[U-Boot] unable to see jffs2 partition
Hi all, I've been trying unsuccessfully to see my jffs2 partition I've created by the mtdtools under linux. If their a known issue with this? Is their a size limit? Maybe the way it's created? I do not have a problem with this partition from linux but also never looked at it from the u-boot. I can change partitions but "ls" shows partition is empty when their are files.
... #define CONFIG_CMD_JFFS2 1 /** JFFS2 Support */ #define CONFIG_CMD_MTDPARTS 1 #define CONFIG_JFFS2_CMDLINE 1 #undef CONFIG_CMD_FLASH #define CONFIG_JFFS2_NAND 1 #define CONFIG_JFFS2_DEV "nand0" #define CONFIG_JFFS2_PART_OFFSET 0x0 #define CONFIG_JFFS2_PART_SIZE 0x5000000 #define MTDPARTS_DEFAULT "mtdparts=nand:80M(IMGS),-(DATA)" #define MTDIDS_DEFAULT "nand0=nand" ...
Thanks, E!
Thanks, E!
Forget to add I'm using 03.09 git source on SAM9263 SoC.
E Robertson
