[PATCH 1/2] configs: am65x: Merge the HS and non-HS defconfigs
K3 devices have runtime type board detection. Make the default defconfig include the secure configuration. Then remove the HS specific config.
Non-HS devices will continue to boot due to runtime device type detection.
Signed-off-by: Andrew Davis afd@ti.com --- MAINTAINERS | 2 - configs/am65x_evm_a53_defconfig | 3 +- configs/am65x_evm_r5_defconfig | 1 + configs/am65x_evm_r5_usbdfu_defconfig | 1 + configs/am65x_evm_r5_usbmsc_defconfig | 1 + configs/am65x_hs_evm_a53_defconfig | 158 -------------------------- configs/am65x_hs_evm_r5_defconfig | 135 ---------------------- 7 files changed, 5 insertions(+), 296 deletions(-) delete mode 100644 configs/am65x_hs_evm_a53_defconfig delete mode 100644 configs/am65x_hs_evm_r5_defconfig
diff --git a/MAINTAINERS b/MAINTAINERS index 47581cf6fbb..d3b9f4cc6c4 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -1506,8 +1506,6 @@ F: configs/k2hk_hs_evm_defconfig F: configs/k2e_hs_evm_defconfig F: configs/k2g_hs_evm_defconfig F: configs/k2l_hs_evm_defconfig -F: configs/am65x_hs_evm_r5_defconfig -F: configs/am65x_hs_evm_a53_defconfig
TPM DRIVERS M: Ilias Apalodimas ilias.apalodimas@linaro.org diff --git a/configs/am65x_evm_a53_defconfig b/configs/am65x_evm_a53_defconfig index 4301553af8d..55c1b23c8db 100644 --- a/configs/am65x_evm_a53_defconfig +++ b/configs/am65x_evm_a53_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_K3=y +CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_MALLOC_LEN=0x2000000 CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL_LIBCOMMON_SUPPORT=y @@ -34,7 +35,7 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 CONFIG_OF_SYSTEM_SETUP=y CONFIG_DISTRO_DEFAULTS=y -CONFIG_BOOTCOMMAND="run findfdt; run distro_bootcmd; run init_${boot}; run boot_rprocs; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern" +CONFIG_BOOTCOMMAND="run findfdt; run distro_bootcmd; run init_${boot}; run boot_rprocs; if test ${boot_fit} -eq 1; then run get_fit_${boot}; run get_overlaystring; run run_fit; else; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern; fi;" CONFIG_LOGLEVEL=7 CONFIG_CONSOLE_MUX=y CONFIG_SPL_MAX_SIZE=0x58000 diff --git a/configs/am65x_evm_r5_defconfig b/configs/am65x_evm_r5_defconfig index d5196c2024e..b9b69b921be 100644 --- a/configs/am65x_evm_r5_defconfig +++ b/configs/am65x_evm_r5_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_K3=y +CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_MALLOC_LEN=0x2000000 CONFIG_SYS_MALLOC_F_LEN=0x55000 CONFIG_SPL_GPIO=y diff --git a/configs/am65x_evm_r5_usbdfu_defconfig b/configs/am65x_evm_r5_usbdfu_defconfig index 88f68aa70e4..fb93024bda9 100644 --- a/configs/am65x_evm_r5_usbdfu_defconfig +++ b/configs/am65x_evm_r5_usbdfu_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_K3=y +CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_MALLOC_LEN=0x2000000 CONFIG_SYS_MALLOC_F_LEN=0x55000 CONFIG_SPL_GPIO=y diff --git a/configs/am65x_evm_r5_usbmsc_defconfig b/configs/am65x_evm_r5_usbmsc_defconfig index 8da49c78c82..931b756ab52 100644 --- a/configs/am65x_evm_r5_usbmsc_defconfig +++ b/configs/am65x_evm_r5_usbmsc_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_K3=y +CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_MALLOC_LEN=0x2000000 CONFIG_SYS_MALLOC_F_LEN=0x55000 CONFIG_SPL_GPIO=y diff --git a/configs/am65x_hs_evm_a53_defconfig b/configs/am65x_hs_evm_a53_defconfig deleted file mode 100644 index 3f9626e4550..00000000000 --- a/configs/am65x_hs_evm_a53_defconfig +++ /dev/null @@ -1,158 +0,0 @@ -CONFIG_ARM=y -CONFIG_SKIP_LOWLEVEL_INIT=y -CONFIG_ARCH_K3=y -CONFIG_TI_SECURE_DEVICE=y -CONFIG_SYS_MALLOC_LEN=0x2000000 -CONFIG_SYS_MALLOC_F_LEN=0x8000 -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=2 -CONFIG_SOC_K3_AM654=y -CONFIG_TARGET_AM654_A53_EVM=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80480000 -CONFIG_ENV_SIZE=0x20000 -CONFIG_ENV_OFFSET=0x680000 -CONFIG_DM_GPIO=y -CONFIG_SPL_DM_SPI=y -CONFIG_DEFAULT_DEVICE_TREE="k3-am654-base-board" -CONFIG_SPL_TEXT_BASE=0x80080000 -CONFIG_OF_LIBFDT_OVERLAY=y -CONFIG_DM_RESET=y -CONFIG_SPL_MMC=y -CONFIG_SPL_SERIAL=y -CONFIG_SPL_DRIVERS_MISC=y -CONFIG_SPL_STACK_R_ADDR=0x82000000 -CONFIG_ENV_OFFSET_REDUND=0x6A0000 -CONFIG_SPL_FS_FAT=y -CONFIG_SPL_LIBDISK_SUPPORT=y -CONFIG_SPL_SPI_FLASH_SUPPORT=y -CONFIG_SPL_SPI=y -# CONFIG_PSCI_RESET is not set -CONFIG_PCI=y -# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SPL_LOAD_FIT=y -CONFIG_OF_SYSTEM_SETUP=y -CONFIG_DISTRO_DEFAULTS=y -CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run get_fit_${boot}; run get_overlaystring; run run_fit" -CONFIG_LOGLEVEL=7 -CONFIG_CONSOLE_MUX=y -CONFIG_SPL_MAX_SIZE=0x58000 -CONFIG_SPL_HAS_BSS_LINKER_SECTION=y -CONFIG_SPL_BSS_START_ADDR=0x80a00000 -CONFIG_SPL_BSS_MAX_SIZE=0x80000 -CONFIG_SPL_SYS_MALLOC_SIMPLE=y -CONFIG_SPL_STACK_R=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 -CONFIG_SPL_DMA=y -CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" -CONFIG_SPL_I2C=y -CONFIG_SPL_DM_MAILBOX=y -CONFIG_SPL_MTD_SUPPORT=y -CONFIG_SPL_DM_SPI_FLASH=y -CONFIG_SPL_DM_RESET=y -CONFIG_SPL_POWER_DOMAIN=y -# CONFIG_SPL_SPI_FLASH_TINY is not set -CONFIG_SPL_SPI_FLASH_SFDP_SUPPORT=y -CONFIG_SPL_SPI_LOAD=y -CONFIG_SYS_SPI_U_BOOT_OFFS=0x280000 -CONFIG_SPL_YMODEM_SUPPORT=y -CONFIG_SYS_MAXARGS=64 -CONFIG_CMD_ASKENV=y -CONFIG_CMD_DFU=y -CONFIG_CMD_GPT=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y -CONFIG_CMD_PCI=y -CONFIG_CMD_REMOTEPROC=y -CONFIG_CMD_USB=y -CONFIG_CMD_TIME=y -CONFIG_MTDIDS_DEFAULT="nor0=47040000.spi.0" -CONFIG_MTDPARTS_DEFAULT="mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),128k(ospi.env),128k(ospi.env.backup),1m(ospi.sysfw),-@8m(ospi.rootfs)" -CONFIG_CMD_UBI=y -# CONFIG_ISO_PARTITION is not set -CONFIG_OF_CONTROL=y -CONFIG_SPL_OF_CONTROL=y -CONFIG_SPL_MULTI_DTB_FIT=y -CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y -CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_IN_MMC=y -CONFIG_SYS_REDUNDAND_ENVIRONMENT=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_SYS_MMC_ENV_PART=1 -CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_SPL_DM=y -CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_SPL_REGMAP=y -CONFIG_SPL_OF_TRANSLATE=y -CONFIG_CLK=y -CONFIG_SPL_CLK=y -CONFIG_CLK_TI_SCI=y -CONFIG_DFU_MMC=y -CONFIG_DFU_RAM=y -CONFIG_DFU_SF=y -CONFIG_SYS_DFU_DATA_BUF_SIZE=0x20000 -CONFIG_SYS_DFU_MAX_FILE_SIZE=0x800000 -CONFIG_DMA_CHANNELS=y -CONFIG_TI_K3_NAVSS_UDMA=y -CONFIG_TI_SCI_PROTOCOL=y -CONFIG_DM_PCA953X=y -CONFIG_DM_I2C=y -CONFIG_I2C_SET_DEFAULT_BUS_NUM=y -CONFIG_SYS_I2C_OMAP24XX=y -CONFIG_DM_MAILBOX=y -CONFIG_K3_SEC_PROXY=y -CONFIG_MMC_SDHCI=y -CONFIG_MMC_SDHCI_ADMA=y -CONFIG_SPL_MMC_SDHCI_ADMA=y -CONFIG_MMC_SDHCI_AM654=y -CONFIG_MTD=y -CONFIG_DM_MTD=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_SFDP_SUPPORT=y -CONFIG_SPI_FLASH_STMICRO=y -# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set -CONFIG_SPI_FLASH_MTD=y -CONFIG_PHY_TI_DP83867=y -CONFIG_PHY_FIXED=y -CONFIG_E1000=y -CONFIG_CMD_E1000=y -CONFIG_TI_AM65_CPSW_NUSS=y -CONFIG_PCI_KEYSTONE=y -CONFIG_PHY=y -CONFIG_AM654_PHY=y -CONFIG_OMAP_USB2_PHY=y -CONFIG_PINCTRL=y -# CONFIG_PINCTRL_GENERIC is not set -CONFIG_SPL_PINCTRL=y -# CONFIG_SPL_PINCTRL_GENERIC is not set -CONFIG_PINCTRL_SINGLE=y -CONFIG_POWER_DOMAIN=y -CONFIG_TI_SCI_POWER_DOMAIN=y -CONFIG_REMOTEPROC_TI_K3_R5F=y -CONFIG_RESET_TI_SCI=y -CONFIG_DM_SERIAL=y -CONFIG_SOC_DEVICE=y -CONFIG_SOC_DEVICE_TI_K3=y -CONFIG_SOC_TI=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_CADENCE_QSPI=y -CONFIG_SYSRESET=y -CONFIG_SPL_SYSRESET=y -CONFIG_SYSRESET_TI_SCI=y -CONFIG_USB=y -CONFIG_DM_USB_GADGET=y -CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y -CONFIG_USB_DWC3=y -CONFIG_USB_DWC3_GENERIC=y -CONFIG_USB_KEYBOARD=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" -CONFIG_USB_GADGET_VENDOR_NUM=0x0451 -CONFIG_USB_GADGET_PRODUCT_NUM=0x6162 -CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/am65x_hs_evm_r5_defconfig b/configs/am65x_hs_evm_r5_defconfig deleted file mode 100644 index 0c7b53ca2c0..00000000000 --- a/configs/am65x_hs_evm_r5_defconfig +++ /dev/null @@ -1,135 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_K3=y -CONFIG_TI_SECURE_DEVICE=y -CONFIG_SYS_MALLOC_LEN=0x2000000 -CONFIG_SYS_MALLOC_F_LEN=0x55000 -CONFIG_SPL_GPIO=y -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=2 -CONFIG_SOC_K3_AM654=y -CONFIG_K3_EARLY_CONS=y -CONFIG_TARGET_AM654_R5_EVM=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x41c7effc -CONFIG_ENV_SIZE=0x20000 -CONFIG_DM_GPIO=y -CONFIG_SPL_DM_SPI=y -CONFIG_DEFAULT_DEVICE_TREE="k3-am654-r5-base-board" -CONFIG_SPL_TEXT_BASE=0x41c00000 -CONFIG_DM_RESET=y -CONFIG_SPL_MMC=y -CONFIG_SPL_SERIAL=y -CONFIG_SPL_DRIVERS_MISC=y -CONFIG_SPL_STACK_R_ADDR=0x82000000 -CONFIG_SPL_FS_FAT=y -CONFIG_SPL_LIBDISK_SUPPORT=y -CONFIG_SPL_SPI_FLASH_SUPPORT=y -CONFIG_SPL_SPI=y -# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SPL_LOAD_FIT=y -CONFIG_USE_BOOTCOMMAND=y -# CONFIG_DISPLAY_CPUINFO is not set -CONFIG_SPL_MAX_SIZE=0x58000 -CONFIG_SPL_HAS_BSS_LINKER_SECTION=y -CONFIG_SPL_BSS_START_ADDR=0x41c7effc -CONFIG_SPL_BSS_MAX_SIZE=0xc00 -CONFIG_SPL_STACK_R=y -CONFIG_SPL_SEPARATE_BSS=y -CONFIG_SYS_SPL_MALLOC=y -CONFIG_HAS_CUSTOM_SPL_MALLOC_START=y -CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x84000000 -CONFIG_SYS_SPL_MALLOC_SIZE=0x1000000 -CONFIG_SPL_EARLY_BSS=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x400 -CONFIG_SPL_DMA=y -CONFIG_SPL_I2C=y -CONFIG_SPL_DM_MAILBOX=y -CONFIG_SPL_DM_SPI_FLASH=y -CONFIG_SPL_DM_RESET=y -CONFIG_SPL_POWER_DOMAIN=y -CONFIG_SPL_RAM_SUPPORT=y -CONFIG_SPL_RAM_DEVICE=y -CONFIG_SPL_REMOTEPROC=y -# CONFIG_SPL_SPI_FLASH_TINY is not set -CONFIG_SPL_SPI_FLASH_SFDP_SUPPORT=y -CONFIG_SPL_SPI_LOAD=y -CONFIG_SYS_SPI_U_BOOT_OFFS=0x80000 -CONFIG_SPL_YMODEM_SUPPORT=y -CONFIG_HUSH_PARSER=y -CONFIG_SYS_MAXARGS=64 -CONFIG_CMD_BOOTZ=y -CONFIG_SYS_BOOTM_LEN=0x4000000 -CONFIG_CMD_ASKENV=y -CONFIG_CMD_GPT=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y -CONFIG_CMD_REMOTEPROC=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_TIME=y -CONFIG_CMD_FAT=y -CONFIG_OF_CONTROL=y -CONFIG_SPL_OF_CONTROL=y -CONFIG_SPL_MULTI_DTB_FIT=y -CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y -CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_IN_FAT=y -CONFIG_ENV_FAT_DEVICE_AND_PART="1:1" -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_SPL_DM=y -CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_REGMAP=y -CONFIG_SPL_REGMAP=y -CONFIG_SPL_OF_TRANSLATE=y -CONFIG_CLK=y -CONFIG_SPL_CLK=y -CONFIG_CLK_TI_SCI=y -CONFIG_DMA_CHANNELS=y -CONFIG_TI_K3_NAVSS_UDMA=y -CONFIG_TI_SCI_PROTOCOL=y -CONFIG_DA8XX_GPIO=y -CONFIG_DM_I2C=y -CONFIG_I2C_SET_DEFAULT_BUS_NUM=y -CONFIG_SYS_I2C_OMAP24XX=y -CONFIG_DM_MAILBOX=y -CONFIG_K3_SEC_PROXY=y -CONFIG_K3_AVS0=y -CONFIG_MMC_SDHCI=y -CONFIG_SPL_MMC_SDHCI_ADMA=y -CONFIG_MMC_SDHCI_AM654=y -CONFIG_DM_SPI_FLASH=y -CONFIG_SPI_FLASH_SFDP_SUPPORT=y -CONFIG_SPI_FLASH_STMICRO=y -# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set -CONFIG_PINCTRL=y -# CONFIG_PINCTRL_GENERIC is not set -CONFIG_SPL_PINCTRL=y -# CONFIG_SPL_PINCTRL_GENERIC is not set -CONFIG_PINCTRL_SINGLE=y -CONFIG_POWER_DOMAIN=y -CONFIG_TI_SCI_POWER_DOMAIN=y -CONFIG_DM_REGULATOR=y -CONFIG_SPL_DM_REGULATOR=y -CONFIG_DM_REGULATOR_GPIO=y -CONFIG_SPL_DM_REGULATOR_GPIO=y -CONFIG_DM_REGULATOR_TPS62360=y -CONFIG_RAM=y -CONFIG_SPL_RAM=y -CONFIG_K3_SYSTEM_CONTROLLER=y -CONFIG_REMOTEPROC_TI_K3_ARM64=y -CONFIG_RESET_TI_SCI=y -CONFIG_DM_SERIAL=y -CONFIG_SOC_DEVICE=y -CONFIG_SOC_DEVICE_TI_K3=y -CONFIG_SOC_TI=y -CONFIG_SPI=y -CONFIG_DM_SPI=y -CONFIG_CADENCE_QSPI=y -CONFIG_SYSRESET=y -CONFIG_SPL_SYSRESET=y -CONFIG_SYSRESET_TI_SCI=y -CONFIG_TIMER=y -CONFIG_SPL_TIMER=y -CONFIG_OMAP_TIMER=y -CONFIG_FS_FAT_MAX_CLUSTSIZE=16384
All K3 boards now are secure by default, instead of setting this in each defconfig, make it implied by the ARCH config.
The only exception is IOT2050, which I do not believe will have any problems with being a TI_SECURE_DEVICE, but for now turn it off to keep its config the same.
Signed-off-by: Andrew Davis afd@ti.com --- arch/arm/Kconfig | 1 + configs/am62ax_evm_a53_defconfig | 1 - configs/am62ax_evm_r5_defconfig | 1 - configs/am62x_evm_a53_defconfig | 1 - configs/am62x_evm_r5_defconfig | 1 - configs/am64x_evm_a53_defconfig | 1 - configs/am64x_evm_r5_defconfig | 1 - configs/iot2050_defconfig | 1 + configs/j7200_evm_a72_defconfig | 1 - configs/j7200_evm_r5_defconfig | 1 - configs/j721e_evm_a72_defconfig | 1 - configs/j721e_evm_r5_defconfig | 1 - configs/j721s2_evm_a72_defconfig | 1 - configs/j721s2_evm_r5_defconfig | 1 - 14 files changed, 2 insertions(+), 12 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 97c25b4f146..8ad6c5582ce 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -787,6 +787,7 @@ config ARCH_K3 select FIT select REGEX select FIT_SIGNATURE if ARM64 + imply TI_SECURE_DEVICE
config ARCH_OMAP2PLUS bool "TI OMAP2+" diff --git a/configs/am62ax_evm_a53_defconfig b/configs/am62ax_evm_a53_defconfig index 773cf3a591c..d0a34c75505 100644 --- a/configs/am62ax_evm_a53_defconfig +++ b/configs/am62ax_evm_a53_defconfig @@ -1,6 +1,5 @@ CONFIG_ARM=y CONFIG_ARCH_K3=y -CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y diff --git a/configs/am62ax_evm_r5_defconfig b/configs/am62ax_evm_r5_defconfig index 05c30cbba19..2c1110d227f 100644 --- a/configs/am62ax_evm_r5_defconfig +++ b/configs/am62ax_evm_r5_defconfig @@ -1,6 +1,5 @@ CONFIG_ARM=y CONFIG_ARCH_K3=y -CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_MALLOC_F_LEN=0x9000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y diff --git a/configs/am62x_evm_a53_defconfig b/configs/am62x_evm_a53_defconfig index d55caabe22c..1d05cecbcde 100644 --- a/configs/am62x_evm_a53_defconfig +++ b/configs/am62x_evm_a53_defconfig @@ -1,6 +1,5 @@ CONFIG_ARM=y CONFIG_ARCH_K3=y -CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y diff --git a/configs/am62x_evm_r5_defconfig b/configs/am62x_evm_r5_defconfig index 3c5f3672984..9dd2930dc89 100644 --- a/configs/am62x_evm_r5_defconfig +++ b/configs/am62x_evm_r5_defconfig @@ -1,6 +1,5 @@ CONFIG_ARM=y CONFIG_ARCH_K3=y -CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_MALLOC_LEN=0x08000000 CONFIG_SYS_MALLOC_F_LEN=0x9000 CONFIG_SPL_LIBCOMMON_SUPPORT=y diff --git a/configs/am64x_evm_a53_defconfig b/configs/am64x_evm_a53_defconfig index 9bdb767f9e6..d1d46c61075 100644 --- a/configs/am64x_evm_a53_defconfig +++ b/configs/am64x_evm_a53_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_K3=y -CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_MALLOC_LEN=0x2000000 CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL_GPIO=y diff --git a/configs/am64x_evm_r5_defconfig b/configs/am64x_evm_r5_defconfig index 45d32658cff..96cb437b10b 100644 --- a/configs/am64x_evm_r5_defconfig +++ b/configs/am64x_evm_r5_defconfig @@ -1,6 +1,5 @@ CONFIG_ARM=y CONFIG_ARCH_K3=y -CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_MALLOC_LEN=0x2000000 CONFIG_SYS_MALLOC_F_LEN=0x80000 CONFIG_SPL_GPIO=y diff --git a/configs/iot2050_defconfig b/configs/iot2050_defconfig index bcbaa92ee89..ad9217ff86a 100644 --- a/configs/iot2050_defconfig +++ b/configs/iot2050_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_K3=y +# CONFIG_TI_SECURE_DEVICE is not set CONFIG_SYS_MALLOC_LEN=0x2000000 CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL_GPIO=y diff --git a/configs/j7200_evm_a72_defconfig b/configs/j7200_evm_a72_defconfig index c68d52537e5..a9f5d36ffe3 100644 --- a/configs/j7200_evm_a72_defconfig +++ b/configs/j7200_evm_a72_defconfig @@ -1,6 +1,5 @@ CONFIG_ARM=y CONFIG_ARCH_K3=y -CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_MALLOC_LEN=0x2000000 CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL_GPIO=y diff --git a/configs/j7200_evm_r5_defconfig b/configs/j7200_evm_r5_defconfig index c4dd33627bd..0da16f25a23 100644 --- a/configs/j7200_evm_r5_defconfig +++ b/configs/j7200_evm_r5_defconfig @@ -1,6 +1,5 @@ CONFIG_ARM=y CONFIG_ARCH_K3=y -CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_MALLOC_LEN=0x2000000 CONFIG_SYS_MALLOC_F_LEN=0x70000 CONFIG_SPL_GPIO=y diff --git a/configs/j721e_evm_a72_defconfig b/configs/j721e_evm_a72_defconfig index 525f150e91d..af784c4e005 100644 --- a/configs/j721e_evm_a72_defconfig +++ b/configs/j721e_evm_a72_defconfig @@ -1,6 +1,5 @@ CONFIG_ARM=y CONFIG_ARCH_K3=y -CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_MALLOC_LEN=0x2000000 CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL_GPIO=y diff --git a/configs/j721e_evm_r5_defconfig b/configs/j721e_evm_r5_defconfig index cf7bc872b5f..f6dba64530c 100644 --- a/configs/j721e_evm_r5_defconfig +++ b/configs/j721e_evm_r5_defconfig @@ -1,6 +1,5 @@ CONFIG_ARM=y CONFIG_ARCH_K3=y -CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_MALLOC_LEN=0x2000000 CONFIG_SYS_MALLOC_F_LEN=0x70000 CONFIG_SPL_GPIO=y diff --git a/configs/j721s2_evm_a72_defconfig b/configs/j721s2_evm_a72_defconfig index d59f3156d10..7b7f3dc08e4 100644 --- a/configs/j721s2_evm_a72_defconfig +++ b/configs/j721s2_evm_a72_defconfig @@ -1,6 +1,5 @@ CONFIG_ARM=y CONFIG_ARCH_K3=y -CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_MALLOC_LEN=0x2000000 CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL_GPIO=y diff --git a/configs/j721s2_evm_r5_defconfig b/configs/j721s2_evm_r5_defconfig index 1e66ac23d05..39467e0d00e 100644 --- a/configs/j721s2_evm_r5_defconfig +++ b/configs/j721s2_evm_r5_defconfig @@ -1,6 +1,5 @@ CONFIG_ARM=y CONFIG_ARCH_K3=y -CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_MALLOC_LEN=0x2000000 CONFIG_SYS_MALLOC_F_LEN=0x10000 CONFIG_SPL_GPIO=y
On my J721E GP EVM:
Tested-by: Tom Rini trini@konsulko.com
The IOT2050 firmware is not using TI_SECURE_DEVICE because it serves non-HS devices by default as well. Secure boot on HS devices can be enabled by applying an extra config fragment like [1].
So it's indeed better to keep this off for the IO2050 to avoid untested side effects. E.g., we would probably lose legacy image booting in non-secure mode.
Jan
[1] https://github.com/siemens/meta-iot2050/blob/master/recipes-bsp/u-boot/files...
- imply TI_SECURE_DEVICE
Signed-off-by: Andrew Davis afd@ti.com Tested-by: Tom Rini trini@konsulko.com
On my AM65x GP EVM:
Hi Andrew,
While merging these defconfigs for other boards I had faced an issue where the multi DTB detection wasn't working for HS devices and we were hitting a firewall exception while trying to access the EEPROM Scratchpad before the firewalls were opened. I see that AM65x still uses the old Scratchpad address in the Kconfig which had triggered exceptions for other K3 devices.
config SYS_K3_MCU_SCRATCHPAD_BASE hex default 0x40280000 if SOC_K3_AM654 default 0x41cff9fc if SOC_K3_J721S2 default 0x41cff9fc if SOC_K3_J721E
Can you double check if this also needs a change along with the merged defconfigs?
Regards, Manorit
2.39.2
Hi Andrew,
On 04/08/23 10:35, Manorit Chawdhry wrote:
Hi Andrew,
Regards, Manorit
I just noticed that the multi fit configs were already enabled in HS defconfig before the merge so ig merging the configs shouldn't bring the problem I was suspecting.
Reviewed-by: Manorit Chawdhry m-chawdhry@ti.com
Regards, Manorit
2.39.2
Signed-off-by: Andrew Davis afd@ti.com Tested-by: Tom Rini trini@konsulko.com Reviewed-by: Manorit Chawdhry m-chawdhry@ti.com
Andrew Davis
Jan Kiszka
Manorit Chawdhry
