[U-Boot-Users] [PATCH] Improve configuration of FPGA subsystem
This patch removes the FPGA subsystem configuration through the CONFIG_FPGA bitmask configuration option.
See README for the new options:
CONFIG_FPGA, CONFIG_FPGA_<vendor>, CONFIG_FPGA_<family>
Signed-off-by: Matthias Fuchs matthias.fuchs@esd-electronics.com --- README | 19 ++++++++++++++----- board/gen860t/fpga.c | 2 +- board/gen860t/gen860t.c | 2 +- common/ACEX1K.c | 4 ++-- common/altera.c | 18 +++++++++--------- common/cmd_fpga.c | 2 +- common/cyclon2.c | 4 ++-- common/fpga.c | 30 +++++++++++------------------- common/spartan2.c | 2 +- common/spartan3.c | 2 +- common/virtex2.c | 2 +- common/xilinx.c | 28 ++++++++++++++-------------- include/configs/GEN860T.h | 4 +++- include/configs/M54455EVB.h | 4 +++- include/configs/alpr.h | 4 +++- include/xilinx.h | 4 ++-- 16 files changed, 69 insertions(+), 62 deletions(-)
diff --git a/README b/README index 3dad5fc..a33ced7 100644 --- a/README +++ b/README @@ -1379,14 +1379,23 @@ The following options need to be configured: SPI configuration items (port pins to use, etc). For an example, see include/configs/sacsng.h.
-- FPGA Support: CONFIG_FPGA_COUNT +- FPGA Support: CONFIG_FPGA
- Specify the number of FPGA devices to support. + Enables FPGA subsystem. + + CONFIG_FPGA_<vendor> + + Enables support for specific chip vendors. + (ALTERA, XILINX)
- CONFIG_FPGA + CONFIG_FPGA_<family>
- Used to specify the types of FPGA devices. For example, - #define CONFIG_FPGA CFG_XILINX_VIRTEX2 + Enables support for FPGA family. + (SPARTAN2, SPARTAN3, VIRTEX2, CYCLONE2, ACEX1K, ACEX) + + CONFIG_FPGA_COUNT + + Specify the number of FPGA devices to support.
CFG_FPGA_PROG_FEEDBACK
diff --git a/board/gen860t/fpga.c b/board/gen860t/fpga.c index 2ba7e0e..3816e52 100644 --- a/board/gen860t/fpga.c +++ b/board/gen860t/fpga.c @@ -34,7 +34,7 @@
DECLARE_GLOBAL_DATA_PTR;
-#if (CONFIG_FPGA) +#if defined(CONFIG_FPGA)
#if 0 #define GEN860T_FPGA_DEBUG diff --git a/board/gen860t/gen860t.c b/board/gen860t/gen860t.c index d448f9f..73cc16d 100644 --- a/board/gen860t/gen860t.c +++ b/board/gen860t/gen860t.c @@ -254,7 +254,7 @@ int misc_init_r (void) mii_init (); #endif
-#if (CONFIG_FPGA) +#if defined(CONFIG_FPGA) gen860t_init_fpga (); #endif return 0; diff --git a/common/ACEX1K.c b/common/ACEX1K.c index 2a421e2..76dc166 100644 --- a/common/ACEX1K.c +++ b/common/ACEX1K.c @@ -28,7 +28,7 @@ #include <common.h> /* core U-Boot definitions */ #include <ACEX1K.h> /* ACEX device family */
-#if (CONFIG_FPGA & (CFG_ALTERA | CFG_ACEX1K)) +#if defined(CONFIG_FPGA) && defined(CONFIG_FPGA_ALTERA) && defined(CONFIG_FPGA_ACEX1K)
/* Define FPGA_DEBUG to get debug printf's */ #ifdef FPGA_DEBUG @@ -363,4 +363,4 @@ static int ACEX1K_ps_reloc (Altera_desc * desc, ulong reloc_offset)
-#endif /* (CONFIG_FPGA & (CFG_ALTERA | CFG_ACEX1K)) */ +#endif /* CONFIG_FPGA && CONFIG_FPGA_ALTERA && CONFIG_FPGA_ACEX1K */ diff --git a/common/altera.c b/common/altera.c index 06e8a95..0df7bae 100644 --- a/common/altera.c +++ b/common/altera.c @@ -40,7 +40,7 @@ #define PRINTF(fmt,args...) #endif
-#if (CONFIG_FPGA & CFG_FPGA_ALTERA) +#if defined(CONFIG_FPGA) && defined(CONFIG_FPGA_ALTERA)
/* Local Static Functions */ static int altera_validate (Altera_desc * desc, char *fn); @@ -56,11 +56,11 @@ int altera_load( Altera_desc *desc, void *buf, size_t bsize ) switch (desc->family) { case Altera_ACEX1K: case Altera_CYC2: -#if (CONFIG_FPGA & CFG_ACEX1K) +#if defined(CONFIG_FPGA_ACEX1K) PRINTF ("%s: Launching the ACEX1K Loader...\n", __FUNCTION__); ret_val = ACEX1K_load (desc, buf, bsize); -#elif (CONFIG_FPGA & CFG_CYCLON2) +#elif defined CONFIG_FPGA_CYCLON2 PRINTF ("%s: Launching the CYCLON II Loader...\n", __FUNCTION__); ret_val = CYC2_load (desc, buf, bsize); @@ -88,7 +88,7 @@ int altera_dump( Altera_desc *desc, void *buf, size_t bsize ) } else { switch (desc->family) { case Altera_ACEX1K: -#if (CONFIG_FPGA & CFG_ACEX) +#if defined(CONFIG_FPGA_ACEX) PRINTF ("%s: Launching the ACEX1K Reader...\n", __FUNCTION__); ret_val = ACEX1K_dump (desc, buf, bsize); @@ -156,9 +156,9 @@ int altera_info( Altera_desc *desc ) switch (desc->family) { case Altera_ACEX1K: case Altera_CYC2: -#if (CONFIG_FPGA & CFG_ACEX1K) +#if defined(CONFIG_FPGA_ACEX1K) ACEX1K_info (desc); -#elif (CONFIG_FPGA & CFG_CYCLON2) +#elif defined(CONFIG_FPGA_CYCLON2) CYC2_info (desc); #else /* just in case */ @@ -192,7 +192,7 @@ int altera_reloc( Altera_desc *desc, ulong reloc_offset) } else { switch (desc->family) { case Altera_ACEX1K: -#if (CONFIG_FPGA & CFG_ACEX1K) +#if defined(CONFIG_FPGA_ACEX1K) ret_val = ACEX1K_reloc (desc, reloc_offset); #else printf ("%s: No support for ACEX devices.\n", @@ -200,7 +200,7 @@ int altera_reloc( Altera_desc *desc, ulong reloc_offset) #endif break; case Altera_CYC2: -#if (CONFIG_FPGA & CFG_CYCLON2) +#if defined(CONFIG_FPGA_CYCLON2) ret_val = CYC2_reloc (desc, reloc_offset); #else printf ("%s: No support for CYCLON II devices.\n", @@ -249,4 +249,4 @@ static int altera_validate (Altera_desc * desc, char *fn)
-#endif /* CONFIG_FPGA & CFG_FPGA_ALTERA */ +#endif /* CONFIG_FPGA & CONFIG_FPGA_ALTERA */ diff --git a/common/cmd_fpga.c b/common/cmd_fpga.c index cce23ad..3affeba 100644 --- a/common/cmd_fpga.c +++ b/common/cmd_fpga.c @@ -60,7 +60,7 @@ static int fpga_get_op (char *opstr); /* Convert bitstream data and load into the fpga */ int fpga_loadbitstream(unsigned long dev, char* fpgadata, size_t size) { -#if (CONFIG_FPGA & CFG_FPGA_XILINX) +#if defined(CONFIG_FPGA_XILINX) unsigned int length; unsigned char* swapdata; unsigned int swapsize; diff --git a/common/cyclon2.c b/common/cyclon2.c index dce13b5..06f5e8a 100644 --- a/common/cyclon2.c +++ b/common/cyclon2.c @@ -27,7 +27,7 @@ #include <altera.h> #include <ACEX1K.h> /* ACEX device family */
-#if (CONFIG_FPGA & (CFG_ALTERA | CFG_CYCLON2)) +#if defined(CONFIG_FPGA) && defined(CONFIG_FPGA_ALTERA) && defined(CONFIG_FPGA_CYCLON2)
/* Define FPGA_DEBUG to get debug printf's */ #ifdef FPGA_DEBUG @@ -302,4 +302,4 @@ static int CYC2_ps_reloc (Altera_desc * desc, ulong reloc_offset) return ret_val; }
-#endif /* (CONFIG_FPGA & (CFG_ALTERA | CFG_CYCLON2)) */ +#endif /* CONFIG_FPGA && CONFIG_FPGA_ALTERA && CONFIG_FPGA_CYCLON2 */ diff --git a/common/fpga.c b/common/fpga.c index 2eff239..d8b6ae3 100644 --- a/common/fpga.c +++ b/common/fpga.c @@ -67,14 +67,11 @@ static int fpga_dev_info( int devnum ); static void fpga_no_sup( char *fn, char *msg ) { if ( fn && msg ) { - printf( "%s: No support for %s. CONFIG_FPGA defined as 0x%x.\n", - fn, msg, CONFIG_FPGA ); + printf( "%s: No support for %s.\n", fn, msg); } else if ( msg ) { - printf( "No support for %s. CONFIG_FPGA defined as 0x%x.\n", - msg, CONFIG_FPGA ); + printf( "No support for %s.\n", msg); } else { - printf( "No FPGA suport! CONFIG_FPGA defined as 0x%x.\n", - CONFIG_FPGA ); + printf( "No FPGA suport!\n"); } }
@@ -112,11 +109,6 @@ static __attribute__((__const__)) fpga_desc * __attribute__((__const__)) fpga_va printf( "%s: Null buffer.\n", fn ); return (fpga_desc * const)NULL; } - if ( !bsize ) { - printf( "%s: Null buffer size.\n", fn ); - return (fpga_desc * const)NULL; - } - return desc; }
@@ -135,7 +127,7 @@ static int fpga_dev_info( int devnum )
switch ( desc->devtype ) { case fpga_xilinx: -#if CONFIG_FPGA & CFG_FPGA_XILINX +#if defined(CONFIG_FPGA_XILINX) printf( "Xilinx Device\nDescriptor @ 0x%p\n", desc ); ret_val = xilinx_info( desc->devdesc ); #else @@ -143,7 +135,7 @@ static int fpga_dev_info( int devnum ) #endif break; case fpga_altera: -#if CONFIG_FPGA & CFG_FPGA_ALTERA +#if defined(CONFIG_FPGA_ALTERA) printf( "Altera Device\nDescriptor @ 0x%p\n", desc ); ret_val = altera_info( desc->devdesc ); #else @@ -175,14 +167,14 @@ int fpga_reloc( fpga_type devtype, void *desc, ulong reloc_off )
switch ( devtype ) { case fpga_xilinx: -#if CONFIG_FPGA & CFG_FPGA_XILINX +#if defined(CONFIG_FPGA_XILINX) ret_val = xilinx_reloc( desc, reloc_off ); #else fpga_no_sup( (char *)__FUNCTION__, "Xilinx devices" ); #endif break; case fpga_altera: -#if CONFIG_FPGA & CFG_FPGA_ALTERA +#if defined(CONFIG_FPGA_ALTERA) ret_val = altera_reloc( desc, reloc_off ); #else fpga_no_sup( (char *)__FUNCTION__, "Altera devices" ); @@ -268,14 +260,14 @@ int fpga_load( int devnum, void *buf, size_t bsize ) if ( desc ) { switch ( desc->devtype ) { case fpga_xilinx: -#if CONFIG_FPGA & CFG_FPGA_XILINX +#if defined(CONFIG_FPGA_XILINX) ret_val = xilinx_load( desc->devdesc, buf, bsize ); #else fpga_no_sup( (char *)__FUNCTION__, "Xilinx devices" ); #endif break; case fpga_altera: -#if CONFIG_FPGA & CFG_FPGA_ALTERA +#if defined(CONFIG_FPGA_ALTERA) ret_val = altera_load( desc->devdesc, buf, bsize ); #else fpga_no_sup( (char *)__FUNCTION__, "Altera devices" ); @@ -301,14 +293,14 @@ int fpga_dump( int devnum, void *buf, size_t bsize ) if ( desc ) { switch ( desc->devtype ) { case fpga_xilinx: -#if CONFIG_FPGA & CFG_FPGA_XILINX +#if defined(CONFIG_FPGA_XILINX) ret_val = xilinx_dump( desc->devdesc, buf, bsize ); #else fpga_no_sup( (char *)__FUNCTION__, "Xilinx devices" ); #endif break; case fpga_altera: -#if CONFIG_FPGA & CFG_FPGA_ALTERA +#if defined(CONFIG_FPGA_ALTERA) ret_val = altera_dump( desc->devdesc, buf, bsize ); #else fpga_no_sup( (char *)__FUNCTION__, "Altera devices" ); diff --git a/common/spartan2.c b/common/spartan2.c index 0fb23b6..0181c35 100644 --- a/common/spartan2.c +++ b/common/spartan2.c @@ -25,7 +25,7 @@ #include <common.h> /* core U-Boot definitions */ #include <spartan2.h> /* Spartan-II device family */
-#if (CONFIG_FPGA & (CFG_XILINX | CFG_SPARTAN2)) +#if defined(CONFIG_FPGA) && defined(CONFIG_FPGA_SPARTAN2)
/* Define FPGA_DEBUG to get debug printf's */ #ifdef FPGA_DEBUG diff --git a/common/spartan3.c b/common/spartan3.c index c0f2b05..4bf76a0 100644 --- a/common/spartan3.c +++ b/common/spartan3.c @@ -30,7 +30,7 @@ #include <common.h> /* core U-Boot definitions */ #include <spartan3.h> /* Spartan-II device family */
-#if (CONFIG_FPGA & (CFG_XILINX | CFG_SPARTAN3)) +#if defined(CONFIG_FPGA) && defined(CONFIG_FPGA_SPARTAN3)
/* Define FPGA_DEBUG to get debug printf's */ #ifdef FPGA_DEBUG diff --git a/common/virtex2.c b/common/virtex2.c index b5dc366..1283ff6 100644 --- a/common/virtex2.c +++ b/common/virtex2.c @@ -31,7 +31,7 @@ #include <common.h> #include <virtex2.h>
-#if (CONFIG_FPGA & (CFG_XILINX | CFG_VIRTEX2)) +#if defined(CONFIG_FPGA) && defined(CONFIG_FPGA_VIRTEX2)
#if 0 #define FPGA_DEBUG diff --git a/common/xilinx.c b/common/xilinx.c index e03e78c..c898238 100644 --- a/common/xilinx.c +++ b/common/xilinx.c @@ -32,7 +32,7 @@ #include <spartan2.h> #include <spartan3.h>
-#if (CONFIG_FPGA & CFG_FPGA_XILINX) +#if defined(CONFIG_FPGA) && defined(CONFIG_FPGA_XILINX)
#if 0 #define FPGA_DEBUG @@ -59,7 +59,7 @@ int xilinx_load (Xilinx_desc * desc, void *buf, size_t bsize) } else switch (desc->family) { case Xilinx_Spartan2: -#if (CONFIG_FPGA & CFG_SPARTAN2) +#if defined(CONFIG_FPGA_SPARTAN2) PRINTF ("%s: Launching the Spartan-II Loader...\n", __FUNCTION__); ret_val = Spartan2_load (desc, buf, bsize); @@ -69,7 +69,7 @@ int xilinx_load (Xilinx_desc * desc, void *buf, size_t bsize) #endif break; case Xilinx_Spartan3: -#if (CONFIG_FPGA & CFG_SPARTAN3) +#if defined(CONFIG_FPGA_SPARTAN3) PRINTF ("%s: Launching the Spartan-III Loader...\n", __FUNCTION__); ret_val = Spartan3_load (desc, buf, bsize); @@ -79,7 +79,7 @@ int xilinx_load (Xilinx_desc * desc, void *buf, size_t bsize) #endif break; case Xilinx_Virtex2: -#if (CONFIG_FPGA & CFG_VIRTEX2) +#if defined(CONFIG_FPGA_VIRTEX2) PRINTF ("%s: Launching the Virtex-II Loader...\n", __FUNCTION__); ret_val = Virtex2_load (desc, buf, bsize); @@ -106,7 +106,7 @@ int xilinx_dump (Xilinx_desc * desc, void *buf, size_t bsize) } else switch (desc->family) { case Xilinx_Spartan2: -#if (CONFIG_FPGA & CFG_SPARTAN2) +#if defined(CONFIG_FPGA_SPARTAN2) PRINTF ("%s: Launching the Spartan-II Reader...\n", __FUNCTION__); ret_val = Spartan2_dump (desc, buf, bsize); @@ -116,7 +116,7 @@ int xilinx_dump (Xilinx_desc * desc, void *buf, size_t bsize) #endif break; case Xilinx_Spartan3: -#if (CONFIG_FPGA & CFG_SPARTAN3) +#if defined(CONFIG_FPGA_SPARTAN3) PRINTF ("%s: Launching the Spartan-III Reader...\n", __FUNCTION__); ret_val = Spartan3_dump (desc, buf, bsize); @@ -126,7 +126,7 @@ int xilinx_dump (Xilinx_desc * desc, void *buf, size_t bsize) #endif break; case Xilinx_Virtex2: -#if (CONFIG_FPGA & CFG_VIRTEX2) +#if defined( CONFIG_FPGA_VIRTEX2) PRINTF ("%s: Launching the Virtex-II Reader...\n", __FUNCTION__); ret_val = Virtex2_dump (desc, buf, bsize); @@ -198,7 +198,7 @@ int xilinx_info (Xilinx_desc * desc) printf ("Device Function Table @ 0x%p\n", desc->iface_fns); switch (desc->family) { case Xilinx_Spartan2: -#if (CONFIG_FPGA & CFG_SPARTAN2) +#if defined(CONFIG_FPGA_SPARTAN2) Spartan2_info (desc); #else /* just in case */ @@ -207,7 +207,7 @@ int xilinx_info (Xilinx_desc * desc) #endif break; case Xilinx_Spartan3: -#if (CONFIG_FPGA & CFG_SPARTAN3) +#if defined(CONFIG_FPGA_SPARTAN3) Spartan3_info (desc); #else /* just in case */ @@ -216,7 +216,7 @@ int xilinx_info (Xilinx_desc * desc) #endif break; case Xilinx_Virtex2: -#if (CONFIG_FPGA & CFG_VIRTEX2) +#if defined(CONFIG_FPGA_VIRTEX2) Virtex2_info (desc); #else /* just in case */ @@ -249,7 +249,7 @@ int xilinx_reloc (Xilinx_desc * desc, ulong reloc_offset) } else switch (desc->family) { case Xilinx_Spartan2: -#if (CONFIG_FPGA & CFG_SPARTAN2) +#if defined(CONFIG_FPGA_SPARTAN2) ret_val = Spartan2_reloc (desc, reloc_offset); #else printf ("%s: No support for Spartan-II devices.\n", @@ -257,7 +257,7 @@ int xilinx_reloc (Xilinx_desc * desc, ulong reloc_offset) #endif break; case Xilinx_Spartan3: -#if (CONFIG_FPGA & CFG_SPARTAN3) +#if defined(CONFIG_FPGA_SPARTAN3) ret_val = Spartan3_reloc (desc, reloc_offset); #else printf ("%s: No support for Spartan-III devices.\n", @@ -265,7 +265,7 @@ int xilinx_reloc (Xilinx_desc * desc, ulong reloc_offset) #endif break; case Xilinx_Virtex2: -#if (CONFIG_FPGA & CFG_VIRTEX2) +#if defined(CONFIG_FPGA_VIRTEX2) ret_val = Virtex2_reloc (desc, reloc_offset); #else printf ("%s: No support for Virtex-II devices.\n", @@ -308,4 +308,4 @@ static int xilinx_validate (Xilinx_desc * desc, char *fn) return ret_val; }
-#endif /* CONFIG_FPGA & CFG_FPGA_XILINX */ +#endif /* CONFIG_FPGA && CONFIG_FPGA_XILINX */ diff --git a/include/configs/GEN860T.h b/include/configs/GEN860T.h index bfbf3a8..3eb3131 100644 --- a/include/configs/GEN860T.h +++ b/include/configs/GEN860T.h @@ -273,7 +273,9 @@ * Virtex2 FPGA configuration support */ #define CONFIG_FPGA_COUNT 1 -#define CONFIG_FPGA CFG_XILINX_VIRTEX2 +#define CONFIG_FPGA +#define CONFIG_FPGA_XILINX +#define CONFIG_FPGA_VIRTEX2 #define CFG_FPGA_PROG_FEEDBACK
diff --git a/include/configs/M54455EVB.h b/include/configs/M54455EVB.h index db30958..35637f9 100644 --- a/include/configs/M54455EVB.h +++ b/include/configs/M54455EVB.h @@ -192,7 +192,9 @@
/* FPGA - Spartan 2 */ /* experiment -#define CONFIG_FPGA CFG_SPARTAN3 +#define CONFIG_FPGA +#define CONFIG_FPGA_XILINX +#define CONFIG_FPGA_SPARTAN3 #define CONFIG_FPGA_COUNT 1 #define CFG_FPGA_PROG_FEEDBACK #define CFG_FPGA_CHECK_CTRLC diff --git a/include/configs/alpr.h b/include/configs/alpr.h index d88c3ad..324537b 100644 --- a/include/configs/alpr.h +++ b/include/configs/alpr.h @@ -296,7 +296,9 @@ /*----------------------------------------------------------------------- * FPGA stuff *-----------------------------------------------------------------------*/ -#define CONFIG_FPGA CFG_ALTERA_CYCLON2 +#define CONFIG_FPGA +#define CONFIG_FPGA_ALTERA +#define CONFIG_FPGA_CYCLON2 #define CFG_FPGA_CHECK_CTRLC #define CFG_FPGA_PROG_FEEDBACK #define CONFIG_FPGA_COUNT 1 /* Ich habe 2 ... aber in diff --git a/include/xilinx.h b/include/xilinx.h index 3704e1d..95ebe3d 100644 --- a/include/xilinx.h +++ b/include/xilinx.h @@ -31,11 +31,11 @@ *********************************************************************/ #define CFG_SPARTAN2 CFG_FPGA_DEV( 0x1 ) #define CFG_VIRTEX_E CFG_FPGA_DEV( 0x2 ) -#define CFG_VIRTEX2 CFG_FPGA_DEV( 0x4 ) +#define CFG_VIRTEX2 CFG_FPGA_DEV( 0x4 ) #define CFG_SPARTAN3 CFG_FPGA_DEV( 0x8 ) #define CFG_XILINX_SPARTAN2 (CFG_FPGA_XILINX | CFG_SPARTAN2) #define CFG_XILINX_VIRTEX_E (CFG_FPGA_XILINX | CFG_VIRTEX_E) -#define CFG_XILINX_VIRTEX2 (CFG_FPGA_XILINX | CFG_VIRTEX2) +#define CFG_XILINX_VIRTEX2 (CFG_FPGA_XILINX | CFG_VIRTEX2) #define CFG_XILINX_SPARTAN3 (CFG_FPGA_XILINX | CFG_SPARTAN3) /* XXX - Add new models here */
This patch adds a post configuration callback for Spartan2/3 FPGAs. pre and post configuration callback are now optional and not called when the function pointer is set to NULL.
Signed-off-by: Matthias Fuchs matthias.fuchs@esd-electronics.com --- common/spartan2.c | 18 ++++++++++++++++-- common/spartan3.c | 18 ++++++++++++++++-- include/spartan2.h | 1 + include/spartan3.h | 1 + 4 files changed, 34 insertions(+), 4 deletions(-)
diff --git a/common/spartan2.c b/common/spartan2.c index 0181c35..724ad0d 100644 --- a/common/spartan2.c +++ b/common/spartan2.c @@ -561,6 +561,13 @@ static int Spartan2_ss_load (Xilinx_desc * desc, void *buf, size_t bsize) } putc ('\n'); /* terminate the dotted line */
+ /* + * Run the post configuration function if there is one. + */ + if (*fn->post) { + (*fn->post) (cookie); + } + #ifdef CFG_FPGA_PROG_FEEDBACK if (ret_val == FPGA_SUCCESS) { puts ("Done.\n"); @@ -615,8 +622,10 @@ static int Spartan2_ss_reloc (Xilinx_desc * desc, ulong reloc_offset) PRINTF ("%s: Relocating descriptor at 0x%p\n", __FUNCTION__, desc);
- addr = (ulong) (fn->pre) + reloc_offset; - fn_r->pre = (Xilinx_pre_fn) addr; + if (fn->pre) { + addr = (ulong) (fn->pre) + reloc_offset; + fn_r->pre = (Xilinx_pre_fn) addr; + }
addr = (ulong) (fn->pgm) + reloc_offset; fn_r->pgm = (Xilinx_pgm_fn) addr; @@ -633,6 +642,11 @@ static int Spartan2_ss_reloc (Xilinx_desc * desc, ulong reloc_offset) addr = (ulong) (fn->wr) + reloc_offset; fn_r->wr = (Xilinx_wr_fn) addr;
+ if (fn->post) { + addr = (ulong) (fn->post) + reloc_offset; + fn_r->post = (Xilinx_post_fn) addr; + } + fn_r->relocated = TRUE;
} else { diff --git a/common/spartan3.c b/common/spartan3.c index 4bf76a0..20edc0c 100644 --- a/common/spartan3.c +++ b/common/spartan3.c @@ -566,6 +566,13 @@ static int Spartan3_ss_load (Xilinx_desc * desc, void *buf, size_t bsize) } putc ('\n'); /* terminate the dotted line */
+ /* + * Run the post configuration function if there is one. + */ + if (*fn->post) { + (*fn->post) (cookie); + } + #ifdef CFG_FPGA_PROG_FEEDBACK if (ret_val == FPGA_SUCCESS) { puts ("Done.\n"); @@ -620,8 +627,10 @@ static int Spartan3_ss_reloc (Xilinx_desc * desc, ulong reloc_offset) PRINTF ("%s: Relocating descriptor at 0x%p\n", __FUNCTION__, desc);
addr = (ulong) (fn->pgm) + reloc_offset; fn_r->pgm = (Xilinx_pgm_fn) addr; @@ -638,6 +647,11 @@ static int Spartan3_ss_reloc (Xilinx_desc * desc, ulong reloc_offset) addr = (ulong) (fn->wr) + reloc_offset; fn_r->wr = (Xilinx_wr_fn) addr;
} else { diff --git a/include/spartan2.h b/include/spartan2.h index d2e81e3..f3cde68 100644 --- a/include/spartan2.h +++ b/include/spartan2.h @@ -58,6 +58,7 @@ typedef struct { Xilinx_init_fn init; Xilinx_done_fn done; Xilinx_wr_fn wr; + Xilinx_post_fn post; int relocated; } Xilinx_Spartan2_Slave_Serial_fns;
diff --git a/include/spartan3.h b/include/spartan3.h index 65a3f5a..529aade 100644 --- a/include/spartan3.h +++ b/include/spartan3.h @@ -58,6 +58,7 @@ typedef struct { Xilinx_init_fn init; Xilinx_done_fn done; Xilinx_wr_fn wr; + Xilinx_post_fn post; int relocated; } Xilinx_Spartan3_Slave_Serial_fns;
Signed-off-by: Matthias Fuchs matthias.fuchs@esd-electronics.com --- include/spartan2.h | 4 ++++ include/spartan3.h | 10 +++++++++- 2 files changed, 13 insertions(+), 1 deletions(-)
diff --git a/include/spartan2.h b/include/spartan2.h index f3cde68..bd159e1 100644 --- a/include/spartan2.h +++ b/include/spartan2.h @@ -70,6 +70,7 @@ typedef struct { #define XILINX_XC2S50_SIZE 559232/8 #define XILINX_XC2S100_SIZE 781248/8 #define XILINX_XC2S150_SIZE 1040128/8 +#define XILINX_XC2S200_SIZE 1335872/8
/* Spartan-IIE (1.8V) */ #define XILINX_XC2S50E_SIZE 630048/8 @@ -96,6 +97,9 @@ typedef struct { #define XILINX_XC2S150_DESC(iface, fn_table, cookie) \ { Xilinx_Spartan2, iface, XILINX_XC2S150_SIZE, fn_table, cookie }
+#define XILINX_XC2S200_DESC(iface, fn_table, cookie) \ +{ Xilinx_Spartan2, iface, XILINX_XC2S200_SIZE, fn_table, cookie } + #define XILINX_XC2S50E_DESC(iface, fn_table, cookie) \ { Xilinx_Spartan2, iface, XILINX_XC2S50E_SIZE, fn_table, cookie }
diff --git a/include/spartan3.h b/include/spartan3.h index 529aade..c203eeb 100644 --- a/include/spartan3.h +++ b/include/spartan3.h @@ -81,9 +81,12 @@ typedef struct { #define XILINX_XC3S1200E_SIZE 3841184/8 #define XILINX_XC3S1600E_SIZE 5969696/8
+/* Spartan-IIIE (1.2V) */ +#define XILINX_XC3S1200E_SIZE 3841184/8 + /* Descriptor Macros *********************************************************************/ -/* Spartan-II devices */ +/* Spartan-III devices */ #define XILINX_XC3S50_DESC(iface, fn_table, cookie) \ { Xilinx_Spartan3, iface, XILINX_XC3S50_SIZE, fn_table, cookie }
@@ -125,4 +128,9 @@ typedef struct { #define XILINX_XC3S1600E_DESC(iface, fn_table, cookie) \ { Xilinx_Spartan3, iface, XILINX_XC3S1600E_SIZE, fn_table, cookie }
+ +/* Spartan-IIIE devices */ +#define XILINX_XC3S1200E_DESC(iface, fn_table, cookie) \ +{ Xilinx_Spartan3, iface, XILINX_XC3S1200E_SIZE, fn_table, cookie } + #endif /* _SPARTAN3_H_ */
Signed-off-by: Matthias Fuchs matthias.fuchs@esd-electronics.com --- common/spartan2.c | 4 ++-- common/spartan3.c | 4 ++-- 2 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/common/spartan2.c b/common/spartan2.c index 724ad0d..2f1ea2c 100644 --- a/common/spartan2.c +++ b/common/spartan2.c @@ -441,7 +441,7 @@ static int Spartan2_ss_load (Xilinx_desc * desc, void *buf, size_t bsize) int ret_val = FPGA_FAIL; /* assume the worst */ Xilinx_Spartan2_Slave_Serial_fns *fn = desc->iface_fns; int i; - char val; + unsigned char val;
PRINTF ("%s: start with interface functions @ 0x%p\n", __FUNCTION__, fn); @@ -516,7 +516,7 @@ static int Spartan2_ss_load (Xilinx_desc * desc, void *buf, size_t bsize) (*fn->clk) (FALSE, TRUE, cookie); CONFIG_FPGA_DELAY (); /* Write data */ - (*fn->wr) ((val < 0), TRUE, cookie); + (*fn->wr) ((val & 0x80), TRUE, cookie); CONFIG_FPGA_DELAY (); /* Assert the clock */ (*fn->clk) (TRUE, TRUE, cookie); diff --git a/common/spartan3.c b/common/spartan3.c index 20edc0c..d329e70 100644 --- a/common/spartan3.c +++ b/common/spartan3.c @@ -446,7 +446,7 @@ static int Spartan3_ss_load (Xilinx_desc * desc, void *buf, size_t bsize) int ret_val = FPGA_FAIL; /* assume the worst */ Xilinx_Spartan3_Slave_Serial_fns *fn = desc->iface_fns; int i; - char val; + unsigned char val;
PRINTF ("%s: start with interface functions @ 0x%p\n", __FUNCTION__, fn); @@ -521,7 +521,7 @@ static int Spartan3_ss_load (Xilinx_desc * desc, void *buf, size_t bsize) (*fn->clk) (FALSE, TRUE, cookie); CONFIG_FPGA_DELAY (); /* Write data */ - (*fn->wr) ((val < 0), TRUE, cookie); + (*fn->wr) ((val & 0x80), TRUE, cookie); CONFIG_FPGA_DELAY (); /* Assert the clock */ (*fn->clk) (TRUE, TRUE, cookie);
This patch removes the unnecessary bit swapping when booting .bit files with the 'fpga loadb' command.
Signed-off-by: Matthias Fuchs matthias.fuchs@esd-electronics.com --- common/cmd_fpga.c | 37 +------------------------------------ 1 files changed, 1 insertions(+), 36 deletions(-)
diff --git a/common/cmd_fpga.c b/common/cmd_fpga.c index 3affeba..6ede031 100644 --- a/common/cmd_fpga.c +++ b/common/cmd_fpga.c @@ -62,12 +62,9 @@ int fpga_loadbitstream(unsigned long dev, char* fpgadata, size_t size) { #if defined(CONFIG_FPGA_XILINX) unsigned int length; - unsigned char* swapdata; unsigned int swapsize; char buffer[80]; - unsigned char *ptr; unsigned char *dataptr; - unsigned char data; unsigned int i; int rc;
@@ -145,39 +142,7 @@ int fpga_loadbitstream(unsigned long dev, char* fpgadata, size_t size) dataptr+=4; printf(" bytes in bitstream = %d\n", swapsize);
- /* check consistency of length obtained */ - if (swapsize >= size) { - printf("%s: Could not find right length of data in bitstream\n", - __FUNCTION__); - return FPGA_FAIL; - } - - /* allocate memory */ - swapdata = (unsigned char *)malloc(swapsize); - if (swapdata == NULL) { - printf("%s: Could not allocate %d bytes memory !\n", - __FUNCTION__, swapsize); - return FPGA_FAIL; - } - - /* read data into memory and swap bits */ - ptr = swapdata; - for (i = 0; i < swapsize; i++) { - data = 0x00; - data |= (*dataptr & 0x01) << 7; - data |= (*dataptr & 0x02) << 5; - data |= (*dataptr & 0x04) << 3; - data |= (*dataptr & 0x08) << 1; - data |= (*dataptr & 0x10) >> 1; - data |= (*dataptr & 0x20) >> 3; - data |= (*dataptr & 0x40) >> 5; - data |= (*dataptr & 0x80) >> 7; - *ptr++ = data; - dataptr++; - } - - rc = fpga_load(dev, swapdata, swapsize); - free(swapdata); + rc = fpga_load(dev, dataptr, swapsize); return rc; #else printf("Bitstream support only for Xilinx devices\n");
Matthias Fuchs
