[PATCH] binman: bintool: Add support for tool directories
Currently, bintool supports external compilable tools as single executable files. Adding support for git repos that can be used to run non-compilable scripting tools that cannot otherwise be present in binman.
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- tools/binman/bintool.py | 42 ++++++++++++++++++++++++++++++++++------- tools/patman/tools.py | 2 ++ 2 files changed, 37 insertions(+), 7 deletions(-)
diff --git a/tools/binman/bintool.py b/tools/binman/bintool.py index 8fda13ff01..a1e37699aa 100644 --- a/tools/binman/bintool.py +++ b/tools/binman/bintool.py @@ -32,12 +32,13 @@ FORMAT = '%-16.16s %-12.12s %-26.26s %s' modules = {}
# Possible ways of fetching a tool (FETCH_COUNT is number of ways) -FETCH_ANY, FETCH_BIN, FETCH_BUILD, FETCH_COUNT = range(4) +FETCH_ANY, FETCH_BIN, FETCH_BUILD, FETCH_NO_BUILD, FETCH_COUNT = range(5)
FETCH_NAMES = { FETCH_ANY: 'any method', FETCH_BIN: 'binary download', - FETCH_BUILD: 'build from source' + FETCH_BUILD: 'build from source', + FETCH_NO_BUILD: 'download source without building' }
# Status of tool fetching @@ -206,7 +207,7 @@ class Bintool: result = try_fetch(method) if not result: return FAIL - if result is not True: + if result is not True and method != FETCH_NO_BUILD: fname, tmpdir = result dest = os.path.join(DOWNLOAD_DESTDIR, self.name) print(f"- writing to '{dest}'") @@ -261,7 +262,7 @@ class Bintool: show_status(col.RED, 'Failures', status[FAIL]) return not status[FAIL]
- def run_cmd_result(self, *args, binary=False, raise_on_error=True): + def run_cmd_result(self, *args, binary=False, raise_on_error=True, add_name=True): """Run the bintool using command-line arguments
Args: @@ -278,7 +279,10 @@ class Bintool: if self.name in self.missing_list: return None name = os.path.expanduser(self.name) # Expand paths containing ~ - all_args = (name,) + args + if add_name: + all_args = (name,) + args + else: + all_args = args env = tools.get_env_with_path() tout.detail(f"bintool: {' '.join(all_args)}") result = command.run_pipe( @@ -304,7 +308,7 @@ class Bintool: tout.debug(result.stderr) return result
- def run_cmd(self, *args, binary=False): + def run_cmd(self, *args, binary=False, add_name=True): """Run the bintool using command-line arguments
Args: @@ -315,7 +319,7 @@ class Bintool: Returns: str or bytes: Resulting stdout from the bintool """ - result = self.run_cmd_result(*args, binary=binary) + result = self.run_cmd_result(*args, binary=binary, add_name=add_name) if result: return result.stdout
@@ -354,6 +358,30 @@ class Bintool: return None return fname, tmpdir
+ @classmethod + def fetch_from_git(cls, git_repo): + """Fetch a bintool git repo + + This clones the repo and returns + + Args: + git_repo (str): URL of git repo + bintool_path (str): Relative path of the tool in the repo, after + build is complete + + Returns: + str: Directory of fetched repo + or None on error + """ + dir = os.path.join(DOWNLOAD_DESTDIR, cls.name) + os.mkdir(dir) + print(f"- clone git repo '{git_repo}' to '{dir}'") + tools.run('git', 'clone', '--depth', '1', git_repo, dir) + if not os.path.exists(dir): + print(f"- Repo '{dir}' was not produced") + return None + return dir + @classmethod def fetch_from_url(cls, url): """Fetch a bintool from a URL diff --git a/tools/patman/tools.py b/tools/patman/tools.py index 2ac814d476..b8533c72b2 100644 --- a/tools/patman/tools.py +++ b/tools/patman/tools.py @@ -399,6 +399,8 @@ def tool_find(name): fname = os.path.join(path, name) if os.path.isfile(fname) and os.access(fname, os.X_OK): return fname + if os.path.isdir(fname) and os.access(fname, os.X_OK): + return fname
def run(name, *args, **kwargs): """Run a tool with some arguments
This is another reason that the download mechanic really needs to move out of populating the users bin directory directly.
Hi Neha,
- FETCH_BUILD: 'build from source',
- FETCH_NO_BUILD: 'download source without building'
How about FETCH_SOURCE ?
Args:
if add_name:
else:
Args:
- @classmethod
- def fetch_from_git(cls, git_repo):
Args:
build is complete
Returns:
or None on error
os.mkdir(dir)
return None
return dir
- @classmethod def fetch_from_url(cls, url): """Fetch a bintool from a URL
return fname
How come the duplication?
def run(name, *args, **kwargs): """Run a tool with some arguments -- 2.34.1
Please can you add a test to bintool_test.py ?
Neha Malcom Francis
