[U-Boot] [PATCH 1/2] ARM: implement erratum 716044 workaround
Add common code to enable the workaround for ARM erratum 716044. This will be enabled for Tegra.
Signed-off-by: Stephen Warren swarren@nvidia.com --- This depends on my previous ARM errata series. I found out we needed another one after I wrote the first series.
README | 1 + arch/arm/cpu/armv7/start.S | 6 ++++++ 2 files changed, 7 insertions(+)
diff --git a/README b/README index f2b1c88..97ef9f0 100644 --- a/README +++ b/README @@ -485,6 +485,7 @@ The following options need to be configured: Thumb2 this flag will result in Thumb2 code generated by GCC.
+ CONFIG_ARM_ERRATA_716044 CONFIG_ARM_ERRATA_742230 CONFIG_ARM_ERRATA_743622 CONFIG_ARM_ERRATA_751472 diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index 30f02d3..6834ffe 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -310,6 +310,12 @@ ENTRY(cpu_init_cp15) #endif mcr p15, 0, r0, c1, c0, 0
+#ifdef CONFIG_ARM_ERRATA_716044 + mrc p15, 0, r0, c1, c0, 0 @ read system control register + orr r0, r0, #1 << 11 @ set bit #11 + mcr p15, 0, r0, c1, c0, 0 @ write system control register +#endif + #ifdef CONFIG_ARM_ERRATA_742230 mrc p15, 0, r0, c15, c0, 1 @ read diagnostic register orr r0, r0, #1 << 4 @ set bit #4
Tegra20 requires the workaround for this erratum. Enable it.
Signed-off-by: Stephen Warren swarren@nvidia.com --- include/configs/tegra20-common.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/tegra20-common.h b/include/configs/tegra20-common.h index e464e06..395a657 100644 --- a/include/configs/tegra20-common.h +++ b/include/configs/tegra20-common.h @@ -28,6 +28,7 @@ /* * Errata configuration */ +#define CONFIG_ARM_ERRATA_716044 #define CONFIG_ARM_ERRATA_742230 #define CONFIG_ARM_ERRATA_751472
Stephen/Albert,
-----Original Message----- From: Stephen Warren [mailto:swarren@wwwdotorg.org] Sent: Monday, March 04, 2013 4:30 PM To: u-boot@lists.denx.de; Albert Aribaud Cc: Simon Glass; Tom Warren; Stephen Warren Subject: [PATCH 2/2] ARM: tegra: enable workaround for ARM erratum 716044
diff --git a/include/configs/tegra20-common.h b/include/configs/tegra20- common.h index e464e06..395a657 100644 --- a/include/configs/tegra20-common.h +++ b/include/configs/tegra20-common.h @@ -28,6 +28,7 @@ /*
- Errata configuration
The two sets of ARM erratum patches are currently assigned to Albert. I can take just the Tegra patches, since adding these #defines won't affect anything w/o the corresponding ARM code. Let me know if you (Albert) want me to take the 2 ARM: tegra: errata patches in thru the Tegra tree, or if you'll take 'em whole hog in thru ARM.
Tom
-- nvpublic
Albert,
-----Original Message----- From: Stephen Warren [mailto:swarren@wwwdotorg.org] Sent: Monday, March 04, 2013 4:30 PM To: u-boot@lists.denx.de; Albert Aribaud Cc: Simon Glass; Tom Warren; Stephen Warren Subject: [PATCH 1/2] ARM: implement erratum 716044 workaround
This patchset from Stephen (includes "2/2 ARM: tegra: enable workaround for ARM erratum 716044") are both assigned to you in PatchWork, but haven't been applied yet to ARM/master AFAICT. I found them when I was searching for unapplied Tegra patches.
Could you please take this in thru the ARM tree ASAP?
Thanks,
Tom
CONFIG_ARM_ERRATA_742230 CONFIG_ARM_ERRATA_743622 CONFIG_ARM_ERRATA_751472CONFIG_ARM_ERRATA_716044
- mrc p15, 0, r0, c1, c0, 0 @ read system control register
- orr r0, r0, #1 << 11 @ set bit #11
- mcr p15, 0, r0, c1, c0, 0 @ write system control register
#ifdef CONFIG_ARM_ERRATA_742230 mrc p15, 0, r0, c15, c0, 1 @ read diagnostic register orr r0, r0, #1 << 4 @ set bit #4 -- 1.7.10.4
-- nvpublic
Hi Tom,
On Thu, 21 Mar 2013 09:29:14 -0700, Tom Warren TWarren@nvidia.com wrote:
Albert,
Will take them in later today. Want an ARM PR once done?
Thanks,
Tom
Amicalement,
Albert,
-----Original Message----- From: Albert ARIBAUD [mailto:albert.u.boot@aribaud.net] Sent: Thursday, March 21, 2013 10:56 AM To: Tom Warren Cc: u-boot@lists.denx.de; Simon Glass; Stephen Warren; Tom Warren; Stephen Warren Subject: Re: [PATCH 1/2] ARM: implement erratum 716044 workaround
Hi Tom,
Albert,
Just a notice that they're in TOT u-boot-arm/master, and I'll rebase u-boot-tegra/next against it.
Thanks,
Tom
Thanks,
Tom
Amicalement,
Albert.
-- nvpublic
Hi Tom,
On Thu, 21 Mar 2013 11:35:11 -0700, Tom Warren TWarren@nvidia.com wrote:
Albert,
Hi Tom,
Albert,
Hmm... I don't see them in ARM ToT on my side. Can you point me to the commit ID?
Thanks,
Tom
Amicalement,
Albert,
-----Original Message----- From: Albert ARIBAUD [mailto:albert.u.boot@aribaud.net] Sent: Thursday, March 21, 2013 11:34 PM To: Tom Warren Cc: u-boot@lists.denx.de; Tom Warren; Stephen Warren Subject: Re: [U-Boot] [PATCH 1/2] ARM: implement erratum 716044 workaround
Hi Tom,
Albert,
Hi Tom,
Albert,
I think there's some confusion here. You asked if I wanted an ARM PR - I assume you thought I was Tom Rini?
I'm Tom Warren, the Tegra custodian. I'd like to see this patchset (ARM errata 716044, 2 parts, from Stephen Warren, assigned to you in PatchWork) pulled into u-boot-arm/master. Once that happens, if you let me know it's done, I can rebase u-boot-tegra.git against u-boot-arm.git so that it's pulled into the Tegra repo.
Thanks,
Tom Warren
Thanks,
Tom
Amicalement,
Albert.
-- nvpublic
Hi Tom,
On Fri, 22 Mar 2013 08:24:14 -0700, Tom Warren TWarren@nvidia.com wrote:
Albert,
Hi Tom,
Albert,
Hi Tom,
Albert,
I had indeed ask if a PR was wanted, i.e. if you wanted the commits to also go to u-boot/master, as the request seemed urgent and some people prefer to use the mainline tree as their reference.
But I did mis-understand something: when you said "just a notice etc", I took this as meaning you were making the notice to me that the commits were actually there, while you were saying "no PR needed, a simple notice will do". Apologies for this msistake.
I am build-testing the two changes and will push them as soon as done.
Thanks,
Tom Warren
Amicalement,
Hi Tom,
Albert,
Hi Tom,
Albert,
Here is said notice, with my apologies for the misunderstanding.
Amicalement,
Albert,
-----Original Message----- From: Albert ARIBAUD [mailto:albert.u.boot@aribaud.net] Sent: Friday, March 22, 2013 8:59 AM To: Tom Warren Cc: u-boot@lists.denx.de; Tom Warren; Stephen Warren Subject: Re: [U-Boot] [PATCH 1/2] ARM: implement erratum 716044 workaround
Hi Tom,
Albert,
Hi Tom,
Albert,
No worries, and thanks for the quick work. I'll pull a new ARM FETCH_HEAD into u-boot-tegra/next today.
Tom
Amicalement,
Albert.
-- nvpublic
Albert ARIBAUD
Stephen Warren
Tom Warren
