imx8mp: Flashing U-Boot into eMMC hardware partition via UUU
I am using an imx8mp-evk board and I can flash the U-Boot into the eMMC hardware partition 0 by running:
=> tftpboot $loadaddr flash.bin => setexpr blkcnt $filesize + 0x1ff && setexpr blkcnt $blkcnt / 0x200 => mmc dev 2 1 => mmc write $loadaddr 0 $blkcnt
Now I want to do the same via UUU.
I tried to create a script called emmc_flash:
uuu_version 1.5.21
SDPS: boot -f flash.bin SDPS: done FB: ucmd setenv fastboot_dev mmc FB: ucmd mmc dev 2 1 FB: flash bootloader flash.bin FB: Done
Then on the PC: uuu emmc_flash
U-Boot is loaded to RAM, but the eMMC hardware partition is not programmed.
What is the correct script for doing this?
Any suggestions?
Thanks
uuu_version 1.5.21
Any suggestions?
Create an lst file
Hi Fabio
Top posting
# @_flash.bin | bootloader # @_image [_flash.bin] | image burn to nand, default is the same as bootloader # @_filesystem | filesystem to burn # @_kernel | kernel image # @_dtb | dtb image
# This command will be run when ROM support stream mode # i.MX8QXP, i.MX8QM SDPS: boot -f _flash.bin
FB: ucmd setenv fastboot_buffer ${loadaddr} FB: download -f _image # Burn image to nandfit partition if needed FB: ucmd if env exists nandfit_part; then nand erase.part nandfit; nand write ${fastboot_buffer} nandfit ${filesize}; else true; fi; FB: ucmd nandbcb init ${fastboot_buffer} nandboot ${filesize}
FB[-t 10000]: ucmd ubi part nandrootfs FB[-t 10000]: ucmd ubi create root - FB: download -f _filesystem FB[-t 60000]: ucmd ubi write ${loadaddr} root ${filesize}
FB: download -f _kernel FB[-t 10000]: ucmd nand write ${loadaddr} nandkernel ${filesize}
FB: download -f _dtb FB[-t 8000]: ucmd nand write ${loadaddr} nanddtb ${filesize}
FB: reboot FB: done
You can just change as you want. We have this file in buildroot, uuu can run command on the device using FB command. Example how call it
${OUTPUT_DIR}/host/bin/uuu -v -b ${IMAGES_DIR}/nand-full.lst \ ${IMAGES_DIR}/flash.bin \ ${IMAGES_DIR}/flash.bin \ ${IMAGES_DIR}/rootfs.ubifs \ ${IMAGES_DIR}/Image \ ${IMAGES_DIR}/freescale/imx8mn-bsh-smm-s2.dtb
Michael
Thanks
Hi Michael,
On Fri, May 10, 2024 at 11:28 AM Michael Nazzareno Trimarchi michael@amarulasolutions.com wrote:
Thanks for sharing the example.
I adapted the UUU script like this:
SDPS: boot -f flash.bin FB: ucmd setenv fastboot_buffer ${loadaddr} FB: ucmd mmc dev 2 1 FB: download -f flash.bin FB: ucmd setexpr blkcnt $filesize + 0x1ff FB: ucmd setexpr blkcnt $blkcnt / 0x200 FB: ucmd mmc write $loadaddr 0 $blkcnt FB: reboot FB: done
Did the following changes based on imx8mn_bsh_smm_s2pro:
index 024b46ef8bc2..0b6026c34309 100644 --- a/board/freescale/imx8mp_evk/imx8mp_evk.c +++ b/board/freescale/imx8mp_evk/imx8mp_evk.c @@ -3,6 +3,8 @@ * Copyright 2019 NXP */
+#include <common.h> +#include <asm/arch/sys_proto.h> #include <env.h>
int board_init(void) @@ -17,5 +19,11 @@ int board_late_init(void) env_set("board_rev", "iMX8MP"); #endif
+ if (is_usb_boot()) { + printf("***** Entering in USB download mode\n"); + env_set("bootcmd", "fastboot usb 0"); + env_set("bootdelay", "0"); + } + return 0; } diff --git a/include/configs/imx8mp_evk.h b/include/configs/imx8mp_evk.h index 1759318fdd35..148b36bd3169 100644 --- a/include/configs/imx8mp_evk.h +++ b/include/configs/imx8mp_evk.h @@ -25,8 +25,17 @@
#include <config_distro_bootcmd.h>
+#define EMMCARGS \ + "fastboot_partition_alias_all=" \ + __stringify(CONFIG_FASTBOOT_FLASH_MMC_DEV) ".0:0\0" \ + "fastboot_partition_alias_bootloader=" \ + __stringify(CONFIG_FASTBOOT_FLASH_MMC_DEV) ".1:0\0" \ + "emmc_dev=" __stringify(CONFIG_FASTBOOT_FLASH_MMC_DEV) "\0" \ + "emmc_ack=1\0" \ + /* Initial environment variables */ #define CFG_EXTRA_ENV_SETTINGS \ + EMMCARGS \ BOOTENV \ "scriptaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ "kernel_addr_r=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \
and now UUU correctly flashes the eMMC hardware partition.
Thanks a lot,
Fabio Estevam
Hi Fabio
On Fri, May 10, 2024 at 5:10 PM Fabio Estevam festevam@gmail.com wrote:
Hi Michael,
My suggestion is use timeout of some command when is possible
FB: reboot FB: done
- Copyright 2019 NXP
I think that is kind of good example
+#define EMMCARGS \
"emmc_ack=1\0" \
Thanks a lot,
No problem
Micheal
Fabio Estevam
Fabio Estevam
