[U-Boot] [PATCH v2 1/2] spi: zynqmp_qspi: Add support for ZynqMP qspi driver
This patch adds qspi driver support for ZynqMP SoC. This driver is responsible for communicating with qspi flash devices.
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- Changes from v1: - Rebased on top of latest master - Moved macro definitions to .h file as per comment - Fixed magic values with macros as per comment --- arch/arm/cpu/armv8/zynqmp/Kconfig | 7 + arch/arm/include/asm/arch-zynqmp/zynqmp_qspi.h | 154 ++++++ drivers/spi/Makefile | 1 + drivers/spi/zynqmp_qspi.c | 678 +++++++++++++++++++++++++ 4 files changed, 840 insertions(+) create mode 100644 arch/arm/include/asm/arch-zynqmp/zynqmp_qspi.h create mode 100644 drivers/spi/zynqmp_qspi.c
diff --git a/arch/arm/cpu/armv8/zynqmp/Kconfig b/arch/arm/cpu/armv8/zynqmp/Kconfig index 3f922b4..2fe4f71 100644 --- a/arch/arm/cpu/armv8/zynqmp/Kconfig +++ b/arch/arm/cpu/armv8/zynqmp/Kconfig @@ -65,6 +65,13 @@ config PMUFW_INIT_FILE Include external PMUFW (Platform Management Unit FirmWare) to a Xilinx bootable image (boot.bin).
+config ZYNQMP_QSPI + bool "Configure ZynqMP QSPI" + select DM_SPI + help + This option is used to enable ZynqMP QSPI controller driver which + is used to communicate with qspi flash devices. + config ZYNQMP_USB bool "Configure ZynqMP USB"
diff --git a/arch/arm/include/asm/arch-zynqmp/zynqmp_qspi.h b/arch/arm/include/asm/arch-zynqmp/zynqmp_qspi.h new file mode 100644 index 0000000..5e2926e --- /dev/null +++ b/arch/arm/include/asm/arch-zynqmp/zynqmp_qspi.h @@ -0,0 +1,154 @@ +/* + * (C) Copyright 2014 - 2015 Xilinx + * + * Xilinx ZynqMP Quad-SPI(QSPI) controller driver (master mode only) + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _ASM_ARCH_ZYNQMP_QSPI_H_ +#define _ASM_ARCH_ZYNQMP_QSPI_H_ + +#define ZYNQMP_QSPI_GFIFO_STRT_MODE_MASK BIT(29) +#define ZYNQMP_QSPI_CONFIG_MODE_EN_MASK (3 << 30) +#define ZYNQMP_QSPI_CONFIG_DMA_MODE (2 << 30) +#define ZYNQMP_QSPI_CONFIG_CPHA_MASK BIT(2) +#define ZYNQMP_QSPI_CONFIG_CPOL_MASK BIT(1) + +/* QSPI MIO's count for different connection topologies */ +#define ZYNQMP_QSPI_MIO_NUM_QSPI0 6 +#define ZYNQMP_QSPI_MIO_NUM_QSPI1 5 +#define ZYNQMP_QSPI_MIO_NUM_QSPI1_CS 1 + +/* + * QSPI Interrupt Registers bit Masks + * + * All the four interrupt registers (Status/Mask/Enable/Disable) have the same + * bit definitions. + */ +#define ZYNQMP_QSPI_IXR_TXNFULL_MASK 0x00000004 /* QSPI TX FIFO Overflow */ +#define ZYNQMP_QSPI_IXR_TXFULL_MASK 0x00000008 /* QSPI TX FIFO is full */ +#define ZYNQMP_QSPI_IXR_RXNEMTY_MASK 0x00000010 /* QSPI RX FIFO Not Empty */ +#define ZYNQMP_QSPI_IXR_GFEMTY_MASK 0x00000080 /* QSPI Generic FIFO Empty */ +#define ZYNQMP_QSPI_IXR_ALL_MASK (ZYNQMP_QSPI_IXR_TXNFULL_MASK | \ + ZYNQMP_QSPI_IXR_RXNEMTY_MASK) + +/* + * QSPI Enable Register bit Masks + * + * This register is used to enable or disable the QSPI controller + */ +#define ZYNQMP_QSPI_ENABLE_ENABLE_MASK 0x00000001 /* QSPI Enable Bit Mask */ + +#define ZYNQMP_QSPI_GFIFO_LOW_BUS BIT(14) +#define ZYNQMP_QSPI_GFIFO_CS_LOWER BIT(12) +#define ZYNQMP_QSPI_GFIFO_UP_BUS BIT(15) +#define ZYNQMP_QSPI_GFIFO_CS_UPPER BIT(13) +#define ZYNQMP_QSPI_SPI_MODE_QSPI (3 << 10) +#define ZYNQMP_QSPI_SPI_MODE_SPI BIT(10) +#define ZYNQMP_QSPI_SPI_MODE_DUAL_SPI (2 << 10) +#define ZYNQMP_QSPI_IMD_DATA_CS_ASSERT 5 +#define ZYNQMP_QSPI_IMD_DATA_CS_DEASSERT 5 +#define ZYNQMP_QSPI_GFIFO_TX BIT(16) +#define ZYNQMP_QSPI_GFIFO_RX BIT(17) +#define ZYNQMP_QSPI_GFIFO_STRIPE_MASK BIT(18) +#define ZYNQMP_QSPI_GFIFO_IMD_MASK 0xFF +#define ZYNQMP_QSPI_GFIFO_EXP_MASK BIT(9) +#define ZYNQMP_QSPI_GFIFO_DATA_XFR_MASK BIT(8) +#define ZYNQMP_QSPI_STRT_GEN_FIFO BIT(28) +#define ZYNQMP_QSPI_GEN_FIFO_STRT_MOD BIT(29) +#define ZYNQMP_QSPI_GFIFO_WP_HOLD BIT(19) +#define ZYNQMP_QSPI_BAUD_DIV_MASK (7 << 3) +#define ZYNQMP_QSPI_DFLT_BAUD_RATE_DIV BIT(3) +#define ZYNQMP_QSPI_GFIFO_ALL_INT_MASK 0xFBE +#define ZYNQMP_QSPI_DMA_DST_I_STS_DONE BIT(1) +#define ZYNQMP_QSPI_DMA_DST_I_STS_MASK 0xFE +#define MODEBITS 0x6 + +#define QUAD_OUT_READ_CMD 0x6B +#define QUAD_PAGE_PROGRAM_CMD 0x32 +#define DUAL_OUTPUT_FASTRD_CMD 0x3B + +#define ZYNQMP_QSPI_GFIFO_SELECT BIT(0) + +#define ZYNQMP_QSPI_FIFO_THRESHOLD 1 + +#define SPI_XFER_ON_BOTH 0 +#define SPI_XFER_ON_LOWER 1 +#define SPI_XFER_ON_UPPER 2 + +#define ZYNQMP_QSPI_DMA_ALIGN 0x4 +#define ZYNQMP_QSPI_MAX_BAUD_RATE_VAL 7 +#define ZYNQMP_QSPI_DFLT_BAUD_RATE_VAL 2 + +#define ZYNQMP_QSPI_TIMEOUT 100000000 + +#define GQSPI_BAUD_DIV_SHIFT 2 +#define GQSPI_LPBK_DLY_ADJ_LPBK_SHIFT 5 +#define GQSPI_LPBK_DLY_ADJ_DLY_1 0x2 +#define GQSPI_LPBK_DLY_ADJ_DLY_1_SHIFT 3 +#define GQSPI_LPBK_DLY_ADJ_DLY_0 0x3 +#define GQSPI_USE_DATA_DLY 0x1 +#define GQSPI_USE_DATA_DLY_SHIFT 31 +#define GQSPI_DATA_DLY_ADJ_VALUE 0x2 +#define GQSPI_DATA_DLY_ADJ_SHIFT 28 +#define TAP_DLY_BYPASS_LQSPI_RX_VALUE 0x1 +#define TAP_DLY_BYPASS_LQSPI_RX_SHIFT 2 +#define GQSPI_DATA_DLY_ADJ_OFST 0x000001F8 +#define IOU_TAPDLY_BYPASS_OFST 0xFF180390 +#define GQSPI_LPBK_DLY_ADJ_USE_LPBK_MASK 0x00000020 +#define GQSPI_FREQ_40MHZ 40000000 +#define GQSPI_FREQ_100MHZ 100000000 +#define GQSPI_FREQ_150MHZ 150000000 +#define IOU_TAPDLY_BYPASS_MASK 0x7 + +#define ZYNQMP_GQSPI_REG_OFFSET 0x100 +#define ZYNQMP_GQSPI_DMA_REG_OFFSET 0x800 + +/* QSPI register offsets */ +struct zynqmp_qspi_regs { + u32 confr; /* 0x00 */ + u32 isr; /* 0x04 */ + u32 ier; /* 0x08 */ + u32 idisr; /* 0x0C */ + u32 imaskr; /* 0x10 */ + u32 enbr; /* 0x14 */ + u32 dr; /* 0x18 */ + u32 txd0r; /* 0x1C */ + u32 drxr; /* 0x20 */ + u32 sicr; /* 0x24 */ + u32 txftr; /* 0x28 */ + u32 rxftr; /* 0x2C */ + u32 gpior; /* 0x30 */ + u32 reserved0; /* 0x34 */ + u32 lpbkdly; /* 0x38 */ + u32 reserved1; /* 0x3C */ + u32 genfifo; /* 0x40 */ + u32 gqspisel; /* 0x44 */ + u32 reserved2; /* 0x48 */ + u32 gqfifoctrl; /* 0x4C */ + u32 gqfthr; /* 0x50 */ + u32 gqpollcfg; /* 0x54 */ + u32 gqpollto; /* 0x58 */ + u32 gqxfersts; /* 0x5C */ + u32 gqfifosnap; /* 0x60 */ + u32 gqrxcpy; /* 0x64 */ + u32 reserved3[36]; /* 0x68 */ + u32 gqspidlyadj; /* 0xF8 */ +}; + +struct zynqmp_qspi_dma_regs { + u32 dmadst; /* 0x00 */ + u32 dmasize; /* 0x04 */ + u32 dmasts; /* 0x08 */ + u32 dmactrl; /* 0x0C */ + u32 reserved0; /* 0x10 */ + u32 dmaisr; /* 0x14 */ + u32 dmaier; /* 0x18 */ + u32 dmaidr; /* 0x1C */ + u32 dmaimr; /* 0x20 */ + u32 dmactrl2; /* 0x24 */ + u32 dmadstmsb; /* 0x28 */ +}; + +#endif /* _ASM_ARCH_ZYNQMP_QSPI_H_ */ diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index e3184db..9cdd94a 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -50,3 +50,4 @@ obj-$(CONFIG_TI_QSPI) += ti_qspi.o obj-$(CONFIG_XILINX_SPI) += xilinx_spi.o obj-$(CONFIG_ZYNQ_SPI) += zynq_spi.o obj-$(CONFIG_ZYNQ_QSPI) += zynq_qspi.o +obj-$(CONFIG_ZYNQMP_QSPI) += zynqmp_qspi.o diff --git a/drivers/spi/zynqmp_qspi.c b/drivers/spi/zynqmp_qspi.c new file mode 100644 index 0000000..199e704 --- /dev/null +++ b/drivers/spi/zynqmp_qspi.c @@ -0,0 +1,678 @@ +/* + * (C) Copyright 2014 - 2015 Xilinx + * + * Xilinx ZynqMP Quad-SPI(QSPI) controller driver (master mode only) + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <malloc.h> +#include <memalign.h> +#include <ubi_uboot.h> +#include <spi.h> +#include <spi_flash.h> +#include <asm/io.h> +#include <asm/arch/hardware.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/clk.h> +#include "../mtd/spi/sf_internal.h" +#include <clk.h> +#include <asm/arch/zynqmp_qspi.h> + +DECLARE_GLOBAL_DATA_PTR; + +struct zynqmp_qspi_platdata { + struct zynqmp_qspi_regs *regs; + struct zynqmp_qspi_dma_regs *dma_regs; + u32 frequency; + u32 speed_hz; + unsigned int tx_rx_mode; +}; + +struct zynqmp_qspi_priv { + struct zynqmp_qspi_regs *regs; + struct zynqmp_qspi_dma_regs *dma_regs; + u8 mode; + const void *tx_buf; + void *rx_buf; + unsigned int len; + int bytes_to_transfer; + int bytes_to_receive; + unsigned int is_inst; + unsigned int cs_change:1; +}; + +static u8 last_cmd; + +static int zynqmp_qspi_ofdata_to_platdata(struct udevice *bus) +{ + struct zynqmp_qspi_platdata *plat = bus->platdata; + u32 mode = 0; + u32 value; + int ret; + struct clk clk; + unsigned long clock; + + debug("%s\n", __func__); + + plat->regs = (struct zynqmp_qspi_regs *)(devfdt_get_addr(bus) + + ZYNQMP_GQSPI_REG_OFFSET); + plat->dma_regs = (struct zynqmp_qspi_dma_regs *) + (devfdt_get_addr(bus) + ZYNQMP_GQSPI_DMA_REG_OFFSET); + + ret = clk_get_by_index(bus, 0, &clk); + if (ret < 0) { + dev_err(dev, "failed to get clock\n"); + return ret; + } + + clock = clk_get_rate(&clk); + if (IS_ERR_VALUE(clock)) { + dev_err(dev, "failed to get rate\n"); + return clock; + } + debug("%s: CLK %ld\n", __func__, clock); + + ret = clk_enable(&clk); + if (ret && ret != -ENOSYS) { + dev_err(dev, "failed to enable clock\n"); + return ret; + } + + value = dev_read_u32_default(bus, "spi-rx-bus-width", 1); + switch (value) { + case 1: + break; + case 2: + mode |= SPI_RX_DUAL; + break; + case 4: + mode |= SPI_RX_QUAD; + break; + default: + printf("Invalid spi-rx-bus-width %d\n", value); + break; + } + + value = dev_read_u32_default(bus, "spi-tx-bus-width", 1); + switch (value) { + case 1: + break; + case 2: + mode |= SPI_TX_DUAL; + break; + case 4: + mode |= SPI_TX_QUAD; + break; + default: + printf("Invalid spi-tx-bus-width %d\n", value); + break; + } + + plat->tx_rx_mode = mode; + + plat->frequency = clock; + plat->speed_hz = plat->frequency; + + return 0; +} + +static void zynqmp_qspi_init_hw(struct zynqmp_qspi_priv *priv) +{ + u32 config_reg; + struct zynqmp_qspi_regs *regs = priv->regs; + + writel(ZYNQMP_QSPI_GFIFO_SELECT, ®s->gqspisel); + writel(ZYNQMP_QSPI_GFIFO_ALL_INT_MASK, ®s->idisr); + writel(ZYNQMP_QSPI_FIFO_THRESHOLD, ®s->txftr); + writel(ZYNQMP_QSPI_FIFO_THRESHOLD, ®s->rxftr); + writel(ZYNQMP_QSPI_GFIFO_ALL_INT_MASK, ®s->isr); + + config_reg = readl(®s->confr); + config_reg &= ~(ZYNQMP_QSPI_GFIFO_STRT_MODE_MASK | + ZYNQMP_QSPI_CONFIG_MODE_EN_MASK); + config_reg |= ZYNQMP_QSPI_CONFIG_DMA_MODE | + ZYNQMP_QSPI_GFIFO_WP_HOLD | + ZYNQMP_QSPI_DFLT_BAUD_RATE_DIV; + writel(config_reg, ®s->confr); + + writel(ZYNQMP_QSPI_ENABLE_ENABLE_MASK, ®s->enbr); +} + +static u32 zynqmp_qspi_bus_select(struct zynqmp_qspi_priv *priv) +{ + u32 gqspi_fifo_reg = 0; + + gqspi_fifo_reg = ZYNQMP_QSPI_GFIFO_LOW_BUS | + ZYNQMP_QSPI_GFIFO_CS_LOWER; + + return gqspi_fifo_reg; +} + +static void zynqmp_qspi_fill_gen_fifo(struct zynqmp_qspi_priv *priv, + u32 gqspi_fifo_reg) +{ + struct zynqmp_qspi_regs *regs = priv->regs; + u32 reg; + + do { + reg = readl(®s->isr); + } while (!(reg & ZYNQMP_QSPI_IXR_GFEMTY_MASK)); + + writel(gqspi_fifo_reg, ®s->genfifo); +} + +static void zynqmp_qspi_chipselect(struct zynqmp_qspi_priv *priv, int is_on) +{ + u32 gqspi_fifo_reg = 0; + + if (is_on) { + gqspi_fifo_reg = zynqmp_qspi_bus_select(priv); + gqspi_fifo_reg |= ZYNQMP_QSPI_SPI_MODE_SPI | + ZYNQMP_QSPI_IMD_DATA_CS_ASSERT; + } else { + gqspi_fifo_reg = ZYNQMP_QSPI_GFIFO_LOW_BUS; + gqspi_fifo_reg |= ZYNQMP_QSPI_IMD_DATA_CS_DEASSERT; + } + + debug("GFIFO_CMD_CS: 0x%x\n", gqspi_fifo_reg); + + zynqmp_qspi_fill_gen_fifo(priv, gqspi_fifo_reg); +} + +void zynqmp_qspi_set_tapdelay(struct udevice *bus, u32 baudrateval) +{ + struct zynqmp_qspi_platdata *plat = bus->platdata; + struct zynqmp_qspi_priv *priv = dev_get_priv(bus); + struct zynqmp_qspi_regs *regs = priv->regs; + u32 tapdlybypass = 0, lpbkdlyadj = 0, datadlyadj = 0, clk_rate; + u32 reqhz = 0; + + clk_rate = plat->frequency; + reqhz = (clk_rate / (GQSPI_BAUD_DIV_SHIFT << baudrateval)); + + debug("%s, req_hz:%d, clk_rate:%d, baudrateval:%d\n", + __func__, reqhz, clk_rate, baudrateval); + + if (reqhz < GQSPI_FREQ_40MHZ) { + zynqmp_mmio_read(IOU_TAPDLY_BYPASS_OFST, &tapdlybypass); + tapdlybypass |= (TAP_DLY_BYPASS_LQSPI_RX_VALUE << + TAP_DLY_BYPASS_LQSPI_RX_SHIFT); + } else if (reqhz < GQSPI_FREQ_100MHZ) { + zynqmp_mmio_read(IOU_TAPDLY_BYPASS_OFST, &tapdlybypass); + tapdlybypass |= (TAP_DLY_BYPASS_LQSPI_RX_VALUE << + TAP_DLY_BYPASS_LQSPI_RX_SHIFT); + lpbkdlyadj = readl(®s->lpbkdly); + lpbkdlyadj |= (GQSPI_LPBK_DLY_ADJ_USE_LPBK_MASK); + datadlyadj = readl(®s->gqspidlyadj); + datadlyadj |= ((GQSPI_USE_DATA_DLY << GQSPI_USE_DATA_DLY_SHIFT) + | (GQSPI_DATA_DLY_ADJ_VALUE << + GQSPI_DATA_DLY_ADJ_SHIFT)); + } else if (reqhz < GQSPI_FREQ_150MHZ) { + lpbkdlyadj = readl(®s->lpbkdly); + lpbkdlyadj |= ((GQSPI_LPBK_DLY_ADJ_USE_LPBK_MASK) | + GQSPI_LPBK_DLY_ADJ_DLY_0); + } + + zynqmp_mmio_write(IOU_TAPDLY_BYPASS_OFST, IOU_TAPDLY_BYPASS_MASK, + tapdlybypass); + writel(lpbkdlyadj, ®s->lpbkdly); + writel(datadlyadj, ®s->gqspidlyadj); +} + +static int zynqmp_qspi_set_speed(struct udevice *bus, uint speed) +{ + struct zynqmp_qspi_platdata *plat = bus->platdata; + struct zynqmp_qspi_priv *priv = dev_get_priv(bus); + struct zynqmp_qspi_regs *regs = priv->regs; + u32 confr; + u8 baud_rate_val = 0; + + debug("%s\n", __func__); + if (speed > plat->frequency) + speed = plat->frequency; + + /* Set the clock frequency */ + confr = readl(®s->confr); + if (speed == 0) { + /* Set baudrate x8, if the freq is 0 */ + baud_rate_val = ZYNQMP_QSPI_DFLT_BAUD_RATE_VAL; + } else if (plat->speed_hz != speed) { + while ((baud_rate_val < 8) && + ((plat->frequency / + (2 << baud_rate_val)) > speed)) + baud_rate_val++; + + if (baud_rate_val > ZYNQMP_QSPI_MAX_BAUD_RATE_VAL) + baud_rate_val = ZYNQMP_QSPI_DFLT_BAUD_RATE_VAL; + + plat->speed_hz = plat->frequency / (2 << baud_rate_val); + } + confr &= ~ZYNQMP_QSPI_BAUD_DIV_MASK; + confr |= (baud_rate_val << 3); + writel(confr, ®s->confr); + + zynqmp_qspi_set_tapdelay(bus, baud_rate_val); + debug("regs=%p, speed=%d\n", priv->regs, plat->speed_hz); + + return 0; +} + +static int zynqmp_qspi_child_pre_probe(struct udevice *bus) +{ + struct spi_slave *slave = dev_get_parent_priv(bus); + struct zynqmp_qspi_platdata *plat = dev_get_platdata(bus->parent); + + slave->mode = plat->tx_rx_mode; + + return 0; +} + +static int zynqmp_qspi_probe(struct udevice *bus) +{ + struct zynqmp_qspi_platdata *plat = dev_get_platdata(bus); + struct zynqmp_qspi_priv *priv = dev_get_priv(bus); + + debug("%s: bus:%p, priv:%p\n", __func__, bus, priv); + + priv->regs = plat->regs; + priv->dma_regs = plat->dma_regs; + + /* init the zynq spi hw */ + zynqmp_qspi_init_hw(priv); + + return 0; +} + +static int zynqmp_qspi_set_mode(struct udevice *bus, uint mode) +{ + struct zynqmp_qspi_priv *priv = dev_get_priv(bus); + struct zynqmp_qspi_regs *regs = priv->regs; + u32 confr; + + debug("%s\n", __func__); + /* Set the SPI Clock phase and polarities */ + confr = readl(®s->confr); + confr &= ~(ZYNQMP_QSPI_CONFIG_CPHA_MASK | + ZYNQMP_QSPI_CONFIG_CPOL_MASK); + + if (priv->mode & SPI_CPHA) + confr |= ZYNQMP_QSPI_CONFIG_CPHA_MASK; + if (priv->mode & SPI_CPOL) + confr |= ZYNQMP_QSPI_CONFIG_CPOL_MASK; + + priv->mode = mode; + + debug("regs=%p, mode=%d\n", priv->regs, priv->mode); + + return 0; +} + +static int zynqmp_qspi_fill_tx_fifo(struct zynqmp_qspi_priv *priv, u32 size) +{ + u32 data; + u32 timeout = ZYNQMP_QSPI_TIMEOUT; + struct zynqmp_qspi_regs *regs = priv->regs; + u32 *buf = (u32 *)priv->tx_buf; + u32 len = size; + + debug("TxFIFO: 0x%x, size: 0x%x\n", readl(®s->isr), + size); + + while (size && timeout) { + if (readl(®s->isr) & + ZYNQMP_QSPI_IXR_TXNFULL_MASK) { + if (size >= 4) { + writel(*buf, ®s->txd0r); + buf++; + size -= 4; + } else { + switch (size) { + case 1: + data = *((u8 *)buf); + buf += 1; + data |= 0xFFFFFF00; + break; + case 2: + data = *((u16 *)buf); + buf += 2; + data |= 0xFFFF0000; + break; + case 3: + data = *((u16 *)buf); + buf += 2; + data |= (*((u8 *)buf) << 16); + buf += 1; + data |= 0xFF000000; + break; + } + writel(data, ®s->txd0r); + size = 0; + } + } else { + udelay(1); + timeout--; + } + } + if (!timeout) { + printf("%s: Timeout\n", __func__); + return -1; + } + + priv->tx_buf += len; + return 0; +} + +static void zynqmp_qspi_genfifo_cmd(struct zynqmp_qspi_priv *priv) +{ + u8 command = 1; + u32 gen_fifo_cmd; + u32 bytecount = 0; + + while (priv->len) { + gen_fifo_cmd = zynqmp_qspi_bus_select(priv); + gen_fifo_cmd |= ZYNQMP_QSPI_GFIFO_TX; + + if (command) { + command = 0; + last_cmd = *(u8 *)priv->tx_buf; + } + + gen_fifo_cmd |= ZYNQMP_QSPI_SPI_MODE_SPI; + gen_fifo_cmd |= *(u8 *)priv->tx_buf; + bytecount++; + priv->len--; + priv->tx_buf = (u8 *)priv->tx_buf + 1; + + debug("GFIFO_CMD_Cmd = 0x%x\n", gen_fifo_cmd); + + zynqmp_qspi_fill_gen_fifo(priv, gen_fifo_cmd); + } +} + +static u32 zynqmp_qspi_calc_exp(struct zynqmp_qspi_priv *priv, + u32 *gen_fifo_cmd) +{ + u32 expval = 8; + u32 len; + + while (1) { + if (priv->len > 255) { + if (priv->len & (1 << expval)) { + *gen_fifo_cmd &= ~ZYNQMP_QSPI_GFIFO_IMD_MASK; + *gen_fifo_cmd |= ZYNQMP_QSPI_GFIFO_EXP_MASK; + *gen_fifo_cmd |= expval; + priv->len -= (1 << expval); + return expval; + } + expval++; + } else { + *gen_fifo_cmd &= ~(ZYNQMP_QSPI_GFIFO_IMD_MASK | + ZYNQMP_QSPI_GFIFO_EXP_MASK); + *gen_fifo_cmd |= (u8)priv->len; + len = (u8)priv->len; + priv->len = 0; + return len; + } + } +} + +static int zynqmp_qspi_genfifo_fill_tx(struct zynqmp_qspi_priv *priv) +{ + u32 gen_fifo_cmd; + u32 len; + int ret = 0; + + gen_fifo_cmd = zynqmp_qspi_bus_select(priv); + gen_fifo_cmd |= ZYNQMP_QSPI_GFIFO_TX | + ZYNQMP_QSPI_GFIFO_DATA_XFR_MASK; + + if (last_cmd == QUAD_PAGE_PROGRAM_CMD) + gen_fifo_cmd |= ZYNQMP_QSPI_SPI_MODE_QSPI; + else + gen_fifo_cmd |= ZYNQMP_QSPI_SPI_MODE_SPI; + + while (priv->len) { + len = zynqmp_qspi_calc_exp(priv, &gen_fifo_cmd); + zynqmp_qspi_fill_gen_fifo(priv, gen_fifo_cmd); + + debug("GFIFO_CMD_TX:0x%x\n", gen_fifo_cmd); + + if (gen_fifo_cmd & ZYNQMP_QSPI_GFIFO_EXP_MASK) + ret = zynqmp_qspi_fill_tx_fifo(priv, + 1 << len); + else + ret = zynqmp_qspi_fill_tx_fifo(priv, + len); + + if (ret) + return ret; + } + return ret; +} + +static int zynqmp_qspi_start_dma(struct zynqmp_qspi_priv *priv, + u32 gen_fifo_cmd, u32 *buf) +{ + u32 addr; + u32 size, len; + u32 timeout = ZYNQMP_QSPI_TIMEOUT; + u32 actuallen = priv->len; + struct zynqmp_qspi_dma_regs *dma_regs = priv->dma_regs; + + writel((unsigned long)buf, &dma_regs->dmadst); + writel(roundup(priv->len, 4), &dma_regs->dmasize); + writel(ZYNQMP_QSPI_DMA_DST_I_STS_MASK, &dma_regs->dmaier); + addr = (unsigned long)buf; + size = roundup(priv->len, ARCH_DMA_MINALIGN); + flush_dcache_range(addr, addr + size); + + while (priv->len) { + len = zynqmp_qspi_calc_exp(priv, &gen_fifo_cmd); + if (!(gen_fifo_cmd & ZYNQMP_QSPI_GFIFO_EXP_MASK) && + (len % 4)) { + gen_fifo_cmd &= ~(0xFF); + gen_fifo_cmd |= (len / 4 + 1) * 4; + } + zynqmp_qspi_fill_gen_fifo(priv, gen_fifo_cmd); + + debug("GFIFO_CMD_RX:0x%x\n", gen_fifo_cmd); + } + + while (timeout) { + if (readl(&dma_regs->dmaisr) & + ZYNQMP_QSPI_DMA_DST_I_STS_DONE) { + writel(ZYNQMP_QSPI_DMA_DST_I_STS_DONE, + &dma_regs->dmaisr); + break; + } + udelay(1); + timeout--; + } + + debug("buf:0x%lx, rxbuf:0x%lx, *buf:0x%x len: 0x%x\n", + (unsigned long)buf, (unsigned long)priv->rx_buf, *buf, + actuallen); + if (!timeout) { + printf("DMA Timeout:0x%x\n", readl(&dma_regs->dmaisr)); + return -1; + } + + if (buf != priv->rx_buf) + memcpy(priv->rx_buf, buf, actuallen); + + return 0; +} + +static int zynqmp_qspi_genfifo_fill_rx(struct zynqmp_qspi_priv *priv) +{ + u32 gen_fifo_cmd; + u32 *buf; + u32 actuallen = priv->len; + + gen_fifo_cmd = zynqmp_qspi_bus_select(priv); + gen_fifo_cmd |= ZYNQMP_QSPI_GFIFO_RX | + ZYNQMP_QSPI_GFIFO_DATA_XFR_MASK; + + if (last_cmd == QUAD_OUT_READ_CMD) + gen_fifo_cmd |= ZYNQMP_QSPI_SPI_MODE_QSPI; + else if (last_cmd == DUAL_OUTPUT_FASTRD_CMD) + gen_fifo_cmd |= ZYNQMP_QSPI_SPI_MODE_DUAL_SPI; + else + gen_fifo_cmd |= ZYNQMP_QSPI_SPI_MODE_SPI; + + /* + * Check if receive buffer is aligned to 4 byte and length + * is multiples of four byte as we are using dma to receive. + */ + if (!((unsigned long)priv->rx_buf & (ZYNQMP_QSPI_DMA_ALIGN - 1)) && + !(actuallen % ZYNQMP_QSPI_DMA_ALIGN)) { + buf = (u32 *)priv->rx_buf; + return zynqmp_qspi_start_dma(priv, gen_fifo_cmd, buf); + } + + ALLOC_CACHE_ALIGN_BUFFER(u8, tmp, roundup(priv->len, + ZYNQMP_QSPI_DMA_ALIGN)); + buf = (u32 *)tmp; + return zynqmp_qspi_start_dma(priv, gen_fifo_cmd, buf); +} + +static int zynqmp_qspi_start_transfer(struct zynqmp_qspi_priv *priv) +{ + int ret = 0; + + if (priv->is_inst) { + if (priv->tx_buf) + zynqmp_qspi_genfifo_cmd(priv); + else + ret = -1; + } else { + if (priv->tx_buf) + ret = zynqmp_qspi_genfifo_fill_tx(priv); + else if (priv->rx_buf) + ret = zynqmp_qspi_genfifo_fill_rx(priv); + else + ret = -1; + } + return ret; +} + +static int zynqmp_qspi_transfer(struct zynqmp_qspi_priv *priv) +{ + static unsigned int cs_change = 1; + int status = 0; + + debug("%s\n", __func__); + + while (1) { + /* Select the chip if required */ + if (cs_change) + zynqmp_qspi_chipselect(priv, 1); + + cs_change = priv->cs_change; + + if (!priv->tx_buf && !priv->rx_buf && priv->len) { + status = -1; + break; + } + + /* Request the transfer */ + if (priv->len) { + status = zynqmp_qspi_start_transfer(priv); + priv->is_inst = 0; + if (status < 0) + break; + } + + if (cs_change) + /* Deselect the chip */ + zynqmp_qspi_chipselect(priv, 0); + break; + } + + return status; +} + +static int zynqmp_qspi_claim_bus(struct udevice *dev) +{ + struct udevice *bus = dev->parent; + struct zynqmp_qspi_priv *priv = dev_get_priv(bus); + struct zynqmp_qspi_regs *regs = priv->regs; + + debug("%s\n", __func__); + writel(ZYNQMP_QSPI_ENABLE_ENABLE_MASK, ®s->enbr); + + return 0; +} + +static int zynqmp_qspi_release_bus(struct udevice *dev) +{ + struct udevice *bus = dev->parent; + struct zynqmp_qspi_priv *priv = dev_get_priv(bus); + struct zynqmp_qspi_regs *regs = priv->regs; + + debug("%s\n", __func__); + writel(~ZYNQMP_QSPI_ENABLE_ENABLE_MASK, ®s->enbr); + + return 0; +} + +int zynqmp_qspi_xfer(struct udevice *dev, unsigned int bitlen, const void *dout, + void *din, unsigned long flags) +{ + struct udevice *bus = dev->parent; + struct zynqmp_qspi_priv *priv = dev_get_priv(bus); + + debug("%s: priv: 0x%08lx bitlen: %d dout: 0x%08lx ", __func__, + (unsigned long)priv, bitlen, (unsigned long)dout); + debug("din: 0x%08lx flags: 0x%lx\n", (unsigned long)din, flags); + + priv->tx_buf = dout; + priv->rx_buf = din; + priv->len = bitlen / 8; + + /* + * Festering sore. + * Assume that the beginning of a transfer with bits to + * transmit must contain a device command. + */ + if (dout && flags & SPI_XFER_BEGIN) + priv->is_inst = 1; + else + priv->is_inst = 0; + + if (flags & SPI_XFER_END) + priv->cs_change = 1; + else + priv->cs_change = 0; + + zynqmp_qspi_transfer(priv); + + return 0; +} + +static const struct dm_spi_ops zynqmp_qspi_ops = { + .claim_bus = zynqmp_qspi_claim_bus, + .release_bus = zynqmp_qspi_release_bus, + .xfer = zynqmp_qspi_xfer, + .set_speed = zynqmp_qspi_set_speed, + .set_mode = zynqmp_qspi_set_mode, +}; + +static const struct udevice_id zynqmp_qspi_ids[] = { + { .compatible = "xlnx,zynqmp-qspi-1.0" }, + { } +}; + +U_BOOT_DRIVER(zynqmp_qspi) = { + .name = "zynqmp_qspi", + .id = UCLASS_SPI, + .of_match = zynqmp_qspi_ids, + .ops = &zynqmp_qspi_ops, + .ofdata_to_platdata = zynqmp_qspi_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct zynqmp_qspi_platdata), + .priv_auto_alloc_size = sizeof(struct zynqmp_qspi_priv), + .probe = zynqmp_qspi_probe, + .child_pre_probe = zynqmp_qspi_child_pre_probe, +};
This patch adds qspi driver support for all ZynqMP ZCU102 boards.
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- Changes for v2: - Rebased on top of latest master and enabled qspi for all zcu102 boards. --- configs/xilinx_zynqmp_zcu102_rev1_0_defconfig | 3 +++ configs/xilinx_zynqmp_zcu102_revA_defconfig | 3 +++ configs/xilinx_zynqmp_zcu102_revB_defconfig | 3 +++ 3 files changed, 9 insertions(+)
diff --git a/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig b/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig index c761d49..021c4ef 100644 --- a/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig +++ b/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig @@ -4,6 +4,7 @@ CONFIG_ARCH_ZYNQMP=y CONFIG_SYS_TEXT_BASE=0x8000000 CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_IDENT_STRING=" Xilinx ZynqMP ZCU102 rev1.0" +CONFIG_ZYNQMP_QSPI=y CONFIG_ZYNQMP_USB=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zcu102-rev1.0" CONFIG_DEBUG_UART=y @@ -34,6 +35,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y CONFIG_CMD_USB=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TIME=y @@ -57,6 +59,7 @@ CONFIG_MISC=y CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y +CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/xilinx_zynqmp_zcu102_revA_defconfig b/configs/xilinx_zynqmp_zcu102_revA_defconfig index 43b533f..a7fcbb7 100644 --- a/configs/xilinx_zynqmp_zcu102_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revA_defconfig @@ -4,6 +4,7 @@ CONFIG_ARCH_ZYNQMP=y CONFIG_SYS_TEXT_BASE=0x8000000 CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_IDENT_STRING=" Xilinx ZynqMP ZCU102 revA" +CONFIG_ZYNQMP_QSPI=y CONFIG_ZYNQMP_USB=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zcu102-revA" CONFIG_DEBUG_UART=y @@ -34,6 +35,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y CONFIG_CMD_USB=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TIME=y @@ -57,6 +59,7 @@ CONFIG_MISC=y CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y +CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/xilinx_zynqmp_zcu102_revB_defconfig b/configs/xilinx_zynqmp_zcu102_revB_defconfig index c2d0ddb..e744241 100644 --- a/configs/xilinx_zynqmp_zcu102_revB_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revB_defconfig @@ -4,6 +4,7 @@ CONFIG_ARCH_ZYNQMP=y CONFIG_SYS_TEXT_BASE=0x8000000 CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_IDENT_STRING=" Xilinx ZynqMP ZCU102 revB" +CONFIG_ZYNQMP_QSPI=y CONFIG_ZYNQMP_USB=y CONFIG_DEFAULT_DEVICE_TREE="zynqmp-zcu102-revB" CONFIG_DEBUG_UART=y @@ -34,6 +35,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y CONFIG_CMD_USB=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TIME=y @@ -57,6 +59,7 @@ CONFIG_MISC=y CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y +CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_MACRONIX=y
Hi Jagan,
Ping!
Thanks, Siva
-----Original Message----- From: Siva Durga Prasad Paladugu [mailto:siva.durga.paladugu@xilinx.com] Sent: Thursday, January 04, 2018 1:08 PM To: u-boot@lists.denx.de Cc: jagannadh.teki@gmail.com; Siva Durga Prasad Paladugu sivadur@xilinx.com Subject: [PATCH v2 1/2] spi: zynqmp_qspi: Add support for ZynqMP qspi driver
Changes from v1:
+config ZYNQMP_QSPI
- bool "Configure ZynqMP QSPI"
- select DM_SPI
- help
- (C) Copyright 2014 - 2015 Xilinx
- Xilinx ZynqMP Quad-SPI(QSPI) controller driver (master mode only)
- QSPI Interrupt Registers bit Masks
- All the four interrupt registers (Status/Mask/Enable/Disable) have
+the same
- bit definitions.
- ZYNQMP_QSPI_IXR_RXNEMTY_MASK)
- QSPI Enable Register bit Masks
- This register is used to enable or disable the QSPI controller */
- u32 confr; /* 0x00 */
- u32 isr; /* 0x04 */
- u32 ier; /* 0x08 */
- u32 idisr; /* 0x0C */
- u32 imaskr; /* 0x10 */
- u32 enbr; /* 0x14 */
- u32 dr; /* 0x18 */
- u32 txd0r; /* 0x1C */
- u32 drxr; /* 0x20 */
- u32 sicr; /* 0x24 */
- u32 txftr; /* 0x28 */
- u32 rxftr; /* 0x2C */
- u32 gpior; /* 0x30 */
- u32 reserved0; /* 0x34 */
- u32 lpbkdly; /* 0x38 */
- u32 reserved1; /* 0x3C */
- u32 genfifo; /* 0x40 */
- u32 gqspisel; /* 0x44 */
- u32 reserved2; /* 0x48 */
- u32 gqfifoctrl; /* 0x4C */
- u32 gqfthr; /* 0x50 */
- u32 gqpollcfg; /* 0x54 */
- u32 gqpollto; /* 0x58 */
- u32 gqxfersts; /* 0x5C */
- u32 gqfifosnap; /* 0x60 */
- u32 gqrxcpy; /* 0x64 */
- u32 reserved3[36]; /* 0x68 */
- u32 gqspidlyadj; /* 0xF8 */
- u32 dmadst; /* 0x00 */
- u32 dmasize; /* 0x04 */
- u32 dmasts; /* 0x08 */
- u32 dmactrl; /* 0x0C */
- u32 reserved0; /* 0x10 */
- u32 dmaisr; /* 0x14 */
- u32 dmaier; /* 0x18 */
- u32 dmaidr; /* 0x1C */
- u32 dmaimr; /* 0x20 */
- u32 dmactrl2; /* 0x24 */
- u32 dmadstmsb; /* 0x28 */
- struct zynqmp_qspi_regs *regs;
- struct zynqmp_qspi_dma_regs *dma_regs;
- u32 frequency;
- u32 speed_hz;
- unsigned int tx_rx_mode;
- u8 mode;
- const void *tx_buf;
- void *rx_buf;
- unsigned int len;
- int bytes_to_transfer;
- int bytes_to_receive;
- unsigned int is_inst;
- unsigned int cs_change:1;
+static int zynqmp_qspi_ofdata_to_platdata(struct udevice *bus) {
- struct zynqmp_qspi_platdata *plat = bus->platdata;
- u32 mode = 0;
- u32 value;
- int ret;
- struct clk clk;
- unsigned long clock;
- debug("%s\n", __func__);
- plat->regs = (struct zynqmp_qspi_regs *)(devfdt_get_addr(bus) +
- plat->dma_regs = (struct zynqmp_qspi_dma_regs *)
- ret = clk_get_by_index(bus, 0, &clk);
- if (ret < 0) {
return ret;
- clock = clk_get_rate(&clk);
- if (IS_ERR_VALUE(clock)) {
return clock;
- debug("%s: CLK %ld\n", __func__, clock);
- ret = clk_enable(&clk);
- if (ret && ret != -ENOSYS) {
return ret;
- value = dev_read_u32_default(bus, "spi-rx-bus-width", 1);
- switch (value) {
- case 1:
break;
- case 2:
break;
- case 4:
break;
- default:
break;
- value = dev_read_u32_default(bus, "spi-tx-bus-width", 1);
- switch (value) {
- case 1:
break;
- case 2:
break;
- case 4:
break;
- default:
break;
- plat->tx_rx_mode = mode;
- plat->frequency = clock;
- plat->speed_hz = plat->frequency;
+static void zynqmp_qspi_init_hw(struct zynqmp_qspi_priv *priv) {
- u32 config_reg;
- struct zynqmp_qspi_regs *regs = priv->regs;
- writel(ZYNQMP_QSPI_GFIFO_SELECT, ®s->gqspisel);
- writel(ZYNQMP_QSPI_GFIFO_ALL_INT_MASK, ®s->idisr);
- writel(ZYNQMP_QSPI_FIFO_THRESHOLD, ®s->txftr);
- writel(ZYNQMP_QSPI_FIFO_THRESHOLD, ®s->rxftr);
- writel(ZYNQMP_QSPI_GFIFO_ALL_INT_MASK, ®s->isr);
- config_reg = readl(®s->confr);
- config_reg &= ~(ZYNQMP_QSPI_GFIFO_STRT_MODE_MASK |
- config_reg |= ZYNQMP_QSPI_CONFIG_DMA_MODE |
- writel(config_reg, ®s->confr);
- writel(ZYNQMP_QSPI_ENABLE_ENABLE_MASK, ®s->enbr); }
+static u32 zynqmp_qspi_bus_select(struct zynqmp_qspi_priv *priv) {
- u32 gqspi_fifo_reg = 0;
- gqspi_fifo_reg = ZYNQMP_QSPI_GFIFO_LOW_BUS |
- return gqspi_fifo_reg;
u32 gqspi_fifo_reg)
- u32 reg;
- do {
- } while (!(reg & ZYNQMP_QSPI_IXR_GFEMTY_MASK));
- writel(gqspi_fifo_reg, ®s->genfifo); }
+static void zynqmp_qspi_chipselect(struct zynqmp_qspi_priv *priv, int +is_on) {
- if (is_on) {
- } else {
gqspi_fifo_reg |=
- debug("GFIFO_CMD_CS: 0x%x\n", gqspi_fifo_reg);
- zynqmp_qspi_fill_gen_fifo(priv, gqspi_fifo_reg); }
+void zynqmp_qspi_set_tapdelay(struct udevice *bus, u32 baudrateval) {
- struct zynqmp_qspi_priv *priv = dev_get_priv(bus);
- u32 tapdlybypass = 0, lpbkdlyadj = 0, datadlyadj = 0, clk_rate;
- u32 reqhz = 0;
- clk_rate = plat->frequency;
- reqhz = (clk_rate / (GQSPI_BAUD_DIV_SHIFT << baudrateval));
- debug("%s, req_hz:%d, clk_rate:%d, baudrateval:%d\n",
- if (reqhz < GQSPI_FREQ_40MHZ) {
&tapdlybypass);
- } else if (reqhz < GQSPI_FREQ_100MHZ) {
&tapdlybypass);
- } else if (reqhz < GQSPI_FREQ_150MHZ) {
- zynqmp_mmio_write(IOU_TAPDLY_BYPASS_OFST,
tapdlybypass);
- writel(lpbkdlyadj, ®s->lpbkdly);
- writel(datadlyadj, ®s->gqspidlyadj); }
+static int zynqmp_qspi_set_speed(struct udevice *bus, uint speed) {
- u32 confr;
- u8 baud_rate_val = 0;
- if (speed > plat->frequency)
- /* Set the clock frequency */
- confr = readl(®s->confr);
- if (speed == 0) {
- } else if (plat->speed_hz != speed) {
((plat->frequency /
baud_rate_val++;
baud_rate_val =
- confr &= ~ZYNQMP_QSPI_BAUD_DIV_MASK;
- confr |= (baud_rate_val << 3);
- writel(confr, ®s->confr);
- zynqmp_qspi_set_tapdelay(bus, baud_rate_val);
- debug("regs=%p, speed=%d\n", priv->regs, plat->speed_hz);
+static int zynqmp_qspi_child_pre_probe(struct udevice *bus) {
- struct spi_slave *slave = dev_get_parent_priv(bus);
- struct zynqmp_qspi_platdata *plat = dev_get_platdata(bus-
parent);
- slave->mode = plat->tx_rx_mode;
+static int zynqmp_qspi_probe(struct udevice *bus) {
- struct zynqmp_qspi_platdata *plat = dev_get_platdata(bus);
- debug("%s: bus:%p, priv:%p\n", __func__, bus, priv);
- priv->regs = plat->regs;
- priv->dma_regs = plat->dma_regs;
- /* init the zynq spi hw */
- zynqmp_qspi_init_hw(priv);
+static int zynqmp_qspi_set_mode(struct udevice *bus, uint mode) {
- u32 confr;
- /* Set the SPI Clock phase and polarities */
- confr &= ~(ZYNQMP_QSPI_CONFIG_CPHA_MASK |
- if (priv->mode & SPI_CPHA)
- if (priv->mode & SPI_CPOL)
- priv->mode = mode;
- debug("regs=%p, mode=%d\n", priv->regs, priv->mode);
+static int zynqmp_qspi_fill_tx_fifo(struct zynqmp_qspi_priv *priv, u32 +size) {
- u32 data;
- u32 timeout = ZYNQMP_QSPI_TIMEOUT;
- u32 *buf = (u32 *)priv->tx_buf;
- u32 len = size;
- debug("TxFIFO: 0x%x, size: 0x%x\n", readl(®s->isr),
size);
- while (size && timeout) {
if (size >= 4) {
buf++;
size -= 4;
} else {
switch (size) {
case 1:
buf += 1;
data |= 0xFFFFFF00;
break;
case 2:
buf += 2;
data |= 0xFFFF0000;
break;
case 3:
buf += 2;
buf += 1;
data |= 0xFF000000;
break;
size = 0;
} else {
udelay(1);
timeout--;
- if (!timeout) {
return -1;
- priv->tx_buf += len;
+static void zynqmp_qspi_genfifo_cmd(struct zynqmp_qspi_priv *priv) {
- u8 command = 1;
- u32 gen_fifo_cmd;
- u32 bytecount = 0;
- while (priv->len) {
if (command) {
command = 0;
bytecount++;
priv->len--;
u32 *gen_fifo_cmd)
- u32 expval = 8;
- u32 len;
- while (1) {
*gen_fifo_cmd &=
*gen_fifo_cmd |=
return expval;
expval++;
} else {
*gen_fifo_cmd &=
priv->len = 0;
return len;
+static int zynqmp_qspi_genfifo_fill_tx(struct zynqmp_qspi_priv *priv) {
- u32 gen_fifo_cmd;
- u32 len;
- int ret = 0;
- gen_fifo_cmd = zynqmp_qspi_bus_select(priv);
- gen_fifo_cmd |= ZYNQMP_QSPI_GFIFO_TX |
- if (last_cmd == QUAD_PAGE_PROGRAM_CMD)
- else
1 << len);
else
len);
if (ret)
return ret;
- return ret;
- u32 addr;
- u32 size, len;
- u32 actuallen = priv->len;
- struct zynqmp_qspi_dma_regs *dma_regs = priv->dma_regs;
- writel((unsigned long)buf, &dma_regs->dmadst);
- writel(roundup(priv->len, 4), &dma_regs->dmasize);
- writel(ZYNQMP_QSPI_DMA_DST_I_STS_MASK, &dma_regs-
dmaier);
- addr = (unsigned long)buf;
- size = roundup(priv->len, ARCH_DMA_MINALIGN);
- flush_dcache_range(addr, addr + size);
(len % 4)) {
- while (timeout) {
&dma_regs->dmaisr);
break;
udelay(1);
timeout--;
- debug("buf:0x%lx, rxbuf:0x%lx, *buf:0x%x len: 0x%x\n",
actuallen);
- if (!timeout) {
return -1;
- if (buf != priv->rx_buf)
+static int zynqmp_qspi_genfifo_fill_rx(struct zynqmp_qspi_priv *priv) {
- u32 gen_fifo_cmd;
- u32 *buf;
- gen_fifo_cmd |= ZYNQMP_QSPI_GFIFO_RX |
- if (last_cmd == QUAD_OUT_READ_CMD)
- else if (last_cmd == DUAL_OUTPUT_FASTRD_CMD)
- else
- if (!((unsigned long)priv->rx_buf & (ZYNQMP_QSPI_DMA_ALIGN -
1)) &&
- ALLOC_CACHE_ALIGN_BUFFER(u8, tmp, roundup(priv->len,
- buf = (u32 *)tmp;
- return zynqmp_qspi_start_dma(priv, gen_fifo_cmd, buf); }
+static int zynqmp_qspi_start_transfer(struct zynqmp_qspi_priv *priv) {
- int ret = 0;
- if (priv->is_inst) {
if (priv->tx_buf)
else
ret = -1;
- } else {
if (priv->tx_buf)
else
ret = -1;
- return ret;
+static int zynqmp_qspi_transfer(struct zynqmp_qspi_priv *priv) {
- static unsigned int cs_change = 1;
- int status = 0;
- while (1) {
if (cs_change)
status = -1;
break;
if (priv->len) {
priv->is_inst = 0;
if (status < 0)
break;
if (cs_change)
break;
- return status;
+static int zynqmp_qspi_claim_bus(struct udevice *dev) {
- struct udevice *bus = dev->parent;
+static int zynqmp_qspi_release_bus(struct udevice *dev) {
- writel(~ZYNQMP_QSPI_ENABLE_ENABLE_MASK, ®s->enbr);
- debug("%s: priv: 0x%08lx bitlen: %d dout: 0x%08lx ", __func__,
- debug("din: 0x%08lx flags: 0x%lx\n", (unsigned long)din, flags);
- priv->tx_buf = dout;
- priv->rx_buf = din;
- priv->len = bitlen / 8;
* Festering sore.
- if (dout && flags & SPI_XFER_BEGIN)
priv->is_inst = 1;
- else
priv->is_inst = 0;
- if (flags & SPI_XFER_END)
- else
- zynqmp_qspi_transfer(priv);
- .claim_bus = zynqmp_qspi_claim_bus,
- .release_bus = zynqmp_qspi_release_bus,
- .xfer = zynqmp_qspi_xfer,
- .set_speed = zynqmp_qspi_set_speed,
- .set_mode = zynqmp_qspi_set_mode,
- { .compatible = "xlnx,zynqmp-qspi-1.0" },
- .name = "zynqmp_qspi",
- .id = UCLASS_SPI,
- .of_match = zynqmp_qspi_ids,
- .ops = &zynqmp_qspi_ops,
- .ofdata_to_platdata = zynqmp_qspi_ofdata_to_platdata,
- .platdata_auto_alloc_size = sizeof(struct zynqmp_qspi_platdata),
- .priv_auto_alloc_size = sizeof(struct zynqmp_qspi_priv),
- .probe = zynqmp_qspi_probe,
- .child_pre_probe = zynqmp_qspi_child_pre_probe, };
-- 2.7.4
On Thu, Jan 4, 2018 at 1:07 PM, Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com wrote:
Changes from v1:
Was this gqspi like linux spi-zynqmp-gqspi.c or different?
+config ZYNQMP_QSPI
select DM_SPI
help
I've commented this before, what is the reason for adding spi kconfig entry in arch area instead of drivers/spi?
- All the four interrupt registers (Status/Mask/Enable/Disable) have the same
- bit definitions.
u32 isr; /* 0x04 */
u32 ier; /* 0x08 */
u32 dr; /* 0x18 */
Move all these on driver file itself, also try to use short macro names.
This I've already commented and still there any reason?
u32 frequency;
u32 speed_hz;
u8 mode;
const void *tx_buf;
void *rx_buf;
unsigned int len;
u32 mode = 0;
u32 value;
int ret;
struct clk clk;
no need
if (ret < 0) {
return ret;
return clock;
return ret;
switch (value) {
case 1:
break;
case 2:
break;
case 4:
break;
default:
break;
switch (value) {
case 1:
break;
case 2:
break;
case 4:
break;
default:
break;
why we need this? all these are generic stuff which is available at spi-uclass.c
u32 config_reg;
u32 gqspi_fifo_reg)
u32 reg;
do {
infinite loop? use wait_for_bit with definete duration.
if (is_on) {
} else {
u32 reqhz = 0;
tapdlybypass);
u32 confr;
no need
if (speed == 0) {
((plat->frequency /
baud_rate_val++;
mode we can get it from spi-uclass, no need to have this.
no need
u32 confr;
missing confr write?
priv->mode = mode;
no need
u32 data;
u32 len = size;
size);
if (size >= 4) {
buf++;
size -= 4;
} else {
switch (size) {
case 1:
buf += 1;
data |= 0xFFFFFF00;
break;
case 2:
buf += 2;
data |= 0xFFFF0000;
break;
case 3:
buf += 2;
buf += 1;
data |= 0xFF000000;
break;
size = 0;
} else {
udelay(1);
timeout--;
if (!timeout) {
return -1;
u8 command = 1;
u32 gen_fifo_cmd;
u32 bytecount = 0;
while (priv->len) {
if (command) {
command = 0;
bytecount++;
priv->len--;
u32 *gen_fifo_cmd)
u32 expval = 8;
u32 len;
while (1) {
return expval;
expval++;
} else {
priv->len = 0;
return len;
u32 gen_fifo_cmd;
u32 len;
int ret = 0;
else
while (priv->len) {
1 << len);
else
len);
if (ret)
return ret;
return ret;
u32 addr;
u32 size, len;
while (priv->len) {
(len % 4)) {
while (timeout) {
&dma_regs->dmaisr);
break;
udelay(1);
timeout--;
wait_for_bit?
actuallen);
if (!timeout) {
return -1;
u32 gen_fifo_cmd;
u32 *buf;
else
buf = (u32 *)tmp;
int ret = 0;
if (priv->tx_buf)
else
ret = -1;
} else {
if (priv->tx_buf)
else
ret = -1;
return ret;
int status = 0;
while (1) {
if (cs_change)
status = -1;
break;
if (priv->len) {
priv->is_inst = 0;
if (status < 0)
break;
if (cs_change)
break;
return status;
no need
no need
Hi Jagan,
-----Original Message----- From: Jagan Teki [mailto:jagan@amarulasolutions.com] Sent: Tuesday, January 23, 2018 10:41 PM To: Siva Durga Prasad Paladugu sivadur@xilinx.com Cc: U-Boot-Denx u-boot@lists.denx.de; Siva Durga Prasad Paladugu sivadur@xilinx.com Subject: Re: [U-Boot] [PATCH v2 1/2] spi: zynqmp_qspi: Add support for ZynqMP qspi driver
Changes from v1:
Yes.
+config ZYNQMP_QSPI
select DM_SPI
help
I might have missed it, Will move to drivers/spi
+the same
- bit definitions.
FIFO Overflow */
FIFO is full */
FIFO Not Empty */
Enable Bit
+Mask */
+#define ZYNQMP_QSPI_GFIFO_LOW_BUS BIT(14) +#define ZYNQMP_QSPI_GFIFO_CS_LOWER BIT(12) +#define ZYNQMP_QSPI_GFIFO_UP_BUS BIT(15) +#define ZYNQMP_QSPI_GFIFO_CS_UPPER BIT(13) +#define ZYNQMP_QSPI_SPI_MODE_QSPI (3 << 10) +#define ZYNQMP_QSPI_SPI_MODE_SPI BIT(10) +#define ZYNQMP_QSPI_SPI_MODE_DUAL_SPI (2 << 10) +#define ZYNQMP_QSPI_IMD_DATA_CS_ASSERT 5 +#define ZYNQMP_QSPI_IMD_DATA_CS_DEASSERT 5 +#define ZYNQMP_QSPI_GFIFO_TX BIT(16) +#define ZYNQMP_QSPI_GFIFO_RX BIT(17) +#define ZYNQMP_QSPI_GFIFO_STRIPE_MASK BIT(18) +#define ZYNQMP_QSPI_GFIFO_IMD_MASK 0xFF +#define ZYNQMP_QSPI_GFIFO_EXP_MASK BIT(9) +#define ZYNQMP_QSPI_GFIFO_DATA_XFR_MASK BIT(8) +#define ZYNQMP_QSPI_STRT_GEN_FIFO BIT(28) +#define ZYNQMP_QSPI_GEN_FIFO_STRT_MOD BIT(29) +#define ZYNQMP_QSPI_GFIFO_WP_HOLD BIT(19) +#define ZYNQMP_QSPI_BAUD_DIV_MASK (7 << 3) +#define ZYNQMP_QSPI_DFLT_BAUD_RATE_DIV BIT(3) #define +ZYNQMP_QSPI_GFIFO_ALL_INT_MASK 0xFBE #define +ZYNQMP_QSPI_DMA_DST_I_STS_DONE BIT(1) #define +ZYNQMP_QSPI_DMA_DST_I_STS_MASK 0xFE +#define MODEBITS 0x6
+#define ZYNQMP_QSPI_DMA_ALIGN 0x4 +#define ZYNQMP_QSPI_MAX_BAUD_RATE_VAL 7 #define +ZYNQMP_QSPI_DFLT_BAUD_RATE_VAL 2
+#define GQSPI_BAUD_DIV_SHIFT 2 +#define GQSPI_LPBK_DLY_ADJ_LPBK_SHIFT 5 +#define GQSPI_LPBK_DLY_ADJ_DLY_1 0x2 +#define GQSPI_LPBK_DLY_ADJ_DLY_1_SHIFT 3 +#define GQSPI_LPBK_DLY_ADJ_DLY_0 0x3 +#define GQSPI_USE_DATA_DLY 0x1 +#define GQSPI_USE_DATA_DLY_SHIFT 31 +#define GQSPI_DATA_DLY_ADJ_VALUE 0x2 +#define GQSPI_DATA_DLY_ADJ_SHIFT 28 +#define TAP_DLY_BYPASS_LQSPI_RX_VALUE 0x1 #define +TAP_DLY_BYPASS_LQSPI_RX_SHIFT 2 +#define GQSPI_DATA_DLY_ADJ_OFST 0x000001F8 +#define IOU_TAPDLY_BYPASS_OFST 0xFF180390 +#define GQSPI_LPBK_DLY_ADJ_USE_LPBK_MASK 0x00000020 +#define GQSPI_FREQ_40MHZ 40000000 +#define GQSPI_FREQ_100MHZ 100000000 +#define GQSPI_FREQ_150MHZ 150000000 +#define IOU_TAPDLY_BYPASS_MASK 0x7
u32 isr; /* 0x04 */
u32 ier; /* 0x08 */
u32 dr; /* 0x18 */
I moved to .h based on v1 comments, now vice versa. I didn’t see any problem in having these in .h
u32 frequency;
u32 speed_hz;
u8 mode;
const void *tx_buf;
void *rx_buf;
unsigned int len;
u32 mode = 0;
u32 value;
int ret;
struct clk clk;
no need
Any issue in having it with debug..?? I can remove if you don’t like.
- ZYNQMP_GQSPI_DMA_REG_OFFSET);
if (ret < 0) {
return ret;
return clock;
return ret;
switch (value) {
case 1:
break;
case 2:
break;
case 4:
break;
default:
break;
switch (value) {
case 1:
break;
case 2:
break;
case 4:
break;
default:
break;
why we need this? all these are generic stuff which is available at spi- uclass.c
Somehow I am not able to get these from spi-uclass.c , the routine which reads all these info from dt in spi-uclass.c is never getting invoked in my flow. I checked other driver as well,. Do you have an idea on why is it so?
u32 config_reg;
u32 gqspi_fifo_reg) {
u32 reg;
do {
Sure.
if (is_on) {
} else {
u32 reqhz = 0;
&tapdlybypass);
&tapdlybypass);
tapdlybypass);
u32 confr;
no need
if (speed == 0) {
((plat->frequency /
baud_rate_val++;
baud_rate_val =
- ZYNQMP_QSPI_DFLT_BAUD_RATE_VAL;
+dev_get_platdata(bus->parent);
Same as above comment about spi-uclass.c .
no need
u32 confr;
Will check and correct.
priv->mode = mode;
no need
+static int zynqmp_qspi_fill_tx_fifo(struct zynqmp_qspi_priv *priv, +u32 size) {
u32 data;
u32 len = size;
size);
if (size >= 4) {
buf++;
size -= 4;
} else {
switch (size) {
case 1:
buf += 1;
data |= 0xFFFFFF00;
break;
case 2:
buf += 2;
data |= 0xFFFF0000;
break;
case 3:
buf += 2;
buf += 1;
data |= 0xFF000000;
break;
size = 0;
} else {
udelay(1);
timeout--;
if (!timeout) {
return -1;
u8 command = 1;
u32 gen_fifo_cmd;
u32 bytecount = 0;
while (priv->len) {
if (command) {
command = 0;
bytecount++;
priv->len--;
u32 *gen_fifo_cmd) {
u32 expval = 8;
u32 len;
while (1) {
*gen_fifo_cmd &=
return expval;
expval++;
} else {
priv->len = 0;
return len;
u32 gen_fifo_cmd;
u32 len;
int ret = 0;
else
while (priv->len) {
1 << len);
else
len);
if (ret)
return ret;
return ret;
u32 gen_fifo_cmd, u32 *buf) {
u32 addr;
u32 size, len;
dmaier);
while (priv->len) {
(len % 4)) {
while (timeout) {
&dma_regs->dmaisr);
break;
udelay(1);
timeout--;
wait_for_bit?
Ok, will correct.
Thanks, Siva
actuallen);
if (!timeout) {
return -1;
u32 gen_fifo_cmd;
u32 *buf;
else
buf = (u32 *)tmp;
int ret = 0;
if (priv->tx_buf)
else
ret = -1;
} else {
if (priv->tx_buf)
else
ret = -1;
return ret;
int status = 0;
while (1) {
if (cs_change)
status = -1;
break;
if (priv->len) {
priv->is_inst = 0;
if (status < 0)
break;
if (cs_change)
break;
return status;
no need
no need
H Jagan,
Any further comments on this. I am waiting for your reply on some of my replies to your comment.
Thanks, Siva
-----Original Message----- From: U-Boot [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Siva Durga Prasad Paladugu Sent: Wednesday, February 07, 2018 3:40 PM To: Jagan Teki jagan@amarulasolutions.com Cc: U-Boot-Denx u-boot@lists.denx.de Subject: Re: [U-Boot] [PATCH v2 1/2] spi: zynqmp_qspi: Add support for ZynqMP qspi driver
[This sender failed our fraud detection checks and may not be who they appear to be. Learn about spoofing at http://aka.ms/LearnAboutSpoofing]
Hi Jagan,
Changes from v1:
Yes.
to
+config ZYNQMP_QSPI
select DM_SPI
help
which
+only)
+have the same
- bit definitions.
FIFO Overflow */
FIFO is full */
RX
FIFO Not Empty */
+*/ #define ZYNQMP_QSPI_ENABLE_ENABLE_MASK 0x00000001 /*
QSPI
Enable Bit
+Mask */
u32 isr; /* 0x04 */
u32 ier; /* 0x08 */
u32 dr; /* 0x18 */
+only)
u32 frequency;
u32 speed_hz;
u8 mode;
const void *tx_buf;
void *rx_buf;
unsigned int len;
u32 mode = 0;
u32 value;
int ret;
struct clk clk;
no need
if (ret < 0) {
return ret;
return clock;
return ret;
switch (value) {
case 1:
break;
case 2:
break;
case 4:
break;
default:
break;
switch (value) {
case 1:
break;
case 2:
break;
case 4:
break;
default:
break;
u32 config_reg;
u32 reg;
do {
Sure.
+static void zynqmp_qspi_chipselect(struct zynqmp_qspi_priv *priv, +int +is_on) {
if (is_on) {
} else {
baudrateval) {
u32 reqhz = 0;
&tapdlybypass);
&tapdlybypass);
tapdlybypass);
u32 confr;
no need
if (speed == 0) {
((plat->frequency /
baud_rate_val++;
baud_rate_val =
no need
u32 confr;
priv->mode = mode;
no need
u32 data;
u32 len = size;
size);
if (size >= 4) {
buf++;
size -= 4;
} else {
switch (size) {
case 1:
buf += 1;
data |= 0xFFFFFF00;
break;
case 2:
buf += 2;
data |= 0xFFFF0000;
break;
case 3:
buf += 2;
buf += 1;
data |= 0xFF000000;
break;
size = 0;
} else {
udelay(1);
timeout--;
if (!timeout) {
return -1;
u8 command = 1;
u32 gen_fifo_cmd;
u32 bytecount = 0;
while (priv->len) {
if (command) {
command = 0;
bytecount++;
priv->len--;
u32 expval = 8;
u32 len;
while (1) {
*gen_fifo_cmd &=
*gen_fifo_cmd |=
return expval;
expval++;
} else {
priv->len = 0;
return len;
+static int zynqmp_qspi_genfifo_fill_tx(struct zynqmp_qspi_priv +*priv) {
u32 gen_fifo_cmd;
u32 len;
int ret = 0;
else
while (priv->len) {
1 << len);
else
len);
if (ret)
return ret;
return ret;
u32 addr;
u32 size, len;
dmaier);
while (priv->len) {
(len % 4)) {
while (timeout) {
&dma_regs->dmaisr);
break;
udelay(1);
timeout--;
wait_for_bit?
Ok, will correct.
Thanks, Siva
actuallen);
if (!timeout) {
return -1;
+static int zynqmp_qspi_genfifo_fill_rx(struct zynqmp_qspi_priv +*priv) {
u32 gen_fifo_cmd;
u32 *buf;
else
- 1))
buf = (u32 *)tmp;
+static int zynqmp_qspi_start_transfer(struct zynqmp_qspi_priv +*priv) {
int ret = 0;
if (priv->tx_buf)
else
ret = -1;
} else {
if (priv->tx_buf)
else
ret = -1;
return ret;
int status = 0;
while (1) {
if (cs_change)
status = -1;
break;
if (priv->len) {
priv->is_inst = 0;
if (status < 0)
break;
if (cs_change)
break;
return status;
no need
no need
Hi Siva,
I've been working on a patch to add support for io-mode [1]. It's based on xilinx/master which is closer to v1 (no include file). I haven't had much time to test it further but I can load a bitstream from a ubifs partition with it. Let me know if you have comments.
On Tue, 10 Apr 2018 at 02:27 Siva Durga Prasad Paladugu sivadur@xilinx.com wrote:
H Jagan,
Thanks, Siva
Thanks, Liam
Hi Liam,
We already have a patch for IO mode that we just verified internally. We got it for our tree from NGC guy John Moon. I will be sending that patch soon may be with v3 which I am planning to send once I got response from Jagan on my v2 queries.
Regards, Siva
From: Liam Beguin [mailto:liambeguin@gmail.com] Sent: Tuesday, April 10, 2018 8:56 PM To: Siva Durga Prasad Paladugu sivadur@xilinx.com Cc: Jagan Teki jagan@amarulasolutions.com; U-Boot-Denx u-boot@lists.denx.de; Michal Simek michal.simek@xilinx.com Subject: Re: [U-Boot] [PATCH v2 1/2] spi: zynqmp_qspi: Add support for ZynqMP qspi driver
Hi Siva,
On Tue, 10 Apr 2018 at 02:27 Siva Durga Prasad Paladugu <sivadur@xilinx.commailto:sivadur@xilinx.com> wrote: H Jagan,
Thanks, Siva
Thanks, Liam
Hi Siva,
I wasn't able to find it on the Xilinx github. Is it in that tree already?
Thanks, Liam
On Thu, 12 Apr 2018 at 07:18 Siva Durga Prasad Paladugu sivadur@xilinx.com wrote:
Hi Liam,
Regards,
Siva
*From:* Liam Beguin [mailto:liambeguin@gmail.com] *Sent:* Tuesday, April 10, 2018 8:56 PM *To:* Siva Durga Prasad Paladugu sivadur@xilinx.com *Cc:* Jagan Teki jagan@amarulasolutions.com; U-Boot-Denx < u-boot@lists.denx.de>; Michal Simek michal.simek@xilinx.com
*Subject:* Re: [U-Boot] [PATCH v2 1/2] spi: zynqmp_qspi: Add support for ZynqMP qspi driver
Hi Siva,
On Tue, 10 Apr 2018 at 02:27 Siva Durga Prasad Paladugu < sivadur@xilinx.com> wrote:
H Jagan,
Thanks, Siva
Thanks,
Liam
On Wed, Feb 7, 2018 at 3:40 PM, Siva Durga Prasad Paladugu sivadur@xilinx.com wrote:
Hi Jagan,
Changes from v1:
Yes.
then try to use similar naming conventions in macros, or in function names as well.
+config ZYNQMP_QSPI
select DM_SPI
help
+the same
- bit definitions.
FIFO Overflow */
FIFO is full */
FIFO Not Empty */
Enable Bit
+Mask */
u32 isr; /* 0x04 */
u32 ier; /* 0x08 */
u32 dr; /* 0x18 */
u32 frequency;
u32 speed_hz;
u8 mode;
const void *tx_buf;
void *rx_buf;
unsigned int len;
u32 mode = 0;
u32 value;
int ret;
struct clk clk;
no need
if (ret < 0) {
return ret;
return clock;
return ret;
switch (value) {
case 1:
break;
case 2:
break;
case 4:
break;
default:
break;
switch (value) {
case 1:
break;
case 2:
break;
case 4:
break;
default:
break;
All these attributes are from platdata which were initialized by spi-uclass.c so if you need any of these we can get the dm_spi_slave_platdata from your driver using dev_get_parent_platdata() function.
Remeber let not add spi-nor features in this driver, you may ended-up more adding more redundent code in driver if you do so.
Fix, what ever comments you agree and resend we will review again.
Jagan.
-----Original Message----- From: Jagan Teki [mailto:jagan@amarulasolutions.com] Sent: Wednesday, April 25, 2018 10:47 AM To: Siva Durga Prasad Paladugu sivadur@xilinx.com Cc: U-Boot-Denx u-boot@lists.denx.de Subject: Re: [U-Boot] [PATCH v2 1/2] spi: zynqmp_qspi: Add support for ZynqMP qspi driver
Hi Jagan,
Changes from v1:
Yes.
to
+config ZYNQMP_QSPI
select DM_SPI
help
which
+only)
+have the same
- bit definitions.
TX
FIFO Overflow */
FIFO is full */
RX
FIFO Not Empty */
QSPI
Enable Bit
+Mask */
+#define ZYNQMP_QSPI_DMA_ALIGN 0x4 #define +ZYNQMP_QSPI_MAX_BAUD_RATE_VAL 7 #define +ZYNQMP_QSPI_DFLT_BAUD_RATE_VAL 2
u32 isr; /* 0x04 */
u32 ier; /* 0x08 */
u32 dr; /* 0x18 */
+only)
u32 frequency;
u32 speed_hz;
u8 mode;
const void *tx_buf;
void *rx_buf;
unsigned int len;
u32 mode = 0;
u32 value;
int ret;
struct clk clk;
no need
if (ret < 0) {
return ret;
return clock;
return ret;
switch (value) {
case 1:
break;
case 2:
break;
case 4:
break;
default:
break;
switch (value) {
case 1:
break;
case 2:
break;
case 4:
break;
default:
break;
Looks like you didn’t get my point, in my flow the routine spi_slave_ofdata_to_platdata() in spi-uclass.c is not getting invoked at all that’s why I am not getting this data from spi-uclass.c. do you have an idea on what could be the issue that spi_slave_ofdata_to_platdata() is not getting invoked. I will anyway debug it but, if you already encountered this and aware of any reason for this , please let me know, that really helps me.
Thanks, Siva
Jagan.
-- Jagan Teki Senior Linux Kernel Engineer | Amarula Solutions U-Boot, Linux | Upstream Maintainer Hyderabad, India.
On Wed, May 2, 2018 at 2:49 PM, Siva Durga Prasad Paladugu sivadur@xilinx.com wrote:
[snip]
if (ret < 0) {
return ret;
return clock;
return ret;
switch (value) {
case 1:
break;
case 2:
break;
case 4:
break;
default:
break;
switch (value) {
case 1:
break;
case 2:
break;
case 4:
break;
default:
break;
Fix the rest and keep this as it is we will discuss on next version.
Jagan.
Hi Siva,
Sorry for the very late reply!
The Technical Reference Manual of the ZynqMP talks about the LQSPI and the GQSPI. Based on the #defines, I'm guessing this is for the GQSPI but should we be more explicit about it?
Changes from v1:
I tried building on top of master and running it on a zcu102 (Rev-B) board but I can't get anything newer than v2017.11 to work. I get this failure (unrelated to this series):
In: serial@ff000000 Out: serial@ff000000 Err: serial@ff000000 initcall sequence 000000007ff8dee8 failed at call 0000000008002c7c (err=-22) ### ERROR ### Please RESET the board ###
After looking arround a little, it seems it may be because of my FSBL.
Since I can't get another FSBL for now, I rebased the series on top of v2017.11 and it seems to be working well except for the erase operation in a certain range of flash addresses. The same operations (in that range) in Linux seem to be working.
I'm guessing this is due to something else, maybe in the spi_flash driver.
Here is the test I used:
ZynqMP> sf probe SF: Detected n25q512a with page size 256 Bytes, erase size 4 KiB, total 64 MiB ZynqMP> mw.w 0x100 0x00 0x100 ZynqMP> md.w 0x100 00000100: 0000 0000 0000 0000 0000 0000 0000 0000 ................ 00000110: 0000 0000 0000 0000 0000 0000 0000 0000 ................ 00000120: 0000 0000 0000 0000 0000 0000 0000 0000 ................ 00000130: 0000 0000 0000 0000 0000 0000 0000 0000 ................ 00000140: 0000 0000 0000 0000 0000 0000 0000 0000 ................ 00000150: 0000 0000 0000 0000 0000 0000 0000 0000 ................ 00000160: 0000 0000 0000 0000 0000 0000 0000 0000 ................ 00000170: 0000 0000 0000 0000 0000 0000 0000 0000 ................ ZynqMP> sf read 0x100 0x00 0x100 device 0 offset 0x0, size 0x100 SF: 256 bytes @ 0x0 Read: OK ZynqMP> md.w 0x100 00000100: 1234 1234 abcd abcd abcd abcd abcd abcd 4.4............. 00000110: abcd abcd abcd abcd abcd abcd abcd abcd ................ 00000120: ffff ffff ffff ffff ffff ffff ffff ffff ................ 00000130: ffff ffff ffff ffff ffff ffff ffff ffff ................ 00000140: ffff ffff ffff ffff ffff ffff ffff ffff ................ 00000150: ffff ffff ffff ffff ffff ffff ffff ffff ................ 00000160: ffff ffff ffff ffff ffff ffff ffff ffff ................ 00000170: ffff ffff ffff ffff ffff ffff ffff ffff ................ ZynqMP> mw.w 0x100 0xbeee 0x10 ZynqMP> md.w 0x100 00000100: beee beee beee beee beee beee beee beee ................ 00000110: beee beee beee beee beee beee beee beee ................ 00000120: ffff ffff ffff ffff ffff ffff ffff ffff ................ 00000130: ffff ffff ffff ffff ffff ffff ffff ffff ................ 00000140: ffff ffff ffff ffff ffff ffff ffff ffff ................ 00000150: ffff ffff ffff ffff ffff ffff ffff ffff ................ 00000160: ffff ffff ffff ffff ffff ffff ffff ffff ................ 00000170: ffff ffff ffff ffff ffff ffff ffff ffff ................ ZynqMP> sf update 0x100 0x00 0x100 device 0 offset 0x0, size 0x100 256 bytes written, 0 bytes skipped in 0.70s, speed 3591 B/s ZynqMP> mw.w 0x100 0x00 0x100 ZynqMP> md.w 0x100 00000100: 0000 0000 0000 0000 0000 0000 0000 0000 ................ 00000110: 0000 0000 0000 0000 0000 0000 0000 0000 ................ 00000120: 0000 0000 0000 0000 0000 0000 0000 0000 ................ 00000130: 0000 0000 0000 0000 0000 0000 0000 0000 ................ 00000140: 0000 0000 0000 0000 0000 0000 0000 0000 ................ 00000150: 0000 0000 0000 0000 0000 0000 0000 0000 ................ 00000160: 0000 0000 0000 0000 0000 0000 0000 0000 ................ 00000170: 0000 0000 0000 0000 0000 0000 0000 0000 ................ ZynqMP> sf read 0x100 0x00 0x100 device 0 offset 0x0, size 0x100 SF: 256 bytes @ 0x0 Read: OK ZynqMP> md.w 0x100 00000100: beee beee beee beee beee beee beee beee ................ 00000110: beee beee beee beee beee beee beee beee ................ 00000120: ffff ffff ffff ffff ffff ffff ffff ffff ................ 00000130: ffff ffff ffff ffff ffff ffff ffff ffff ................ 00000140: ffff ffff ffff ffff ffff ffff ffff ffff ................ 00000150: ffff ffff ffff ffff ffff ffff ffff ffff ................ 00000160: ffff ffff ffff ffff ffff ffff ffff ffff ................ 00000170: ffff ffff ffff ffff ffff ffff ffff ffff ................
Here is a case where it failed:
ZynqMP> mw.w 100 abcd 10 ; md.w 100 10 00000100: abcd abcd abcd abcd abcd abcd abcd abcd ................ 00000110: abcd abcd abcd abcd abcd abcd abcd abcd ................ ZynqMP> sf update 100 100 10 device 0 offset 0x100, size 0x10 SPI flash failed in erase step ZynqMP> mw.w 100 00 100 ; sf read 100 100 10 ; md.w 100 10 device 0 offset 0x100, size 0x10 SF: 16 bytes @ 0x100 Read: OK 00000100: ffff ffff ffff ffff ffff ffff ffff ffff ................ 00000110: 0000 0000 0000 0000 0000 0000 0000 0000 ................
I hope this helps! Thanks,
Liam Beguin Xiphos Systems Corp. http://xiphos.ca
participants (5)
Jagan Teki
Jagan Teki
Liam Beguin
