[PATCH v1 0/4] phy: Add generic_{setup,shutdown}_phy() helpers
In drivers ehci-generic.c and ohci-generic.c, specific phy helpers has been added and shared 95% of common code. Factorize this code in generic_{setup,shutdown}_phy() helpers and update all consumers.
Patrice Chotard (4): phy: Add generic_{setup,shutdown}_phy() helpers usb: ohci: Make usage of generic_{setup,shutdown}_phy() helpers usb: ehci: Make usage of generic_{setup,shutdown}_phy() helpers usb: ehci: Remove unused ehci_{setup,shutdown}_phy() helpers
drivers/phy/phy-uclass.c | 42 +++++++++++++++++++++ drivers/usb/host/ehci-generic.c | 6 +-- drivers/usb/host/ehci-hcd.c | 66 --------------------------------- drivers/usb/host/ehci-msm.c | 4 +- drivers/usb/host/ehci-mx6.c | 6 +-- drivers/usb/host/ehci-pci.c | 4 +- drivers/usb/host/ehci.h | 4 -- drivers/usb/host/ohci-generic.c | 56 ++-------------------------- include/generic-phy.h | 30 +++++++++++++++ 9 files changed, 85 insertions(+), 133 deletions(-)
In drivers usb/host/{ehci,ohci}-generic.c, {ehci,ohci}_setup_phy() and {ehci,ohci}_shutdown_phy() shares 95% of common code. Factorize this code in new generic_{setup,shudown}_phy() functions.
Signed-off-by: Patrice Chotard patrice.chotard@foss.st.com Cc: Marek Vasut marex@denx.de Cc: Simon Glass sjg@chromium.org ---
drivers/phy/phy-uclass.c | 42 ++++++++++++++++++++++++++++++++++++++++ include/generic-phy.h | 30 ++++++++++++++++++++++++++++ 2 files changed, 72 insertions(+)
diff --git a/drivers/phy/phy-uclass.c b/drivers/phy/phy-uclass.c index 8b84da3ce0..3fef5135a9 100644 --- a/drivers/phy/phy-uclass.c +++ b/drivers/phy/phy-uclass.c @@ -455,6 +455,48 @@ int generic_phy_power_off_bulk(struct phy_bulk *bulk) return ret; }
+int generic_setup_phy(struct udevice *dev, struct phy *phy, int index) +{ + int ret = 0; + + if (!phy) + return 0; + + ret = generic_phy_get_by_index(dev, index, phy); + if (ret) { + if (ret != -ENOENT) + return ret; + } else { + ret = generic_phy_init(phy); + if (ret) + return ret; + + ret = generic_phy_power_on(phy); + if (ret) + ret = generic_phy_exit(phy); + } + + return ret; +} + +int generic_shutdown_phy(struct phy *phy) +{ + int ret = 0; + + if (!phy) + return 0; + + if (generic_phy_valid(phy)) { + ret = generic_phy_power_off(phy); + if (ret) + return ret; + + ret = generic_phy_exit(phy); + } + + return ret; +} + UCLASS_DRIVER(phy) = { .id = UCLASS_PHY, .name = "phy", diff --git a/include/generic-phy.h b/include/generic-phy.h index d40ce589b6..f8eddeff67 100644 --- a/include/generic-phy.h +++ b/include/generic-phy.h @@ -342,6 +342,26 @@ int generic_phy_power_on_bulk(struct phy_bulk *bulk); */ int generic_phy_power_off_bulk(struct phy_bulk *bulk);
+/** + * generic_setup_phy() - Get, initialize and power on phy. + * + * @dev: The consumer device. + * @phy: A pointer to the PHY port + * @index: The index in the list of available PHYs + * + * Return: 0 if OK, or negative error code. + */ +int generic_setup_phy(struct udevice *dev, struct phy *phy, int index); + +/** + * generic_shutdown_phy() - Power off and de-initialize phy. + * + * @phy: A pointer to the PHY port. + * + * Return: 0 if OK, or negative error code. + */ +int generic_shutdown_phy(struct phy *phy); + #else /* CONFIG_PHY */
static inline int generic_phy_init(struct phy *phy) @@ -407,6 +427,16 @@ static inline int generic_phy_power_off_bulk(struct phy_bulk *bulk) return 0; }
+static inline int generic_setup_phy(struct udevice *dev, struct phy *phy, int index) +{ + return 0; +} + +static inline int generic_shutdown_phy(struct phy *phy) +{ + return 0; +} + #endif /* CONFIG_PHY */
Replace ohci_setup_phy() and ohci_shutdown_phy () by respectively generic_setup_phy() and generic_shutdown_phy().
drivers/usb/host/ohci-generic.c | 56 ++------------------------------- 1 file changed, 3 insertions(+), 53 deletions(-)
diff --git a/drivers/usb/host/ohci-generic.c b/drivers/usb/host/ohci-generic.c index 5d23058aaf..2d8d38ce9a 100644 --- a/drivers/usb/host/ohci-generic.c +++ b/drivers/usb/host/ohci-generic.c @@ -23,56 +23,6 @@ struct generic_ohci { int reset_count; /* number of reset in reset list */ };
-static int ohci_setup_phy(struct udevice *dev, int index) -{ - struct generic_ohci *priv = dev_get_priv(dev); - int ret; - - ret = generic_phy_get_by_index(dev, index, &priv->phy); - if (ret) { - if (ret != -ENOENT) { - dev_err(dev, "failed to get usb phy\n"); - return ret; - } - } else { - ret = generic_phy_init(&priv->phy); - if (ret) { - dev_dbg(dev, "failed to init usb phy\n"); - return ret; - } - - ret = generic_phy_power_on(&priv->phy); - if (ret) { - dev_dbg(dev, "failed to power on usb phy\n"); - return generic_phy_exit(&priv->phy); - } - } - - return 0; -} - -static int ohci_shutdown_phy(struct udevice *dev) -{ - struct generic_ohci *priv = dev_get_priv(dev); - int ret = 0; - - if (generic_phy_valid(&priv->phy)) { - ret = generic_phy_power_off(&priv->phy); - if (ret) { - dev_dbg(dev, "failed to power off usb phy\n"); - return ret; - } - - ret = generic_phy_exit(&priv->phy); - if (ret) { - dev_dbg(dev, "failed to power off usb phy\n"); - return ret; - } - } - - return 0; -} - static int ohci_usb_probe(struct udevice *dev) { struct ohci_regs *regs = dev_read_addr_ptr(dev); @@ -135,7 +85,7 @@ static int ohci_usb_probe(struct udevice *dev) goto clk_err; }
- err = ohci_setup_phy(dev, 0); + err = generic_setup_phy(dev, &priv->phy, 0); if (err) goto reset_err;
@@ -146,7 +96,7 @@ static int ohci_usb_probe(struct udevice *dev) return 0;
phy_err: - ret = ohci_shutdown_phy(dev); + ret = generic_shutdown_phy(&priv->phy); if (ret) dev_err(dev, "failed to shutdown usb phy\n");
@@ -171,7 +121,7 @@ static int ohci_usb_remove(struct udevice *dev) if (ret) return ret;
- ret = ohci_shutdown_phy(dev); + ret = generic_shutdown_phy(&priv->phy); if (ret) return ret;
Replace ehci_setup_phy() and ehci_shutdown_phy () by respectively generic_setup_phy() and generic_shutdown_phy().
drivers/usb/host/ehci-generic.c | 6 +++--- drivers/usb/host/ehci-msm.c | 4 ++-- drivers/usb/host/ehci-mx6.c | 6 +++--- drivers/usb/host/ehci-pci.c | 4 ++-- 4 files changed, 10 insertions(+), 10 deletions(-)
diff --git a/drivers/usb/host/ehci-generic.c b/drivers/usb/host/ehci-generic.c index 75c73bfe4e..a765a307a3 100644 --- a/drivers/usb/host/ehci-generic.c +++ b/drivers/usb/host/ehci-generic.c @@ -96,7 +96,7 @@ static int ehci_usb_probe(struct udevice *dev) if (err) goto reset_err;
- err = ehci_setup_phy(dev, &priv->phy, 0); + err = generic_setup_phy(dev, &priv->phy, 0); if (err) goto regulator_err;
@@ -111,7 +111,7 @@ static int ehci_usb_probe(struct udevice *dev) return 0;
phy_err: - ret = ehci_shutdown_phy(dev, &priv->phy); + ret = generic_shutdown_phy(&priv->phy); if (ret) dev_err(dev, "failed to shutdown usb phy (ret=%d)\n", ret);
@@ -141,7 +141,7 @@ static int ehci_usb_remove(struct udevice *dev) if (ret) return ret;
- ret = ehci_shutdown_phy(dev, &priv->phy); + ret = generic_shutdown_phy(&priv->phy); if (ret) return ret;
diff --git a/drivers/usb/host/ehci-msm.c b/drivers/usb/host/ehci-msm.c index d160cf019d..dd0d153500 100644 --- a/drivers/usb/host/ehci-msm.c +++ b/drivers/usb/host/ehci-msm.c @@ -56,7 +56,7 @@ static int ehci_usb_probe(struct udevice *dev) hcor = (struct ehci_hcor *)((phys_addr_t)hccr + HC_LENGTH(ehci_readl(&(hccr)->cr_capbase)));
- ret = ehci_setup_phy(dev, &p->phy, 0); + ret = generic_setup_phy(dev, &p->phy, 0); if (ret) return ret;
@@ -81,7 +81,7 @@ static int ehci_usb_remove(struct udevice *dev) /* Stop controller. */ clrbits_le32(&ehci->usbcmd, CMD_RUN);
- ret = ehci_shutdown_phy(dev, &p->phy); + ret = generic_shutdown_phy(&p->phy); if (ret) return ret;
diff --git a/drivers/usb/host/ehci-mx6.c b/drivers/usb/host/ehci-mx6.c index e30449b55e..fa2ca2a1d9 100644 --- a/drivers/usb/host/ehci-mx6.c +++ b/drivers/usb/host/ehci-mx6.c @@ -726,7 +726,7 @@ static int ehci_usb_probe(struct udevice *dev) mdelay(10);
#if defined(CONFIG_PHY) - ret = ehci_setup_phy(dev, &priv->phy, 0); + ret = generic_setup_phy(dev, &priv->phy, 0); if (ret) goto err_regulator; #endif @@ -743,7 +743,7 @@ static int ehci_usb_probe(struct udevice *dev)
err_phy: #if defined(CONFIG_PHY) - ehci_shutdown_phy(dev, &priv->phy); + generic_shutdown_phy(&priv->phy); err_regulator: #endif #if CONFIG_IS_ENABLED(DM_REGULATOR) @@ -767,7 +767,7 @@ int ehci_usb_remove(struct udevice *dev) ehci_deregister(dev);
#if defined(CONFIG_PHY) - ehci_shutdown_phy(dev, &priv->phy); + generic_shutdown_phy(&priv->phy); #endif
#if CONFIG_IS_ENABLED(DM_REGULATOR) diff --git a/drivers/usb/host/ehci-pci.c b/drivers/usb/host/ehci-pci.c index 1ab306147f..e98ab31261 100644 --- a/drivers/usb/host/ehci-pci.c +++ b/drivers/usb/host/ehci-pci.c @@ -31,7 +31,7 @@ static int ehci_pci_init(struct udevice *dev, struct ehci_hccr **ret_hccr, int ret; u32 cmd;
- ret = ehci_setup_phy(dev, &priv->phy, 0); + ret = generic_setup_phy(dev, &priv->phy, 0); if (ret) return ret;
@@ -149,7 +149,7 @@ static int ehci_pci_remove(struct udevice *dev) if (ret) return ret;
- return ehci_shutdown_phy(dev, &priv->phy); + return generic_shutdown_phy(&priv->phy); }
static const struct udevice_id ehci_pci_ids[] = {
Remove unused ehci_{setup,shutdown}_phy() helpers now replaced by generic_{setup,shutdown}_phy().
drivers/usb/host/ehci-hcd.c | 66 ------------------------------------- drivers/usb/host/ehci.h | 4 --- 2 files changed, 70 deletions(-)
diff --git a/drivers/usb/host/ehci-hcd.c b/drivers/usb/host/ehci-hcd.c index f033198a7c..fb970e3148 100644 --- a/drivers/usb/host/ehci-hcd.c +++ b/drivers/usb/host/ehci-hcd.c @@ -1767,69 +1767,3 @@ struct dm_usb_ops ehci_usb_ops = { };
#endif - -#ifdef CONFIG_PHY -int ehci_setup_phy(struct udevice *dev, struct phy *phy, int index) -{ - int ret; - - if (!phy) - return 0; - - ret = generic_phy_get_by_index(dev, index, phy); - if (ret) { - if (ret != -ENOENT) { - dev_err(dev, "failed to get usb phy\n"); - return ret; - } - } else { - ret = generic_phy_init(phy); - if (ret) { - dev_dbg(dev, "failed to init usb phy\n"); - return ret; - } - - ret = generic_phy_power_on(phy); - if (ret) { - dev_dbg(dev, "failed to power on usb phy\n"); - return generic_phy_exit(phy); - } - } - - return 0; -} - -int ehci_shutdown_phy(struct udevice *dev, struct phy *phy) -{ - int ret = 0; - - if (!phy) - return 0; - - if (generic_phy_valid(phy)) { - ret = generic_phy_power_off(phy); - if (ret) { - dev_dbg(dev, "failed to power off usb phy\n"); - return ret; - } - - ret = generic_phy_exit(phy); - if (ret) { - dev_dbg(dev, "failed to power off usb phy\n"); - return ret; - } - } - - return 0; -} -#else -int ehci_setup_phy(struct udevice *dev, struct phy *phy, int index) -{ - return 0; -} - -int ehci_shutdown_phy(struct udevice *dev, struct phy *phy) -{ - return 0; -} -#endif diff --git a/drivers/usb/host/ehci.h b/drivers/usb/host/ehci.h index 5170044a3a..5770d35b46 100644 --- a/drivers/usb/host/ehci.h +++ b/drivers/usb/host/ehci.h @@ -295,9 +295,5 @@ int ehci_register(struct udevice *dev, struct ehci_hccr *hccr, int ehci_deregister(struct udevice *dev); extern struct dm_usb_ops ehci_usb_ops;
-/* EHCI PHY functions */ -int ehci_setup_phy(struct udevice *dev, struct phy *phy, int index); -int ehci_shutdown_phy(struct udevice *dev, struct phy *phy); - #include <linux/bitops.h> #endif /* USB_EHCI_H */
Entire series
Hi Marek
Entire series
Just a gentle reminder as you have reviewed this series, but it has not been merged into next branch.
Thanks Patrice
On 10/4/22 08:43, Patrice CHOTARD wrote:
Hi Marek
Entire series
Applied to usb/master, thanks.
Patrice CHOTARD
Patrice Chotard
