[GIT PULL] Please pull u-boot-dfu-20241017
Hi Tom,
Please find some fixes for master:
Usb Gadget: - Fix cdns3 endpoint configuration by setting maxpacket - Fix dwc3 cache handling when using DMA
Fastboot: - Make AVB_VERIFY depends on FASTBOOT
CI job: - https://source.denx.de/u-boot/custodians/u-boot-dfu/-/pipelines/22742
Thanks, Mattijs
The following changes since commit a404065479be2c1fe1167c3c91367e8194a69d1b:
power: pmic: pca9450: Add missing newline (2024-10-10 12:17:46 -0600)
https://source.denx.de/u-boot/custodians/u-boot-dfu.git tags/u-boot-dfu-20241017
for you to fetch changes up to 3e47302dd71267b85e5ec65c5b6d881c23cce6cb:
usb: dwc3: invalidate dcache on buffer used in interrupt handling (2024-10-15 11:03:57 +0200)
---------------------------------------------------------------- u-boot-dfu-20241017
---------------------------------------------------------------- Jerome Forissier (1): Make AVB_VERIFY depend on FASTBOOT
Neil Armstrong (3): usb: dwc3: allocate setup_buf with dma_alloc_coherent() usb: dwc3: fix dcache flush range calculation usb: dwc3: invalidate dcache on buffer used in interrupt handling
Siddharth Vadapalli (1): usb: gadget: cdns3: Fix cdns3_ep_config() by setting ep.maxpacket
common/Kconfig | 1 + drivers/usb/cdns3/gadget.c | 8 ++++++++ drivers/usb/dwc3/core.h | 2 ++ drivers/usb/dwc3/ep0.c | 6 ++++-- drivers/usb/dwc3/gadget.c | 10 ++++++---- drivers/usb/dwc3/io.h | 13 ++++++++++++- 6 files changed, 33 insertions(+), 7 deletions(-)
On Thu, Oct 17, 2024 at 10:20:30AM +0200, Mattijs Korpershoek wrote:
Hi Tom,
Usb Gadget:
Fastboot:
CI job:
Thanks, Mattijs
Mattijs Korpershoek
