[U-Boot] Please pull u-boot-fsl-qoriq master
Tom,
The following changes since commit 6b3943f1b04be60f147ee540fbd72c4c7ea89f80:
siemens,am33x: add draco etamin board (2016-06-09 13:53:13 -0400)
git://git.denx.de/u-boot-fsl-qoriq.git master
for you to fetch changes up to a646f6698173ef4ff34c414f91541b4b8f014de1:
armv8: ls2080aqds: Enable QSPI boot support (2016-06-10 13:45:01 -0700)
---------------------------------------------------------------- Pratiyush Mohan Srivastava (1): board: ls2080a: Add "mcinitcmd" env for MC & DPL deployment
Yuan Yao (10): drivers: i2c: mxc: Add early init armv8: ls2080aqds: Select QSPI CLK div via SCFG configs: ls2080a_common: Remove duplicate NOR configs armv8: ls2080aqds: disable IFC NOR & QIXIS when QSPI enable configs: ls2080aqds: Enable QSPI flash support dts: ls2080aqds: Add QSPI dts node armv8: ls2080aqds: Config QSPI pin mux via FPGA in NAND boot configs: ls2080a: Increase load image len in NAND boot configs: ls2080aqds_nand_defconfig: Enable QSPI armv8: ls2080aqds: Enable QSPI boot support
Yunhui Cui (1): armv8/ls2080a: configure PMU's PCTBENR to enable WDT
arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 12 ++++++ arch/arm/cpu/armv8/fsl-layerscape/doc/README.lsch3 | 29 +++++++++++++ arch/arm/dts/fsl-ls2080a-qds.dts | 14 +++++++ arch/arm/dts/fsl-ls2080a.dtsi | 10 +++++ arch/arm/include/asm/arch-fsl-layerscape/cpu.h | 4 ++ .../include/asm/arch-fsl-layerscape/immap_lsch3.h | 4 ++ board/freescale/ls2080aqds/eth.c | 5 +++ board/freescale/ls2080aqds/ls2080aqds.c | 19 +++++++++ board/freescale/ls2080ardb/eth_ls2080rdb.c | 5 +++ configs/ls2080aqds_nand_defconfig | 9 ++++ configs/ls2080aqds_qspi_defconfig | 37 +++++++++++++++++ drivers/i2c/i2c_core.c | 5 +++ drivers/i2c/mxc_i2c.c | 27 ++++++++++++ include/configs/ls2080a_common.h | 11 ++--- include/configs/ls2080a_simu.h | 7 ++++ include/configs/ls2080aqds.h | 43 +++++++++++++++++++- include/i2c.h | 3 ++ 17 files changed, 234 insertions(+), 10 deletions(-) create mode 100644 configs/ls2080aqds_qspi_defconfig
Thanks.
York
On Fri, Jun 10, 2016 at 03:18:02PM -0700, York Sun wrote:
Tom,
York Sun
