[U-Boot-Users] [PATCH] 86xx: Allow for fewer DDR slots per memory controller.
As a direct correlation exists between DDR DIMM slots and SPD EEPROM addresses used to configure them, use the individually defined SPD_EEPROM_ADDRESS* values to determine if a DDR DIMM slot should have its SPD configuration read or not.
Effectively, this now allows for 1 or 2 DIMM slots per memory controller.
Signed-off-by: Jon Loeliger jdl@freescale.com --- cpu/mpc86xx/spd_sdram.c | 30 +++++++++++++++++++++--------- 1 files changed, 21 insertions(+), 9 deletions(-)
diff --git a/cpu/mpc86xx/spd_sdram.c b/cpu/mpc86xx/spd_sdram.c index f37ab43..059097f 100644 --- a/cpu/mpc86xx/spd_sdram.c +++ b/cpu/mpc86xx/spd_sdram.c @@ -948,19 +948,25 @@ unsigned int enable_ddr(unsigned int ddr_num) * Read both dimm slots and decide whether * or not to enable this controller. */ - memset((void *)&spd1,0,sizeof(spd1)); - memset((void *)&spd2,0,sizeof(spd2)); + memset((void *)&spd1, 0, sizeof(spd1)); + memset((void *)&spd2, 0, sizeof(spd2));
if (ddr_num == 1) { CFG_READ_SPD(SPD_EEPROM_ADDRESS1, 0, 1, (uchar *) &spd1, sizeof(spd1)); +#if defined(SPD_EEPROM_ADDRESS2) CFG_READ_SPD(SPD_EEPROM_ADDRESS2, 0, 1, (uchar *) &spd2, sizeof(spd2)); +#endif } else { +#if defined(SPD_EEPROM_ADDRESS3) CFG_READ_SPD(SPD_EEPROM_ADDRESS3, 0, 1, (uchar *) &spd1, sizeof(spd1)); +#endif +#if defined(SPD_EEPROM_ADDRESS4) CFG_READ_SPD(SPD_EEPROM_ADDRESS4, 0, 1, (uchar *) &spd2, sizeof(spd2)); +#endif }
/* @@ -1105,21 +1111,25 @@ spd_sdram(void) { int memsize_ddr1_dimm1 = 0; int memsize_ddr1_dimm2 = 0; + int memsize_ddr1 = 0; + unsigned int law_size_ddr1; + volatile immap_t *immap = (immap_t *)CFG_IMMR; + volatile ccsr_ddr_t *ddr1 = &immap->im_ddr1; + volatile ccsr_local_mcm_t *mcm = &immap->im_local_mcm; + +#if (CONFIG_NUM_DDR_CONTROLLERS > 1) int memsize_ddr2_dimm1 = 0; int memsize_ddr2_dimm2 = 0; - int memsize_total = 0; - int memsize_ddr1 = 0; int memsize_ddr2 = 0; + unsigned int law_size_ddr2; +#endif + unsigned int ddr1_enabled = 0; unsigned int ddr2_enabled = 0; - unsigned int law_size_ddr1; - unsigned int law_size_ddr2; - volatile immap_t *immap = (immap_t *)CFG_IMMR; - volatile ccsr_local_mcm_t *mcm = &immap->im_local_mcm; + int memsize_total = 0;
#ifdef CONFIG_DDR_INTERLEAVE unsigned int law_size_interleaved; - volatile ccsr_ddr_t *ddr1 = &immap->im_ddr1; volatile ccsr_ddr_t *ddr2 = &immap->im_ddr2;
memsize_ddr1_dimm1 = spd_init(SPD_EEPROM_ADDRESS1, @@ -1194,9 +1204,11 @@ spd_sdram(void) (unsigned int)memsize_total * 1024*1024); memsize_total += memsize_ddr1_dimm1;
+#if defined(SPD_EEPROM_ADDRESS2) memsize_ddr1_dimm2 = spd_init(SPD_EEPROM_ADDRESS2, 1, 2, (unsigned int)memsize_total * 1024*1024); +#endif memsize_total += memsize_ddr1_dimm2;
Applied, thanks.
Jon Loeliger
