[PATCH v2 1/3] video: Add VIDEO_FONT_4x6 to Kconfig add fix compile waring
CONFIG_VIDEO_FONT_4x6 is referenced in include/video_font.h, but doesn't has a Kconfig configuration.
Add it.
Signed-off-by: qianfan Zhao qianfanguijin@163.com --- drivers/video/Kconfig | 15 +++++++++++++++ include/video_font_4x6.h | 2 +- 2 files changed, 16 insertions(+), 1 deletion(-)
diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index e2cf1e752f..adc620682e 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -138,6 +138,21 @@ config CONSOLE_NORMAL CONFIG_CONSOLE_ROTATION for that). A built-in 8x16 font is used for the display.
+choice + prompt "bitmap video font" + default VIDEO_FONT_8X16 + depends on CONSOLE_NORMAL + help + Select the default bitmap font. + +config VIDEO_FONT_4X6 + bool "4x6" + +config VIDEO_FONT_8X16 + bool "8x16" + +endchoice + config CONSOLE_ROTATION bool "Support rotated displays" depends on DM_VIDEO diff --git a/include/video_font_4x6.h b/include/video_font_4x6.h index c7e6351b64..65dd5e8c1d 100644 --- a/include/video_font_4x6.h +++ b/include/video_font_4x6.h @@ -46,7 +46,7 @@ __END__; #define VIDEO_FONT_HEIGHT 6 #define VIDEO_FONT_SIZE (VIDEO_FONT_CHARS * VIDEO_FONT_HEIGHT)
-static unsigned char video_fontdata[VIDEO_FONT_SIZE] = { +static unsigned char __maybe_unused video_fontdata[VIDEO_FONT_SIZE] = {
/*{*/ /* Char 0: ' ' */
Add support \, \r, \n, \t and \b.
eg: => lcdputs "hello\nworld"
Signed-off-by: qianfan Zhao qianfanguijin@163.com --- drivers/video/vidconsole-uclass.c | 34 +++++++++++++++++++++++++++++-- 1 file changed, 32 insertions(+), 2 deletions(-)
diff --git a/drivers/video/vidconsole-uclass.c b/drivers/video/vidconsole-uclass.c index f42db40d4c..d2554fd3f7 100644 --- a/drivers/video/vidconsole-uclass.c +++ b/drivers/video/vidconsole-uclass.c @@ -709,15 +709,45 @@ static int do_video_puts(struct cmd_tbl *cmdtp, int flag, int argc, { struct udevice *dev; const char *s; + char c;
if (argc != 2) return CMD_RET_USAGE;
if (uclass_first_device_err(UCLASS_VIDEO_CONSOLE, &dev)) return CMD_RET_FAILURE; - for (s = argv[1]; *s; s++) - vidconsole_put_char(dev, *s);
+ for (s = argv[1]; (c = *s); s++) { + if (c == '\') { + s++; + + switch (*s) { + case '\0': + goto sync; + case '\': + c = '\'; + break; + case 'r': + c = '\r'; + break; + case 'n': + c = '\n'; + break; + case 't': + c = '\t'; + break; + case 'b': + c = '\b'; + break; + default: + continue; + } + } + + vidconsole_put_char(dev, c); + } + +sync: return video_sync(dev->parent, false); }
6x8 bitmap font has better display effect on smaller lcd screen.
Signed-off-by: qianfan Zhao qianfanguijin@163.com --- drivers/video/Kconfig | 3 + include/video_font.h | 4 +- include/video_font_6x8.h | 2580 ++++++++++++++++++++++++++++++++++++++ 3 files changed, 2586 insertions(+), 1 deletion(-) create mode 100644 include/video_font_6x8.h
diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index adc620682e..0526a88ee3 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -148,6 +148,9 @@ choice config VIDEO_FONT_4X6 bool "4x6"
+config VIDEO_FONT_6X8 + bool "6x8" + config VIDEO_FONT_8X16 bool "8x16"
diff --git a/include/video_font.h b/include/video_font.h index 5e23f70f85..4eac37a0f0 100644 --- a/include/video_font.h +++ b/include/video_font.h @@ -7,8 +7,10 @@ #ifndef _VIDEO_FONT_ #define _VIDEO_FONT_
-#ifdef CONFIG_VIDEO_FONT_4X6 +#if defined(CONFIG_VIDEO_FONT_4X6) #include <video_font_4x6.h> +#elif defined(CONFIG_VIDEO_FONT_6X8) +#include <video_font_6x8.h> #else #include <video_font_data.h> #endif diff --git a/include/video_font_6x8.h b/include/video_font_6x8.h new file mode 100644 index 0000000000..e090372c02 --- /dev/null +++ b/include/video_font_6x8.h @@ -0,0 +1,2580 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2022 + * qianfan Zhao qianfanguijin@163.com + * + * This file contains an 6x8 bitmap font for code page 437. + */ + +#ifndef _VIDEO_FONT_DATA_ +#define _VIDEO_FONT_DATA_ + +#define VIDEO_FONT_CHARS 256 +#define VIDEO_FONT_WIDTH 6 +#define VIDEO_FONT_HEIGHT 8 +#define VIDEO_FONT_SIZE (VIDEO_FONT_CHARS * VIDEO_FONT_HEIGHT) + +static unsigned char __maybe_unused video_fontdata[VIDEO_FONT_SIZE] = { + /* 0 0x00 */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + + /* 1 0x01 */ + 0x38, /* *** */ + 0x44, /* * * */ + 0x6c, /* ** ** */ + 0x44, /* * * */ + 0x54, /* * * * */ + 0x44, /* * * */ + 0x38, /* *** */ + 0x00, /* */ + + /* 2 0x02 */ + 0x38, /* *** */ + 0x7c, /* ***** */ + 0x54, /* * * * */ + 0x7c, /* ***** */ + 0x44, /* * * */ + 0x7c, /* ***** */ + 0x38, /* *** */ + 0x00, /* */ + + /* 3 0x03 */ + 0x00, /* */ + 0x28, /* * * */ + 0x7c, /* ***** */ + 0x7c, /* ***** */ + 0x7c, /* ***** */ + 0x38, /* *** */ + 0x10, /* * */ + 0x00, /* */ + + /* 4 0x04 */ + 0x00, /* */ + 0x10, /* * */ + 0x38, /* *** */ + 0x7c, /* ***** */ + 0x7c, /* ***** */ + 0x38, /* *** */ + 0x10, /* * */ + 0x00, /* */ + + /* 5 0x05 */ + 0x10, /* * */ + 0x38, /* *** */ + 0x38, /* *** */ + 0x10, /* * */ + 0x7c, /* ***** */ + 0x7c, /* ***** */ + 0x10, /* * */ + 0x00, /* */ + + /* 6 0x06 */ + 0x00, /* */ + 0x10, /* * */ + 0x38, /* *** */ + 0x7c, /* ***** */ + 0x7c, /* ***** */ + 0x10, /* * */ + 0x38, /* *** */ + 0x00, /* */ + + /* 7 0x07 */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + + /* 8 0x08 */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + + /* 9 0x09 */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + + /* 10 0x0a */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + + /* 11 0x0b */ + 0x00, /* */ + 0x1c, /* *** */ + 0x0c, /* ** */ + 0x34, /* ** * */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x30, /* ** */ + 0x00, /* */ + + /* 12 0x0c */ + 0x38, /* *** */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x38, /* *** */ + 0x10, /* * */ + 0x38, /* *** */ + 0x10, /* * */ + 0x00, /* */ + + /* 13 0x0d */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + + /* 14 0x0e */ + 0x0c, /* ** */ + 0x34, /* ** * */ + 0x2c, /* * ** */ + 0x34, /* ** * */ + 0x2c, /* * ** */ + 0x6c, /* ** ** */ + 0x60, /* ** */ + 0x00, /* */ + + /* 15 0x0f */ + 0x00, /* */ + 0x54, /* * * * */ + 0x38, /* *** */ + 0x6c, /* ** ** */ + 0x38, /* *** */ + 0x54, /* * * * */ + 0x00, /* */ + 0x00, /* */ + + /* 16 0x10 */ + 0x20, /* * */ + 0x30, /* ** */ + 0x38, /* *** */ + 0x3c, /* **** */ + 0x38, /* *** */ + 0x30, /* ** */ + 0x20, /* * */ + 0x00, /* */ + + /* 17 0x11 */ + 0x08, /* * */ + 0x18, /* ** */ + 0x38, /* *** */ + 0x78, /* **** */ + 0x38, /* *** */ + 0x18, /* ** */ + 0x08, /* * */ + 0x00, /* */ + + /* 18 0x12 */ + 0x10, /* * */ + 0x38, /* *** */ + 0x7c, /* ***** */ + 0x10, /* * */ + 0x7c, /* ***** */ + 0x38, /* *** */ + 0x10, /* * */ + 0x00, /* */ + + /* 19 0x13 */ + 0x28, /* * * */ + 0x28, /* * * */ + 0x28, /* * * */ + 0x28, /* * * */ + 0x28, /* * * */ + 0x00, /* */ + 0x28, /* * * */ + 0x00, /* */ + + /* 20 0x14 */ + 0x3c, /* **** */ + 0x54, /* * * * */ + 0x54, /* * * * */ + 0x34, /* ** * */ + 0x14, /* * * */ + 0x14, /* * * */ + 0x14, /* * * */ + 0x00, /* */ + + /* 21 0x15 */ + 0x38, /* *** */ + 0x44, /* * * */ + 0x30, /* ** */ + 0x28, /* * * */ + 0x18, /* ** */ + 0x44, /* * * */ + 0x38, /* *** */ + 0x00, /* */ + + /* 22 0x16 */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x78, /* **** */ + 0x78, /* **** */ + 0x00, /* */ + + /* 23 0x17 */ + 0x10, /* * */ + 0x38, /* *** */ + 0x7c, /* ***** */ + 0x10, /* * */ + 0x7c, /* ***** */ + 0x38, /* *** */ + 0x10, /* * */ + 0x38, /* *** */ + + /* 24 0x18 */ + 0x10, /* * */ + 0x38, /* *** */ + 0x7c, /* ***** */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x00, /* */ + + /* 25 0x19 */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x7c, /* ***** */ + 0x38, /* *** */ + 0x10, /* * */ + 0x00, /* */ + + /* 26 0x1a */ + 0x00, /* */ + 0x10, /* * */ + 0x18, /* ** */ + 0x7c, /* ***** */ + 0x18, /* ** */ + 0x10, /* * */ + 0x00, /* */ + 0x00, /* */ + + /* 27 0x1b */ + 0x00, /* */ + 0x10, /* * */ + 0x30, /* ** */ + 0x7c, /* ***** */ + 0x30, /* ** */ + 0x10, /* * */ + 0x00, /* */ + 0x00, /* */ + + /* 28 0x1c */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x40, /* * */ + 0x40, /* * */ + 0x40, /* * */ + 0x7c, /* ***** */ + 0x00, /* */ + + /* 29 0x1d */ + 0x00, /* */ + 0x28, /* * * */ + 0x28, /* * * */ + 0x7c, /* ***** */ + 0x28, /* * * */ + 0x28, /* * * */ + 0x00, /* */ + 0x00, /* */ + + /* 30 0x1e */ + 0x10, /* * */ + 0x10, /* * */ + 0x38, /* *** */ + 0x38, /* *** */ + 0x7c, /* ***** */ + 0x7c, /* ***** */ + 0x00, /* */ + 0x00, /* */ + + /* 31 0x1f */ + 0x7c, /* ***** */ + 0x7c, /* ***** */ + 0x38, /* *** */ + 0x38, /* *** */ + 0x10, /* * */ + 0x10, /* * */ + 0x00, /* */ + 0x00, /* */ + + /* 32 0x20 */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + + /* 33 0x21! */ + 0x10, /* * */ + 0x38, /* *** */ + 0x38, /* *** */ + 0x10, /* * */ + 0x10, /* * */ + 0x00, /* */ + 0x10, /* * */ + 0x00, /* */ + + /* 34 0x22" */ + 0x6c, /* ** ** */ + 0x6c, /* ** ** */ + 0x48, /* * * */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + + /* 35 0x23# */ + 0x00, /* */ + 0x28, /* * * */ + 0x7c, /* ***** */ + 0x28, /* * * */ + 0x28, /* * * */ + 0x7c, /* ***** */ + 0x28, /* * * */ + 0x00, /* */ + + /* 36 0x24$ */ + 0x20, /* * */ + 0x38, /* *** */ + 0x40, /* * */ + 0x30, /* ** */ + 0x08, /* * */ + 0x70, /* *** */ + 0x10, /* * */ + 0x00, /* */ + + /* 37 0x25% */ + 0x64, /* ** * */ + 0x64, /* ** * */ + 0x08, /* * */ + 0x10, /* * */ + 0x20, /* * */ + 0x4c, /* * ** */ + 0x4c, /* * ** */ + 0x00, /* */ + + /* 38 0x26& */ + 0x20, /* * */ + 0x50, /* * * */ + 0x50, /* * * */ + 0x20, /* * */ + 0x54, /* * * * */ + 0x48, /* * * */ + 0x34, /* ** * */ + 0x00, /* */ + + /* 39 0x27' */ + 0x30, /* ** */ + 0x30, /* ** */ + 0x20, /* * */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + + /* 40 0x28( */ + 0x10, /* * */ + 0x20, /* * */ + 0x20, /* * */ + 0x20, /* * */ + 0x20, /* * */ + 0x20, /* * */ + 0x10, /* * */ + 0x00, /* */ + + /* 41 0x29) */ + 0x20, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x20, /* * */ + 0x00, /* */ + + /* 42 0x2a* */ + 0x00, /* */ + 0x28, /* * * */ + 0x38, /* *** */ + 0x7c, /* ***** */ + 0x38, /* *** */ + 0x28, /* * * */ + 0x00, /* */ + 0x00, /* */ + + /* 43 0x2b+ */ + 0x00, /* */ + 0x10, /* * */ + 0x10, /* * */ + 0x7c, /* ***** */ + 0x10, /* * */ + 0x10, /* * */ + 0x00, /* */ + 0x00, /* */ + + /* 44 0x2c, */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x30, /* ** */ + 0x30, /* ** */ + 0x20, /* * */ + + /* 45 0x2d- */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x7c, /* ***** */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + + /* 46 0x2e. */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x30, /* ** */ + 0x30, /* ** */ + 0x00, /* */ + + /* 47 0x2f/ */ + 0x00, /* */ + 0x04, /* * */ + 0x08, /* * */ + 0x10, /* * */ + 0x20, /* * */ + 0x40, /* * */ + 0x00, /* */ + 0x00, /* */ + + /* 48 0x300 */ + 0x38, /* *** */ + 0x44, /* * * */ + 0x4c, /* * ** */ + 0x54, /* * * * */ + 0x64, /* ** * */ + 0x44, /* * * */ + 0x38, /* *** */ + 0x00, /* */ + + /* 49 0x311 */ + 0x10, /* * */ + 0x30, /* ** */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x38, /* *** */ + 0x00, /* */ + + /* 50 0x322 */ + 0x38, /* *** */ + 0x44, /* * * */ + 0x04, /* * */ + 0x18, /* ** */ + 0x20, /* * */ + 0x40, /* * */ + 0x7c, /* ***** */ + 0x00, /* */ + + /* 51 0x333 */ + 0x38, /* *** */ + 0x44, /* * * */ + 0x04, /* * */ + 0x38, /* *** */ + 0x04, /* * */ + 0x44, /* * * */ + 0x38, /* *** */ + 0x00, /* */ + + /* 52 0x344 */ + 0x08, /* * */ + 0x18, /* ** */ + 0x28, /* * * */ + 0x48, /* * * */ + 0x7c, /* ***** */ + 0x08, /* * */ + 0x08, /* * */ + 0x00, /* */ + + /* 53 0x355 */ + 0x7c, /* ***** */ + 0x40, /* * */ + 0x40, /* * */ + 0x78, /* **** */ + 0x04, /* * */ + 0x44, /* * * */ + 0x38, /* *** */ + 0x00, /* */ + + /* 54 0x366 */ + 0x18, /* ** */ + 0x20, /* * */ + 0x40, /* * */ + 0x78, /* **** */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x38, /* *** */ + 0x00, /* */ + + /* 55 0x377 */ + 0x7c, /* ***** */ + 0x04, /* * */ + 0x08, /* * */ + 0x10, /* * */ + 0x20, /* * */ + 0x20, /* * */ + 0x20, /* * */ + 0x00, /* */ + + /* 56 0x388 */ + 0x38, /* *** */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x38, /* *** */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x38, /* *** */ + 0x00, /* */ + + /* 57 0x399 */ + 0x38, /* *** */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x3c, /* **** */ + 0x04, /* * */ + 0x08, /* * */ + 0x30, /* ** */ + 0x00, /* */ + + /* 58 0x3a: */ + 0x00, /* */ + 0x00, /* */ + 0x30, /* ** */ + 0x30, /* ** */ + 0x00, /* */ + 0x30, /* ** */ + 0x30, /* ** */ + 0x00, /* */ + + /* 59 0x3b; */ + 0x00, /* */ + 0x00, /* */ + 0x30, /* ** */ + 0x30, /* ** */ + 0x00, /* */ + 0x30, /* ** */ + 0x30, /* ** */ + 0x20, /* * */ + + /* 60 0x3c< */ + 0x08, /* * */ + 0x10, /* * */ + 0x20, /* * */ + 0x40, /* * */ + 0x20, /* * */ + 0x10, /* * */ + 0x08, /* * */ + 0x00, /* */ + + /* 61 0x3d= */ + 0x00, /* */ + 0x00, /* */ + 0x7c, /* ***** */ + 0x00, /* */ + 0x00, /* */ + 0x7c, /* ***** */ + 0x00, /* */ + 0x00, /* */ + + /* 62 0x3e> */ + 0x20, /* * */ + 0x10, /* * */ + 0x08, /* * */ + 0x04, /* * */ + 0x08, /* * */ + 0x10, /* * */ + 0x20, /* * */ + 0x00, /* */ + + /* 63 0x3f? */ + 0x38, /* *** */ + 0x44, /* * * */ + 0x04, /* * */ + 0x18, /* ** */ + 0x10, /* * */ + 0x00, /* */ + 0x10, /* * */ + 0x00, /* */ + + /* 64 0x40@ */ + 0x38, /* *** */ + 0x44, /* * * */ + 0x5c, /* * *** */ + 0x54, /* * * * */ + 0x5c, /* * *** */ + 0x40, /* * */ + 0x38, /* *** */ + 0x00, /* */ + + /* 65 0x41A */ + 0x38, /* *** */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x7c, /* ***** */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x00, /* */ + + /* 66 0x42B */ + 0x78, /* **** */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x78, /* **** */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x78, /* **** */ + 0x00, /* */ + + /* 67 0x43C */ + 0x38, /* *** */ + 0x44, /* * * */ + 0x40, /* * */ + 0x40, /* * */ + 0x40, /* * */ + 0x44, /* * * */ + 0x38, /* *** */ + 0x00, /* */ + + /* 68 0x44D */ + 0x78, /* **** */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x78, /* **** */ + 0x00, /* */ + + /* 69 0x45E */ + 0x7c, /* ***** */ + 0x40, /* * */ + 0x40, /* * */ + 0x78, /* **** */ + 0x40, /* * */ + 0x40, /* * */ + 0x7c, /* ***** */ + 0x00, /* */ + + /* 70 0x46F */ + 0x7c, /* ***** */ + 0x40, /* * */ + 0x40, /* * */ + 0x78, /* **** */ + 0x40, /* * */ + 0x40, /* * */ + 0x40, /* * */ + 0x00, /* */ + + /* 71 0x47G */ + 0x38, /* *** */ + 0x44, /* * * */ + 0x40, /* * */ + 0x5c, /* * *** */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x3c, /* **** */ + 0x00, /* */ + + /* 72 0x48H */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x7c, /* ***** */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x00, /* */ + + /* 73 0x49I */ + 0x38, /* *** */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x38, /* *** */ + 0x00, /* */ + + /* 74 0x4aJ */ + 0x04, /* * */ + 0x04, /* * */ + 0x04, /* * */ + 0x04, /* * */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x38, /* *** */ + 0x00, /* */ + + /* 75 0x4bK */ + 0x44, /* * * */ + 0x48, /* * * */ + 0x50, /* * * */ + 0x60, /* ** */ + 0x50, /* * * */ + 0x48, /* * * */ + 0x44, /* * * */ + 0x00, /* */ + + /* 76 0x4cL */ + 0x40, /* * */ + 0x40, /* * */ + 0x40, /* * */ + 0x40, /* * */ + 0x40, /* * */ + 0x40, /* * */ + 0x7c, /* ***** */ + 0x00, /* */ + + /* 77 0x4dM */ + 0x44, /* * * */ + 0x6c, /* ** ** */ + 0x54, /* * * * */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x00, /* */ + + /* 78 0x4eN */ + 0x44, /* * * */ + 0x64, /* ** * */ + 0x54, /* * * * */ + 0x4c, /* * ** */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x00, /* */ + + /* 79 0x4fO */ + 0x38, /* *** */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x38, /* *** */ + 0x00, /* */ + + /* 80 0x50P */ + 0x78, /* **** */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x78, /* **** */ + 0x40, /* * */ + 0x40, /* * */ + 0x40, /* * */ + 0x00, /* */ + + /* 81 0x51Q */ + 0x38, /* *** */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x54, /* * * * */ + 0x48, /* * * */ + 0x34, /* ** * */ + 0x00, /* */ + + /* 82 0x52R */ + 0x78, /* **** */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x78, /* **** */ + 0x48, /* * * */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x00, /* */ + + /* 83 0x53S */ + 0x38, /* *** */ + 0x44, /* * * */ + 0x40, /* * */ + 0x38, /* *** */ + 0x04, /* * */ + 0x44, /* * * */ + 0x38, /* *** */ + 0x00, /* */ + + /* 84 0x54T */ + 0x7c, /* ***** */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x00, /* */ + + /* 85 0x55U */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x38, /* *** */ + 0x00, /* */ + + /* 86 0x56V */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x28, /* * * */ + 0x10, /* * */ + 0x00, /* */ + + /* 87 0x57W */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x54, /* * * * */ + 0x54, /* * * * */ + 0x54, /* * * * */ + 0x54, /* * * * */ + 0x28, /* * * */ + 0x00, /* */ + + /* 88 0x58X */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x28, /* * * */ + 0x10, /* * */ + 0x28, /* * * */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x00, /* */ + + /* 89 0x59Y */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x28, /* * * */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x00, /* */ + + /* 90 0x5aZ */ + 0x78, /* **** */ + 0x08, /* * */ + 0x10, /* * */ + 0x20, /* * */ + 0x40, /* * */ + 0x40, /* * */ + 0x78, /* **** */ + 0x00, /* */ + + /* 91 0x5b[ */ + 0x38, /* *** */ + 0x20, /* * */ + 0x20, /* * */ + 0x20, /* * */ + 0x20, /* * */ + 0x20, /* * */ + 0x38, /* *** */ + 0x00, /* */ + + /* 92 0x5c\ */ + 0x00, /* */ + 0x40, /* * */ + 0x20, /* * */ + 0x10, /* * */ + 0x08, /* * */ + 0x04, /* * */ + 0x00, /* */ + 0x00, /* */ + + /* 93 0x5d] */ + 0x38, /* *** */ + 0x08, /* * */ + 0x08, /* * */ + 0x08, /* * */ + 0x08, /* * */ + 0x08, /* * */ + 0x38, /* *** */ + 0x00, /* */ + + /* 94 0x5e^ */ + 0x10, /* * */ + 0x28, /* * * */ + 0x44, /* * * */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + + /* 95 0x5f_ */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0xfc, /* ****** */ + + /* 96 0x60` */ + 0x30, /* ** */ + 0x30, /* ** */ + 0x10, /* * */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + + /* 97 0x61a */ + 0x00, /* */ + 0x00, /* */ + 0x38, /* *** */ + 0x04, /* * */ + 0x3c, /* **** */ + 0x44, /* * * */ + 0x3c, /* **** */ + 0x00, /* */ + + /* 98 0x62b */ + 0x40, /* * */ + 0x40, /* * */ + 0x78, /* **** */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x78, /* **** */ + 0x00, /* */ + + /* 99 0x63c */ + 0x00, /* */ + 0x00, /* */ + 0x38, /* *** */ + 0x44, /* * * */ + 0x40, /* * */ + 0x44, /* * * */ + 0x38, /* *** */ + 0x00, /* */ + + /* 100 0x64d */ + 0x04, /* * */ + 0x04, /* * */ + 0x3c, /* **** */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x3c, /* **** */ + 0x00, /* */ + + /* 101 0x65e */ + 0x00, /* */ + 0x00, /* */ + 0x38, /* *** */ + 0x44, /* * * */ + 0x78, /* **** */ + 0x40, /* * */ + 0x38, /* *** */ + 0x00, /* */ + + /* 102 0x66f */ + 0x18, /* ** */ + 0x20, /* * */ + 0x20, /* * */ + 0x78, /* **** */ + 0x20, /* * */ + 0x20, /* * */ + 0x20, /* * */ + 0x00, /* */ + + /* 103 0x67g */ + 0x00, /* */ + 0x00, /* */ + 0x3c, /* **** */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x3c, /* **** */ + 0x04, /* * */ + 0x38, /* *** */ + + /* 104 0x68h */ + 0x40, /* * */ + 0x40, /* * */ + 0x70, /* *** */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x00, /* */ + + /* 105 0x69i */ + 0x10, /* * */ + 0x00, /* */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x18, /* ** */ + 0x00, /* */ + + /* 106 0x6aj */ + 0x08, /* * */ + 0x00, /* */ + 0x18, /* ** */ + 0x08, /* * */ + 0x08, /* * */ + 0x08, /* * */ + 0x48, /* * * */ + 0x30, /* ** */ + + /* 107 0x6bk */ + 0x40, /* * */ + 0x40, /* * */ + 0x48, /* * * */ + 0x50, /* * * */ + 0x60, /* ** */ + 0x50, /* * * */ + 0x48, /* * * */ + 0x00, /* */ + + /* 108 0x6cl */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x18, /* ** */ + 0x00, /* */ + + /* 109 0x6dm */ + 0x00, /* */ + 0x00, /* */ + 0x68, /* ** * */ + 0x54, /* * * * */ + 0x54, /* * * * */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x00, /* */ + + /* 110 0x6en */ + 0x00, /* */ + 0x00, /* */ + 0x70, /* *** */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x00, /* */ + + /* 111 0x6fo */ + 0x00, /* */ + 0x00, /* */ + 0x38, /* *** */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x38, /* *** */ + 0x00, /* */ + + /* 112 0x70p */ + 0x00, /* */ + 0x00, /* */ + 0x78, /* **** */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x78, /* **** */ + 0x40, /* * */ + + /* 113 0x71q */ + 0x00, /* */ + 0x00, /* */ + 0x3c, /* **** */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x3c, /* **** */ + 0x04, /* * */ + + /* 114 0x72r */ + 0x00, /* */ + 0x00, /* */ + 0x58, /* * ** */ + 0x24, /* * * */ + 0x20, /* * */ + 0x20, /* * */ + 0x70, /* *** */ + 0x00, /* */ + + /* 115 0x73s */ + 0x00, /* */ + 0x00, /* */ + 0x38, /* *** */ + 0x40, /* * */ + 0x38, /* *** */ + 0x04, /* * */ + 0x38, /* *** */ + 0x00, /* */ + + /* 116 0x74t */ + 0x00, /* */ + 0x20, /* * */ + 0x78, /* **** */ + 0x20, /* * */ + 0x20, /* * */ + 0x28, /* * * */ + 0x10, /* * */ + 0x00, /* */ + + /* 117 0x75u */ + 0x00, /* */ + 0x00, /* */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x58, /* * ** */ + 0x28, /* * * */ + 0x00, /* */ + + /* 118 0x76v */ + 0x00, /* */ + 0x00, /* */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x28, /* * * */ + 0x10, /* * */ + 0x00, /* */ + + /* 119 0x77w */ + 0x00, /* */ + 0x00, /* */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x54, /* * * * */ + 0x7c, /* ***** */ + 0x28, /* * * */ + 0x00, /* */ + + /* 120 0x78x */ + 0x00, /* */ + 0x00, /* */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x30, /* ** */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x00, /* */ + + /* 121 0x79y */ + 0x00, /* */ + 0x00, /* */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x38, /* *** */ + 0x10, /* * */ + 0x60, /* ** */ + + /* 122 0x7az */ + 0x00, /* */ + 0x00, /* */ + 0x78, /* **** */ + 0x08, /* * */ + 0x30, /* ** */ + 0x40, /* * */ + 0x78, /* **** */ + 0x00, /* */ + + /* 123 0x7b{ */ + 0x18, /* ** */ + 0x20, /* * */ + 0x20, /* * */ + 0x60, /* ** */ + 0x20, /* * */ + 0x20, /* * */ + 0x18, /* ** */ + 0x00, /* */ + + /* 124 0x7c| */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x00, /* */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x00, /* */ + + /* 125 0x7d} */ + 0x30, /* ** */ + 0x08, /* * */ + 0x08, /* * */ + 0x0c, /* ** */ + 0x08, /* * */ + 0x08, /* * */ + 0x30, /* ** */ + 0x00, /* */ + + /* 126 0x7e~ */ + 0x28, /* * * */ + 0x50, /* * * */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + + /* 127 0x7f */ + 0x10, /* * */ + 0x38, /* *** */ + 0x6c, /* ** ** */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x7c, /* ***** */ + 0x00, /* */ + 0x00, /* */ + + /* 128 0x80 */ + 0x38, /* *** */ + 0x44, /* * * */ + 0x40, /* * */ + 0x40, /* * */ + 0x44, /* * * */ + 0x38, /* *** */ + 0x10, /* * */ + 0x30, /* ** */ + + /* 129 0x81 */ + 0x48, /* * * */ + 0x00, /* */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x58, /* * ** */ + 0x28, /* * * */ + 0x00, /* */ + + /* 130 0x82 */ + 0x0c, /* ** */ + 0x00, /* */ + 0x38, /* *** */ + 0x44, /* * * */ + 0x78, /* **** */ + 0x40, /* * */ + 0x38, /* *** */ + 0x00, /* */ + + /* 131 0x83 */ + 0x38, /* *** */ + 0x00, /* */ + 0x38, /* *** */ + 0x04, /* * */ + 0x3c, /* **** */ + 0x44, /* * * */ + 0x3c, /* **** */ + 0x00, /* */ + + /* 132 0x84 */ + 0x28, /* * * */ + 0x00, /* */ + 0x38, /* *** */ + 0x04, /* * */ + 0x3c, /* **** */ + 0x44, /* * * */ + 0x3c, /* **** */ + 0x00, /* */ + + /* 133 0x85 */ + 0x30, /* ** */ + 0x00, /* */ + 0x38, /* *** */ + 0x04, /* * */ + 0x3c, /* **** */ + 0x44, /* * * */ + 0x3c, /* **** */ + 0x00, /* */ + + /* 134 0x86 */ + 0x38, /* *** */ + 0x28, /* * * */ + 0x38, /* *** */ + 0x04, /* * */ + 0x3c, /* **** */ + 0x44, /* * * */ + 0x3c, /* **** */ + 0x00, /* */ + + /* 135 0x87 */ + 0x00, /* */ + 0x38, /* *** */ + 0x44, /* * * */ + 0x40, /* * */ + 0x44, /* * * */ + 0x38, /* *** */ + 0x10, /* * */ + 0x30, /* ** */ + + /* 136 0x88 */ + 0x38, /* *** */ + 0x00, /* */ + 0x38, /* *** */ + 0x44, /* * * */ + 0x78, /* **** */ + 0x40, /* * */ + 0x38, /* *** */ + 0x00, /* */ + + /* 137 0x89 */ + 0x28, /* * * */ + 0x00, /* */ + 0x38, /* *** */ + 0x44, /* * * */ + 0x78, /* **** */ + 0x40, /* * */ + 0x38, /* *** */ + 0x00, /* */ + + /* 138 0x8a */ + 0x30, /* ** */ + 0x00, /* */ + 0x38, /* *** */ + 0x44, /* * * */ + 0x78, /* **** */ + 0x40, /* * */ + 0x38, /* *** */ + 0x00, /* */ + + /* 139 0x8b */ + 0x28, /* * * */ + 0x00, /* */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x18, /* ** */ + 0x00, /* */ + + /* 140 0x8c */ + 0x38, /* *** */ + 0x00, /* */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x18, /* ** */ + 0x00, /* */ + + /* 141 0x8d */ + 0x20, /* * */ + 0x00, /* */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x18, /* ** */ + 0x00, /* */ + + /* 142 0x8e */ + 0x28, /* * * */ + 0x00, /* */ + 0x10, /* * */ + 0x28, /* * * */ + 0x44, /* * * */ + 0x7c, /* ***** */ + 0x44, /* * * */ + 0x00, /* */ + + /* 143 0x8f */ + 0x38, /* *** */ + 0x28, /* * * */ + 0x38, /* *** */ + 0x6c, /* ** ** */ + 0x44, /* * * */ + 0x7c, /* ***** */ + 0x44, /* * * */ + 0x00, /* */ + + /* 144 0x90 */ + 0x0c, /* ** */ + 0x00, /* */ + 0x7c, /* ***** */ + 0x40, /* * */ + 0x78, /* **** */ + 0x40, /* * */ + 0x7c, /* ***** */ + 0x00, /* */ + + /* 145 0x91 */ + 0x00, /* */ + 0x00, /* */ + 0x78, /* **** */ + 0x14, /* * * */ + 0x7c, /* ***** */ + 0x50, /* * * */ + 0x3c, /* **** */ + 0x00, /* */ + + /* 146 0x92 */ + 0x3c, /* **** */ + 0x50, /* * * */ + 0x50, /* * * */ + 0x7c, /* ***** */ + 0x50, /* * * */ + 0x50, /* * * */ + 0x5c, /* * *** */ + 0x00, /* */ + + /* 147 0x93 */ + 0x38, /* *** */ + 0x00, /* */ + 0x30, /* ** */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x30, /* ** */ + 0x00, /* */ + + /* 148 0x94 */ + 0x28, /* * * */ + 0x00, /* */ + 0x30, /* ** */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x30, /* ** */ + 0x00, /* */ + + /* 149 0x95 */ + 0x60, /* ** */ + 0x00, /* */ + 0x30, /* ** */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x30, /* ** */ + 0x00, /* */ + + /* 150 0x96 */ + 0x38, /* *** */ + 0x00, /* */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x58, /* * ** */ + 0x28, /* * * */ + 0x00, /* */ + + /* 151 0x97 */ + 0x60, /* ** */ + 0x00, /* */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x58, /* * ** */ + 0x28, /* * * */ + 0x00, /* */ + + /* 152 0x98 */ + 0x28, /* * * */ + 0x00, /* */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x38, /* *** */ + 0x10, /* * */ + 0x60, /* ** */ + + /* 153 0x99 */ + 0x48, /* * * */ + 0x30, /* ** */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x30, /* ** */ + 0x00, /* */ + + /* 154 0x9a */ + 0x28, /* * * */ + 0x00, /* */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x30, /* ** */ + 0x00, /* */ + + /* 155 0x9b */ + 0x00, /* */ + 0x00, /* */ + 0x04, /* * */ + 0x38, /* *** */ + 0x58, /* * ** */ + 0x68, /* ** * */ + 0x70, /* *** */ + 0x80, /* * */ + + /* 156 0x9c */ + 0x18, /* ** */ + 0x24, /* * * */ + 0x20, /* * */ + 0x78, /* **** */ + 0x20, /* * */ + 0x24, /* * * */ + 0x5c, /* * *** */ + 0x00, /* */ + + /* 157 0x9d */ + 0x3c, /* **** */ + 0x4c, /* * ** */ + 0x54, /* * * * */ + 0x54, /* * * * */ + 0x54, /* * * * */ + 0x64, /* ** * */ + 0x78, /* **** */ + 0x00, /* */ + + /* 158 0x9e */ + 0x00, /* */ + 0x44, /* * * */ + 0x28, /* * * */ + 0x10, /* * */ + 0x28, /* * * */ + 0x44, /* * * */ + 0x00, /* */ + 0x00, /* */ + + /* 159 0x9f */ + 0x08, /* * */ + 0x14, /* * * */ + 0x10, /* * */ + 0x38, /* *** */ + 0x10, /* * */ + 0x10, /* * */ + 0x50, /* * * */ + 0x20, /* * */ + + /* 160 0xa0 */ + 0x18, /* ** */ + 0x00, /* */ + 0x38, /* *** */ + 0x04, /* * */ + 0x3c, /* **** */ + 0x44, /* * * */ + 0x3c, /* **** */ + 0x00, /* */ + + /* 161 0xa1 */ + 0x18, /* ** */ + 0x00, /* */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x18, /* ** */ + 0x00, /* */ + + /* 162 0xa2 */ + 0x18, /* ** */ + 0x00, /* */ + 0x30, /* ** */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x30, /* ** */ + 0x00, /* */ + + /* 163 0xa3 */ + 0x18, /* ** */ + 0x00, /* */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x58, /* * ** */ + 0x28, /* * * */ + 0x00, /* */ + + /* 164 0xa4 */ + 0x28, /* * * */ + 0x50, /* * * */ + 0x00, /* */ + 0x70, /* *** */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x00, /* */ + + /* 165 0xa5 */ + 0x28, /* * * */ + 0x50, /* * * */ + 0x00, /* */ + 0x48, /* * * */ + 0x68, /* ** * */ + 0x58, /* * ** */ + 0x48, /* * * */ + 0x00, /* */ + + /* 166 0xa6 */ + 0x38, /* *** */ + 0x04, /* * */ + 0x3c, /* **** */ + 0x44, /* * * */ + 0x3c, /* **** */ + 0x00, /* */ + 0x3c, /* **** */ + 0x00, /* */ + + /* 167 0xa7 */ + 0x30, /* ** */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x30, /* ** */ + 0x00, /* */ + 0x78, /* **** */ + 0x00, /* */ + + /* 168 0xa8 */ + 0x10, /* * */ + 0x00, /* */ + 0x10, /* * */ + 0x30, /* ** */ + 0x40, /* * */ + 0x44, /* * * */ + 0x38, /* *** */ + 0x00, /* */ + + /* 169 0xa9 */ + 0x78, /* **** */ + 0x94, /* * * * */ + 0xac, /* * * ** */ + 0xb4, /* * ** * */ + 0xac, /* * * ** */ + 0x84, /* * * */ + 0x78, /* **** */ + 0x00, /* */ + + /* 170 0xaa */ + 0x00, /* */ + 0x00, /* */ + 0xfc, /* ****** */ + 0x04, /* * */ + 0x04, /* * */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + + /* 171 0xab */ + 0x40, /* * */ + 0x48, /* * * */ + 0x50, /* * * */ + 0x38, /* *** */ + 0x44, /* * * */ + 0x08, /* * */ + 0x1c, /* *** */ + 0x00, /* */ + + /* 172 0xac */ + 0x40, /* * */ + 0x48, /* * * */ + 0x50, /* * * */ + 0x2c, /* * ** */ + 0x54, /* * * * */ + 0x1c, /* *** */ + 0x04, /* * */ + 0x00, /* */ + + /* 173 0xad */ + 0x10, /* * */ + 0x00, /* */ + 0x10, /* * */ + 0x10, /* * */ + 0x38, /* *** */ + 0x38, /* *** */ + 0x10, /* * */ + 0x00, /* */ + + /* 174 0xae */ + 0x00, /* */ + 0x00, /* */ + 0x24, /* * * */ + 0x48, /* * * */ + 0x24, /* * * */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + + /* 175 0xaf */ + 0x00, /* */ + 0x00, /* */ + 0x48, /* * * */ + 0x24, /* * * */ + 0x48, /* * * */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + + /* 176 0xb0 */ + 0x54, /* * * * */ + 0x00, /* */ + 0xa8, /* * * * */ + 0x00, /* */ + 0x54, /* * * * */ + 0x00, /* */ + 0xa8, /* * * * */ + 0x00, /* */ + + /* 177 0xb1 */ + 0x54, /* * * * */ + 0xa8, /* * * * */ + 0x54, /* * * * */ + 0xa8, /* * * * */ + 0x54, /* * * * */ + 0xa8, /* * * * */ + 0x54, /* * * * */ + 0xa8, /* * * * */ + + /* 178 0xb2 */ + 0xa8, /* * * * */ + 0xfc, /* ****** */ + 0x54, /* * * * */ + 0xfc, /* ****** */ + 0xa8, /* * * * */ + 0xfc, /* ****** */ + 0x54, /* * * * */ + 0xfc, /* ****** */ + + /* 179 0xb3 */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + + /* 180 0xb4 */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0xf0, /* **** */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + + /* 181 0xb5 */ + 0x18, /* ** */ + 0x00, /* */ + 0x10, /* * */ + 0x28, /* * * */ + 0x44, /* * * */ + 0x7c, /* ***** */ + 0x44, /* * * */ + 0x00, /* */ + + /* 182 0xb6 */ + 0x38, /* *** */ + 0x00, /* */ + 0x10, /* * */ + 0x28, /* * * */ + 0x44, /* * * */ + 0x7c, /* ***** */ + 0x44, /* * * */ + 0x00, /* */ + + /* 183 0xb7 */ + 0x30, /* ** */ + 0x00, /* */ + 0x10, /* * */ + 0x28, /* * * */ + 0x44, /* * * */ + 0x7c, /* ***** */ + 0x44, /* * * */ + 0x00, /* */ + + /* 184 0xb8 */ + 0x78, /* **** */ + 0x84, /* * * */ + 0xb4, /* * ** * */ + 0xa4, /* * * * */ + 0xb4, /* * ** * */ + 0x84, /* * * */ + 0x78, /* **** */ + 0x00, /* */ + + /* 185 0xb9 */ + 0x50, /* * * */ + 0xd0, /* ** * */ + 0x10, /* * */ + 0xd0, /* ** * */ + 0x50, /* * * */ + 0x50, /* * * */ + 0x50, /* * * */ + 0x50, /* * * */ + + /* 186 0xba */ + 0x50, /* * * */ + 0x50, /* * * */ + 0x50, /* * * */ + 0x50, /* * * */ + 0x50, /* * * */ + 0x50, /* * * */ + 0x50, /* * * */ + 0x50, /* * * */ + + /* 187 0xbb */ + 0x00, /* */ + 0xf0, /* **** */ + 0x10, /* * */ + 0xd0, /* ** * */ + 0x50, /* * * */ + 0x50, /* * * */ + 0x50, /* * * */ + 0x50, /* * * */ + + /* 188 0xbc */ + 0x50, /* * * */ + 0xd0, /* ** * */ + 0x10, /* * */ + 0xf0, /* **** */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + + /* 189 0xbd */ + 0x00, /* */ + 0x10, /* * */ + 0x38, /* *** */ + 0x40, /* * */ + 0x40, /* * */ + 0x38, /* *** */ + 0x10, /* * */ + 0x00, /* */ + + /* 190 0xbe */ + 0x44, /* * * */ + 0x28, /* * * */ + 0x10, /* * */ + 0x7c, /* ***** */ + 0x10, /* * */ + 0x7c, /* ***** */ + 0x10, /* * */ + 0x00, /* */ + + /* 191 0xbf */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0xf0, /* **** */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + + /* 192 0xc0 */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x1c, /* *** */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + + /* 193 0xc1 */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0xfc, /* ****** */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + + /* 194 0xc2 */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0xfc, /* ****** */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + + /* 195 0xc3 */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x1c, /* *** */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + + /* 196 0xc4 */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0xfc, /* ****** */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + + /* 197 0xc5 */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0xfc, /* ****** */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + + /* 198 0xc6 */ + 0x14, /* * * */ + 0x28, /* * * */ + 0x38, /* *** */ + 0x04, /* * */ + 0x3c, /* **** */ + 0x44, /* * * */ + 0x3c, /* **** */ + 0x00, /* */ + + /* 199 0xc7 */ + 0x14, /* * * */ + 0x28, /* * * */ + 0x10, /* * */ + 0x28, /* * * */ + 0x44, /* * * */ + 0x7c, /* ***** */ + 0x44, /* * * */ + 0x00, /* */ + + /* 200 0xc8 */ + 0x50, /* * * */ + 0x5c, /* * *** */ + 0x40, /* * */ + 0x7c, /* ***** */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + + /* 201 0xc9 */ + 0x00, /* */ + 0x7c, /* ***** */ + 0x40, /* * */ + 0x5c, /* * *** */ + 0x50, /* * * */ + 0x50, /* * * */ + 0x50, /* * * */ + 0x50, /* * * */ + + /* 202 0xca */ + 0x50, /* * * */ + 0xdc, /* ** *** */ + 0x00, /* */ + 0xfc, /* ****** */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + + /* 203 0xcb */ + 0x00, /* */ + 0xfc, /* ****** */ + 0x00, /* */ + 0xdc, /* ** *** */ + 0x50, /* * * */ + 0x50, /* * * */ + 0x50, /* * * */ + 0x50, /* * * */ + + /* 204 0xcc */ + 0x50, /* * * */ + 0x5c, /* * *** */ + 0x40, /* * */ + 0x5c, /* * *** */ + 0x50, /* * * */ + 0x50, /* * * */ + 0x50, /* * * */ + 0x50, /* * * */ + + /* 205 0xcd */ + 0x00, /* */ + 0xfc, /* ****** */ + 0x00, /* */ + 0xfc, /* ****** */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + + /* 206 0xce */ + 0x50, /* * * */ + 0xdc, /* ** *** */ + 0x00, /* */ + 0xdc, /* ** *** */ + 0x50, /* * * */ + 0x50, /* * * */ + 0x50, /* * * */ + 0x50, /* * * */ + + /* 207 0xcf */ + 0x44, /* * * */ + 0x38, /* *** */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x44, /* * * */ + 0x38, /* *** */ + 0x44, /* * * */ + 0x00, /* */ + + /* 208 0xd0 */ + 0x30, /* ** */ + 0x40, /* * */ + 0x20, /* * */ + 0x10, /* * */ + 0x38, /* *** */ + 0x48, /* * * */ + 0x30, /* ** */ + 0x00, /* */ + + /* 209 0xd1 */ + 0x38, /* *** */ + 0x24, /* * * */ + 0x24, /* * * */ + 0x74, /* *** * */ + 0x24, /* * * */ + 0x24, /* * * */ + 0x38, /* *** */ + 0x00, /* */ + + /* 210 0xd2 */ + 0x38, /* *** */ + 0x00, /* */ + 0x7c, /* ***** */ + 0x40, /* * */ + 0x78, /* **** */ + 0x40, /* * */ + 0x7c, /* ***** */ + 0x00, /* */ + + /* 211 0xd3 */ + 0x28, /* * * */ + 0x00, /* */ + 0x7c, /* ***** */ + 0x40, /* * */ + 0x78, /* **** */ + 0x40, /* * */ + 0x7c, /* ***** */ + 0x00, /* */ + + /* 212 0xd4 */ + 0x30, /* ** */ + 0x00, /* */ + 0x7c, /* ***** */ + 0x40, /* * */ + 0x78, /* **** */ + 0x40, /* * */ + 0x7c, /* ***** */ + 0x00, /* */ + + /* 213 0xd5 */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + + /* 214 0xd6 */ + 0x18, /* ** */ + 0x00, /* */ + 0x38, /* *** */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x38, /* *** */ + 0x00, /* */ + + /* 215 0xd7 */ + 0x38, /* *** */ + 0x00, /* */ + 0x38, /* *** */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x38, /* *** */ + 0x00, /* */ + + /* 216 0xd8 */ + 0x28, /* * * */ + 0x00, /* */ + 0x38, /* *** */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x38, /* *** */ + 0x00, /* */ + + /* 217 0xd9 */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0xf0, /* **** */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + + /* 218 0xda */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x1c, /* *** */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + + /* 219 0xdb */ + 0xfc, /* ****** */ + 0xfc, /* ****** */ + 0xfc, /* ****** */ + 0xfc, /* ****** */ + 0xfc, /* ****** */ + 0xfc, /* ****** */ + 0xfc, /* ****** */ + 0xfc, /* ****** */ + + /* 220 0xdc */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0xfc, /* ****** */ + 0xfc, /* ****** */ + 0xfc, /* ****** */ + 0xfc, /* ****** */ + + /* 221 0xdd */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x00, /* */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x00, /* */ + + /* 222 0xde */ + 0x30, /* ** */ + 0x00, /* */ + 0x38, /* *** */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x38, /* *** */ + 0x00, /* */ + + /* 223 0xdf */ + 0xfc, /* ****** */ + 0xfc, /* ****** */ + 0xfc, /* ****** */ + 0xfc, /* ****** */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + + /* 224 0xe0 */ + 0x18, /* ** */ + 0x30, /* ** */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x30, /* ** */ + 0x00, /* */ + + /* 225 0xe1 */ + 0x00, /* */ + 0x70, /* *** */ + 0x48, /* * * */ + 0x70, /* *** */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x70, /* *** */ + 0x40, /* * */ + + /* 226 0xe2 */ + 0x38, /* *** */ + 0x30, /* ** */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x30, /* ** */ + 0x00, /* */ + + /* 227 0xe3 */ + 0x60, /* ** */ + 0x30, /* ** */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x30, /* ** */ + 0x00, /* */ + + /* 228 0xe4 */ + 0x28, /* * * */ + 0x50, /* * * */ + 0x00, /* */ + 0x30, /* ** */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x30, /* ** */ + 0x00, /* */ + + /* 229 0xe5 */ + 0x28, /* * * */ + 0x50, /* * * */ + 0x30, /* ** */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x30, /* ** */ + 0x00, /* */ + + /* 230 0xe6 */ + 0x00, /* */ + 0x00, /* */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x70, /* *** */ + 0x40, /* * */ + 0x40, /* * */ + + /* 231 0xe7 */ + 0x00, /* */ + 0x60, /* ** */ + 0x40, /* * */ + 0x70, /* *** */ + 0x48, /* * * */ + 0x70, /* *** */ + 0x40, /* * */ + 0x60, /* ** */ + + /* 232 0xe8 */ + 0x60, /* ** */ + 0x40, /* * */ + 0x70, /* *** */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x70, /* *** */ + 0x40, /* * */ + 0x60, /* ** */ + + /* 233 0xe9 */ + 0x18, /* ** */ + 0x00, /* */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x30, /* ** */ + 0x00, /* */ + + /* 234 0xea */ + 0x38, /* *** */ + 0x00, /* */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x30, /* ** */ + 0x00, /* */ + + /* 235 0xeb */ + 0x60, /* ** */ + 0x00, /* */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x30, /* ** */ + 0x00, /* */ + + /* 236 0xec */ + 0x18, /* ** */ + 0x00, /* */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x38, /* *** */ + 0x10, /* * */ + 0x60, /* ** */ + + /* 237 0xed */ + 0x18, /* ** */ + 0x00, /* */ + 0x44, /* * * */ + 0x28, /* * * */ + 0x10, /* * */ + 0x10, /* * */ + 0x10, /* * */ + 0x00, /* */ + + /* 238 0xee */ + 0x00, /* */ + 0x38, /* *** */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + + /* 239 0xef */ + 0x30, /* ** */ + 0x30, /* ** */ + 0x20, /* * */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + + /* 240 0xf0 */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x38, /* *** */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + + /* 241 0xf1 */ + 0x00, /* */ + 0x10, /* * */ + 0x38, /* *** */ + 0x10, /* * */ + 0x00, /* */ + 0x38, /* *** */ + 0x00, /* */ + 0x00, /* */ + + /* 242 0xf2 */ + 0x00, /* */ + 0x00, /* */ + 0x7c, /* ***** */ + 0x00, /* */ + 0x00, /* */ + 0x7c, /* ***** */ + 0x00, /* */ + 0x00, /* */ + + /* 243 0xf3 */ + 0xc0, /* ** */ + 0x68, /* ** * */ + 0xd0, /* ** * */ + 0x2c, /* * ** */ + 0x54, /* * * * */ + 0x1c, /* *** */ + 0x04, /* * */ + 0x00, /* */ + + /* 244 0xf4 */ + 0x3c, /* **** */ + 0x54, /* * * * */ + 0x54, /* * * * */ + 0x34, /* ** * */ + 0x14, /* * * */ + 0x14, /* * * */ + 0x14, /* * * */ + 0x00, /* */ + + /* 245 0xf5 */ + 0x38, /* *** */ + 0x44, /* * * */ + 0x30, /* ** */ + 0x28, /* * * */ + 0x18, /* ** */ + 0x44, /* * * */ + 0x38, /* *** */ + 0x00, /* */ + + /* 246 0xf6 */ + 0x00, /* */ + 0x10, /* * */ + 0x00, /* */ + 0x7c, /* ***** */ + 0x00, /* */ + 0x10, /* * */ + 0x00, /* */ + 0x00, /* */ + + /* 247 0xf7 */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x38, /* *** */ + 0x18, /* ** */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + + /* 248 0xf8 */ + 0x30, /* ** */ + 0x48, /* * * */ + 0x48, /* * * */ + 0x30, /* ** */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + + /* 249 0xf9 */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x28, /* * * */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + + /* 250 0xfa */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x20, /* * */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + + /* 251 0xfb */ + 0x20, /* * */ + 0x60, /* ** */ + 0x20, /* * */ + 0x20, /* * */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + + /* 252 0xfc */ + 0x70, /* *** */ + 0x20, /* * */ + 0x30, /* ** */ + 0x60, /* ** */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + + /* 253 0xfd */ + 0x60, /* ** */ + 0x10, /* * */ + 0x20, /* * */ + 0x70, /* *** */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + + /* 254 0xfe */ + 0x00, /* */ + 0x00, /* */ + 0x78, /* **** */ + 0x78, /* **** */ + 0x78, /* **** */ + 0x78, /* **** */ + 0x00, /* */ + 0x00, /* */ + + /* 255 0xff */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ + 0x00, /* */ +}; + +#endif +
