[U-Boot] Low BogoMIPS on MPC8541
Hi All,
I'm working on a stripped-down mpc8541 board (that has just a serian and twe enets). I have an issue on delay calibration. In fact at boot time, I see the following linux printk message on the serial console:
.... Calibrating delay loop... 83.20 BogoMIPS (lpj=166400) ....
This value seems to be too low and I suspect an error propagated from u-boot.
Can anyone help me to understand a good way to investigate this problem? which registers or configuration values I need to check?
I will post the necessary snips of code or configuration if required.
Thanks a lot for your help,
ciao
luigi
On Oct 27, 2009, at 10:29 AM, Luigi 'Comio' Mantellini wrote:
Hi All,
The value seems reasonable. What freq is the core running at (guessing 833Mhz). My 1.5Ghz 8572 has a bogomips of 150.
- k
Hi Kumar,
Hi All,
Seems that the value is about a tenth of the core frequency. I observed similar on TQM8548. Although I know, that the value is bogus (as the name tells), do you know the reason, why it isn't the core frequency?
Thanks.
Kind regards, Jens
Dear Jens Gehrlein,
Please read the FAQ:
http://www.denx.de/wiki/view/DULG/BogoMIPSValueTooLow
(especially entry 2)
Thanks for the information... this means less work form me... at least for this day.
ciao
luigi
On Thu, Oct 29, 2009 at 11:36 AM, Wolfgang Denk wd@denx.de wrote:
Dear Jens Gehrlein,
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de Bugs are by far the largest and most successful class of entity, with nearly a million known species. In this res- pect they outnumber all the other known creatures about four to one. -- Professor Snope's Encyclopedia of Animal _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
participants (5)
Jens Gehrlein
Kumar Gala
Luigi Mantellini
