CCACHE + bool "SiFive composable cache" + select CACHE + help + This driver is for SiFive Composable L2/L3 cache. It enables cache + ways of composable cache. + endmenu diff --git a/drivers/cache/Makefile b/drivers/cache/Makefile index fed50be3f9..ad765774e3 100644 --- a/drivers/cache/Makefile +++ b/drivers/cache/Makefile @@ -4,3 +4,4 @@ obj-$(CONFIG_SANDBOX) += sandbox_cache.o obj-$(CONFIG_L2X0_CACHE) += cache-l2x0.o obj-$(CONFIG_NCORE_CACHE) += cache-ncore.o obj-$(CONFIG_V5L2_CACHE) += cache-v5l2.o +obj-$(CONFIG_SIFIVE_CCACHE) += cache-sifive-ccache.o diff --git a/drivers/cache/cache-sifive-ccache.c b/drivers/cache/cache-sifive-ccache.c new file mode 100644 index 0000000000..76c0ab26ae --- /dev/null +++ b/drivers/cache/cache-sifive-ccache.c @@ -0,0 +1,75 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2021 SiFive + */ + +#include <common.h> +#include <cache.h> +#include <dm.h> +#include <asm/io.h> +#include <dm/device.h> +#include <linux/bitfield.h> + +#define SIFIVE_CCACHE_CONFIG 0x000 +#define SIFIVE_CCACHE_CONFIG_WAYS GENMASK(15, 8) + +#define SIFIVE_CCACHE_WAY_ENABLE 0x008 + +struct sifive_ccache { + void __iomem *base; +}; + +static int sifive_ccache_enable(struct udevice *dev) +{ + struct sifive_ccache *priv = dev_get_priv(dev); + u32 config; + u32 ways; + + /* Enable all ways of composable cache */ + config = readl(priv->base + SIFIVE_CCACHE_CONFIG); + ways = FIELD_GET(SIFIVE_CCACHE_CONFIG_WAYS, config); + + writel(ways - 1, priv->base + SIFIVE_CCACHE_WAY_ENABLE); + + return 0; +} + +static int sifive_ccache_get_info(struct udevice *dev, struct cache_info *info) +{ + struct sifive_ccache *priv = dev_get_priv(dev); + + info->base = (phys_addr_t)priv->base; + + return 0; +} + +static const struct cache_ops sifive_ccache_ops = { + .enable = sifive_ccache_enable, + .get_info = sifive_ccache_get_info, +}; + +static int sifive_ccache_probe(struct udevice *dev) +{ + struct sifive_ccache *priv = dev_get_priv(dev); + + priv->base = dev_read_addr_ptr(dev); + if (!priv->base) + return -EINVAL; + + return 0; +} + +static const struct udevice_id sifive_ccache_ids[] = { + { .compatible = "sifive,fu540-c000-ccache" }, + { .compatible = "sifive,fu740-c000-ccache" }, + {} +}; + +U_BOOT_DRIVER(sifive_ccache) = { + .name = "sifive_ccache", + .id = UCLASS_CACHE, + .of_match = sifive_ccache_ids, + .probe = sifive_ccache_probe, + .priv_auto = sizeof(struct sifive_ccache), + .ops = &sifive_ccache_ops, +};
Add an interface for cache initialization. Each platform can overwrite this weak function by their own implementation, such as sifive_cache in this patch.
In sifive_cache, it invokes the generic cache_enable interface of cache uclass to execute the relative implementation in SiFive ccache driver.
Signed-off-by: Zong Li zong.li@sifive.com --- arch/riscv/Kconfig | 5 +++++ arch/riscv/include/asm/cache.h | 1 + arch/riscv/lib/Makefile | 1 + arch/riscv/lib/cache.c | 5 +++++ arch/riscv/lib/sifive_cache.c | 27 +++++++++++++++++++++++++++ 5 files changed, 39 insertions(+) create mode 100644 arch/riscv/lib/sifive_cache.c
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index 4b0c3dffa6..ec651fe0a4 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -179,6 +179,11 @@ config SPL_SIFIVE_CLINT The SiFive CLINT block holds memory-mapped control and status registers associated with software and timer interrupts.
+config SIFIVE_CACHE + bool + help + This enables the operations to configure SiFive cache + config ANDES_PLIC bool depends on RISCV_MMODE || SPL_RISCV_MMODE diff --git a/arch/riscv/include/asm/cache.h b/arch/riscv/include/asm/cache.h index ec8fe201d3..6ebb2b4329 100644 --- a/arch/riscv/include/asm/cache.h +++ b/arch/riscv/include/asm/cache.h @@ -9,6 +9,7 @@
/* cache */ void cache_flush(void); +int cache_init(void);
/* * The current upper bound for RISCV L1 data cache line sizes is 32 bytes. diff --git a/arch/riscv/lib/Makefile b/arch/riscv/lib/Makefile index c4cc41434b..06020fcc2a 100644 --- a/arch/riscv/lib/Makefile +++ b/arch/riscv/lib/Makefile @@ -10,6 +10,7 @@ obj-$(CONFIG_CMD_BOOTM) += bootm.o obj-$(CONFIG_CMD_BOOTI) += bootm.o image.o obj-$(CONFIG_CMD_GO) += boot.o obj-y += cache.o +obj-$(CONFIG_SIFIVE_CACHE) += sifive_cache.o ifeq ($(CONFIG_$(SPL_)RISCV_MMODE),y) obj-$(CONFIG_$(SPL_)SIFIVE_CLINT) += sifive_clint.o obj-$(CONFIG_ANDES_PLIC) += andes_plic.o diff --git a/arch/riscv/lib/cache.c b/arch/riscv/lib/cache.c index b1d42bcc2b..2cd66504c6 100644 --- a/arch/riscv/lib/cache.c +++ b/arch/riscv/lib/cache.c @@ -70,3 +70,8 @@ __weak int dcache_status(void) { return 0; } + +__weak int cache_init(void) +{ + return 0; +} diff --git a/arch/riscv/lib/sifive_cache.c b/arch/riscv/lib/sifive_cache.c new file mode 100644 index 0000000000..94e84e024e --- /dev/null +++ b/arch/riscv/lib/sifive_cache.c @@ -0,0 +1,27 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2021 SiFive, Inc + */ + +#include <common.h> +#include <cache.h> +#include <dm.h> + +int cache_init(void) +{ + struct udevice *dev; + int ret; + + /* Enable ways of ccache */ + ret = uclass_get_device_by_driver(UCLASS_CACHE, + DM_DRIVER_GET(sifive_ccache), + &dev); + if (ret) + return log_msg_ret("Cannot enable cache ways", ret); + + ret = cache_enable(dev); + if (ret) + return log_msg_ret("ccache enable failed", ret); + + return 0; +}
- bool
- help
- config ANDES_PLIC bool depends on RISCV_MMODE || SPL_RISCV_MMODE
- The current upper bound for RISCV L1 data cache line sizes is 32 bytes.
Don't make this generic. Just call a `sifive_cache_init` or whatever.
IMO this pattern shouldn't be duplicated by other platforms, but it is OK to do for now until we have a more generic method.
--Sean
- Copyright (C) 2021 SiFive, Inc
- struct udevice *dev;
- int ret;
- /* Enable ways of ccache */
- ret = uclass_get_device_by_driver(UCLASS_CACHE,
&dev);
- if (ret)
- ret = cache_enable(dev);
- if (ret)
bool
help
Hi Sean, I have sent the v4 patch to use generic enable_caches hook, it seems to me that we could add an additional arch-defined interface in the future if we really needed it, rather than at this time. Please help me to review the v4 patch and hope we are on the same page.
--Sean
int ret;
&dev);
if (ret)
if (ret)
Invokes the common cache_init function to initialize ccache.
Signed-off-by: Zong Li zong.li@sifive.com --- arch/riscv/cpu/fu540/Kconfig | 2 + arch/riscv/cpu/fu540/Makefile | 1 - arch/riscv/cpu/fu540/cache.c | 55 ----------------------- arch/riscv/cpu/fu740/Kconfig | 2 + arch/riscv/cpu/fu740/Makefile | 1 - arch/riscv/cpu/fu740/cache.c | 55 ----------------------- arch/riscv/include/asm/arch-fu540/cache.h | 14 ------ arch/riscv/include/asm/arch-fu740/cache.h | 14 ------ board/sifive/unleashed/unleashed.c | 12 +---- board/sifive/unmatched/unmatched.c | 11 +---- 10 files changed, 8 insertions(+), 159 deletions(-) delete mode 100644 arch/riscv/cpu/fu540/cache.c delete mode 100644 arch/riscv/cpu/fu740/cache.c delete mode 100644 arch/riscv/include/asm/arch-fu540/cache.h delete mode 100644 arch/riscv/include/asm/arch-fu740/cache.h
diff --git a/arch/riscv/cpu/fu540/Kconfig b/arch/riscv/cpu/fu540/Kconfig index 05463b2625..1604b412b4 100644 --- a/arch/riscv/cpu/fu540/Kconfig +++ b/arch/riscv/cpu/fu540/Kconfig @@ -19,6 +19,8 @@ config SIFIVE_FU540 imply SMP imply CLK_SIFIVE imply CLK_SIFIVE_PRCI + imply SIFIVE_CACHE + imply SIFIVE_CCACHE imply SIFIVE_SERIAL imply MACB imply MII diff --git a/arch/riscv/cpu/fu540/Makefile b/arch/riscv/cpu/fu540/Makefile index 088205ef57..043fb961a5 100644 --- a/arch/riscv/cpu/fu540/Makefile +++ b/arch/riscv/cpu/fu540/Makefile @@ -8,5 +8,4 @@ obj-y += spl.o else obj-y += dram.o obj-y += cpu.o -obj-y += cache.o endif diff --git a/arch/riscv/cpu/fu540/cache.c b/arch/riscv/cpu/fu540/cache.c deleted file mode 100644 index 0fc4ef6c00..0000000000 --- a/arch/riscv/cpu/fu540/cache.c +++ /dev/null @@ -1,55 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright (C) 2020 SiFive, Inc - * - * Authors: - * Pragnesh Patel pragnesh.patel@sifive.com - */ - -#include <common.h> -#include <asm/global_data.h> -#include <asm/io.h> -#include <linux/bitops.h> - -/* Register offsets */ -#define L2_CACHE_CONFIG 0x000 -#define L2_CACHE_ENABLE 0x008 - -#define MASK_NUM_WAYS GENMASK(15, 8) -#define NUM_WAYS_SHIFT 8 - -DECLARE_GLOBAL_DATA_PTR; - -int cache_enable_ways(void) -{ - const void *blob = gd->fdt_blob; - int node; - fdt_addr_t base; - u32 config; - u32 ways; - - volatile u32 *enable; - - node = fdt_node_offset_by_compatible(blob, -1, - "sifive,fu540-c000-ccache"); - - if (node < 0) - return node; - - base = fdtdec_get_addr_size_auto_parent(blob, 0, node, "reg", 0, - NULL, false); - if (base == FDT_ADDR_T_NONE) - return FDT_ADDR_T_NONE; - - config = readl((volatile u32 *)base + L2_CACHE_CONFIG); - ways = (config & MASK_NUM_WAYS) >> NUM_WAYS_SHIFT; - - enable = (volatile u32 *)(base + L2_CACHE_ENABLE); - - /* memory barrier */ - mb(); - (*enable) = ways - 1; - /* memory barrier */ - mb(); - return 0; -} diff --git a/arch/riscv/cpu/fu740/Kconfig b/arch/riscv/cpu/fu740/Kconfig index 408195f149..049a0a0584 100644 --- a/arch/riscv/cpu/fu740/Kconfig +++ b/arch/riscv/cpu/fu740/Kconfig @@ -19,6 +19,8 @@ config SIFIVE_FU740 imply SMP imply CLK_SIFIVE imply CLK_SIFIVE_PRCI + imply SIFIVE_CACHE + imply SIFIVE_CCACHE imply SIFIVE_SERIAL imply MACB imply MII diff --git a/arch/riscv/cpu/fu740/Makefile b/arch/riscv/cpu/fu740/Makefile index 5ef8ac18a7..1d1ad98ba7 100644 --- a/arch/riscv/cpu/fu740/Makefile +++ b/arch/riscv/cpu/fu740/Makefile @@ -8,5 +8,4 @@ obj-y += spl.o else obj-y += dram.o obj-y += cpu.o -obj-y += cache.o endif diff --git a/arch/riscv/cpu/fu740/cache.c b/arch/riscv/cpu/fu740/cache.c deleted file mode 100644 index 680955c9e3..0000000000 --- a/arch/riscv/cpu/fu740/cache.c +++ /dev/null @@ -1,55 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright (C) 2020-2021 SiFive, Inc - * - * Authors: - * Pragnesh Patel pragnesh.patel@sifive.com - */ - -#include <common.h> -#include <asm/io.h> -#include <linux/bitops.h> -#include <asm/global_data.h> - -/* Register offsets */ -#define L2_CACHE_CONFIG 0x000 -#define L2_CACHE_ENABLE 0x008 - -#define MASK_NUM_WAYS GENMASK(15, 8) -#define NUM_WAYS_SHIFT 8 - -DECLARE_GLOBAL_DATA_PTR; - -int cache_enable_ways(void) -{ - const void *blob = gd->fdt_blob; - int node; - fdt_addr_t base; - u32 config; - u32 ways; - - volatile u32 *enable; - - node = fdt_node_offset_by_compatible(blob, -1, - "sifive,fu740-c000-ccache"); - - if (node < 0) - return node; - - base = fdtdec_get_addr_size_auto_parent(blob, 0, node, "reg", 0, - NULL, false); - if (base == FDT_ADDR_T_NONE) - return FDT_ADDR_T_NONE; - - config = readl((volatile u32 *)base + L2_CACHE_CONFIG); - ways = (config & MASK_NUM_WAYS) >> NUM_WAYS_SHIFT; - - enable = (volatile u32 *)(base + L2_CACHE_ENABLE); - - /* memory barrier */ - mb(); - (*enable) = ways - 1; - /* memory barrier */ - mb(); - return 0; -} diff --git a/arch/riscv/include/asm/arch-fu540/cache.h b/arch/riscv/include/asm/arch-fu540/cache.h deleted file mode 100644 index 135a17c679..0000000000 --- a/arch/riscv/include/asm/arch-fu540/cache.h +++ /dev/null @@ -1,14 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2020 SiFive, Inc. - * - * Authors: - * Pragnesh Patel pragnesh.patel@sifve.com - */ - -#ifndef _CACHE_SIFIVE_H -#define _CACHE_SIFIVE_H - -int cache_enable_ways(void); - -#endif /* _CACHE_SIFIVE_H */ diff --git a/arch/riscv/include/asm/arch-fu740/cache.h b/arch/riscv/include/asm/arch-fu740/cache.h deleted file mode 100644 index 7d4fe9942b..0000000000 --- a/arch/riscv/include/asm/arch-fu740/cache.h +++ /dev/null @@ -1,14 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2020-2021 SiFive, Inc. - * - * Authors: - * Pragnesh Patel pragnesh.patel@sifve.com - */ - -#ifndef _CACHE_SIFIVE_H -#define _CACHE_SIFIVE_H - -int cache_enable_ways(void); - -#endif /* _CACHE_SIFIVE_H */ diff --git a/board/sifive/unleashed/unleashed.c b/board/sifive/unleashed/unleashed.c index 43027f0b54..6d697d797d 100644 --- a/board/sifive/unleashed/unleashed.c +++ b/board/sifive/unleashed/unleashed.c @@ -15,7 +15,7 @@ #include <linux/delay.h> #include <misc.h> #include <spl.h> -#include <asm/arch/cache.h> +#include <asm/cache.h> #include <asm/sections.h>
/* @@ -126,14 +126,6 @@ void *board_fdt_blob_setup(void)
int board_init(void) { - int ret; - /* enable all cache ways */ - ret = cache_enable_ways(); - if (ret) { - debug("%s: could not enable cache ways\n", __func__); - return ret; - } - - return 0; + return cache_init(); } diff --git a/board/sifive/unmatched/unmatched.c b/board/sifive/unmatched/unmatched.c index 2f5629b578..f4fc2a793d 100644 --- a/board/sifive/unmatched/unmatched.c +++ b/board/sifive/unmatched/unmatched.c @@ -8,7 +8,7 @@
#include <common.h> #include <dm.h> -#include <asm/arch/cache.h> +#include <asm/cache.h> #include <asm/sections.h>
#if defined(CONFIG_OF_SEPARATE) @@ -23,13 +23,6 @@ void *board_fdt_blob_setup(void)
int board_init(void) { - int ret; - /* enable all cache ways */ - ret = cache_enable_ways(); - if (ret) { - debug("%s: could not enable cache ways\n", __func__); - return ret; - } - return 0; + return cache_init(); }
- imply SIFIVE_CACHE
- imply SIFIVE_CCACHE imply SIFIVE_SERIAL imply MACB imply MII
- Copyright (C) 2020 SiFive, Inc
- Authors:
- Pragnesh Patel pragnesh.patel@sifive.com
- int node;
- fdt_addr_t base;
- u32 config;
- u32 ways;
- if (node < 0)
return node;
NULL, false);
- mb();
- mb();
- Copyright (C) 2020-2021 SiFive, Inc
- Authors:
- int node;
- fdt_addr_t base;
- u32 config;
- u32 ways;
- if (node < 0)
return node;
NULL, false);
- mb();
- mb();
- Copyright (C) 2020 SiFive, Inc.
- Authors:
- Pragnesh Patel pragnesh.patel@sifve.com
- Copyright (C) 2020-2021 SiFive, Inc.
- Authors:
- int ret;
- if (ret) {
return ret;
- return cache_init(); }
- int ret;
- if (ret) {
return ret;
We usually use a space in function declaration, rather than a tab.
Signed-off-by: Zong Li zong.li@sifive.com Reviewed-by: Sean Anderson seanga2@gmail.com --- arch/riscv/include/asm/cache.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/riscv/include/asm/cache.h b/arch/riscv/include/asm/cache.h index 6ebb2b4329..b700ff5021 100644 --- a/arch/riscv/include/asm/cache.h +++ b/arch/riscv/include/asm/cache.h @@ -8,7 +8,7 @@ #define _ASM_RISCV_CACHE_H
/* cache */ -void cache_flush(void); +void cache_flush(void); int cache_init(void);
Changed in v3:
- Rebase codebase
Changed in v2:
-- 2.32.0
ping
Sean Anderson
Zong Li
