[U-Boot] Fw: FDT pointer value, passed by the PI firmware, is not set in u-boot
I modified the current u-boot code to store r2 in rpi.c board_init, but only get a zero value from the register.
It could be one of three issues: 1. My use of the c asm statement to store r2 is wrong (I've never done this before), assembler yes, c assembler no. 2. The compiler has consumed the value of r2 before getting to board_init 3. The pi firmware does not put the fdt value in r2.
asm statement to store r2 is asm("mov %%r2, %0" : "=r" (gd->bd->bpi_boot_parms) );
In order to use up Marco's ATAG and FDT code.
What the earliest place where I can store the input r2 value? Hopefully, I'm putting the r2 value into gd->bd->bpi_boot_parms in board_init, but it appear it is zero at that point.
Should I restrict the compiler's use of r2? (I'm reluctant to limit the compiler in that manner)?
Suggestion would be welcome.
Thanks Duncan Hare
714 931 7952
- My use of the c asm statement to store r2 is wrong (I've never done this before), assembler yes, c assembler no.
- The compiler has consumed the value of r2 before getting to board_init
- The pi firmware does not put the fdt value in r2.
You could try save_boot_params(). Some boards use that. But gd is not available then - perhaps you could put it in a variable in the data segment?
Thanks Duncan Hare
714 931 7952
dh@synoia.com
