[U-Boot] [PATCH] net/phy: support the mv88e6352 switch
This patch add support for the configuration of an external switch from the 88E6xxx series from Marvell trough an MDIO link using indirect adressing. This can be used if we do not want to use an EEPROM for the configuration.
This driver is not generic and was not tested on other switches than the 88e6352. This is proposed as a first implementation that is somewhat limited but works and that can be used as a basis for further developments for this switch family.
Signed-off-by: Valentin Longchamp valentin.longchamp@keymile.com cc: Holger Brunck holger.brunck@keymile.com cc: Prafulla Wadaskar prafulla@marvell.com cc: Joe Hershberger joe.hershberger@gmail.com --- drivers/net/phy/Makefile | 1 + drivers/net/phy/mv88e6352.c | 318 +++++++++++++++++++++++++++++++++++++++++++ include/mv88e6352.h | 92 +++++++++++++ 3 files changed, 411 insertions(+), 0 deletions(-) create mode 100644 drivers/net/phy/mv88e6352.c create mode 100644 include/mv88e6352.h
diff --git a/drivers/net/phy/Makefile b/drivers/net/phy/Makefile index feced39..5e90d70 100644 --- a/drivers/net/phy/Makefile +++ b/drivers/net/phy/Makefile @@ -27,6 +27,7 @@ LIB := $(obj)libphy.o
COBJS-$(CONFIG_BITBANGMII) += miiphybb.o COBJS-$(CONFIG_MV88E61XX_SWITCH) += mv88e61xx.o +COBJS-$(CONFIG_MV88E6352_SWITCH) += mv88e6352.o
COBJS-$(CONFIG_PHYLIB) += phy.o COBJS-$(CONFIG_PHYLIB_10G) += generic_10g.o diff --git a/drivers/net/phy/mv88e6352.c b/drivers/net/phy/mv88e6352.c new file mode 100644 index 0000000..7269a6a --- /dev/null +++ b/drivers/net/phy/mv88e6352.c @@ -0,0 +1,318 @@ +/* + * (C) Copyright 2012 + * Valentin Lontgchamp, Keymile AG, valentin.longchamp@keymile.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <miiphy.h> +#include <asm/errno.h> +#include <mv88e6352.h> + +#define SMI_HDR ((0x8 | 0x1) << 12) +#define SMI_BUSY_MASK (0x8000) +#define SMIRD_OP (0x2 << 10) +#define SMIWR_OP (0x1 << 10) +#define SMI_MASK 0x1f +#define PORT_SHIFT 5 + +#define COMMAND_REG 0 +#define DATA_REG 1 + +/* global registers */ +#define GLOBAL 0x1b + +#define GLOBAL_STATUS 0x00 +#define PPU_STATE 0x8000 + +#define GLOBAL_CTRL 0x04 +#define SW_RESET 0x8000 +#define PPU_ENABLE 0x4000 + +static int sw_wait_rdy(const char *devname, u8 phy_addr) +{ + u16 command; + u32 timeout = 100; + int ret; + + /* wait till the SMI is not busy */ + do { + /* read command register */ + ret = miiphy_read(devname, phy_addr, COMMAND_REG, &command); + if (ret < 0) { + printf("%s: Error reading command register\n", + __func__); + return ret; + } + if (timeout-- == 0) { + printf("Err..(%s) SMI busy timeout\n", __func__); + return -EFAULT; + } + } while (command & SMI_BUSY_MASK); + + return 0; +} + +static int sw_reg_read(const char *devname, u8 phy_addr, u8 port, + u8 reg, u16 *data) +{ + int ret; + u16 command; + + ret = sw_wait_rdy(devname, phy_addr); + if (ret) + return ret; + + command = SMI_HDR | SMIRD_OP | ((port&SMI_MASK) << PORT_SHIFT) | + (reg & SMI_MASK); + debug("%s: write to command: %#x\n", __func__, command); + ret = miiphy_write(devname, phy_addr, COMMAND_REG, command); + if (ret) + return ret; + + ret = sw_wait_rdy(devname, phy_addr); + if (ret) + return ret; + + ret = miiphy_read(devname, phy_addr, DATA_REG, data); + + return ret; +} + +static int sw_reg_write(const char *devname, u8 phy_addr, u8 port, + u8 reg, u16 data) +{ + int ret; + u16 value; + + ret = sw_wait_rdy(devname, phy_addr); + if (ret) + return ret; + + debug("%s: write to data: %#x\n", __func__, data); + ret = miiphy_write(devname, phy_addr, DATA_REG, data); + if (ret) + return ret; + + value = SMI_HDR | SMIWR_OP | ((port & SMI_MASK) << PORT_SHIFT) | + (reg & SMI_MASK); + debug("%s: write to command: %#x\n", __func__, value); + ret = miiphy_write(devname, phy_addr, COMMAND_REG, value); + if (ret) + return ret; + + ret = sw_wait_rdy(devname, phy_addr); + if (ret) + return ret; + + return 0; +} + +static int ppu_enable(const char *devname, u8 phy_addr) +{ + int i, ret = 0; + u16 reg; + + ret = sw_reg_read(devname, phy_addr, GLOBAL, GLOBAL_CTRL, ®); + if (ret) { + printf("%s: Error reading global ctrl reg\n", __func__); + return ret; + } + + reg |= PPU_ENABLE; + + ret = sw_reg_write(devname, phy_addr, GLOBAL, GLOBAL_CTRL, reg); + if (ret) { + printf("%s: Error writing global ctrl reg\n", __func__); + return ret; + } + + for (i = 0; i < 1000; i++) { + sw_reg_read(devname, phy_addr, GLOBAL, GLOBAL_STATUS, + ®); + if ((reg & 0xc000) == 0xc000) + return 0; + udelay(1000); + } + + return -ETIMEDOUT; +} + +static int ppu_disable(const char *devname, u8 phy_addr) +{ + int i, ret = 0; + u16 reg; + + ret = sw_reg_read(devname, phy_addr, GLOBAL, GLOBAL_CTRL, ®); + if (ret) { + printf("%s: Error reading global ctrl reg\n", __func__); + return ret; + } + + reg &= ~PPU_ENABLE; + + ret = sw_reg_write(devname, phy_addr, GLOBAL, GLOBAL_CTRL, reg); + if (ret) { + printf("%s: Error writing global ctrl reg\n", __func__); + return ret; + } + + for (i = 0; i < 1000; i++) { + sw_reg_read(devname, phy_addr, GLOBAL, GLOBAL_STATUS, + ®); + if ((reg & 0xc000) != 0xc000) + return 0; + udelay(1000); + } + + return -ETIMEDOUT; +} + +int mv88e_sw_program(const char *devname, u8 phy_addr, + struct mv88e_sw_reg *regs, int regs_nb) +{ + int i, ret = 0; + + /* first we need to disable the PPU */ + ret = ppu_disable(devname, phy_addr); + if (ret) { + printf("%s: Error disabling PPU\n", __func__); + return ret; + } + + for (i = 0; i < regs_nb; i++) { + ret = sw_reg_write(devname, phy_addr, regs[i].port, + regs[i].reg, regs[i].value); + if (ret) { + printf("%s: Error configuring switch\n", __func__); + ppu_enable(devname, phy_addr); + return ret; + } + } + + /* re-enable the PPU */ + ret = ppu_enable(devname, phy_addr); + if (ret) { + printf("%s: Error enabling PPU\n", __func__); + return ret; + } + + return 0; +} + +int mv88e_sw_reset(const char *devname, u8 phy_addr) +{ + int i, ret = 0; + u16 reg; + + ret = sw_reg_read(devname, phy_addr, GLOBAL, GLOBAL_CTRL, ®); + if (ret) { + printf("%s: Error reading global ctrl reg\n", __func__); + return ret; + } + + reg = SW_RESET | PPU_ENABLE | 0x0400; + + ret = sw_reg_write(devname, phy_addr, GLOBAL, GLOBAL_CTRL, reg); + if (ret) { + printf("%s: Error writing global ctrl reg\n", __func__); + return ret; + } + + for (i = 0; i < 1000; i++) { + sw_reg_read(devname, phy_addr, GLOBAL, GLOBAL_STATUS, + ®); + if ((reg & 0xc800) != 0xc800) + return 0; + udelay(1000); + } + + return -ETIMEDOUT; +} + +int do_mvsw_reg_read(const char *name, int argc, char * const argv[]) +{ + u16 value = 0, phyaddr, reg, port; + int ret; + + phyaddr = simple_strtoul(argv[1], NULL, 10); + port = simple_strtoul(argv[2], NULL, 10); + reg = simple_strtoul(argv[3], NULL, 10); + + ret = sw_reg_read(name, phyaddr, port, reg, &value); + printf("%#x\n", value); + + return ret; +} + +int do_mvsw_reg_write(const char *name, int argc, char * const argv[]) +{ + u16 value = 0, phyaddr, reg, port; + int ret; + + phyaddr = simple_strtoul(argv[1], NULL, 10); + port = simple_strtoul(argv[2], NULL, 10); + reg = simple_strtoul(argv[3], NULL, 10); + value = simple_strtoul(argv[4], NULL, 16); + + ret = sw_reg_write(name, phyaddr, port, reg, value); + + return ret; +} + + +int do_mvsw_reg(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + int ret; + const char *cmd, *ethname; + + if (argc < 2) + return cmd_usage(cmdtp); + + cmd = argv[1]; + --argc; + ++argv; + + if (strcmp(cmd, "read") == 0) { + if (argc < 5) + return cmd_usage(cmdtp); + ethname = argv[1]; + --argc; + ++argv; + ret = do_mvsw_reg_read(ethname, argc, argv); + } else if (strcmp(cmd, "write") == 0) { + if (argc < 6) + return cmd_usage(cmdtp); + ethname = argv[1]; + --argc; + ++argv; + ret = do_mvsw_reg_write(ethname, argc, argv); + } else + return cmd_usage(cmdtp); + + return ret; +} + +U_BOOT_CMD( + mvsw_reg, 7, 1, do_mvsw_reg, + "marvell 88e6352 switch register access", + "write ethname phyaddr port reg value\n" + "mvsw_reg read ethname phyaddr port reg\n" + ); diff --git a/include/mv88e6352.h b/include/mv88e6352.h new file mode 100644 index 0000000..cdc4db7 --- /dev/null +++ b/include/mv88e6352.h @@ -0,0 +1,92 @@ +/* + * (C) Copyright 2012 + * Valentin Lontgchamp, Keymile AG, valentin.longchamp@keymile.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef __MV886352_H +#define __MV886352_H + +#include <common.h> + +/* PHY registers */ +#define PHY(itf) (itf) + +#define PHY_CTRL 0x00 +#define PHY_100_MBPS 0x2000 +#define PHY_1_GBPS 0x0040 +#define AUTONEG_EN 0x1000 +#define AUTONEG_RST 0x0200 +#define FULL_DUPLEX 0x0100 +#define PHY_PWR_DOWN 0x0800 + +#define PHY_STATUS 0x01 +#define AN1000FIX 0x0001 + +#define PHY_SPEC_CTRL 0x10 +#define SPEC_PWR_DOWN 0x0004 +#define AUTO_MDIX_EN 0x0060 + +#define PHY_1000_CTRL 0x9 + +#define NO_ADV 0x0000 +#define ADV_1000_FDPX 0x0200 +#define ADV_1000_HDPX 0x0100 + +#define PHY_PAGE 0x16 + +#define AN1000FIX_PAGE 0x00fc + +/* PORT or MAC registers */ +#define PORT(itf) (itf+0x10) + +#define PORT_STATUS 0x00 +#define NO_PHY_DETECT 0x0000 + +#define PORT_PHY 0x01 +#define RX_RGMII_TIM 0x8000 +#define TX_RGMII_TIM 0x4000 +#define FLOW_CTRL_EN 0x0080 +#define FLOW_CTRL_FOR 0x0040 +#define LINK_VAL 0x0020 +#define LINK_FOR 0x0010 +#define FULL_DPX 0x0008 +#define FULL_DPX_FOR 0x0004 +#define NO_SPEED_FOR 0x0003 +#define SPEED_1000_FOR 0x0002 +#define SPEED_100_FOR 0x0001 +#define SPEED_10_FOR 0x0000 + +#define PORT_CTRL 0x04 +#define FORWARDING 0x0003 +#define EGRS_FLD_ALL 0x000c +#define PORT_DIS 0x0000 + +struct mv88e_sw_reg { + u8 port; + u8 reg; + u16 value; +}; + +int mv88e_sw_reset(const char *devname, u8 phy_addr); +int mv88e_sw_program(const char *devname, u8 phy_addr, + struct mv88e_sw_reg *regs, int regs_nb); + +#endif
-----Original Message----- From: Valentin Longchamp [mailto:valentin.longchamp@keymile.com] Sent: 16 August 2012 16:47 To: u-boot@lists.denx.de Cc: Valentin Longchamp; Holger Brunck; Prafulla Wadaskar; Joe Hershberger Subject: [PATCH] net/phy: support the mv88e6352 switch
Hi Valentin
I do not have any specific feedback for this patch, To me this looks okay.
Joe may pull it if he finds everything okay.
Regards... Prafulla . . .
Hi Valentin
Hi Joe,
We have never received any feedback from you regarding this patch. Could you please consider review it and if applicable apply it since it is a dependency for another series in the Marvell tree.
Thank you and best regards
Valentin
Hi Valentin,
On Fri, Sep 21, 2012 at 9:00 AM, Valentin Longchamp valentin.longchamp@keymile.com wrote:
Hi Valentin
Hi Joe,
Sorry... I'm a bit behind on applying patches and testing. It is assigned to me in patchwork. I'll get to it as soon as I can.
Cheers, -Joe
Hi Valentin,
On Thu, Aug 16, 2012 at 6:17 AM, Valentin Longchamp valentin.longchamp@keymile.com wrote:
Applied, thanks.
-Joe
Joe Hershberger
Prafulla Wadaskar
Valentin Longchamp
