[U-Boot] [PATCH] ventana: fixed comments in eeprom header
Fix several invalid comments regarding the EEPROM structure used by Gateworks Ventana boards.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/gw_ventana/ventana_eeprom.h | 14 +++++++------- 1 file changed, 7 insertions(+), 7 deletions(-)
diff --git a/board/gateworks/gw_ventana/ventana_eeprom.h b/board/gateworks/gw_ventana/ventana_eeprom.h index d310bfd..434b604 100644 --- a/board/gateworks/gw_ventana/ventana_eeprom.h +++ b/board/gateworks/gw_ventana/ventana_eeprom.h @@ -16,16 +16,16 @@ struct ventana_board_info { u8 mfgdate[4]; /* 0x20: MFG date (read only) */ u8 res2[7]; /* 0x24 */ /* sdram config */ - u8 sdram_size; /* 0x2B: enum (512,1024,2048) MB */ - u8 sdram_speed; /* 0x2C: enum (100,133,166,200,267,333,400) MHz */ - u8 sdram_width; /* 0x2D: enum (32,64) bit */ + u8 sdram_size; /* 0x2B: (16 << n) MB */ + u8 sdram_speed; /* 0x2C: (33.333 * n) MHz */ + u8 sdram_width; /* 0x2D: (8 << n) bit */ /* cpu config */ - u8 cpu_speed; /* 0x2E: enum (800,1000,1200) MHz */ - u8 cpu_type; /* 0x2F: enum (imx6q,imx6d,imx6dl,imx6s) */ + u8 cpu_speed; /* 0x2E: (33.333 * n) MHz */ + u8 cpu_type; /* 0x2F: 7=imx6q, 8=imx6dl */ u8 model[16]; /* 0x30: model string */ /* FLASH config */ - u8 nand_flash_size; /* 0x40: enum (4,8,16,32,64,128) MB */ - u8 spi_flash_size; /* 0x41: enum (4,8,16,32,64,128) MB */ + u8 nand_flash_size; /* 0x40: (8 << (n-1)) MB */ + u8 spi_flash_size; /* 0x41: (4 << (n-1)) MB */
/* Config1: SoC Peripherals */ u8 config[8]; /* 0x42: loading options */
Hallo Tim,
Best regards, Stefano Babic
Stefano Babic
Tim Harvey
