[U-Boot-Users] Pull request: nand-flash
The following changes since commit c956717ab25c962ef49d49064dfc73f4edcba1fb: Wolfgang Denk (1): Merge branch 'master' of /home/wd/git/u-boot/custodians
git://www.denx.de/git/u-boot-nand-flash.git master
Marcel Ziswiler (1): NAND: Fix warning due to missing env_ptr casts to u_char * in env_nand.c.
Scott Wood (2): NAND: Rename DEBUG to MTDDEBUG to avoid namespace pollution. NAND: ifdef-protect most of nand.h when using legacy NAND.
common/env_nand.c | 8 ++-- cpu/arm926ejs/davinci/nand.c | 10 +++- drivers/mtd/nand/nand_base.c | 103 +++++++++++++++++++++++------------ drivers/mtd/nand/nand_bbt.c | 4 +- drivers/mtd/onenand/onenand_base.c | 95 +++++++++++++++++---------------- drivers/mtd/onenand/onenand_bbt.c | 6 +- include/linux/mtd/mtd.h | 4 +- include/nand.h | 5 ++- 8 files changed, 140 insertions(+), 95 deletions(-)
Applied, thanks.
Scott Wood
