[U-Boot] [RFC] Add Nitrogen6x support.
I'd like to get some feedback on this patch set which adds support for our Nitrogen6X series of boards because this patch introduces some additional feature for i.MX6x processors specifically, but possibly other i.MX processors as well.
To give a little background, we're supporting a variety of i.MX6 processors with out Nitrogen6X product, including the Dual-Lite and Solo processors.
Some of this has been discussed on the mailing list, most recently here: http://lists.denx.de/pipermail/u-boot/2013-January/#144323
To give a little background, the i.MX6x architecture has three major variants: i.MX6 Quad and i.MX6 Dual i.MX6 Dual-Lite and i.MX6 Solo i.MX6 Solo Lite
Because the first two are pin compatible, those variants are what we're supporting in this product line.
Unfortunately, they have differing register locations, and also support different DDR clock rates (1066MHz on Quad/Dual and 800MHz on Dual-Lite/Solo).
To simplify support for the two, we recently pushed patches adding support for the preprocessor to the 'imximage' utility and these have been merged.
This allows us to define a single set of DCD data to configure portions of the device setup like this line from board/boundary/ddr-setup.cfg:
DATA 4, IOM_DRAM_SDQS0, 0x00000030
The address of IOM_DRAM_SDQS0 depends on which processor variant is used. To resolve this, we've introduced header files arch/arm/include/asm/arch-mx6/mx6q-ddr.h and arch/arm/include/asm/arch-mx6/mx6dl-ddr.h
The 'q' refers to Quad/Dual. The 'dl' refers to Dual-Lite/Solo.
To make things simpler, we've added this header file, which includes one of the headers above based on whether we're compiling for MX6Q or MX6DL.
arch/arm/include/asm/arch-mx6/mx6-ddr.h
The net result seems to be fairly clean. We're able to express the various boards concisely in these files within board/boundary/nitrogen6x: board/boundary/nitrogen6x/nitrogen6dl2g.cfg board/boundary/nitrogen6x/nitrogen6dl.cfg board/boundary/nitrogen6x/nitrogen6q2g.cfg board/boundary/nitrogen6x/nitrogen6q.cfg board/boundary/nitrogen6x/nitrogen6s1g.cfg board/boundary/nitrogen6x/nitrogen6s.cfg
By using the preprocessor, we were also able to separate common setup for clocks and DDR from the specific memory arrangements that differentiate some of our boards: clocks.cfg ddr-setup.cfg 1066mhz_4x128mx16.cfg 1066mhz_4x256mx16.cfg 800mhz_2x128mx16.cfg 800mhz_2x256mx16.cfg 800mhz_4x128mx16.cfg 800mhz_4x256mx16.cfg
We're trying to keep the nomenclature consistent: 6x - refers to things that are independent of the variant used 6q - refers to the 6Quad/6Dual variant 6dl - refers to the 6Dual-Lite/6Solo
Note that this differs from what's currently done in some other i.MX6 headers.
For example, arch/arm/include/asm/arch-mx6/mx6x_pins.h defines the pad setting for UART2 using symbol MX6Q_PAD_EIM_D26__UART2_TXD while arch/arm/include/asm/arch-mx6/mx6dl_pins.h defines MX6DL_PAD_EIM_D26__UART2_TXD
This necessitated a bit of preprocessor-fu in nitrogen6x.c where we create a common MX6PAD macro:
#ifdef FOR_DL_SOLO #define MX6PAD(a) MX6DL_PAD_##a #else #define MX6PAD(a) MX6Q_PAD_##a #endif
and use it later like this: MX6PAD(EIM_D26__UART2_TXD)
It seems worthwhile to rename mx6x_pins.h to mx6q_pins.h and also change the pad declarations so that other boards can avoid the MX6PAD() macro.
I also suggest that we add an intermediate mx6_pins.h or mx6x_pins.h file that includes the appropriate file based on the processor macro.
There are a couple of other changes to common files that I'll break out before submitting this officially, but I'm hoping to get some feedback first.
Eric Nelson (1): Add support for Boundary Devices Nitrogen6x boards
MAINTAINERS | 8 + arch/arm/include/asm/arch-mx6/crm_regs.h | 12 + arch/arm/include/asm/arch-mx6/iomux.h | 5 + arch/arm/include/asm/arch-mx6/mx6-ddr.h | 73 ++ arch/arm/include/asm/arch-mx6/mx6dl-ddr.h | 59 ++ arch/arm/include/asm/arch-mx6/mx6dl_pins.h | 3 + arch/arm/include/asm/arch-mx6/mx6q-ddr.h | 57 ++ board/boundary/nitrogen6x/1066mhz_4x128mx16.cfg | 37 + board/boundary/nitrogen6x/1066mhz_4x256mx16.cfg | 37 + board/boundary/nitrogen6x/6x_bootscript.txt | 58 ++ .../boundary/nitrogen6x/6x_bootscript_android.txt | 64 ++ .../nitrogen6x/6x_bootscript_android_recovery.txt | 64 ++ board/boundary/nitrogen6x/6x_upgrade.txt | 46 + board/boundary/nitrogen6x/800mhz_2x128mx16.cfg | 37 + board/boundary/nitrogen6x/800mhz_2x256mx16.cfg | 37 + board/boundary/nitrogen6x/800mhz_4x128mx16.cfg | 37 + board/boundary/nitrogen6x/800mhz_4x256mx16.cfg | 37 + board/boundary/nitrogen6x/Makefile | 41 + board/boundary/nitrogen6x/README | 93 ++ board/boundary/nitrogen6x/clocks.cfg | 31 + board/boundary/nitrogen6x/ddr-setup.cfg | 94 ++ board/boundary/nitrogen6x/nitrogen6dl.cfg | 46 + board/boundary/nitrogen6x/nitrogen6dl2g.cfg | 46 + board/boundary/nitrogen6x/nitrogen6q.cfg | 46 + board/boundary/nitrogen6x/nitrogen6q2g.cfg | 46 + board/boundary/nitrogen6x/nitrogen6s.cfg | 46 + board/boundary/nitrogen6x/nitrogen6s1g.cfg | 46 + board/boundary/nitrogen6x/nitrogen6x.c | 901 ++++++++++++++++++++ boards.cfg | 6 + drivers/usb/host/ehci-mx6.c | 1 - include/configs/nitrogen6x.h | 284 ++++++ 31 files changed, 2397 insertions(+), 1 deletion(-) create mode 100644 arch/arm/include/asm/arch-mx6/mx6-ddr.h create mode 100644 arch/arm/include/asm/arch-mx6/mx6dl-ddr.h create mode 100644 arch/arm/include/asm/arch-mx6/mx6q-ddr.h create mode 100644 board/boundary/nitrogen6x/1066mhz_4x128mx16.cfg create mode 100644 board/boundary/nitrogen6x/1066mhz_4x256mx16.cfg create mode 100644 board/boundary/nitrogen6x/6x_bootscript.txt create mode 100644 board/boundary/nitrogen6x/6x_bootscript_android.txt create mode 100644 board/boundary/nitrogen6x/6x_bootscript_android_recovery.txt create mode 100644 board/boundary/nitrogen6x/6x_upgrade.txt create mode 100644 board/boundary/nitrogen6x/800mhz_2x128mx16.cfg create mode 100644 board/boundary/nitrogen6x/800mhz_2x256mx16.cfg create mode 100644 board/boundary/nitrogen6x/800mhz_4x128mx16.cfg create mode 100644 board/boundary/nitrogen6x/800mhz_4x256mx16.cfg create mode 100644 board/boundary/nitrogen6x/Makefile create mode 100644 board/boundary/nitrogen6x/README create mode 100644 board/boundary/nitrogen6x/clocks.cfg create mode 100644 board/boundary/nitrogen6x/ddr-setup.cfg create mode 100644 board/boundary/nitrogen6x/nitrogen6dl.cfg create mode 100644 board/boundary/nitrogen6x/nitrogen6dl2g.cfg create mode 100644 board/boundary/nitrogen6x/nitrogen6q.cfg create mode 100644 board/boundary/nitrogen6x/nitrogen6q2g.cfg create mode 100644 board/boundary/nitrogen6x/nitrogen6s.cfg create mode 100644 board/boundary/nitrogen6x/nitrogen6s1g.cfg create mode 100644 board/boundary/nitrogen6x/nitrogen6x.c create mode 100644 include/configs/nitrogen6x.h
This patch adds support for the Nitrogen6X board(s) from Boundary Devices. The boards are based on the i.MX6x processor family with two major variants: i.MX6Quad/6Dual i.MX6Dual-Lite/6Solo
More specifically, the board variations are: nitrogen6q i.MX6Q/6D 1GB nitrogen6dl i.MX6DL 1GB nitrogen6s i.MX6S 512MB nitrogen6q2g i.MX6Q/6D 2GB nitrogen6dl2g i.MX6DL 2GB nitrogen6s1g i.MX6S 1GB
Refer to http://boundarydevices.com/products/ for details.
Signed-off-by: Eric Nelson eric.nelson@boundarydevices.com --- MAINTAINERS | 8 + arch/arm/include/asm/arch-mx6/crm_regs.h | 12 + arch/arm/include/asm/arch-mx6/iomux.h | 5 + arch/arm/include/asm/arch-mx6/mx6-ddr.h | 73 ++ arch/arm/include/asm/arch-mx6/mx6dl-ddr.h | 59 ++ arch/arm/include/asm/arch-mx6/mx6dl_pins.h | 3 + arch/arm/include/asm/arch-mx6/mx6q-ddr.h | 57 ++ board/boundary/nitrogen6x/1066mhz_4x128mx16.cfg | 37 + board/boundary/nitrogen6x/1066mhz_4x256mx16.cfg | 37 + board/boundary/nitrogen6x/6x_bootscript.txt | 58 ++ .../boundary/nitrogen6x/6x_bootscript_android.txt | 64 ++ .../nitrogen6x/6x_bootscript_android_recovery.txt | 64 ++ board/boundary/nitrogen6x/6x_upgrade.txt | 46 + board/boundary/nitrogen6x/800mhz_2x128mx16.cfg | 37 + board/boundary/nitrogen6x/800mhz_2x256mx16.cfg | 37 + board/boundary/nitrogen6x/800mhz_4x128mx16.cfg | 37 + board/boundary/nitrogen6x/800mhz_4x256mx16.cfg | 37 + board/boundary/nitrogen6x/Makefile | 41 + board/boundary/nitrogen6x/README | 93 ++ board/boundary/nitrogen6x/clocks.cfg | 31 + board/boundary/nitrogen6x/ddr-setup.cfg | 94 ++ board/boundary/nitrogen6x/nitrogen6dl.cfg | 46 + board/boundary/nitrogen6x/nitrogen6dl2g.cfg | 46 + board/boundary/nitrogen6x/nitrogen6q.cfg | 46 + board/boundary/nitrogen6x/nitrogen6q2g.cfg | 46 + board/boundary/nitrogen6x/nitrogen6s.cfg | 46 + board/boundary/nitrogen6x/nitrogen6s1g.cfg | 46 + board/boundary/nitrogen6x/nitrogen6x.c | 901 ++++++++++++++++++++ boards.cfg | 6 + drivers/usb/host/ehci-mx6.c | 1 - include/configs/nitrogen6x.h | 284 ++++++ 31 files changed, 2397 insertions(+), 1 deletion(-) create mode 100644 arch/arm/include/asm/arch-mx6/mx6-ddr.h create mode 100644 arch/arm/include/asm/arch-mx6/mx6dl-ddr.h create mode 100644 arch/arm/include/asm/arch-mx6/mx6q-ddr.h create mode 100644 board/boundary/nitrogen6x/1066mhz_4x128mx16.cfg create mode 100644 board/boundary/nitrogen6x/1066mhz_4x256mx16.cfg create mode 100644 board/boundary/nitrogen6x/6x_bootscript.txt create mode 100644 board/boundary/nitrogen6x/6x_bootscript_android.txt create mode 100644 board/boundary/nitrogen6x/6x_bootscript_android_recovery.txt create mode 100644 board/boundary/nitrogen6x/6x_upgrade.txt create mode 100644 board/boundary/nitrogen6x/800mhz_2x128mx16.cfg create mode 100644 board/boundary/nitrogen6x/800mhz_2x256mx16.cfg create mode 100644 board/boundary/nitrogen6x/800mhz_4x128mx16.cfg create mode 100644 board/boundary/nitrogen6x/800mhz_4x256mx16.cfg create mode 100644 board/boundary/nitrogen6x/Makefile create mode 100644 board/boundary/nitrogen6x/README create mode 100644 board/boundary/nitrogen6x/clocks.cfg create mode 100644 board/boundary/nitrogen6x/ddr-setup.cfg create mode 100644 board/boundary/nitrogen6x/nitrogen6dl.cfg create mode 100644 board/boundary/nitrogen6x/nitrogen6dl2g.cfg create mode 100644 board/boundary/nitrogen6x/nitrogen6q.cfg create mode 100644 board/boundary/nitrogen6x/nitrogen6q2g.cfg create mode 100644 board/boundary/nitrogen6x/nitrogen6s.cfg create mode 100644 board/boundary/nitrogen6x/nitrogen6s1g.cfg create mode 100644 board/boundary/nitrogen6x/nitrogen6x.c create mode 100644 include/configs/nitrogen6x.h
diff --git a/MAINTAINERS b/MAINTAINERS index faa9b5e..720beab 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -1029,6 +1029,14 @@ Pali Rohár pali.rohar@gmail.com
nokia_rx51 ARM ARMV7 (OMAP34xx SoC)
+Eric Nelson eric.nelson@boundarydevices.com + nitrogen6q i.MX6Q/6D 1GB + nitrogen6dl i.MX6DL 1GB + nitrogen6s i.MX6S 512MB + nitrogen6q2g i.MX6Q/6D 2GB + nitrogen6dl2g i.MX6DL 2GB + nitrogen6s1g i.MX6S 1GB + -------------------------------------------------------------------------
Unknown / orphaned boards: diff --git a/arch/arm/include/asm/arch-mx6/crm_regs.h b/arch/arm/include/asm/arch-mx6/crm_regs.h index d670f30..7676457 100644 --- a/arch/arm/include/asm/arch-mx6/crm_regs.h +++ b/arch/arm/include/asm/arch-mx6/crm_regs.h @@ -20,6 +20,17 @@ #ifndef __ARCH_ARM_MACH_MX6_CCM_REGS_H__ #define __ARCH_ARM_MACH_MX6_CCM_REGS_H__
+#define CCM_CCGR0 0x020C4068 +#define CCM_CCGR1 0x020C406c +#define CCM_CCGR2 0x020C4070 +#define CCM_CCGR3 0x020C4074 +#define CCM_CCGR4 0x020C4078 +#define CCM_CCGR5 0x020C407c +#define CCM_CCGR6 0x020C4080 + +#define PMU_MISC2 0x020C8170 + +#ifndef __ASSEMBLY__ struct mxc_ccm_reg { u32 ccr; /* 0x0000 */ u32 ccdr; @@ -105,6 +116,7 @@ struct mxc_ccm_reg { u32 analog_pfd_528_clr; u32 analog_pfd_528_tog; }; +#endif
/* Define the bits in register CCR */ #define MXC_CCM_CCR_RBC_EN (1 << 27) diff --git a/arch/arm/include/asm/arch-mx6/iomux.h b/arch/arm/include/asm/arch-mx6/iomux.h index d23abd7..57b514f 100644 --- a/arch/arm/include/asm/arch-mx6/iomux.h +++ b/arch/arm/include/asm/arch-mx6/iomux.h @@ -16,6 +16,11 @@
#ifndef __ASM_ARCH_IOMUX_H__ #define __ASM_ARCH_IOMUX_H__ + +#define IOMUXC_GPR4 0x020e0010 +#define IOMUXC_GPR6 0x020e0018 +#define IOMUXC_GPR7 0x020e001c + /* * IOMUXC_GPR13 bit fields */ diff --git a/arch/arm/include/asm/arch-mx6/mx6-ddr.h b/arch/arm/include/asm/arch-mx6/mx6-ddr.h new file mode 100644 index 0000000..0a3cddc --- /dev/null +++ b/arch/arm/include/asm/arch-mx6/mx6-ddr.h @@ -0,0 +1,73 @@ +/* + * Copyright (C) 2012 Boundary Devices Inc. + * + * Licensed under the GPL-2 or later. + */ +#ifndef __ASM_ARCH_MX6_DDR_H__ +#define __ASM_ARCH_MX6_DDR_H__ + +#ifdef CONFIG_MX6Q +#include "mx6q-ddr.h" +#else +#ifdef CONFIG_MX6DL +#include "mx6dl-ddr.h" +#else +#error "Please select cpu" +#endif /* CONFIG_MX6DL */ +#endif /* CONFIG_MX6Q */ + +#define MMDC_P0_MDCTL 0x021b0000 +#define MMDC_P0_MDPDC 0x021b0004 +#define MMDC_P0_MDOTC 0x021b0008 +#define MMDC_P0_MDCFG0 0x021b000c +#define MMDC_P0_MDCFG1 0x021b0010 +#define MMDC_P0_MDCFG2 0x021b0014 +#define MMDC_P0_MDMISC 0x021b0018 +#define MMDC_P0_MDSCR 0x021b001c +#define MMDC_P0_MDREF 0x021b0020 +#define MMDC_P0_MDRWD 0x021b002c +#define MMDC_P0_MDOR 0x021b0030 +#define MMDC_P0_MDASP 0x021b0040 +#define MMDC_P0_MAPSR 0x021b0404 +#define MMDC_P0_MPZQHWCTRL 0x021b0800 +#define MMDC_P0_MPWLDECTRL0 0x021b080c +#define MMDC_P0_MPWLDECTRL1 0x021b0810 +#define MMDC_P0_MPODTCTRL 0x021b0818 +#define MMDC_P0_MPRDDQBY0DL 0x021b081c +#define MMDC_P0_MPRDDQBY1DL 0x021b0820 +#define MMDC_P0_MPRDDQBY2DL 0x021b0824 +#define MMDC_P0_MPRDDQBY3DL 0x021b0828 +#define MMDC_P0_MPDGCTRL0 0x021b083c +#define MMDC_P0_MPDGCTRL1 0x021b0840 +#define MMDC_P0_MPRDDLCTL 0x021b0848 +#define MMDC_P0_MPWRDLCTL 0x021b0850 +#define MMDC_P0_MPMUR0 0x021b08b8 + +#define MMDC_P1_MDCTL 0x021b4000 +#define MMDC_P1_MDPDC 0x021b4004 +#define MMDC_P1_MDOTC 0x021b4008 +#define MMDC_P1_MDCFG0 0x021b400c +#define MMDC_P1_MDCFG1 0x021b4010 +#define MMDC_P1_MDCFG2 0x021b4014 +#define MMDC_P1_MDMISC 0x021b4018 +#define MMDC_P1_MDSCR 0x021b401c +#define MMDC_P1_MDREF 0x021b4020 +#define MMDC_P1_MDRWD 0x021b402c +#define MMDC_P1_MDOR 0x021b4030 +#define MMDC_P1_MDASP 0x021b4040 +#define MMDC_P1_MAPSR 0x021b4404 +#define MMDC_P1_MPZQHWCTRL 0x021b4800 +#define MMDC_P1_MPWLDECTRL0 0x021b480c +#define MMDC_P1_MPWLDECTRL1 0x021b4810 +#define MMDC_P1_MPODTCTRL 0x021b4818 +#define MMDC_P1_MPRDDQBY0DL 0x021b481c +#define MMDC_P1_MPRDDQBY1DL 0x021b4820 +#define MMDC_P1_MPRDDQBY2DL 0x021b4824 +#define MMDC_P1_MPRDDQBY3DL 0x021b4828 +#define MMDC_P1_MPDGCTRL0 0x021b483c +#define MMDC_P1_MPDGCTRL1 0x021b4840 +#define MMDC_P1_MPRDDLCTL 0x021b4848 +#define MMDC_P1_MPWRDLCTL 0x021b4850 +#define MMDC_P1_MPMUR0 0x021b48b8 + +#endif /*__ASM_ARCH_MX6_DDR_H__ */ diff --git a/arch/arm/include/asm/arch-mx6/mx6dl-ddr.h b/arch/arm/include/asm/arch-mx6/mx6dl-ddr.h new file mode 100644 index 0000000..5a4bfc6 --- /dev/null +++ b/arch/arm/include/asm/arch-mx6/mx6dl-ddr.h @@ -0,0 +1,59 @@ +/* + * Copyright (C) 2012 Boundary Devices Inc. + * + * Licensed under the GPL-2 or later. + */ +#ifndef __ASM_ARCH_MX6DLS_DDR_H__ +#define __ASM_ARCH_MX6DLS_DDR_H__ + +#ifndef CONFIG_MX6DL +#ifndef CONFIG_MX6S +#error "wrong CPU" +#endif +#endif + +#define IOM_DRAM_DQM0 0x020e0470 +#define IOM_DRAM_DQM1 0x020e0474 +#define IOM_DRAM_DQM2 0x020e0478 +#define IOM_DRAM_DQM3 0x020e047c +#define IOM_DRAM_DQM4 0x020e0480 +#define IOM_DRAM_DQM5 0x020e0484 +#define IOM_DRAM_DQM6 0x020e0488 +#define IOM_DRAM_DQM7 0x020e048c + +#define IOM_DRAM_CAS 0x020e0464 +#define IOM_DRAM_RAS 0x020e0490 +#define IOM_DRAM_RESET 0x020e0494 +#define IOM_DRAM_SDCLK_0 0x020e04ac +#define IOM_DRAM_SDCLK_1 0x020e04b0 +#define IOM_DRAM_SDBA2 0x020e04a0 +#define IOM_DRAM_SDCKE0 0x020e04a4 +#define IOM_DRAM_SDCKE1 0x020e04a8 +#define IOM_DRAM_SDODT0 0x020e04b4 +#define IOM_DRAM_SDODT1 0x020e04b8 + +#define IOM_DRAM_SDQS0 0x020e04bc +#define IOM_DRAM_SDQS1 0x020e04c0 +#define IOM_DRAM_SDQS2 0x020e04c4 +#define IOM_DRAM_SDQS3 0x020e04c8 +#define IOM_DRAM_SDQS4 0x020e04cc +#define IOM_DRAM_SDQS5 0x020e04d0 +#define IOM_DRAM_SDQS6 0x020e04d4 +#define IOM_DRAM_SDQS7 0x020e04d8 + +#define IOM_GRP_B0DS 0x020e0764 +#define IOM_GRP_B1DS 0x020e0770 +#define IOM_GRP_B2DS 0x020e0778 +#define IOM_GRP_B3DS 0x020e077c +#define IOM_GRP_B4DS 0x020e0780 +#define IOM_GRP_B5DS 0x020e0784 +#define IOM_GRP_B6DS 0x020e078c +#define IOM_GRP_B7DS 0x020e0748 +#define IOM_GRP_ADDDS 0x020e074c +#define IOM_DDRMODE_CTL 0x020e0750 +#define IOM_GRP_DDRPKE 0x020e0754 +#define IOM_GRP_DDRMODE 0x020e0760 +#define IOM_GRP_CTLDS 0x020e076c +#define IOM_GRP_DDR_TYPE 0x020e0774 + +#endif /*__ASM_ARCH_MX6S_DDR_H__ */ diff --git a/arch/arm/include/asm/arch-mx6/mx6dl_pins.h b/arch/arm/include/asm/arch-mx6/mx6dl_pins.h index 79e2c4f..9b9c571 100644 --- a/arch/arm/include/asm/arch-mx6/mx6dl_pins.h +++ b/arch/arm/include/asm/arch-mx6/mx6dl_pins.h @@ -105,6 +105,9 @@ enum { MX6DL_PAD_KEY_COL3__GPIO_4_12 = IOMUX_PAD(0x0638, 0x0250, 5, 0x0000, 0, 0), MX6DL_PAD_KEY_ROW3__I2C2_SDA = IOMUX_PAD(0x064C, 0x0264, 4 | IOMUX_CONFIG_SION, 0x0874, 1, 0), MX6DL_PAD_KEY_ROW3__GPIO_4_13 = IOMUX_PAD(0x064C, 0x0264, 5, 0x0000, 0, 0), + MX6DL_PAD_NANDF_CS1__GPIO_6_14 = IOMUX_PAD(0x0660, 0x0278, 5, 0x0000, 0, 0), + MX6DL_PAD_NANDF_CS2__GPIO_6_15 = IOMUX_PAD(0x0664, 0x027C, 5, 0x0000, 0, 0), + MX6DL_PAD_NANDF_CS3__GPIO_6_16 = IOMUX_PAD(0x0668, 0x0280, 5, 0x0000, 0, 0), MX6DL_PAD_NANDF_D1__GPIO_2_1 = IOMUX_PAD(0x0670, 0x0288, 5, 0x0000, 0, 0), MX6DL_PAD_NANDF_D2__GPIO_2_2 = IOMUX_PAD(0x0674, 0x028C, 5, 0x0000, 0, 0), MX6DL_PAD_NANDF_D3__GPIO_2_3 = IOMUX_PAD(0x0678, 0x0290, 5, 0x0000, 0, 0), diff --git a/arch/arm/include/asm/arch-mx6/mx6q-ddr.h b/arch/arm/include/asm/arch-mx6/mx6q-ddr.h new file mode 100644 index 0000000..4060600 --- /dev/null +++ b/arch/arm/include/asm/arch-mx6/mx6q-ddr.h @@ -0,0 +1,57 @@ +/* + * Copyright (C) 2012 Boundary Devices Inc. + * + * Licensed under the GPL-2 or later. + */ +#ifndef __ASM_ARCH_MX6Q_DDR_H__ +#define __ASM_ARCH_MX6Q_DDR_H__ + +#ifndef CONFIG_MX6Q +#error "wrong CPU" +#endif + +#define IOM_DRAM_DQM0 0x020e05ac +#define IOM_DRAM_DQM1 0x020e05b4 +#define IOM_DRAM_DQM2 0x020e0528 +#define IOM_DRAM_DQM3 0x020e0520 +#define IOM_DRAM_DQM4 0x020e0514 +#define IOM_DRAM_DQM5 0x020e0510 +#define IOM_DRAM_DQM6 0x020e05bc +#define IOM_DRAM_DQM7 0x020e05c4 + +#define IOM_DRAM_CAS 0x020e056c +#define IOM_DRAM_RAS 0x020e0578 +#define IOM_DRAM_RESET 0x020e057c +#define IOM_DRAM_SDCLK_0 0x020e0588 +#define IOM_DRAM_SDCLK_1 0x020e0594 +#define IOM_DRAM_SDBA2 0x020e058c +#define IOM_DRAM_SDCKE0 0x020e0590 +#define IOM_DRAM_SDCKE1 0x020e0598 +#define IOM_DRAM_SDODT0 0x020e059c +#define IOM_DRAM_SDODT1 0x020e05a0 + +#define IOM_DRAM_SDQS0 0x020e05a8 +#define IOM_DRAM_SDQS1 0x020e05b0 +#define IOM_DRAM_SDQS2 0x020e0524 +#define IOM_DRAM_SDQS3 0x020e051c +#define IOM_DRAM_SDQS4 0x020e0518 +#define IOM_DRAM_SDQS5 0x020e050c +#define IOM_DRAM_SDQS6 0x020e05b8 +#define IOM_DRAM_SDQS7 0x020e05c0 + +#define IOM_GRP_B0DS 0x020e0784 +#define IOM_GRP_B1DS 0x020e0788 +#define IOM_GRP_B2DS 0x020e0794 +#define IOM_GRP_B3DS 0x020e079c +#define IOM_GRP_B4DS 0x020e07a0 +#define IOM_GRP_B5DS 0x020e07a4 +#define IOM_GRP_B6DS 0x020e07a8 +#define IOM_GRP_B7DS 0x020e0748 +#define IOM_GRP_ADDDS 0x020e074c +#define IOM_DDRMODE_CTL 0x020e0750 +#define IOM_GRP_DDRPKE 0x020e0758 +#define IOM_GRP_DDRMODE 0x020e0774 +#define IOM_GRP_CTLDS 0x020e078c +#define IOM_GRP_DDR_TYPE 0x020e0798 + +#endif /*__ASM_ARCH_MX6Q_DDR_H__ */ diff --git a/board/boundary/nitrogen6x/1066mhz_4x128mx16.cfg b/board/boundary/nitrogen6x/1066mhz_4x128mx16.cfg new file mode 100644 index 0000000..63fb31d --- /dev/null +++ b/board/boundary/nitrogen6x/1066mhz_4x128mx16.cfg @@ -0,0 +1,37 @@ +DATA 4, MMDC_P0_MDPDC, 0x00020036 +DATA 4, MMDC_P0_MDCFG0, 0x555A7975 +DATA 4, MMDC_P0_MDCFG1, 0xFF538E64 +DATA 4, MMDC_P0_MDCFG2, 0x01FF00DB +DATA 4, MMDC_P0_MDRWD, 0x000026D2 +DATA 4, MMDC_P0_MDOR, 0x005B0E21 +DATA 4, MMDC_P0_MDOTC, 0x09444040 +DATA 4, MMDC_P0_MDPDC, 0x00025576 +DATA 4, MMDC_P0_MDASP, 0x00000027 +DATA 4, MMDC_P0_MDCTL, 0x831A0000 +DATA 4, MMDC_P0_MDSCR, 0x04088032 +DATA 4, MMDC_P0_MDSCR, 0x00008033 +DATA 4, MMDC_P0_MDSCR, 0x00428031 +DATA 4, MMDC_P0_MDSCR, 0x09408030 +DATA 4, MMDC_P0_MDSCR, 0x04008040 +DATA 4, MMDC_P0_MPZQHWCTRL, 0xA1390003 +DATA 4, MMDC_P1_MPZQHWCTRL, 0xA1390003 +DATA 4, MMDC_P0_MDREF, 0x00005800 +DATA 4, MMDC_P0_MPODTCTRL, 0x00022227 +DATA 4, MMDC_P1_MPODTCTRL, 0x00022227 +DATA 4, MMDC_P0_MPDGCTRL0, 0x434B0350 +DATA 4, MMDC_P0_MPDGCTRL1, 0x034C0359 +DATA 4, MMDC_P1_MPDGCTRL0, 0x434B0350 +DATA 4, MMDC_P1_MPDGCTRL1, 0x03650348 +DATA 4, MMDC_P0_MPRDDLCTL, 0x4436383B +DATA 4, MMDC_P1_MPRDDLCTL, 0x39393341 +DATA 4, MMDC_P0_MPWRDLCTL, 0x35373933 +DATA 4, MMDC_P1_MPWRDLCTL, 0x48254A36 +DATA 4, MMDC_P0_MPWLDECTRL0, 0x001F001F +DATA 4, MMDC_P0_MPWLDECTRL1, 0x001F001F +DATA 4, MMDC_P1_MPWLDECTRL0, 0x00440044 +DATA 4, MMDC_P1_MPWLDECTRL1, 0x00440044 +DATA 4, MMDC_P0_MPMUR0, 0x00000800 +DATA 4, MMDC_P1_MPMUR0, 0x00000800 +DATA 4, MMDC_P0_MDSCR, 0x00000000 +DATA 4, MMDC_P0_MAPSR, 0x00011006 + diff --git a/board/boundary/nitrogen6x/1066mhz_4x256mx16.cfg b/board/boundary/nitrogen6x/1066mhz_4x256mx16.cfg new file mode 100644 index 0000000..68e70ad --- /dev/null +++ b/board/boundary/nitrogen6x/1066mhz_4x256mx16.cfg @@ -0,0 +1,37 @@ +DATA 4, MMDC_P0_MDPDC, 0x00020036 +DATA 4, MMDC_P0_MDCFG0, 0x895A7975 +DATA 4, MMDC_P0_MDCFG1, 0xFF538E64 +DATA 4, MMDC_P0_MDCFG2, 0x01FF00DB +DATA 4, MMDC_P0_MDRWD, 0x000026D2 +DATA 4, MMDC_P0_MDOR, 0x005B0E21 +DATA 4, MMDC_P0_MDOTC, 0x09444040 +DATA 4, MMDC_P0_MDPDC, 0x00025576 +DATA 4, MMDC_P0_MDASP, 0x00000047 +DATA 4, MMDC_P0_MDCTL, 0x841A0000 +DATA 4, MMDC_P0_MDSCR, 0x04008032 +DATA 4, MMDC_P0_MDSCR, 0x00008033 +DATA 4, MMDC_P0_MDSCR, 0x00428031 +DATA 4, MMDC_P0_MDSCR, 0x09408030 +DATA 4, MMDC_P0_MDSCR, 0x04008040 +DATA 4, MMDC_P0_MPZQHWCTRL, 0xA1390003 +DATA 4, MMDC_P1_MPZQHWCTRL, 0xA1390003 +DATA 4, MMDC_P0_MDREF, 0x00007800 +DATA 4, MMDC_P0_MPODTCTRL, 0x00022227 +DATA 4, MMDC_P1_MPODTCTRL, 0x00022227 +DATA 4, MMDC_P0_MPDGCTRL0, 0x43040319 +DATA 4, MMDC_P0_MPDGCTRL1, 0x03040279 +DATA 4, MMDC_P1_MPDGCTRL0, 0x43040321 +DATA 4, MMDC_P1_MPDGCTRL1, 0x03030251 +DATA 4, MMDC_P0_MPRDDLCTL, 0x4d434248 +DATA 4, MMDC_P1_MPRDDLCTL, 0x42413c4d +DATA 4, MMDC_P0_MPWRDLCTL, 0x34424543 +DATA 4, MMDC_P1_MPWRDLCTL, 0x49324933 +DATA 4, MMDC_P0_MPWLDECTRL0, 0x001a0017 +DATA 4, MMDC_P0_MPWLDECTRL1, 0x001F001F +DATA 4, MMDC_P1_MPWLDECTRL0, 0x00170027 +DATA 4, MMDC_P1_MPWLDECTRL1, 0x000a001f +DATA 4, MMDC_P0_MPMUR0, 0x00000800 +DATA 4, MMDC_P1_MPMUR0, 0x00000800 +DATA 4, MMDC_P0_MDSCR, 0x00000000 +DATA 4, MMDC_P0_MAPSR, 0x00011006 + diff --git a/board/boundary/nitrogen6x/6x_bootscript.txt b/board/boundary/nitrogen6x/6x_bootscript.txt new file mode 100644 index 0000000..fe75976 --- /dev/null +++ b/board/boundary/nitrogen6x/6x_bootscript.txt @@ -0,0 +1,58 @@ +setenv bootargs enable_wait_mode=off +setenv nextcon 0; + +if hdmidet ; then + setenv bootargs $bootargs video=mxcfb${nextcon}:dev=hdmi,1280x720M@60,if=RGB24 + setenv fbmem "fbmem=28M"; + setexpr nextcon $nextcon + 1 +else + echo "------ no HDMI monitor"; +fi + +i2c dev 2 +if i2c probe 0x04 ; then + setenv bootargs $bootargs video=mxcfb${nextcon}:dev=ldb,LDB-XGA,if=RGB666 + if test "0" -eq $nextcon; then + setenv fbmem "fbmem=10M"; + else + setenv fbmem ${fbmem},10M + fi + setexpr nextcon $nextcon + 1 +else + echo "------ no Freescale display"; +fi + +if i2c probe 0x38 ; then + setenv bootargs $bootargs video=mxcfb${nextcon}:dev=ldb,1024x600M@60,if=RGB666 + if test "0" -eq $nextcon; then + setenv fbmem "fbmem=10M"; + else + setenv fbmem ${fbmem},10M + fi + setexpr nextcon $nextcon + 1 +else + echo "------ no 1024x600 display"; +fi + +if i2c probe 0x48 ; then + setenv bootargs $bootargs video=mxcfb${nextcon}:dev=lcd,CLAA-WVGA,if=RGB666 + if test "0" -eq $nextcon; then + setenv fbmem "fbmem=10M"; + else + setenv fbmem ${fbmem},10M + fi + setexpr nextcon $nextcon + 1 +else + echo "------ no 800x480 display"; +fi + +while test "3" -ne $nextcon ; do + setenv bootargs $bootargs video=mxcfb${nextcon}:off ; + setexpr nextcon $nextcon + 1 ; +done + +setenv bootargs $bootargs $fbmem + +setenv bootargs $bootargs console=ttymxc1,115200 vmalloc=400M root=/dev/mmcblk0p1 rootwait consoleblank=0 ; +${fs}load mmc ${disk}:1 10800000 /boot/uImage && bootm 10800000 ; echo "Error loading kernel image" + diff --git a/board/boundary/nitrogen6x/6x_bootscript_android.txt b/board/boundary/nitrogen6x/6x_bootscript_android.txt new file mode 100644 index 0000000..7ade2e5 --- /dev/null +++ b/board/boundary/nitrogen6x/6x_bootscript_android.txt @@ -0,0 +1,64 @@ +${dtype} dev ${disk} + +setenv bootargs enable_wait_mode=off +setenv nextcon 0; +setenv bootargs $bootargs console=ttymxc1,115200 vmalloc=400M consoleblank=0 ; + +i2c dev 2 + +if i2c probe 0x04 ; then + setenv bootargs $bootargs video=mxcfb${nextcon}:dev=ldb,LDB-XGA,if=RGB666 + if test "0" -eq $nextcon; then + setenv fbcon "fbcon=10M"; + else + setenv fbcon ${fbcon},10M + fi + setexpr nextcon $nextcon + 1 +else + echo "------ no Freescale display"; +fi + +if i2c probe 0x38 ; then + setenv bootargs $bootargs video=mxcfb${nextcon}:dev=ldb,1024x600M@60,if=RGB666 + if test "0" -eq $nextcon; then + setenv fbcon "fbcon=10M"; + else + setenv fbcon ${fbcon},10M + fi + setexpr nextcon $nextcon + 1 +else + echo "------ no 1024x600 display"; +fi + +if i2c probe 0x48 ; then + setenv bootargs $bootargs video=mxcfb${nextcon}:dev=lcd,CLAA-WVGA,if=RGB666 tsdev=tsc2004 calibration + if test "0" -eq $nextcon; then + setenv fbcon "fbcon=10M"; + else + setenv fbcon ${fbcon},10M + fi + setexpr nextcon $nextcon + 1 +else + echo "------ no 800x480 display"; +fi + +if hdmidet ; then + setenv bootargs $bootargs video=mxcfb${nextcon}:dev=hdmi,1280x720M@60,if=RGB24 + if test "0" -eq $nextcon; then + setenv fbcon "fbcon=28M"; + else + setenv fbcon ${fbcon},28M + fi + setexpr nextcon $nextcon + 1 +else + echo "------ no HDMI monitor"; +fi + +while test "3" -ne $nextcon ; do + setenv bootargs $bootargs video=mxcfb${nextcon}:off ; + setexpr nextcon $nextcon + 1 ; +done + +setenv bootargs $bootargs fbcon=$fbcon +${fs}load ${dtype} ${disk}:1 10800000 uImage && ${fs}load ${dtype} ${disk}:1 12800000 uramdisk.img && bootm 10800000 12800000; echo "Error loading kernel image" + diff --git a/board/boundary/nitrogen6x/6x_bootscript_android_recovery.txt b/board/boundary/nitrogen6x/6x_bootscript_android_recovery.txt new file mode 100644 index 0000000..7ade2e5 --- /dev/null +++ b/board/boundary/nitrogen6x/6x_bootscript_android_recovery.txt @@ -0,0 +1,64 @@ +${dtype} dev ${disk} + +setenv bootargs enable_wait_mode=off +setenv nextcon 0; +setenv bootargs $bootargs console=ttymxc1,115200 vmalloc=400M consoleblank=0 ; + +i2c dev 2 + +if i2c probe 0x04 ; then + setenv bootargs $bootargs video=mxcfb${nextcon}:dev=ldb,LDB-XGA,if=RGB666 + if test "0" -eq $nextcon; then + setenv fbcon "fbcon=10M"; + else + setenv fbcon ${fbcon},10M + fi + setexpr nextcon $nextcon + 1 +else + echo "------ no Freescale display"; +fi + +if i2c probe 0x38 ; then + setenv bootargs $bootargs video=mxcfb${nextcon}:dev=ldb,1024x600M@60,if=RGB666 + if test "0" -eq $nextcon; then + setenv fbcon "fbcon=10M"; + else + setenv fbcon ${fbcon},10M + fi + setexpr nextcon $nextcon + 1 +else + echo "------ no 1024x600 display"; +fi + +if i2c probe 0x48 ; then + setenv bootargs $bootargs video=mxcfb${nextcon}:dev=lcd,CLAA-WVGA,if=RGB666 tsdev=tsc2004 calibration + if test "0" -eq $nextcon; then + setenv fbcon "fbcon=10M"; + else + setenv fbcon ${fbcon},10M + fi + setexpr nextcon $nextcon + 1 +else + echo "------ no 800x480 display"; +fi + +if hdmidet ; then + setenv bootargs $bootargs video=mxcfb${nextcon}:dev=hdmi,1280x720M@60,if=RGB24 + if test "0" -eq $nextcon; then + setenv fbcon "fbcon=28M"; + else + setenv fbcon ${fbcon},28M + fi + setexpr nextcon $nextcon + 1 +else + echo "------ no HDMI monitor"; +fi + +while test "3" -ne $nextcon ; do + setenv bootargs $bootargs video=mxcfb${nextcon}:off ; + setexpr nextcon $nextcon + 1 ; +done + +setenv bootargs $bootargs fbcon=$fbcon +${fs}load ${dtype} ${disk}:1 10800000 uImage && ${fs}load ${dtype} ${disk}:1 12800000 uramdisk.img && bootm 10800000 12800000; echo "Error loading kernel image" + diff --git a/board/boundary/nitrogen6x/6x_upgrade.txt b/board/boundary/nitrogen6x/6x_upgrade.txt new file mode 100644 index 0000000..354d1a2 --- /dev/null +++ b/board/boundary/nitrogen6x/6x_upgrade.txt @@ -0,0 +1,46 @@ +setenv stdout serial,vga +echo "check U-Boot" ; +setenv offset 0x400 +if ${fs}load ${dtype} ${disk}:1 12000000 u-boot.imx || ${fs}load ${dtype} ${disk}:1 12000000 u-boot.nopadding ; then + echo "read $filesize bytes from SD card" ; + if sf probe || sf probe || \ + sf probe 1 27000000 || sf probe 1 27000000 ; then + echo "probed SPI ROM" ; + if sf read 0x12400000 $offset $filesize ; then + if cmp.b 0x12000000 0x12400000 $filesize ; then + echo "------- U-Boot versions match" ; + else + echo "Need U-Boot upgrade" ; + echo "Program in 5 seconds" ; + for n in 5 4 3 2 1 ; do + echo $n ; + sleep 1 ; + done + echo "erasing" ; + sf erase 0 0x50000 ; + # two steps to prevent bricking + echo "programming" ; + sf write 0x12000000 $offset $filesize ; + echo "verifying" ; + if sf read 0x12400000 $offset $filesize ; then + if cmp.b 0x12000000 0x12400000 $filesize ; then + while echo "---- U-Boot upgraded. reset" ; do + sleep 120 + done + else + echo "Read verification error" ; + fi + else + echo "Error re-reading EEPROM" ; + fi + fi + else + echo "Error reading boot loader from EEPROM" ; + fi + else + echo "Error initializing EEPROM" ; + fi ; +else + echo "No U-Boot image found on SD card" ; +fi + diff --git a/board/boundary/nitrogen6x/800mhz_2x128mx16.cfg b/board/boundary/nitrogen6x/800mhz_2x128mx16.cfg new file mode 100644 index 0000000..ffd1078 --- /dev/null +++ b/board/boundary/nitrogen6x/800mhz_2x128mx16.cfg @@ -0,0 +1,37 @@ +DATA 4, MMDC_P0_MDPDC, 0x0002002D +DATA 4, MMDC_P0_MDCFG0, 0x696D5323 +DATA 4, MMDC_P0_MDCFG1, 0xB66E8C63 +DATA 4, MMDC_P0_MDCFG2, 0x01FF00DB +DATA 4, MMDC_P0_MDRWD, 0x000026D2 +DATA 4, MMDC_P0_MDOR, 0x005B0E21 +DATA 4, MMDC_P0_MDOTC, 0x00333030 +DATA 4, MMDC_P0_MDPDC, 0x0002556D +DATA 4, MMDC_P0_MDASP, 0x00000017 +DATA 4, MMDC_P0_MDCTL, 0x83190000 +DATA 4, MMDC_P0_MDSCR, 0x04008032 +DATA 4, MMDC_P0_MDSCR, 0x00008033 +DATA 4, MMDC_P0_MDSCR, 0x00048031 +DATA 4, MMDC_P0_MDSCR, 0x07208030 +DATA 4, MMDC_P0_MDSCR, 0x04008040 +DATA 4, MMDC_P0_MPZQHWCTRL, 0xA1390003 +DATA 4, MMDC_P1_MPZQHWCTRL, 0xA1390003 +DATA 4, MMDC_P0_MDREF, 0x00005800 +DATA 4, MMDC_P0_MPODTCTRL, 0x00022227 +DATA 4, MMDC_P1_MPODTCTRL, 0x00022227 +DATA 4, MMDC_P0_MPDGCTRL0, 0x42350231 +DATA 4, MMDC_P0_MPDGCTRL1, 0x021A0218 +DATA 4, MMDC_P1_MPDGCTRL0, 0x42350231 +DATA 4, MMDC_P1_MPDGCTRL1, 0x021A0218 +DATA 4, MMDC_P0_MPRDDLCTL, 0x4B4B4E49 +DATA 4, MMDC_P1_MPRDDLCTL, 0x4B4B4E49 +DATA 4, MMDC_P0_MPWRDLCTL, 0x3F3F3035 +DATA 4, MMDC_P1_MPWRDLCTL, 0x3F3F3035 +DATA 4, MMDC_P0_MPWLDECTRL0, 0x0040003C +DATA 4, MMDC_P0_MPWLDECTRL1, 0x0032003E +DATA 4, MMDC_P1_MPWLDECTRL0, 0x0040003C +DATA 4, MMDC_P1_MPWLDECTRL1, 0x0032003E +DATA 4, MMDC_P0_MPMUR0, 0x00000800 +DATA 4, MMDC_P1_MPMUR0, 0x00000800 +DATA 4, MMDC_P0_MDSCR, 0x00000000 +DATA 4, MMDC_P0_MAPSR, 0x00011006 + diff --git a/board/boundary/nitrogen6x/800mhz_2x256mx16.cfg b/board/boundary/nitrogen6x/800mhz_2x256mx16.cfg new file mode 100644 index 0000000..35b38b7 --- /dev/null +++ b/board/boundary/nitrogen6x/800mhz_2x256mx16.cfg @@ -0,0 +1,37 @@ +DATA 4, MMDC_P0_MDPDC, 0x0002002D +DATA 4, MMDC_P0_MDCFG0, 0x696D5323 +DATA 4, MMDC_P0_MDCFG1, 0xB66E8C63 +DATA 4, MMDC_P0_MDCFG2, 0x01FF00DB +DATA 4, MMDC_P0_MDRWD, 0x000026D2 +DATA 4, MMDC_P0_MDOR, 0x005B0E21 +DATA 4, MMDC_P0_MDOTC, 0x00333030 +DATA 4, MMDC_P0_MDPDC, 0x0002556D +DATA 4, MMDC_P0_MDASP, 0x00000027 +DATA 4, MMDC_P0_MDCTL, 0x84190000 +DATA 4, MMDC_P0_MDSCR, 0x04008032 +DATA 4, MMDC_P0_MDSCR, 0x00008033 +DATA 4, MMDC_P0_MDSCR, 0x00048031 +DATA 4, MMDC_P0_MDSCR, 0x07208030 +DATA 4, MMDC_P0_MDSCR, 0x04008040 +DATA 4, MMDC_P0_MPZQHWCTRL, 0xA1390003 +DATA 4, MMDC_P1_MPZQHWCTRL, 0xA1390003 +DATA 4, MMDC_P0_MDREF, 0x00007800 +DATA 4, MMDC_P0_MPODTCTRL, 0x00022227 +DATA 4, MMDC_P1_MPODTCTRL, 0x00022227 +DATA 4, MMDC_P0_MPDGCTRL0, 0x42350231 +DATA 4, MMDC_P0_MPDGCTRL1, 0x021A0218 +DATA 4, MMDC_P1_MPDGCTRL0, 0x42350231 +DATA 4, MMDC_P1_MPDGCTRL1, 0x021A0218 +DATA 4, MMDC_P0_MPRDDLCTL, 0x4B4B4E49 +DATA 4, MMDC_P1_MPRDDLCTL, 0x4B4B4E49 +DATA 4, MMDC_P0_MPWRDLCTL, 0x3F3F3035 +DATA 4, MMDC_P1_MPWRDLCTL, 0x3F3F3035 +DATA 4, MMDC_P0_MPWLDECTRL0, 0x0040003C +DATA 4, MMDC_P0_MPWLDECTRL1, 0x0032003E +DATA 4, MMDC_P1_MPWLDECTRL0, 0x0040003C +DATA 4, MMDC_P1_MPWLDECTRL1, 0x0032003E +DATA 4, MMDC_P0_MPMUR0, 0x00000800 +DATA 4, MMDC_P1_MPMUR0, 0x00000800 +DATA 4, MMDC_P0_MDSCR, 0x00000000 +DATA 4, MMDC_P0_MAPSR, 0x00011006 + diff --git a/board/boundary/nitrogen6x/800mhz_4x128mx16.cfg b/board/boundary/nitrogen6x/800mhz_4x128mx16.cfg new file mode 100644 index 0000000..76ae7e9 --- /dev/null +++ b/board/boundary/nitrogen6x/800mhz_4x128mx16.cfg @@ -0,0 +1,37 @@ +DATA 4, MMDC_P0_MDPDC, 0x0002002D +DATA 4, MMDC_P0_MDCFG0, 0x696D5323 +DATA 4, MMDC_P0_MDCFG1, 0xB66E8C63 +DATA 4, MMDC_P0_MDCFG2, 0x01FF00DB +DATA 4, MMDC_P0_MDRWD, 0x000026D2 +DATA 4, MMDC_P0_MDOR, 0x005B0E21 +DATA 4, MMDC_P0_MDOTC, 0x00333030 +DATA 4, MMDC_P0_MDPDC, 0x0002556D +DATA 4, MMDC_P0_MDASP, 0x00000027 +DATA 4, MMDC_P0_MDCTL, 0x831A0000 +DATA 4, MMDC_P0_MDSCR, 0x04008032 +DATA 4, MMDC_P0_MDSCR, 0x00008033 +DATA 4, MMDC_P0_MDSCR, 0x00048031 +DATA 4, MMDC_P0_MDSCR, 0x07208030 +DATA 4, MMDC_P0_MDSCR, 0x04008040 +DATA 4, MMDC_P0_MPZQHWCTRL, 0xA1390003 +DATA 4, MMDC_P1_MPZQHWCTRL, 0xA1390003 +DATA 4, MMDC_P0_MDREF, 0x00005800 +DATA 4, MMDC_P0_MPODTCTRL, 0x00022227 +DATA 4, MMDC_P1_MPODTCTRL, 0x00022227 +DATA 4, MMDC_P0_MPDGCTRL0, 0x42350231 +DATA 4, MMDC_P0_MPDGCTRL1, 0x021A0218 +DATA 4, MMDC_P1_MPDGCTRL0, 0x42350231 +DATA 4, MMDC_P1_MPDGCTRL1, 0x021A0218 +DATA 4, MMDC_P0_MPRDDLCTL, 0x4B4B4E49 +DATA 4, MMDC_P1_MPRDDLCTL, 0x4B4B4E49 +DATA 4, MMDC_P0_MPWRDLCTL, 0x3F3F3035 +DATA 4, MMDC_P1_MPWRDLCTL, 0x3F3F3035 +DATA 4, MMDC_P0_MPWLDECTRL0, 0x0040003C +DATA 4, MMDC_P0_MPWLDECTRL1, 0x0032003E +DATA 4, MMDC_P1_MPWLDECTRL0, 0x0040003C +DATA 4, MMDC_P1_MPWLDECTRL1, 0x0032003E +DATA 4, MMDC_P0_MPMUR0, 0x00000800 +DATA 4, MMDC_P1_MPMUR0, 0x00000800 +DATA 4, MMDC_P0_MDSCR, 0x00000000 +DATA 4, MMDC_P0_MAPSR, 0x00011006 + diff --git a/board/boundary/nitrogen6x/800mhz_4x256mx16.cfg b/board/boundary/nitrogen6x/800mhz_4x256mx16.cfg new file mode 100644 index 0000000..8de937c --- /dev/null +++ b/board/boundary/nitrogen6x/800mhz_4x256mx16.cfg @@ -0,0 +1,37 @@ +DATA 4, MMDC_P0_MDPDC, 0x0002002D +DATA 4, MMDC_P0_MDCFG0, 0x696D5323 +DATA 4, MMDC_P0_MDCFG1, 0xB66E8C63 +DATA 4, MMDC_P0_MDCFG2, 0x01FF00DB +DATA 4, MMDC_P0_MDRWD, 0x000026D2 +DATA 4, MMDC_P0_MDOR, 0x005B0E21 +DATA 4, MMDC_P0_MDOTC, 0x00333030 +DATA 4, MMDC_P0_MDPDC, 0x0002556D +DATA 4, MMDC_P0_MDASP, 0x00000047 +DATA 4, MMDC_P0_MDCTL, 0x841A0000 +DATA 4, MMDC_P0_MDSCR, 0x04008032 +DATA 4, MMDC_P0_MDSCR, 0x00008033 +DATA 4, MMDC_P0_MDSCR, 0x00048031 +DATA 4, MMDC_P0_MDSCR, 0x07208030 +DATA 4, MMDC_P0_MDSCR, 0x04008040 +DATA 4, MMDC_P0_MPZQHWCTRL, 0xA1390003 +DATA 4, MMDC_P1_MPZQHWCTRL, 0xA1390003 +DATA 4, MMDC_P0_MDREF, 0x00007800 +DATA 4, MMDC_P0_MPODTCTRL, 0x00022227 +DATA 4, MMDC_P1_MPODTCTRL, 0x00022227 +DATA 4, MMDC_P0_MPDGCTRL0, 0x42350231 +DATA 4, MMDC_P0_MPDGCTRL1, 0x021A0218 +DATA 4, MMDC_P1_MPDGCTRL0, 0x42350231 +DATA 4, MMDC_P1_MPDGCTRL1, 0x021A0218 +DATA 4, MMDC_P0_MPRDDLCTL, 0x4B4B4E49 +DATA 4, MMDC_P1_MPRDDLCTL, 0x4B4B4E49 +DATA 4, MMDC_P0_MPWRDLCTL, 0x3F3F3035 +DATA 4, MMDC_P1_MPWRDLCTL, 0x3F3F3035 +DATA 4, MMDC_P0_MPWLDECTRL0, 0x0040003C +DATA 4, MMDC_P0_MPWLDECTRL1, 0x0032003E +DATA 4, MMDC_P1_MPWLDECTRL0, 0x0040003C +DATA 4, MMDC_P1_MPWLDECTRL1, 0x0032003E +DATA 4, MMDC_P0_MPMUR0, 0x00000800 +DATA 4, MMDC_P1_MPMUR0, 0x00000800 +DATA 4, MMDC_P0_MDSCR, 0x00000000 +DATA 4, MMDC_P0_MAPSR, 0x00011006 + diff --git a/board/boundary/nitrogen6x/Makefile b/board/boundary/nitrogen6x/Makefile new file mode 100644 index 0000000..63da7d0 --- /dev/null +++ b/board/boundary/nitrogen6x/Makefile @@ -0,0 +1,41 @@ +# +# Copyright (C) 2012, Guennadi Liakhovetski lg@denx.de +# +# (C) Copyright 2012 Freescale Semiconductor, Inc. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS := nitrogen6x.o + +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/boundary/nitrogen6x/README b/board/boundary/nitrogen6x/README new file mode 100644 index 0000000..330cb49 --- /dev/null +++ b/board/boundary/nitrogen6x/README @@ -0,0 +1,93 @@ +U-Boot for the Boundary Devices Nitrogen6X and +Freescale i.MX6Q SabreLite boards + +This file contains information for the port of +U-Boot to the Boundary Devices Nitrogen6X and +Freescale i.MX6Q SabreLite boards. + +1. Boot source, boot from SPI NOR +--------------------------------- +The configuration in this directory supports both the +Nitrogen6X and Freescale SabreLite board, but in a +different fashion from Freescale's implementation in +board/freescale/mx6qsabrelite. + +In particular, this image supports booting from SPI NOR +and saving the environment to SPI NOR. + +It does not support 'boot from SD' at offset 0x400 +except through the 'bmode' command. + http://lists.denx.de/pipermail/u-boot/2012-August/131151.html + +2. Boots using 6x_bootscript on SATA or SD card +----------------------------------------------- +The default bootcmd for these boards is configured +to look for and source a boot script named '6x_bootscript' +in the root of the first partition of the following +devices: + + sata 0 + mmc 0 + mmc 1 + +They're searched in the order listed above, trying both the +ext2 and fat filesystems. + +2. Maintaining the SPI NOR +-------------------------- +A couple of convenience commands + + clearenv - clear environment to factory default + upgradeu - look and source a boot script named + '6x_upgrade' to upgrade the U-Boot version + in SPI NOR. The search is the same as for + 6x_bootscript described above. + +3. Display support +------------------ +U-Boot support for the following displays is configured by +default: + + HDMI - 1024 x 768 for maximum compatibility + Hannstar-XGA - 1024 x 768 LVDS (Freescale part number MCIMX-LVDS1) + wsvga-lvds - 1024 x 600 LVDS (Boundary p/n Nit6X_1024x600) + wvga-rgb - 800 x 480 RGB (Boundary p/n Nit6X_800x480) + +Since the ipuv3_fb display driver currently supports only a single display, +this code auto-detects panel by probing the HDMI Phy for Hot Plug Detect +or the I2C touch controller of the LVDS and RGB displays in the priority +listed above. + +Setting 'panel' environment variable to one of the names above will +override auto-detection and force activation of the specified panel. + +4. Building +------------ + +To build U-Boot for one of the Nitrogen6x or SabreLite board: + + make nitrogen6x_config + make u-boot.imx + +Note that 'nitrogen6x' is a placeholder. The complete list of supported +board configurations is shown in tha MAINTAINERS file: + nitrogen6q i.MX6Q/6D 1GB + nitrogen6dl i.MX6DL 1GB + nitrogen6s i.MX6S 512MB + nitrogen6q2g i.MX6Q/6D 2GB + nitrogen6dl2g i.MX6DL 2GB + nitrogen6s1g i.MX6S 1GB + +The -6q variants support either the i.MX6Quad or i.MX6Dual processors +and are configured for a 64-bit memory bus at 1066 MHz. + +The -6dl variants also use a 64-bit memory bus, operated at 800MHz. + +The -6s variants use a 32-bit memory bus at 800MHz. + +If you place the u-boot.imx into a single-partition SD card +along with a binary version of the boot script 6x_upgrade.txt, +you can program it using 'upgradeu': + + U-Boot> run upgradeu + diff --git a/board/boundary/nitrogen6x/clocks.cfg b/board/boundary/nitrogen6x/clocks.cfg new file mode 100644 index 0000000..5143b78 --- /dev/null +++ b/board/boundary/nitrogen6x/clocks.cfg @@ -0,0 +1,31 @@ +/* + * Device Configuration Data (DCD) + * + * Each entry must have the format: + * Addr-type Address Value + * + * where: + * Addr-type register length (1,2 or 4 bytes) + * Address absolute address of the register + * value value to be stored in the register + */ + +/* set the default clock gate to save power */ +DATA 4, CCM_CCGR0, 0x00C03F3F +DATA 4, CCM_CCGR1, 0x0030FC03 +DATA 4, CCM_CCGR2, 0x0FFFC000 +DATA 4, CCM_CCGR3, 0x3FF00000 +DATA 4, CCM_CCGR4, 0x00FFF300 +DATA 4, CCM_CCGR5, 0x0F0000C3 +DATA 4, CCM_CCGR6, 0x000003FF + +/* enable AXI cache for VDOA/VPU/IPU */ +DATA 4, IOMUXC_GPR4, 0xF00000CF +/* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ +DATA 4, IOMUXC_GPR6, 0x007F007F +DATA 4, IOMUXC_GPR7, 0x007F007F + +/* Set LDO Ramp rates to fast */ +/* 64 clocks/0.266uS/25mV */ +/* == 32uS for 0.95->1.25V */ +DATA 4, PMU_MISC2, 0x00670f67 diff --git a/board/boundary/nitrogen6x/ddr-setup.cfg b/board/boundary/nitrogen6x/ddr-setup.cfg new file mode 100644 index 0000000..b3f7ec4 --- /dev/null +++ b/board/boundary/nitrogen6x/ddr-setup.cfg @@ -0,0 +1,94 @@ +/* + * Device Configuration Data (DCD) + * + * Each entry must have the format: + * Addr-type Address Value + * + * where: + * Addr-type register length (1,2 or 4 bytes) + * Address absolute address of the register + * value value to be stored in the register + */ + +/* + * DDR3 settings + * MX6Q ddr is limited to 1066 Mhz currently 1056 MHz(528 MHz clock), + * memory bus width: 64 bits x16/x32/x64 + * MX6DL ddr is limited to 800 MHz(400 MHz clock) + * memory bus width: 64 bits x16/x32/x64 + * MX6SOLO ddr is limited to 800 MHz(400 MHz clock) + * memory bus width: 32 bits x16/x32 + */ +DATA 4, IOM_DRAM_SDQS0, 0x00000030 +DATA 4, IOM_DRAM_SDQS1, 0x00000030 +DATA 4, IOM_DRAM_SDQS2, 0x00000030 +DATA 4, IOM_DRAM_SDQS3, 0x00000030 +DATA 4, IOM_DRAM_SDQS4, 0x00000030 +DATA 4, IOM_DRAM_SDQS5, 0x00000030 +DATA 4, IOM_DRAM_SDQS6, 0x00000030 +DATA 4, IOM_DRAM_SDQS7, 0x00000030 + +DATA 4, IOM_GRP_B0DS, 0x00000030 +DATA 4, IOM_GRP_B1DS, 0x00000030 +DATA 4, IOM_GRP_B2DS, 0x00000030 +DATA 4, IOM_GRP_B3DS, 0x00000030 +DATA 4, IOM_GRP_B4DS, 0x00000030 +DATA 4, IOM_GRP_B5DS, 0x00000030 +DATA 4, IOM_GRP_B6DS, 0x00000030 +DATA 4, IOM_GRP_B7DS, 0x00000030 +DATA 4, IOM_GRP_ADDDS, 0x00000030 +/* 40 Ohm drive strength for cs0/1,sdba2,cke0/1,sdwe */ +DATA 4, IOM_GRP_CTLDS, 0x00000030 + +DATA 4, IOM_DRAM_DQM0, 0x00020030 +DATA 4, IOM_DRAM_DQM1, 0x00020030 +DATA 4, IOM_DRAM_DQM2, 0x00020030 +DATA 4, IOM_DRAM_DQM3, 0x00020030 +DATA 4, IOM_DRAM_DQM4, 0x00020030 +DATA 4, IOM_DRAM_DQM5, 0x00020030 +DATA 4, IOM_DRAM_DQM6, 0x00020030 +DATA 4, IOM_DRAM_DQM7, 0x00020030 + +DATA 4, IOM_DRAM_CAS, 0x00020030 +DATA 4, IOM_DRAM_RAS, 0x00020030 +DATA 4, IOM_DRAM_SDCLK_0, 0x00020030 +DATA 4, IOM_DRAM_SDCLK_1, 0x00020030 + +DATA 4, IOM_DRAM_RESET, 0x000e0030 +DATA 4, IOM_DRAM_SDCKE0, 0x00003000 +DATA 4, IOM_DRAM_SDCKE1, 0x00003000 + +DATA 4, IOM_DRAM_SDODT0, 0x00003030 +DATA 4, IOM_DRAM_SDODT1, 0x00003030 + +/* (differential input) */ +DATA 4, IOM_DDRMODE_CTL, 0x00020000 +/* (differential input) */ +DATA 4, IOM_GRP_DDRMODE, 0x00020000 +/* disable ddr pullups */ +DATA 4, IOM_GRP_DDRPKE, 0x00000000 +DATA 4, IOM_DRAM_SDBA2, 0x00000000 +/* 40 Ohm drive strength for cs0/1,sdba2,cke0/1,sdwe */ +DATA 4, IOM_GRP_DDR_TYPE, 0x000C0000 + +/* Read data DQ Byte0-3 delay */ +DATA 4, MMDC_P0_MPRDDQBY0DL, 0x33333333 +DATA 4, MMDC_P0_MPRDDQBY1DL, 0x33333333 +DATA 4, MMDC_P0_MPRDDQBY2DL, 0x33333333 +DATA 4, MMDC_P0_MPRDDQBY3DL, 0x33333333 +DATA 4, MMDC_P1_MPRDDQBY0DL, 0x33333333 +DATA 4, MMDC_P1_MPRDDQBY1DL, 0x33333333 +DATA 4, MMDC_P1_MPRDDQBY2DL, 0x33333333 +DATA 4, MMDC_P1_MPRDDQBY3DL, 0x33333333 + +/* + * MDMISC mirroring interleaved (row/bank/col) + */ +DATA 4, MMDC_P0_MDMISC, 0x00081740 + +/* + * MDSCR con_req + */ +DATA 4, MMDC_P0_MDSCR, 0x00008000 + + diff --git a/board/boundary/nitrogen6x/nitrogen6dl.cfg b/board/boundary/nitrogen6x/nitrogen6dl.cfg new file mode 100644 index 0000000..60300c5 --- /dev/null +++ b/board/boundary/nitrogen6x/nitrogen6dl.cfg @@ -0,0 +1,46 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not write to the Free Software + * Foundation Inc. 51 Franklin Street Fifth Floor Boston, + * MA 02110-1301 USA + * + * Refer docs/README.imxmage for more details about how-to configure + * and create imximage boot image + * + * The syntax is taken as close as possible with the kwbimage + */ + +/* image version */ +IMAGE_VERSION 2 + +/* + * Boot Device : one of + * spi, sd (the board has no nand neither onenand) + */ +BOOT_FROM sd + +#define __ASSEMBLY__ +#include <config.h> +#include "asm/arch/mx6-ddr.h" +#include "asm/arch/iomux.h" +#include "asm/arch/crm_regs.h" + +#include "ddr-setup.cfg" +#include "800mhz_4x128mx16.cfg" +#include "clocks.cfg" + diff --git a/board/boundary/nitrogen6x/nitrogen6dl2g.cfg b/board/boundary/nitrogen6x/nitrogen6dl2g.cfg new file mode 100644 index 0000000..b62c73e --- /dev/null +++ b/board/boundary/nitrogen6x/nitrogen6dl2g.cfg @@ -0,0 +1,46 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not write to the Free Software + * Foundation Inc. 51 Franklin Street Fifth Floor Boston, + * MA 02110-1301 USA + * + * Refer docs/README.imxmage for more details about how-to configure + * and create imximage boot image + * + * The syntax is taken as close as possible with the kwbimage + */ + +/* image version */ +IMAGE_VERSION 2 + +/* + * Boot Device : one of + * spi, sd (the board has no nand neither onenand) + */ +BOOT_FROM sd + +#define __ASSEMBLY__ +#include <config.h> +#include "asm/arch/mx6-ddr.h" +#include "asm/arch/iomux.h" +#include "asm/arch/crm_regs.h" + +#include "ddr-setup.cfg" +#include "800mhz_4x256mx16.cfg" +#include "clocks.cfg" + diff --git a/board/boundary/nitrogen6x/nitrogen6q.cfg b/board/boundary/nitrogen6x/nitrogen6q.cfg new file mode 100644 index 0000000..30353a5 --- /dev/null +++ b/board/boundary/nitrogen6x/nitrogen6q.cfg @@ -0,0 +1,46 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not write to the Free Software + * Foundation Inc. 51 Franklin Street Fifth Floor Boston, + * MA 02110-1301 USA + * + * Refer docs/README.imxmage for more details about how-to configure + * and create imximage boot image + * + * The syntax is taken as close as possible with the kwbimage + */ + +/* image version */ +IMAGE_VERSION 2 + +/* + * Boot Device : one of + * spi, sd (the board has no nand neither onenand) + */ +BOOT_FROM sd + +#define __ASSEMBLY__ +#include <config.h> +#include "asm/arch/mx6-ddr.h" +#include "asm/arch/iomux.h" +#include "asm/arch/crm_regs.h" + +#include "ddr-setup.cfg" +#include "1066mhz_4x128mx16.cfg" +#include "clocks.cfg" + diff --git a/board/boundary/nitrogen6x/nitrogen6q2g.cfg b/board/boundary/nitrogen6x/nitrogen6q2g.cfg new file mode 100644 index 0000000..8c1a74f --- /dev/null +++ b/board/boundary/nitrogen6x/nitrogen6q2g.cfg @@ -0,0 +1,46 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not write to the Free Software + * Foundation Inc. 51 Franklin Street Fifth Floor Boston, + * MA 02110-1301 USA + * + * Refer docs/README.imxmage for more details about how-to configure + * and create imximage boot image + * + * The syntax is taken as close as possible with the kwbimage + */ + +/* image version */ +IMAGE_VERSION 2 + +/* + * Boot Device : one of + * spi, sd (the board has no nand neither onenand) + */ +BOOT_FROM sd + +#define __ASSEMBLY__ +#include <config.h> +#include "asm/arch/mx6-ddr.h" +#include "asm/arch/iomux.h" +#include "asm/arch/crm_regs.h" + +#include "ddr-setup.cfg" +#include "1066mhz_4x256mx16.cfg" +#include "clocks.cfg" + diff --git a/board/boundary/nitrogen6x/nitrogen6s.cfg b/board/boundary/nitrogen6x/nitrogen6s.cfg new file mode 100644 index 0000000..8a73a51 --- /dev/null +++ b/board/boundary/nitrogen6x/nitrogen6s.cfg @@ -0,0 +1,46 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not write to the Free Software + * Foundation Inc. 51 Franklin Street Fifth Floor Boston, + * MA 02110-1301 USA + * + * Refer docs/README.imxmage for more details about how-to configure + * and create imximage boot image + * + * The syntax is taken as close as possible with the kwbimage + */ + +/* image version */ +IMAGE_VERSION 2 + +/* + * Boot Device : one of + * spi, sd (the board has no nand neither onenand) + */ +BOOT_FROM sd + +#define __ASSEMBLY__ +#include <config.h> +#include "asm/arch/mx6-ddr.h" +#include "asm/arch/iomux.h" +#include "asm/arch/crm_regs.h" + +#include "ddr-setup.cfg" +#include "800mhz_2x128mx16.cfg" +#include "clocks.cfg" + diff --git a/board/boundary/nitrogen6x/nitrogen6s1g.cfg b/board/boundary/nitrogen6x/nitrogen6s1g.cfg new file mode 100644 index 0000000..3659e1e --- /dev/null +++ b/board/boundary/nitrogen6x/nitrogen6s1g.cfg @@ -0,0 +1,46 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not write to the Free Software + * Foundation Inc. 51 Franklin Street Fifth Floor Boston, + * MA 02110-1301 USA + * + * Refer docs/README.imxmage for more details about how-to configure + * and create imximage boot image + * + * The syntax is taken as close as possible with the kwbimage + */ + +/* image version */ +IMAGE_VERSION 2 + +/* + * Boot Device : one of + * spi, sd (the board has no nand neither onenand) + */ +BOOT_FROM sd + +#define __ASSEMBLY__ +#include <config.h> +#include "asm/arch/mx6-ddr.h" +#include "asm/arch/iomux.h" +#include "asm/arch/crm_regs.h" + +#include "ddr-setup.cfg" +#include "800mhz_2x256mx16.cfg" +#include "clocks.cfg" + diff --git a/board/boundary/nitrogen6x/nitrogen6x.c b/board/boundary/nitrogen6x/nitrogen6x.c new file mode 100644 index 0000000..9e3898a --- /dev/null +++ b/board/boundary/nitrogen6x/nitrogen6x.c @@ -0,0 +1,901 @@ +/* + * Copyright (C) 2010-2011 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/iomux.h> +#ifdef CONFIG_MX6Q +#include <asm/arch/mx6x_pins.h> +#else +#ifdef CONFIG_MX6DL +#include <asm/arch/mx6dl_pins.h> +#define FOR_DL_SOLO +#else +#ifdef CONFIG_MX6S +#include <asm/arch/mx6dl_pins.h> +#define FOR_DL_SOLO +#else +#error "Please select cpu" +#endif /* CONFIG_MX6S */ +#endif /* CONFIG_MX6DL */ +#endif /* CONFIG_MX6Q */ +#include <asm/errno.h> +#include <asm/gpio.h> +#include <asm/imx-common/iomux-v3.h> +#include <asm/imx-common/mxc_i2c.h> +#include <asm/imx-common/boot_mode.h> +#include <mmc.h> +#include <fsl_esdhc.h> +#include <micrel.h> +#include <miiphy.h> +#include <netdev.h> +#include <linux/fb.h> +#include <ipu_pixfmt.h> +#include <asm/arch/crm_regs.h> +#include <asm/arch/mxc_hdmi.h> +#include <i2c.h> + +DECLARE_GLOBAL_DATA_PTR; + +#ifdef FOR_DL_SOLO +#define MX6PAD(a) MX6DL_PAD_##a +#else +#define MX6PAD(a) MX6Q_PAD_##a +#endif + +#define UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define USDHC_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_47K_UP | PAD_CTL_SPEED_LOW | \ + PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define ENET_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_HYS) + +#define SPI_PAD_CTRL (PAD_CTL_HYS | \ + PAD_CTL_PUS_100K_DOWN | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST) + +#define BUTTON_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_HYS) + +#define I2C_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ + PAD_CTL_ODE | PAD_CTL_SRE_FAST) + +#define WEAK_PULLUP (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ + PAD_CTL_SRE_SLOW) + +#define WEAK_PULLDOWN (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_DOWN | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ + PAD_CTL_SRE_SLOW) + +#define OUTPUT_40OHM (PAD_CTL_SPEED_MED|PAD_CTL_DSE_40ohm) + +int dram_init(void) +{ + gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE); + + return 0; +} + +iomux_v3_cfg_t const uart1_pads[] = { + MX6PAD(SD3_DAT6__UART1_RXD) | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6PAD(SD3_DAT7__UART1_TXD) | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +iomux_v3_cfg_t const uart2_pads[] = { + MX6PAD(EIM_D26__UART2_TXD) | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6PAD(EIM_D27__UART2_RXD) | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +#define PC MUX_PAD_CTRL(I2C_PAD_CTRL) + +/* I2C1, SGTL5000 */ +struct i2c_pads_info i2c_pad_info0 = { + .scl = { + .i2c_mode = MX6PAD(EIM_D21__I2C1_SCL) | PC, + .gpio_mode = MX6PAD(EIM_D21__GPIO_3_21) | PC, + .gp = IMX_GPIO_NR(3, 21) + }, + .sda = { + .i2c_mode = MX6PAD(EIM_D28__I2C1_SDA) | PC, + .gpio_mode = MX6PAD(EIM_D28__GPIO_3_28) | PC, + .gp = IMX_GPIO_NR(3, 28) + } +}; + +/* I2C2 Camera, MIPI */ +struct i2c_pads_info i2c_pad_info1 = { + .scl = { + .i2c_mode = MX6PAD(KEY_COL3__I2C2_SCL) | PC, + .gpio_mode = MX6PAD(KEY_COL3__GPIO_4_12) | PC, + .gp = IMX_GPIO_NR(4, 12) + }, + .sda = { + .i2c_mode = MX6PAD(KEY_ROW3__I2C2_SDA) | PC, + .gpio_mode = MX6PAD(KEY_ROW3__GPIO_4_13) | PC, + .gp = IMX_GPIO_NR(4, 13) + } +}; + +/* I2C3, J15 - RGB connector */ +struct i2c_pads_info i2c_pad_info2 = { + .scl = { + .i2c_mode = MX6PAD(GPIO_5__I2C3_SCL) | PC, + .gpio_mode = MX6PAD(GPIO_5__GPIO_1_5) | PC, + .gp = IMX_GPIO_NR(1, 5) + }, + .sda = { + .i2c_mode = MX6PAD(GPIO_16__I2C3_SDA) | PC, + .gpio_mode = MX6PAD(GPIO_16__GPIO_7_11) | PC, + .gp = IMX_GPIO_NR(7, 11) + } +}; + +iomux_v3_cfg_t const usdhc3_pads[] = { + MX6PAD(SD3_CLK__USDHC3_CLK) | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6PAD(SD3_CMD__USDHC3_CMD) | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6PAD(SD3_DAT0__USDHC3_DAT0) | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6PAD(SD3_DAT1__USDHC3_DAT1) | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6PAD(SD3_DAT2__USDHC3_DAT2) | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6PAD(SD3_DAT3__USDHC3_DAT3) | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6PAD(SD3_DAT5__GPIO_7_0) | MUX_PAD_CTRL(NO_PAD_CTRL), /* CD */ +}; + +iomux_v3_cfg_t const usdhc4_pads[] = { + MX6PAD(SD4_CLK__USDHC4_CLK) | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6PAD(SD4_CMD__USDHC4_CMD) | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6PAD(SD4_DAT0__USDHC4_DAT0) | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6PAD(SD4_DAT1__USDHC4_DAT1) | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6PAD(SD4_DAT2__USDHC4_DAT2) | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6PAD(SD4_DAT3__USDHC4_DAT3) | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6PAD(NANDF_D6__GPIO_2_6) | MUX_PAD_CTRL(NO_PAD_CTRL), /* CD */ +}; + +iomux_v3_cfg_t const enet_pads1[] = { + MX6PAD(ENET_MDIO__ENET_MDIO) | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6PAD(ENET_MDC__ENET_MDC) | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6PAD(RGMII_TXC__ENET_RGMII_TXC) | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6PAD(RGMII_TD0__ENET_RGMII_TD0) | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6PAD(RGMII_TD1__ENET_RGMII_TD1) | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6PAD(RGMII_TD2__ENET_RGMII_TD2) | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6PAD(RGMII_TD3__ENET_RGMII_TD3) | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6PAD(RGMII_TX_CTL__RGMII_TX_CTL) | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6PAD(ENET_REF_CLK__ENET_TX_CLK) | MUX_PAD_CTRL(ENET_PAD_CTRL), + /* pin 35 - 1 (PHY_AD2) on reset */ + MX6PAD(RGMII_RXC__GPIO_6_30) | MUX_PAD_CTRL(NO_PAD_CTRL), + /* pin 32 - 1 - (MODE0) all */ + MX6PAD(RGMII_RD0__GPIO_6_25) | MUX_PAD_CTRL(NO_PAD_CTRL), + /* pin 31 - 1 - (MODE1) all */ + MX6PAD(RGMII_RD1__GPIO_6_27) | MUX_PAD_CTRL(NO_PAD_CTRL), + /* pin 28 - 1 - (MODE2) all */ + MX6PAD(RGMII_RD2__GPIO_6_28) | MUX_PAD_CTRL(NO_PAD_CTRL), + /* pin 27 - 1 - (MODE3) all */ + MX6PAD(RGMII_RD3__GPIO_6_29) | MUX_PAD_CTRL(NO_PAD_CTRL), + /* pin 33 - 1 - (CLK125_EN) 125Mhz clockout enabled */ + MX6PAD(RGMII_RX_CTL__GPIO_6_24) | MUX_PAD_CTRL(NO_PAD_CTRL), + /* pin 42 PHY nRST */ + MX6PAD(EIM_D23__GPIO_3_23) | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6PAD(ENET_RXD0__GPIO_1_27) | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +iomux_v3_cfg_t const enet_pads2[] = { + MX6PAD(RGMII_RXC__ENET_RGMII_RXC) | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6PAD(RGMII_RD0__ENET_RGMII_RD0) | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6PAD(RGMII_RD1__ENET_RGMII_RD1) | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6PAD(RGMII_RD2__ENET_RGMII_RD2) | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6PAD(RGMII_RD3__ENET_RGMII_RD3) | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6PAD(RGMII_RX_CTL__RGMII_RX_CTL) | MUX_PAD_CTRL(ENET_PAD_CTRL), +}; + +/* wl1271 pads on nitrogen6x */ +iomux_v3_cfg_t const wl12xx_pads[] = { + (MX6PAD(NANDF_CS1__GPIO_6_14) & ~MUX_PAD_CTRL_MASK) + | MUX_PAD_CTRL(WEAK_PULLDOWN), + (MX6PAD(NANDF_CS2__GPIO_6_15) & ~MUX_PAD_CTRL_MASK) + | MUX_PAD_CTRL(OUTPUT_40OHM), + (MX6PAD(NANDF_CS3__GPIO_6_16) & ~MUX_PAD_CTRL_MASK) + | MUX_PAD_CTRL(OUTPUT_40OHM), +}; +#define WL12XX_WL_IRQ_GP IMX_GPIO_NR(6, 14) +#define WL12XX_WL_ENABLE_GP IMX_GPIO_NR(6, 15) +#define WL12XX_BT_ENABLE_GP IMX_GPIO_NR(6, 16) + +/* Button assignments for J14 */ +static iomux_v3_cfg_t const button_pads[] = { + /* Menu */ + MX6PAD(NANDF_D1__GPIO_2_1) | MUX_PAD_CTRL(BUTTON_PAD_CTRL), + /* Back */ + MX6PAD(NANDF_D2__GPIO_2_2) | MUX_PAD_CTRL(BUTTON_PAD_CTRL), + /* Labelled Search (mapped to Power under Android) */ + MX6PAD(NANDF_D3__GPIO_2_3) | MUX_PAD_CTRL(BUTTON_PAD_CTRL), + /* Home */ + MX6PAD(NANDF_D4__GPIO_2_4) | MUX_PAD_CTRL(BUTTON_PAD_CTRL), + /* Volume Down */ + MX6PAD(GPIO_19__GPIO_4_5) | MUX_PAD_CTRL(BUTTON_PAD_CTRL), + /* Volume Up */ + MX6PAD(GPIO_18__GPIO_7_13) | MUX_PAD_CTRL(BUTTON_PAD_CTRL), +}; + +static void setup_iomux_enet(void) +{ + gpio_direction_output(IMX_GPIO_NR(3, 23), 0); /* SABRE Lite PHY rst */ + gpio_direction_output(IMX_GPIO_NR(1, 27), 0); /* Nitrogen6X PHY rst */ + gpio_direction_output(IMX_GPIO_NR(6, 30), 1); + gpio_direction_output(IMX_GPIO_NR(6, 25), 1); + gpio_direction_output(IMX_GPIO_NR(6, 27), 1); + gpio_direction_output(IMX_GPIO_NR(6, 28), 1); + gpio_direction_output(IMX_GPIO_NR(6, 29), 1); + imx_iomux_v3_setup_multiple_pads(enet_pads1, ARRAY_SIZE(enet_pads1)); + gpio_direction_output(IMX_GPIO_NR(6, 24), 1); + + /* Need delay 10ms according to KSZ9021 spec */ + udelay(1000 * 10); + gpio_set_value(IMX_GPIO_NR(3, 23), 1); /* SABRE Lite PHY reset */ + gpio_set_value(IMX_GPIO_NR(1, 27), 1); /* Nitrogen6X PHY reset */ + + imx_iomux_v3_setup_multiple_pads(enet_pads2, ARRAY_SIZE(enet_pads2)); +} + +iomux_v3_cfg_t const usb_pads[] = { + MX6PAD(GPIO_17__GPIO_7_12) | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static void setup_iomux_uart(void) +{ + imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); + imx_iomux_v3_setup_multiple_pads(uart2_pads, ARRAY_SIZE(uart2_pads)); +} + +#ifdef CONFIG_USB_EHCI_MX6 +int board_ehci_hcd_init(int port) +{ + imx_iomux_v3_setup_multiple_pads(usb_pads, ARRAY_SIZE(usb_pads)); + + /* Reset USB hub */ + gpio_direction_output(IMX_GPIO_NR(7, 12), 0); + mdelay(2); + gpio_set_value(IMX_GPIO_NR(7, 12), 1); + + return 0; +} +#endif + +#ifdef CONFIG_FSL_ESDHC +struct fsl_esdhc_cfg usdhc_cfg[2] = { + {USDHC3_BASE_ADDR}, + {USDHC4_BASE_ADDR}, +}; + +int board_mmc_getcd(struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + int ret; + + if (cfg->esdhc_base == USDHC3_BASE_ADDR) { + gpio_direction_input(IMX_GPIO_NR(7, 0)); + ret = !gpio_get_value(IMX_GPIO_NR(7, 0)); + } else { + gpio_direction_input(IMX_GPIO_NR(2, 6)); + ret = !gpio_get_value(IMX_GPIO_NR(2, 6)); + } + + return ret; +} + +int board_mmc_init(bd_t *bis) +{ + s32 status = 0; + u32 index = 0; + + usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); + usdhc_cfg[1].sdhc_clk = mxc_get_clock(MXC_ESDHC4_CLK); + + for (index = 0; index < CONFIG_SYS_FSL_USDHC_NUM; ++index) { + switch (index) { + case 0: + imx_iomux_v3_setup_multiple_pads( + usdhc3_pads, ARRAY_SIZE(usdhc3_pads)); + break; + case 1: + imx_iomux_v3_setup_multiple_pads( + usdhc4_pads, ARRAY_SIZE(usdhc4_pads)); + break; + default: + printf("Warning: you configured more USDHC controllers" + "(%d) then supported by the board (%d)\n", + index + 1, CONFIG_SYS_FSL_USDHC_NUM); + return status; + } + + status |= fsl_esdhc_initialize(bis, &usdhc_cfg[index]); + } + + return status; +} +#endif + +u32 get_board_rev(void) +{ + return 0x63000; +} + +#ifdef CONFIG_MXC_SPI +iomux_v3_cfg_t const ecspi1_pads[] = { + /* SS1 */ + MX6PAD(EIM_D19__GPIO_3_19) | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6PAD(EIM_D17__ECSPI1_MISO) | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6PAD(EIM_D18__ECSPI1_MOSI) | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6PAD(EIM_D16__ECSPI1_SCLK) | MUX_PAD_CTRL(SPI_PAD_CTRL), +}; + +void setup_spi(void) +{ + gpio_direction_output(CONFIG_SF_DEFAULT_CS, 1); + imx_iomux_v3_setup_multiple_pads(ecspi1_pads, + ARRAY_SIZE(ecspi1_pads)); +} +#endif + +int board_phy_config(struct phy_device *phydev) +{ + /* min rx data delay */ + ksz9021_phy_extended_write(phydev, + MII_KSZ9021_EXT_RGMII_RX_DATA_SKEW, 0x0); + /* min tx data delay */ + ksz9021_phy_extended_write(phydev, + MII_KSZ9021_EXT_RGMII_TX_DATA_SKEW, 0x0); + /* max rx/tx clock delay, min rx/tx control */ + ksz9021_phy_extended_write(phydev, + MII_KSZ9021_EXT_RGMII_CLOCK_SKEW, 0xf0f0); + if (phydev->drv->config) + phydev->drv->config(phydev); + + return 0; +} + +int board_eth_init(bd_t *bis) +{ + int ret; + + setup_iomux_enet(); + + ret = cpu_eth_init(bis); + if (ret) + printf("FEC MXC: %s:failed\n", __func__); + + return 0; +} + +static void setup_buttons(void) +{ + imx_iomux_v3_setup_multiple_pads(button_pads, + ARRAY_SIZE(button_pads)); +} + +#ifdef CONFIG_CMD_SATA + +int setup_sata(void) +{ + struct iomuxc_base_regs *const iomuxc_regs + = (struct iomuxc_base_regs *) IOMUXC_BASE_ADDR; + int ret = enable_sata_clock(); + if (ret) + return ret; + + clrsetbits_le32(&iomuxc_regs->gpr[13], + IOMUXC_GPR13_SATA_MASK, + IOMUXC_GPR13_SATA_PHY_8_RXEQ_3P0DB + |IOMUXC_GPR13_SATA_PHY_7_SATA2M + |IOMUXC_GPR13_SATA_SPEED_3G + |(3<<IOMUXC_GPR13_SATA_PHY_6_SHIFT) + |IOMUXC_GPR13_SATA_SATA_PHY_5_SS_DISABLED + |IOMUXC_GPR13_SATA_SATA_PHY_4_ATTEN_9_16 + |IOMUXC_GPR13_SATA_PHY_3_TXBOOST_0P00_DB + |IOMUXC_GPR13_SATA_PHY_2_TX_1P104V + |IOMUXC_GPR13_SATA_PHY_1_SLOW); + + return 0; +} +#endif + +#if defined(CONFIG_VIDEO_IPUV3) + +static iomux_v3_cfg_t const backlight_pads[] = { + /* Backlight on RGB connector: J15 */ + MX6PAD(SD1_DAT3__GPIO_1_21) | MUX_PAD_CTRL(NO_PAD_CTRL), +#define RGB_BACKLIGHT_GP IMX_GPIO_NR(1, 21) + + /* Backlight on LVDS connector: J6 */ + MX6PAD(SD1_CMD__GPIO_1_18) | MUX_PAD_CTRL(NO_PAD_CTRL), +#define LVDS_BACKLIGHT_GP IMX_GPIO_NR(1, 18) +}; + +static iomux_v3_cfg_t const rgb_pads[] = { + MX6PAD(DI0_DISP_CLK__IPU1_DI0_DISP_CLK), + MX6PAD(DI0_PIN15__IPU1_DI0_PIN15), + MX6PAD(DI0_PIN2__IPU1_DI0_PIN2), + MX6PAD(DI0_PIN3__IPU1_DI0_PIN3), + MX6PAD(DI0_PIN4__GPIO_4_20), + MX6PAD(DISP0_DAT0__IPU1_DISP0_DAT_0), + MX6PAD(DISP0_DAT1__IPU1_DISP0_DAT_1), + MX6PAD(DISP0_DAT2__IPU1_DISP0_DAT_2), + MX6PAD(DISP0_DAT3__IPU1_DISP0_DAT_3), + MX6PAD(DISP0_DAT4__IPU1_DISP0_DAT_4), + MX6PAD(DISP0_DAT5__IPU1_DISP0_DAT_5), + MX6PAD(DISP0_DAT6__IPU1_DISP0_DAT_6), + MX6PAD(DISP0_DAT7__IPU1_DISP0_DAT_7), + MX6PAD(DISP0_DAT8__IPU1_DISP0_DAT_8), + MX6PAD(DISP0_DAT9__IPU1_DISP0_DAT_9), + MX6PAD(DISP0_DAT10__IPU1_DISP0_DAT_10), + MX6PAD(DISP0_DAT11__IPU1_DISP0_DAT_11), + MX6PAD(DISP0_DAT12__IPU1_DISP0_DAT_12), + MX6PAD(DISP0_DAT13__IPU1_DISP0_DAT_13), + MX6PAD(DISP0_DAT14__IPU1_DISP0_DAT_14), + MX6PAD(DISP0_DAT15__IPU1_DISP0_DAT_15), + MX6PAD(DISP0_DAT16__IPU1_DISP0_DAT_16), + MX6PAD(DISP0_DAT17__IPU1_DISP0_DAT_17), + MX6PAD(DISP0_DAT18__IPU1_DISP0_DAT_18), + MX6PAD(DISP0_DAT19__IPU1_DISP0_DAT_19), + MX6PAD(DISP0_DAT20__IPU1_DISP0_DAT_20), + MX6PAD(DISP0_DAT21__IPU1_DISP0_DAT_21), + MX6PAD(DISP0_DAT22__IPU1_DISP0_DAT_22), + MX6PAD(DISP0_DAT23__IPU1_DISP0_DAT_23), +}; + +struct display_info_t { + int bus; + int addr; + int pixfmt; + int (*detect)(struct display_info_t const *dev); + void (*enable)(struct display_info_t const *dev); + struct fb_videomode mode; +}; + + +static int detect_hdmi(struct display_info_t const *dev) +{ + return __raw_readb(HDMI_ARB_BASE_ADDR+HDMI_PHY_STAT0) & HDMI_PHY_HPD; +} + +static void enable_hdmi(struct display_info_t const *dev) +{ + u8 reg; + printf("%s: setup HDMI monitor\n", __func__); + reg = __raw_readb( + HDMI_ARB_BASE_ADDR + +HDMI_PHY_CONF0); + reg |= HDMI_PHY_CONF0_PDZ_MASK; + __raw_writeb(reg, + HDMI_ARB_BASE_ADDR + +HDMI_PHY_CONF0); + udelay(3000); + reg |= HDMI_PHY_CONF0_ENTMDS_MASK; + __raw_writeb(reg, + HDMI_ARB_BASE_ADDR + +HDMI_PHY_CONF0); + udelay(3000); + reg |= HDMI_PHY_CONF0_GEN2_TXPWRON_MASK; + __raw_writeb(reg, + HDMI_ARB_BASE_ADDR + +HDMI_PHY_CONF0); + __raw_writeb(HDMI_MC_PHYRSTZ_ASSERT, + HDMI_ARB_BASE_ADDR+HDMI_MC_PHYRSTZ); +} + +static int detect_i2c(struct display_info_t const *dev) +{ + return ((0 == i2c_set_bus_num(dev->bus)) + && + (0 == i2c_probe(dev->addr))); +} + +static void enable_lvds(struct display_info_t const *dev) +{ + struct iomuxc *iomux = (struct iomuxc *) + IOMUXC_BASE_ADDR; + u32 reg = readl(&iomux->gpr[2]); + reg |= IOMUXC_GPR2_DATA_WIDTH_CH0_24BIT; + writel(reg, &iomux->gpr[2]); + gpio_direction_output(LVDS_BACKLIGHT_GP, 1); +} + +static void enable_rgb(struct display_info_t const *dev) +{ + imx_iomux_v3_setup_multiple_pads( + rgb_pads, + ARRAY_SIZE(rgb_pads)); + gpio_direction_output(RGB_BACKLIGHT_GP, 1); +} + +static struct display_info_t const displays[] = {{ + .bus = -1, + .addr = 0, + .pixfmt = IPU_PIX_FMT_RGB24, + .detect = detect_hdmi, + .enable = enable_hdmi, + .mode = { + .name = "HDMI", + .refresh = 60, + .xres = 1024, + .yres = 768, + .pixclock = 15385, + .left_margin = 220, + .right_margin = 40, + .upper_margin = 21, + .lower_margin = 7, + .hsync_len = 60, + .vsync_len = 10, + .sync = FB_SYNC_EXT, + .vmode = FB_VMODE_NONINTERLACED +} }, { + .bus = 2, + .addr = 0x4, + .pixfmt = IPU_PIX_FMT_LVDS666, + .detect = detect_i2c, + .enable = enable_lvds, + .mode = { + .name = "Hannstar-XGA", + .refresh = 60, + .xres = 1024, + .yres = 768, + .pixclock = 15385, + .left_margin = 220, + .right_margin = 40, + .upper_margin = 21, + .lower_margin = 7, + .hsync_len = 60, + .vsync_len = 10, + .sync = FB_SYNC_EXT, + .vmode = FB_VMODE_NONINTERLACED +} }, { + .bus = 2, + .addr = 0x38, + .pixfmt = IPU_PIX_FMT_LVDS666, + .detect = detect_i2c, + .enable = enable_lvds, + .mode = { + .name = "wsvga-lvds", + .refresh = 60, + .xres = 1024, + .yres = 600, + .pixclock = 15385, + .left_margin = 220, + .right_margin = 40, + .upper_margin = 21, + .lower_margin = 7, + .hsync_len = 60, + .vsync_len = 10, + .sync = FB_SYNC_EXT, + .vmode = FB_VMODE_NONINTERLACED +} }, { + .bus = 2, + .addr = 0x48, + .pixfmt = IPU_PIX_FMT_RGB666, + .detect = detect_i2c, + .enable = enable_rgb, + .mode = { + .name = "wvga-rgb", + .refresh = 57, + .xres = 800, + .yres = 480, + .pixclock = 37037, + .left_margin = 40, + .right_margin = 60, + .upper_margin = 10, + .lower_margin = 10, + .hsync_len = 20, + .vsync_len = 10, + .sync = 0, + .vmode = FB_VMODE_NONINTERLACED +} } }; + +int board_video_skip(void) +{ + int i; + int ret; + char const *panel = getenv("panel"); + if (!panel) { + for (i = 0; i < ARRAY_SIZE(displays); i++) { + struct display_info_t const *dev = displays+i; + if (dev->detect(dev)) { + panel = dev->mode.name; + printf("auto-detected panel %s\n", panel); + break; + } + } + if (!panel) { + panel = displays[0].mode.name; + printf("No panel detected: default to %s\n", panel); + } + } else { + for (i = 0; i < ARRAY_SIZE(displays); i++) { + if (!strcmp(panel, displays[i].mode.name)) + break; + } + } + if (i < ARRAY_SIZE(displays)) { + ret = ipuv3_fb_init(&displays[i].mode, 0, + displays[i].pixfmt); + if (!ret) { + displays[i].enable(displays+i); + printf("Display: %s (%ux%u)\n", + displays[i].mode.name, + displays[i].mode.xres, + displays[i].mode.yres); + } else + printf("LCD %s cannot be configured: %d\n", + displays[i].mode.name, ret); + } else { + printf("unsupported panel %s\n", panel); + ret = -EINVAL; + } + return (0 != ret); +} + +static void setup_display(void) +{ + struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + struct anatop_regs *anatop = (struct anatop_regs *)ANATOP_BASE_ADDR; + struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; + + int reg; + + /* Turn on LDB0,IPU,IPU DI0 clocks */ + reg = __raw_readl(&mxc_ccm->CCGR3); + reg |= MXC_CCM_CCGR3_IPU1_IPU_DI0_OFFSET + |MXC_CCM_CCGR3_LDB_DI0_MASK; + writel(reg, &mxc_ccm->CCGR3); + + /* Turn on HDMI PHY clock */ + reg = __raw_readl(&mxc_ccm->CCGR2); + reg |= MXC_CCM_CCGR2_HDMI_TX_IAHBCLK_MASK + |MXC_CCM_CCGR2_HDMI_TX_ISFRCLK_MASK; + writel(reg, &mxc_ccm->CCGR2); + + /* clear HDMI PHY reset */ + __raw_writeb(HDMI_MC_PHYRSTZ_DEASSERT, + HDMI_ARB_BASE_ADDR+HDMI_MC_PHYRSTZ); + + /* set PFD1_FRAC to 0x13 == 455 MHz (480*18)/0x13 */ + writel(ANATOP_PFD_480_PFD1_FRAC_MASK, &anatop->pfd_480_clr); + writel(0x13<<ANATOP_PFD_480_PFD1_FRAC_SHIFT, &anatop->pfd_480_set); + + /* set LDB0, LDB1 clk select to 011/011 */ + reg = readl(&mxc_ccm->cs2cdr); + reg &= ~(MXC_CCM_CS2CDR_LDB_DI0_CLK_SEL_MASK + |MXC_CCM_CS2CDR_LDB_DI1_CLK_SEL_MASK); + reg |= (3<<MXC_CCM_CS2CDR_LDB_DI0_CLK_SEL_OFFSET) + |(3<<MXC_CCM_CS2CDR_LDB_DI1_CLK_SEL_OFFSET); + writel(reg, &mxc_ccm->cs2cdr); + + reg = readl(&mxc_ccm->cscmr2); + reg |= MXC_CCM_CSCMR2_LDB_DI0_IPU_DIV; + writel(reg, &mxc_ccm->cscmr2); + + reg = readl(&mxc_ccm->chsccdr); + reg &= ~(MXC_CCM_CHSCCDR_IPU1_DI0_PRE_CLK_SEL_MASK + |MXC_CCM_CHSCCDR_IPU1_DI0_PODF_MASK + |MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_MASK); + reg |= (CHSCCDR_CLK_SEL_LDB_DI0 + <<MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_OFFSET) + |(CHSCCDR_PODF_DIVIDE_BY_3 + <<MXC_CCM_CHSCCDR_IPU1_DI0_PODF_OFFSET) + |(CHSCCDR_IPU_PRE_CLK_540M_PFD + <<MXC_CCM_CHSCCDR_IPU1_DI0_PRE_CLK_SEL_OFFSET); + writel(reg, &mxc_ccm->chsccdr); + + reg = IOMUXC_GPR2_BGREF_RRMODE_EXTERNAL_RES + |IOMUXC_GPR2_DI1_VS_POLARITY_ACTIVE_HIGH + |IOMUXC_GPR2_DI0_VS_POLARITY_ACTIVE_LOW + |IOMUXC_GPR2_BIT_MAPPING_CH1_SPWG + |IOMUXC_GPR2_DATA_WIDTH_CH1_18BIT + |IOMUXC_GPR2_BIT_MAPPING_CH0_SPWG + |IOMUXC_GPR2_DATA_WIDTH_CH0_18BIT + |IOMUXC_GPR2_LVDS_CH1_MODE_DISABLED + |IOMUXC_GPR2_LVDS_CH0_MODE_ENABLED_DI0; + writel(reg, &iomux->gpr[2]); + + reg = readl(&iomux->gpr[3]); + reg = (reg & ~IOMUXC_GPR3_LVDS0_MUX_CTL_MASK) + | (IOMUXC_GPR3_MUX_SRC_IPU1_DI0 + <<IOMUXC_GPR3_LVDS0_MUX_CTL_OFFSET); + writel(reg, &iomux->gpr[3]); + + /* backlights off until needed */ + imx_iomux_v3_setup_multiple_pads(backlight_pads, + ARRAY_SIZE(backlight_pads)); + gpio_direction_input(LVDS_BACKLIGHT_GP); + gpio_direction_input(RGB_BACKLIGHT_GP); +} +#endif + +int board_early_init_f(void) +{ + setup_iomux_uart(); + + /* Disable wl1271 For Nitrogen6w */ + gpio_direction_input(WL12XX_WL_IRQ_GP); + gpio_direction_output(WL12XX_WL_ENABLE_GP, 0); + gpio_direction_output(WL12XX_BT_ENABLE_GP, 0); + + imx_iomux_v3_setup_multiple_pads(wl12xx_pads, ARRAY_SIZE(wl12xx_pads)); + setup_buttons(); + +#if defined(CONFIG_VIDEO_IPUV3) + setup_display(); +#endif + return 0; +} + +/* + * Do not overwrite the console + * Use always serial for U-Boot console + */ +int overwrite_console(void) +{ + return 1; +} + +int board_init(void) +{ + /* address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + +#ifdef CONFIG_MXC_SPI + setup_spi(); +#endif + setup_i2c(0, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info0); + setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info1); + setup_i2c(2, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info2); + +#ifdef CONFIG_CMD_SATA + setup_sata(); +#endif + + return 0; +} + +int checkboard(void) +{ + if (gpio_get_value(WL12XX_WL_IRQ_GP)) + puts("Board: Nitrogen6X\n"); + else + puts("Board: SABRE Lite\n"); + + return 0; +} + +struct button_key { + char const *name; + unsigned gpnum; + char ident; +}; + +static struct button_key const buttons[] = { + {"back", IMX_GPIO_NR(2, 2), 'B'}, + {"home", IMX_GPIO_NR(2, 4), 'H'}, + {"menu", IMX_GPIO_NR(2, 1), 'M'}, + {"search", IMX_GPIO_NR(2, 3), 'S'}, + {"volup", IMX_GPIO_NR(7, 13), 'V'}, + {"voldown", IMX_GPIO_NR(4, 5), 'v'}, +}; + +/* + * generate a null-terminated string containing the buttons pressed + * returns number of keys pressed + */ +static int read_keys(char *buf) +{ + int i, numpressed = 0; + for (i = 0; i < ARRAY_SIZE(buttons); i++) { + if (!gpio_get_value(buttons[i].gpnum)) + buf[numpressed++] = buttons[i].ident; + } + buf[numpressed] = '\0'; + return numpressed; +} + +static int do_kbd(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + char envvalue[ARRAY_SIZE(buttons)+1]; + int numpressed = read_keys(envvalue); + setenv("keybd", envvalue); + return numpressed == 0; +} + +U_BOOT_CMD( + kbd, 1, 1, do_kbd, + "Tests for keypresses, sets 'keybd' environment variable", + "Returns 0 (true) to shell if key is pressed." +); + +#ifdef CONFIG_PREBOOT +static char const kbd_magic_prefix[] = "key_magic"; +static char const kbd_command_prefix[] = "key_cmd"; + +static void preboot_keys(void) +{ + int numpressed; + char keypress[ARRAY_SIZE(buttons)+1]; + numpressed = read_keys(keypress); + if (numpressed) { + char *kbd_magic_keys = getenv("magic_keys"); + char *suffix; + /* + * loop over all magic keys + */ + for (suffix = kbd_magic_keys; *suffix; ++suffix) { + char *keys; + char magic[sizeof(kbd_magic_prefix) + 1]; + sprintf(magic, "%s%c", kbd_magic_prefix, *suffix); + keys = getenv(magic); + if (keys) { + if (!strcmp(keys, keypress)) + break; + } + } + if (*suffix) { + char cmd_name[sizeof(kbd_command_prefix) + 1]; + char *cmd; + sprintf(cmd_name, "%s%c", kbd_command_prefix, *suffix); + cmd = getenv(cmd_name); + if (cmd) { + setenv("preboot", cmd); + return; + } + } + } +} +#endif + +#ifdef CONFIG_CMD_BMODE +static const struct boot_mode board_boot_modes[] = { + /* 4 bit bus width */ + {"mmc0", MAKE_CFGVAL(0x40, 0x30, 0x00, 0x00)}, + {"mmc1", MAKE_CFGVAL(0x40, 0x38, 0x00, 0x00)}, + {NULL, 0}, +}; +#endif + +int misc_init_r(void) +{ +#ifdef CONFIG_PREBOOT + preboot_keys(); +#endif + +#ifdef CONFIG_CMD_BMODE + add_board_boot_modes(board_boot_modes); +#endif + return 0; +} diff --git a/boards.cfg b/boards.cfg index 7d03620..d778f63 100644 --- a/boards.cfg +++ b/boards.cfg @@ -252,6 +252,12 @@ mx6qarm2 arm armv7 mx6qarm2 freesca mx6qsabreauto arm armv7 mx6qsabreauto freescale mx6 mx6qsabreauto:IMX_CONFIG=board/freescale/mx6qsabreauto/imximage.cfg mx6qsabrelite arm armv7 mx6qsabrelite freescale mx6 mx6qsabrelite:IMX_CONFIG=board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg mx6qsabresd arm armv7 mx6qsabresd freescale mx6 mx6qsabresd:IMX_CONFIG=board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg +nitrogen6q arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q +nitrogen6dl arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL +nitrogen6s arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s.cfg,MX6S +nitrogen6q2g arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q2g.cfg,MX6Q +nitrogen6dl2g arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl2g.cfg,MX6DL +nitrogen6s1g arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg,MX6S eco5pk arm armv7 eco5pk 8dtech omap3 cm_t35 arm armv7 cm_t35 - omap3 omap3_overo arm armv7 overo - omap3 diff --git a/drivers/usb/host/ehci-mx6.c b/drivers/usb/host/ehci-mx6.c index 1b20e41..c1ae3d9 100644 --- a/drivers/usb/host/ehci-mx6.c +++ b/drivers/usb/host/ehci-mx6.c @@ -21,7 +21,6 @@ #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/arch/clock.h> -#include <asm/arch/mx6x_pins.h> #include <asm/imx-common/iomux-v3.h>
#include "ehci.h" diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h new file mode 100644 index 0000000..ef6089a --- /dev/null +++ b/include/configs/nitrogen6x.h @@ -0,0 +1,284 @@ +/* + * Copyright (C) 2010-2011 Freescale Semiconductor, Inc. + * + * Configuration settings for the Boundary Devices Nitrogen6X + * and Freescale i.MX6Q Sabre Lite boards. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#define CONFIG_MX6 +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +#define CONFIG_MACH_TYPE 3769 + +#include <asm/arch/imx-regs.h> +#include <asm/imx-common/gpio.h> + +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_REVISION_TAG + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (10 * 1024 * 1024) + +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_MISC_INIT_R +#define CONFIG_MXC_GPIO + +#define CONFIG_MXC_UART +#define CONFIG_MXC_UART_BASE UART2_BASE + +#define CONFIG_CMD_SF +#ifdef CONFIG_CMD_SF +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_SST +#define CONFIG_MXC_SPI +#define CONFIG_SF_DEFAULT_BUS 0 +#define CONFIG_SF_DEFAULT_CS (0|(IMX_GPIO_NR(3, 19)<<8)) +#define CONFIG_SF_DEFAULT_SPEED 25000000 +#define CONFIG_SF_DEFAULT_MODE (SPI_MODE_0) +#endif + +/* I2C Configs */ +#define CONFIG_CMD_I2C +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_I2C_MXC +#define CONFIG_SYS_I2C_SPEED 100000 + +/* OCOTP Configs */ +#define CONFIG_CMD_IMXOTP +#ifdef CONFIG_CMD_IMXOTP +#define CONFIG_IMX_OTP +#define IMX_OTP_BASE OCOTP_BASE_ADDR +#define IMX_OTP_ADDR_MAX 0x7F +#define IMX_OTP_DATA_ERROR_VAL 0xBADABADA +/* #define IMX_OTPWRITE_ENABLED */ +#endif + +/* MMC Configs */ +#define CONFIG_FSL_ESDHC +#define CONFIG_FSL_USDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 +#define CONFIG_SYS_FSL_USDHC_NUM 2 + +#define CONFIG_MMC +#define CONFIG_CMD_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_BOUNCE_BUFFER +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION + +#ifdef CONFIG_MX6Q +#define CONFIG_CMD_SATA +#endif + +/* + * SATA Configs + */ +#ifdef CONFIG_CMD_SATA +#define CONFIG_DWC_AHSATA +#define CONFIG_SYS_SATA_MAX_DEVICE 1 +#define CONFIG_DWC_AHSATA_PORT_ID 0 +#define CONFIG_DWC_AHSATA_BASE_ADDR SATA_ARB_BASE_ADDR +#define CONFIG_LBA48 +#define CONFIG_LIBATA +#endif + +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_MII +#define CONFIG_CMD_NET +#define CONFIG_FEC_MXC +#define CONFIG_MII +#define IMX_FEC_BASE ENET_BASE_ADDR +#define CONFIG_FEC_XCV_TYPE RGMII +#define CONFIG_ETHPRIME "FEC" +#define CONFIG_FEC_MXC_PHYADDR 6 +#define CONFIG_PHYLIB +#define CONFIG_PHY_MICREL +#define CONFIG_PHY_MICREL_KSZ9021 + +/* USB Configs */ +#define CONFIG_CMD_USB +#define CONFIG_CMD_FAT +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_MX6 +#define CONFIG_USB_STORAGE +#define CONFIG_USB_HOST_ETHER +#define CONFIG_USB_ETHER_ASIX +#define CONFIG_USB_ETHER_SMSC95XX +#define CONFIG_MXC_USB_PORT 1 +#define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) +#define CONFIG_MXC_USB_FLAGS 0 + +/* Miscellaneous commands */ +#define CONFIG_CMD_BMODE +#define CONFIG_CMD_SETEXPR + +/* Framebuffer and LCD */ +#define CONFIG_VIDEO +#define CONFIG_VIDEO_IPUV3 +#define CONFIG_CFB_CONSOLE +#define CONFIG_VGA_AS_SINGLE_DEVICE +#define CONFIG_SYS_CONSOLE_IS_IN_ENV +#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE +#define CONFIG_VIDEO_BMP_RLE8 +#define CONFIG_SPLASH_SCREEN +#define CONFIG_BMP_16BPP +#define CONFIG_VIDEO_LOGO +#define CONFIG_IPUV3_CLK 260000000 +#define CONFIG_CMD_HDMIDETECT +#define CONFIG_CONSOLE_MUX + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_CONS_INDEX 1 +#define CONFIG_BAUDRATE 115200 + +/* Command definition */ +#include <config_cmd_default.h> + +#undef CONFIG_CMD_IMLS + +#define CONFIG_BOOTDELAY 1 + +#define CONFIG_PREBOOT "" + +#define CONFIG_LOADADDR 0x12000000 +#define CONFIG_SYS_TEXT_BASE 0x17800000 + +#ifdef CONFIG_CMD_SATA +#define CONFIG_DRIVE_SATA "sata " +#else +#define CONFIG_DRIVE_SATA +#endif + +#ifdef CONFIG_CMD_MMC +#define CONFIG_DRIVE_MMC "mmc " +#else +#define CONFIG_DRIVE_MMC +#endif + +#define CONFIG_DRIVE_TYPES CONFIG_DRIVE_SATA CONFIG_DRIVE_MMC + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "console=ttymxc1\0" \ + "clearenv=if sf probe || sf probe || sf probe 1 ; then " \ + "sf erase 0xc0000 0x2000 && " \ + "echo restored environment to factory default ; fi\0" \ + "bootcmd=for dtype in " CONFIG_DRIVE_TYPES \ + "; do " \ + "for disk in 0 1 ; do ${dtype} dev ${disk} ;" \ + "for fs in fat ext2 ; do " \ + "${fs}load " \ + "${dtype} ${disk}:1 " \ + "10008000 " \ + "/6x_bootscript" \ + "&& source 10008000 ; " \ + "done ; " \ + "done ; " \ + "done; " \ + "setenv stdout serial,vga ; " \ + "echo ; echo 6x_bootscript not found ; " \ + "echo ; echo serial console at 115200, 8N1 ; echo ; " \ + "echo details at http://boundarydevices.com/6q_bootscript ; " \ + "setenv stdout serial\0" \ + "upgradeu=for dtype in sata mmc " CONFIG_DRIVE_TYPES \ + "; do " \ + "for disk in 0 1 ; do ${dtype} dev ${disk} ;" \ + "for fs in fat ext2 ; do " \ + "${fs}load ${dtype} ${disk}:1 10008000 " \ + "/6x_upgrade " \ + "&& source 10008000 ; " \ + "done ; " \ + "done ; " \ + "done\0" \ + +#define CONFIG_ARP_TIMEOUT 200UL + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT "U-Boot > " +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_CBSIZE 1024 + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +#define CONFIG_SYS_MEMTEST_START 0x10000000 +#define CONFIG_SYS_MEMTEST_END 0x10010000 + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_CMDLINE_EDITING + +/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM MMDC0_ARB_BASE_ADDR +#define PHYS_SDRAM_SIZE (1u * 1024 * 1024 * 1024) + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +/* FLASH and environment organization */ +#define CONFIG_SYS_NO_FLASH + +#define CONFIG_ENV_SIZE (8 * 1024) + +/* #define CONFIG_ENV_IS_IN_MMC */ +#define CONFIG_ENV_IS_IN_SPI_FLASH + +#if defined(CONFIG_ENV_IS_IN_MMC) +#define CONFIG_ENV_OFFSET (6 * 64 * 1024) +#define CONFIG_SYS_MMC_ENV_DEV 0 +#elif defined(CONFIG_ENV_IS_IN_SPI_FLASH) +#define CONFIG_ENV_OFFSET (768 * 1024) +#define CONFIG_ENV_SECT_SIZE (8 * 1024) +#define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS +#define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS +#define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE +#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED +#endif + +#define CONFIG_OF_LIBFDT +#define CONFIG_CMD_BOOTZ + +#define CONFIG_SYS_DCACHE_OFF + +#ifndef CONFIG_SYS_DCACHE_OFF +#define CONFIG_CMD_CACHE +#endif + +#define CONFIG_CMD_BMP + +#endif /* __CONFIG_H */
Hi Eric,
On Wednesday, January 30, 2013 7:10:52 PM, Eric Nelson wrote:
This patch adds support for the Nitrogen6X board(s) from Boundary Devices. The boards are based on the i.MX6x processor family with two major variants: i.MX6Quad/6Dual i.MX6Dual-Lite/6Solo
More specifically, the board variations are: nitrogen6q i.MX6Q/6D 1GB nitrogen6dl i.MX6DL 1GB nitrogen6s i.MX6S 512MB nitrogen6q2g i.MX6Q/6D 2GB nitrogen6dl2g i.MX6DL 2GB nitrogen6s1g i.MX6S 1GB
Refer to http://boundarydevices.com/products/ for details.
Signed-off-by: Eric Nelson eric.nelson@boundarydevices.com
You have probably already noticed it, but just to make sure you do not miss it, my series about the i.MX6Q DDR3 init also affects this patch. And for the 6DL and 6S variants, there is an equivalent change to make, translated to 400 MHz (DDR3-800).
After a quick look at this patch, it looks good.
Best regards, Benoît
Hi Eric,
some general comments in praparation your V2. I have only some minor points.
- Try to split your patch in several patches, if possible. The patch covers different issues and the series will be easy to be review. This is mainly for the changes outside boards/boundary - I know it is not easy to split the rest.
- I agree you put your script in the board directory instead opf trying to use CONFIG_EXTRA_ENV_SETTINGS.
- Agree with the split of the configuration data (clocks.cfg and ddr setup). The same mechanism can be reused for other boards, too.
- and agree with the nomenclature. My +1 to rename mx6x_pins.h to mx6q_pins.h as you suggest in the cover letter.
Regards, Stefano Babic
MAINTAINERS | 8 + arch/arm/include/asm/arch-mx6/crm_regs.h | 12 + arch/arm/include/asm/arch-mx6/iomux.h | 5 + arch/arm/include/asm/arch-mx6/mx6-ddr.h | 73 ++ arch/arm/include/asm/arch-mx6/mx6dl-ddr.h | 59 ++ arch/arm/include/asm/arch-mx6/mx6dl_pins.h | 3 + arch/arm/include/asm/arch-mx6/mx6q-ddr.h | 57 ++ board/boundary/nitrogen6x/1066mhz_4x128mx16.cfg | 37 + board/boundary/nitrogen6x/1066mhz_4x256mx16.cfg | 37 + board/boundary/nitrogen6x/6x_bootscript.txt | 58 ++ .../boundary/nitrogen6x/6x_bootscript_android.txt | 64 ++ .../nitrogen6x/6x_bootscript_android_recovery.txt | 64 ++ board/boundary/nitrogen6x/6x_upgrade.txt | 46 + board/boundary/nitrogen6x/800mhz_2x128mx16.cfg | 37 + board/boundary/nitrogen6x/800mhz_2x256mx16.cfg | 37 + board/boundary/nitrogen6x/800mhz_4x128mx16.cfg | 37 + board/boundary/nitrogen6x/800mhz_4x256mx16.cfg | 37 + board/boundary/nitrogen6x/Makefile | 41 + board/boundary/nitrogen6x/README | 93 ++ board/boundary/nitrogen6x/clocks.cfg | 31 + board/boundary/nitrogen6x/ddr-setup.cfg | 94 ++ board/boundary/nitrogen6x/nitrogen6dl.cfg | 46 + board/boundary/nitrogen6x/nitrogen6dl2g.cfg | 46 + board/boundary/nitrogen6x/nitrogen6q.cfg | 46 + board/boundary/nitrogen6x/nitrogen6q2g.cfg | 46 + board/boundary/nitrogen6x/nitrogen6s.cfg | 46 + board/boundary/nitrogen6x/nitrogen6s1g.cfg | 46 + board/boundary/nitrogen6x/nitrogen6x.c | 901 ++++++++++++++++++++ boards.cfg | 6 + drivers/usb/host/ehci-mx6.c | 1 - include/configs/nitrogen6x.h | 284 ++++++ 31 files changed, 2397 insertions(+), 1 deletion(-) create mode 100644 arch/arm/include/asm/arch-mx6/mx6-ddr.h create mode 100644 arch/arm/include/asm/arch-mx6/mx6dl-ddr.h create mode 100644 arch/arm/include/asm/arch-mx6/mx6q-ddr.h create mode 100644 board/boundary/nitrogen6x/1066mhz_4x128mx16.cfg create mode 100644 board/boundary/nitrogen6x/1066mhz_4x256mx16.cfg create mode 100644 board/boundary/nitrogen6x/6x_bootscript.txt create mode 100644 board/boundary/nitrogen6x/6x_bootscript_android.txt create mode 100644 board/boundary/nitrogen6x/6x_bootscript_android_recovery.txt create mode 100644 board/boundary/nitrogen6x/6x_upgrade.txt create mode 100644 board/boundary/nitrogen6x/800mhz_2x128mx16.cfg create mode 100644 board/boundary/nitrogen6x/800mhz_2x256mx16.cfg create mode 100644 board/boundary/nitrogen6x/800mhz_4x128mx16.cfg create mode 100644 board/boundary/nitrogen6x/800mhz_4x256mx16.cfg create mode 100644 board/boundary/nitrogen6x/Makefile create mode 100644 board/boundary/nitrogen6x/README create mode 100644 board/boundary/nitrogen6x/clocks.cfg create mode 100644 board/boundary/nitrogen6x/ddr-setup.cfg create mode 100644 board/boundary/nitrogen6x/nitrogen6dl.cfg create mode 100644 board/boundary/nitrogen6x/nitrogen6dl2g.cfg create mode 100644 board/boundary/nitrogen6x/nitrogen6q.cfg create mode 100644 board/boundary/nitrogen6x/nitrogen6q2g.cfg create mode 100644 board/boundary/nitrogen6x/nitrogen6s.cfg create mode 100644 board/boundary/nitrogen6x/nitrogen6s1g.cfg create mode 100644 board/boundary/nitrogen6x/nitrogen6x.c create mode 100644 include/configs/nitrogen6x.h
diff --git a/MAINTAINERS b/MAINTAINERS index faa9b5e..720beab 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -1029,6 +1029,14 @@ Pali Rohár pali.rohar@gmail.com
nokia_rx51 ARM ARMV7 (OMAP34xx SoC)
+Eric Nelson eric.nelson@boundarydevices.com
- nitrogen6q i.MX6Q/6D 1GB
- nitrogen6dl i.MX6DL 1GB
- nitrogen6s i.MX6S 512MB
- nitrogen6q2g i.MX6Q/6D 2GB
- nitrogen6dl2g i.MX6DL 2GB
- nitrogen6s1g i.MX6S 1GB
Please maintain the list alphabetically sorted. I see that it last entries were put unsorted, the issue was not seen.
Unknown / orphaned boards: diff --git a/arch/arm/include/asm/arch-mx6/crm_regs.h b/arch/arm/include/asm/arch-mx6/crm_regs.h index d670f30..7676457 100644 --- a/arch/arm/include/asm/arch-mx6/crm_regs.h +++ b/arch/arm/include/asm/arch-mx6/crm_regs.h @@ -20,6 +20,17 @@ #ifndef __ARCH_ARM_MACH_MX6_CCM_REGS_H__ #define __ARCH_ARM_MACH_MX6_CCM_REGS_H__
+#define CCM_CCGR0 0x020C4068 +#define CCM_CCGR1 0x020C406c +#define CCM_CCGR2 0x020C4070 +#define CCM_CCGR3 0x020C4074 +#define CCM_CCGR4 0x020C4078 +#define CCM_CCGR5 0x020C407c +#define CCM_CCGR6 0x020C4080
+#define PMU_MISC2 0x020C8170
+#ifndef __ASSEMBLY__ struct mxc_ccm_reg { u32 ccr; /* 0x0000 */
The 0x0000 comment is superfluous...
u32 ccdr; @@ -105,6 +116,7 @@ struct mxc_ccm_reg { u32 analog_pfd_528_clr; u32 analog_pfd_528_tog; }; +#endif
/* Define the bits in register CCR */ #define MXC_CCM_CCR_RBC_EN (1 << 27) diff --git a/arch/arm/include/asm/arch-mx6/iomux.h b/arch/arm/include/asm/arch-mx6/iomux.h index d23abd7..57b514f 100644 --- a/arch/arm/include/asm/arch-mx6/iomux.h +++ b/arch/arm/include/asm/arch-mx6/iomux.h @@ -16,6 +16,11 @@
#ifndef __ASM_ARCH_IOMUX_H__ #define __ASM_ARCH_IOMUX_H__
+#define IOMUXC_GPR4 0x020e0010 +#define IOMUXC_GPR6 0x020e0018 +#define IOMUXC_GPR7 0x020e001c
- IOMUXC_GPR13 bit fields
*/ diff --git a/arch/arm/include/asm/arch-mx6/mx6-ddr.h b/arch/arm/include/asm/arch-mx6/mx6-ddr.h new file mode 100644 index 0000000..0a3cddc --- /dev/null +++ b/arch/arm/include/asm/arch-mx6/mx6-ddr.h @@ -0,0 +1,73 @@ +/*
- Copyright (C) 2012 Boundary Devices Inc.
- Licensed under the GPL-2 or later.
+#ifndef __ASM_ARCH_MX6_DDR_H__ +#define __ASM_ARCH_MX6_DDR_H__
+#ifdef CONFIG_MX6Q +#include "mx6q-ddr.h" +#else +#ifdef CONFIG_MX6DL +#include "mx6dl-ddr.h" +#else +#error "Please select cpu" +#endif /* CONFIG_MX6DL */ +#endif /* CONFIG_MX6Q */
Ok for me. We have discussed this way previously on ML.
+#define MMDC_P0_MDCTL 0x021b0000 +#define MMDC_P0_MDPDC 0x021b0004 +#define MMDC_P0_MDOTC 0x021b0008 +#define MMDC_P0_MDCFG0 0x021b000c +#define MMDC_P0_MDCFG1 0x021b0010 +#define MMDC_P0_MDCFG2 0x021b0014 +#define MMDC_P0_MDMISC 0x021b0018 +#define MMDC_P0_MDSCR 0x021b001c +#define MMDC_P0_MDREF 0x021b0020 +#define MMDC_P0_MDRWD 0x021b002c +#define MMDC_P0_MDOR 0x021b0030 +#define MMDC_P0_MDASP 0x021b0040 +#define MMDC_P0_MAPSR 0x021b0404 +#define MMDC_P0_MPZQHWCTRL 0x021b0800 +#define MMDC_P0_MPWLDECTRL0 0x021b080c +#define MMDC_P0_MPWLDECTRL1 0x021b0810 +#define MMDC_P0_MPODTCTRL 0x021b0818 +#define MMDC_P0_MPRDDQBY0DL 0x021b081c +#define MMDC_P0_MPRDDQBY1DL 0x021b0820 +#define MMDC_P0_MPRDDQBY2DL 0x021b0824 +#define MMDC_P0_MPRDDQBY3DL 0x021b0828 +#define MMDC_P0_MPDGCTRL0 0x021b083c +#define MMDC_P0_MPDGCTRL1 0x021b0840 +#define MMDC_P0_MPRDDLCTL 0x021b0848 +#define MMDC_P0_MPWRDLCTL 0x021b0850 +#define MMDC_P0_MPMUR0 0x021b08b8
+#define MMDC_P1_MDCTL 0x021b4000 +#define MMDC_P1_MDPDC 0x021b4004 +#define MMDC_P1_MDOTC 0x021b4008 +#define MMDC_P1_MDCFG0 0x021b400c +#define MMDC_P1_MDCFG1 0x021b4010 +#define MMDC_P1_MDCFG2 0x021b4014 +#define MMDC_P1_MDMISC 0x021b4018 +#define MMDC_P1_MDSCR 0x021b401c +#define MMDC_P1_MDREF 0x021b4020 +#define MMDC_P1_MDRWD 0x021b402c +#define MMDC_P1_MDOR 0x021b4030 +#define MMDC_P1_MDASP 0x021b4040 +#define MMDC_P1_MAPSR 0x021b4404 +#define MMDC_P1_MPZQHWCTRL 0x021b4800 +#define MMDC_P1_MPWLDECTRL0 0x021b480c +#define MMDC_P1_MPWLDECTRL1 0x021b4810 +#define MMDC_P1_MPODTCTRL 0x021b4818 +#define MMDC_P1_MPRDDQBY0DL 0x021b481c +#define MMDC_P1_MPRDDQBY1DL 0x021b4820 +#define MMDC_P1_MPRDDQBY2DL 0x021b4824 +#define MMDC_P1_MPRDDQBY3DL 0x021b4828 +#define MMDC_P1_MPDGCTRL0 0x021b483c +#define MMDC_P1_MPDGCTRL1 0x021b4840 +#define MMDC_P1_MPRDDLCTL 0x021b4848 +#define MMDC_P1_MPWRDLCTL 0x021b4850 +#define MMDC_P1_MPMUR0 0x021b48b8
+#endif /*__ASM_ARCH_MX6_DDR_H__ */ diff --git a/arch/arm/include/asm/arch-mx6/mx6dl-ddr.h b/arch/arm/include/asm/arch-mx6/mx6dl-ddr.h new file mode 100644 index 0000000..5a4bfc6 --- /dev/null +++ b/arch/arm/include/asm/arch-mx6/mx6dl-ddr.h @@ -0,0 +1,59 @@ +/*
+#ifndef __ASM_ARCH_MX6DLS_DDR_H__ +#define __ASM_ARCH_MX6DLS_DDR_H__
+#ifndef CONFIG_MX6DL +#ifndef CONFIG_MX6S +#error "wrong CPU" +#endif +#endif
+#define IOM_DRAM_DQM0 0x020e0470 +#define IOM_DRAM_DQM1 0x020e0474 +#define IOM_DRAM_DQM2 0x020e0478 +#define IOM_DRAM_DQM3 0x020e047c +#define IOM_DRAM_DQM4 0x020e0480 +#define IOM_DRAM_DQM5 0x020e0484 +#define IOM_DRAM_DQM6 0x020e0488 +#define IOM_DRAM_DQM7 0x020e048c
+#define IOM_DRAM_CAS 0x020e0464 +#define IOM_DRAM_RAS 0x020e0490 +#define IOM_DRAM_RESET 0x020e0494 +#define IOM_DRAM_SDCLK_0 0x020e04ac +#define IOM_DRAM_SDCLK_1 0x020e04b0 +#define IOM_DRAM_SDBA2 0x020e04a0 +#define IOM_DRAM_SDCKE0 0x020e04a4 +#define IOM_DRAM_SDCKE1 0x020e04a8 +#define IOM_DRAM_SDODT0 0x020e04b4 +#define IOM_DRAM_SDODT1 0x020e04b8
+#define IOM_DRAM_SDQS0 0x020e04bc +#define IOM_DRAM_SDQS1 0x020e04c0 +#define IOM_DRAM_SDQS2 0x020e04c4 +#define IOM_DRAM_SDQS3 0x020e04c8 +#define IOM_DRAM_SDQS4 0x020e04cc +#define IOM_DRAM_SDQS5 0x020e04d0 +#define IOM_DRAM_SDQS6 0x020e04d4 +#define IOM_DRAM_SDQS7 0x020e04d8
+#define IOM_GRP_B0DS 0x020e0764 +#define IOM_GRP_B1DS 0x020e0770 +#define IOM_GRP_B2DS 0x020e0778 +#define IOM_GRP_B3DS 0x020e077c +#define IOM_GRP_B4DS 0x020e0780 +#define IOM_GRP_B5DS 0x020e0784 +#define IOM_GRP_B6DS 0x020e078c +#define IOM_GRP_B7DS 0x020e0748 +#define IOM_GRP_ADDDS 0x020e074c +#define IOM_DDRMODE_CTL 0x020e0750 +#define IOM_GRP_DDRPKE 0x020e0754 +#define IOM_GRP_DDRMODE 0x020e0760 +#define IOM_GRP_CTLDS 0x020e076c +#define IOM_GRP_DDR_TYPE 0x020e0774
+#endif /*__ASM_ARCH_MX6S_DDR_H__ */ diff --git a/arch/arm/include/asm/arch-mx6/mx6dl_pins.h b/arch/arm/include/asm/arch-mx6/mx6dl_pins.h index 79e2c4f..9b9c571 100644 --- a/arch/arm/include/asm/arch-mx6/mx6dl_pins.h +++ b/arch/arm/include/asm/arch-mx6/mx6dl_pins.h @@ -105,6 +105,9 @@ enum { MX6DL_PAD_KEY_COL3__GPIO_4_12 = IOMUX_PAD(0x0638, 0x0250, 5, 0x0000, 0, 0), MX6DL_PAD_KEY_ROW3__I2C2_SDA = IOMUX_PAD(0x064C, 0x0264, 4 | IOMUX_CONFIG_SION, 0x0874, 1, 0), MX6DL_PAD_KEY_ROW3__GPIO_4_13 = IOMUX_PAD(0x064C, 0x0264, 5, 0x0000, 0, 0),
- MX6DL_PAD_NANDF_CS1__GPIO_6_14 = IOMUX_PAD(0x0660, 0x0278, 5, 0x0000, 0, 0),
- MX6DL_PAD_NANDF_CS2__GPIO_6_15 = IOMUX_PAD(0x0664, 0x027C, 5, 0x0000, 0, 0),
- MX6DL_PAD_NANDF_CS3__GPIO_6_16 = IOMUX_PAD(0x0668, 0x0280, 5, 0x0000, 0, 0), MX6DL_PAD_NANDF_D1__GPIO_2_1 = IOMUX_PAD(0x0670, 0x0288, 5, 0x0000, 0, 0), MX6DL_PAD_NANDF_D2__GPIO_2_2 = IOMUX_PAD(0x0674, 0x028C, 5, 0x0000, 0, 0), MX6DL_PAD_NANDF_D3__GPIO_2_3 = IOMUX_PAD(0x0678, 0x0290, 5, 0x0000, 0, 0),
diff --git a/arch/arm/include/asm/arch-mx6/mx6q-ddr.h b/arch/arm/include/asm/arch-mx6/mx6q-ddr.h new file mode 100644 index 0000000..4060600 --- /dev/null +++ b/arch/arm/include/asm/arch-mx6/mx6q-ddr.h @@ -0,0 +1,57 @@ +/*
+#ifndef __ASM_ARCH_MX6Q_DDR_H__ +#define __ASM_ARCH_MX6Q_DDR_H__
+#ifndef CONFIG_MX6Q +#error "wrong CPU" +#endif
+#define IOM_DRAM_DQM0 0x020e05ac +#define IOM_DRAM_DQM1 0x020e05b4 +#define IOM_DRAM_DQM2 0x020e0528 +#define IOM_DRAM_DQM3 0x020e0520 +#define IOM_DRAM_DQM4 0x020e0514 +#define IOM_DRAM_DQM5 0x020e0510 +#define IOM_DRAM_DQM6 0x020e05bc +#define IOM_DRAM_DQM7 0x020e05c4
+#define IOM_DRAM_CAS 0x020e056c +#define IOM_DRAM_RAS 0x020e0578 +#define IOM_DRAM_RESET 0x020e057c +#define IOM_DRAM_SDCLK_0 0x020e0588 +#define IOM_DRAM_SDCLK_1 0x020e0594 +#define IOM_DRAM_SDBA2 0x020e058c +#define IOM_DRAM_SDCKE0 0x020e0590 +#define IOM_DRAM_SDCKE1 0x020e0598 +#define IOM_DRAM_SDODT0 0x020e059c +#define IOM_DRAM_SDODT1 0x020e05a0
+#define IOM_DRAM_SDQS0 0x020e05a8 +#define IOM_DRAM_SDQS1 0x020e05b0 +#define IOM_DRAM_SDQS2 0x020e0524 +#define IOM_DRAM_SDQS3 0x020e051c +#define IOM_DRAM_SDQS4 0x020e0518 +#define IOM_DRAM_SDQS5 0x020e050c +#define IOM_DRAM_SDQS6 0x020e05b8 +#define IOM_DRAM_SDQS7 0x020e05c0
+#define IOM_GRP_B0DS 0x020e0784 +#define IOM_GRP_B1DS 0x020e0788 +#define IOM_GRP_B2DS 0x020e0794 +#define IOM_GRP_B3DS 0x020e079c +#define IOM_GRP_B4DS 0x020e07a0 +#define IOM_GRP_B5DS 0x020e07a4 +#define IOM_GRP_B6DS 0x020e07a8 +#define IOM_GRP_B7DS 0x020e0748 +#define IOM_GRP_ADDDS 0x020e074c +#define IOM_DDRMODE_CTL 0x020e0750 +#define IOM_GRP_DDRPKE 0x020e0758 +#define IOM_GRP_DDRMODE 0x020e0774 +#define IOM_GRP_CTLDS 0x020e078c +#define IOM_GRP_DDR_TYPE 0x020e0798
+#endif /*__ASM_ARCH_MX6Q_DDR_H__ */ diff --git a/board/boundary/nitrogen6x/1066mhz_4x128mx16.cfg b/board/boundary/nitrogen6x/1066mhz_4x128mx16.cfg new file mode 100644 index 0000000..63fb31d --- /dev/null +++ b/board/boundary/nitrogen6x/1066mhz_4x128mx16.cfg @@ -0,0 +1,37 @@ +DATA 4, MMDC_P0_MDPDC, 0x00020036 +DATA 4, MMDC_P0_MDCFG0, 0x555A7975 +DATA 4, MMDC_P0_MDCFG1, 0xFF538E64 +DATA 4, MMDC_P0_MDCFG2, 0x01FF00DB +DATA 4, MMDC_P0_MDRWD, 0x000026D2 +DATA 4, MMDC_P0_MDOR, 0x005B0E21 +DATA 4, MMDC_P0_MDOTC, 0x09444040 +DATA 4, MMDC_P0_MDPDC, 0x00025576 +DATA 4, MMDC_P0_MDASP, 0x00000027 +DATA 4, MMDC_P0_MDCTL, 0x831A0000 +DATA 4, MMDC_P0_MDSCR, 0x04088032 +DATA 4, MMDC_P0_MDSCR, 0x00008033 +DATA 4, MMDC_P0_MDSCR, 0x00428031 +DATA 4, MMDC_P0_MDSCR, 0x09408030 +DATA 4, MMDC_P0_MDSCR, 0x04008040 +DATA 4, MMDC_P0_MPZQHWCTRL, 0xA1390003 +DATA 4, MMDC_P1_MPZQHWCTRL, 0xA1390003 +DATA 4, MMDC_P0_MDREF, 0x00005800 +DATA 4, MMDC_P0_MPODTCTRL, 0x00022227 +DATA 4, MMDC_P1_MPODTCTRL, 0x00022227 +DATA 4, MMDC_P0_MPDGCTRL0, 0x434B0350 +DATA 4, MMDC_P0_MPDGCTRL1, 0x034C0359 +DATA 4, MMDC_P1_MPDGCTRL0, 0x434B0350 +DATA 4, MMDC_P1_MPDGCTRL1, 0x03650348 +DATA 4, MMDC_P0_MPRDDLCTL, 0x4436383B +DATA 4, MMDC_P1_MPRDDLCTL, 0x39393341 +DATA 4, MMDC_P0_MPWRDLCTL, 0x35373933 +DATA 4, MMDC_P1_MPWRDLCTL, 0x48254A36 +DATA 4, MMDC_P0_MPWLDECTRL0, 0x001F001F +DATA 4, MMDC_P0_MPWLDECTRL1, 0x001F001F +DATA 4, MMDC_P1_MPWLDECTRL0, 0x00440044 +DATA 4, MMDC_P1_MPWLDECTRL1, 0x00440044 +DATA 4, MMDC_P0_MPMUR0, 0x00000800 +DATA 4, MMDC_P1_MPMUR0, 0x00000800 +DATA 4, MMDC_P0_MDSCR, 0x00000000 +DATA 4, MMDC_P0_MAPSR, 0x00011006
diff --git a/board/boundary/nitrogen6x/1066mhz_4x256mx16.cfg b/board/boundary/nitrogen6x/1066mhz_4x256mx16.cfg new file mode 100644 index 0000000..68e70ad --- /dev/null +++ b/board/boundary/nitrogen6x/1066mhz_4x256mx16.cfg @@ -0,0 +1,37 @@ +DATA 4, MMDC_P0_MDPDC, 0x00020036 +DATA 4, MMDC_P0_MDCFG0, 0x895A7975 +DATA 4, MMDC_P0_MDCFG1, 0xFF538E64 +DATA 4, MMDC_P0_MDCFG2, 0x01FF00DB +DATA 4, MMDC_P0_MDRWD, 0x000026D2 +DATA 4, MMDC_P0_MDOR, 0x005B0E21 +DATA 4, MMDC_P0_MDOTC, 0x09444040 +DATA 4, MMDC_P0_MDPDC, 0x00025576 +DATA 4, MMDC_P0_MDASP, 0x00000047 +DATA 4, MMDC_P0_MDCTL, 0x841A0000 +DATA 4, MMDC_P0_MDSCR, 0x04008032 +DATA 4, MMDC_P0_MDSCR, 0x00008033 +DATA 4, MMDC_P0_MDSCR, 0x00428031 +DATA 4, MMDC_P0_MDSCR, 0x09408030 +DATA 4, MMDC_P0_MDSCR, 0x04008040 +DATA 4, MMDC_P0_MPZQHWCTRL, 0xA1390003 +DATA 4, MMDC_P1_MPZQHWCTRL, 0xA1390003 +DATA 4, MMDC_P0_MDREF, 0x00007800 +DATA 4, MMDC_P0_MPODTCTRL, 0x00022227 +DATA 4, MMDC_P1_MPODTCTRL, 0x00022227 +DATA 4, MMDC_P0_MPDGCTRL0, 0x43040319 +DATA 4, MMDC_P0_MPDGCTRL1, 0x03040279 +DATA 4, MMDC_P1_MPDGCTRL0, 0x43040321 +DATA 4, MMDC_P1_MPDGCTRL1, 0x03030251 +DATA 4, MMDC_P0_MPRDDLCTL, 0x4d434248 +DATA 4, MMDC_P1_MPRDDLCTL, 0x42413c4d +DATA 4, MMDC_P0_MPWRDLCTL, 0x34424543 +DATA 4, MMDC_P1_MPWRDLCTL, 0x49324933 +DATA 4, MMDC_P0_MPWLDECTRL0, 0x001a0017 +DATA 4, MMDC_P0_MPWLDECTRL1, 0x001F001F +DATA 4, MMDC_P1_MPWLDECTRL0, 0x00170027 +DATA 4, MMDC_P1_MPWLDECTRL1, 0x000a001f +DATA 4, MMDC_P0_MPMUR0, 0x00000800 +DATA 4, MMDC_P1_MPMUR0, 0x00000800 +DATA 4, MMDC_P0_MDSCR, 0x00000000 +DATA 4, MMDC_P0_MAPSR, 0x00011006
diff --git a/board/boundary/nitrogen6x/6x_bootscript.txt b/board/boundary/nitrogen6x/6x_bootscript.txt new file mode 100644 index 0000000..fe75976 --- /dev/null +++ b/board/boundary/nitrogen6x/6x_bootscript.txt @@ -0,0 +1,58 @@ +setenv bootargs enable_wait_mode=off +setenv nextcon 0;
+if hdmidet ; then
- setenv bootargs $bootargs video=mxcfb${nextcon}:dev=hdmi,1280x720M@60,if=RGB24
- setenv fbmem "fbmem=28M";
- setexpr nextcon $nextcon + 1
+else
- echo "------ no HDMI monitor";
+fi
+i2c dev 2 +if i2c probe 0x04 ; then
- setenv bootargs $bootargs video=mxcfb${nextcon}:dev=ldb,LDB-XGA,if=RGB666
- if test "0" -eq $nextcon; then
setenv fbmem "fbmem=10M";
- else
setenv fbmem ${fbmem},10M
- fi
+else
- echo "------ no Freescale display";
+fi
+if i2c probe 0x38 ; then
- setenv bootargs $bootargs video=mxcfb${nextcon}:dev=ldb,1024x600M@60,if=RGB666
- else
- fi
+else
- echo "------ no 1024x600 display";
+fi
+if i2c probe 0x48 ; then
- setenv bootargs $bootargs video=mxcfb${nextcon}:dev=lcd,CLAA-WVGA,if=RGB666
- else
- fi
+else
- echo "------ no 800x480 display";
+fi
+while test "3" -ne $nextcon ; do
- setenv bootargs $bootargs video=mxcfb${nextcon}:off ;
- setexpr nextcon $nextcon + 1 ;
+done
+setenv bootargs $bootargs $fbmem
+setenv bootargs $bootargs console=ttymxc1,115200 vmalloc=400M root=/dev/mmcblk0p1 rootwait consoleblank=0 ; +${fs}load mmc ${disk}:1 10800000 /boot/uImage && bootm 10800000 ; echo "Error loading kernel image"
diff --git a/board/boundary/nitrogen6x/6x_bootscript_android.txt b/board/boundary/nitrogen6x/6x_bootscript_android.txt new file mode 100644 index 0000000..7ade2e5 --- /dev/null +++ b/board/boundary/nitrogen6x/6x_bootscript_android.txt @@ -0,0 +1,64 @@ +${dtype} dev ${disk}
+setenv bootargs enable_wait_mode=off +setenv nextcon 0; +setenv bootargs $bootargs console=ttymxc1,115200 vmalloc=400M consoleblank=0 ;
+i2c dev 2
setenv fbcon "fbcon=10M";
- else
setenv fbcon ${fbcon},10M
- fi
+else
+fi
- else
- fi
+else
+fi
- setenv bootargs $bootargs video=mxcfb${nextcon}:dev=lcd,CLAA-WVGA,if=RGB666 tsdev=tsc2004 calibration
- else
- fi
+else
+fi
+if hdmidet ; then
setenv fbcon "fbcon=28M";
- else
setenv fbcon ${fbcon},28M
- fi
+else
+fi
+done
+setenv bootargs $bootargs fbcon=$fbcon +${fs}load ${dtype} ${disk}:1 10800000 uImage && ${fs}load ${dtype} ${disk}:1 12800000 uramdisk.img && bootm 10800000 12800000; echo "Error loading kernel image"
diff --git a/board/boundary/nitrogen6x/6x_bootscript_android_recovery.txt b/board/boundary/nitrogen6x/6x_bootscript_android_recovery.txt new file mode 100644 index 0000000..7ade2e5 --- /dev/null +++ b/board/boundary/nitrogen6x/6x_bootscript_android_recovery.txt @@ -0,0 +1,64 @@ +${dtype} dev ${disk}
+i2c dev 2
- else
- fi
+else
+fi
- else
- fi
+else
+fi
- else
- fi
+else
+fi
+if hdmidet ; then
- else
- fi
+else
+fi
+done
diff --git a/board/boundary/nitrogen6x/6x_upgrade.txt b/board/boundary/nitrogen6x/6x_upgrade.txt new file mode 100644 index 0000000..354d1a2 --- /dev/null +++ b/board/boundary/nitrogen6x/6x_upgrade.txt @@ -0,0 +1,46 @@ +setenv stdout serial,vga +echo "check U-Boot" ; +setenv offset 0x400 +if ${fs}load ${dtype} ${disk}:1 12000000 u-boot.imx || ${fs}load ${dtype} ${disk}:1 12000000 u-boot.nopadding ; then
echo "read $filesize bytes from SD card" ;
if sf probe || sf probe || \
sf probe 1 27000000 || sf probe 1 27000000 ; then
echo "probed SPI ROM" ;
if sf read 0x12400000 $offset $filesize ; then
if cmp.b 0x12000000 0x12400000 $filesize ; then
echo "------- U-Boot versions match" ;
else
echo "Need U-Boot upgrade" ;
echo "Program in 5 seconds" ;
for n in 5 4 3 2 1 ; do
echo $n ;
sleep 1 ;
done
echo "erasing" ;
sf erase 0 0x50000 ;
# two steps to prevent bricking
echo "programming" ;
sf write 0x12000000 $offset $filesize ;
echo "verifying" ;
while echo "---- U-Boot upgraded. reset" ; do
sleep 120
done
else
echo "Read verification error" ;
fi
else
echo "Error re-reading EEPROM" ;
fi
fi
else
echo "Error reading boot loader from EEPROM" ;
fi
else
echo "Error initializing EEPROM" ;
fi ;
+else
echo "No U-Boot image found on SD card" ;
+fi
diff --git a/board/boundary/nitrogen6x/800mhz_2x128mx16.cfg b/board/boundary/nitrogen6x/800mhz_2x128mx16.cfg new file mode 100644 index 0000000..ffd1078 --- /dev/null +++ b/board/boundary/nitrogen6x/800mhz_2x128mx16.cfg @@ -0,0 +1,37 @@ +DATA 4, MMDC_P0_MDPDC, 0x0002002D +DATA 4, MMDC_P0_MDCFG0, 0x696D5323 +DATA 4, MMDC_P0_MDCFG1, 0xB66E8C63 +DATA 4, MMDC_P0_MDCFG2, 0x01FF00DB +DATA 4, MMDC_P0_MDRWD, 0x000026D2 +DATA 4, MMDC_P0_MDOR, 0x005B0E21 +DATA 4, MMDC_P0_MDOTC, 0x00333030 +DATA 4, MMDC_P0_MDPDC, 0x0002556D +DATA 4, MMDC_P0_MDASP, 0x00000017 +DATA 4, MMDC_P0_MDCTL, 0x83190000 +DATA 4, MMDC_P0_MDSCR, 0x04008032 +DATA 4, MMDC_P0_MDSCR, 0x00008033 +DATA 4, MMDC_P0_MDSCR, 0x00048031 +DATA 4, MMDC_P0_MDSCR, 0x07208030 +DATA 4, MMDC_P0_MDSCR, 0x04008040 +DATA 4, MMDC_P0_MPZQHWCTRL, 0xA1390003 +DATA 4, MMDC_P1_MPZQHWCTRL, 0xA1390003 +DATA 4, MMDC_P0_MDREF, 0x00005800 +DATA 4, MMDC_P0_MPODTCTRL, 0x00022227 +DATA 4, MMDC_P1_MPODTCTRL, 0x00022227 +DATA 4, MMDC_P0_MPDGCTRL0, 0x42350231 +DATA 4, MMDC_P0_MPDGCTRL1, 0x021A0218 +DATA 4, MMDC_P1_MPDGCTRL0, 0x42350231 +DATA 4, MMDC_P1_MPDGCTRL1, 0x021A0218 +DATA 4, MMDC_P0_MPRDDLCTL, 0x4B4B4E49 +DATA 4, MMDC_P1_MPRDDLCTL, 0x4B4B4E49 +DATA 4, MMDC_P0_MPWRDLCTL, 0x3F3F3035 +DATA 4, MMDC_P1_MPWRDLCTL, 0x3F3F3035 +DATA 4, MMDC_P0_MPWLDECTRL0, 0x0040003C +DATA 4, MMDC_P0_MPWLDECTRL1, 0x0032003E +DATA 4, MMDC_P1_MPWLDECTRL0, 0x0040003C +DATA 4, MMDC_P1_MPWLDECTRL1, 0x0032003E +DATA 4, MMDC_P0_MPMUR0, 0x00000800 +DATA 4, MMDC_P1_MPMUR0, 0x00000800 +DATA 4, MMDC_P0_MDSCR, 0x00000000 +DATA 4, MMDC_P0_MAPSR, 0x00011006
diff --git a/board/boundary/nitrogen6x/800mhz_2x256mx16.cfg b/board/boundary/nitrogen6x/800mhz_2x256mx16.cfg new file mode 100644 index 0000000..35b38b7 --- /dev/null +++ b/board/boundary/nitrogen6x/800mhz_2x256mx16.cfg @@ -0,0 +1,37 @@ +DATA 4, MMDC_P0_MDPDC, 0x0002002D +DATA 4, MMDC_P0_MDCFG0, 0x696D5323 +DATA 4, MMDC_P0_MDCFG1, 0xB66E8C63 +DATA 4, MMDC_P0_MDCFG2, 0x01FF00DB +DATA 4, MMDC_P0_MDRWD, 0x000026D2 +DATA 4, MMDC_P0_MDOR, 0x005B0E21 +DATA 4, MMDC_P0_MDOTC, 0x00333030 +DATA 4, MMDC_P0_MDPDC, 0x0002556D +DATA 4, MMDC_P0_MDASP, 0x00000027 +DATA 4, MMDC_P0_MDCTL, 0x84190000 +DATA 4, MMDC_P0_MDSCR, 0x04008032 +DATA 4, MMDC_P0_MDSCR, 0x00008033 +DATA 4, MMDC_P0_MDSCR, 0x00048031 +DATA 4, MMDC_P0_MDSCR, 0x07208030 +DATA 4, MMDC_P0_MDSCR, 0x04008040 +DATA 4, MMDC_P0_MPZQHWCTRL, 0xA1390003 +DATA 4, MMDC_P1_MPZQHWCTRL, 0xA1390003 +DATA 4, MMDC_P0_MDREF, 0x00007800 +DATA 4, MMDC_P0_MPODTCTRL, 0x00022227 +DATA 4, MMDC_P1_MPODTCTRL, 0x00022227 +DATA 4, MMDC_P0_MPDGCTRL0, 0x42350231 +DATA 4, MMDC_P0_MPDGCTRL1, 0x021A0218 +DATA 4, MMDC_P1_MPDGCTRL0, 0x42350231 +DATA 4, MMDC_P1_MPDGCTRL1, 0x021A0218 +DATA 4, MMDC_P0_MPRDDLCTL, 0x4B4B4E49 +DATA 4, MMDC_P1_MPRDDLCTL, 0x4B4B4E49 +DATA 4, MMDC_P0_MPWRDLCTL, 0x3F3F3035 +DATA 4, MMDC_P1_MPWRDLCTL, 0x3F3F3035 +DATA 4, MMDC_P0_MPWLDECTRL0, 0x0040003C +DATA 4, MMDC_P0_MPWLDECTRL1, 0x0032003E +DATA 4, MMDC_P1_MPWLDECTRL0, 0x0040003C +DATA 4, MMDC_P1_MPWLDECTRL1, 0x0032003E +DATA 4, MMDC_P0_MPMUR0, 0x00000800 +DATA 4, MMDC_P1_MPMUR0, 0x00000800 +DATA 4, MMDC_P0_MDSCR, 0x00000000 +DATA 4, MMDC_P0_MAPSR, 0x00011006
diff --git a/board/boundary/nitrogen6x/800mhz_4x128mx16.cfg b/board/boundary/nitrogen6x/800mhz_4x128mx16.cfg new file mode 100644 index 0000000..76ae7e9 --- /dev/null +++ b/board/boundary/nitrogen6x/800mhz_4x128mx16.cfg @@ -0,0 +1,37 @@ +DATA 4, MMDC_P0_MDPDC, 0x0002002D +DATA 4, MMDC_P0_MDCFG0, 0x696D5323 +DATA 4, MMDC_P0_MDCFG1, 0xB66E8C63 +DATA 4, MMDC_P0_MDCFG2, 0x01FF00DB +DATA 4, MMDC_P0_MDRWD, 0x000026D2 +DATA 4, MMDC_P0_MDOR, 0x005B0E21 +DATA 4, MMDC_P0_MDOTC, 0x00333030 +DATA 4, MMDC_P0_MDPDC, 0x0002556D +DATA 4, MMDC_P0_MDASP, 0x00000027 +DATA 4, MMDC_P0_MDCTL, 0x831A0000 +DATA 4, MMDC_P0_MDSCR, 0x04008032 +DATA 4, MMDC_P0_MDSCR, 0x00008033 +DATA 4, MMDC_P0_MDSCR, 0x00048031 +DATA 4, MMDC_P0_MDSCR, 0x07208030 +DATA 4, MMDC_P0_MDSCR, 0x04008040 +DATA 4, MMDC_P0_MPZQHWCTRL, 0xA1390003 +DATA 4, MMDC_P1_MPZQHWCTRL, 0xA1390003 +DATA 4, MMDC_P0_MDREF, 0x00005800 +DATA 4, MMDC_P0_MPODTCTRL, 0x00022227 +DATA 4, MMDC_P1_MPODTCTRL, 0x00022227 +DATA 4, MMDC_P0_MPDGCTRL0, 0x42350231 +DATA 4, MMDC_P0_MPDGCTRL1, 0x021A0218 +DATA 4, MMDC_P1_MPDGCTRL0, 0x42350231 +DATA 4, MMDC_P1_MPDGCTRL1, 0x021A0218 +DATA 4, MMDC_P0_MPRDDLCTL, 0x4B4B4E49 +DATA 4, MMDC_P1_MPRDDLCTL, 0x4B4B4E49 +DATA 4, MMDC_P0_MPWRDLCTL, 0x3F3F3035 +DATA 4, MMDC_P1_MPWRDLCTL, 0x3F3F3035 +DATA 4, MMDC_P0_MPWLDECTRL0, 0x0040003C +DATA 4, MMDC_P0_MPWLDECTRL1, 0x0032003E +DATA 4, MMDC_P1_MPWLDECTRL0, 0x0040003C +DATA 4, MMDC_P1_MPWLDECTRL1, 0x0032003E +DATA 4, MMDC_P0_MPMUR0, 0x00000800 +DATA 4, MMDC_P1_MPMUR0, 0x00000800 +DATA 4, MMDC_P0_MDSCR, 0x00000000 +DATA 4, MMDC_P0_MAPSR, 0x00011006
diff --git a/board/boundary/nitrogen6x/800mhz_4x256mx16.cfg b/board/boundary/nitrogen6x/800mhz_4x256mx16.cfg new file mode 100644 index 0000000..8de937c --- /dev/null +++ b/board/boundary/nitrogen6x/800mhz_4x256mx16.cfg @@ -0,0 +1,37 @@ +DATA 4, MMDC_P0_MDPDC, 0x0002002D +DATA 4, MMDC_P0_MDCFG0, 0x696D5323 +DATA 4, MMDC_P0_MDCFG1, 0xB66E8C63 +DATA 4, MMDC_P0_MDCFG2, 0x01FF00DB +DATA 4, MMDC_P0_MDRWD, 0x000026D2 +DATA 4, MMDC_P0_MDOR, 0x005B0E21 +DATA 4, MMDC_P0_MDOTC, 0x00333030 +DATA 4, MMDC_P0_MDPDC, 0x0002556D +DATA 4, MMDC_P0_MDASP, 0x00000047 +DATA 4, MMDC_P0_MDCTL, 0x841A0000 +DATA 4, MMDC_P0_MDSCR, 0x04008032 +DATA 4, MMDC_P0_MDSCR, 0x00008033 +DATA 4, MMDC_P0_MDSCR, 0x00048031 +DATA 4, MMDC_P0_MDSCR, 0x07208030 +DATA 4, MMDC_P0_MDSCR, 0x04008040 +DATA 4, MMDC_P0_MPZQHWCTRL, 0xA1390003 +DATA 4, MMDC_P1_MPZQHWCTRL, 0xA1390003 +DATA 4, MMDC_P0_MDREF, 0x00007800 +DATA 4, MMDC_P0_MPODTCTRL, 0x00022227 +DATA 4, MMDC_P1_MPODTCTRL, 0x00022227 +DATA 4, MMDC_P0_MPDGCTRL0, 0x42350231 +DATA 4, MMDC_P0_MPDGCTRL1, 0x021A0218 +DATA 4, MMDC_P1_MPDGCTRL0, 0x42350231 +DATA 4, MMDC_P1_MPDGCTRL1, 0x021A0218 +DATA 4, MMDC_P0_MPRDDLCTL, 0x4B4B4E49 +DATA 4, MMDC_P1_MPRDDLCTL, 0x4B4B4E49 +DATA 4, MMDC_P0_MPWRDLCTL, 0x3F3F3035 +DATA 4, MMDC_P1_MPWRDLCTL, 0x3F3F3035 +DATA 4, MMDC_P0_MPWLDECTRL0, 0x0040003C +DATA 4, MMDC_P0_MPWLDECTRL1, 0x0032003E +DATA 4, MMDC_P1_MPWLDECTRL0, 0x0040003C +DATA 4, MMDC_P1_MPWLDECTRL1, 0x0032003E +DATA 4, MMDC_P0_MPMUR0, 0x00000800 +DATA 4, MMDC_P1_MPMUR0, 0x00000800 +DATA 4, MMDC_P0_MDSCR, 0x00000000 +DATA 4, MMDC_P0_MAPSR, 0x00011006
diff --git a/board/boundary/nitrogen6x/Makefile b/board/boundary/nitrogen6x/Makefile new file mode 100644 index 0000000..63da7d0 --- /dev/null +++ b/board/boundary/nitrogen6x/Makefile @@ -0,0 +1,41 @@ +# +# Copyright (C) 2012, Guennadi Liakhovetski lg@denx.de +# +# (C) Copyright 2012 Freescale Semiconductor, Inc. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +#
+include $(TOPDIR)/config.mk
+LIB = $(obj)lib$(BOARD).o
+COBJS := nitrogen6x.o
+SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS))
+$(LIB): $(obj).depend $(OBJS)
- $(call cmd_link_o_target, $(OBJS))
+# defines $(obj).depend target +include $(SRCTREE)/rules.mk
+sinclude $(obj).depend
+######################################################################### diff --git a/board/boundary/nitrogen6x/README b/board/boundary/nitrogen6x/README new file mode 100644 index 0000000..330cb49 --- /dev/null +++ b/board/boundary/nitrogen6x/README @@ -0,0 +1,93 @@ +U-Boot for the Boundary Devices Nitrogen6X and +Freescale i.MX6Q SabreLite boards
+This file contains information for the port of +U-Boot to the Boundary Devices Nitrogen6X and +Freescale i.MX6Q SabreLite boards.
+1. Boot source, boot from SPI NOR +--------------------------------- +The configuration in this directory supports both the +Nitrogen6X and Freescale SabreLite board, but in a +different fashion from Freescale's implementation in +board/freescale/mx6qsabrelite.
+In particular, this image supports booting from SPI NOR +and saving the environment to SPI NOR.
+It does not support 'boot from SD' at offset 0x400 +except through the 'bmode' command.
+2. Boots using 6x_bootscript on SATA or SD card +----------------------------------------------- +The default bootcmd for these boards is configured +to look for and source a boot script named '6x_bootscript' +in the root of the first partition of the following +devices:
- sata 0
- mmc 0
- mmc 1
+They're searched in the order listed above, trying both the +ext2 and fat filesystems.
+2. Maintaining the SPI NOR +-------------------------- +A couple of convenience commands
- clearenv - clear environment to factory default
- upgradeu - look and source a boot script named
'6x_upgrade' to upgrade the U-Boot version
in SPI NOR. The search is the same as for
6x_bootscript described above.
+3. Display support +------------------ +U-Boot support for the following displays is configured by +default:
- HDMI - 1024 x 768 for maximum compatibility
- Hannstar-XGA - 1024 x 768 LVDS (Freescale part number MCIMX-LVDS1)
- wsvga-lvds - 1024 x 600 LVDS (Boundary p/n Nit6X_1024x600)
- wvga-rgb - 800 x 480 RGB (Boundary p/n Nit6X_800x480)
+Since the ipuv3_fb display driver currently supports only a single display, +this code auto-detects panel by probing the HDMI Phy for Hot Plug Detect +or the I2C touch controller of the LVDS and RGB displays in the priority +listed above.
+Setting 'panel' environment variable to one of the names above will +override auto-detection and force activation of the specified panel.
+4. Building +------------
+To build U-Boot for one of the Nitrogen6x or SabreLite board:
- make nitrogen6x_config
- make u-boot.imx
+Note that 'nitrogen6x' is a placeholder. The complete list of supported +board configurations is shown in tha MAINTAINERS file:
+The -6q variants support either the i.MX6Quad or i.MX6Dual processors +and are configured for a 64-bit memory bus at 1066 MHz.
+The -6dl variants also use a 64-bit memory bus, operated at 800MHz.
+The -6s variants use a 32-bit memory bus at 800MHz.
+If you place the u-boot.imx into a single-partition SD card +along with a binary version of the boot script 6x_upgrade.txt, +you can program it using 'upgradeu':
- U-Boot> run upgradeu
diff --git a/board/boundary/nitrogen6x/clocks.cfg b/board/boundary/nitrogen6x/clocks.cfg new file mode 100644 index 0000000..5143b78 --- /dev/null +++ b/board/boundary/nitrogen6x/clocks.cfg @@ -0,0 +1,31 @@ +/*
- Device Configuration Data (DCD)
- Each entry must have the format:
- Addr-type Address Value
- where:
Addr-type register length (1,2 or 4 bytes)
Address absolute address of the register
value value to be stored in the register
+/* set the default clock gate to save power */ +DATA 4, CCM_CCGR0, 0x00C03F3F +DATA 4, CCM_CCGR1, 0x0030FC03 +DATA 4, CCM_CCGR2, 0x0FFFC000 +DATA 4, CCM_CCGR3, 0x3FF00000 +DATA 4, CCM_CCGR4, 0x00FFF300 +DATA 4, CCM_CCGR5, 0x0F0000C3 +DATA 4, CCM_CCGR6, 0x000003FF
+/* enable AXI cache for VDOA/VPU/IPU */ +DATA 4, IOMUXC_GPR4, 0xF00000CF +/* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ +DATA 4, IOMUXC_GPR6, 0x007F007F +DATA 4, IOMUXC_GPR7, 0x007F007F
+/* Set LDO Ramp rates to fast */ +/* 64 clocks/0.266uS/25mV */ +/* == 32uS for 0.95->1.25V */ +DATA 4, PMU_MISC2, 0x00670f67 diff --git a/board/boundary/nitrogen6x/ddr-setup.cfg b/board/boundary/nitrogen6x/ddr-setup.cfg new file mode 100644 index 0000000..b3f7ec4 --- /dev/null +++ b/board/boundary/nitrogen6x/ddr-setup.cfg @@ -0,0 +1,94 @@ +/*
- where:
- DDR3 settings
- MX6Q ddr is limited to 1066 Mhz currently 1056 MHz(528 MHz clock),
memory bus width: 64 bits x16/x32/x64
- MX6DL ddr is limited to 800 MHz(400 MHz clock)
- MX6SOLO ddr is limited to 800 MHz(400 MHz clock)
memory bus width: 32 bits x16/x32
+DATA 4, IOM_DRAM_SDQS0, 0x00000030 +DATA 4, IOM_DRAM_SDQS1, 0x00000030 +DATA 4, IOM_DRAM_SDQS2, 0x00000030 +DATA 4, IOM_DRAM_SDQS3, 0x00000030 +DATA 4, IOM_DRAM_SDQS4, 0x00000030 +DATA 4, IOM_DRAM_SDQS5, 0x00000030 +DATA 4, IOM_DRAM_SDQS6, 0x00000030 +DATA 4, IOM_DRAM_SDQS7, 0x00000030
+DATA 4, IOM_GRP_B0DS, 0x00000030 +DATA 4, IOM_GRP_B1DS, 0x00000030 +DATA 4, IOM_GRP_B2DS, 0x00000030 +DATA 4, IOM_GRP_B3DS, 0x00000030 +DATA 4, IOM_GRP_B4DS, 0x00000030 +DATA 4, IOM_GRP_B5DS, 0x00000030 +DATA 4, IOM_GRP_B6DS, 0x00000030 +DATA 4, IOM_GRP_B7DS, 0x00000030 +DATA 4, IOM_GRP_ADDDS, 0x00000030 +/* 40 Ohm drive strength for cs0/1,sdba2,cke0/1,sdwe */ +DATA 4, IOM_GRP_CTLDS, 0x00000030
+DATA 4, IOM_DRAM_DQM0, 0x00020030 +DATA 4, IOM_DRAM_DQM1, 0x00020030 +DATA 4, IOM_DRAM_DQM2, 0x00020030 +DATA 4, IOM_DRAM_DQM3, 0x00020030 +DATA 4, IOM_DRAM_DQM4, 0x00020030 +DATA 4, IOM_DRAM_DQM5, 0x00020030 +DATA 4, IOM_DRAM_DQM6, 0x00020030 +DATA 4, IOM_DRAM_DQM7, 0x00020030
+DATA 4, IOM_DRAM_CAS, 0x00020030 +DATA 4, IOM_DRAM_RAS, 0x00020030 +DATA 4, IOM_DRAM_SDCLK_0, 0x00020030 +DATA 4, IOM_DRAM_SDCLK_1, 0x00020030
+DATA 4, IOM_DRAM_RESET, 0x000e0030 +DATA 4, IOM_DRAM_SDCKE0, 0x00003000 +DATA 4, IOM_DRAM_SDCKE1, 0x00003000
+DATA 4, IOM_DRAM_SDODT0, 0x00003030 +DATA 4, IOM_DRAM_SDODT1, 0x00003030
+/* (differential input) */ +DATA 4, IOM_DDRMODE_CTL, 0x00020000 +/* (differential input) */ +DATA 4, IOM_GRP_DDRMODE, 0x00020000 +/* disable ddr pullups */ +DATA 4, IOM_GRP_DDRPKE, 0x00000000 +DATA 4, IOM_DRAM_SDBA2, 0x00000000 +/* 40 Ohm drive strength for cs0/1,sdba2,cke0/1,sdwe */ +DATA 4, IOM_GRP_DDR_TYPE, 0x000C0000
+/* Read data DQ Byte0-3 delay */ +DATA 4, MMDC_P0_MPRDDQBY0DL, 0x33333333 +DATA 4, MMDC_P0_MPRDDQBY1DL, 0x33333333 +DATA 4, MMDC_P0_MPRDDQBY2DL, 0x33333333 +DATA 4, MMDC_P0_MPRDDQBY3DL, 0x33333333 +DATA 4, MMDC_P1_MPRDDQBY0DL, 0x33333333 +DATA 4, MMDC_P1_MPRDDQBY1DL, 0x33333333 +DATA 4, MMDC_P1_MPRDDQBY2DL, 0x33333333 +DATA 4, MMDC_P1_MPRDDQBY3DL, 0x33333333
- MDMISC mirroring interleaved (row/bank/col)
+DATA 4, MMDC_P0_MDMISC, 0x00081740
- MDSCR con_req
+DATA 4, MMDC_P0_MDSCR, 0x00008000
diff --git a/board/boundary/nitrogen6x/nitrogen6dl.cfg b/board/boundary/nitrogen6x/nitrogen6dl.cfg new file mode 100644 index 0000000..60300c5 --- /dev/null +++ b/board/boundary/nitrogen6x/nitrogen6dl.cfg @@ -0,0 +1,46 @@ +/*
- Copyright (C) 2013 Boundary Devices
- project.
- the License or (at your option) any later version.
- along with this program; if not write to the Free Software
- Foundation Inc. 51 Franklin Street Fifth Floor Boston,
- MA 02110-1301 USA
- Refer docs/README.imxmage for more details about how-to configure
- and create imximage boot image
- The syntax is taken as close as possible with the kwbimage
+/* image version */ +IMAGE_VERSION 2
- Boot Device : one of
- spi, sd (the board has no nand neither onenand)
+BOOT_FROM sd
+#define __ASSEMBLY__ +#include <config.h> +#include "asm/arch/mx6-ddr.h" +#include "asm/arch/iomux.h" +#include "asm/arch/crm_regs.h"
+#include "ddr-setup.cfg" +#include "800mhz_4x128mx16.cfg" +#include "clocks.cfg"
diff --git a/board/boundary/nitrogen6x/nitrogen6dl2g.cfg b/board/boundary/nitrogen6x/nitrogen6dl2g.cfg new file mode 100644 index 0000000..b62c73e --- /dev/null +++ b/board/boundary/nitrogen6x/nitrogen6dl2g.cfg @@ -0,0 +1,46 @@ +/*
- project.
- MA 02110-1301 USA
+BOOT_FROM sd
+#include "ddr-setup.cfg" +#include "800mhz_4x256mx16.cfg" +#include "clocks.cfg"
diff --git a/board/boundary/nitrogen6x/nitrogen6q.cfg b/board/boundary/nitrogen6x/nitrogen6q.cfg new file mode 100644 index 0000000..30353a5 --- /dev/null +++ b/board/boundary/nitrogen6x/nitrogen6q.cfg @@ -0,0 +1,46 @@ +/*
- project.
- MA 02110-1301 USA
+BOOT_FROM sd
+#include "ddr-setup.cfg" +#include "1066mhz_4x128mx16.cfg" +#include "clocks.cfg"
diff --git a/board/boundary/nitrogen6x/nitrogen6q2g.cfg b/board/boundary/nitrogen6x/nitrogen6q2g.cfg new file mode 100644 index 0000000..8c1a74f --- /dev/null +++ b/board/boundary/nitrogen6x/nitrogen6q2g.cfg @@ -0,0 +1,46 @@ +/*
- project.
- MA 02110-1301 USA
+BOOT_FROM sd
+#include "ddr-setup.cfg" +#include "1066mhz_4x256mx16.cfg" +#include "clocks.cfg"
diff --git a/board/boundary/nitrogen6x/nitrogen6s.cfg b/board/boundary/nitrogen6x/nitrogen6s.cfg new file mode 100644 index 0000000..8a73a51 --- /dev/null +++ b/board/boundary/nitrogen6x/nitrogen6s.cfg @@ -0,0 +1,46 @@ +/*
- project.
- MA 02110-1301 USA
+BOOT_FROM sd
+#include "ddr-setup.cfg" +#include "800mhz_2x128mx16.cfg" +#include "clocks.cfg"
diff --git a/board/boundary/nitrogen6x/nitrogen6s1g.cfg b/board/boundary/nitrogen6x/nitrogen6s1g.cfg new file mode 100644 index 0000000..3659e1e --- /dev/null +++ b/board/boundary/nitrogen6x/nitrogen6s1g.cfg @@ -0,0 +1,46 @@ +/*
- project.
- MA 02110-1301 USA
+BOOT_FROM sd
+#include "ddr-setup.cfg" +#include "800mhz_2x256mx16.cfg" +#include "clocks.cfg"
diff --git a/board/boundary/nitrogen6x/nitrogen6x.c b/board/boundary/nitrogen6x/nitrogen6x.c new file mode 100644 index 0000000..9e3898a --- /dev/null +++ b/board/boundary/nitrogen6x/nitrogen6x.c @@ -0,0 +1,901 @@ +/*
- Copyright (C) 2010-2011 Freescale Semiconductor, Inc.
- project.
- MA 02111-1307 USA
+#include <common.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/iomux.h> +#ifdef CONFIG_MX6Q +#include <asm/arch/mx6x_pins.h> +#else +#ifdef CONFIG_MX6DL +#include <asm/arch/mx6dl_pins.h> +#define FOR_DL_SOLO +#else +#ifdef CONFIG_MX6S +#include <asm/arch/mx6dl_pins.h> +#define FOR_DL_SOLO +#else +#error "Please select cpu" +#endif /* CONFIG_MX6S */ +#endif /* CONFIG_MX6DL */ +#endif /* CONFIG_MX6Q */ +#include <asm/errno.h> +#include <asm/gpio.h> +#include <asm/imx-common/iomux-v3.h> +#include <asm/imx-common/mxc_i2c.h> +#include <asm/imx-common/boot_mode.h> +#include <mmc.h> +#include <fsl_esdhc.h> +#include <micrel.h> +#include <miiphy.h> +#include <netdev.h> +#include <linux/fb.h> +#include <ipu_pixfmt.h> +#include <asm/arch/crm_regs.h> +#include <asm/arch/mxc_hdmi.h> +#include <i2c.h>
+DECLARE_GLOBAL_DATA_PTR;
+#ifdef FOR_DL_SOLO +#define MX6PAD(a) MX6DL_PAD_##a +#else +#define MX6PAD(a) MX6Q_PAD_##a +#endif
+#define UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \
- PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \
- PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS)
+#define USDHC_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \
- PAD_CTL_PUS_47K_UP | PAD_CTL_SPEED_LOW | \
- PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS)
+#define ENET_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \
- PAD_CTL_DSE_40ohm | PAD_CTL_HYS)
+#define SPI_PAD_CTRL (PAD_CTL_HYS | \
- PAD_CTL_PUS_100K_DOWN | PAD_CTL_SPEED_MED | \
- PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST)
+#define BUTTON_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \
+#define I2C_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \
- PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \
- PAD_CTL_ODE | PAD_CTL_SRE_FAST)
+#define WEAK_PULLUP (PAD_CTL_PKE | PAD_CTL_PUE | \
- PAD_CTL_SRE_SLOW)
+#define WEAK_PULLDOWN (PAD_CTL_PKE | PAD_CTL_PUE | \
- PAD_CTL_SRE_SLOW)
+#define OUTPUT_40OHM (PAD_CTL_SPEED_MED|PAD_CTL_DSE_40ohm)
+int dram_init(void) +{
- gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE);
+iomux_v3_cfg_t const uart1_pads[] = {
- MX6PAD(SD3_DAT6__UART1_RXD) | MUX_PAD_CTRL(UART_PAD_CTRL),
- MX6PAD(SD3_DAT7__UART1_TXD) | MUX_PAD_CTRL(UART_PAD_CTRL),
+iomux_v3_cfg_t const uart2_pads[] = {
- MX6PAD(EIM_D26__UART2_TXD) | MUX_PAD_CTRL(UART_PAD_CTRL),
- MX6PAD(EIM_D27__UART2_RXD) | MUX_PAD_CTRL(UART_PAD_CTRL),
+#define PC MUX_PAD_CTRL(I2C_PAD_CTRL)
+/* I2C1, SGTL5000 */ +struct i2c_pads_info i2c_pad_info0 = {
- .scl = {
.i2c_mode = MX6PAD(EIM_D21__I2C1_SCL) | PC,
.gpio_mode = MX6PAD(EIM_D21__GPIO_3_21) | PC,
.gp = IMX_GPIO_NR(3, 21)
- .sda = {
.i2c_mode = MX6PAD(EIM_D28__I2C1_SDA) | PC,
.gpio_mode = MX6PAD(EIM_D28__GPIO_3_28) | PC,
.gp = IMX_GPIO_NR(3, 28)
+/* I2C2 Camera, MIPI */ +struct i2c_pads_info i2c_pad_info1 = {
- .scl = {
.i2c_mode = MX6PAD(KEY_COL3__I2C2_SCL) | PC,
.gpio_mode = MX6PAD(KEY_COL3__GPIO_4_12) | PC,
.gp = IMX_GPIO_NR(4, 12)
- .sda = {
.i2c_mode = MX6PAD(KEY_ROW3__I2C2_SDA) | PC,
.gpio_mode = MX6PAD(KEY_ROW3__GPIO_4_13) | PC,
.gp = IMX_GPIO_NR(4, 13)
+/* I2C3, J15 - RGB connector */ +struct i2c_pads_info i2c_pad_info2 = {
- .scl = {
.i2c_mode = MX6PAD(GPIO_5__I2C3_SCL) | PC,
.gpio_mode = MX6PAD(GPIO_5__GPIO_1_5) | PC,
.gp = IMX_GPIO_NR(1, 5)
- .sda = {
.i2c_mode = MX6PAD(GPIO_16__I2C3_SDA) | PC,
.gpio_mode = MX6PAD(GPIO_16__GPIO_7_11) | PC,
.gp = IMX_GPIO_NR(7, 11)
+iomux_v3_cfg_t const usdhc3_pads[] = {
- MX6PAD(SD3_CLK__USDHC3_CLK) | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6PAD(SD3_CMD__USDHC3_CMD) | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6PAD(SD3_DAT0__USDHC3_DAT0) | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6PAD(SD3_DAT1__USDHC3_DAT1) | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6PAD(SD3_DAT2__USDHC3_DAT2) | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6PAD(SD3_DAT3__USDHC3_DAT3) | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6PAD(SD3_DAT5__GPIO_7_0) | MUX_PAD_CTRL(NO_PAD_CTRL), /* CD */
+iomux_v3_cfg_t const usdhc4_pads[] = {
- MX6PAD(SD4_CLK__USDHC4_CLK) | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6PAD(SD4_CMD__USDHC4_CMD) | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6PAD(SD4_DAT0__USDHC4_DAT0) | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6PAD(SD4_DAT1__USDHC4_DAT1) | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6PAD(SD4_DAT2__USDHC4_DAT2) | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6PAD(SD4_DAT3__USDHC4_DAT3) | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6PAD(NANDF_D6__GPIO_2_6) | MUX_PAD_CTRL(NO_PAD_CTRL), /* CD */
+iomux_v3_cfg_t const enet_pads1[] = {
- MX6PAD(ENET_MDIO__ENET_MDIO) | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6PAD(ENET_MDC__ENET_MDC) | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6PAD(RGMII_TXC__ENET_RGMII_TXC) | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6PAD(RGMII_TD0__ENET_RGMII_TD0) | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6PAD(RGMII_TD1__ENET_RGMII_TD1) | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6PAD(RGMII_TD2__ENET_RGMII_TD2) | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6PAD(RGMII_TD3__ENET_RGMII_TD3) | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6PAD(RGMII_TX_CTL__RGMII_TX_CTL) | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6PAD(ENET_REF_CLK__ENET_TX_CLK) | MUX_PAD_CTRL(ENET_PAD_CTRL),
- /* pin 35 - 1 (PHY_AD2) on reset */
- MX6PAD(RGMII_RXC__GPIO_6_30) | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* pin 32 - 1 - (MODE0) all */
- MX6PAD(RGMII_RD0__GPIO_6_25) | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* pin 31 - 1 - (MODE1) all */
- MX6PAD(RGMII_RD1__GPIO_6_27) | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* pin 28 - 1 - (MODE2) all */
- MX6PAD(RGMII_RD2__GPIO_6_28) | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* pin 27 - 1 - (MODE3) all */
- MX6PAD(RGMII_RD3__GPIO_6_29) | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* pin 33 - 1 - (CLK125_EN) 125Mhz clockout enabled */
- MX6PAD(RGMII_RX_CTL__GPIO_6_24) | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* pin 42 PHY nRST */
- MX6PAD(EIM_D23__GPIO_3_23) | MUX_PAD_CTRL(NO_PAD_CTRL),
- MX6PAD(ENET_RXD0__GPIO_1_27) | MUX_PAD_CTRL(NO_PAD_CTRL),
+iomux_v3_cfg_t const enet_pads2[] = {
- MX6PAD(RGMII_RXC__ENET_RGMII_RXC) | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6PAD(RGMII_RD0__ENET_RGMII_RD0) | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6PAD(RGMII_RD1__ENET_RGMII_RD1) | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6PAD(RGMII_RD2__ENET_RGMII_RD2) | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6PAD(RGMII_RD3__ENET_RGMII_RD3) | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6PAD(RGMII_RX_CTL__RGMII_RX_CTL) | MUX_PAD_CTRL(ENET_PAD_CTRL),
+/* wl1271 pads on nitrogen6x */ +iomux_v3_cfg_t const wl12xx_pads[] = {
- (MX6PAD(NANDF_CS1__GPIO_6_14) & ~MUX_PAD_CTRL_MASK)
| MUX_PAD_CTRL(WEAK_PULLDOWN),
- (MX6PAD(NANDF_CS2__GPIO_6_15) & ~MUX_PAD_CTRL_MASK)
| MUX_PAD_CTRL(OUTPUT_40OHM),
- (MX6PAD(NANDF_CS3__GPIO_6_16) & ~MUX_PAD_CTRL_MASK)
+}; +#define WL12XX_WL_IRQ_GP IMX_GPIO_NR(6, 14) +#define WL12XX_WL_ENABLE_GP IMX_GPIO_NR(6, 15) +#define WL12XX_BT_ENABLE_GP IMX_GPIO_NR(6, 16)
+/* Button assignments for J14 */ +static iomux_v3_cfg_t const button_pads[] = {
- /* Menu */
- MX6PAD(NANDF_D1__GPIO_2_1) | MUX_PAD_CTRL(BUTTON_PAD_CTRL),
- /* Back */
- MX6PAD(NANDF_D2__GPIO_2_2) | MUX_PAD_CTRL(BUTTON_PAD_CTRL),
- /* Labelled Search (mapped to Power under Android) */
- MX6PAD(NANDF_D3__GPIO_2_3) | MUX_PAD_CTRL(BUTTON_PAD_CTRL),
- /* Home */
- MX6PAD(NANDF_D4__GPIO_2_4) | MUX_PAD_CTRL(BUTTON_PAD_CTRL),
- /* Volume Down */
- MX6PAD(GPIO_19__GPIO_4_5) | MUX_PAD_CTRL(BUTTON_PAD_CTRL),
- /* Volume Up */
- MX6PAD(GPIO_18__GPIO_7_13) | MUX_PAD_CTRL(BUTTON_PAD_CTRL),
+static void setup_iomux_enet(void) +{
- gpio_direction_output(IMX_GPIO_NR(3, 23), 0); /* SABRE Lite PHY rst */
- gpio_direction_output(IMX_GPIO_NR(1, 27), 0); /* Nitrogen6X PHY rst */
- gpio_direction_output(IMX_GPIO_NR(6, 30), 1);
- gpio_direction_output(IMX_GPIO_NR(6, 25), 1);
- gpio_direction_output(IMX_GPIO_NR(6, 27), 1);
- gpio_direction_output(IMX_GPIO_NR(6, 28), 1);
- gpio_direction_output(IMX_GPIO_NR(6, 29), 1);
- imx_iomux_v3_setup_multiple_pads(enet_pads1, ARRAY_SIZE(enet_pads1));
- gpio_direction_output(IMX_GPIO_NR(6, 24), 1);
- /* Need delay 10ms according to KSZ9021 spec */
- udelay(1000 * 10);
- gpio_set_value(IMX_GPIO_NR(3, 23), 1); /* SABRE Lite PHY reset */
- gpio_set_value(IMX_GPIO_NR(1, 27), 1); /* Nitrogen6X PHY reset */
- imx_iomux_v3_setup_multiple_pads(enet_pads2, ARRAY_SIZE(enet_pads2));
+iomux_v3_cfg_t const usb_pads[] = {
- MX6PAD(GPIO_17__GPIO_7_12) | MUX_PAD_CTRL(NO_PAD_CTRL),
+static void setup_iomux_uart(void) +{
- imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads));
- imx_iomux_v3_setup_multiple_pads(uart2_pads, ARRAY_SIZE(uart2_pads));
+#ifdef CONFIG_USB_EHCI_MX6 +int board_ehci_hcd_init(int port) +{
- imx_iomux_v3_setup_multiple_pads(usb_pads, ARRAY_SIZE(usb_pads));
- /* Reset USB hub */
- gpio_direction_output(IMX_GPIO_NR(7, 12), 0);
- mdelay(2);
- gpio_set_value(IMX_GPIO_NR(7, 12), 1);
+} +#endif
+#ifdef CONFIG_FSL_ESDHC +struct fsl_esdhc_cfg usdhc_cfg[2] = {
- {USDHC3_BASE_ADDR},
- {USDHC4_BASE_ADDR},
+int board_mmc_getcd(struct mmc *mmc) +{
- struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv;
- int ret;
- if (cfg->esdhc_base == USDHC3_BASE_ADDR) {
gpio_direction_input(IMX_GPIO_NR(7, 0));
ret = !gpio_get_value(IMX_GPIO_NR(7, 0));
- } else {
gpio_direction_input(IMX_GPIO_NR(2, 6));
ret = !gpio_get_value(IMX_GPIO_NR(2, 6));
- return ret;
+int board_mmc_init(bd_t *bis) +{
- s32 status = 0;
- u32 index = 0;
- usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK);
- usdhc_cfg[1].sdhc_clk = mxc_get_clock(MXC_ESDHC4_CLK);
- for (index = 0; index < CONFIG_SYS_FSL_USDHC_NUM; ++index) {
switch (index) {
case 0:
usdhc3_pads, ARRAY_SIZE(usdhc3_pads));
break;
case 1:
usdhc4_pads, ARRAY_SIZE(usdhc4_pads));
break;
default:
printf("Warning: you configured more USDHC controllers"
"(%d) then supported by the board (%d)\n",
index + 1, CONFIG_SYS_FSL_USDHC_NUM);
return status;
status |= fsl_esdhc_initialize(bis, &usdhc_cfg[index]);
- return status;
+} +#endif
+u32 get_board_rev(void) +{
- return 0x63000;
+#ifdef CONFIG_MXC_SPI +iomux_v3_cfg_t const ecspi1_pads[] = {
- /* SS1 */
- MX6PAD(EIM_D19__GPIO_3_19) | MUX_PAD_CTRL(SPI_PAD_CTRL),
- MX6PAD(EIM_D17__ECSPI1_MISO) | MUX_PAD_CTRL(SPI_PAD_CTRL),
- MX6PAD(EIM_D18__ECSPI1_MOSI) | MUX_PAD_CTRL(SPI_PAD_CTRL),
- MX6PAD(EIM_D16__ECSPI1_SCLK) | MUX_PAD_CTRL(SPI_PAD_CTRL),
+void setup_spi(void) +{
- gpio_direction_output(CONFIG_SF_DEFAULT_CS, 1);
- imx_iomux_v3_setup_multiple_pads(ecspi1_pads,
ARRAY_SIZE(ecspi1_pads));
+} +#endif
+int board_phy_config(struct phy_device *phydev) +{
- /* min rx data delay */
- ksz9021_phy_extended_write(phydev,
MII_KSZ9021_EXT_RGMII_RX_DATA_SKEW, 0x0);
- /* min tx data delay */
MII_KSZ9021_EXT_RGMII_TX_DATA_SKEW, 0x0);
- /* max rx/tx clock delay, min rx/tx control */
MII_KSZ9021_EXT_RGMII_CLOCK_SKEW, 0xf0f0);
- if (phydev->drv->config)
phydev->drv->config(phydev);
+int board_eth_init(bd_t *bis) +{
- int ret;
- setup_iomux_enet();
- ret = cpu_eth_init(bis);
- if (ret)
printf("FEC MXC: %s:failed\n", __func__);
+static void setup_buttons(void) +{
- imx_iomux_v3_setup_multiple_pads(button_pads,
ARRAY_SIZE(button_pads));
+int setup_sata(void) +{
- struct iomuxc_base_regs *const iomuxc_regs
= (struct iomuxc_base_regs *) IOMUXC_BASE_ADDR;
- int ret = enable_sata_clock();
- if (ret)
return ret;
- clrsetbits_le32(&iomuxc_regs->gpr[13],
IOMUXC_GPR13_SATA_MASK,
IOMUXC_GPR13_SATA_PHY_8_RXEQ_3P0DB
|IOMUXC_GPR13_SATA_PHY_7_SATA2M
|IOMUXC_GPR13_SATA_SPEED_3G
|(3<<IOMUXC_GPR13_SATA_PHY_6_SHIFT)
|IOMUXC_GPR13_SATA_SATA_PHY_5_SS_DISABLED
|IOMUXC_GPR13_SATA_SATA_PHY_4_ATTEN_9_16
|IOMUXC_GPR13_SATA_PHY_3_TXBOOST_0P00_DB
|IOMUXC_GPR13_SATA_PHY_2_TX_1P104V
|IOMUXC_GPR13_SATA_PHY_1_SLOW);
+} +#endif
+#if defined(CONFIG_VIDEO_IPUV3)
+static iomux_v3_cfg_t const backlight_pads[] = {
- /* Backlight on RGB connector: J15 */
- MX6PAD(SD1_DAT3__GPIO_1_21) | MUX_PAD_CTRL(NO_PAD_CTRL),
+#define RGB_BACKLIGHT_GP IMX_GPIO_NR(1, 21)
- /* Backlight on LVDS connector: J6 */
- MX6PAD(SD1_CMD__GPIO_1_18) | MUX_PAD_CTRL(NO_PAD_CTRL),
+#define LVDS_BACKLIGHT_GP IMX_GPIO_NR(1, 18) +};
+static iomux_v3_cfg_t const rgb_pads[] = {
- MX6PAD(DI0_DISP_CLK__IPU1_DI0_DISP_CLK),
- MX6PAD(DI0_PIN15__IPU1_DI0_PIN15),
- MX6PAD(DI0_PIN2__IPU1_DI0_PIN2),
- MX6PAD(DI0_PIN3__IPU1_DI0_PIN3),
- MX6PAD(DI0_PIN4__GPIO_4_20),
- MX6PAD(DISP0_DAT0__IPU1_DISP0_DAT_0),
- MX6PAD(DISP0_DAT1__IPU1_DISP0_DAT_1),
- MX6PAD(DISP0_DAT2__IPU1_DISP0_DAT_2),
- MX6PAD(DISP0_DAT3__IPU1_DISP0_DAT_3),
- MX6PAD(DISP0_DAT4__IPU1_DISP0_DAT_4),
- MX6PAD(DISP0_DAT5__IPU1_DISP0_DAT_5),
- MX6PAD(DISP0_DAT6__IPU1_DISP0_DAT_6),
- MX6PAD(DISP0_DAT7__IPU1_DISP0_DAT_7),
- MX6PAD(DISP0_DAT8__IPU1_DISP0_DAT_8),
- MX6PAD(DISP0_DAT9__IPU1_DISP0_DAT_9),
- MX6PAD(DISP0_DAT10__IPU1_DISP0_DAT_10),
- MX6PAD(DISP0_DAT11__IPU1_DISP0_DAT_11),
- MX6PAD(DISP0_DAT12__IPU1_DISP0_DAT_12),
- MX6PAD(DISP0_DAT13__IPU1_DISP0_DAT_13),
- MX6PAD(DISP0_DAT14__IPU1_DISP0_DAT_14),
- MX6PAD(DISP0_DAT15__IPU1_DISP0_DAT_15),
- MX6PAD(DISP0_DAT16__IPU1_DISP0_DAT_16),
- MX6PAD(DISP0_DAT17__IPU1_DISP0_DAT_17),
- MX6PAD(DISP0_DAT18__IPU1_DISP0_DAT_18),
- MX6PAD(DISP0_DAT19__IPU1_DISP0_DAT_19),
- MX6PAD(DISP0_DAT20__IPU1_DISP0_DAT_20),
- MX6PAD(DISP0_DAT21__IPU1_DISP0_DAT_21),
- MX6PAD(DISP0_DAT22__IPU1_DISP0_DAT_22),
- MX6PAD(DISP0_DAT23__IPU1_DISP0_DAT_23),
+struct display_info_t {
- int bus;
- int addr;
- int pixfmt;
- int (*detect)(struct display_info_t const *dev);
- void (*enable)(struct display_info_t const *dev);
- struct fb_videomode mode;
+static int detect_hdmi(struct display_info_t const *dev) +{
- return __raw_readb(HDMI_ARB_BASE_ADDR+HDMI_PHY_STAT0) & HDMI_PHY_HPD;
+static void enable_hdmi(struct display_info_t const *dev) +{
- u8 reg;
- printf("%s: setup HDMI monitor\n", __func__);
- reg = __raw_readb(
HDMI_ARB_BASE_ADDR
+HDMI_PHY_CONF0);
- reg |= HDMI_PHY_CONF0_PDZ_MASK;
- __raw_writeb(reg,
HDMI_ARB_BASE_ADDR
+HDMI_PHY_CONF0);
- udelay(3000);
- reg |= HDMI_PHY_CONF0_ENTMDS_MASK;
- __raw_writeb(reg,
HDMI_ARB_BASE_ADDR
+HDMI_PHY_CONF0);
- udelay(3000);
- reg |= HDMI_PHY_CONF0_GEN2_TXPWRON_MASK;
- __raw_writeb(reg,
HDMI_ARB_BASE_ADDR
+HDMI_PHY_CONF0);
- __raw_writeb(HDMI_MC_PHYRSTZ_ASSERT,
HDMI_ARB_BASE_ADDR+HDMI_MC_PHYRSTZ);
+static int detect_i2c(struct display_info_t const *dev) +{
- return ((0 == i2c_set_bus_num(dev->bus))
(0 == i2c_probe(dev->addr)));
+static void enable_lvds(struct display_info_t const *dev) +{
- struct iomuxc *iomux = (struct iomuxc *)
IOMUXC_BASE_ADDR;
- u32 reg = readl(&iomux->gpr[2]);
- reg |= IOMUXC_GPR2_DATA_WIDTH_CH0_24BIT;
- writel(reg, &iomux->gpr[2]);
- gpio_direction_output(LVDS_BACKLIGHT_GP, 1);
+static void enable_rgb(struct display_info_t const *dev) +{
rgb_pads,
ARRAY_SIZE(rgb_pads));
- gpio_direction_output(RGB_BACKLIGHT_GP, 1);
+static struct display_info_t const displays[] = {{
- .bus = -1,
- .addr = 0,
- .pixfmt = IPU_PIX_FMT_RGB24,
- .detect = detect_hdmi,
- .enable = enable_hdmi,
- .mode = {
.name = "HDMI",
.refresh = 60,
.xres = 1024,
.yres = 768,
.pixclock = 15385,
.left_margin = 220,
.right_margin = 40,
.upper_margin = 21,
.lower_margin = 7,
.hsync_len = 60,
.vsync_len = 10,
.sync = FB_SYNC_EXT,
.vmode = FB_VMODE_NONINTERLACED
- .bus = 2,
- .addr = 0x4,
- .pixfmt = IPU_PIX_FMT_LVDS666,
- .detect = detect_i2c,
- .enable = enable_lvds,
- .mode = {
.name = "Hannstar-XGA",
.refresh = 60,
.xres = 1024,
.yres = 768,
.pixclock = 15385,
.left_margin = 220,
.right_margin = 40,
.upper_margin = 21,
.lower_margin = 7,
.hsync_len = 60,
.vsync_len = 10,
- .bus = 2,
- .addr = 0x38,
- .mode = {
.name = "wsvga-lvds",
.refresh = 60,
.xres = 1024,
.yres = 600,
.pixclock = 15385,
.left_margin = 220,
.right_margin = 40,
.upper_margin = 21,
.lower_margin = 7,
.hsync_len = 60,
.vsync_len = 10,
- .bus = 2,
- .addr = 0x48,
- .pixfmt = IPU_PIX_FMT_RGB666,
- .enable = enable_rgb,
- .mode = {
.name = "wvga-rgb",
.refresh = 57,
.xres = 800,
.yres = 480,
.pixclock = 37037,
.left_margin = 40,
.right_margin = 60,
.upper_margin = 10,
.lower_margin = 10,
.hsync_len = 20,
.vsync_len = 10,
.sync = 0,
+int board_video_skip(void) +{
- int i;
- int ret;
- char const *panel = getenv("panel");
- if (!panel) {
for (i = 0; i < ARRAY_SIZE(displays); i++) {
struct display_info_t const *dev = displays+i;
if (dev->detect(dev)) {
panel = dev->mode.name;
printf("auto-detected panel %s\n", panel);
break;
if (!panel) {
panel = displays[0].mode.name;
printf("No panel detected: default to %s\n", panel);
- } else {
if (!strcmp(panel, displays[i].mode.name))
break;
- if (i < ARRAY_SIZE(displays)) {
ret = ipuv3_fb_init(&displays[i].mode, 0,
displays[i].pixfmt);
if (!ret) {
displays[i].enable(displays+i);
printf("Display: %s (%ux%u)\n",
displays[i].mode.name,
displays[i].mode.xres,
displays[i].mode.yres);
} else
printf("LCD %s cannot be configured: %d\n",
displays[i].mode.name, ret);
- } else {
printf("unsupported panel %s\n", panel);
ret = -EINVAL;
- return (0 != ret);
+static void setup_display(void) +{
- struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR;
- struct anatop_regs *anatop = (struct anatop_regs *)ANATOP_BASE_ADDR;
- struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR;
- int reg;
- /* Turn on LDB0,IPU,IPU DI0 clocks */
- reg = __raw_readl(&mxc_ccm->CCGR3);
- reg |= MXC_CCM_CCGR3_IPU1_IPU_DI0_OFFSET
|MXC_CCM_CCGR3_LDB_DI0_MASK;
- writel(reg, &mxc_ccm->CCGR3);
- /* Turn on HDMI PHY clock */
- reg = __raw_readl(&mxc_ccm->CCGR2);
- reg |= MXC_CCM_CCGR2_HDMI_TX_IAHBCLK_MASK
|MXC_CCM_CCGR2_HDMI_TX_ISFRCLK_MASK;
- writel(reg, &mxc_ccm->CCGR2);
- /* clear HDMI PHY reset */
- __raw_writeb(HDMI_MC_PHYRSTZ_DEASSERT,
- /* set PFD1_FRAC to 0x13 == 455 MHz (480*18)/0x13 */
- writel(ANATOP_PFD_480_PFD1_FRAC_MASK, &anatop->pfd_480_clr);
- writel(0x13<<ANATOP_PFD_480_PFD1_FRAC_SHIFT, &anatop->pfd_480_set);
- /* set LDB0, LDB1 clk select to 011/011 */
- reg = readl(&mxc_ccm->cs2cdr);
- reg &= ~(MXC_CCM_CS2CDR_LDB_DI0_CLK_SEL_MASK
|MXC_CCM_CS2CDR_LDB_DI1_CLK_SEL_MASK);
- reg |= (3<<MXC_CCM_CS2CDR_LDB_DI0_CLK_SEL_OFFSET)
|(3<<MXC_CCM_CS2CDR_LDB_DI1_CLK_SEL_OFFSET);
- writel(reg, &mxc_ccm->cs2cdr);
- reg = readl(&mxc_ccm->cscmr2);
- reg |= MXC_CCM_CSCMR2_LDB_DI0_IPU_DIV;
- writel(reg, &mxc_ccm->cscmr2);
- reg = readl(&mxc_ccm->chsccdr);
- reg &= ~(MXC_CCM_CHSCCDR_IPU1_DI0_PRE_CLK_SEL_MASK
|MXC_CCM_CHSCCDR_IPU1_DI0_PODF_MASK
|MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_MASK);
- reg |= (CHSCCDR_CLK_SEL_LDB_DI0
<<MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_OFFSET)
|(CHSCCDR_PODF_DIVIDE_BY_3
<<MXC_CCM_CHSCCDR_IPU1_DI0_PODF_OFFSET)
|(CHSCCDR_IPU_PRE_CLK_540M_PFD
<<MXC_CCM_CHSCCDR_IPU1_DI0_PRE_CLK_SEL_OFFSET);
- writel(reg, &mxc_ccm->chsccdr);
- reg = IOMUXC_GPR2_BGREF_RRMODE_EXTERNAL_RES
|IOMUXC_GPR2_DI1_VS_POLARITY_ACTIVE_HIGH
|IOMUXC_GPR2_DI0_VS_POLARITY_ACTIVE_LOW
|IOMUXC_GPR2_BIT_MAPPING_CH1_SPWG
|IOMUXC_GPR2_DATA_WIDTH_CH1_18BIT
|IOMUXC_GPR2_BIT_MAPPING_CH0_SPWG
|IOMUXC_GPR2_DATA_WIDTH_CH0_18BIT
|IOMUXC_GPR2_LVDS_CH1_MODE_DISABLED
|IOMUXC_GPR2_LVDS_CH0_MODE_ENABLED_DI0;
- reg = readl(&iomux->gpr[3]);
- reg = (reg & ~IOMUXC_GPR3_LVDS0_MUX_CTL_MASK)
| (IOMUXC_GPR3_MUX_SRC_IPU1_DI0
<<IOMUXC_GPR3_LVDS0_MUX_CTL_OFFSET);
- writel(reg, &iomux->gpr[3]);
- /* backlights off until needed */
- imx_iomux_v3_setup_multiple_pads(backlight_pads,
ARRAY_SIZE(backlight_pads));
- gpio_direction_input(LVDS_BACKLIGHT_GP);
- gpio_direction_input(RGB_BACKLIGHT_GP);
+} +#endif
+int board_early_init_f(void) +{
- setup_iomux_uart();
- /* Disable wl1271 For Nitrogen6w */
- gpio_direction_input(WL12XX_WL_IRQ_GP);
- gpio_direction_output(WL12XX_WL_ENABLE_GP, 0);
- gpio_direction_output(WL12XX_BT_ENABLE_GP, 0);
- imx_iomux_v3_setup_multiple_pads(wl12xx_pads, ARRAY_SIZE(wl12xx_pads));
- setup_buttons();
- setup_display();
- Do not overwrite the console
- Use always serial for U-Boot console
+int overwrite_console(void) +{
- return 1;
+int board_init(void) +{
- /* address of boot parameters */
- gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
- setup_spi();
- setup_i2c(0, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info0);
- setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info1);
- setup_i2c(2, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info2);
+#ifdef CONFIG_CMD_SATA
- setup_sata();
+int checkboard(void) +{
- if (gpio_get_value(WL12XX_WL_IRQ_GP))
puts("Board: Nitrogen6X\n");
- else
puts("Board: SABRE Lite\n");
+struct button_key {
- char const *name;
- unsigned gpnum;
- char ident;
+static struct button_key const buttons[] = {
- {"back", IMX_GPIO_NR(2, 2), 'B'},
- {"home", IMX_GPIO_NR(2, 4), 'H'},
- {"menu", IMX_GPIO_NR(2, 1), 'M'},
- {"search", IMX_GPIO_NR(2, 3), 'S'},
- {"volup", IMX_GPIO_NR(7, 13), 'V'},
- {"voldown", IMX_GPIO_NR(4, 5), 'v'},
- generate a null-terminated string containing the buttons pressed
- returns number of keys pressed
+static int read_keys(char *buf) +{
- int i, numpressed = 0;
- for (i = 0; i < ARRAY_SIZE(buttons); i++) {
if (!gpio_get_value(buttons[i].gpnum))
buf[numpressed++] = buttons[i].ident;
- buf[numpressed] = '\0';
- return numpressed;
+static int do_kbd(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{
- char envvalue[ARRAY_SIZE(buttons)+1];
- int numpressed = read_keys(envvalue);
- setenv("keybd", envvalue);
- return numpressed == 0;
+U_BOOT_CMD(
- kbd, 1, 1, do_kbd,
- "Tests for keypresses, sets 'keybd' environment variable",
- "Returns 0 (true) to shell if key is pressed."
+#ifdef CONFIG_PREBOOT +static char const kbd_magic_prefix[] = "key_magic"; +static char const kbd_command_prefix[] = "key_cmd";
+static void preboot_keys(void) +{
- int numpressed;
- char keypress[ARRAY_SIZE(buttons)+1];
- numpressed = read_keys(keypress);
- if (numpressed) {
char *kbd_magic_keys = getenv("magic_keys");
char *suffix;
* loop over all magic keys
for (suffix = kbd_magic_keys; *suffix; ++suffix) {
char *keys;
char magic[sizeof(kbd_magic_prefix) + 1];
sprintf(magic, "%s%c", kbd_magic_prefix, *suffix);
keys = getenv(magic);
if (keys) {
if (!strcmp(keys, keypress))
break;
if (*suffix) {
char cmd_name[sizeof(kbd_command_prefix) + 1];
char *cmd;
sprintf(cmd_name, "%s%c", kbd_command_prefix, *suffix);
cmd = getenv(cmd_name);
if (cmd) {
setenv("preboot", cmd);
return;
+} +#endif
+#ifdef CONFIG_CMD_BMODE +static const struct boot_mode board_boot_modes[] = {
- /* 4 bit bus width */
- {"mmc0", MAKE_CFGVAL(0x40, 0x30, 0x00, 0x00)},
- {"mmc1", MAKE_CFGVAL(0x40, 0x38, 0x00, 0x00)},
- {NULL, 0},
+}; +#endif
+int misc_init_r(void) +{ +#ifdef CONFIG_PREBOOT
- preboot_keys();
- add_board_boot_modes(board_boot_modes);
+} diff --git a/boards.cfg b/boards.cfg index 7d03620..d778f63 100644 --- a/boards.cfg +++ b/boards.cfg @@ -252,6 +252,12 @@ mx6qarm2 arm armv7 mx6qarm2 freesca mx6qsabreauto arm armv7 mx6qsabreauto freescale mx6 mx6qsabreauto:IMX_CONFIG=board/freescale/mx6qsabreauto/imximage.cfg mx6qsabrelite arm armv7 mx6qsabrelite freescale mx6 mx6qsabrelite:IMX_CONFIG=board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg mx6qsabresd arm armv7 mx6qsabresd freescale mx6 mx6qsabresd:IMX_CONFIG=board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg +nitrogen6q arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q +nitrogen6dl arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL +nitrogen6s arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s.cfg,MX6S +nitrogen6q2g arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q2g.cfg,MX6Q +nitrogen6dl2g arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl2g.cfg,MX6DL +nitrogen6s1g arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg,MX6S eco5pk arm armv7 eco5pk 8dtech omap3 cm_t35 arm armv7 cm_t35 - omap3 omap3_overo arm armv7 overo - omap3 diff --git a/drivers/usb/host/ehci-mx6.c b/drivers/usb/host/ehci-mx6.c index 1b20e41..c1ae3d9 100644 --- a/drivers/usb/host/ehci-mx6.c +++ b/drivers/usb/host/ehci-mx6.c @@ -21,7 +21,6 @@ #include <asm/io.h> #include <asm/arch/imx-regs.h> #include <asm/arch/clock.h> -#include <asm/arch/mx6x_pins.h> #include <asm/imx-common/iomux-v3.h>
Move this to a separate patch, as it is for all MX6. Add USB maintainer to the list (Marek Vasut), even if it is a small change.
#include "ehci.h" diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h new file mode 100644 index 0000000..ef6089a --- /dev/null +++ b/include/configs/nitrogen6x.h @@ -0,0 +1,284 @@ +/*
- Configuration settings for the Boundary Devices Nitrogen6X
- and Freescale i.MX6Q Sabre Lite boards.
- MA 02111-1307 USA
+#ifndef __CONFIG_H +#define __CONFIG_H
+#define CONFIG_MX6 +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO
+#define CONFIG_MACH_TYPE 3769
+#include <asm/arch/imx-regs.h> +#include <asm/imx-common/gpio.h>
+#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_REVISION_TAG
+/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (10 * 1024 * 1024)
+#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_MISC_INIT_R +#define CONFIG_MXC_GPIO
+#define CONFIG_MXC_UART +#define CONFIG_MXC_UART_BASE UART2_BASE
+#define CONFIG_CMD_SF +#ifdef CONFIG_CMD_SF +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_SST +#define CONFIG_MXC_SPI +#define CONFIG_SF_DEFAULT_BUS 0 +#define CONFIG_SF_DEFAULT_CS (0|(IMX_GPIO_NR(3, 19)<<8)) +#define CONFIG_SF_DEFAULT_SPEED 25000000 +#define CONFIG_SF_DEFAULT_MODE (SPI_MODE_0) +#endif
+/* I2C Configs */ +#define CONFIG_CMD_I2C +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_I2C_MXC +#define CONFIG_SYS_I2C_SPEED 100000
+/* OCOTP Configs */ +#define CONFIG_CMD_IMXOTP +#ifdef CONFIG_CMD_IMXOTP +#define CONFIG_IMX_OTP +#define IMX_OTP_BASE OCOTP_BASE_ADDR +#define IMX_OTP_ADDR_MAX 0x7F +#define IMX_OTP_DATA_ERROR_VAL 0xBADABADA +/* #define IMX_OTPWRITE_ENABLED */ +#endif
+/* MMC Configs */ +#define CONFIG_FSL_ESDHC +#define CONFIG_FSL_USDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 +#define CONFIG_SYS_FSL_USDHC_NUM 2
+#define CONFIG_MMC +#define CONFIG_CMD_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_BOUNCE_BUFFER +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION
+#ifdef CONFIG_MX6Q +#define CONFIG_CMD_SATA +#endif
- SATA Configs
+#ifdef CONFIG_CMD_SATA +#define CONFIG_DWC_AHSATA +#define CONFIG_SYS_SATA_MAX_DEVICE 1 +#define CONFIG_DWC_AHSATA_PORT_ID 0 +#define CONFIG_DWC_AHSATA_BASE_ADDR SATA_ARB_BASE_ADDR +#define CONFIG_LBA48 +#define CONFIG_LIBATA +#endif
+#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_MII +#define CONFIG_CMD_NET +#define CONFIG_FEC_MXC +#define CONFIG_MII +#define IMX_FEC_BASE ENET_BASE_ADDR +#define CONFIG_FEC_XCV_TYPE RGMII +#define CONFIG_ETHPRIME "FEC" +#define CONFIG_FEC_MXC_PHYADDR 6 +#define CONFIG_PHYLIB +#define CONFIG_PHY_MICREL +#define CONFIG_PHY_MICREL_KSZ9021
+/* USB Configs */ +#define CONFIG_CMD_USB +#define CONFIG_CMD_FAT +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_MX6 +#define CONFIG_USB_STORAGE +#define CONFIG_USB_HOST_ETHER +#define CONFIG_USB_ETHER_ASIX +#define CONFIG_USB_ETHER_SMSC95XX +#define CONFIG_MXC_USB_PORT 1 +#define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) +#define CONFIG_MXC_USB_FLAGS 0
+/* Miscellaneous commands */ +#define CONFIG_CMD_BMODE +#define CONFIG_CMD_SETEXPR
+/* Framebuffer and LCD */ +#define CONFIG_VIDEO +#define CONFIG_VIDEO_IPUV3 +#define CONFIG_CFB_CONSOLE +#define CONFIG_VGA_AS_SINGLE_DEVICE +#define CONFIG_SYS_CONSOLE_IS_IN_ENV +#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE +#define CONFIG_VIDEO_BMP_RLE8 +#define CONFIG_SPLASH_SCREEN +#define CONFIG_BMP_16BPP +#define CONFIG_VIDEO_LOGO +#define CONFIG_IPUV3_CLK 260000000 +#define CONFIG_CMD_HDMIDETECT +#define CONFIG_CONSOLE_MUX
+/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_CONS_INDEX 1 +#define CONFIG_BAUDRATE 115200
+/* Command definition */ +#include <config_cmd_default.h>
+#undef CONFIG_CMD_IMLS
+#define CONFIG_BOOTDELAY 1
+#define CONFIG_PREBOOT ""
+#define CONFIG_LOADADDR 0x12000000 +#define CONFIG_SYS_TEXT_BASE 0x17800000
+#ifdef CONFIG_CMD_SATA +#define CONFIG_DRIVE_SATA "sata " +#else +#define CONFIG_DRIVE_SATA +#endif
+#ifdef CONFIG_CMD_MMC +#define CONFIG_DRIVE_MMC "mmc " +#else +#define CONFIG_DRIVE_MMC +#endif
+#define CONFIG_DRIVE_TYPES CONFIG_DRIVE_SATA CONFIG_DRIVE_MMC
+#define CONFIG_EXTRA_ENV_SETTINGS \
- "console=ttymxc1\0" \
- "clearenv=if sf probe || sf probe || sf probe 1 ; then " \
"sf erase 0xc0000 0x2000 && " \
"echo restored environment to factory default ; fi\0" \
- "bootcmd=for dtype in " CONFIG_DRIVE_TYPES \
"; do " \
"for disk in 0 1 ; do ${dtype} dev ${disk} ;" \
"for fs in fat ext2 ; do " \
"${fs}load " \
"${dtype} ${disk}:1 " \
"10008000 " \
"/6x_bootscript" \
"&& source 10008000 ; " \
"done ; " \
"done ; " \
"done; " \
"setenv stdout serial,vga ; " \
"echo ; echo 6x_bootscript not found ; " \
"echo ; echo serial console at 115200, 8N1 ; echo ; " \
"echo details at http://boundarydevices.com/6q_bootscript ; " \
"setenv stdout serial\0" \
- "upgradeu=for dtype in sata mmc " CONFIG_DRIVE_TYPES \
"; do " \
"${fs}load ${dtype} ${disk}:1 10008000 " \
"/6x_upgrade " \
"done ; " \
"done ; " \
- "done\0" \
+#define CONFIG_ARP_TIMEOUT 200UL
+/* Miscellaneous configurable options */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT "U-Boot > " +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_CBSIZE 1024
+/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE
+#define CONFIG_SYS_MEMTEST_START 0x10000000 +#define CONFIG_SYS_MEMTEST_END 0x10010000
+#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR +#define CONFIG_SYS_HZ 1000
+#define CONFIG_CMDLINE_EDITING
+/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM MMDC0_ARB_BASE_ADDR +#define PHYS_SDRAM_SIZE (1u * 1024 * 1024 * 1024)
+#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE
+#define CONFIG_SYS_INIT_SP_OFFSET \
- (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
+#define CONFIG_SYS_INIT_SP_ADDR \
- (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
+/* FLASH and environment organization */ +#define CONFIG_SYS_NO_FLASH
+#define CONFIG_ENV_SIZE (8 * 1024)
+/* #define CONFIG_ENV_IS_IN_MMC */ +#define CONFIG_ENV_IS_IN_SPI_FLASH
+#if defined(CONFIG_ENV_IS_IN_MMC) +#define CONFIG_ENV_OFFSET (6 * 64 * 1024) +#define CONFIG_SYS_MMC_ENV_DEV 0 +#elif defined(CONFIG_ENV_IS_IN_SPI_FLASH) +#define CONFIG_ENV_OFFSET (768 * 1024) +#define CONFIG_ENV_SECT_SIZE (8 * 1024) +#define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS +#define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS +#define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE +#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED +#endif
+#define CONFIG_OF_LIBFDT +#define CONFIG_CMD_BOOTZ
+#define CONFIG_SYS_DCACHE_OFF
+#ifndef CONFIG_SYS_DCACHE_OFF +#define CONFIG_CMD_CACHE +#endif
+#define CONFIG_CMD_BMP
+#endif /* __CONFIG_H */
Thanks for the review, Stefano.
On 02/12/2013 02:12 AM, Stefano Babic wrote:
On 30/01/2013 19:10, Eric Nelson wrote:
This patch adds support for the Nitrogen6X board(s) from Boundary Devices. The boards are based on the i.MX6x processor family with two major variants: i.MX6Quad/6Dual i.MX6Dual-Lite/6Solo
More specifically, the board variations are: nitrogen6q i.MX6Q/6D 1GB nitrogen6dl i.MX6DL 1GB nitrogen6s i.MX6S 512MB nitrogen6q2g i.MX6Q/6D 2GB nitrogen6dl2g i.MX6DL 2GB nitrogen6s1g i.MX6S 1GB
Refer to http://boundarydevices.com/products/ for details.
Hi Eric,
some general comments in praparation your V2. I have only some minor points.
- Try to split your patch in several patches, if possible. The patch
covers different issues and the series will be easy to be review. This is mainly for the changes outside boards/boundary - I know it is not easy to split the rest.
Understood. I submitted this as one big patch to show things in context.
- I agree you put your script in the board directory instead opf trying
to use CONFIG_EXTRA_ENV_SETTINGS.
Cool.
- Agree with the split of the configuration data (clocks.cfg and ddr
setup). The same mechanism can be reused for other boards, too.
Thanks. Note that there's a bit of hand-waving for things that don't quite fit, but the essential differences in memory setup are properly partitioned.
- and agree with the nomenclature. My +1 to rename mx6x_pins.h to
mx6q_pins.h as you suggest in the cover letter.
Will do. I'll submit that before V2 of Nitrogen6X support so it can be discussed separately.
Regards,
Eric
Hi Eric,
On Wed, Jan 30, 2013 at 4:10 PM, Eric Nelson eric.nelson@boundarydevices.com wrote:
board/boundary/nitrogen6x/800mhz_2x128mx16.cfg | 37 + board/boundary/nitrogen6x/800mhz_2x256mx16.cfg | 37 + board/boundary/nitrogen6x/800mhz_4x128mx16.cfg | 37 + board/boundary/nitrogen6x/800mhz_4x256mx16.cfg | 37 +
Good work, I really like this series.
I managed to test it and added support for a mx6dl board.
I would like to suggest if you could move the different memory inits (like 800mhz_4x256mx16.cfg) into a common directory so that other boards can pull their DDR init from there when possible.
Do you think we still can make this go into 2013.04?
Thanks,
Fabio Estevam
Thanks for the review Fabio,
On 03/08/2013 03:49 PM, Fabio Estevam wrote:
Hi Eric,
Glad to hear it.
Okay, but this might be a bit of a stretch. We went through a lot of our SABRE Lite, Nitrogen6x, and Nitrogen6x SOM boards to select the right median values for the termination values and such.
These may not apply for other boards, so another level of indirection might be appropriate.
IOW, while most of the registers in the files like 800mhz_4x256mx16.cfg are for the memory **arrangement**, some of them are or could be specific to the layout and PCB fabrication details.
Yep.
Now that this guy at Freescale fixed up the HDMI stuff, I can even re-send the HDMI detect patch ;)
I'll send V2 tomorrow.
Regards,
Eric
Benoît Thébaudeau
Eric Nelson
Fabio Estevam
Stefano Babic
