[PATCH v1 1/1] tools: env: use /run to store lockfile
According this issue https://github.com/ppp-project/ppp/issues/339. Eventually, the dt-utils changed lock directory to fix missing /var/lock directory error then make dt-utils can run normally.
We also have a similar issue with these two utilities fw_printenv and fw_setenv will failed when the directory /var/lock is non-existent.
We have a custom linux distribution built with yocto (OpenBMC) that use systemd and it deprecated the /var/lock directory. More discussion in systemd/systemd#15668.
Thus, we sync with community's solution for uboot/tools/env utilities: The current location /var/lock is considered legacy (at least by systemd). Just use /run to store the lockfile and append the usual .lock suffix.
Tested: Verified /run/lock is now present and fw_printenv can work in OpenBMC.
Signed-off-by: Tim Lee timlee660101@gmail.com --- tools/env/fw_env_main.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/tools/env/fw_env_main.c b/tools/env/fw_env_main.c index 1d193bd437..0b201b9e62 100644 --- a/tools/env/fw_env_main.c +++ b/tools/env/fw_env_main.c @@ -73,7 +73,7 @@ void usage_printenv(void) " -c, --config configuration file, default:" CONFIG_FILE "\n" #endif " -n, --noheader do not repeat variable name in output\n" - " -l, --lock lock node, default:/var/lock\n" + " -l, --lock lock node, default:/run\n" "\n"); }
@@ -88,7 +88,7 @@ void usage_env_set(void) #ifdef CONFIG_FILE " -c, --config configuration file, default:" CONFIG_FILE "\n" #endif - " -l, --lock lock node, default:/var/lock\n" + " -l, --lock lock node, default:/run\n" " -s, --script batch mode to minimize writes\n" "\n" "Examples:\n" @@ -206,7 +206,7 @@ int parse_setenv_args(int argc, char *argv[])
int main(int argc, char *argv[]) { - char *lockname = "/var/lock/" CMD_PRINTENV ".lock"; + char *lockname = "/run/" CMD_PRINTENV ".lock"; int lockfd = -1; int retval = EXIT_SUCCESS; char *_cmdname;
Hi Tom,
Is this commit valuable to merge into u-boot upstream? Thanks your reviewing, just ping this event friendly.
Best regards, Tim
-----Original Message----- From: Tom Rini trini@konsulko.com Sent: Friday, February 10, 2023 11:30 PM To: Tim Lee timlee660101@gmail.com Cc: sjg@chromium.org; CS20 CHLi30 CHLI30@nuvoton.com; u-boot@lists.denx.de Subject: Re: [PATCH v1 1/1] tools: env: use /run to store lockfile
-- Tom ________________________________ ________________________________ The privileged confidential information contained in this email is intended for use only by the addressees as indicated by the original sender of this email. If you are not the addressee indicated in this email or are not responsible for delivery of the email to such a person, please kindly reply to the sender indicating this fact and delete all copies of it from your computer and network server immediately. Your cooperation is highly appreciated. It is advised that any unauthorized use of confidential information of Nuvoton is strictly prohibited; and any information in this email irrelevant to the official business of Nuvoton shall be deemed as neither given nor endorsed by Nuvoton.
On Thu, Feb 23, 2023 at 01:06:20AM +0000, CHLI30@nuvoton.com wrote:
Hi Tom,
Yes, I'll be putting this in next soon, thanks.
Best regards, Tim
Signed-off-by: Tim Lee timlee660101@gmail.com Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Tom Rini trini@konsulko.com
CHLI30@nuvoton.com
Tim Lee
