[PATCH 1/1] net: sntp: remove CONFIG_TIMESTAMP constraint
CONFIG_TIMESTAMP is not related to the RTC drivers. It does not make any sense to let the updating of the RTC by the sntp command depend on it.
Drop the CONFIG_TIMESTAMP checks.
Furthermore function dm_rtc_set() is enabled by CONFIG_DM_RTC. There is no reason to require CONFIG_CMD_DATE when using a driver model RTC. The UEFI sub-system can consume the RTC functions even if there is not date command.
Only check CONFIG_CMD_DATE when using a non-driver model RTC.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- net/sntp.c | 10 ++-------- 1 file changed, 2 insertions(+), 8 deletions(-)
diff --git a/net/sntp.c b/net/sntp.c index d5d5671933..dac0f8ceea 100644 --- a/net/sntp.c +++ b/net/sntp.c @@ -57,18 +57,15 @@ static void sntp_timeout_handler(void) static void sntp_handler(uchar *pkt, unsigned dest, struct in_addr sip, unsigned src, unsigned len) { -#ifdef CONFIG_TIMESTAMP struct sntp_pkt_t *rpktp = (struct sntp_pkt_t *)pkt; struct rtc_time tm; ulong seconds; -#endif
debug("%s\n", __func__);
if (dest != sntp_our_port) return;
-#ifdef CONFIG_TIMESTAMP /* * As the RTC's used in U-Boot support second resolution only * we simply ignore the sub-second field. @@ -76,8 +73,7 @@ static void sntp_handler(uchar *pkt, unsigned dest, struct in_addr sip, memcpy(&seconds, &rpktp->transmit_timestamp, sizeof(ulong));
rtc_to_tm(ntohl(seconds) - 2208988800UL + net_ntp_time_offset, &tm); -#if defined(CONFIG_CMD_DATE) -# ifdef CONFIG_DM_RTC +#ifdef CONFIG_DM_RTC struct udevice *dev; int ret;
@@ -86,14 +82,12 @@ static void sntp_handler(uchar *pkt, unsigned dest, struct in_addr sip, printf("SNTP: cannot find RTC: err=%d\n", ret); else dm_rtc_set(dev, &tm); -# else +#elif defined(CONFIG_CMD_DATE) rtc_set(&tm); -# endif #endif printf("Date: %4d-%02d-%02d Time: %2d:%02d:%02d\n", tm.tm_year, tm.tm_mon, tm.tm_mday, tm.tm_hour, tm.tm_min, tm.tm_sec); -#endif
net_set_state(NETLOOP_SUCCESS); } -- 2.28.0
