[U-Boot] [PATCH 1/3] Integrate USB gadget layer and USB CDC driver layer
Derived from Linux kernel 2.6.27
Signed-off-by: Thomas Smits ts.smits@gmail.com Signed-off-by: Remy Bohmer linux@bohmer.net --- drivers/usb/gadget/Makefile | 3 + drivers/usb/gadget/config.c | 119 +++ drivers/usb/gadget/epautoconf.c | 306 ++++++ drivers/usb/gadget/ether.c | 1947 +++++++++++++++++++++++++++++++++++++ drivers/usb/gadget/gadget_chips.h | 219 +++++ drivers/usb/gadget/usbstring.c | 134 +++ include/linux/usb/cdc.h | 224 +++++ include/linux/usb/ch9.h | 587 +++++++++++ include/linux/usb/gadget.h | 871 +++++++++++++++++ include/net.h | 17 +- 10 files changed, 4425 insertions(+), 2 deletions(-) create mode 100644 drivers/usb/gadget/config.c create mode 100644 drivers/usb/gadget/epautoconf.c create mode 100644 drivers/usb/gadget/ether.c create mode 100644 drivers/usb/gadget/gadget_chips.h create mode 100644 drivers/usb/gadget/usbstring.c create mode 100644 include/linux/usb/cdc.h create mode 100644 include/linux/usb/ch9.h create mode 100644 include/linux/usb/gadget.h
diff --git a/drivers/usb/gadget/Makefile b/drivers/usb/gadget/Makefile index 1d7362d..9b1b55b 100644 --- a/drivers/usb/gadget/Makefile +++ b/drivers/usb/gadget/Makefile @@ -25,6 +25,7 @@ include $(TOPDIR)/config.mk
LIB := $(obj)libusb_gadget.a
+# Devices not related to the new gadget layer depend on CONFIG_USB_DEVICE ifdef CONFIG_USB_DEVICE COBJS-y += core.o COBJS-y += ep0.o @@ -34,6 +35,8 @@ COBJS-$(CONFIG_MPC885_FAMILY) += mpc8xx_udc.o COBJS-$(CONFIG_PXA27X) += pxa27x_udc.o COBJS-$(CONFIG_SPEARUDC) += spr_udc.o endif +# new USB gadget layer dependencies +COBJS-$(CONFIG_USB_ETHER) += ether.o epautoconf.o config.o usbstring.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/usb/gadget/config.c b/drivers/usb/gadget/config.c new file mode 100644 index 0000000..84c90f0 --- /dev/null +++ b/drivers/usb/gadget/config.c @@ -0,0 +1,119 @@ +/* + * usb/gadget/config.c -- simplify building config descriptors + * + * Copyright (C) 2003 David Brownell + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + * Ported to U-boot by: Thomas Smits ts.smits@gmail.com and + * Remy Bohmer linux@bohmer.net + */ + +#include <common.h> +#include <asm/errno.h> +#include <linux/list.h> +#include <linux/string.h> + +#include <linux/usb/ch9.h> +#include <linux/usb/gadget.h> + + +/** + * usb_descriptor_fillbuf - fill buffer with descriptors + * @buf: Buffer to be filled + * @buflen: Size of buf + * @src: Array of descriptor pointers, terminated by null pointer. + * + * Copies descriptors into the buffer, returning the length or a + * negative error code if they can't all be copied. Useful when + * assembling descriptors for an associated set of interfaces used + * as part of configuring a composite device; or in other cases where + * sets of descriptors need to be marshaled. + */ +int +usb_descriptor_fillbuf(void *buf, unsigned buflen, + const struct usb_descriptor_header **src) +{ + u8 *dest = buf; + + if (!src) + return -EINVAL; + + /* fill buffer from src[] until null descriptor ptr */ + for (; NULL != *src; src++) { + unsigned len = (*src)->bLength; + + if (len > buflen) + return -EINVAL; + memcpy(dest, *src, len); + buflen -= len; + dest += len; + } + return dest - (u8 *)buf; +} + + +/** + * usb_gadget_config_buf - builts a complete configuration descriptor + * @config: Header for the descriptor, including characteristics such + * as power requirements and number of interfaces. + * @desc: Null-terminated vector of pointers to the descriptors (interface, + * endpoint, etc) defining all functions in this device configuration. + * @buf: Buffer for the resulting configuration descriptor. + * @length: Length of buffer. If this is not big enough to hold the + * entire configuration descriptor, an error code will be returned. + * + * This copies descriptors into the response buffer, building a descriptor + * for that configuration. It returns the buffer length or a negative + * status code. The config.wTotalLength field is set to match the length + * of the result, but other descriptor fields (including power usage and + * interface count) must be set by the caller. + * + * Gadget drivers could use this when constructing a config descriptor + * in response to USB_REQ_GET_DESCRIPTOR. They will need to patch the + * resulting bDescriptorType value if USB_DT_OTHER_SPEED_CONFIG is needed. + */ +int usb_gadget_config_buf( + const struct usb_config_descriptor *config, + void *buf, + unsigned length, + const struct usb_descriptor_header **desc +) +{ + struct usb_config_descriptor *cp = buf; + int len; + + /* config descriptor first */ + if (length < USB_DT_CONFIG_SIZE || !desc) + return -EINVAL; + *cp = *config; + + /* then interface/endpoint/class/vendor/... */ + len = usb_descriptor_fillbuf(USB_DT_CONFIG_SIZE + (u8*)buf, + length - USB_DT_CONFIG_SIZE, desc); + if (len < 0) + return len; + len += USB_DT_CONFIG_SIZE; + if (len > 0xffff) + return -EINVAL; + + /* patch up the config descriptor */ + cp->bLength = USB_DT_CONFIG_SIZE; + cp->bDescriptorType = USB_DT_CONFIG; + cp->wTotalLength = cpu_to_le16(len); + cp->bmAttributes |= USB_CONFIG_ATT_ONE; + return len; +} + diff --git a/drivers/usb/gadget/epautoconf.c b/drivers/usb/gadget/epautoconf.c new file mode 100644 index 0000000..c7fad39 --- /dev/null +++ b/drivers/usb/gadget/epautoconf.c @@ -0,0 +1,306 @@ +/* + * epautoconf.c -- endpoint autoconfiguration for usb gadget drivers + * + * Copyright (C) 2004 David Brownell + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + * Ported to U-boot by: Thomas Smits ts.smits@gmail.com and + * Remy Bohmer linux@bohmer.net + */ + +#include <common.h> +#include <linux/usb/ch9.h> +#include <asm/errno.h> +#include <linux/usb/gadget.h> +#include "gadget_chips.h" + +#define isdigit(c) ('0' <= (c) && (c) <= '9') + +/* we must assign addresses for configurable endpoints (like net2280) */ +static unsigned epnum; + +// #define MANY_ENDPOINTS +#ifdef MANY_ENDPOINTS +/* more than 15 configurable endpoints */ +static unsigned in_epnum; +#endif + + +/* + * This should work with endpoints from controller drivers sharing the + * same endpoint naming convention. By example: + * + * - ep1, ep2, ... address is fixed, not direction or type + * - ep1in, ep2out, ... address and direction are fixed, not type + * - ep1-bulk, ep2-bulk, ... address and type are fixed, not direction + * - ep1in-bulk, ep2out-iso, ... all three are fixed + * - ep-* ... no functionality restrictions + * + * Type suffixes are "-bulk", "-iso", or "-int". Numbers are decimal. + * Less common restrictions are implied by gadget_is_*(). + * + * NOTE: each endpoint is unidirectional, as specified by its USB + * descriptor; and isn't specific to a configuration or altsetting. + */ +static int +ep_matches ( + struct usb_gadget *gadget, + struct usb_ep *ep, + struct usb_endpoint_descriptor *desc +) +{ + u8 type; + const char *tmp; + u16 max; + + /* endpoint already claimed? */ + if (NULL != ep->driver_data) + return 0; + + /* only support ep0 for portable CONTROL traffic */ + type = desc->bmAttributes & USB_ENDPOINT_XFERTYPE_MASK; + if (USB_ENDPOINT_XFER_CONTROL == type) + return 0; + + /* some other naming convention */ + if ('e' != ep->name[0]) + return 0; + + /* type-restriction: "-iso", "-bulk", or "-int". + * direction-restriction: "in", "out". + */ + if ('-' != ep->name[2]) { + tmp = strrchr (ep->name, '-'); + if (tmp) { + switch (type) { + case USB_ENDPOINT_XFER_INT: + /* bulk endpoints handle interrupt transfers, + * except the toggle-quirky iso-synch kind + */ + if ('s' == tmp[2]) // == "-iso" + return 0; + /* for now, avoid PXA "interrupt-in"; + * it's documented as never using DATA1. + */ + if (gadget_is_pxa (gadget) + && 'i' == tmp [1]) + return 0; + break; + case USB_ENDPOINT_XFER_BULK: + if ('b' != tmp[1]) // != "-bulk" + return 0; + break; + case USB_ENDPOINT_XFER_ISOC: + if ('s' != tmp[2]) // != "-iso" + return 0; + } + } else { + tmp = ep->name + strlen (ep->name); + } + + /* direction-restriction: "..in-..", "out-.." */ + tmp--; + if (!isdigit (*tmp)) { + if (desc->bEndpointAddress & USB_DIR_IN) { + if ('n' != *tmp) + return 0; + } else { + if ('t' != *tmp) + return 0; + } + } + } + + /* endpoint maxpacket size is an input parameter, except for bulk + * where it's an output parameter representing the full speed limit. + * the usb spec fixes high speed bulk maxpacket at 512 bytes. + */ + max = 0x7ff & le16_to_cpu(desc->wMaxPacketSize); + switch (type) { + case USB_ENDPOINT_XFER_INT: + /* INT: limit 64 bytes full speed, 1024 high speed */ + if (!gadget->is_dualspeed && max > 64) + return 0; + /* FALLTHROUGH */ + + case USB_ENDPOINT_XFER_ISOC: + /* ISO: limit 1023 bytes full speed, 1024 high speed */ + if (ep->maxpacket < max) + return 0; + if (!gadget->is_dualspeed && max > 1023) + return 0; + + /* BOTH: "high bandwidth" works only at high speed */ + if ((desc->wMaxPacketSize & __constant_cpu_to_le16(3<<11))) { + if (!gadget->is_dualspeed) + return 0; + /* configure your hardware with enough buffering!! */ + } + break; + } + + /* MATCH!! */ + + /* report address */ + if (isdigit (ep->name [2])) { + u8 num = simple_strtol (&ep->name [2], NULL, 10); + desc->bEndpointAddress |= num; +#ifdef MANY_ENDPOINTS + } else if (desc->bEndpointAddress & USB_DIR_IN) { + if (++in_epnum > 15) + return 0; + desc->bEndpointAddress = USB_DIR_IN | in_epnum; +#endif + } else { + if (++epnum > 15) + return 0; + desc->bEndpointAddress |= epnum; + } + + /* report (variable) full speed bulk maxpacket */ + if (USB_ENDPOINT_XFER_BULK == type) { + int size = ep->maxpacket; + + /* min() doesn't work on bitfields with gcc-3.5 */ + if (size > 64) + size = 64; + desc->wMaxPacketSize = cpu_to_le16(size); + } + return 1; +} + +static struct usb_ep * +find_ep (struct usb_gadget *gadget, const char *name) +{ + struct usb_ep *ep; + + list_for_each_entry (ep, &gadget->ep_list, ep_list) { + if (0 == strcmp (ep->name, name)) + return ep; + } + return NULL; +} + +/** + * usb_ep_autoconfig - choose an endpoint matching the descriptor + * @gadget: The device to which the endpoint must belong. + * @desc: Endpoint descriptor, with endpoint direction and transfer mode + * initialized. For periodic transfers, the maximum packet + * size must also be initialized. This is modified on success. + * + * By choosing an endpoint to use with the specified descriptor, this + * routine simplifies writing gadget drivers that work with multiple + * USB device controllers. The endpoint would be passed later to + * usb_ep_enable(), along with some descriptor. + * + * That second descriptor won't always be the same as the first one. + * For example, isochronous endpoints can be autoconfigured for high + * bandwidth, and then used in several lower bandwidth altsettings. + * Also, high and full speed descriptors will be different. + * + * Be sure to examine and test the results of autoconfiguration on your + * hardware. This code may not make the best choices about how to use the + * USB controller, and it can't know all the restrictions that may apply. + * Some combinations of driver and hardware won't be able to autoconfigure. + * + * On success, this returns an un-claimed usb_ep, and modifies the endpoint + * descriptor bEndpointAddress. For bulk endpoints, the wMaxPacket value + * is initialized as if the endpoint were used at full speed. To prevent + * the endpoint from being returned by a later autoconfig call, claim it + * by assigning ep->driver_data to some non-null value. + * + * On failure, this returns a null endpoint descriptor. + */ +struct usb_ep * usb_ep_autoconfig ( + struct usb_gadget *gadget, + struct usb_endpoint_descriptor *desc +) +{ + struct usb_ep *ep; + u8 type; + + type = desc->bmAttributes & USB_ENDPOINT_XFERTYPE_MASK; + + /* First, apply chip-specific "best usage" knowledge. + * This might make a good usb_gadget_ops hook ... + */ + if (gadget_is_net2280 (gadget) && type == USB_ENDPOINT_XFER_INT) { + /* ep-e, ep-f are PIO with only 64 byte fifos */ + ep = find_ep (gadget, "ep-e"); + if (ep && ep_matches (gadget, ep, desc)) + return ep; + ep = find_ep (gadget, "ep-f"); + if (ep && ep_matches (gadget, ep, desc)) + return ep; + + } else if (gadget_is_goku (gadget)) { + if (USB_ENDPOINT_XFER_INT == type) { + /* single buffering is enough */ + ep = find_ep (gadget, "ep3-bulk"); + if (ep && ep_matches (gadget, ep, desc)) + return ep; + } else if (USB_ENDPOINT_XFER_BULK == type + && (USB_DIR_IN & desc->bEndpointAddress)) { + /* DMA may be available */ + ep = find_ep (gadget, "ep2-bulk"); + if (ep && ep_matches (gadget, ep, desc)) + return ep; + } + + } else if (gadget_is_sh (gadget) && USB_ENDPOINT_XFER_INT == type) { + /* single buffering is enough; maybe 8 byte fifo is too */ + ep = find_ep (gadget, "ep3in-bulk"); + if (ep && ep_matches (gadget, ep, desc)) + return ep; + + } else if (gadget_is_mq11xx (gadget) && USB_ENDPOINT_XFER_INT == type) { + ep = find_ep (gadget, "ep1-bulk"); + if (ep && ep_matches (gadget, ep, desc)) + return ep; + } + + /* Second, look at endpoints until an unclaimed one looks usable */ + list_for_each_entry (ep, &gadget->ep_list, ep_list) { + if (ep_matches (gadget, ep, desc)) + return ep; + } + + /* Fail */ + return NULL; +} + +/** + * usb_ep_autoconfig_reset - reset endpoint autoconfig state + * @gadget: device for which autoconfig state will be reset + * + * Use this for devices where one configuration may need to assign + * endpoint resources very differently from the next one. It clears + * state such as ep->driver_data and the record of assigned endpoints + * used by usb_ep_autoconfig(). + */ +void usb_ep_autoconfig_reset (struct usb_gadget *gadget) +{ + struct usb_ep *ep; + + list_for_each_entry (ep, &gadget->ep_list, ep_list) { + ep->driver_data = NULL; + } +#ifdef MANY_ENDPOINTS + in_epnum = 0; +#endif + epnum = 0; +} + diff --git a/drivers/usb/gadget/ether.c b/drivers/usb/gadget/ether.c new file mode 100644 index 0000000..3d871fa --- /dev/null +++ b/drivers/usb/gadget/ether.c @@ -0,0 +1,1947 @@ +/* + * ether.c -- Ethernet gadget driver, with CDC and non-CDC options + * + * Copyright (C) 2003-2005,2008 David Brownell + * Copyright (C) 2003-2004 Robert Schwebel, Benedikt Spranger + * Copyright (C) 2008 Nokia Corporation + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/errno.h> +#include <linux/usb/ch9.h> +#include <linux/usb/cdc.h> +#include <linux/usb/gadget.h> +#include <net.h> +#include <linux/ctype.h> + +#include "gadget_chips.h" + +#define USB_NET_NAME "usb0" +#define dprintf(x, ...) +#undef INFO +#define INFO(x, s...) printf(s) +#define dev_err(x, stuff...) printf(stuff) +#define dev_dbg dev_err +#define dev_warn dev_err +#define DEBUG dev_err +#define VDEBUG DEBUG +#define atomic_read +extern struct platform_data brd; +#define spin_lock(x) +#define spin_unlock(x) + + +unsigned packet_received, packet_sent; + +#define DEV_CONFIG_CDC 1 +#define GFP_ATOMIC ((gfp_t) 0) +#define GFP_KERNEL ((gfp_t) 0) + +/* + * Ethernet gadget driver -- with CDC and non-CDC options + * Builds on hardware support for a full duplex link. + * + * CDC Ethernet is the standard USB solution for sending Ethernet frames + * using USB. Real hardware tends to use the same framing protocol but look + * different for control features. This driver strongly prefers to use + * this USB-IF standard as its open-systems interoperability solution; + * most host side USB stacks (except from Microsoft) support it. + * + * This is sometimes called "CDC ECM" (Ethernet Control Model) to support + * TLA-soup. "CDC ACM" (Abstract Control Model) is for modems, and a new + * "CDC EEM" (Ethernet Emulation Model) is starting to spread. + * + * There's some hardware that can't talk CDC ECM. We make that hardware + * implement a "minimalist" vendor-agnostic CDC core: same framing, but + * link-level setup only requires activating the configuration. Only the + * endpoint descriptors, and product/vendor IDs, are relevant; no control + * operations are available. Linux supports it, but other host operating + * systems may not. (This is a subset of CDC Ethernet.) + * + * It turns out that if you add a few descriptors to that "CDC Subset", + * (Windows) host side drivers from MCCI can treat it as one submode of + * a proprietary scheme called "SAFE" ... without needing to know about + * specific product/vendor IDs. So we do that, making it easier to use + * those MS-Windows drivers. Those added descriptors make it resemble a + * CDC MDLM device, but they don't change device behavior at all. (See + * MCCI Engineering report 950198 "SAFE Networking Functions".) + * + * A third option is also in use. Rather than CDC Ethernet, or something + * simpler, Microsoft pushes their own approach: RNDIS. The published + * RNDIS specs are ambiguous and appear to be incomplete, and are also + * needlessly complex. They borrow more from CDC ACM than CDC ECM. + */ +#define ETH_ALEN 6 /* Octets in one ethernet addr */ +#define ETH_HLEN 14 /* Total octets in header. */ +#define ETH_ZLEN 60 /* Min. octets in frame sans FCS */ +#define ETH_DATA_LEN 1500 /* Max. octets in payload */ +#define ETH_FRAME_LEN PKTSIZE_ALIGN /* Max. octets in frame sans FCS */ +#define ETH_FCS_LEN 4 /* Octets in the FCS */ + +#define DRIVER_DESC "Ethernet Gadget" +/* Based on linux 2.6.27 version */ +#define DRIVER_VERSION "May Day 2005" + +static const char shortname [] = "ether"; +static const char driver_desc [] = DRIVER_DESC; + +#define RX_EXTRA 20 /* guard against rx overflows */ + +/* CDC support the same host-chosen outgoing packet filters. */ +#define DEFAULT_FILTER (USB_CDC_PACKET_TYPE_BROADCAST \ + |USB_CDC_PACKET_TYPE_ALL_MULTICAST \ + |USB_CDC_PACKET_TYPE_PROMISCUOUS \ + |USB_CDC_PACKET_TYPE_DIRECTED) + +#define USB_CONNECT_TIMEOUT (3 * CONFIG_SYS_HZ) + +/*-------------------------------------------------------------------------*/ +static struct eth_dev l_ethdev; +static struct eth_device l_netdev; +static struct usb_gadget_driver eth_driver; + +/*-------------------------------------------------------------------------*/ + +/* "main" config is either CDC, or its simple subset */ +static inline int is_cdc(struct eth_dev *dev) +{ +#if !defined(DEV_CONFIG_SUBSET) + return 1; /* only cdc possible */ +#elif !defined (DEV_CONFIG_CDC) + return 0; /* only subset possible */ +#else + return dev->cdc; /* depends on what hardware we found */ +#endif +} + +#define subset_active(dev) (!is_cdc(dev)) +#define cdc_active(dev) ( is_cdc(dev)) + +#define DEFAULT_QLEN 2 /* double buffering by default */ + +/* peak bulk transfer bits-per-second */ +#define HS_BPS (13 * 512 * 8 * 1000 * 8) +#define FS_BPS (19 * 64 * 1 * 1000 * 8) + +#ifdef CONFIG_USB_GADGET_DUALSPEED +#define DEVSPEED USB_SPEED_HIGH + +/* for dual-speed hardware, use deeper queues at highspeed */ +#define qlen(gadget) \ + (DEFAULT_QLEN*((gadget->speed == USB_SPEED_HIGH) ? qmult : 1)) + +static inline int BITRATE(struct usb_gadget *g) +{ + return (g->speed == USB_SPEED_HIGH) ? HS_BPS : FS_BPS; +} + +#else /* full speed (low speed doesn't do bulk) */ + +#define qmult 1 + +#define DEVSPEED USB_SPEED_FULL + +#define qlen(gadget) DEFAULT_QLEN + +static inline int BITRATE(struct usb_gadget *g) +{ + return FS_BPS; +} +#endif + +struct eth_dev { + struct usb_gadget *gadget; + struct usb_request *req; /* for control responses */ + struct usb_request *stat_req; /* for cdc status */ + + u8 config; + struct usb_ep *in_ep, *out_ep, *status_ep; + const struct usb_endpoint_descriptor + *in, *out, *status; + + struct usb_request *tx_req, *rx_req; + + struct eth_device *net; + unsigned int tx_qlen; + + unsigned zlp:1; + unsigned cdc:1; + unsigned suspended:1; + unsigned network_started:1; + u16 cdc_filter; + unsigned long todo; + int mtu; +#define WORK_RX_MEMORY 0 + u8 host_mac [ETH_ALEN]; +}; + +/* This version autoconfigures as much as possible at run-time. + * + * It also ASSUMES a self-powered device, without remote wakeup, + * although remote wakeup support would make sense. + */ + +/*-------------------------------------------------------------------------*/ + +/* DO NOT REUSE THESE IDs with a protocol-incompatible driver!! Ever!! + * Instead: allocate your own, using normal USB-IF procedures. + */ + +/* Thanks to NetChip Technologies for donating this product ID. + * It's for devices with only CDC Ethernet configurations. + */ +#define CDC_VENDOR_NUM 0x0525 /* NetChip */ +#define CDC_PRODUCT_NUM 0xa4a1 /* Linux-USB Ethernet Gadget */ + +/* For hardware that can't talk CDC, we use the same vendor ID that + * ARM Linux has used for ethernet-over-usb, both with sa1100 and + * with pxa250. We're protocol-compatible, if the host-side drivers + * use the endpoint descriptors. bcdDevice (version) is nonzero, so + * drivers that need to hard-wire endpoint numbers have a hook. + * + * The protocol is a minimal subset of CDC Ether, which works on any bulk + * hardware that's not deeply broken ... even on hardware that can't talk + * RNDIS (like SA-1100, with no interrupt endpoint, or anything that + * doesn't handle control-OUT). + */ +#define SIMPLE_VENDOR_NUM 0x049f +#define SIMPLE_PRODUCT_NUM 0x505a + +/* Some systems will want different product identifers published in the + * device descriptor, either numbers or strings or both. These string + * parameters are in UTF-8 (superset of ASCII's 7 bit characters). + */ + +static ushort bcdDevice; +#if defined(CONFIG_USBNET_MANUFACTURER) +static char *iManufacturer = CONFIG_USBNET_MANUFACTURER; +#else +static char *iManufacturer = "U-boot"; +#endif +static char *iProduct; +static char *iSerialNumber; +static char dev_addr[18]; +static char host_addr[18]; + +/*-------------------------------------------------------------------------*/ + +/* USB DRIVER HOOKUP (to the hardware driver, below us), mostly + * ep0 implementation: descriptors, config management, setup(). + * also optional class-specific notification interrupt transfer. + */ + +/* + * DESCRIPTORS ... most are static, but strings and (full) configuration + * descriptors are built on demand. For now we do either full CDC, or + * our simple subset. + */ + +#define STRING_MANUFACTURER 1 +#define STRING_PRODUCT 2 +#define STRING_ETHADDR 3 +#define STRING_DATA 4 +#define STRING_CONTROL 5 +#define STRING_CDC 7 +#define STRING_SUBSET 8 +#define STRING_SERIALNUMBER 10 + +/* holds our biggest descriptor */ +#define USB_BUFSIZ 256 + +/* + * This device advertises one configuration, eth_config, + * on hardware supporting at least two configs. + * + * FIXME define some higher-powered configurations to make it easier + * to recharge batteries ... + */ + +#define DEV_CONFIG_VALUE 1 /* cdc or subset */ + +static struct usb_device_descriptor +device_desc = { + .bLength = sizeof device_desc, + .bDescriptorType = USB_DT_DEVICE, + + .bcdUSB = __constant_cpu_to_le16 (0x0200), + + .bDeviceClass = USB_CLASS_COMM, + .bDeviceSubClass = 0, + .bDeviceProtocol = 0, + + .idVendor = __constant_cpu_to_le16 (CDC_VENDOR_NUM), + .idProduct = __constant_cpu_to_le16 (CDC_PRODUCT_NUM), + .iManufacturer = STRING_MANUFACTURER, + .iProduct = STRING_PRODUCT, + .bNumConfigurations = 1, +}; + +static struct usb_otg_descriptor +otg_descriptor = { + .bLength = sizeof otg_descriptor, + .bDescriptorType = USB_DT_OTG, + + .bmAttributes = USB_OTG_SRP, +}; + +static struct usb_config_descriptor +eth_config = { + .bLength = sizeof eth_config, + .bDescriptorType = USB_DT_CONFIG, + + /* compute wTotalLength on the fly */ + .bNumInterfaces = 2, + .bConfigurationValue = DEV_CONFIG_VALUE, + .iConfiguration = STRING_CDC, + .bmAttributes = USB_CONFIG_ATT_ONE | USB_CONFIG_ATT_SELFPOWER, + .bMaxPower = 1, +}; + +/* + * Compared to the simple CDC subset, the full CDC Ethernet model adds + * three class descriptors, two interface descriptors, optional status + * endpoint. Both have a "data" interface and two bulk endpoints. + * There are also differences in how control requests are handled. + */ + +#ifdef DEV_CONFIG_CDC +static struct usb_interface_descriptor +control_intf = { + .bLength = sizeof control_intf, + .bDescriptorType = USB_DT_INTERFACE, + + .bInterfaceNumber = 0, + /* status endpoint is optional; this may be patched later */ + .bNumEndpoints = 1, + .bInterfaceClass = USB_CLASS_COMM, + .bInterfaceSubClass = USB_CDC_SUBCLASS_ETHERNET, + .bInterfaceProtocol = USB_CDC_PROTO_NONE, + .iInterface = STRING_CONTROL, +}; +#endif + +static const struct usb_cdc_header_desc header_desc = { + .bLength = sizeof header_desc, + .bDescriptorType = USB_DT_CS_INTERFACE, + .bDescriptorSubType = USB_CDC_HEADER_TYPE, + + .bcdCDC = __constant_cpu_to_le16 (0x0110), +}; + +#if defined(DEV_CONFIG_CDC) + +static const struct usb_cdc_union_desc union_desc = { + .bLength = sizeof union_desc, + .bDescriptorType = USB_DT_CS_INTERFACE, + .bDescriptorSubType = USB_CDC_UNION_TYPE, + + .bMasterInterface0 = 0, /* index of control interface */ + .bSlaveInterface0 = 1, /* index of DATA interface */ +}; + +#endif /* CDC */ + +#ifndef DEV_CONFIG_CDC + +/* "SAFE" loosely follows CDC WMC MDLM, violating the spec in various + * ways: data endpoints live in the control interface, there's no data + * interface, and it's not used to talk to a cell phone radio. + */ + +static const struct usb_cdc_mdlm_desc mdlm_desc = { + .bLength = sizeof mdlm_desc, + .bDescriptorType = USB_DT_CS_INTERFACE, + .bDescriptorSubType = USB_CDC_MDLM_TYPE, + + .bcdVersion = __constant_cpu_to_le16(0x0100), + .bGUID = { + 0x5d, 0x34, 0xcf, 0x66, 0x11, 0x18, 0x11, 0xd6, + 0xa2, 0x1a, 0x00, 0x01, 0x02, 0xca, 0x9a, 0x7f, + }, +}; + +/* since "usb_cdc_mdlm_detail_desc" is a variable length structure, we + * can't really use its struct. All we do here is say that we're using + * the submode of "SAFE" which directly matches the CDC Subset. + */ +static const u8 mdlm_detail_desc[] = { + 6, + USB_DT_CS_INTERFACE, + USB_CDC_MDLM_DETAIL_TYPE, + + 0, /* "SAFE" */ + 0, /* network control capabilities (none) */ + 0, /* network data capabilities ("raw" encapsulation) */ +}; + +#endif + + +static const struct usb_cdc_ether_desc ether_desc = { + .bLength = sizeof (ether_desc), + .bDescriptorType = USB_DT_CS_INTERFACE, + .bDescriptorSubType = USB_CDC_ETHERNET_TYPE, + + /* this descriptor actually adds value, surprise! */ + .iMACAddress = STRING_ETHADDR, + .bmEthernetStatistics = __constant_cpu_to_le32 (0), /* no statistics */ + .wMaxSegmentSize = __constant_cpu_to_le16 (ETH_FRAME_LEN), + .wNumberMCFilters = __constant_cpu_to_le16 (0), + .bNumberPowerFilters = 0, +}; + + +#if defined(DEV_CONFIG_CDC) + +/* include the status endpoint if we can, even where it's optional. + * use wMaxPacketSize big enough to fit CDC_NOTIFY_SPEED_CHANGE in one + * packet, to simplify cancellation; and a big transfer interval, to + * waste less bandwidth. + * + * some drivers (like Linux 2.4 cdc-ether!) "need" it to exist even + * if they ignore the connect/disconnect notifications that real aether + * can provide. more advanced cdc configurations might want to support + * encapsulated commands (vendor-specific, using control-OUT). + */ + +#define LOG2_STATUS_INTERVAL_MSEC 5 /* 1 << 5 == 32 msec */ +#define STATUS_BYTECOUNT 16 /* 8 byte header + data */ + +static struct usb_endpoint_descriptor +fs_status_desc = { + .bLength = USB_DT_ENDPOINT_SIZE, + .bDescriptorType = USB_DT_ENDPOINT, + + .bEndpointAddress = USB_DIR_IN, + .bmAttributes = USB_ENDPOINT_XFER_INT, + .wMaxPacketSize = __constant_cpu_to_le16 (STATUS_BYTECOUNT), + .bInterval = 1 << LOG2_STATUS_INTERVAL_MSEC, +}; +#endif + +#ifdef DEV_CONFIG_CDC + +/* the default data interface has no endpoints ... */ + +static const struct usb_interface_descriptor +data_nop_intf = { + .bLength = sizeof data_nop_intf, + .bDescriptorType = USB_DT_INTERFACE, + + .bInterfaceNumber = 1, + .bAlternateSetting = 0, + .bNumEndpoints = 0, + .bInterfaceClass = USB_CLASS_CDC_DATA, + .bInterfaceSubClass = 0, + .bInterfaceProtocol = 0, +}; + +/* ... but the "real" data interface has two bulk endpoints */ + +static const struct usb_interface_descriptor +data_intf = { + .bLength = sizeof data_intf, + .bDescriptorType = USB_DT_INTERFACE, + + .bInterfaceNumber = 1, + .bAlternateSetting = 1, + .bNumEndpoints = 2, + .bInterfaceClass = USB_CLASS_CDC_DATA, + .bInterfaceSubClass = 0, + .bInterfaceProtocol = 0, + .iInterface = STRING_DATA, +}; + +#endif + +#ifdef DEV_CONFIG_SUBSET + +/* + * "Simple" CDC-subset option is a simple vendor-neutral model that most + * full speed controllers can handle: one interface, two bulk endpoints. + * + * To assist host side drivers, we fancy it up a bit, and add descriptors + * so some host side drivers will understand it as a "SAFE" variant. + */ + +static const struct usb_interface_descriptor +subset_data_intf = { + .bLength = sizeof subset_data_intf, + .bDescriptorType = USB_DT_INTERFACE, + + .bInterfaceNumber = 0, + .bAlternateSetting = 0, + .bNumEndpoints = 2, + .bInterfaceClass = USB_CLASS_COMM, + .bInterfaceSubClass = USB_CDC_SUBCLASS_MDLM, + .bInterfaceProtocol = 0, + .iInterface = STRING_DATA, +}; + +#endif /* SUBSET */ + + +static struct usb_endpoint_descriptor +fs_source_desc = { + .bLength = USB_DT_ENDPOINT_SIZE, + .bDescriptorType = USB_DT_ENDPOINT, + + .bEndpointAddress = USB_DIR_IN, + .bmAttributes = USB_ENDPOINT_XFER_BULK, +}; + +static struct usb_endpoint_descriptor +fs_sink_desc = { + .bLength = USB_DT_ENDPOINT_SIZE, + .bDescriptorType = USB_DT_ENDPOINT, + + .bEndpointAddress = USB_DIR_OUT, + .bmAttributes = USB_ENDPOINT_XFER_BULK, +}; + +static const struct usb_descriptor_header *fs_eth_function [11] = { + (struct usb_descriptor_header *) &otg_descriptor, +#ifdef DEV_CONFIG_CDC + /* "cdc" mode descriptors */ + (struct usb_descriptor_header *) &control_intf, + (struct usb_descriptor_header *) &header_desc, + (struct usb_descriptor_header *) &union_desc, + (struct usb_descriptor_header *) ðer_desc, + /* NOTE: status endpoint may need to be removed */ + (struct usb_descriptor_header *) &fs_status_desc, + /* data interface, with altsetting */ + (struct usb_descriptor_header *) &data_nop_intf, + (struct usb_descriptor_header *) &data_intf, + (struct usb_descriptor_header *) &fs_source_desc, + (struct usb_descriptor_header *) &fs_sink_desc, + NULL, +#endif /* DEV_CONFIG_CDC */ +}; + +static inline void fs_subset_descriptors(void) +{ +#ifdef DEV_CONFIG_SUBSET + /* behavior is "CDC Subset"; extra descriptors say "SAFE" */ + fs_eth_function[1] = (struct usb_descriptor_header *) &subset_data_intf; + fs_eth_function[2] = (struct usb_descriptor_header *) &header_desc; + fs_eth_function[3] = (struct usb_descriptor_header *) &mdlm_desc; + fs_eth_function[4] = (struct usb_descriptor_header *) &mdlm_detail_desc; + fs_eth_function[5] = (struct usb_descriptor_header *) ðer_desc; + fs_eth_function[6] = (struct usb_descriptor_header *) &fs_source_desc; + fs_eth_function[7] = (struct usb_descriptor_header *) &fs_sink_desc; + fs_eth_function[8] = NULL; +#else + fs_eth_function[1] = NULL; +#endif +} + +/* + * usb 2.0 devices need to expose both high speed and full speed + * descriptors, unless they only run at full speed. + */ + +#if defined(DEV_CONFIG_CDC) +static struct usb_endpoint_descriptor +hs_status_desc = { + .bLength = USB_DT_ENDPOINT_SIZE, + .bDescriptorType = USB_DT_ENDPOINT, + + .bmAttributes = USB_ENDPOINT_XFER_INT, + .wMaxPacketSize = __constant_cpu_to_le16 (STATUS_BYTECOUNT), + .bInterval = LOG2_STATUS_INTERVAL_MSEC + 4, +}; +#endif /* DEV_CONFIG_CDC */ + +static struct usb_endpoint_descriptor +hs_source_desc = { + .bLength = USB_DT_ENDPOINT_SIZE, + .bDescriptorType = USB_DT_ENDPOINT, + + .bmAttributes = USB_ENDPOINT_XFER_BULK, + .wMaxPacketSize = __constant_cpu_to_le16 (512), +}; + +static struct usb_endpoint_descriptor +hs_sink_desc = { + .bLength = USB_DT_ENDPOINT_SIZE, + .bDescriptorType = USB_DT_ENDPOINT, + + .bmAttributes = USB_ENDPOINT_XFER_BULK, + .wMaxPacketSize = __constant_cpu_to_le16 (512), +}; + +static struct usb_qualifier_descriptor +dev_qualifier = { + .bLength = sizeof dev_qualifier, + .bDescriptorType = USB_DT_DEVICE_QUALIFIER, + + .bcdUSB = __constant_cpu_to_le16 (0x0200), + .bDeviceClass = USB_CLASS_COMM, + + .bNumConfigurations = 1, +}; + +static const struct usb_descriptor_header *hs_eth_function [11] = { + (struct usb_descriptor_header *) &otg_descriptor, +#ifdef DEV_CONFIG_CDC + /* "cdc" mode descriptors */ + (struct usb_descriptor_header *) &control_intf, + (struct usb_descriptor_header *) &header_desc, + (struct usb_descriptor_header *) &union_desc, + (struct usb_descriptor_header *) ðer_desc, + /* NOTE: status endpoint may need to be removed */ + (struct usb_descriptor_header *) &hs_status_desc, + /* data interface, with altsetting */ + (struct usb_descriptor_header *) &data_nop_intf, + (struct usb_descriptor_header *) &data_intf, + (struct usb_descriptor_header *) &hs_source_desc, + (struct usb_descriptor_header *) &hs_sink_desc, + NULL, +#endif /* DEV_CONFIG_CDC */ +}; + +static inline void hs_subset_descriptors(void) +{ +#ifdef DEV_CONFIG_SUBSET + /* behavior is "CDC Subset"; extra descriptors say "SAFE" */ + hs_eth_function[1] = (struct usb_descriptor_header *) &subset_data_intf; + hs_eth_function[2] = (struct usb_descriptor_header *) &header_desc; + hs_eth_function[3] = (struct usb_descriptor_header *) &mdlm_desc; + hs_eth_function[4] = (struct usb_descriptor_header *) &mdlm_detail_desc; + hs_eth_function[5] = (struct usb_descriptor_header *) ðer_desc; + hs_eth_function[6] = (struct usb_descriptor_header *) &hs_source_desc; + hs_eth_function[7] = (struct usb_descriptor_header *) &hs_sink_desc; + hs_eth_function[8] = NULL; +#else + hs_eth_function[1] = NULL; +#endif +} + +/* maxpacket and other transfer characteristics vary by speed. */ +static inline struct usb_endpoint_descriptor * +ep_desc(struct usb_gadget *g, struct usb_endpoint_descriptor *hs, + struct usb_endpoint_descriptor *fs) +{ + if (gadget_is_dualspeed(g) && g->speed == USB_SPEED_HIGH) + return hs; + return fs; +} + + +/*-------------------------------------------------------------------------*/ + +/* descriptors that are built on-demand */ + +static char manufacturer [50]; +static char product_desc [40] = DRIVER_DESC; +static char serial_number [20]; + +/* address that the host will use ... usually assigned at random */ +static char ethaddr [2 * ETH_ALEN + 1]; + +/* static strings, in UTF-8 */ +static struct usb_string strings [] = { + { STRING_MANUFACTURER, manufacturer, }, + { STRING_PRODUCT, product_desc, }, + { STRING_SERIALNUMBER, serial_number, }, + { STRING_DATA, "Ethernet Data", }, + { STRING_ETHADDR, ethaddr, }, +#ifdef DEV_CONFIG_CDC + { STRING_CDC, "CDC Ethernet", }, + { STRING_CONTROL, "CDC Communications Control", }, +#endif +#ifdef DEV_CONFIG_SUBSET + { STRING_SUBSET, "CDC Ethernet Subset", }, +#endif + { } /* end of list */ +}; + +static struct usb_gadget_strings stringtab = { + .language = 0x0409, /* en-us */ + .strings = strings, +}; + + +/*============================================================================*/ +static u8 control_req[USB_BUFSIZ]; +static u8 status_req[STATUS_BYTECOUNT]; + + + +/** + * strlcpy - Copy a %NUL terminated string into a sized buffer + * @dest: Where to copy the string to + * @src: Where to copy the string from + * @size: size of destination buffer + * + * Compatible with *BSD: the result is always a valid + * NUL-terminated string that fits in the buffer (unless, + * of course, the buffer size is zero). It does not pad + * out the result like strncpy() does. + */ +size_t strlcpy(char *dest, const char *src, size_t size) +{ + size_t ret = strlen(src); + + if (size) { + size_t len = (ret >= size) ? size - 1 : ret; + memcpy(dest, src, len); + dest[len] = '\0'; + } + return ret; +} + + +/*============================================================================*/ + +/* + * one config, two interfaces: control, data. + * complications: class descriptors, and an altsetting. + */ +static int +config_buf(struct usb_gadget *g, u8 *buf, u8 type, unsigned index, int is_otg) +{ + int len; + const struct usb_config_descriptor *config; + const struct usb_descriptor_header **function; + int hs = 0; + + if (gadget_is_dualspeed(g)) { + hs = (g->speed == USB_SPEED_HIGH); + if (type == USB_DT_OTHER_SPEED_CONFIG) + hs = !hs; + } +#define which_fn(t) (hs ? hs_ ## t ## _function : fs_ ## t ## _function) + + if (index >= device_desc.bNumConfigurations) + return -EINVAL; + + config = ð_config; + function = which_fn (eth); + + /* for now, don't advertise srp-only devices */ + if (!is_otg) + function++; + + len = usb_gadget_config_buf (config, buf, USB_BUFSIZ, function); + if (len < 0) + return len; + ((struct usb_config_descriptor *) buf)->bDescriptorType = type; + return len; +} + +/*-------------------------------------------------------------------------*/ + +static int alloc_requests (struct eth_dev *dev, unsigned n, gfp_t gfp_flags); + +static int +set_ether_config (struct eth_dev *dev, gfp_t gfp_flags) +{ + int result = 0; + struct usb_gadget *gadget = dev->gadget; + +#if defined(DEV_CONFIG_CDC) + /* status endpoint used for (optionally) CDC */ + if (!subset_active(dev) && dev->status_ep) { + dev->status = ep_desc (gadget, &hs_status_desc, + &fs_status_desc); + dev->status_ep->driver_data = dev; + + result = usb_ep_enable (dev->status_ep, dev->status); + if (result != 0) { + printf ("enable %s --> %d\n", + dev->status_ep->name, result); + goto done; + } + } +#endif + + dev->in = ep_desc(gadget, &hs_source_desc, &fs_source_desc); + dev->in_ep->driver_data = dev; + + dev->out = ep_desc(gadget, &hs_sink_desc, &fs_sink_desc); + dev->out_ep->driver_data = dev; + + /* With CDC, the host isn't allowed to use these two data + * endpoints in the default altsetting for the interface. + * so we don't activate them yet. Reset from SET_INTERFACE. + */ + if (!cdc_active(dev)) { + result = usb_ep_enable (dev->in_ep, dev->in); + if (result != 0) { + printf ("enable %s --> %d\n", + dev->in_ep->name, result); + goto done; + } + + result = usb_ep_enable (dev->out_ep, dev->out); + if (result != 0) { + printf ("enable %s --> %d\n", + dev->out_ep->name, result); + goto done; + } + } + +done: + if (result == 0) + result = alloc_requests (dev, qlen (gadget), gfp_flags); + + /* on error, disable any endpoints */ + if (result < 0) { + if (!subset_active(dev)) + (void) usb_ep_disable (dev->status_ep); + dev->status = NULL; + (void) usb_ep_disable (dev->in_ep); + (void) usb_ep_disable (dev->out_ep); + dev->in = NULL; + dev->out = NULL; + } + + /* caller is responsible for cleanup on error */ + return result; +} + + +static void eth_reset_config (struct eth_dev *dev) +{ + if (dev->config == 0) + return; + + /* disable endpoints, forcing (synchronous) completion of + * pending i/o. then free the requests. + */ + + if (dev->in) { + usb_ep_disable (dev->in_ep); + if (dev->tx_req) { + usb_ep_free_request (dev->in_ep, dev->tx_req); + dev->tx_req=NULL; + } + } + if (dev->out) { + usb_ep_disable (dev->out_ep); + if (dev->rx_req) { + usb_ep_free_request (dev->in_ep, dev->rx_req); + dev->rx_req=NULL; + } + } + if (dev->status) { + usb_ep_disable (dev->status_ep); + } + dev->cdc_filter = 0; + dev->config = 0; +} + +/* change our operational config. must agree with the code + * that returns config descriptors, and altsetting code. + */ +static int eth_set_config (struct eth_dev *dev, unsigned number, gfp_t gfp_flags) +{ + int result = 0; + struct usb_gadget *gadget = dev->gadget; + + if (gadget_is_sa1100 (gadget) + && dev->config + && dev->tx_qlen != 0) { + /* tx fifo is full, but we can't clear it...*/ + INFO (dev, "can't change configurations\n"); + return -ESPIPE; + } + eth_reset_config (dev); + + switch (number) { + case DEV_CONFIG_VALUE: + result = set_ether_config (dev, gfp_flags); + break; + default: + result = -EINVAL; + /* FALL THROUGH */ + case 0: + break; + } + + if (result) { + if (number) + eth_reset_config (dev); + usb_gadget_vbus_draw(dev->gadget, + gadget_is_otg(dev->gadget) ? 8 : 100); + } else { + char *speed; + unsigned power; + + power = 2 * eth_config.bMaxPower; + usb_gadget_vbus_draw(dev->gadget, power); + + switch (gadget->speed) { + case USB_SPEED_FULL: speed = "full"; break; +#ifdef CONFIG_USB_GADGET_DUALSPEED + case USB_SPEED_HIGH: speed = "high"; break; +#endif + default: speed = "?"; break; + } + + dev->config = number; + INFO (dev, "%s speed config #%d: %d mA, %s, using %s\n", + speed, number, power, driver_desc, + (cdc_active(dev)? "CDC Ethernet" + : "CDC Ethernet Subset")); + } + return result; +} + +/*-------------------------------------------------------------------------*/ + +#ifdef DEV_CONFIG_CDC + +/* The interrupt endpoint is used in CDC networking models (Ethernet, ATM) + * only to notify the host about link status changes (which we support) or + * report completion of some encapsulated command. Since + * we want this CDC Ethernet code to be vendor-neutral, we don't use that + * command mechanism; and only one status request is ever queued. + */ +static void eth_status_complete (struct usb_ep *ep, struct usb_request *req) +{ + struct usb_cdc_notification *event = req->buf; + int value = req->status; + struct eth_dev *dev = ep->driver_data; + + /* issue the second notification if host reads the first */ + if (event->bNotificationType == USB_CDC_NOTIFY_NETWORK_CONNECTION + && value == 0) { + __le32 *data = req->buf + sizeof *event; + + event->bmRequestType = 0xA1; + event->bNotificationType = USB_CDC_NOTIFY_SPEED_CHANGE; + event->wValue = __constant_cpu_to_le16 (0); + event->wIndex = __constant_cpu_to_le16 (1); + event->wLength = __constant_cpu_to_le16 (8); + + /* SPEED_CHANGE data is up/down speeds in bits/sec */ + data [0] = data [1] = cpu_to_le32 (BITRATE (dev->gadget)); + + req->length = STATUS_BYTECOUNT; + value = usb_ep_queue (ep, req, GFP_ATOMIC); + dprintf ("send SPEED_CHANGE --> %d\n", value); + if (value == 0) + return; + } else if (value != -ECONNRESET) { + dprintf("event %02x --> %d\n", + event->bNotificationType, value); + if (event->bNotificationType== + USB_CDC_NOTIFY_SPEED_CHANGE) + { + l_ethdev.network_started=1; + printf("USB network up!\n"); + } + } + req->context = NULL; +} + +static void issue_start_status (struct eth_dev *dev) +{ + struct usb_request *req = dev->stat_req; + struct usb_cdc_notification *event; + int value; + + /* flush old status + * + * FIXME ugly idiom, maybe we'd be better with just + * a "cancel the whole queue" primitive since any + * unlink-one primitive has way too many error modes. + * here, we "know" toggle is already clear... + * + * FIXME iff req->context != null just dequeue it + */ + usb_ep_disable (dev->status_ep); + usb_ep_enable (dev->status_ep, dev->status); + + /* 3.8.1 says to issue first NETWORK_CONNECTION, then + * a SPEED_CHANGE. could be useful in some configs. + */ + event = req->buf; + event->bmRequestType = 0xA1; + event->bNotificationType = USB_CDC_NOTIFY_NETWORK_CONNECTION; + event->wValue = __constant_cpu_to_le16 (1); /* connected */ + event->wIndex = __constant_cpu_to_le16 (1); + event->wLength = 0; + + req->length = sizeof *event; + req->complete = eth_status_complete; + req->context = dev; + + value = usb_ep_queue (dev->status_ep, req, GFP_ATOMIC); + if (value < 0) + printf ("status buf queue --> %d\n", value); +} + +#endif + +/*-------------------------------------------------------------------------*/ + +static void eth_setup_complete (struct usb_ep *ep, struct usb_request *req) +{ + if (req->status || req->actual != req->length) + dprintf (/*(struct eth_dev *) ep->driver_data*/ + "setup complete --> %d, %d/%d\n", + req->status, req->actual, req->length); +} + +/* + * The setup() callback implements all the ep0 functionality that's not + * handled lower down. CDC has a number of less-common features: + * + * - two interfaces: control, and ethernet data + * - Ethernet data interface has two altsettings: default, and active + * - class-specific descriptors for the control interface + * - class-specific control requests + */ +static int +eth_setup (struct usb_gadget *gadget, const struct usb_ctrlrequest *ctrl) +{ + struct eth_dev *dev = get_gadget_data (gadget); + struct usb_request *req = dev->req; + int value = -EOPNOTSUPP; + u16 wIndex = le16_to_cpu(ctrl->wIndex); + u16 wValue = le16_to_cpu(ctrl->wValue); + u16 wLength = le16_to_cpu(ctrl->wLength); + + /* descriptors just go into the pre-allocated ep0 buffer, + * while config change events may enable network traffic. + */ + + dprintf("eth_setup:...\n"); + + req->complete = eth_setup_complete; + switch (ctrl->bRequest) { + + case USB_REQ_GET_DESCRIPTOR: + if (ctrl->bRequestType != USB_DIR_IN) + break; + switch (wValue >> 8) { + + case USB_DT_DEVICE: + value = min (wLength, (u16) sizeof device_desc); + memcpy (req->buf, &device_desc, value); + break; + case USB_DT_DEVICE_QUALIFIER: + if (!gadget_is_dualspeed(gadget)) + break; + value = min (wLength, (u16) sizeof dev_qualifier); + memcpy (req->buf, &dev_qualifier, value); + break; + + case USB_DT_OTHER_SPEED_CONFIG: + if (!gadget_is_dualspeed(gadget)) + break; + /* FALLTHROUGH */ + case USB_DT_CONFIG: + value = config_buf(gadget, req->buf, + wValue >> 8, + wValue & 0xff, + gadget_is_otg(gadget)); + if (value >= 0) + value = min (wLength, (u16) value); + break; + + case USB_DT_STRING: + value = usb_gadget_get_string (&stringtab, + wValue & 0xff, req->buf); + + if (value >= 0) + value = min (wLength, (u16) value); + + break; + } + break; + + case USB_REQ_SET_CONFIGURATION: + if (ctrl->bRequestType != 0) + break; + if (gadget->a_hnp_support) + DEBUG (dev, "HNP available\n"); + else if (gadget->a_alt_hnp_support) + DEBUG (dev, "HNP needs a different root port\n"); + value = eth_set_config (dev, wValue, GFP_ATOMIC); + break; + case USB_REQ_GET_CONFIGURATION: + if (ctrl->bRequestType != USB_DIR_IN) + break; + *(u8 *)req->buf = dev->config; + value = min (wLength, (u16) 1); + break; + + case USB_REQ_SET_INTERFACE: + if (ctrl->bRequestType != USB_RECIP_INTERFACE + || !dev->config + || wIndex > 1) + break; + if (!cdc_active(dev) && wIndex != 0) + break; + + /* PXA hardware partially handles SET_INTERFACE; + * we need to kluge around that interference. + */ + if (gadget_is_pxa (gadget)) { + value = eth_set_config (dev, DEV_CONFIG_VALUE, + GFP_ATOMIC); + goto done_set_intf; + } + +#ifdef DEV_CONFIG_CDC + switch (wIndex) { + case 0: /* control/master intf */ + if (wValue != 0) + break; + if (dev->status) { + usb_ep_disable (dev->status_ep); + usb_ep_enable (dev->status_ep, dev->status); + } + value = 0; + break; + case 1: /* data intf */ + if (wValue > 1) + break; + usb_ep_disable (dev->in_ep); + usb_ep_disable (dev->out_ep); + + /* CDC requires the data transfers not be done from + * the default interface setting ... also, setting + * the non-default interface resets filters etc. + */ + if (wValue == 1) { + if (!cdc_active (dev)) + break; + usb_ep_enable (dev->in_ep, dev->in); + usb_ep_enable (dev->out_ep, dev->out); + dev->cdc_filter = DEFAULT_FILTER; + if (dev->status) + issue_start_status (dev); + } + + value = 0; + break; + } +#else + /* FIXME this is wrong, as is the assumption that + * all non-PXA hardware talks real CDC ... + */ + dev_warn (&gadget->dev, "set_interface ignored!\n"); +#endif /* DEV_CONFIG_CDC */ + +done_set_intf: + break; + case USB_REQ_GET_INTERFACE: + if (ctrl->bRequestType != (USB_DIR_IN|USB_RECIP_INTERFACE) + || !dev->config + || wIndex > 1) + break; + if (!(cdc_active(dev)) && wIndex != 0) + break; + + /* for CDC, iff carrier is on, data interface is active. */ + if (wIndex != 1) + *(u8 *)req->buf = 0; + else { + /* *(u8 *)req->buf = netif_carrier_ok (dev->net) ? 1 : 0; */ + /* carrier always ok ...*/ + *(u8 *)req->buf = 1 ; + } + value = min (wLength, (u16) 1); + break; + +#ifdef DEV_CONFIG_CDC + case USB_CDC_SET_ETHERNET_PACKET_FILTER: + /* see 6.2.30: no data, wIndex = interface, + * wValue = packet filter bitmap + */ + if (ctrl->bRequestType != (USB_TYPE_CLASS|USB_RECIP_INTERFACE) + || !cdc_active(dev) + || wLength != 0 + || wIndex > 1) + break; + printf ("packet filter %02x\n", wValue); + dev->cdc_filter = wValue; + value = 0; + break; + + /* and potentially: + * case USB_CDC_SET_ETHERNET_MULTICAST_FILTERS: + * case USB_CDC_SET_ETHERNET_PM_PATTERN_FILTER: + * case USB_CDC_GET_ETHERNET_PM_PATTERN_FILTER: + * case USB_CDC_GET_ETHERNET_STATISTIC: + */ + +#endif /* DEV_CONFIG_CDC */ + + default: + printf ( + "unknown control req%02x.%02x v%04x i%04x l%d\n", + ctrl->bRequestType, ctrl->bRequest, + wValue, wIndex, wLength); + } + + /* respond with data transfer before status phase? */ + if (value >= 0) { + dprintf("respond with data transfer before status phase\n"); + req->length = value; + req->zero = value < wLength + && (value % gadget->ep0->maxpacket) == 0; + value = usb_ep_queue (gadget->ep0, req, GFP_ATOMIC); + if (value < 0) { + DEBUG (dev, "ep_queue --> %d\n", value); + req->status = 0; + eth_setup_complete (gadget->ep0, req); + } + } + + /* host either stalls (value < 0) or reports success */ + return value; +} + + +/*-------------------------------------------------------------------------*/ + +static void rx_complete (struct usb_ep *ep, struct usb_request *req); + +static int rx_submit ( struct eth_dev *dev, struct usb_request *req, \ + gfp_t gfp_flags) +{ + int retval = -ENOMEM; + size_t size; + + /* Padding up to RX_EXTRA handles minor disagreements with host. + * Normally we use the USB "terminate on short read" convention; + * so allow up to (N*maxpacket), since that memory is normally + * already allocated. Some hardware doesn't deal well with short + * reads (e.g. DMA must be N*maxpacket), so for now don't trim a + * byte off the end (to force hardware errors on overflow). + */ + + dprintf("%s\n", __func__); + + size = (ETHER_HDR_SIZE + dev->mtu + RX_EXTRA); + size += dev->out_ep->maxpacket - 1; + size -= size % dev->out_ep->maxpacket; + + + /* Some platforms perform better when IP packets are aligned, + * but on at least one, checksumming fails otherwise. + */ + + req->buf = (u8 *) NetRxPackets[0]; + req->length = size; + req->complete = rx_complete; + + retval = usb_ep_queue (dev->out_ep, req, gfp_flags); + + if (retval) { + dprintf ("rx submit --> %d\n", retval); + } + return retval; +} + + +static void rx_complete (struct usb_ep *ep, struct usb_request *req) +{ + struct eth_dev *dev = ep->driver_data; + + dprintf("%s\n", __func__); + dprintf("rx status %d\n", req->status); + + packet_received=1; + + if (req) + dev->rx_req=req; +} + + +static int alloc_requests (struct eth_dev *dev, unsigned n, gfp_t gfp_flags) +{ + + dev->tx_req = usb_ep_alloc_request (dev->in_ep, 0); + + if (!dev->tx_req) + goto fail; + + dev->rx_req = usb_ep_alloc_request (dev->out_ep, 0); + + if (!dev->rx_req) + goto fail; + + return 0; + +fail: + DEBUG (dev, "can't alloc requests\n"); + return -1; +} + + +static void tx_complete (struct usb_ep *ep, struct usb_request *req) +{ + dprintf("%s, status: %s\n", __func__,(req->status) ? "failed":"ok"); + packet_sent=1; +} + +static inline int eth_is_promisc (struct eth_dev *dev) +{ + /* no filters for the CDC subset; always promisc */ + if (subset_active (dev)) + return 1; + return dev->cdc_filter & USB_CDC_PACKET_TYPE_PROMISCUOUS; +} + +#if 0 +static int eth_start_xmit (struct sk_buff *skb, struct net_device *net) +{ + struct eth_dev *dev = netdev_priv(net); + int length = skb->len; + int retval; + struct usb_request *req = NULL; + unsigned long flags; + + /* apply outgoing CDC or RNDIS filters */ + if (!eth_is_promisc (dev)) { + u8 *dest = skb->data; + + if (is_multicast_ether_addr(dest)) { + u16 type; + + /* ignores USB_CDC_PACKET_TYPE_MULTICAST and host + * SET_ETHERNET_MULTICAST_FILTERS requests + */ + if (is_broadcast_ether_addr(dest)) + type = USB_CDC_PACKET_TYPE_BROADCAST; + else + type = USB_CDC_PACKET_TYPE_ALL_MULTICAST; + if (!(dev->cdc_filter & type)) { + dev_kfree_skb_any (skb); + return 0; + } + } + /* ignores USB_CDC_PACKET_TYPE_DIRECTED */ + } + + spin_lock_irqsave(&dev->req_lock, flags); + /* + * this freelist can be empty if an interrupt triggered disconnect() + * and reconfigured the gadget (shutting down this queue) after the + * network stack decided to xmit but before we got the spinlock. + */ + if (list_empty(&dev->tx_reqs)) { + spin_unlock_irqrestore(&dev->req_lock, flags); + return 1; + } + + req = container_of (dev->tx_reqs.next, struct usb_request, list); + list_del (&req->list); + + /* temporarily stop TX queue when the freelist empties */ + if (list_empty (&dev->tx_reqs)) + netif_stop_queue (net); + spin_unlock_irqrestore(&dev->req_lock, flags); + + /* no buffer copies needed, unless the network stack did it + * or the hardware can't use skb buffers. + * or there's not enough space for any RNDIS headers we need + */ + if (rndis_active(dev)) { + struct sk_buff *skb_rndis; + + skb_rndis = skb_realloc_headroom (skb, + sizeof (struct rndis_packet_msg_type)); + if (!skb_rndis) + goto drop; + + dev_kfree_skb_any (skb); + skb = skb_rndis; + rndis_add_hdr (skb); + length = skb->len; + } + req->buf = skb->data; + req->context = skb; + req->complete = tx_complete; + + /* use zlp framing on tx for strict CDC-Ether conformance, + * though any robust network rx path ignores extra padding. + * and some hardware doesn't like to write zlps. + */ + req->zero = 1; + if (!dev->zlp && (length % dev->in_ep->maxpacket) == 0) + length++; + + req->length = length; + + /* throttle highspeed IRQ rate back slightly */ + if (gadget_is_dualspeed(dev->gadget)) + req->no_interrupt = (dev->gadget->speed == USB_SPEED_HIGH) + ? ((atomic_read(&dev->tx_qlen) % qmult) != 0) + : 0; + + retval = usb_ep_queue (dev->in_ep, req, GFP_ATOMIC); + switch (retval) { + default: + DEBUG (dev, "tx queue err %d\n", retval); + break; + case 0: + net->trans_start = jiffies; + atomic_inc (&dev->tx_qlen); + } + + if (retval) { +drop: + dev->stats.tx_dropped++; + dev_kfree_skb_any (skb); + spin_lock_irqsave(&dev->req_lock, flags); + if (list_empty (&dev->tx_reqs)) + netif_start_queue (net); + list_add (&req->list, &dev->tx_reqs); + spin_unlock_irqrestore(&dev->req_lock, flags); + } + return 0; +} + +/*-------------------------------------------------------------------------*/ +#endif + +static void eth_unbind (struct usb_gadget *gadget) +{ + struct eth_dev *dev = get_gadget_data (gadget); + + printf("eth_unbind:...\n"); + + if (dev->stat_req) { + usb_ep_free_request (dev->status_ep, dev->stat_req); + dev->stat_req = NULL; + } + + if (dev->tx_req) { + usb_ep_free_request (dev->in_ep, dev->tx_req); + dev->tx_req=NULL; + } + + if (dev->rx_req) { + usb_ep_free_request (dev->in_ep, dev->rx_req); + dev->rx_req=NULL; + } + +/* unregister_netdev (dev->net);*/ +/* free_netdev(dev->net);*/ + + set_gadget_data (gadget, NULL); +} + +static void eth_disconnect (struct usb_gadget *gadget) +{ + eth_reset_config (get_gadget_data (gadget)); +} + +static void eth_suspend (struct usb_gadget *gadget) +{ + /* Not used */ +} + +static void eth_resume (struct usb_gadget *gadget) +{ + /* Not used */ +} + +/*-------------------------------------------------------------------------*/ + +static int is_eth_addr_valid(char *str) +{ + if (strlen(str) == 17) { + int i; + char *p, *q; + uchar ea[6]; + + /* see if it looks like an ethernet address */ + + p = str; + + for (i = 0; i < 6; i++) { + char term = (i == 5 ? '\0' : ':'); + + ea[i] = simple_strtol(p, &q, 16); + + if ((q - p) != 2 || *q++ != term) + break; + + p = q; + } + + if (i == 6) /* it looks ok */ + return 1; + } + return 0; +} + +static u8 nibble (unsigned char c) +{ + if (likely (isdigit (c))) + return c - '0'; + c = toupper (c); + if (likely (isxdigit (c))) + return 10 + c - 'A'; + return 0; +} + +static int get_ether_addr(const char *str, u8 *dev_addr) +{ + if (str) { + unsigned i; + + for (i = 0; i < 6; i++) { + unsigned char num; + + if((*str == '.') || (*str == ':')) + str++; + num = nibble(*str++) << 4; + num |= (nibble(*str++)); + dev_addr [i] = num; + } + if (is_valid_ether_addr (dev_addr)) + return 0; + } + return 1; +} + +static int eth_bind(struct usb_gadget *gadget) +{ + struct eth_dev *dev = &l_ethdev; + u8 cdc = 1, zlp = 1; + struct usb_ep *in_ep, *out_ep, *status_ep = NULL; + int gcnum; + u8 tmp[7]; + + /* these flags are only ever cleared; compiler take note */ +#ifndef DEV_CONFIG_CDC + cdc = 0; +#endif + /* Because most host side USB stacks handle CDC Ethernet, that + * standard protocol is _strongly_ preferred for interop purposes. + * (By everyone except Microsoft.) + */ + if (gadget_is_pxa (gadget)) { + /* pxa doesn't support altsettings */ + cdc = 0; + } else if (gadget_is_musbhdrc(gadget)) { + /* reduce tx dma overhead by avoiding special cases */ + zlp = 0; + } else if (gadget_is_sh(gadget)) { + /* sh doesn't support multiple interfaces or configs */ + cdc = 0; + } else if (gadget_is_sa1100 (gadget)) { + /* hardware can't write zlps */ + zlp = 0; + /* sa1100 CAN do CDC, without status endpoint ... we use + * non-CDC to be compatible with ARM Linux-2.4 "usb-eth". + */ + cdc = 0; + } + + gcnum = usb_gadget_controller_number (gadget); + if (gcnum >= 0) + device_desc.bcdDevice = cpu_to_le16 (0x0300 + gcnum); + else { + /* can't assume CDC works. don't want to default to + * anything less functional on CDC-capable hardware, + * so we fail in this case. + */ + dev_err (&gadget->dev, + "controller '%s' not recognized\n", + gadget->name); + return -ENODEV; + } + + /* CDC subset ... recognized by Linux since 2.4.10, but Windows + * drivers aren't widely available. (That may be improved by + * supporting one submode of the "SAFE" variant of MDLM.) + */ + if (!cdc) { + device_desc.idVendor = + __constant_cpu_to_le16(SIMPLE_VENDOR_NUM); + device_desc.idProduct = + __constant_cpu_to_le16(SIMPLE_PRODUCT_NUM); + } + + /* support optional vendor/distro customization */ +#if defined(CONFIG_USB_CDC_VENDOR_ID) && defined(CONFIG_USB_CDC_PRODUCT_ID) + device_desc.idVendor = cpu_to_le16(CONFIG_USB_CDC_VENDOR_ID); + device_desc.idProduct = cpu_to_le16(CONFIG_USB_CDC_PRODUCT_ID); +#endif + if (bcdDevice) + device_desc.bcdDevice = cpu_to_le16(bcdDevice); + if (iManufacturer) + strcpy (manufacturer, iManufacturer); + if (iProduct) + strcpy (product_desc, iProduct); + if (iSerialNumber) { + device_desc.iSerialNumber = STRING_SERIALNUMBER, + strcpy(serial_number, iSerialNumber); + } + + /* all we really need is bulk IN/OUT */ + usb_ep_autoconfig_reset (gadget); + in_ep = usb_ep_autoconfig (gadget, &fs_source_desc); + if (!in_ep) { +autoconf_fail: + dev_err (&gadget->dev, + "can't autoconfigure on %s\n", + gadget->name); + return -ENODEV; + } + in_ep->driver_data = in_ep; /* claim */ + + out_ep = usb_ep_autoconfig (gadget, &fs_sink_desc); + if (!out_ep) + goto autoconf_fail; + out_ep->driver_data = out_ep; /* claim */ + +#if defined(DEV_CONFIG_CDC) + /* CDC Ethernet control interface doesn't require a status endpoint. + * Since some hosts expect one, try to allocate one anyway. + */ + if (cdc) { + status_ep = usb_ep_autoconfig (gadget, &fs_status_desc); + if (status_ep) { + status_ep->driver_data = status_ep; /* claim */ + } else if (cdc) { + control_intf.bNumEndpoints = 0; + /* FIXME remove endpoint from descriptor list */ + } + } +#endif + + /* one config: cdc, else minimal subset */ + if (!cdc) { + eth_config.bNumInterfaces = 1; + eth_config.iConfiguration = STRING_SUBSET; + + /* use functions to set these up, in case we're built to work + * with multiple controllers and must override CDC Ethernet. + */ + fs_subset_descriptors(); + hs_subset_descriptors(); + } + + device_desc.bMaxPacketSize0 = gadget->ep0->maxpacket; + usb_gadget_set_selfpowered (gadget); + + if (gadget_is_dualspeed(gadget)) { + if (!cdc) + dev_qualifier.bDeviceClass = USB_CLASS_VENDOR_SPEC; + + /* assumes ep0 uses the same value for both speeds ... */ + dev_qualifier.bMaxPacketSize0 = device_desc.bMaxPacketSize0; + + /* and that all endpoints are dual-speed */ + hs_source_desc.bEndpointAddress = + fs_source_desc.bEndpointAddress; + hs_sink_desc.bEndpointAddress = + fs_sink_desc.bEndpointAddress; +#if defined(DEV_CONFIG_CDC) + if (status_ep) + hs_status_desc.bEndpointAddress = + fs_status_desc.bEndpointAddress; +#endif + } + + if (gadget_is_otg(gadget)) { + otg_descriptor.bmAttributes |= USB_OTG_HNP, + eth_config.bmAttributes |= USB_CONFIG_ATT_WAKEUP; + eth_config.bMaxPower = 4; + } + + dev->net = &l_netdev; + strcpy (dev->net->name, USB_NET_NAME); + + dev->cdc = cdc; + dev->zlp = zlp; + + dev->in_ep = in_ep; + dev->out_ep = out_ep; + dev->status_ep = status_ep; + + /* Module params for these addresses should come from ID proms. + * The host side address is used with CDC, and commonly + * ends up in a persistent config database. It's not clear if + * host side code for the SAFE thing cares -- its original BLAN + * thing didn't, Sharp never assigned those addresses on Zaurii. + */ + get_ether_addr(dev_addr, dev->net->enetaddr); + + memset(tmp, 0, sizeof(tmp)); + memcpy(tmp, dev->net->enetaddr, sizeof(dev->net->enetaddr)); + + get_ether_addr(host_addr, dev->host_mac); + + sprintf (ethaddr, "%02X%02X%02X%02X%02X%02X", + dev->host_mac [0], dev->host_mac [1], + dev->host_mac [2], dev->host_mac [3], + dev->host_mac [4], dev->host_mac [5]); + + INFO (dev, "using %s, OUT %s IN %s%s%s\n", gadget->name, + out_ep->name, in_ep->name, + status_ep ? " STATUS " : "", + status_ep ? status_ep->name : "" + ); + INFO (dev, "MAC %02x:%02x:%02x:%02x:%02x:%02x\n", + dev->net->enetaddr [0], dev->net->enetaddr [1], + dev->net->enetaddr [2], dev->net->enetaddr [3], + dev->net->enetaddr [4], dev->net->enetaddr [5]); + + if (cdc) { + INFO (dev, "HOST MAC %02x:%02x:%02x:%02x:%02x:%02x\n", + dev->host_mac [0], dev->host_mac [1], + dev->host_mac [2], dev->host_mac [3], + dev->host_mac [4], dev->host_mac [5]); + } + + /* use PKTSIZE (or aligned... from u-boot) and set + * wMaxSegmentSize accordingly*/ + dev->mtu = PKTSIZE_ALIGN; /* RNDIS does not like this, only 1514, TODO*/ + + /* preallocate control message data and buffer */ + dev->req = usb_ep_alloc_request (gadget->ep0, GFP_KERNEL); + if (!dev->req) + goto fail; + dev->req->buf = control_req; + dev->req->complete = eth_setup_complete; + + /* ... and maybe likewise for status transfer */ +#if defined(DEV_CONFIG_CDC) + if (dev->status_ep) { + dev->stat_req = usb_ep_alloc_request(gadget->ep0, GFP_KERNEL); + dev->stat_req->buf = status_req; + if (!dev->stat_req) { + dev->stat_req->buf=NULL; + usb_ep_free_request (gadget->ep0, dev->req); + + goto fail; + } + dev->stat_req->context = NULL; + } +#endif + + /* finish hookup to lower layer ... */ + dev->gadget = gadget; + set_gadget_data (gadget, dev); + gadget->ep0->driver_data = dev; + + /* two kinds of host-initiated state changes: + * - iff DATA transfer is active, carrier is "on" + * - tx queueing enabled if open *and* carrier is "on" + */ + return 0; + +fail: + dev_dbg(&gadget->dev, "register_netdev failed\n"); + eth_unbind (gadget); + return -ENOMEM; +} + +static int usb_eth_init(struct eth_device* netdev, bd_t* bd) +{ + struct eth_dev *dev=&l_ethdev; + struct usb_gadget *gadget; + unsigned long ts; + unsigned long timeout = USB_CONNECT_TIMEOUT; + + if (!netdev) { + printf("ERROR: received NULL ptr\n"); + goto fail; + } + + dev->network_started = 0; + dev->tx_req = NULL; + dev->rx_req = NULL; + + packet_received = 0; + packet_sent = 0; + + gadget = dev->gadget; + usb_gadget_connect(gadget); + + if (getenv("cdc_connect_timeout")) + timeout = simple_strtoul(getenv("cdc_connect_timeout"), + NULL, 10) * CONFIG_SYS_HZ; + ts = get_timer(0); + while (!l_ethdev.network_started) + { + /* Handle control-c and timeouts */ + if (ctrlc() || (get_timer(ts) > timeout)) { + printf("The remote end did not respond in time.\n"); + goto fail; + } + usb_gadget_handle_interrupts(); + } + + rx_submit (dev, dev->rx_req, 0); + return 0; +fail: + return -1; +} + +static int usb_eth_send(struct eth_device* netdev, volatile void* packet, int length) +{ + int retval; + struct usb_request *req = NULL; + + struct eth_dev *dev = &l_ethdev; + dprintf("%s:...\n",__func__); + + req = dev->tx_req; + + req->buf = (void *)packet; + req->context = NULL; + req->complete = tx_complete; + + /* use zlp framing on tx for strict CDC-Ether conformance, + * though any robust network rx path ignores extra padding. + * and some hardware doesn't like to write zlps. + */ + req->zero = 1; + if (!dev->zlp && (length % dev->in_ep->maxpacket) == 0) + length++; + + req->length = length; +#if 0 + /* throttle highspeed IRQ rate back slightly */ + if (gadget_is_dualspeed(dev->gadget)) + req->no_interrupt = (dev->gadget->speed == USB_SPEED_HIGH) + ? ((dev->tx_qlen % qmult) != 0) : 0; +#endif + dev->tx_qlen=1; + + retval = usb_ep_queue (dev->in_ep, req, GFP_ATOMIC); + + if (!retval) + dprintf("%s: packet queued\n",__func__); + while(!packet_sent) + { + packet_sent=0; + } + + return 0; +} + +static int usb_eth_recv(struct eth_device* netdev) +{ + struct eth_dev *dev = &l_ethdev; + + usb_gadget_handle_interrupts(); + + if (packet_received) + { + dprintf("%s: packet received \n",__func__); + if (dev->rx_req) + { + NetReceive(NetRxPackets[0],dev->rx_req->length); + packet_received=0; + + if (dev->rx_req) + rx_submit (dev, dev->rx_req, 0); + } + else printf("dev->rx_req invalid\n"); + } + return 0; +} + +void usb_eth_halt(struct eth_device* netdev) +{ + struct eth_dev *dev =&l_ethdev; + + if (!netdev) + { + printf("ERROR: received NULL ptr\n"); + return; + } + + usb_gadget_disconnect(dev->gadget); +} + +static struct usb_gadget_driver eth_driver = { + .speed = DEVSPEED, + + .bind = eth_bind, + .unbind = eth_unbind, + + .setup = eth_setup, + .disconnect = eth_disconnect, + + .suspend = eth_suspend, + .resume = eth_resume, +}; + +int usb_eth_initialize(bd_t *bi) +{ + int status = 0; + struct eth_device *netdev=&l_netdev; + + sprintf(netdev->name,"usb_ether"); + + netdev->init = usb_eth_init; + netdev->send = usb_eth_send; + netdev->recv = usb_eth_recv; + netdev->halt = usb_eth_halt; + +#ifdef CONFIG_MCAST_TFTP + #error not supported +#endif + /* Configure default mac-addresses for the USB ethernet device */ +#ifdef CONFIG_USBNET_DEV_ADDR + strncpy(dev_addr, CONFIG_USBNET_DEV_ADDR, sizeof(dev_addr)); +#endif +#ifdef CONFIG_USBNET_HOST_ADDR + strncpy(host_addr, CONFIG_USBNET_HOST_ADDR, sizeof(host_addr)); +#endif + /* Check if the user overruled the MAC addresses */ + if (getenv("usbnet_devaddr")) + strncpy(dev_addr, getenv("usbnet_devaddr"), + sizeof(dev_addr)); + + if (getenv("usbnet_hostaddr")) + strncpy(host_addr, getenv("usbnet_hostaddr"), + sizeof(host_addr)); + + /* Make sure both strings are terminated */ + dev_addr[sizeof(dev_addr)-1] = '\0'; + host_addr[sizeof(host_addr)-1] = '\0'; + + if (!is_eth_addr_valid(dev_addr)) { + printf("ERROR: Need valid 'usbnet_devaddr' to be set\n"); + status = -1; + } + if (!is_eth_addr_valid(host_addr)) { + printf("ERROR: Need valid 'usbnet_hostaddr' to be set\n"); + status = -1; + } + if (status) + goto fail; + + status = usb_gadget_register_driver(ð_driver); + if (status < 0) + goto fail; + + eth_register(netdev); + return 0; + +fail: + printf("%s failed\n", __func__ ); + return status; +} + diff --git a/drivers/usb/gadget/gadget_chips.h b/drivers/usb/gadget/gadget_chips.h new file mode 100644 index 0000000..480bc87 --- /dev/null +++ b/drivers/usb/gadget/gadget_chips.h @@ -0,0 +1,219 @@ +/* + * USB device controllers have lots of quirks. Use these macros in + * gadget drivers or other code that needs to deal with them, and which + * autoconfigures instead of using early binding to the hardware. + * + * This SHOULD eventually work like the ARM mach_is_*() stuff, driven by + * some config file that gets updated as new hardware is supported. + * (And avoiding all runtime comparisons in typical one-choice configs!) + * + * NOTE: some of these controller drivers may not be available yet. + * Some are available on 2.4 kernels; several are available, but not + * yet pushed in the 2.6 mainline tree. + * + * Ported to U-boot by: Thomas Smits ts.smits@gmail.com and + * Remy Bohmer linux@bohmer.net + */ +#ifdef CONFIG_USB_GADGET_NET2280 +#define gadget_is_net2280(g) !strcmp("net2280", (g)->name) +#else +#define gadget_is_net2280(g) 0 +#endif + +#ifdef CONFIG_USB_GADGET_AMD5536UDC +#define gadget_is_amd5536udc(g) !strcmp("amd5536udc", (g)->name) +#else +#define gadget_is_amd5536udc(g) 0 +#endif + +#ifdef CONFIG_USB_GADGET_DUMMY_HCD +#define gadget_is_dummy(g) !strcmp("dummy_udc", (g)->name) +#else +#define gadget_is_dummy(g) 0 +#endif + +#ifdef CONFIG_USB_GADGET_PXA2XX +#define gadget_is_pxa(g) !strcmp("pxa2xx_udc", (g)->name) +#else +#define gadget_is_pxa(g) 0 +#endif + +#ifdef CONFIG_USB_GADGET_GOKU +#define gadget_is_goku(g) !strcmp("goku_udc", (g)->name) +#else +#define gadget_is_goku(g) 0 +#endif + +/* SH3 UDC -- not yet ported 2.4 --> 2.6 */ +#ifdef CONFIG_USB_GADGET_SUPERH +#define gadget_is_sh(g) !strcmp("sh_udc", (g)->name) +#else +#define gadget_is_sh(g) 0 +#endif + +/* not yet stable on 2.6 (would help "original Zaurus") */ +#ifdef CONFIG_USB_GADGET_SA1100 +#define gadget_is_sa1100(g) !strcmp("sa1100_udc", (g)->name) +#else +#define gadget_is_sa1100(g) 0 +#endif + +#ifdef CONFIG_USB_GADGET_LH7A40X +#define gadget_is_lh7a40x(g) !strcmp("lh7a40x_udc", (g)->name) +#else +#define gadget_is_lh7a40x(g) 0 +#endif + +/* handhelds.org tree (?) */ +#ifdef CONFIG_USB_GADGET_MQ11XX +#define gadget_is_mq11xx(g) !strcmp("mq11xx_udc", (g)->name) +#else +#define gadget_is_mq11xx(g) 0 +#endif + +#ifdef CONFIG_USB_GADGET_OMAP +#define gadget_is_omap(g) !strcmp("omap_udc", (g)->name) +#else +#define gadget_is_omap(g) 0 +#endif + +/* not yet ported 2.4 --> 2.6 */ +#ifdef CONFIG_USB_GADGET_N9604 +#define gadget_is_n9604(g) !strcmp("n9604_udc", (g)->name) +#else +#define gadget_is_n9604(g) 0 +#endif + +/* various unstable versions available */ +#ifdef CONFIG_USB_GADGET_PXA27X +#define gadget_is_pxa27x(g) !strcmp("pxa27x_udc", (g)->name) +#else +#define gadget_is_pxa27x(g) 0 +#endif + +#ifdef CONFIG_USB_GADGET_ATMEL_USBA +#define gadget_is_atmel_usba(g) !strcmp("atmel_usba_udc", (g)->name) +#else +#define gadget_is_atmel_usba(g) 0 +#endif + +#ifdef CONFIG_USB_GADGET_S3C2410 +#define gadget_is_s3c2410(g) !strcmp("s3c2410_udc", (g)->name) +#else +#define gadget_is_s3c2410(g) 0 +#endif + +#ifdef CONFIG_USB_GADGET_AT91 +#define gadget_is_at91(g) !strcmp("at91_udc", (g)->name) +#else +#define gadget_is_at91(g) 0 +#endif + +/* status unclear */ +#ifdef CONFIG_USB_GADGET_IMX +#define gadget_is_imx(g) !strcmp("imx_udc", (g)->name) +#else +#define gadget_is_imx(g) 0 +#endif + +#ifdef CONFIG_USB_GADGET_FSL_USB2 +#define gadget_is_fsl_usb2(g) !strcmp("fsl-usb2-udc", (g)->name) +#else +#define gadget_is_fsl_usb2(g) 0 +#endif + +/* Mentor high speed function controller */ +/* from Montavista kernel (?) */ +#ifdef CONFIG_USB_GADGET_MUSBHSFC +#define gadget_is_musbhsfc(g) !strcmp("musbhsfc_udc", (g)->name) +#else +#define gadget_is_musbhsfc(g) 0 +#endif + +/* Mentor high speed "dual role" controller, in peripheral role */ +#ifdef CONFIG_USB_GADGET_MUSB_HDRC +#define gadget_is_musbhdrc(g) !strcmp("musb_hdrc", (g)->name) +#else +#define gadget_is_musbhdrc(g) 0 +#endif + +/* from Montavista kernel (?) */ +#ifdef CONFIG_USB_GADGET_MPC8272 +#define gadget_is_mpc8272(g) !strcmp("mpc8272_udc", (g)->name) +#else +#define gadget_is_mpc8272(g) 0 +#endif + +#ifdef CONFIG_USB_GADGET_M66592 +#define gadget_is_m66592(g) !strcmp("m66592_udc", (g)->name) +#else +#define gadget_is_m66592(g) 0 +#endif + + +// CONFIG_USB_GADGET_SX2 +// CONFIG_USB_GADGET_AU1X00 +// ... + + +/** + * usb_gadget_controller_number - support bcdDevice id convention + * @gadget: the controller being driven + * + * Return a 2-digit BCD value associated with the peripheral controller, + * suitable for use as part of a bcdDevice value, or a negative error code. + * + * NOTE: this convention is purely optional, and has no meaning in terms of + * any USB specification. If you want to use a different convention in your + * gadget driver firmware -- maybe a more formal revision ID -- feel free. + * + * Hosts see these bcdDevice numbers, and are allowed (but not encouraged!) + * to change their behavior accordingly. For example it might help avoiding + * some chip bug. + */ +static inline int usb_gadget_controller_number(struct usb_gadget *gadget) +{ + if (gadget_is_net2280(gadget)) + return 0x01; + else if (gadget_is_dummy(gadget)) + return 0x02; + else if (gadget_is_pxa(gadget)) + return 0x03; + else if (gadget_is_sh(gadget)) + return 0x04; + else if (gadget_is_sa1100(gadget)) + return 0x05; + else if (gadget_is_goku(gadget)) + return 0x06; + else if (gadget_is_mq11xx(gadget)) + return 0x07; + else if (gadget_is_omap(gadget)) + return 0x08; + else if (gadget_is_lh7a40x(gadget)) + return 0x09; + else if (gadget_is_n9604(gadget)) + return 0x10; + else if (gadget_is_pxa27x(gadget)) + return 0x11; + else if (gadget_is_s3c2410(gadget)) + return 0x12; + else if (gadget_is_at91(gadget)) + return 0x13; + else if (gadget_is_imx(gadget)) + return 0x14; + else if (gadget_is_musbhsfc(gadget)) + return 0x15; + else if (gadget_is_musbhdrc(gadget)) + return 0x16; + else if (gadget_is_mpc8272(gadget)) + return 0x17; + else if (gadget_is_atmel_usba(gadget)) + return 0x18; + else if (gadget_is_fsl_usb2(gadget)) + return 0x19; + else if (gadget_is_amd5536udc(gadget)) + return 0x20; + else if (gadget_is_m66592(gadget)) + return 0x21; + return -ENOENT; +} diff --git a/drivers/usb/gadget/usbstring.c b/drivers/usb/gadget/usbstring.c new file mode 100644 index 0000000..168f75f --- /dev/null +++ b/drivers/usb/gadget/usbstring.c @@ -0,0 +1,134 @@ +/* + * Copyright (C) 2003 David Brownell + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU Lesser General Public License as published + * by the Free Software Foundation; either version 2.1 of the License, or + * (at your option) any later version. + * + * Ported to U-boot by: Thomas Smits ts.smits@gmail.com and + * Remy Bohmer linux@bohmer.net + */ + +#include <common.h> +#include <asm/errno.h> +#include <linux/usb/ch9.h> +#include <linux/usb/gadget.h> + +#include <asm/unaligned.h> + + +static int utf8_to_utf16le(const char *s, __le16 *cp, unsigned len) +{ + int count = 0; + u8 c; + u16 uchar; + + /* this insists on correct encodings, though not minimal ones. + * BUT it currently rejects legit 4-byte UTF-8 code points, + * which need surrogate pairs. (Unicode 3.1 can use them.) + */ + while (len != 0 && (c = (u8) *s++) != 0) { + if ((c & 0x80)) { + // 2-byte sequence: + // 00000yyyyyxxxxxx = 110yyyyy 10xxxxxx + if ((c & 0xe0) == 0xc0) { + uchar = (c & 0x1f) << 6; + + c = (u8) *s++; + if ((c & 0xc0) != 0x80) + goto fail; + c &= 0x3f; + uchar |= c; + + // 3-byte sequence (most CJKV characters): + // zzzzyyyyyyxxxxxx = 1110zzzz 10yyyyyy 10xxxxxx + } else if ((c & 0xf0) == 0xe0) { + uchar = (c & 0x0f) << 12; + + c = (u8) *s++; + if ((c & 0xc0) != 0x80) + goto fail; + c &= 0x3f; + uchar |= c << 6; + + c = (u8) *s++; + if ((c & 0xc0) != 0x80) + goto fail; + c &= 0x3f; + uchar |= c; + + /* no bogus surrogates */ + if (0xd800 <= uchar && uchar <= 0xdfff) + goto fail; + + // 4-byte sequence (surrogate pairs, currently rare): + // 11101110wwwwzzzzyy + 110111yyyyxxxxxx + // = 11110uuu 10uuzzzz 10yyyyyy 10xxxxxx + // (uuuuu = wwww + 1) + // FIXME accept the surrogate code points (only) + + } else + goto fail; + } else + uchar = c; + put_unaligned_le16(uchar, cp++); + count++; + len--; + } + return count; +fail: + return -1; +} + + +/** + * usb_gadget_get_string - fill out a string descriptor + * @table: of c strings encoded using UTF-8 + * @id: string id, from low byte of wValue in get string descriptor + * @buf: at least 256 bytes + * + * Finds the UTF-8 string matching the ID, and converts it into a + * string descriptor in utf16-le. + * Returns length of descriptor (always even) or negative errno + * + * If your driver needs stings in multiple languages, you'll probably + * "switch (wIndex) { ... }" in your ep0 string descriptor logic, + * using this routine after choosing which set of UTF-8 strings to use. + * Note that US-ASCII is a strict subset of UTF-8; any string bytes with + * the eighth bit set will be multibyte UTF-8 characters, not ISO-8859/1 + * characters (which are also widely used in C strings). + */ +int +usb_gadget_get_string (struct usb_gadget_strings *table, int id, u8 *buf) +{ + struct usb_string *s; + int len; + + /* descriptor 0 has the language id */ + if (id == 0) { + buf [0] = 4; + buf [1] = USB_DT_STRING; + buf [2] = (u8) table->language; + buf [3] = (u8) (table->language >> 8); + return 4; + } + for (s = table->strings; s && s->s; s++) + if (s->id == id) + break; + + /* unrecognized: stall. */ + if (!s || !s->s) + return -EINVAL; + + /* string descriptors have length, tag, then UTF16-LE text */ + len = min ((size_t) 126, strlen (s->s)); + memset (buf + 2, 0, 2 * len); /* zero all the bytes */ + len = utf8_to_utf16le(s->s, (__le16 *)&buf[2], len); + if (len < 0) + return -EINVAL; + buf [0] = (len + 1) * 2; + buf [1] = USB_DT_STRING; + return buf [0]; +} + diff --git a/include/linux/usb/cdc.h b/include/linux/usb/cdc.h new file mode 100644 index 0000000..9b129c9 --- /dev/null +++ b/include/linux/usb/cdc.h @@ -0,0 +1,224 @@ +/* + * USB Communications Device Class (CDC) definitions + * + * CDC says how to talk to lots of different types of network adapters, + * notably ethernet adapters and various modems. It's used mostly with + * firmware based USB peripherals. + * + * Ported to U-boot by: Thomas Smits ts.smits@gmail.com and + * Remy Bohmer linux@bohmer.net + */ + + + +#define USB_CDC_SUBCLASS_ACM 0x02 +#define USB_CDC_SUBCLASS_ETHERNET 0x06 +#define USB_CDC_SUBCLASS_WHCM 0x08 +#define USB_CDC_SUBCLASS_DMM 0x09 +#define USB_CDC_SUBCLASS_MDLM 0x0a +#define USB_CDC_SUBCLASS_OBEX 0x0b + +#define USB_CDC_PROTO_NONE 0 + +#define USB_CDC_ACM_PROTO_AT_V25TER 1 +#define USB_CDC_ACM_PROTO_AT_PCCA101 2 +#define USB_CDC_ACM_PROTO_AT_PCCA101_WAKE 3 +#define USB_CDC_ACM_PROTO_AT_GSM 4 +#define USB_CDC_ACM_PROTO_AT_3G 5 +#define USB_CDC_ACM_PROTO_AT_CDMA 6 +#define USB_CDC_ACM_PROTO_VENDOR 0xff + +/*-------------------------------------------------------------------------*/ + +/* + * Class-Specific descriptors ... there are a couple dozen of them + */ + +#define USB_CDC_HEADER_TYPE 0x00 /* header_desc */ +#define USB_CDC_CALL_MANAGEMENT_TYPE 0x01 /* call_mgmt_descriptor */ +#define USB_CDC_ACM_TYPE 0x02 /* acm_descriptor */ +#define USB_CDC_UNION_TYPE 0x06 /* union_desc */ +#define USB_CDC_COUNTRY_TYPE 0x07 +#define USB_CDC_NETWORK_TERMINAL_TYPE 0x0a /* network_terminal_desc */ +#define USB_CDC_ETHERNET_TYPE 0x0f /* ether_desc */ +#define USB_CDC_WHCM_TYPE 0x11 +#define USB_CDC_MDLM_TYPE 0x12 /* mdlm_desc */ +#define USB_CDC_MDLM_DETAIL_TYPE 0x13 /* mdlm_detail_desc */ +#define USB_CDC_DMM_TYPE 0x14 +#define USB_CDC_OBEX_TYPE 0x15 + +/* "Header Functional Descriptor" from CDC spec 5.2.3.1 */ +struct usb_cdc_header_desc { + __u8 bLength; + __u8 bDescriptorType; + __u8 bDescriptorSubType; + + __le16 bcdCDC; +} __attribute__ ((packed)); + +/* "Call Management Descriptor" from CDC spec 5.2.3.2 */ +struct usb_cdc_call_mgmt_descriptor { + __u8 bLength; + __u8 bDescriptorType; + __u8 bDescriptorSubType; + + __u8 bmCapabilities; +#define USB_CDC_CALL_MGMT_CAP_CALL_MGMT 0x01 +#define USB_CDC_CALL_MGMT_CAP_DATA_INTF 0x02 + + __u8 bDataInterface; +} __attribute__ ((packed)); + +/* "Abstract Control Management Descriptor" from CDC spec 5.2.3.3 */ +struct usb_cdc_acm_descriptor { + __u8 bLength; + __u8 bDescriptorType; + __u8 bDescriptorSubType; + + __u8 bmCapabilities; +} __attribute__ ((packed)); + +/* capabilities from 5.2.3.3 */ + +#define USB_CDC_COMM_FEATURE 0x01 +#define USB_CDC_CAP_LINE 0x02 +#define USB_CDC_CAP_BRK 0x04 +#define USB_CDC_CAP_NOTIFY 0x08 + +/* "Union Functional Descriptor" from CDC spec 5.2.3.8 */ +struct usb_cdc_union_desc { + __u8 bLength; + __u8 bDescriptorType; + __u8 bDescriptorSubType; + + __u8 bMasterInterface0; + __u8 bSlaveInterface0; + /* ... and there could be other slave interfaces */ +} __attribute__ ((packed)); + +/* "Country Selection Functional Descriptor" from CDC spec 5.2.3.9 */ +struct usb_cdc_country_functional_desc { + __u8 bLength; + __u8 bDescriptorType; + __u8 bDescriptorSubType; + + __u8 iCountryCodeRelDate; + __le16 wCountyCode0; + /* ... and there can be a lot of country codes */ +} __attribute__ ((packed)); + +/* "Network Channel Terminal Functional Descriptor" from CDC spec 5.2.3.11 */ +struct usb_cdc_network_terminal_desc { + __u8 bLength; + __u8 bDescriptorType; + __u8 bDescriptorSubType; + + __u8 bEntityId; + __u8 iName; + __u8 bChannelIndex; + __u8 bPhysicalInterface; +} __attribute__ ((packed)); + +/* "Ethernet Networking Functional Descriptor" from CDC spec 5.2.3.16 */ +struct usb_cdc_ether_desc { + __u8 bLength; + __u8 bDescriptorType; + __u8 bDescriptorSubType; + + __u8 iMACAddress; + __le32 bmEthernetStatistics; + __le16 wMaxSegmentSize; + __le16 wNumberMCFilters; + __u8 bNumberPowerFilters; +} __attribute__ ((packed)); + +/* "MDLM Functional Descriptor" from CDC WMC spec 6.7.2.3 */ +struct usb_cdc_mdlm_desc { + __u8 bLength; + __u8 bDescriptorType; + __u8 bDescriptorSubType; + + __le16 bcdVersion; + __u8 bGUID[16]; +} __attribute__ ((packed)); + +/* "MDLM Detail Functional Descriptor" from CDC WMC spec 6.7.2.4 */ +struct usb_cdc_mdlm_detail_desc { + __u8 bLength; + __u8 bDescriptorType; + __u8 bDescriptorSubType; + + /* type is associated with mdlm_desc.bGUID */ + __u8 bGuidDescriptorType; + __u8 bDetailData[0]; +} __attribute__ ((packed)); + +/*-------------------------------------------------------------------------*/ + +/* + * Class-Specific Control Requests (6.2) + * + * section 3.6.2.1 table 4 has the ACM profile, for modems. + * section 3.8.2 table 10 has the ethernet profile. + */ + +#define USB_CDC_SEND_ENCAPSULATED_COMMAND 0x00 +#define USB_CDC_GET_ENCAPSULATED_RESPONSE 0x01 +#define USB_CDC_REQ_SET_LINE_CODING 0x20 +#define USB_CDC_REQ_GET_LINE_CODING 0x21 +#define USB_CDC_REQ_SET_CONTROL_LINE_STATE 0x22 +#define USB_CDC_REQ_SEND_BREAK 0x23 +#define USB_CDC_SET_ETHERNET_MULTICAST_FILTERS 0x40 +#define USB_CDC_SET_ETHERNET_PM_PATTERN_FILTER 0x41 +#define USB_CDC_GET_ETHERNET_PM_PATTERN_FILTER 0x42 +#define USB_CDC_SET_ETHERNET_PACKET_FILTER 0x43 +#define USB_CDC_GET_ETHERNET_STATISTIC 0x44 + +/* Line Coding Structure from CDC spec 6.2.13 */ +struct usb_cdc_line_coding { + __le32 dwDTERate; + __u8 bCharFormat; +#define USB_CDC_1_STOP_BITS 0 +#define USB_CDC_1_5_STOP_BITS 1 +#define USB_CDC_2_STOP_BITS 2 + + __u8 bParityType; +#define USB_CDC_NO_PARITY 0 +#define USB_CDC_ODD_PARITY 1 +#define USB_CDC_EVEN_PARITY 2 +#define USB_CDC_MARK_PARITY 3 +#define USB_CDC_SPACE_PARITY 4 + + __u8 bDataBits; +} __attribute__ ((packed)); + +/* table 62; bits in multicast filter */ +#define USB_CDC_PACKET_TYPE_PROMISCUOUS (1 << 0) +#define USB_CDC_PACKET_TYPE_ALL_MULTICAST (1 << 1) /* no filter */ +#define USB_CDC_PACKET_TYPE_DIRECTED (1 << 2) +#define USB_CDC_PACKET_TYPE_BROADCAST (1 << 3) +#define USB_CDC_PACKET_TYPE_MULTICAST (1 << 4) /* filtered */ + + +/*-------------------------------------------------------------------------*/ + +/* + * Class-Specific Notifications (6.3) sent by interrupt transfers + * + * section 3.8.2 table 11 of the CDC spec lists Ethernet notifications + * section 3.6.2.1 table 5 specifies ACM notifications + */ + +#define USB_CDC_NOTIFY_NETWORK_CONNECTION 0x00 +#define USB_CDC_NOTIFY_RESPONSE_AVAILABLE 0x01 +#define USB_CDC_NOTIFY_SERIAL_STATE 0x20 +#define USB_CDC_NOTIFY_SPEED_CHANGE 0x2a + +struct usb_cdc_notification { + __u8 bmRequestType; + __u8 bNotificationType; + __le16 wValue; + __le16 wIndex; + __le16 wLength; +} __attribute__ ((packed)); + diff --git a/include/linux/usb/ch9.h b/include/linux/usb/ch9.h new file mode 100644 index 0000000..1091692 --- /dev/null +++ b/include/linux/usb/ch9.h @@ -0,0 +1,587 @@ +/* + * This file holds USB constants and structures that are needed for + * USB device APIs. These are used by the USB device model, which is + * defined in chapter 9 of the USB 2.0 specification and in the + * Wireless USB 1.0 (spread around). Linux has several APIs in C that + * need these: + * + * - the master/host side Linux-USB kernel driver API; + * - the "usbfs" user space API; and + * - the Linux "gadget" slave/device/peripheral side driver API. + * + * USB 2.0 adds an additional "On The Go" (OTG) mode, which lets systems + * act either as a USB master/host or as a USB slave/device. That means + * the master and slave side APIs benefit from working well together. + * + * There's also "Wireless USB", using low power short range radios for + * peripheral interconnection but otherwise building on the USB framework. + * + * Note all descriptors are declared '__attribute__((packed))' so that: + * + * [a] they never get padded, either internally (USB spec writers + * probably handled that) or externally; + * + * [b] so that accessing bigger-than-a-bytes fields will never + * generate bus errors on any platform, even when the location of + * its descriptor inside a bundle isn't "naturally aligned", and + * + * [c] for consistency, removing all doubt even when it appears to + * someone that the two other points are non-issues for that + * particular descriptor type. + * + * Ported to U-boot by: Thomas Smits ts.smits@gmail.com and + * Remy Bohmer linux@bohmer.net + */ + +#ifndef __LINUX_USB_CH9_H +#define __LINUX_USB_CH9_H + +#include <linux/types.h> /* __u8 etc */ + +/*-------------------------------------------------------------------------*/ + +/* CONTROL REQUEST SUPPORT */ + +/* + * USB directions + * + * This bit flag is used in endpoint descriptors' bEndpointAddress field. + * It's also one of three fields in control requests bRequestType. + */ +#define USB_DIR_OUT 0 /* to device */ +#define USB_DIR_IN 0x80 /* to host */ + +/* + * USB types, the second of three bRequestType fields + */ +#define USB_TYPE_MASK (0x03 << 5) +#define USB_TYPE_STANDARD (0x00 << 5) +#define USB_TYPE_CLASS (0x01 << 5) +#define USB_TYPE_VENDOR (0x02 << 5) +#define USB_TYPE_RESERVED (0x03 << 5) + +/* + * USB recipients, the third of three bRequestType fields + */ +#define USB_RECIP_MASK 0x1f +#define USB_RECIP_DEVICE 0x00 +#define USB_RECIP_INTERFACE 0x01 +#define USB_RECIP_ENDPOINT 0x02 +#define USB_RECIP_OTHER 0x03 +/* From Wireless USB 1.0 */ +#define USB_RECIP_PORT 0x04 +#define USB_RECIP_RPIPE 0x05 + +/* + * Standard requests, for the bRequest field of a SETUP packet. + * + * These are qualified by the bRequestType field, so that for example + * TYPE_CLASS or TYPE_VENDOR specific feature flags could be retrieved + * by a GET_STATUS request. + */ +#define USB_REQ_GET_STATUS 0x00 +#define USB_REQ_CLEAR_FEATURE 0x01 +#define USB_REQ_SET_FEATURE 0x03 +#define USB_REQ_SET_ADDRESS 0x05 +#define USB_REQ_GET_DESCRIPTOR 0x06 +#define USB_REQ_SET_DESCRIPTOR 0x07 +#define USB_REQ_GET_CONFIGURATION 0x08 +#define USB_REQ_SET_CONFIGURATION 0x09 +#define USB_REQ_GET_INTERFACE 0x0A +#define USB_REQ_SET_INTERFACE 0x0B +#define USB_REQ_SYNCH_FRAME 0x0C + +#define USB_REQ_SET_ENCRYPTION 0x0D /* Wireless USB */ +#define USB_REQ_GET_ENCRYPTION 0x0E +#define USB_REQ_RPIPE_ABORT 0x0E +#define USB_REQ_SET_HANDSHAKE 0x0F +#define USB_REQ_RPIPE_RESET 0x0F +#define USB_REQ_GET_HANDSHAKE 0x10 +#define USB_REQ_SET_CONNECTION 0x11 +#define USB_REQ_SET_SECURITY_DATA 0x12 +#define USB_REQ_GET_SECURITY_DATA 0x13 +#define USB_REQ_SET_WUSB_DATA 0x14 +#define USB_REQ_LOOPBACK_DATA_WRITE 0x15 +#define USB_REQ_LOOPBACK_DATA_READ 0x16 +#define USB_REQ_SET_INTERFACE_DS 0x17 + +/* + * USB feature flags are written using USB_REQ_{CLEAR,SET}_FEATURE, and + * are read as a bit array returned by USB_REQ_GET_STATUS. (So there + * are at most sixteen features of each type.) + */ +#define USB_DEVICE_SELF_POWERED 0 /* (read only) */ +#define USB_DEVICE_REMOTE_WAKEUP 1 /* dev may initiate wakeup */ +#define USB_DEVICE_TEST_MODE 2 /* (wired high speed only) */ +#define USB_DEVICE_BATTERY 2 /* (wireless) */ +#define USB_DEVICE_B_HNP_ENABLE 3 /* (otg) dev may initiate HNP */ +#define USB_DEVICE_WUSB_DEVICE 3 /* (wireless)*/ +#define USB_DEVICE_A_HNP_SUPPORT 4 /* (otg) RH port supports HNP */ +#define USB_DEVICE_A_ALT_HNP_SUPPORT 5 /* (otg) other RH port does */ +#define USB_DEVICE_DEBUG_MODE 6 /* (special devices only) */ + +#define USB_ENDPOINT_HALT 0 /* IN/OUT will STALL */ + + +/** + * struct usb_ctrlrequest - SETUP data for a USB device control request + * @bRequestType: matches the USB bmRequestType field + * @bRequest: matches the USB bRequest field + * @wValue: matches the USB wValue field (le16 byte order) + * @wIndex: matches the USB wIndex field (le16 byte order) + * @wLength: matches the USB wLength field (le16 byte order) + * + * This structure is used to send control requests to a USB device. It matches + * the different fields of the USB 2.0 Spec section 9.3, table 9-2. See the + * USB spec for a fuller description of the different fields, and what they are + * used for. + * + * Note that the driver for any interface can issue control requests. + * For most devices, interfaces don't coordinate with each other, so + * such requests may be made at any time. + */ +#if defined(__BIG_ENDIAN) || defined(__ARMEB__) +#error (functionality not verified for big endian targets, todo...) +#endif + +struct usb_ctrlrequest { + __u8 bRequestType; + __u8 bRequest; + __le16 wValue; + __le16 wIndex; + __le16 wLength; +} __attribute__ ((packed)); + +/*-------------------------------------------------------------------------*/ + +/* + * STANDARD DESCRIPTORS ... as returned by GET_DESCRIPTOR, or + * (rarely) accepted by SET_DESCRIPTOR. + * + * Note that all multi-byte values here are encoded in little endian + * byte order "on the wire". But when exposed through Linux-USB APIs, + * they've been converted to cpu byte order. + */ + +/* + * Descriptor types ... USB 2.0 spec table 9.5 + */ +#define USB_DT_DEVICE 0x01 +#define USB_DT_CONFIG 0x02 +#define USB_DT_STRING 0x03 +#define USB_DT_INTERFACE 0x04 +#define USB_DT_ENDPOINT 0x05 +#define USB_DT_DEVICE_QUALIFIER 0x06 +#define USB_DT_OTHER_SPEED_CONFIG 0x07 +#define USB_DT_INTERFACE_POWER 0x08 +/* these are from a minor usb 2.0 revision (ECN) */ +#define USB_DT_OTG 0x09 +#define USB_DT_DEBUG 0x0a +#define USB_DT_INTERFACE_ASSOCIATION 0x0b +/* these are from the Wireless USB spec */ +#define USB_DT_SECURITY 0x0c +#define USB_DT_KEY 0x0d +#define USB_DT_ENCRYPTION_TYPE 0x0e +#define USB_DT_BOS 0x0f +#define USB_DT_DEVICE_CAPABILITY 0x10 +#define USB_DT_WIRELESS_ENDPOINT_COMP 0x11 +#define USB_DT_WIRE_ADAPTER 0x21 +#define USB_DT_RPIPE 0x22 + +/* Conventional codes for class-specific descriptors. The convention is + * defined in the USB "Common Class" Spec (3.11). Individual class specs + * are authoritative for their usage, not the "common class" writeup. + */ +#define USB_DT_CS_DEVICE (USB_TYPE_CLASS | USB_DT_DEVICE) +#define USB_DT_CS_CONFIG (USB_TYPE_CLASS | USB_DT_CONFIG) +#define USB_DT_CS_STRING (USB_TYPE_CLASS | USB_DT_STRING) +#define USB_DT_CS_INTERFACE (USB_TYPE_CLASS | USB_DT_INTERFACE) +#define USB_DT_CS_ENDPOINT (USB_TYPE_CLASS | USB_DT_ENDPOINT) + +/* All standard descriptors have these 2 fields at the beginning */ +struct usb_descriptor_header { + __u8 bLength; + __u8 bDescriptorType; +} __attribute__ ((packed)); + + +/*-------------------------------------------------------------------------*/ + +/* USB_DT_DEVICE: Device descriptor */ +struct usb_device_descriptor { + __u8 bLength; + __u8 bDescriptorType; + + __le16 bcdUSB; + __u8 bDeviceClass; + __u8 bDeviceSubClass; + __u8 bDeviceProtocol; + __u8 bMaxPacketSize0; + __le16 idVendor; + __le16 idProduct; + __le16 bcdDevice; + __u8 iManufacturer; + __u8 iProduct; + __u8 iSerialNumber; + __u8 bNumConfigurations; +} __attribute__ ((packed)); + +#define USB_DT_DEVICE_SIZE 18 + + +/* + * Device and/or Interface Class codes + * as found in bDeviceClass or bInterfaceClass + * and defined by www.usb.org documents + */ +#define USB_CLASS_PER_INTERFACE 0 /* for DeviceClass */ +#define USB_CLASS_AUDIO 1 +#define USB_CLASS_COMM 2 +#define USB_CLASS_HID 3 +#define USB_CLASS_PHYSICAL 5 +#define USB_CLASS_STILL_IMAGE 6 +#define USB_CLASS_PRINTER 7 +#define USB_CLASS_MASS_STORAGE 8 +#define USB_CLASS_HUB 9 +#define USB_CLASS_CDC_DATA 0x0a +#define USB_CLASS_CSCID 0x0b /* chip+ smart card */ +#define USB_CLASS_CONTENT_SEC 0x0d /* content security */ +#define USB_CLASS_VIDEO 0x0e +#define USB_CLASS_WIRELESS_CONTROLLER 0xe0 +#define USB_CLASS_MISC 0xef +#define USB_CLASS_APP_SPEC 0xfe +#define USB_CLASS_VENDOR_SPEC 0xff + +/*-------------------------------------------------------------------------*/ + +/* USB_DT_CONFIG: Configuration descriptor information. + * + * USB_DT_OTHER_SPEED_CONFIG is the same descriptor, except that the + * descriptor type is different. Highspeed-capable devices can look + * different depending on what speed they're currently running. Only + * devices with a USB_DT_DEVICE_QUALIFIER have any OTHER_SPEED_CONFIG + * descriptors. + */ +struct usb_config_descriptor { + __u8 bLength; + __u8 bDescriptorType; + + __le16 wTotalLength; + __u8 bNumInterfaces; + __u8 bConfigurationValue; + __u8 iConfiguration; + __u8 bmAttributes; + __u8 bMaxPower; +} __attribute__ ((packed)); + +#define USB_DT_CONFIG_SIZE 9 + +/* from config descriptor bmAttributes */ +#define USB_CONFIG_ATT_ONE (1 << 7) /* must be set */ +#define USB_CONFIG_ATT_SELFPOWER (1 << 6) /* self powered */ +#define USB_CONFIG_ATT_WAKEUP (1 << 5) /* can wakeup */ +#define USB_CONFIG_ATT_BATTERY (1 << 4) /* battery powered */ + +/*-------------------------------------------------------------------------*/ + +/* USB_DT_STRING: String descriptor */ +struct usb_string_descriptor { + __u8 bLength; + __u8 bDescriptorType; + + __le16 wData[1]; /* UTF-16LE encoded */ +} __attribute__ ((packed)); + +/* note that "string" zero is special, it holds language codes that + * the device supports, not Unicode characters. + */ + +/*-------------------------------------------------------------------------*/ + +/* USB_DT_INTERFACE: Interface descriptor */ +struct usb_interface_descriptor { + __u8 bLength; + __u8 bDescriptorType; + + __u8 bInterfaceNumber; + __u8 bAlternateSetting; + __u8 bNumEndpoints; + __u8 bInterfaceClass; + __u8 bInterfaceSubClass; + __u8 bInterfaceProtocol; + __u8 iInterface; +} __attribute__ ((packed)); + +#define USB_DT_INTERFACE_SIZE 9 + +/*-------------------------------------------------------------------------*/ + +/* USB_DT_ENDPOINT: Endpoint descriptor */ +struct usb_endpoint_descriptor { + __u8 bLength; + __u8 bDescriptorType; + + __u8 bEndpointAddress; + __u8 bmAttributes; + __le16 wMaxPacketSize; + __u8 bInterval; + + /* NOTE: these two are _only_ in audio endpoints. */ + /* use USB_DT_ENDPOINT*_SIZE in bLength, not sizeof. */ + __u8 bRefresh; + __u8 bSynchAddress; +} __attribute__ ((packed)); + +#define USB_DT_ENDPOINT_SIZE 7 +#define USB_DT_ENDPOINT_AUDIO_SIZE 9 /* Audio extension */ + + +/* + * Endpoints + */ +#define USB_ENDPOINT_NUMBER_MASK 0x0f /* in bEndpointAddress */ +#define USB_ENDPOINT_DIR_MASK 0x80 + +#define USB_ENDPOINT_XFERTYPE_MASK 0x03 /* in bmAttributes */ +#define USB_ENDPOINT_XFER_CONTROL 0 +#define USB_ENDPOINT_XFER_ISOC 1 +#define USB_ENDPOINT_XFER_BULK 2 +#define USB_ENDPOINT_XFER_INT 3 +#define USB_ENDPOINT_MAX_ADJUSTABLE 0x80 + + +/*-------------------------------------------------------------------------*/ + +/* USB_DT_DEVICE_QUALIFIER: Device Qualifier descriptor */ +struct usb_qualifier_descriptor { + __u8 bLength; + __u8 bDescriptorType; + + __le16 bcdUSB; + __u8 bDeviceClass; + __u8 bDeviceSubClass; + __u8 bDeviceProtocol; + __u8 bMaxPacketSize0; + __u8 bNumConfigurations; + __u8 bRESERVED; +} __attribute__ ((packed)); + + +/*-------------------------------------------------------------------------*/ + +/* USB_DT_OTG (from OTG 1.0a supplement) */ +struct usb_otg_descriptor { + __u8 bLength; + __u8 bDescriptorType; + + __u8 bmAttributes; /* support for HNP, SRP, etc */ +} __attribute__ ((packed)); + +/* from usb_otg_descriptor.bmAttributes */ +#define USB_OTG_SRP (1 << 0) +#define USB_OTG_HNP (1 << 1) /* swap host/device roles */ + +/*-------------------------------------------------------------------------*/ + +/* USB_DT_DEBUG: for special highspeed devices, replacing serial console */ +struct usb_debug_descriptor { + __u8 bLength; + __u8 bDescriptorType; + + /* bulk endpoints with 8 byte maxpacket */ + __u8 bDebugInEndpoint; + __u8 bDebugOutEndpoint; +} __attribute__((packed)); + +/*-------------------------------------------------------------------------*/ + +/* USB_DT_INTERFACE_ASSOCIATION: groups interfaces */ +struct usb_interface_assoc_descriptor { + __u8 bLength; + __u8 bDescriptorType; + + __u8 bFirstInterface; + __u8 bInterfaceCount; + __u8 bFunctionClass; + __u8 bFunctionSubClass; + __u8 bFunctionProtocol; + __u8 iFunction; +} __attribute__ ((packed)); + + +/*-------------------------------------------------------------------------*/ + +/* USB_DT_SECURITY: group of wireless security descriptors, including + * encryption types available for setting up a CC/association. + */ +struct usb_security_descriptor { + __u8 bLength; + __u8 bDescriptorType; + + __le16 wTotalLength; + __u8 bNumEncryptionTypes; +} __attribute__((packed)); + +/*-------------------------------------------------------------------------*/ + +/* USB_DT_KEY: used with {GET,SET}_SECURITY_DATA; only public keys + * may be retrieved. + */ +struct usb_key_descriptor { + __u8 bLength; + __u8 bDescriptorType; + + __u8 tTKID[3]; + __u8 bReserved; + __u8 bKeyData[0]; +} __attribute__((packed)); + +/*-------------------------------------------------------------------------*/ + +/* USB_DT_ENCRYPTION_TYPE: bundled in DT_SECURITY groups */ +struct usb_encryption_descriptor { + __u8 bLength; + __u8 bDescriptorType; + + __u8 bEncryptionType; +#define USB_ENC_TYPE_UNSECURE 0 +#define USB_ENC_TYPE_WIRED 1 /* non-wireless mode */ +#define USB_ENC_TYPE_CCM_1 2 /* aes128/cbc session */ +#define USB_ENC_TYPE_RSA_1 3 /* rsa3072/sha1 auth */ + __u8 bEncryptionValue; /* use in SET_ENCRYPTION */ + __u8 bAuthKeyIndex; +} __attribute__((packed)); + + +/*-------------------------------------------------------------------------*/ + +/* USB_DT_BOS: group of wireless capabilities */ +struct usb_bos_descriptor { + __u8 bLength; + __u8 bDescriptorType; + + __le16 wTotalLength; + __u8 bNumDeviceCaps; +} __attribute__((packed)); + +/*-------------------------------------------------------------------------*/ + +/* USB_DT_DEVICE_CAPABILITY: grouped with BOS */ +struct usb_dev_cap_header { + __u8 bLength; + __u8 bDescriptorType; + __u8 bDevCapabilityType; +} __attribute__((packed)); + +#define USB_CAP_TYPE_WIRELESS_USB 1 + +struct usb_wireless_cap_descriptor { /* Ultra Wide Band */ + __u8 bLength; + __u8 bDescriptorType; + __u8 bDevCapabilityType; + + __u8 bmAttributes; +#define USB_WIRELESS_P2P_DRD (1 << 1) +#define USB_WIRELESS_BEACON_MASK (3 << 2) +#define USB_WIRELESS_BEACON_SELF (1 << 2) +#define USB_WIRELESS_BEACON_DIRECTED (2 << 2) +#define USB_WIRELESS_BEACON_NONE (3 << 2) + __le16 wPHYRates; /* bit rates, Mbps */ +#define USB_WIRELESS_PHY_53 (1 << 0) /* always set */ +#define USB_WIRELESS_PHY_80 (1 << 1) +#define USB_WIRELESS_PHY_107 (1 << 2) /* always set */ +#define USB_WIRELESS_PHY_160 (1 << 3) +#define USB_WIRELESS_PHY_200 (1 << 4) /* always set */ +#define USB_WIRELESS_PHY_320 (1 << 5) +#define USB_WIRELESS_PHY_400 (1 << 6) +#define USB_WIRELESS_PHY_480 (1 << 7) + __u8 bmTFITXPowerInfo; /* TFI power levels */ + __u8 bmFFITXPowerInfo; /* FFI power levels */ + __le16 bmBandGroup; + __u8 bReserved; +} __attribute__((packed)); + +/*-------------------------------------------------------------------------*/ + +/* USB_DT_WIRELESS_ENDPOINT_COMP: companion descriptor associated with + * each endpoint descriptor for a wireless device + */ +struct usb_wireless_ep_comp_descriptor { + __u8 bLength; + __u8 bDescriptorType; + + __u8 bMaxBurst; + __u8 bMaxSequence; + __le16 wMaxStreamDelay; + __le16 wOverTheAirPacketSize; + __u8 bOverTheAirInterval; + __u8 bmCompAttributes; +#define USB_ENDPOINT_SWITCH_MASK 0x03 /* in bmCompAttributes */ +#define USB_ENDPOINT_SWITCH_NO 0 +#define USB_ENDPOINT_SWITCH_SWITCH 1 +#define USB_ENDPOINT_SWITCH_SCALE 2 +} __attribute__((packed)); + +/*-------------------------------------------------------------------------*/ + +/* USB_REQ_SET_HANDSHAKE is a four-way handshake used between a wireless + * host and a device for connection set up, mutual authentication, and + * exchanging short lived session keys. The handshake depends on a CC. + */ +struct usb_handshake { + __u8 bMessageNumber; + __u8 bStatus; + __u8 tTKID[3]; + __u8 bReserved; + __u8 CDID[16]; + __u8 nonce[16]; + __u8 MIC[8]; +} __attribute__((packed)); + +/*-------------------------------------------------------------------------*/ + +/* USB_REQ_SET_CONNECTION modifies or revokes a connection context (CC). + * A CC may also be set up using non-wireless secure channels (including + * wired USB!), and some devices may support CCs with multiple hosts. + */ +struct usb_connection_context { + __u8 CHID[16]; /* persistent host id */ + __u8 CDID[16]; /* device id (unique w/in host context) */ + __u8 CK[16]; /* connection key */ +} __attribute__((packed)); + +/*-------------------------------------------------------------------------*/ + +/* USB 2.0 defines three speeds, here's how Linux identifies them */ + +enum usb_device_speed { + USB_SPEED_UNKNOWN = 0, /* enumerating */ + USB_SPEED_LOW, USB_SPEED_FULL, /* usb 1.1 */ + USB_SPEED_HIGH, /* usb 2.0 */ + USB_SPEED_VARIABLE, /* wireless (usb 2.5) */ +}; + +enum usb_device_state { + /* NOTATTACHED isn't in the USB spec, and this state acts + * the same as ATTACHED ... but it's clearer this way. + */ + USB_STATE_NOTATTACHED = 0, + + /* chapter 9 and authentication (wireless) device states */ + USB_STATE_ATTACHED, + USB_STATE_POWERED, /* wired */ + USB_STATE_UNAUTHENTICATED, /* auth */ + USB_STATE_RECONNECTING, /* auth */ + USB_STATE_DEFAULT, /* limited function */ + USB_STATE_ADDRESS, + USB_STATE_CONFIGURED, /* most functions */ + + USB_STATE_SUSPENDED + + /* NOTE: there are actually four different SUSPENDED + * states, returning to POWERED, DEFAULT, ADDRESS, or + * CONFIGURED respectively when SOF tokens flow again. + */ +}; + +#endif /* __LINUX_USB_CH9_H */ diff --git a/include/linux/usb/gadget.h b/include/linux/usb/gadget.h new file mode 100644 index 0000000..344fc78 --- /dev/null +++ b/include/linux/usb/gadget.h @@ -0,0 +1,871 @@ +/* + * <linux/usb/gadget.h> + * + * We call the USB code inside a Linux-based peripheral device a "gadget" + * driver, except for the hardware-specific bus glue. One USB host can + * master many USB gadgets, but the gadgets are only slaved to one host. + * + * + * (C) Copyright 2002-2004 by David Brownell + * All Rights Reserved. + * + * This software is licensed under the GNU GPL version 2. + * + * Ported to U-boot by: Thomas Smits ts.smits@gmail.com and + * Remy Bohmer linux@bohmer.net + */ + +#ifndef __LINUX_USB_GADGET_H +#define __LINUX_USB_GADGET_H + +#include <linux/list.h> + +struct usb_ep; + +/** + * struct usb_request - describes one i/o request + * @buf: Buffer used for data. Always provide this; some controllers + * only use PIO, or don't use DMA for some endpoints. + * @dma: DMA address corresponding to 'buf'. If you don't set this + * field, and the usb controller needs one, it is responsible + * for mapping and unmapping the buffer. + * @length: Length of that data + * @no_interrupt: If true, hints that no completion irq is needed. + * Helpful sometimes with deep request queues that are handled + * directly by DMA controllers. + * @zero: If true, when writing data, makes the last packet be "short" + * by adding a zero length packet as needed; + * @short_not_ok: When reading data, makes short packets be + * treated as errors (queue stops advancing till cleanup). + * @complete: Function called when request completes, so this request and + * its buffer may be re-used. + * Reads terminate with a short packet, or when the buffer fills, + * whichever comes first. When writes terminate, some data bytes + * will usually still be in flight (often in a hardware fifo). + * Errors (for reads or writes) stop the queue from advancing + * until the completion function returns, so that any transfers + * invalidated by the error may first be dequeued. + * @context: For use by the completion callback + * @list: For use by the gadget driver. + * @status: Reports completion code, zero or a negative errno. + * Normally, faults block the transfer queue from advancing until + * the completion callback returns. + * Code "-ESHUTDOWN" indicates completion caused by device disconnect, + * or when the driver disabled the endpoint. + * @actual: Reports bytes transferred to/from the buffer. For reads (OUT + * transfers) this may be less than the requested length. If the + * short_not_ok flag is set, short reads are treated as errors + * even when status otherwise indicates successful completion. + * Note that for writes (IN transfers) some data bytes may still + * reside in a device-side FIFO when the request is reported as + * complete. + * + * These are allocated/freed through the endpoint they're used with. The + * hardware's driver can add extra per-request data to the memory it returns, + * which often avoids separate memory allocations (potential failures), + * later when the request is queued. + * + * Request flags affect request handling, such as whether a zero length + * packet is written (the "zero" flag), whether a short read should be + * treated as an error (blocking request queue advance, the "short_not_ok" + * flag), or hinting that an interrupt is not required (the "no_interrupt" + * flag, for use with deep request queues). + * + * Bulk endpoints can use any size buffers, and can also be used for interrupt + * transfers. interrupt-only endpoints can be much less functional. + */ + // NOTE this is analagous to 'struct urb' on the host side, + // except that it's thinner and promotes more pre-allocation. + +struct usb_request { + void *buf; + unsigned length; + dma_addr_t dma; + + unsigned no_interrupt:1; + unsigned zero:1; + unsigned short_not_ok:1; + + void (*complete)(struct usb_ep *ep, + struct usb_request *req); + void *context; + struct list_head list; + + int status; + unsigned actual; +}; + +/*-------------------------------------------------------------------------*/ + +/* endpoint-specific parts of the api to the usb controller hardware. + * unlike the urb model, (de)multiplexing layers are not required. + * (so this api could slash overhead if used on the host side...) + * + * note that device side usb controllers commonly differ in how many + * endpoints they support, as well as their capabilities. + */ +struct usb_ep_ops { + int (*enable) (struct usb_ep *ep, + const struct usb_endpoint_descriptor *desc); + int (*disable) (struct usb_ep *ep); + + struct usb_request *(*alloc_request) (struct usb_ep *ep, + gfp_t gfp_flags); + void (*free_request) (struct usb_ep *ep, struct usb_request *req); + + int (*queue) (struct usb_ep *ep, struct usb_request *req, + gfp_t gfp_flags); + int (*dequeue) (struct usb_ep *ep, struct usb_request *req); + + int (*set_halt) (struct usb_ep *ep, int value); + int (*fifo_status) (struct usb_ep *ep); + void (*fifo_flush) (struct usb_ep *ep); +}; + +/** + * struct usb_ep - device side representation of USB endpoint + * @name:identifier for the endpoint, such as "ep-a" or "ep9in-bulk" + * @ops: Function pointers used to access hardware-specific operations. + * @ep_list:the gadget's ep_list holds all of its endpoints + * @maxpacket:The maximum packet size used on this endpoint. The initial + * value can sometimes be reduced (hardware allowing), according to + * the endpoint descriptor used to configure the endpoint. + * @driver_data:for use by the gadget driver. all other fields are + * read-only to gadget drivers. + * + * the bus controller driver lists all the general purpose endpoints in + * gadget->ep_list. the control endpoint (gadget->ep0) is not in that list, + * and is accessed only in response to a driver setup() callback. + */ +struct usb_ep { + void *driver_data; + const char *name; + const struct usb_ep_ops *ops; + struct list_head ep_list; + unsigned maxpacket:16; +}; + +/*-------------------------------------------------------------------------*/ + +/** + * usb_ep_enable - configure endpoint, making it usable + * @ep:the endpoint being configured. may not be the endpoint named "ep0". + * drivers discover endpoints through the ep_list of a usb_gadget. + * @desc:descriptor for desired behavior. caller guarantees this pointer + * remains valid until the endpoint is disabled; the data byte order + * is little-endian (usb-standard). + * + * when configurations are set, or when interface settings change, the driver + * will enable or disable the relevant endpoints. while it is enabled, an + * endpoint may be used for i/o until the driver receives a disconnect() from + * the host or until the endpoint is disabled. + * + * the ep0 implementation (which calls this routine) must ensure that the + * hardware capabilities of each endpoint match the descriptor provided + * for it. for example, an endpoint named "ep2in-bulk" would be usable + * for interrupt transfers as well as bulk, but it likely couldn't be used + * for iso transfers or for endpoint 14. some endpoints are fully + * configurable, with more generic names like "ep-a". (remember that for + * USB, "in" means "towards the USB master".) + * + * returns zero, or a negative error code. + */ +static inline int +usb_ep_enable (struct usb_ep *ep, const struct usb_endpoint_descriptor *desc) +{ + return ep->ops->enable (ep, desc); +} + +/** + * usb_ep_disable - endpoint is no longer usable + * @ep:the endpoint being unconfigured. may not be the endpoint named "ep0". + * + * no other task may be using this endpoint when this is called. + * any pending and uncompleted requests will complete with status + * indicating disconnect (-ESHUTDOWN) before this call returns. + * gadget drivers must call usb_ep_enable() again before queueing + * requests to the endpoint. + * + * returns zero, or a negative error code. + */ +static inline int +usb_ep_disable (struct usb_ep *ep) +{ + return ep->ops->disable (ep); +} + +/** + * usb_ep_alloc_request - allocate a request object to use with this endpoint + * @ep:the endpoint to be used with with the request + * @gfp_flags:GFP_* flags to use + * + * Request objects must be allocated with this call, since they normally + * need controller-specific setup and may even need endpoint-specific + * resources such as allocation of DMA descriptors. + * Requests may be submitted with usb_ep_queue(), and receive a single + * completion callback. Free requests with usb_ep_free_request(), when + * they are no longer needed. + * + * Returns the request, or null if one could not be allocated. + */ +static inline struct usb_request * +usb_ep_alloc_request (struct usb_ep *ep, gfp_t gfp_flags) +{ + return ep->ops->alloc_request (ep, gfp_flags); +} + +/** + * usb_ep_free_request - frees a request object + * @ep:the endpoint associated with the request + * @req:the request being freed + * + * Reverses the effect of usb_ep_alloc_request(). + * Caller guarantees the request is not queued, and that it will + * no longer be requeued (or otherwise used). + */ +static inline void +usb_ep_free_request (struct usb_ep *ep, struct usb_request *req) +{ + ep->ops->free_request (ep, req); +} + +/** + * usb_ep_queue - queues (submits) an I/O request to an endpoint. + * @ep:the endpoint associated with the request + * @req:the request being submitted + * @gfp_flags: GFP_* flags to use in case the lower level driver couldn't + * pre-allocate all necessary memory with the request. + * + * This tells the device controller to perform the specified request through + * that endpoint (reading or writing a buffer). When the request completes, + * including being canceled by usb_ep_dequeue(), the request's completion + * routine is called to return the request to the driver. Any endpoint + * (except control endpoints like ep0) may have more than one transfer + * request queued; they complete in FIFO order. Once a gadget driver + * submits a request, that request may not be examined or modified until it + * is given back to that driver through the completion callback. + * + * Each request is turned into one or more packets. The controller driver + * never merges adjacent requests into the same packet. OUT transfers + * will sometimes use data that's already buffered in the hardware. + * Drivers can rely on the fact that the first byte of the request's buffer + * always corresponds to the first byte of some USB packet, for both + * IN and OUT transfers. + * + * Bulk endpoints can queue any amount of data; the transfer is packetized + * automatically. The last packet will be short if the request doesn't fill it + * out completely. Zero length packets (ZLPs) should be avoided in portable + * protocols since not all usb hardware can successfully handle zero length + * packets. (ZLPs may be explicitly written, and may be implicitly written if + * the request 'zero' flag is set.) Bulk endpoints may also be used + * for interrupt transfers; but the reverse is not true, and some endpoints + * won't support every interrupt transfer. (Such as 768 byte packets.) + * + * Interrupt-only endpoints are less functional than bulk endpoints, for + * example by not supporting queueing or not handling buffers that are + * larger than the endpoint's maxpacket size. They may also treat data + * toggle differently. + * + * Control endpoints ... after getting a setup() callback, the driver queues + * one response (even if it would be zero length). That enables the + * status ack, after transfering data as specified in the response. Setup + * functions may return negative error codes to generate protocol stalls. + * (Note that some USB device controllers disallow protocol stall responses + * in some cases.) When control responses are deferred (the response is + * written after the setup callback returns), then usb_ep_set_halt() may be + * used on ep0 to trigger protocol stalls. + * + * For periodic endpoints, like interrupt or isochronous ones, the usb host + * arranges to poll once per interval, and the gadget driver usually will + * have queued some data to transfer at that time. + * + * Returns zero, or a negative error code. Endpoints that are not enabled + * report errors; errors will also be + * reported when the usb peripheral is disconnected. + */ +static inline int +usb_ep_queue (struct usb_ep *ep, struct usb_request *req, gfp_t gfp_flags) +{ + return ep->ops->queue (ep, req, gfp_flags); +} + +/** + * usb_ep_dequeue - dequeues (cancels, unlinks) an I/O request from an endpoint + * @ep:the endpoint associated with the request + * @req:the request being canceled + * + * if the request is still active on the endpoint, it is dequeued and its + * completion routine is called (with status -ECONNRESET); else a negative + * error code is returned. + * + * note that some hardware can't clear out write fifos (to unlink the request + * at the head of the queue) except as part of disconnecting from usb. such + * restrictions prevent drivers from supporting configuration changes, + * even to configuration zero (a "chapter 9" requirement). + */ +static inline int usb_ep_dequeue (struct usb_ep *ep, struct usb_request *req) +{ + return ep->ops->dequeue (ep, req); +} + +/** + * usb_ep_set_halt - sets the endpoint halt feature. + * @ep: the non-isochronous endpoint being stalled + * + * Use this to stall an endpoint, perhaps as an error report. + * Except for control endpoints, + * the endpoint stays halted (will not stream any data) until the host + * clears this feature; drivers may need to empty the endpoint's request + * queue first, to make sure no inappropriate transfers happen. + * + * Note that while an endpoint CLEAR_FEATURE will be invisible to the + * gadget driver, a SET_INTERFACE will not be. To reset endpoints for the + * current altsetting, see usb_ep_clear_halt(). When switching altsettings, + * it's simplest to use usb_ep_enable() or usb_ep_disable() for the endpoints. + * + * Returns zero, or a negative error code. On success, this call sets + * underlying hardware state that blocks data transfers. + * Attempts to halt IN endpoints will fail (returning -EAGAIN) if any + * transfer requests are still queued, or if the controller hardware + * (usually a FIFO) still holds bytes that the host hasn't collected. + */ +static inline int +usb_ep_set_halt (struct usb_ep *ep) +{ + return ep->ops->set_halt (ep, 1); +} + +/** + * usb_ep_clear_halt - clears endpoint halt, and resets toggle + * @ep:the bulk or interrupt endpoint being reset + * + * Use this when responding to the standard usb "set interface" request, + * for endpoints that aren't reconfigured, after clearing any other state + * in the endpoint's i/o queue. + * + * Returns zero, or a negative error code. On success, this call clears + * the underlying hardware state reflecting endpoint halt and data toggle. + * Note that some hardware can't support this request (like pxa2xx_udc), + * and accordingly can't correctly implement interface altsettings. + */ +static inline int +usb_ep_clear_halt (struct usb_ep *ep) +{ + return ep->ops->set_halt (ep, 0); +} + +/** + * usb_ep_fifo_status - returns number of bytes in fifo, or error + * @ep: the endpoint whose fifo status is being checked. + * + * FIFO endpoints may have "unclaimed data" in them in certain cases, + * such as after aborted transfers. Hosts may not have collected all + * the IN data written by the gadget driver (and reported by a request + * completion). The gadget driver may not have collected all the data + * written OUT to it by the host. Drivers that need precise handling for + * fault reporting or recovery may need to use this call. + * + * This returns the number of such bytes in the fifo, or a negative + * errno if the endpoint doesn't use a FIFO or doesn't support such + * precise handling. + */ +static inline int +usb_ep_fifo_status (struct usb_ep *ep) +{ + if (ep->ops->fifo_status) + return ep->ops->fifo_status (ep); + else + return -EOPNOTSUPP; +} + +/** + * usb_ep_fifo_flush - flushes contents of a fifo + * @ep: the endpoint whose fifo is being flushed. + * + * This call may be used to flush the "unclaimed data" that may exist in + * an endpoint fifo after abnormal transaction terminations. The call + * must never be used except when endpoint is not being used for any + * protocol translation. + */ +static inline void +usb_ep_fifo_flush (struct usb_ep *ep) +{ + if (ep->ops->fifo_flush) + ep->ops->fifo_flush (ep); +} + + +/*-------------------------------------------------------------------------*/ + +struct usb_gadget; + +/* the rest of the api to the controller hardware: device operations, + * which don't involve endpoints (or i/o). + */ +struct usb_gadget_ops { + int (*get_frame)(struct usb_gadget *); + int (*wakeup)(struct usb_gadget *); + int (*set_selfpowered) (struct usb_gadget *, int is_selfpowered); + int (*vbus_session) (struct usb_gadget *, int is_active); + int (*vbus_draw) (struct usb_gadget *, unsigned mA); + int (*pullup) (struct usb_gadget *, int is_on); + int (*ioctl)(struct usb_gadget *, + unsigned code, unsigned long param); +}; + +struct device { + void *driver_data; /* data private to the driver */ +}; + +/** + * struct usb_gadget - represents a usb slave device + * @ops: Function pointers used to access hardware-specific operations. + * @ep0: Endpoint zero, used when reading or writing responses to + * driver setup() requests + * @ep_list: List of other endpoints supported by the device. + * @speed: Speed of current connection to USB host. + * @is_dualspeed: True if the controller supports both high and full speed + * operation. If it does, the gadget driver must also support both. + * @is_otg: True if the USB device port uses a Mini-AB jack, so that the + * gadget driver must provide a USB OTG descriptor. + * @is_a_peripheral: False unless is_otg, the "A" end of a USB cable + * is in the Mini-AB jack, and HNP has been used to switch roles + * so that the "A" device currently acts as A-Peripheral, not A-Host. + * @a_hnp_support: OTG device feature flag, indicating that the A-Host + * supports HNP at this port. + * @a_alt_hnp_support: OTG device feature flag, indicating that the A-Host + * only supports HNP on a different root port. + * @b_hnp_enable: OTG device feature flag, indicating that the A-Host + * enabled HNP support. + * @name: Identifies the controller hardware type. Used in diagnostics + * and sometimes configuration. + * @dev: Driver model state for this abstract device. + * + * Gadgets have a mostly-portable "gadget driver" implementing device + * functions, handling all usb configurations and interfaces. Gadget + * drivers talk to hardware-specific code indirectly, through ops vectors. + * That insulates the gadget driver from hardware details, and packages + * the hardware endpoints through generic i/o queues. The "usb_gadget" + * and "usb_ep" interfaces provide that insulation from the hardware. + * + * Except for the driver data, all fields in this structure are + * read-only to the gadget driver. That driver data is part of the + * "driver model" infrastructure in 2.6 (and later) kernels, and for + * earlier systems is grouped in a similar structure that's not known + * to the rest of the kernel. + * + * Values of the three OTG device feature flags are updated before the + * setup() call corresponding to USB_REQ_SET_CONFIGURATION, and before + * driver suspend() calls. They are valid only when is_otg, and when the + * device is acting as a B-Peripheral (so is_a_peripheral is false). + */ +struct usb_gadget { + /* readonly to gadget driver */ + const struct usb_gadget_ops *ops; + struct usb_ep *ep0; + struct list_head ep_list; /* of usb_ep */ + enum usb_device_speed speed; + unsigned is_dualspeed:1; + unsigned is_otg:1; + unsigned is_a_peripheral:1; + unsigned b_hnp_enable:1; + unsigned a_hnp_support:1; + unsigned a_alt_hnp_support:1; + const char *name; + struct device dev; +}; + +static inline void set_gadget_data (struct usb_gadget *gadget, void *data) +{ + gadget->dev.driver_data = data; +} + +static inline void *get_gadget_data (struct usb_gadget *gadget) +{ + return gadget->dev.driver_data; +} + +/* iterates the non-control endpoints; 'tmp' is a struct usb_ep pointer */ +#define gadget_for_each_ep(tmp,gadget) \ + list_for_each_entry(tmp, &(gadget)->ep_list, ep_list) + + +/** + * gadget_is_dualspeed - return true iff the hardware handles high speed + * @g: controller that might support both high and full speeds + */ +static inline int gadget_is_dualspeed(struct usb_gadget *g) +{ +#ifdef CONFIG_USB_GADGET_DUALSPEED + /* runtime test would check "g->is_dualspeed" ... that might be + * useful to work around hardware bugs, but is mostly pointless + */ + return 1; +#else + return 0; +#endif +} + +/** + * gadget_is_otg - return true iff the hardware is OTG-ready + * @g: controller that might have a Mini-AB connector + * + * This is a runtime test, since kernels with a USB-OTG stack sometimes + * run on boards which only have a Mini-B (or Mini-A) connector. + */ +static inline int gadget_is_otg(struct usb_gadget *g) +{ +#ifdef CONFIG_USB_OTG + return g->is_otg; +#else + return 0; +#endif +} + + +/** + * usb_gadget_frame_number - returns the current frame number + * @gadget: controller that reports the frame number + * + * Returns the usb frame number, normally eleven bits from a SOF packet, + * or negative errno if this device doesn't support this capability. + */ +static inline int usb_gadget_frame_number (struct usb_gadget *gadget) +{ + return gadget->ops->get_frame (gadget); +} + +/** + * usb_gadget_wakeup - tries to wake up the host connected to this gadget + * @gadget: controller used to wake up the host + * + * Returns zero on success, else negative error code if the hardware + * doesn't support such attempts, or its support has not been enabled + * by the usb host. Drivers must return device descriptors that report + * their ability to support this, or hosts won't enable it. + * + * This may also try to use SRP to wake the host and start enumeration, + * even if OTG isn't otherwise in use. OTG devices may also start + * remote wakeup even when hosts don't explicitly enable it. + */ +static inline int usb_gadget_wakeup (struct usb_gadget *gadget) +{ + if (!gadget->ops->wakeup) + return -EOPNOTSUPP; + return gadget->ops->wakeup (gadget); +} + +/** + * usb_gadget_set_selfpowered - sets the device selfpowered feature. + * @gadget:the device being declared as self-powered + * + * this affects the device status reported by the hardware driver + * to reflect that it now has a local power supply. + * + * returns zero on success, else negative errno. + */ +static inline int +usb_gadget_set_selfpowered (struct usb_gadget *gadget) +{ + if (!gadget->ops->set_selfpowered) + return -EOPNOTSUPP; + return gadget->ops->set_selfpowered (gadget, 1); +} + +/** + * usb_gadget_clear_selfpowered - clear the device selfpowered feature. + * @gadget:the device being declared as bus-powered + * + * this affects the device status reported by the hardware driver. + * some hardware may not support bus-powered operation, in which + * case this feature's value can never change. + * + * returns zero on success, else negative errno. + */ +static inline int +usb_gadget_clear_selfpowered (struct usb_gadget *gadget) +{ + if (!gadget->ops->set_selfpowered) + return -EOPNOTSUPP; + return gadget->ops->set_selfpowered (gadget, 0); +} + +/** + * usb_gadget_vbus_connect - Notify controller that VBUS is powered + * @gadget:The device which now has VBUS power. + * + * This call is used by a driver for an external transceiver (or GPIO) + * that detects a VBUS power session starting. Common responses include + * resuming the controller, activating the D+ (or D-) pullup to let the + * host detect that a USB device is attached, and starting to draw power + * (8mA or possibly more, especially after SET_CONFIGURATION). + * + * Returns zero on success, else negative errno. + */ +static inline int +usb_gadget_vbus_connect(struct usb_gadget *gadget) +{ + if (!gadget->ops->vbus_session) + return -EOPNOTSUPP; + return gadget->ops->vbus_session (gadget, 1); +} + +/** + * usb_gadget_vbus_draw - constrain controller's VBUS power usage + * @gadget:The device whose VBUS usage is being described + * @mA:How much current to draw, in milliAmperes. This should be twice + * the value listed in the configuration descriptor bMaxPower field. + * + * This call is used by gadget drivers during SET_CONFIGURATION calls, + * reporting how much power the device may consume. For example, this + * could affect how quickly batteries are recharged. + * + * Returns zero on success, else negative errno. + */ +static inline int +usb_gadget_vbus_draw(struct usb_gadget *gadget, unsigned mA) +{ + if (!gadget->ops->vbus_draw) + return -EOPNOTSUPP; + return gadget->ops->vbus_draw (gadget, mA); +} + +/** + * usb_gadget_vbus_disconnect - notify controller about VBUS session end + * @gadget:the device whose VBUS supply is being described + * + * This call is used by a driver for an external transceiver (or GPIO) + * that detects a VBUS power session ending. Common responses include + * reversing everything done in usb_gadget_vbus_connect(). + * + * Returns zero on success, else negative errno. + */ +static inline int +usb_gadget_vbus_disconnect(struct usb_gadget *gadget) +{ + if (!gadget->ops->vbus_session) + return -EOPNOTSUPP; + return gadget->ops->vbus_session (gadget, 0); +} + +/** + * usb_gadget_connect - software-controlled connect to USB host + * @gadget:the peripheral being connected + * + * Enables the D+ (or potentially D-) pullup. The host will start + * enumerating this gadget when the pullup is active and a VBUS session + * is active (the link is powered). This pullup is always enabled unless + * usb_gadget_disconnect() has been used to disable it. + * + * Returns zero on success, else negative errno. + */ +static inline int +usb_gadget_connect (struct usb_gadget *gadget) +{ + if (!gadget->ops->pullup) + return -EOPNOTSUPP; + return gadget->ops->pullup (gadget, 1); +} + +/** + * usb_gadget_disconnect - software-controlled disconnect from USB host + * @gadget:the peripheral being disconnected + * + * Disables the D+ (or potentially D-) pullup, which the host may see + * as a disconnect (when a VBUS session is active). Not all systems + * support software pullup controls. + * + * This routine may be used during the gadget driver bind() call to prevent + * the peripheral from ever being visible to the USB host, unless later + * usb_gadget_connect() is called. For example, user mode components may + * need to be activated before the system can talk to hosts. + * + * Returns zero on success, else negative errno. + */ +static inline int +usb_gadget_disconnect (struct usb_gadget *gadget) +{ + if (!gadget->ops->pullup) + return -EOPNOTSUPP; + return gadget->ops->pullup (gadget, 0); +} + + + +/*-------------------------------------------------------------------------*/ + +/** + * struct usb_gadget_driver - driver for usb 'slave' devices + * @speed: Highest speed the driver handles. + * @bind: Invoked when the driver is bound to a gadget, usually + * after registering the driver. + * At that point, ep0 is fully initialized, and ep_list holds + * the currently-available endpoints. + * Called in a context that permits sleeping. + * @setup: Invoked for ep0 control requests that aren't handled by + * the hardware level driver. Most calls must be handled by + * the gadget driver, including descriptor and configuration + * management. The 16 bit members of the setup data are in + * USB byte order. Called in_interrupt; this may not sleep. Driver + * queues a response to ep0, or returns negative to stall. + * @disconnect: Invoked after all transfers have been stopped, + * when the host is disconnected. May be called in_interrupt; this + * may not sleep. Some devices can't detect disconnect, so this might + * not be called except as part of controller shutdown. + * @unbind: Invoked when the driver is unbound from a gadget, + * usually from rmmod (after a disconnect is reported). + * Called in a context that permits sleeping. + * @suspend: Invoked on USB suspend. May be called in_interrupt. + * @resume: Invoked on USB resume. May be called in_interrupt. + * + * Devices are disabled till a gadget driver successfully bind()s, which + * means the driver will handle setup() requests needed to enumerate (and + * meet "chapter 9" requirements) then do some useful work. + * + * If gadget->is_otg is true, the gadget driver must provide an OTG + * descriptor during enumeration, or else fail the bind() call. In such + * cases, no USB traffic may flow until both bind() returns without + * having called usb_gadget_disconnect(), and the USB host stack has + * initialized. + * + * Drivers use hardware-specific knowledge to configure the usb hardware. + * endpoint addressing is only one of several hardware characteristics that + * are in descriptors the ep0 implementation returns from setup() calls. + * + * Except for ep0 implementation, most driver code shouldn't need change to + * run on top of different usb controllers. It'll use endpoints set up by + * that ep0 implementation. + * + * The usb controller driver handles a few standard usb requests. Those + * include set_address, and feature flags for devices, interfaces, and + * endpoints (the get_status, set_feature, and clear_feature requests). + * + * Accordingly, the driver's setup() callback must always implement all + * get_descriptor requests, returning at least a device descriptor and + * a configuration descriptor. Drivers must make sure the endpoint + * descriptors match any hardware constraints. Some hardware also constrains + * other descriptors. (The pxa250 allows only configurations 1, 2, or 3). + * + * The driver's setup() callback must also implement set_configuration, + * and should also implement set_interface, get_configuration, and + * get_interface. Setting a configuration (or interface) is where + * endpoints should be activated or (config 0) shut down. + * + * (Note that only the default control endpoint is supported. Neither + * hosts nor devices generally support control traffic except to ep0.) + * + * Most devices will ignore USB suspend/resume operations, and so will + * not provide those callbacks. However, some may need to change modes + * when the host is not longer directing those activities. For example, + * local controls (buttons, dials, etc) may need to be re-enabled since + * the (remote) host can't do that any longer; or an error state might + * be cleared, to make the device behave identically whether or not + * power is maintained. + */ +struct usb_gadget_driver { + enum usb_device_speed speed; + int (*bind)(struct usb_gadget *); + void (*unbind)(struct usb_gadget *); + int (*setup)(struct usb_gadget *, + const struct usb_ctrlrequest *); + void (*disconnect)(struct usb_gadget *); + void (*suspend)(struct usb_gadget *); + void (*resume)(struct usb_gadget *); +}; + + + +/*-------------------------------------------------------------------------*/ + +/* driver modules register and unregister, as usual. + * these calls must be made in a context that can sleep. + * + * these will usually be implemented directly by the hardware-dependent + * usb bus interface driver, which will only support a single driver. + */ + +/** + * usb_gadget_register_driver - register a gadget driver + * @driver:the driver being registered + * + * Call this in your gadget driver's module initialization function, + * to tell the underlying usb controller driver about your driver. + * The driver's bind() function will be called to bind it to a + * gadget before this registration call returns. It's expected that + * the bind() functions will be in init sections. + * This function must be called in a context that can sleep. + */ +int usb_gadget_register_driver (struct usb_gadget_driver *driver); + +/** + * usb_gadget_unregister_driver - unregister a gadget driver + * @driver:the driver being unregistered + * + * Call this in your gadget driver's module cleanup function, + * to tell the underlying usb controller that your driver is + * going away. If the controller is connected to a USB host, + * it will first disconnect(). The driver is also requested + * to unbind() and clean up any device state, before this procedure + * finally returns. It's expected that the unbind() functions + * will in in exit sections, so may not be linked in some kernels. + * This function must be called in a context that can sleep. + */ +int usb_gadget_unregister_driver (struct usb_gadget_driver *driver); + +/*-------------------------------------------------------------------------*/ + +/* utility to simplify dealing with string descriptors */ + +/** + * struct usb_string - wraps a C string and its USB id + * @id:the (nonzero) ID for this string + * @s:the string, in UTF-8 encoding + * + * If you're using usb_gadget_get_string(), use this to wrap a string + * together with its ID. + */ +struct usb_string { + u8 id; + const char *s; +}; + +/** + * struct usb_gadget_strings - a set of USB strings in a given language + * @language:identifies the strings' language (0x0409 for en-us) + * @strings:array of strings with their ids + * + * If you're using usb_gadget_get_string(), use this to wrap all the + * strings for a given language. + */ +struct usb_gadget_strings { + u16 language; /* 0x0409 for en-us */ + struct usb_string *strings; +}; + +/* put descriptor for string with that id into buf (buflen >= 256) */ +int usb_gadget_get_string (struct usb_gadget_strings *table, int id, u8 *buf); + +/*-------------------------------------------------------------------------*/ + +/* utility to simplify managing config descriptors */ + +/* write vector of descriptors into buffer */ +int usb_descriptor_fillbuf(void *, unsigned, + const struct usb_descriptor_header **); + +/* build config descriptor from single descriptor vector */ +int usb_gadget_config_buf(const struct usb_config_descriptor *config, + void *buf, unsigned buflen, const struct usb_descriptor_header **desc); + +/*-------------------------------------------------------------------------*/ + +/* utility wrapping a simple endpoint selection policy */ + +extern struct usb_ep *usb_ep_autoconfig (struct usb_gadget *, + struct usb_endpoint_descriptor *); + +extern void usb_ep_autoconfig_reset (struct usb_gadget *); + +extern int usb_gadget_handle_interrupts(void); + +#endif /* __LINUX_USB_GADGET_H */ diff --git a/include/net.h b/include/net.h index ab571eb..a29dafc 100644 --- a/include/net.h +++ b/include/net.h @@ -125,8 +125,10 @@ extern int eth_getenv_enetaddr(char *name, uchar *enetaddr); extern int eth_setenv_enetaddr(char *name, const uchar *enetaddr); extern int eth_getenv_enetaddr_by_index(int index, uchar *enetaddr);
+extern int usb_eth_initialize(bd_t *bi); extern int eth_init(bd_t *bis); /* Initialize the device */ extern int eth_send(volatile void *packet, int length); /* Send a packet */ + #ifdef CONFIG_API extern int eth_receive(volatile void *packet, int length); /* Receive a packet*/ #endif @@ -481,7 +483,18 @@ static inline int is_multicast_ether_addr(const u8 *addr) return (0x01 & addr[0]); }
-/** +/* + * is_broadcast_ether_addr - Determine if the Ethernet address is broadcast + * @addr: Pointer to a six-byte array containing the Ethernet address + * + * Return true if the address is the broadcast address. + */ +static inline int is_broadcast_ether_addr(const u8 *addr) +{ + return (addr[0] & addr[1] & addr[2] & addr[3] & addr[4] & addr[5]) == 0xff; +} + +/* * is_valid_ether_addr - Determine if the given Ethernet address is valid * @addr: Pointer to a six-byte array containing the Ethernet address * @@ -490,7 +503,7 @@ static inline int is_multicast_ether_addr(const u8 *addr) * * Return true if the address is valid. */ -static inline int is_valid_ether_addr(const u8 * addr) +static inline int is_valid_ether_addr(const u8 *addr) { /* FF:FF:FF:FF:FF:FF is a multicast address so we don't need to * explicitly check for it here. */
This patch implements the low-level part of the USB CDC layer for AT91 Other boards can use this patch as an example to connect their own.
It does not enable the use of CDC ethernet for any of the AT91 boards. Separate patches are required for that. It works in combination with CONFIG_NET_MULTI.
Signed-off-by: Thomas Smits ts.smits@gmail.com Signed-off-by: Remy Bohmer linux@bohmer.net --- arch/arm/include/asm/arch-at91/at91_dbgu.h | 69 ++ arch/arm/include/asm/arch-at91/cpu.h | 99 ++ drivers/usb/gadget/Makefile | 1 + drivers/usb/gadget/at91_udc.c | 1553 ++++++++++++++++++++++++++++ include/usb/at91_udc.h | 209 ++++ 5 files changed, 1931 insertions(+), 0 deletions(-) create mode 100644 arch/arm/include/asm/arch-at91/at91_dbgu.h create mode 100644 arch/arm/include/asm/arch-at91/cpu.h create mode 100644 drivers/usb/gadget/at91_udc.c create mode 100644 include/usb/at91_udc.h
diff --git a/arch/arm/include/asm/arch-at91/at91_dbgu.h b/arch/arm/include/asm/arch-at91/at91_dbgu.h new file mode 100644 index 0000000..55210da --- /dev/null +++ b/arch/arm/include/asm/arch-at91/at91_dbgu.h @@ -0,0 +1,69 @@ +/* + * include/asm-arm/arch-at91/at91_dbgu.h + * + * Copyright (C) 2005 Ivan Kokshaysky + * Copyright (C) SAN People + * + * Debug Unit (DBGU) - System peripherals registers. + * Based on AT91RM9200 datasheet revision E. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + */ + +#ifndef AT91_DBGU_H +#define AT91_DBGU_H + +#ifdef AT91_DBGU +#define AT91_DBGU_CR (AT91_DBGU + 0x00) /* Control Register */ +#define AT91_DBGU_MR (AT91_DBGU + 0x04) /* Mode Register */ +#define AT91_DBGU_IER (AT91_DBGU + 0x08) /* Interrupt Enable */ +#define AT91_DBGU_TXRDY (1 << 1) /* Transmitter Ready */ +#define AT91_DBGU_TXEMPTY (1 << 9) /* Transmitter Empty */ +#define AT91_DBGU_IDR (AT91_DBGU + 0x0c) /* Interrupt Disable */ +#define AT91_DBGU_IMR (AT91_DBGU + 0x10) /* Interrupt Mask */ +#define AT91_DBGU_SR (AT91_DBGU + 0x14) /* Status Register */ +#define AT91_DBGU_RHR (AT91_DBGU + 0x18) /* Receiver Holding */ +#define AT91_DBGU_THR (AT91_DBGU + 0x1c) /* Transmitter Holding */ +#define AT91_DBGU_BRGR (AT91_DBGU + 0x20) /* Baud Rate Generator */ + +#define AT91_DBGU_CIDR (AT91_DBGU + 0x40) /* Chip ID Register */ +#define AT91_DBGU_EXID (AT91_DBGU + 0x44) /* Chip ID Extension */ +#define AT91_DBGU_FNR (AT91_DBGU + 0x48) /* Force NTRST [SAM9 only] */ +#define AT91_DBGU_FNTRST (1 << 0) /* Force NTRST */ + +#endif /* AT91_DBGU */ + +/* + * Some AT91 parts that don't have full DEBUG units still support the ID + * and extensions register. + */ +#define AT91_CIDR_VERSION (0x1f << 0) /* Version of the Device */ +#define AT91_CIDR_EPROC (7 << 5) /* Embedded Processor */ +#define AT91_CIDR_NVPSIZ (0xf << 8) /* Nonvolatile Program + Memory Size */ +#define AT91_CIDR_NVPSIZ2 (0xf << 12) /* Second Nonvolatile + Program Memory Size */ +#define AT91_CIDR_SRAMSIZ (0xf << 16) /* Internal SRAM Size */ +#define AT91_CIDR_SRAMSIZ_1K (1 << 16) +#define AT91_CIDR_SRAMSIZ_2K (2 << 16) +#define AT91_CIDR_SRAMSIZ_112K (4 << 16) +#define AT91_CIDR_SRAMSIZ_4K (5 << 16) +#define AT91_CIDR_SRAMSIZ_80K (6 << 16) +#define AT91_CIDR_SRAMSIZ_160K (7 << 16) +#define AT91_CIDR_SRAMSIZ_8K (8 << 16) +#define AT91_CIDR_SRAMSIZ_16K (9 << 16) +#define AT91_CIDR_SRAMSIZ_32K (10 << 16) +#define AT91_CIDR_SRAMSIZ_64K (11 << 16) +#define AT91_CIDR_SRAMSIZ_128K (12 << 16) +#define AT91_CIDR_SRAMSIZ_256K (13 << 16) +#define AT91_CIDR_SRAMSIZ_96K (14 << 16) +#define AT91_CIDR_SRAMSIZ_512K (15 << 16) +#define AT91_CIDR_ARCH (0xff << 20) /* Architecture Id */ +#define AT91_CIDR_NVPTYP (7 << 28) /* Nonvolatile Program + Memory Type */ +#define AT91_CIDR_EXT (1 << 31) /* Extension Flag */ + +#endif diff --git a/arch/arm/include/asm/arch-at91/cpu.h b/arch/arm/include/asm/arch-at91/cpu.h new file mode 100644 index 0000000..b5e5715 --- /dev/null +++ b/arch/arm/include/asm/arch-at91/cpu.h @@ -0,0 +1,99 @@ +/* + * include/asm-arm/arch-at91/cpu.h + * + * Copyright (C) 2006 SAN People + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + */ + +#ifndef __ASM_ARCH_CPU_H +#define __ASM_ARCH_CPU_H + +#include <asm/hardware.h> +#include <asm/arch/at91_dbgu.h> +#include <asm/arch/io.h> + + +#define ARCH_ID_AT91RM9200 0x09290780 +#define ARCH_ID_AT91SAM9260 0x019803a0 +#define ARCH_ID_AT91SAM9261 0x019703a0 +#define ARCH_ID_AT91SAM9263 0x019607a0 +#define ARCH_ID_AT91SAM9RL64 0x019b03a0 +#define ARCH_ID_AT91CAP9 0x039A03A0 + +#define ARCH_ID_AT91SAM9XE128 0x329973a0 +#define ARCH_ID_AT91SAM9XE256 0x329a93a0 +#define ARCH_ID_AT91SAM9XE512 0x329aa3a0 + +#define ARCH_ID_AT91M40800 0x14080044 +#define ARCH_ID_AT91R40807 0x44080746 +#define ARCH_ID_AT91M40807 0x14080745 +#define ARCH_ID_AT91R40008 0x44000840 + +static inline unsigned long at91_cpu_identify(void) +{ + return (at91_sys_read(AT91_DBGU_CIDR) & ~AT91_CIDR_VERSION); +} + + +#define ARCH_FAMILY_AT91X92 0x09200000 +#define ARCH_FAMILY_AT91SAM9 0x01900000 +#define ARCH_FAMILY_AT91SAM9XE 0x02900000 + +static inline unsigned long at91_arch_identify(void) +{ + return (at91_sys_read(AT91_DBGU_CIDR) & AT91_CIDR_ARCH); +} + + +#ifdef CONFIG_AT91RM9200 +/* no actual detection for this architecture */ +#define cpu_is_at91rm9200() (1) +#else +#define cpu_is_at91rm9200() (0) +#endif + +#ifdef CONFIG_AT91SAM9261 +#define cpu_is_at91sam9xe() (at91_arch_identify() == ARCH_FAMILY_AT91SAM9XE) +#define cpu_is_at91sam9260() ((at91_cpu_identify() == ARCH_ID_AT91SAM9260) \ + || cpu_is_at91sam9xe()) +#else +#define cpu_is_at91sam9xe() (0) +#define cpu_is_at91sam9260() (0) +#endif + +#ifdef CONFIG_AT91SAM9261 +#define cpu_is_at91sam9261() (at91_cpu_identify() == ARCH_ID_AT91SAM9261) +#else +#define cpu_is_at91sam9261() (0) +#endif + +#ifdef CONFIG_AT91SAM9261 +#define cpu_is_at91sam9263() (at91_cpu_identify() == ARCH_ID_AT91SAM9263) +#else +#define cpu_is_at91sam9263() (0) +#endif + +#ifdef CONFIG_AT91SAM9RL +#define cpu_is_at91sam9rl() (at91_cpu_identify() == ARCH_ID_AT91SAM9RL64) +#else +#define cpu_is_at91sam9rl() (0) +#endif + +#ifdef CONFIG_AT91CAP9 +#define cpu_is_at91cap9() (at91_cpu_identify() == ARCH_ID_AT91CAP9) +#else +#define cpu_is_at91cap9() (0) +#endif + +/* + * Since this is ARM, we will never run on any AVR32 CPU. But these + * definitions may reduce clutter in common drivers. + */ +#define cpu_is_at32ap7000() (0) + +#endif diff --git a/drivers/usb/gadget/Makefile b/drivers/usb/gadget/Makefile index 9b1b55b..27e7f40 100644 --- a/drivers/usb/gadget/Makefile +++ b/drivers/usb/gadget/Makefile @@ -37,6 +37,7 @@ COBJS-$(CONFIG_SPEARUDC) += spr_udc.o endif # new USB gadget layer dependencies COBJS-$(CONFIG_USB_ETHER) += ether.o epautoconf.o config.o usbstring.o +COBJS-$(CONFIG_USB_GADGET_AT91) += at91_udc.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/usb/gadget/at91_udc.c b/drivers/usb/gadget/at91_udc.c new file mode 100644 index 0000000..ef9bbc0 --- /dev/null +++ b/drivers/usb/gadget/at91_udc.c @@ -0,0 +1,1553 @@ +/* + * at91_udc -- driver for at91-series USB peripheral controller + * + * Copyright (C) 2004 by Thomas Rathbone + * Copyright (C) 2005 by HP Labs + * Copyright (C) 2005 by David Brownell + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the + * Free Software Foundation, Inc., 59 Temple Place - Suite 330, + * Boston, MA 02111-1307, USA. + */ + +//#define DEBUG 1 +//#define VERBOSE 1 +//#define PACKET_TRACE 1 + +#include <common.h> +#include <asm/errno.h> +#include <linux/list.h> + +#include <asm/arch/cpu.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91sam9261_matrix.h> + +#include <linux/usb/ch9.h> +#include <linux/usb/gadget.h> + +#include <asm/byteorder.h> +#include <asm/hardware.h> +#include <asm/io.h> +#include <asm/proc-armv/system.h> +#include <asm/mach-types.h> + +#include <asm/arch/gpio.h> + +#define __iomem + +#include <usb/at91_udc.h> + + +/* + * This controller is simple and PIO-only. It's used in many AT91-series + * full speed USB controllers, including the at91rm9200 (arm920T, with MMU), + * at91sam926x (arm926ejs, with MMU), and several no-mmu versions. + * + * This driver expects the board has been wired with two GPIOs suppporting + * a VBUS sensing IRQ, and a D+ pullup. (They may be omitted, but the + * testing hasn't covered such cases.) + * + * The pullup is most important (so it's integrated on sam926x parts). It + * provides software control over whether the host enumerates the device. + * + * The VBUS sensing helps during enumeration, and allows both USB clocks + * (and the transceiver) to stay gated off until they're necessary, saving + * power. During USB suspend, the 48 MHz clock is gated off in hardware; + * it may also be gated off by software during some Linux sleep states. + */ + +#define DRIVER_VERSION "3 May 2006" + +static const char driver_name[] = "at91_udc"; +static const char ep0name[] = "ep0"; + + +#define at91_udp_read(dev, reg) \ + __raw_readl((dev)->udp_baseaddr + (reg)) +#define at91_udp_write(dev, reg, val) \ + __raw_writel((val), (dev)->udp_baseaddr + (reg)) + +/*============================================================================*/ +#define REQ_COUNT 8 +#define MAX_REQ (REQ_COUNT-1) +static struct at91_request req_pool[REQ_COUNT]; + +static void init_requests(void) +{ + int i; + + for (i = 0; i < MAX_REQ; i++) { + req_pool[i].in_use=0; + } +} + +static void free_request(struct at91_request* ptr) +{ + if (ptr < &req_pool[0] && ptr > &req_pool[REQ_COUNT]){ + printf("%s: ptr 0x%p does not specify valid req\n", \ + __func__, ptr); + if (!(ptr->in_use)) + printf("%s: ptr not marked as "in_use"\n", __func__); + + hang(); + } + ptr->in_use=0; +} + +static struct at91_request* alloc_request(void) +{ + int i; + struct at91_request* ptr=NULL; + + for (i = 0; i < MAX_REQ; i++) { + if (!req_pool[i].in_use) { + ptr=&req_pool[i]; + req_pool[i].in_use=1; + DBG("alloc_req: request[%d]\n",i); + break; + } + } + if (!ptr) + DBG("panic: no more free req buffers\n"); + return ptr; +} + +/*-------------------------------------------------------------------------*/ + +static void done(struct at91_ep *ep, struct at91_request *req, int status) +{ + unsigned stopped = ep->stopped; + struct at91_udc *udc = ep->udc; + + list_del_init(&req->queue); + if (req->req.status == -EINPROGRESS) + req->req.status = status; + else + status = req->req.status; + if (status && status != -ESHUTDOWN) + VDBG("%s done %p, status %d\n", ep->ep.name, req, status); + + ep->stopped = 1; + req->req.complete(&ep->ep, &req->req); + ep->stopped = stopped; + + /* ep0 is always ready; other endpoints need a non-empty queue */ + if (list_empty(&ep->queue) && ep->int_mask != (1 << 0)) + at91_udp_write(udc, AT91_UDP_IDR, ep->int_mask); +} + +/*-------------------------------------------------------------------------*/ + +/* bits indicating OUT fifo has data ready */ +#define RX_DATA_READY (AT91_UDP_RX_DATA_BK0 | AT91_UDP_RX_DATA_BK1) + +/* + * Endpoint FIFO CSR bits have a mix of bits, making it unsafe to just write + * back most of the value you just read (because of side effects, including + * bits that may change after reading and before writing). + * + * Except when changing a specific bit, always write values which: + * - clear SET_FX bits (setting them could change something) + * - set CLR_FX bits (clearing them could change something) + * + * There are also state bits like FORCESTALL, EPEDS, DIR, and EPTYPE + * that shouldn't normally be changed. + * + * NOTE at91sam9260 docs mention synch between UDPCK and MCK clock domains, + * implying a need to wait for one write to complete (test relevant bits) + * before starting the next write. This shouldn't be an issue given how + * infrequently we write, except maybe for write-then-read idioms. + */ +#define SET_FX (AT91_UDP_TXPKTRDY) +#define CLR_FX (RX_DATA_READY | AT91_UDP_RXSETUP \ + | AT91_UDP_STALLSENT | AT91_UDP_TXCOMP) + +/* pull OUT packet data from the endpoint's fifo */ +static int read_fifo (struct at91_ep *ep, struct at91_request *req) +{ + u32 __iomem *creg = ep->creg; + u8 __iomem *dreg = ep->creg + (AT91_UDP_FDR(0) - AT91_UDP_CSR(0)); + u32 csr; + u8 *buf; + unsigned int count, bufferspace, is_done; + + buf = req->req.buf + req->req.actual; + bufferspace = req->req.length - req->req.actual; + + /* + * there might be nothing to read if ep_queue() calls us, + * or if we already emptied both pingpong buffers + */ +rescan: + csr = __raw_readl(creg); + if ((csr & RX_DATA_READY) == 0) + return 0; + + count = (csr & AT91_UDP_RXBYTECNT) >> 16; + if (count > ep->ep.maxpacket) + count = ep->ep.maxpacket; + if (count > bufferspace) { + DBG("%s buffer overflow\n", ep->ep.name); + req->req.status = -EOVERFLOW; + count = bufferspace; + } + __raw_readsb((unsigned long)dreg, buf, count); + + /* release and swap pingpong mem bank */ + csr |= CLR_FX; + if (ep->is_pingpong) { + if (ep->fifo_bank == 0) { + csr &= ~(SET_FX | AT91_UDP_RX_DATA_BK0); + ep->fifo_bank = 1; + } else { + csr &= ~(SET_FX | AT91_UDP_RX_DATA_BK1); + ep->fifo_bank = 0; + } + } else + csr &= ~(SET_FX | AT91_UDP_RX_DATA_BK0); + __raw_writel(csr, creg); + + req->req.actual += count; + is_done = (count < ep->ep.maxpacket); + if (count == bufferspace) + is_done = 1; + + PACKET("%s %p out/%d%s\n", ep->ep.name, &req->req, count, + is_done ? " (done)" : ""); + + /* + * avoid extra trips through IRQ logic for packets already in + * the fifo ... maybe preventing an extra (expensive) OUT-NAK + */ + if (is_done) + done(ep, req, 0); + else if (ep->is_pingpong) { + bufferspace -= count; + buf += count; + goto rescan; + } + + return is_done; +} + +/* load fifo for an IN packet */ +static int write_fifo(struct at91_ep *ep, struct at91_request *req) +{ + u32 __iomem *creg = ep->creg; + u32 csr = __raw_readl(creg); + u8 __iomem *dreg = ep->creg + (AT91_UDP_FDR(0) - AT91_UDP_CSR(0)); + unsigned total, count, is_last; + + /* + * TODO: allow for writing two packets to the fifo ... that'll + * reduce the amount of IN-NAKing, but probably won't affect + * throughput much. (Unlike preventing OUT-NAKing!) + */ + + /* + * If ep_queue() calls us, the queue is empty and possibly in + * odd states like TXCOMP not yet cleared (we do it, saving at + * least one IRQ) or the fifo not yet being free. Those aren't + * issues normally (IRQ handler fast path). + */ + if (csr & (AT91_UDP_TXCOMP | AT91_UDP_TXPKTRDY)) { + if (csr & AT91_UDP_TXCOMP) { + csr |= CLR_FX; + csr &= ~(SET_FX | AT91_UDP_TXCOMP); + __raw_writel(csr, creg); + csr = __raw_readl(creg); + } + if (csr & AT91_UDP_TXPKTRDY) + return 0; + } + + total = req->req.length - req->req.actual; + if (ep->ep.maxpacket < total) { + count = ep->ep.maxpacket; + is_last = 0; + } else { + count = total; + is_last = (count < ep->ep.maxpacket) || !req->req.zero; + } + + /* + * Write the packet, maybe it's a ZLP. + * + * NOTE: incrementing req->actual before we receive the ACK means + * gadget driver IN bytecounts can be wrong in fault cases. That's + * fixable with PIO drivers like this one (save "count" here, and + * do the increment later on TX irq), but not for most DMA hardware. + * + * So all gadget drivers must accept that potential error. Some + * hardware supports precise fifo status reporting, letting them + * recover when the actual bytecount matters (e.g. for USB Test + * and Measurement Class devices). + */ + + __raw_writesb((unsigned long)dreg, + req->req.buf + req->req.actual, count); + csr &= ~SET_FX; + csr |= CLR_FX | AT91_UDP_TXPKTRDY; + __raw_writel(csr, creg); + req->req.actual += count; + + PACKET("%s %p in/%d%s\n", ep->ep.name, &req->req, count, + is_last ? " (done)" : ""); + if (is_last) + done(ep, req, 0); + return is_last; +} + +static void nuke(struct at91_ep *ep, int status) +{ + struct at91_request *req; + + // terminer chaque requete dans la queue + ep->stopped = 1; + if (list_empty(&ep->queue)) + return; + + VDBG("%s %s\n", __func__, ep->ep.name); + while (!list_empty(&ep->queue)) { + req = list_entry(ep->queue.next, struct at91_request, queue); + done(ep, req, status); + } +} + +/*-------------------------------------------------------------------------*/ + +static int at91_ep_enable(struct usb_ep *_ep, + const struct usb_endpoint_descriptor *desc) +{ + struct at91_ep *ep = container_of(_ep, struct at91_ep, ep); + struct at91_udc *dev = ep->udc; + u16 maxpacket; + u32 tmp; + unsigned long flags; + + if (!_ep || !ep + || !desc || ep->desc + || _ep->name == ep0name + || desc->bDescriptorType != USB_DT_ENDPOINT + || (maxpacket = le16_to_cpu(desc->wMaxPacketSize)) == 0 + || maxpacket > ep->maxpacket) { + DBG("bad ep or descriptor\n"); + return -EINVAL; + } + + if (!dev->driver || dev->gadget.speed == USB_SPEED_UNKNOWN) { + DBG("bogus device state\n"); + return -ESHUTDOWN; + } + + tmp = desc->bmAttributes & USB_ENDPOINT_XFERTYPE_MASK; + switch (tmp) { + case USB_ENDPOINT_XFER_CONTROL: + DBG("only one control endpoint\n"); + return -EINVAL; + case USB_ENDPOINT_XFER_INT: + if (maxpacket > 64) + goto bogus_max; + break; + case USB_ENDPOINT_XFER_BULK: + switch (maxpacket) { + case 8: + case 16: + case 32: + case 64: + goto ok; + } +bogus_max: + DBG("bogus maxpacket %d\n", maxpacket); + return -EINVAL; + case USB_ENDPOINT_XFER_ISOC: + if (!ep->is_pingpong) { + DBG("iso requires double buffering\n"); + return -EINVAL; + } + break; + } + +ok: + local_irq_save(flags); + + /* initialize endpoint to match this descriptor */ + ep->is_in = (desc->bEndpointAddress & USB_DIR_IN) != 0; + ep->is_iso = (tmp == USB_ENDPOINT_XFER_ISOC); + ep->stopped = 0; + if (ep->is_in) + tmp |= 0x04; + tmp <<= 8; + tmp |= AT91_UDP_EPEDS; + __raw_writel(tmp, ep->creg); + + ep->desc = desc; + ep->ep.maxpacket = maxpacket; + + /* + * reset/init endpoint fifo. NOTE: leaves fifo_bank alone, + * since endpoint resets don't reset hw pingpong state. + */ + at91_udp_write(dev, AT91_UDP_RST_EP, ep->int_mask); + at91_udp_write(dev, AT91_UDP_RST_EP, 0); + + local_irq_restore(flags); + return 0; +} + +static int at91_ep_disable (struct usb_ep * _ep) +{ + struct at91_ep *ep = container_of(_ep, struct at91_ep, ep); + struct at91_udc *udc = ep->udc; + unsigned long flags; + + if (ep == &ep->udc->ep[0]) + return -EINVAL; + + local_irq_save(flags); + + nuke(ep, -ESHUTDOWN); + + /* restore the endpoint's pristine config */ + ep->desc = NULL; + ep->ep.maxpacket = ep->maxpacket; + + /* reset fifos and endpoint */ + if (ep->udc->clocked) { + at91_udp_write(udc, AT91_UDP_RST_EP, ep->int_mask); + at91_udp_write(udc, AT91_UDP_RST_EP, 0); + __raw_writel(0, ep->creg); + } + + local_irq_restore(flags); + return 0; +} + +/* + * this is a PIO-only driver, so there's nothing + * interesting for request or buffer allocation. + */ + +static struct usb_request * +at91_ep_alloc_request(struct usb_ep *_ep, unsigned int gfp_flags) +{ + struct at91_request *req; + + req = alloc_request(); + + if (!req) + return NULL; + + INIT_LIST_HEAD(&req->queue); + return &req->req; +} + +static void at91_ep_free_request(struct usb_ep *_ep, struct usb_request *_req) +{ + struct at91_request *req; + + req = container_of(_req, struct at91_request, req); +/* TODO: + * BUG_ON(!list_empty(&req->queue)); + * kfree(req); */ + free_request(req); +} + +static int at91_ep_queue(struct usb_ep *_ep, + struct usb_request *_req, gfp_t gfp_flags) +{ + struct at91_request *req; + struct at91_ep *ep; + struct at91_udc *dev; + int status; + unsigned long flags; + + req = container_of(_req, struct at91_request, req); + ep = container_of(_ep, struct at91_ep, ep); + + if (!_req || !_req->complete + || !_req->buf || !list_empty(&req->queue)) { + DBG("invalid request\n"); + return -EINVAL; + } + + if (!_ep || (!ep->desc && ep->ep.name != ep0name)) { + DBG("invalid ep\n"); + return -EINVAL; + } + + dev = ep->udc; + + if (!dev || !dev->driver || dev->gadget.speed == USB_SPEED_UNKNOWN) { + DBG("invalid device\n"); + return -EINVAL; + } + + _req->status = -EINPROGRESS; + _req->actual = 0; + + local_irq_save(flags); + + /* try to kickstart any empty and idle queue */ + if (list_empty(&ep->queue) && !ep->stopped) { + int is_ep0; + + /* + * If this control request has a non-empty DATA stage, this + * will start that stage. It works just like a non-control + * request (until the status stage starts, maybe early). + * + * If the data stage is empty, then this starts a successful + * IN/STATUS stage. (Unsuccessful ones use set_halt.) + */ + is_ep0 = (ep->ep.name == ep0name); + if (is_ep0) { + u32 tmp; + + if (!dev->req_pending) { + status = -EINVAL; + goto done; + } + + /* + * defer changing CONFG until after the gadget driver + * reconfigures the endpoints. + */ + if (dev->wait_for_config_ack) { + tmp = at91_udp_read(dev, AT91_UDP_GLB_STAT); + tmp ^= AT91_UDP_CONFG; + VDBG("toggle config\n"); + at91_udp_write(dev, AT91_UDP_GLB_STAT, tmp); + } + if (req->req.length == 0) { +ep0_in_status: + PACKET("ep0 in/status\n"); + status = 0; + tmp = __raw_readl(ep->creg); + tmp &= ~SET_FX; + tmp |= CLR_FX | AT91_UDP_TXPKTRDY; + __raw_writel(tmp, ep->creg); + dev->req_pending = 0; + goto done; + } + } + + if (ep->is_in) + status = write_fifo(ep, req); + else { + status = read_fifo(ep, req); + + /* IN/STATUS stage is otherwise triggered by irq */ + if (status && is_ep0) + goto ep0_in_status; + } + } else + status = 0; + + if (req && !status) { + list_add_tail (&req->queue, &ep->queue); + } +done: + local_irq_restore(flags); + return (status < 0) ? status : 0; +} + +static int at91_ep_dequeue(struct usb_ep *_ep, struct usb_request *_req) +{ + struct at91_ep *ep; + struct at91_request *req; + + ep = container_of(_ep, struct at91_ep, ep); + if (!_ep || ep->ep.name == ep0name) + return -EINVAL; + + /* make sure it's actually queued on this endpoint */ + list_for_each_entry (req, &ep->queue, queue) { + if (&req->req == _req) + break; + } + if (&req->req != _req) + return -EINVAL; + + done(ep, req, -ECONNRESET); + return 0; +} + +static int at91_ep_set_halt(struct usb_ep *_ep, int value) +{ + struct at91_ep *ep = container_of(_ep, struct at91_ep, ep); + struct at91_udc *udc = ep->udc; + u32 __iomem *creg; + u32 csr; + unsigned long flags; + int status = 0; + + if (!_ep || ep->is_iso || !ep->udc->clocked) + return -EINVAL; + + creg = ep->creg; + local_irq_save(flags); + + csr = __raw_readl(creg); + + /* + * fail with still-busy IN endpoints, ensuring correct sequencing + * of data tx then stall. note that the fifo rx bytecount isn't + * completely accurate as a tx bytecount. + */ + if (ep->is_in && (!list_empty(&ep->queue) || (csr >> 16) != 0)) + status = -EAGAIN; + else { + csr |= CLR_FX; + csr &= ~SET_FX; + if (value) { + csr |= AT91_UDP_FORCESTALL; + VDBG("halt %s\n", ep->ep.name); + } else { + at91_udp_write(udc, AT91_UDP_RST_EP, ep->int_mask); + at91_udp_write(udc, AT91_UDP_RST_EP, 0); + csr &= ~AT91_UDP_FORCESTALL; + } + __raw_writel(csr, creg); + } + + local_irq_restore(flags); + return status; +} + +static const struct usb_ep_ops at91_ep_ops = { + .enable = at91_ep_enable, + .disable = at91_ep_disable, + .alloc_request = at91_ep_alloc_request, + .free_request = at91_ep_free_request, + .queue = at91_ep_queue, + .dequeue = at91_ep_dequeue, + .set_halt = at91_ep_set_halt, + // there's only imprecise fifo status reporting +}; + +/*-------------------------------------------------------------------------*/ + +static int at91_get_frame(struct usb_gadget *gadget) +{ + struct at91_udc *udc = to_udc(gadget); + + if (!to_udc(gadget)->clocked) + return -EINVAL; + return at91_udp_read(udc, AT91_UDP_FRM_NUM) & AT91_UDP_NUM; +} + +static int at91_wakeup(struct usb_gadget *gadget) +{ + struct at91_udc *udc = to_udc(gadget); + u32 glbstate; + int status = -EINVAL; + unsigned long flags; + + DBG("%s\n", __func__ ); + local_irq_save(flags); + + if (!udc->clocked || !udc->suspended) + goto done; + + /* NOTE: some "early versions" handle ESR differently ... */ + + glbstate = at91_udp_read(udc, AT91_UDP_GLB_STAT); + if (!(glbstate & AT91_UDP_ESR)) + goto done; + glbstate |= AT91_UDP_ESR; + at91_udp_write(udc, AT91_UDP_GLB_STAT, glbstate); + +done: + local_irq_restore(flags); + return status; +} + +/* reinit == restore inital software state */ +static void udc_reinit(struct at91_udc *udc) +{ + u32 i; + + INIT_LIST_HEAD(&udc->gadget.ep_list); + INIT_LIST_HEAD(&udc->gadget.ep0->ep_list); + + for (i = 0; i < NUM_ENDPOINTS; i++) { + struct at91_ep *ep = &udc->ep[i]; + + if (i != 0) + list_add_tail(&ep->ep.ep_list, &udc->gadget.ep_list); + ep->desc = NULL; + ep->stopped = 0; + ep->fifo_bank = 0; + ep->ep.maxpacket = ep->maxpacket; + ep->creg = (void __iomem *) udc->udp_baseaddr + AT91_UDP_CSR(i); + // initialiser une queue par endpoint + INIT_LIST_HEAD(&ep->queue); + } +} + +static void stop_activity(struct at91_udc *udc) +{ + struct usb_gadget_driver *driver = udc->driver; + int i; + + if (udc->gadget.speed == USB_SPEED_UNKNOWN) + driver = NULL; + udc->gadget.speed = USB_SPEED_UNKNOWN; + udc->suspended = 0; + + for (i = 0; i < NUM_ENDPOINTS; i++) { + struct at91_ep *ep = &udc->ep[i]; + ep->stopped = 1; + nuke(ep, -ESHUTDOWN); + } + if (driver) + driver->disconnect(&udc->gadget); + + udc_reinit(udc); +} + +static inline void clk_enable(unsigned id) +{ + at91_sys_write(AT91_PMC_PCER, 1 << id); +} + +static inline void clk_disable(unsigned id) +{ + at91_sys_write(AT91_PMC_PCER, 1 << id); +} + +static void clk_on(struct at91_udc *udc) +{ + if (udc->clocked) + return; + udc->clocked = 1; + clk_enable(udc->iclk); + /*clk_enable(udc->fclk);*/ +} + +static void clk_off(struct at91_udc *udc) +{ + if (!udc->clocked) + return; + udc->clocked = 0; + udc->gadget.speed = USB_SPEED_UNKNOWN; + + /*clk_disable(udc->fclk);*/ + clk_disable(udc->iclk); +} + +#define VBUS_DOWNTIME 5 /* seconds */ +/* + * activate/deactivate link with host; minimize power usage for + * inactive links by cutting clocks and transceiver power. + */ +static void pullup(struct at91_udc *udc, int is_on) +{ + static int last_pulldown, pulledup_once; + if (!udc->enabled || !udc->vbus) + is_on = 0; + + if (is_on) { + /* + * We need to slow down the pullup/pulldown sequence. + * between pull-down and up at least 5 seconds time is + * required, Windows cannot keep up properly. + */ + if (last_pulldown) { + ulong last = 0, time = get_timer(last_pulldown); + printf("Holding VBUS down: "); + while (time < (VBUS_DOWNTIME * CONFIG_SYS_HZ)) { + if (((time % CONFIG_SYS_HZ) == 0) && + (last != time)) { + printf("%lu...", + VBUS_DOWNTIME - + (time / CONFIG_SYS_HZ)); + last = time; + } + time = get_timer(last_pulldown); + } + printf("Go!\n"); + } + + clk_on(udc); + at91_udp_write(udc, AT91_UDP_ICR, AT91_UDP_RXRSM); + at91_udp_write(udc, AT91_UDP_TXVC, 0); + if (cpu_is_at91rm9200()) + at91_set_gpio_value(udc->board.pullup_pin, 1); + else if (cpu_is_at91sam9260() || cpu_is_at91sam9263()) { + u32 txvc = at91_udp_read(udc, AT91_UDP_TXVC); + + txvc |= AT91_UDP_TXVC_PUON; + at91_udp_write(udc, AT91_UDP_TXVC, txvc); + } else if (cpu_is_at91sam9261()) { + u32 usbpucr; + + usbpucr = at91_sys_read(AT91_MATRIX_USBPUCR); + usbpucr |= AT91_MATRIX_USBPUCR_PUON; + at91_sys_write(AT91_MATRIX_USBPUCR, usbpucr); + } + pulledup_once = 1; + } else { + stop_activity(udc); + at91_udp_write(udc, AT91_UDP_IDR, AT91_UDP_RXRSM); + at91_udp_write(udc, AT91_UDP_TXVC, AT91_UDP_TXVC_TXVDIS); + if (cpu_is_at91rm9200()) + at91_set_gpio_value(udc->board.pullup_pin, 0); + else if (cpu_is_at91sam9260() || cpu_is_at91sam9263()) { + u32 txvc = at91_udp_read(udc, AT91_UDP_TXVC); + + txvc &= ~AT91_UDP_TXVC_PUON; + at91_udp_write(udc, AT91_UDP_TXVC, txvc); + } else if (cpu_is_at91sam9261()) { + u32 usbpucr; + + usbpucr = at91_sys_read(AT91_MATRIX_USBPUCR); + usbpucr &= ~AT91_MATRIX_USBPUCR_PUON; + at91_sys_write(AT91_MATRIX_USBPUCR, usbpucr); + } + clk_off(udc); + + /* Only interesting if it has been pulled up once. */ + if (pulledup_once) + last_pulldown = get_timer(0); + } +} + +/* vbus is here! turn everything on that's ready */ +static int at91_vbus_session(struct usb_gadget *gadget, int is_active) +{ + struct at91_udc *udc = to_udc(gadget); + unsigned long flags; + + /* VDBG("vbus %s\n", is_active ? "on" : "off"); */ + local_irq_save(flags); + if (udc->driver) { + udc->vbus = (is_active != 0); + pullup(udc, is_active); + } + + local_irq_restore(flags); + return 0; +} + +static int at91_pullup(struct usb_gadget *gadget, int is_on) +{ + struct at91_udc *udc = to_udc(gadget); + unsigned long flags; + + local_irq_save(flags); + udc->enabled = is_on = !!is_on; + pullup(udc, is_on); + local_irq_restore(flags); + return 0; +} + +static int at91_set_selfpowered(struct usb_gadget *gadget, int is_on) +{ + struct at91_udc *udc = to_udc(gadget); + unsigned long flags; + + local_irq_save(flags); + udc->selfpowered = (is_on != 0); + local_irq_restore(flags); + return 0; +} + +static const struct usb_gadget_ops at91_udc_ops = { + .get_frame = at91_get_frame, + .wakeup = at91_wakeup, + .set_selfpowered = at91_set_selfpowered, + .vbus_session = at91_vbus_session, + .pullup = at91_pullup, + + /* + * VBUS-powered devices may also also want to support bigger + * power budgets after an appropriate SET_CONFIGURATION. + */ + // .vbus_power = at91_vbus_power, +}; + +/*-------------------------------------------------------------------------*/ + +static int handle_ep(struct at91_ep *ep) +{ + struct at91_request *req; + u32 __iomem *creg = ep->creg; + u32 csr = __raw_readl(creg); + + if (!list_empty(&ep->queue)) + req = list_entry(ep->queue.next, + struct at91_request, queue); + else + req = NULL; + + if (ep->is_in) { + if (csr & (AT91_UDP_STALLSENT | AT91_UDP_TXCOMP)) { + csr |= CLR_FX; + csr &= ~(SET_FX | AT91_UDP_STALLSENT | AT91_UDP_TXCOMP); + __raw_writel(csr, creg); + } + if (req) + return write_fifo(ep, req); + + } else { + if (csr & AT91_UDP_STALLSENT) { + /* STALLSENT bit == ISOERR */ + if (ep->is_iso && req) + req->req.status = -EILSEQ; + csr |= CLR_FX; + csr &= ~(SET_FX | AT91_UDP_STALLSENT); + __raw_writel(csr, creg); + csr = __raw_readl(creg); + } + if (req && (csr & RX_DATA_READY)) + return read_fifo(ep, req); + } + return 0; +} + +union setup { + u8 raw[8]; + struct usb_ctrlrequest r; +}; + +static void handle_setup(struct at91_udc *udc, struct at91_ep *ep, u32 csr) +{ + u32 __iomem *creg = ep->creg; + u8 __iomem *dreg = ep->creg + (AT91_UDP_FDR(0) - AT91_UDP_CSR(0)); + unsigned rxcount, i = 0; + u32 tmp; + union setup pkt; + int status = 0; + + /* read and ack SETUP; hard-fail for bogus packets */ + rxcount = (csr & AT91_UDP_RXBYTECNT) >> 16; + if (rxcount == 8) { + while (rxcount--) + pkt.raw[i++] = __raw_readb(dreg); + if (pkt.r.bRequestType & USB_DIR_IN) { + csr |= AT91_UDP_DIR; + ep->is_in = 1; + } else { + csr &= ~AT91_UDP_DIR; + ep->is_in = 0; + } + } else { + // REVISIT this happens sometimes under load; why?? + printf("error: SETUP len %d, csr %08x\n", rxcount, csr); + status = -EINVAL; + } + csr |= CLR_FX; + csr &= ~(SET_FX | AT91_UDP_RXSETUP); + __raw_writel(csr, creg); + udc->wait_for_addr_ack = 0; + udc->wait_for_config_ack = 0; + ep->stopped = 0; + if (status != 0) + goto stall; + +#define w_index le16_to_cpu(pkt.r.wIndex) +#define w_value le16_to_cpu(pkt.r.wValue) +#define w_length le16_to_cpu(pkt.r.wLength) + + VDBG("SETUP %02x.%02x v%04x i%04x l%04x\n", + pkt.r.bRequestType, pkt.r.bRequest, + w_value, w_index, w_length); + + /* + * A few standard requests get handled here, ones that touch + * hardware ... notably for device and endpoint features. + */ + udc->req_pending = 1; + csr = __raw_readl(creg); + csr |= CLR_FX; + csr &= ~SET_FX; + switch ((pkt.r.bRequestType << 8) | pkt.r.bRequest) { + + case ((USB_TYPE_STANDARD|USB_RECIP_DEVICE) << 8) + | USB_REQ_SET_ADDRESS: + __raw_writel(csr | AT91_UDP_TXPKTRDY, creg); + udc->addr = w_value; + udc->wait_for_addr_ack = 1; + udc->req_pending = 0; + /* FADDR is set later, when we ack host STATUS */ + return; + + case ((USB_TYPE_STANDARD|USB_RECIP_DEVICE) << 8) + | USB_REQ_SET_CONFIGURATION: + tmp = at91_udp_read(udc, AT91_UDP_GLB_STAT) & AT91_UDP_CONFG; + if (pkt.r.wValue) + udc->wait_for_config_ack = (tmp == 0); + else + udc->wait_for_config_ack = (tmp != 0); + if (udc->wait_for_config_ack) + VDBG("wait for config\n"); + /* CONFG is toggled later, if gadget driver succeeds */ + break; + + /* + * Hosts may set or clear remote wakeup status, and + * devices may report they're VBUS powered. + */ + case ((USB_DIR_IN|USB_TYPE_STANDARD|USB_RECIP_DEVICE) << 8) + | USB_REQ_GET_STATUS: + tmp = (udc->selfpowered << USB_DEVICE_SELF_POWERED); + if (at91_udp_read(udc, AT91_UDP_GLB_STAT) & AT91_UDP_ESR) + tmp |= (1 << USB_DEVICE_REMOTE_WAKEUP); + PACKET("get device status\n"); + __raw_writeb(tmp, dreg); + __raw_writeb(0, dreg); + goto write_in; + /* then STATUS starts later, automatically */ + case ((USB_TYPE_STANDARD|USB_RECIP_DEVICE) << 8) + | USB_REQ_SET_FEATURE: + if (w_value != USB_DEVICE_REMOTE_WAKEUP) + goto stall; + tmp = at91_udp_read(udc, AT91_UDP_GLB_STAT); + tmp |= AT91_UDP_ESR; + at91_udp_write(udc, AT91_UDP_GLB_STAT, tmp); + goto succeed; + case ((USB_TYPE_STANDARD|USB_RECIP_DEVICE) << 8) + | USB_REQ_CLEAR_FEATURE: + if (w_value != USB_DEVICE_REMOTE_WAKEUP) + goto stall; + tmp = at91_udp_read(udc, AT91_UDP_GLB_STAT); + tmp &= ~AT91_UDP_ESR; + at91_udp_write(udc, AT91_UDP_GLB_STAT, tmp); + goto succeed; + + /* + * Interfaces have no feature settings; this is pretty useless. + * we won't even insist the interface exists... + */ + case ((USB_DIR_IN|USB_TYPE_STANDARD|USB_RECIP_INTERFACE) << 8) + | USB_REQ_GET_STATUS: + PACKET("get interface status\n"); + __raw_writeb(0, dreg); + __raw_writeb(0, dreg); + goto write_in; + /* then STATUS starts later, automatically */ + case ((USB_TYPE_STANDARD|USB_RECIP_INTERFACE) << 8) + | USB_REQ_SET_FEATURE: + case ((USB_TYPE_STANDARD|USB_RECIP_INTERFACE) << 8) + | USB_REQ_CLEAR_FEATURE: + goto stall; + + /* + * Hosts may clear bulk/intr endpoint halt after the gadget + * driver sets it (not widely used); or set it (for testing) + */ + case ((USB_DIR_IN|USB_TYPE_STANDARD|USB_RECIP_ENDPOINT) << 8) + | USB_REQ_GET_STATUS: + tmp = w_index & USB_ENDPOINT_NUMBER_MASK; + ep = &udc->ep[tmp]; + if (tmp >= NUM_ENDPOINTS || (tmp && !ep->desc)) + goto stall; + + if (tmp) { + if ((w_index & USB_DIR_IN)) { + if (!ep->is_in) + goto stall; + } else if (ep->is_in) + goto stall; + } + PACKET("get %s status\n", ep->ep.name); + if (__raw_readl(ep->creg) & AT91_UDP_FORCESTALL) + tmp = (1 << USB_ENDPOINT_HALT); + else + tmp = 0; + __raw_writeb(tmp, dreg); + __raw_writeb(0, dreg); + goto write_in; + /* then STATUS starts later, automatically */ + case ((USB_TYPE_STANDARD|USB_RECIP_ENDPOINT) << 8) + | USB_REQ_SET_FEATURE: + tmp = w_index & USB_ENDPOINT_NUMBER_MASK; + ep = &udc->ep[tmp]; + if (w_value != USB_ENDPOINT_HALT || tmp >= NUM_ENDPOINTS) + goto stall; + if (!ep->desc || ep->is_iso) + goto stall; + if ((w_index & USB_DIR_IN)) { + if (!ep->is_in) + goto stall; + } else if (ep->is_in) + goto stall; + + tmp = __raw_readl(ep->creg); + tmp &= ~SET_FX; + tmp |= CLR_FX | AT91_UDP_FORCESTALL; + __raw_writel(tmp, ep->creg); + goto succeed; + case ((USB_TYPE_STANDARD|USB_RECIP_ENDPOINT) << 8) + | USB_REQ_CLEAR_FEATURE: + tmp = w_index & USB_ENDPOINT_NUMBER_MASK; + ep = &udc->ep[tmp]; + if (w_value != USB_ENDPOINT_HALT || tmp >= NUM_ENDPOINTS) + goto stall; + if (tmp == 0) + goto succeed; + if (!ep->desc || ep->is_iso) + goto stall; + if ((w_index & USB_DIR_IN)) { + if (!ep->is_in) + goto stall; + } else if (ep->is_in) + goto stall; + + at91_udp_write(udc, AT91_UDP_RST_EP, ep->int_mask); + at91_udp_write(udc, AT91_UDP_RST_EP, 0); + tmp = __raw_readl(ep->creg); + tmp |= CLR_FX; + tmp &= ~(SET_FX | AT91_UDP_FORCESTALL); + __raw_writel(tmp, ep->creg); + if (!list_empty(&ep->queue)) + handle_ep(ep); + goto succeed; + } + +#undef w_value +#undef w_index +#undef w_length + + /* pass request up to the gadget driver */ + if (udc->driver) + status = udc->driver->setup(&udc->gadget, &pkt.r); + else + status = -ENODEV; + if (status < 0) { +stall: + VDBG("req %02x.%02x protocol STALL; stat %d\n", + pkt.r.bRequestType, pkt.r.bRequest, status); + csr |= AT91_UDP_FORCESTALL; + __raw_writel(csr, creg); + udc->req_pending = 0; + } + return; + +succeed: + /* immediate successful (IN) STATUS after zero length DATA */ + PACKET("ep0 in/status\n"); +write_in: + csr |= AT91_UDP_TXPKTRDY; + __raw_writel(csr, creg); + udc->req_pending = 0; + return; +} + +static void handle_ep0(struct at91_udc *udc) +{ + struct at91_ep *ep0 = &udc->ep[0]; + u32 __iomem *creg = ep0->creg; + u32 csr = __raw_readl(creg); + struct at91_request *req; + +// VDBG("%s\n",__func__); + + if (csr & AT91_UDP_STALLSENT) { + nuke(ep0, -EPROTO); + udc->req_pending = 0; + csr |= CLR_FX; + csr &= ~(SET_FX | AT91_UDP_STALLSENT | AT91_UDP_FORCESTALL); + __raw_writel(csr, creg); + VDBG("ep0 stalled\n"); + csr = __raw_readl(creg); + } + if (csr & AT91_UDP_RXSETUP) { + nuke(ep0, 0); + udc->req_pending = 0; + handle_setup(udc, ep0, csr); + return; + } + + if (list_empty(&ep0->queue)) + req = NULL; + else + req = list_entry(ep0->queue.next, struct at91_request, queue); + + /* host ACKed an IN packet that we sent */ + if (csr & AT91_UDP_TXCOMP) { + csr |= CLR_FX; + csr &= ~(SET_FX | AT91_UDP_TXCOMP); + + /* write more IN DATA? */ + if (req && ep0->is_in) { + if (handle_ep(ep0)) + udc->req_pending = 0; + + /* + * Ack after: + * - last IN DATA packet (including GET_STATUS) + * - IN/STATUS for OUT DATA + * - IN/STATUS for any zero-length DATA stage + * except for the IN DATA case, the host should send + * an OUT status later, which we'll ack. + */ + } else { + udc->req_pending = 0; + __raw_writel(csr, creg); + + /* + * SET_ADDRESS takes effect only after the STATUS + * (to the original address) gets acked. + */ + if (udc->wait_for_addr_ack) { + u32 tmp; + + at91_udp_write(udc, AT91_UDP_FADDR, + AT91_UDP_FEN | udc->addr); + tmp = at91_udp_read(udc, AT91_UDP_GLB_STAT); + tmp &= ~AT91_UDP_FADDEN; + if (udc->addr) + tmp |= AT91_UDP_FADDEN; + at91_udp_write(udc, AT91_UDP_GLB_STAT, tmp); + + udc->wait_for_addr_ack = 0; + VDBG("address %d\n", udc->addr); + } + } + } + + /* OUT packet arrived ... */ + else if (csr & AT91_UDP_RX_DATA_BK0) { + csr |= CLR_FX; + csr &= ~(SET_FX | AT91_UDP_RX_DATA_BK0); + + /* OUT DATA stage */ + if (!ep0->is_in) { + if (req) { + if (handle_ep(ep0)) { + /* send IN/STATUS */ + PACKET("ep0 in/status\n"); + csr = __raw_readl(creg); + csr &= ~SET_FX; + csr |= CLR_FX | AT91_UDP_TXPKTRDY; + __raw_writel(csr, creg); + udc->req_pending = 0; + } + } else if (udc->req_pending) { + /* + * AT91 hardware has a hard time with this + * "deferred response" mode for control-OUT + * transfers. (For control-IN it's fine.) + * + * The normal solution leaves OUT data in the + * fifo until the gadget driver is ready. + * We couldn't do that here without disabling + * the IRQ that tells about SETUP packets, + * e.g. when the host gets impatient... + * + * Working around it by copying into a buffer + * would almost be a non-deferred response, + * except that it wouldn't permit reliable + * stalling of the request. Instead, demand + * that gadget drivers not use this mode. + */ + DBG("no control-OUT deferred responses!\n"); + __raw_writel(csr | AT91_UDP_FORCESTALL, creg); + udc->req_pending = 0; + } + + /* STATUS stage for control-IN; ack. */ + } else { + PACKET("ep0 out/status ACK\n"); + __raw_writel(csr, creg); + + /* "early" status stage */ + if (req) + done(ep0, req, 0); + } + } +} + +static void at91_udc_irq (int irq, void *_udc) +{ + struct at91_udc *udc = _udc; + u32 rescans = 5; + + while (rescans--) { + u32 status; + + status = at91_udp_read(udc, AT91_UDP_ISR); + if (!status) + break; + + /* USB reset irq: not maskable */ + if (status & AT91_UDP_ENDBUSRES) { + at91_udp_write(udc, AT91_UDP_IDR, ~MINIMUS_INTERRUPTUS); + /* Atmel code clears this irq twice */ + at91_udp_write(udc, AT91_UDP_ICR, AT91_UDP_ENDBUSRES); + at91_udp_write(udc, AT91_UDP_ICR, AT91_UDP_ENDBUSRES); + VDBG("end bus reset\n"); + udc->addr = 0; + stop_activity(udc); + + /* enable ep0 */ + at91_udp_write(udc, AT91_UDP_CSR(0), + AT91_UDP_EPEDS | AT91_UDP_EPTYPE_CTRL); + udc->gadget.speed = USB_SPEED_FULL; + udc->suspended = 0; + + /* + * NOTE: this driver keeps clocks off unless the + * USB host is present. That saves power, but for + * boards that don't support VBUS detection, both + * clocks need to be active most of the time. + */ + + /* host initiated suspend (3+ms bus idle) */ + } else if (status & AT91_UDP_RXSUSP) { + at91_udp_write(udc, AT91_UDP_IDR, AT91_UDP_RXSUSP); + /* at91_udp_write(udc, AT91_UDP_IER, AT91_UDP_RXRSM); */ + at91_udp_write(udc, AT91_UDP_ICR, AT91_UDP_RXSUSP); + /* VDBG("bus suspend\n"); */ + if (udc->suspended) + continue; + udc->suspended = 1; + + /* + * NOTE: when suspending a VBUS-powered device, the + * gadget driver should switch into slow clock mode + * and then into standby to avoid drawing more than + * 500uA power (2500uA for some high-power configs). + */ + if (udc->driver && udc->driver->suspend) + udc->driver->suspend(&udc->gadget); + + /* host initiated resume */ + } else if (status & AT91_UDP_RXRSM) { + at91_udp_write(udc, AT91_UDP_IDR, AT91_UDP_RXRSM); + /*at91_udp_write(udc, AT91_UDP_IER, AT91_UDP_RXSUSP);*/ + at91_udp_write(udc, AT91_UDP_ICR, AT91_UDP_RXRSM); + /* VDBG("bus resume\n"); */ + if (!udc->suspended) + continue; + udc->suspended = 0; + + /* + * NOTE: for a VBUS-powered device, the gadget driver + * would normally want to switch out of slow clock + * mode into normal mode. + */ + if (udc->driver && udc->driver->resume) + udc->driver->resume(&udc->gadget); + + /* endpoint IRQs are cleared by handling them */ + } else { + int i; + unsigned mask = 1; + struct at91_ep *ep = &udc->ep[1]; + + if (status & mask) + handle_ep0(udc); + for (i = 1; i < NUM_ENDPOINTS; i++) { + mask <<= 1; + if (status & mask) + handle_ep(ep); + ep++; + } + } + } +} + +/*-------------------------------------------------------------------------*/ + +static struct at91_udc controller = { + .udp_baseaddr = (unsigned *) CFG_USBD_REGS_BASE, + .gadget = { + .ops = &at91_udc_ops, + .ep0 = &controller.ep[0].ep, + .name = driver_name, + }, + .ep[0] = { + .ep = { + .name = ep0name, + .ops = &at91_ep_ops, + }, + .udc = &controller, + .maxpacket = 8, + .int_mask = 1 << 0, + }, + .ep[1] = { + .ep = { + .name = "ep1", + .ops = &at91_ep_ops, + }, + .udc = &controller, + .is_pingpong = 1, + .maxpacket = 64, + .int_mask = 1 << 1, + }, + .ep[2] = { + .ep = { + .name = "ep2", + .ops = &at91_ep_ops, + }, + .udc = &controller, + .is_pingpong = 1, + .maxpacket = 64, + .int_mask = 1 << 2, + }, + .ep[3] = { + .ep = { + /* could actually do bulk too */ + .name = "ep3-int", + .ops = &at91_ep_ops, + }, + .udc = &controller, + .maxpacket = 8, + .int_mask = 1 << 3, + }, + .ep[4] = { + .ep = { + .name = "ep4", + .ops = &at91_ep_ops, + }, + .udc = &controller, + .is_pingpong = 1, + .maxpacket = 256, + .int_mask = 1 << 4, + }, + .ep[5] = { + .ep = { + .name = "ep5", + .ops = &at91_ep_ops, + }, + .udc = &controller, + .is_pingpong = 1, + .maxpacket = 256, + .int_mask = 1 << 5, + }, + /* ep6 and ep7 are also reserved (custom silicon might use them) */ +}; + +int usb_gadget_handle_interrupts(void) +{ + struct at91_udc *udc = &controller; + u32 value; + + value = at91_udp_read(udc, AT91_UDP_ISR) & (~(AT91_UDP_SOFINT)); + if (value) + at91_udc_irq(0, udc); + + return (value); +} + +int usb_gadget_register_driver (struct usb_gadget_driver *driver) +{ + struct at91_udc *udc = &controller; + int retval; + unsigned value; + + if (!driver + || driver->speed < USB_SPEED_FULL + || !driver->bind + || !driver->setup) { + DBG("bad parameter.\n"); + return -EINVAL; + } + + if (udc->driver) { + DBG("UDC already has a gadget driver\n"); + return -EBUSY; + } + + udc->driver = driver; + udc->enabled = 1; + udc->selfpowered = 1; + + + retval = driver->bind(&udc->gadget); + if (retval) { + DBG("driver->bind() returned %d\n", retval); + udc->driver = NULL; + udc->enabled = 0; + udc->selfpowered = 0; + return retval; + } + + /* todo: anyway allow registering the driver, maybe a later + * bringup may succeed. postpone pullup the eth_init? + */ + + //check vbus + value = at91_get_gpio_value(udc->board.vbus_pin); + + if (!value) { + //todo: cleanup + printf("no USB host connected...\n"); + return -EAGAIN; + } + udc->vbus=1; + + + DBG("bound to %s\n", driver_name); + return 0; +} + +int at91udc_probe(struct platform_data *pdata) +{ + struct at91_udc *udc; + int retval; + + if (!pdata) { + DBG("missing platform_data\n"); + return -ENODEV; + } + + /* init software state */ + udc = &controller; + //udc->gadget.dev.parent = dev; + udc->board = pdata->board; + udc->enabled = 0; + + init_requests(); + + udc_reinit(udc); + + /* get interface and function clocks */ + udc->iclk = pdata->udc_clk; + if (!udc->iclk) { + DBG("clocks missing\n"); + retval = -ENODEV; + goto fail0; + } + + /* don't do anything until we have both gadget driver and VBUS */ + clk_enable(udc->iclk); + at91_udp_write(udc, AT91_UDP_TXVC, AT91_UDP_TXVC_TXVDIS); + at91_udp_write(udc, AT91_UDP_IDR, 0xffffffff); + /* Clear all pending interrupts - UDP may be used by bootloader. */ + at91_udp_write(udc, AT91_UDP_ICR, 0xffffffff); + clk_disable(udc->iclk); + + if (udc->board.vbus_pin > 0) { + /* + * Get the initial state of VBUS - we cannot expect + * a pending interrupt. + */ + udc->vbus = at91_get_gpio_value(udc->board.vbus_pin); + DBG("VBUS detection: host:%s \n", + udc->vbus ? "present":"absent"); + } else { + DBG("no VBUS detection, assuming always-on\n"); + udc->vbus = 1; + } + return 0; + +fail0: + printf("probe failed, %d\n", retval); + return retval; +} diff --git a/include/usb/at91_udc.h b/include/usb/at91_udc.h new file mode 100644 index 0000000..6ce4dd7 --- /dev/null +++ b/include/usb/at91_udc.h @@ -0,0 +1,209 @@ +/* + * Copyright (C) 2004 by Thomas Rathbone, HP Labs + * Copyright (C) 2005 by Ivan Kokshaysky + * Copyright (C) 2006 by SAN People + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the + * Free Software Foundation, Inc., + * 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA. + */ + +#ifndef AT91_UDC_H +#define AT91_UDC_H + +#include <linux/usb/ch9.h> +#include <linux/usb/gadget.h> +#include <linux/list.h> + + +#define __iomem + +/* + * USB Device Port (UDP) registers. + * Based on AT91RM9200 datasheet revision E. + */ + +#define AT91_UDP_FRM_NUM 0x00 /* Frame Number Register */ +#define AT91_UDP_NUM (0x7ff << 0) /* Frame Number */ +#define AT91_UDP_FRM_ERR (1 << 16) /* Frame Error */ +#define AT91_UDP_FRM_OK (1 << 17) /* Frame OK */ + +#define AT91_UDP_GLB_STAT 0x04 /* Global State Register */ +#define AT91_UDP_FADDEN (1 << 0) /* Function Address Enable */ +#define AT91_UDP_CONFG (1 << 1) /* Configured */ +#define AT91_UDP_ESR (1 << 2) /* Enable Send Resume */ +#define AT91_UDP_RSMINPR (1 << 3) /* Resume has been sent */ +#define AT91_UDP_RMWUPE (1 << 4) /* Remote Wake Up Enable */ + +#define AT91_UDP_FADDR 0x08 /* Function Address Register */ +#define AT91_UDP_FADD (0x7f << 0) /* Function Address Value */ +#define AT91_UDP_FEN (1 << 8) /* Function Enable */ + +#define AT91_UDP_IER 0x10 /* Interrupt Enable Register */ +#define AT91_UDP_IDR 0x14 /* Interrupt Disable Register */ +#define AT91_UDP_IMR 0x18 /* Inte:rrupt Mask Register */ + +#define AT91_UDP_ISR 0x1c /* Interrupt Status Register */ +#define AT91_UDP_EP(n) (1 << (n)) /* Endpoint Interrupt Status */ +#define AT91_UDP_RXSUSP (1 << 8) /* USB Suspend Interrupt Status */ +#define AT91_UDP_RXRSM (1 << 9) /* USB Resume Interrupt Status */ +#define AT91_UDP_EXTRSM (1 << 10) /* External Resume Interrupt Status [AT91RM9200 only] */ +#define AT91_UDP_SOFINT (1 << 11) /* Start of Frame Interrupt Status */ +#define AT91_UDP_ENDBUSRES (1 << 12) /* End of Bus Reset Interrpt Status */ +#define AT91_UDP_WAKEUP (1 << 13) /* USB Wakeup Interrupt Status [AT91RM9200 only] */ + +#define AT91_UDP_ICR 0x20 /* Interrupt Clear Register */ +#define AT91_UDP_RST_EP 0x28 /* Reset Endpoint Register */ + +#define AT91_UDP_CSR(n) (0x30+((n)*4)) /* Endpoint Control/Status Registers 0-7 */ +#define AT91_UDP_TXCOMP (1 << 0) /* Generates IN packet with data previously written in DPR */ +#define AT91_UDP_RX_DATA_BK0 (1 << 1) /* Receive Data Bank 0 */ +#define AT91_UDP_RXSETUP (1 << 2) /* Send STALL to the host */ +#define AT91_UDP_STALLSENT (1 << 3) /* Stall Sent / Isochronous error (Isochronous endpoints) */ +#define AT91_UDP_TXPKTRDY (1 << 4) /* Transmit Packet Ready */ +#define AT91_UDP_FORCESTALL (1 << 5) /* Force Stall */ +#define AT91_UDP_RX_DATA_BK1 (1 << 6) /* Receive Data Bank 1 */ +#define AT91_UDP_DIR (1 << 7) /* Transfer Direction */ +#define AT91_UDP_EPTYPE (7 << 8) /* Endpoint Type */ +#define AT91_UDP_EPTYPE_CTRL (0 << 8) +#define AT91_UDP_EPTYPE_ISO_OUT (1 << 8) +#define AT91_UDP_EPTYPE_BULK_OUT (2 << 8) +#define AT91_UDP_EPTYPE_INT_OUT (3 << 8) +#define AT91_UDP_EPTYPE_ISO_IN (5 << 8) +#define AT91_UDP_EPTYPE_BULK_IN (6 << 8) +#define AT91_UDP_EPTYPE_INT_IN (7 << 8) +#define AT91_UDP_DTGLE (1 << 11) /* Data Toggle */ +#define AT91_UDP_EPEDS (1 << 15) /* Endpoint Enable/Disable */ +#define AT91_UDP_RXBYTECNT (0x7ff << 16) /* Number of bytes in FIFO */ + +#define AT91_UDP_FDR(n) (0x50+((n)*4)) /* Endpoint FIFO Data Registers 0-7 */ + +#define AT91_UDP_TXVC 0x74 /* Transceiver Control Register */ +#define AT91_UDP_TXVC_TXVDIS (1 << 8) /* Transceiver Disable */ +#define AT91_UDP_TXVC_PUON (1 << 9) /* PullUp On [AT91SAM9260 only] */ + +/*-------------------------------------------------------------------------*/ + +/* + * controller driver data structures + */ + +#define NUM_ENDPOINTS 6 + +/* + * hardware won't disable bus reset, or resume while the controller + * is suspended ... watching suspend helps keep the logic symmetric. + */ +#define MINIMUS_INTERRUPTUS \ + (AT91_UDP_ENDBUSRES | AT91_UDP_RXRSM | AT91_UDP_RXSUSP) + +struct at91_ep { + struct usb_ep ep; + struct list_head queue; + struct at91_udc *udc; + void __iomem *creg; + + unsigned maxpacket:16; + u8 int_mask; + unsigned is_pingpong:1; + + unsigned stopped:1; + unsigned is_in:1; + unsigned is_iso:1; + unsigned fifo_bank:1; + + const struct usb_endpoint_descriptor + *desc; +}; + +/* USB Device */ +struct at91_udc_data { + u8 vbus_pin; /* high == host powering us */ + u8 pullup_pin; /* high == D+ pulled up */ +}; + +struct platform_data { + struct at91_udc_data board; + unsigned udc_clk; +}; + +/* + * driver is non-SMP, and just blocks IRQs whenever it needs + * access protection for chip registers or driver state + */ +struct at91_udc { + struct usb_gadget gadget; + struct at91_ep ep[NUM_ENDPOINTS]; + struct usb_gadget_driver *driver; + unsigned vbus:1; + unsigned enabled:1; + unsigned clocked:1; + unsigned suspended:1; + unsigned req_pending:1; + unsigned wait_for_addr_ack:1; + unsigned wait_for_config_ack:1; + unsigned selfpowered:1; + unsigned active_suspend:1; + u8 addr; + struct at91_udc_data board; + unsigned iclk; + void __iomem *udp_baseaddr; + int udp_irq; +}; + +static inline struct at91_udc *to_udc(struct usb_gadget *g) +{ + return container_of(g, struct at91_udc, gadget); +} + +struct at91_request { + struct usb_request req; + struct list_head queue; + unsigned in_use; +}; + +/* udc_disconnect + * + * Disconnect is not used but, is included for completeness + */ +void udc_disconnect (void); + +int at91udc_probe(struct platform_data *pdata); + +/*-------------------------------------------------------------------------*/ + +#ifdef DEBUG +#define DBG(stuff...) printf("udc: " stuff) +#else +#define DBG(stuff...) do{}while(0) +#endif + +#ifdef VERBOSE +#define VDBG(x...) printf(x) +#else +#define VDBG(stuff...) do{}while(0) +#endif + +#ifdef PACKET_TRACE +# define PACKET VDBG +#else +# define PACKET(stuff...) do{}while(0) +#endif + +#define ERR(stuff...) printf("ERR udc: " stuff) +#define WARN(stuff...) printf("WARNING udc: " stuff) +#define INFO(stuff...) printf("INFO udc: " stuff) + +#endif +
Dear Remy Bohmer,
This patch implements the low-level part of the USB CDC layer for AT91 Other boards can use this patch as an example to connect their own. diff --git a/arch/arm/include/asm/arch-at91/at91_dbgu.h b/arch/arm/include/asm/arch-at91/at91_dbgu.h new file mode 100644
Please see my patch introducing at91_dbgu.h (4/5.July 2010)
Use struct access for SoC registers. Offset adressing is depreciated. See the struct in my at91_dbgu.h. Use readl/writel to access the hardware.
Don't define this here, UART handling is in drivers/serial/atmel_usart.? The first 9 registers in the DBGU are identical to the normal USARTS.
I think we should not define stuff that is nowhere used, and if one space or tab will do.
<snip>
Don't include other header files at this point. If a c source requires both DBGU and CPU headers, it shall include both.
<snip>
Nice to have, but determining at runtime which variant we are on makes only sense to me for pin-compatible variants, e.g. 9260, 9xe, 9g20. Then you will notice that their hardware is not different much, if at all. Non pin-compatible variants are #defined in their board specific header file. Use #ifdef in the source to handle necessary variant specific stuff...
<snip>
NO C++ comments allowed. And no commented away defines in general. Maybe say it like this: /* * to switch on debug output define any of those: * DEBUG - general debug * VERBOSE - more debug * PACKET_TRACE - also print packets */ wherever possible use the debug() macro defines in common.h
- This driver expects the board has been wired with two GPIOs suppporting
- a VBUS sensing IRQ, and a D+ pullup. (They may be omitted, but the
- testing hasn't covered such cases.)
It should. Besides AT91 currently cannot handle IRQs. Also I think it should read D- pullup.
<snip>
hang();
Does this mean the system is dead and would need a watchdog or reset button to come alive again?
<snip>
- // terminer chaque requete dans la queue
C++ comment in unknown language ;)?
<snip>
+/* TODO:
- BUG_ON(!list_empty(&req->queue));
- kfree(req); */
Wrong multi line comment.
<snip>
<snip>
I suggest to define and use a weak function to dummy on/off the pullup. Board specific source can implement a function then to really switch on/off a pullup in whatever way the hardware has provided that. That need not necessarily be a GPIO pin...
u32 usbpucr;
Using a board specific function will rid you of that cascade as well.
- u32 __iomem *creg = ep->creg;
- u8 __iomem *dreg = ep->creg + (AT91_UDP_FDR(0) - AT91_UDP_CSR(0));
Always use readl/writel to access hardware.
There are more coding style problems in the source, but for source pulled from the kernel that might be ok (Wolfgang?)
Best Regards, Reinhard Meyer
2010/8/12 Reinhard Meyer u-boot@emk-elektronik.de:
Dear Remy Bohmer,
Hmm, this one does not seem to be in mainline yet. If it was, I probably would have used that one ;-)
Most of the code is copied from Linux. Do you really think we should rewrite it all?
Indeed, but again, it is copied from Linux...
Except for easy synching with Linux code?
<snip> > > +#include <asm/hardware.h> > +#include <asm/arch/at91_dbgu.h> > +#include <asm/arch/io.h>
This is how the file looks like in Linux...
See Linux...
<snip> > > +//#define DEBUG 1 > +//#define VERBOSE 1 > +//#define PACKET_TRACE 1
OK. This is a left-over that I do not seem to have cleaned up. I usually use // during development, then I can easily find what to clean up later...
Even in code with Linux as origin?
suppporting
This file is copied from Linux. That was the goal of this port; to be able to integrate new devices and fixes easier in the future. It was not our goal to make it nicer compared to Linux. If the comments are wrong, I would suggest to fix it in Linux first after which we integrate it in U-boot.
<snip> > > + hang();
Yep, if that happens things are really broken...
<snip>
Linux code...
<snip>
+/* TODO:
- kfree(req); */
OK
<snip>
<snip>
That is doing things differently compared to Linux...
- if (cpu_is_at91rm9200())
- at91_set_gpio_value(udc->board.pullup_pin, 1);
- else if (cpu_is_at91sam9260() || cpu_is_at91sam9263()) {
- u32 txvc = at91_udp_read(udc, AT91_UDP_TXVC);
- txvc |= AT91_UDP_TXVC_PUON;
- at91_udp_write(udc, AT91_UDP_TXVC, txvc);
- } else if (cpu_is_at91sam9261()) {
- u32 usbpucr;
- usbpucr = at91_sys_read(AT91_MATRIX_USBPUCR);
- usbpucr |= AT91_MATRIX_USBPUCR_PUON;
- at91_sys_write(AT91_MATRIX_USBPUCR, usbpucr);
Agree, but that means doing things differently compared to Linux... (the origin of this code)
AT91_UDP_CSR(0));
See Linux
I understand your remarks, and for new written code they are 100% valid to me (I would even not have posted it at all like this), however, most of this code comes from Linux. It is a port to U-boot. True, things can be done differently, but that would make future syncing and integration of new drivers much more difficult.
Kind regards,
Remy
Dear Remy Bohmer,
In message AANLkTi=z0SX9YrXgH-_ogcPdUXhyrHADNErHVVBoNW7L@mail.gmail.com you wrote:
Indeed. Using I/O accessors is mandatory in U-Boot.
Maybe we can do it better?
You got me here. Of course allowing for easy updates from Linux is important, but then, we will have bigger differences anyway, for example for the I/O accessors.
See Linux...
This is not a general purpose, answers-all-questions/kills-them-all argument. Don't over-use it. Linux is great, but there is bad code in Linux like everywhere else. Blindly copying for no better reason that that Linux is doing that ways is NOT a good idea.
Come on. Here a bit statistics:
-> diff -u linux/drivers/usb/gadget/at91_udc.c u-boot/drivers/usb/gadget/at91_udc.c | wc -l 1057 -> wc -l linux/drivers/usb/gadget/at91_udc.c u_boot/drivers/usb/gadget/at91_udc.c 1908 linux/drivers/usb/gadget/at91_udc.c 1553 u-boot/drivers/usb/gadget/at91_udc.c
There are so many lines changed already in the code that claoming "This file is copied from Linux." does not make much sense any more.
And many of the code changes are to the worse actually.
For example:
- ep->is_in = usb_endpoint_dir_in(desc); + ep->is_in = (desc->bEndpointAddress & USB_DIR_IN) != 0;
It is NOT the Linux code that is using CamelCase identifiers, for example.
hang();
So broken that you cannot get back to the command line interpreter? Really?
Linux code...
And that justifies it all.
Face it: the code as is can already be synced only manually. It is way too different already.
Dear Remy Bohmer,
just some more observations:
1. The USB device port hardware in AT91SAM9* is called "UDP". So files that are AT91 specific should have "udp" in their names, not "udc". I know LinuX did do it wrong already...
2. At one part the header file for at9sam9261 is unconditionally included, and none for the other at91 variants. Have you verified that this is OK for all at91 variants? Besides that if so, the common parts used should probably be moved to an extra at91_*.h file.
3. I did not follow the whole USB patches, my concern is what touches AT91, but please explain to me what for we need a board under u-boot to be a USB device. Since u-boot per se is not multitasking how is the traffic handled while at the command prompt?
Which leads to: 4. Which hardware did you test that on, and what device functionality?
- I did not follow the whole USB patches, my concern is
There is no traffic handled while at the command prompt. It behaves just like any other 'normal' network adapter. So, it brings up a USB connection once you start a network action like a ping or tftp command. Once that completes the link is brought down again.
Within the series you can see that it was created for the Atmel at91sam9261-ek kit.
Kind regards,
Remy
Dear Remy Bohmer,
If I understand the procedure correctly now, its as follows:
Any client network command on u-boot's command prompt like ping, dhcp, tftp etc. will 'up' the USB Device... The host to which it is connected to will happily discover and enumerate a network adapter with MAC and IP addresses... And the host will be the server for that command...
2010/8/13 Reinhard Meyer u-boot@emk-elektronik.de:
Dear Remy Bohmer,
Correct.
The procedure is initiated by U-boot, since that one is pulling the D+ resistor up and down. Network traffic is of course bidirectional, so U-boot can initiate a TFTP transfer when it is up.
Kind regards,
Remy
Hi Wolfgang,
2010/8/12 Wolfgang Denk wd@denx.de:
Dear Remy Bohmer,
Ok, but here ends the goal for easy synching with the kernel. In that case we can write our own USB gadget layer
As mentioned: we can, but I did not want to at the time of writing that code.
Well, it is derived from 2.6.27, not latest git. True, there are differences, but mostly it is a strip down of the original code( /proc support is removed for example) And I also noticed that the file can be synced to Linux more than it currently is...
For example:
This was NOT the case in 2.6.27. So, it is not worse compared to 2.6.27...
If malloc is broken, I consider that reason enough for hang/reboot...
Linux code...
No, but please look at the overall goal here. It was the goal to use the Linux code as much as-is, and to allow easy merging new driver code in the future. Everything can be made better, but in that case I would prefer to first make the origin better, and port that back to U-boot.
Further, I am not planning to rewrite the code to the struct based register access _right now_, since the struct based access mechanism is somehow work in progress that is not finalised yet (CONFIG_AT91_LEGACY is still defined for at91sam9261ek). I am not going to shoot on a moving duck. Also because you mention that at91_dbgu.h patches float around that are not in mainline yet. I will probably clean it up later when things are stabilised.
So, if you prefer I can drop patch 2/3 and 3/3 from the series, since those are only needed to prove that patch 1/3 works and to have at least 1 board in U-boot that make use of the USB-CDC-ECM gadget layer... I expect that there will be other boards soon that will use it, since others are working on it right now.
Kind regards,
Remy
Dear Remy Bohmer,
In message AANLkTinv_4m6CfVzGd+ofF1cinzUWEJHiutdd9rPfgas@mail.gmail.com you wrote:
Well, if your argument is true that the current code can easily be kept in sync with Linux, then why is it already 8 kernel releases old?
How about syncing it with Linux, before adding it to U-Boot?
That's not a good idea. Please fix.
Well, the origin has improved by 8 kernel releases since.
Would it make sense to update?
Hi Wolfgang,
2010/8/13 Wolfgang Denk wd@denx.de:
Dear Remy Bohmer,
Because it lives already for a real long time in the u-boot-usb tree with no requests on the ML about this subject. Nobody ever showed interest on the ML, so that did not convince me to put any effort in it to push it further. (Why put a lot of time in something if nobody wants it?) Recently there finally seems to be interest, so now it is time to do something useful with it.
Can be done, but first collect the review comments to figure out how much time it will take to make it U-boot suitable and find out if we need to fork anyway... From functional point of view I see no reason yet to upgrade.
Fix what? If runtime a condition is detected that should _never_ _ever_ happen (like malloc does not work properly for some reason), which would even make Linux OOPS or panic may not result in a hang() on U-boot? In that case I can remove the hang() and consider if it never happened. Maybe even the code will reach the prompt, but there will be no guarantees... I personally consider that worse compared to tell the user that something serious has gone wrong...
Kind regards,
Remy
Dear Remy Bohmer,
In message AANLkTi=eR+5ZTY_S0hE8QR460QntEHXs1izsFNtopopR@mail.gmail.com you wrote:
That's not a good idea. =A0Please fix.
malloc() is not broken, it just has not enough resources to fulfil your request. That does not mean that the rest of the system (which does not make any such requests) would not be able to continue.
Fail the running command with appropriate error message and returen code, but do not decide for the user if he is able and willing to continue.
Of course we have to issue appropriate error messages and return codes, but there is no need to halt the system.
You stop your car, but you don't (usually) take it to a knacker's yard when there is a flat tire.
Signed-off-by: Thomas Smits ts.smits@gmail.com Signed-off-by: Remy Bohmer linux@bohmer.net --- board/atmel/at91sam9261ek/at91sam9261ek.c | 43 +++++++++++++++++++++++++++- include/configs/at91sam9261ek.h | 17 +++++++++++ 2 files changed, 58 insertions(+), 2 deletions(-)
diff --git a/board/atmel/at91sam9261ek/at91sam9261ek.c b/board/atmel/at91sam9261ek/at91sam9261ek.c index de5cfae..1a27e53 100644 --- a/board/atmel/at91sam9261ek/at91sam9261ek.c +++ b/board/atmel/at91sam9261ek/at91sam9261ek.c @@ -33,14 +33,29 @@ #include <asm/arch/gpio.h> #include <asm/arch/io.h> #include <lcd.h> +#include <usb/at91_udc.h> #include <atmel_lcdc.h> #if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_DRIVER_DM9000) #include <net.h> #include <netdev.h> #endif
+#if defined(CONFIG_USB_GADGET_AT91) && !defined(CONFIG_USB_GADGET) +#error "Need CONFIG_USB_GADGET when CONFIG_USB_GADGET_AT91 enabled" +#endif + DECLARE_GLOBAL_DATA_PTR;
+#ifdef CONFIG_USB_GADGET_AT91 +struct platform_data brd = { + .board = { + .vbus_pin = AT91_PIN_PB29, + .pullup_pin = 0, + }, + .udc_clk = AT91SAM9261_ID_UDP, +}; +#endif + /* ------------------------------------------------------------------------- */ /* * Miscelaneous platform dependent initialisations @@ -141,6 +156,16 @@ static void at91sam9261ek_dm9000_hw_init(void) } #endif
+#ifdef CONFIG_USB_GADGET_AT91 +static void at91sam9261ek_usbd_hw_init(void) +{ + /* PLLB is already enabled by the bootstrap loader... */ + at91_sys_write(AT91_PMC_SCER, AT91SAM926x_PMC_UDP); + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9261_ID_PIOB); + at91_set_gpio_input(brd.board.vbus_pin, 0); +} +#endif + #ifdef CONFIG_LCD vidinfo_t panel_info = { vl_col: 240, @@ -255,6 +280,9 @@ int board_init(void) #ifdef CONFIG_HAS_DATAFLASH at91_spi0_hw_init(1 << 0); #endif +#ifdef CONFIG_USB_GADGET_AT91 + at91sam9261ek_usbd_hw_init(); +#endif #ifdef CONFIG_DRIVER_DM9000 at91sam9261ek_dm9000_hw_init(); #endif @@ -264,10 +292,21 @@ int board_init(void) return 0; }
-#ifdef CONFIG_DRIVER_DM9000 +#if defined(CONFIG_DRIVER_DM9000) || defined(CONFIG_USB_GADGET_AT91) int board_eth_init(bd_t *bis) { - return dm9000_initialize(bis); + int res = -1; + +#if defined(CONFIG_DRIVER_DM9000) + res = dm9000_initialize(bis); +#endif +#if defined(CONFIG_USB_GADGET_AT91) + at91udc_probe(&brd); + + if (usb_eth_initialize(bis) >= 0) + res = 0; +#endif + return res; } #endif
diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index df8181b..8749b51 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -151,6 +151,23 @@ #define CONFIG_DM9000_NO_SROM 1 #define CONFIG_NET_RETRY_COUNT 20 #define CONFIG_RESET_PHY_R 1 +#define CONFIG_NET_DO_NOT_TRY_ANOTHER 1 + +/* Configure Ethernet over USB */ +#define CONFIG_USB_GADGET 1 +#define CONFIG_USB_GADGET_AT91 1 +#define CONFIG_USB_ETHER 1 +#ifdef CONFIG_USB_GADGET +#define CFG_USBD_REGS_BASE AT91SAM9261_BASE_UDP +#endif +#define CONFIG_USBNET_MANUFACTURER "Atmel AT91SAM9261-EK" +/* ethaddr settings can be overruled via environment settings */ +#define CONFIG_USBNET_DEV_ADDR "8e:28:0f:fa:3c:39" +#define CONFIG_USBNET_HOST_ADDR "0a:fa:63:8b:e8:0a" +#define CONFIG_USB_CDC_VENDOR_ID 0x0525 +#define CONFIG_USB_CDC_PRODUCT_ID 0xa4a1 +#define CONFIG_USB_RNDIS_VENDOR_ID 0x0525 +#define CONFIG_USB_RNDIS_PRODUCT_ID 0xa4a2
/* USB */ #define CONFIG_USB_ATMEL
Reinhard Meyer
Remy Bohmer
