[U-Boot] [PATCH] omap: am33xx: accomodate input clocks other than 24 Mhz
The PLL setup values currently assume a 24 Mhz input clock.
This patch uses V_OSCK from the board config file to support boards with different input clock rates.
Signed-off-by: Steve Sakoman steve@sakoman.com --- arch/arm/include/asm/arch-am33xx/clocks_am33xx.h | 10 +++++----- 1 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/arch/arm/include/asm/arch-am33xx/clocks_am33xx.h b/arch/arm/include/asm/arch-am33xx/clocks_am33xx.h index abc5b6b..d748dd2 100644 --- a/arch/arm/include/asm/arch-am33xx/clocks_am33xx.h +++ b/arch/arm/include/asm/arch-am33xx/clocks_am33xx.h @@ -19,16 +19,16 @@ #ifndef _CLOCKS_AM33XX_H_ #define _CLOCKS_AM33XX_H_
-#define OSC 24 +#define OSC (V_OSCK/1000000)
/* MAIN PLL Fdll = 550 MHZ, */ #define MPUPLL_M 550 -#define MPUPLL_N 23 +#define MPUPLL_N (OSC-1) #define MPUPLL_M2 1
/* Core PLL Fdll = 1 GHZ, */ #define COREPLL_M 1000 -#define COREPLL_N 23 +#define COREPLL_N (OSC-1)
#define COREPLL_M4 10 /* CORE_CLKOUTM4 = 200 MHZ */ #define COREPLL_M5 8 /* CORE_CLKOUTM5 = 250 MHZ */ @@ -40,13 +40,13 @@ * For clkout = 192 MHZ, Fdll = 960 MHZ, divider values are given below */ #define PERPLL_M 960 -#define PERPLL_N 23 +#define PERPLL_N (OSC-1) #define PERPLL_M2 5
/* DDR Freq is 266 MHZ for now */ /* Set Fdll = 400 MHZ , Fdll = M * 2 * CLKINP/ N + 1; clkout = Fdll /(2 * M2) */ #define DDRPLL_M 266 -#define DDRPLL_N 23 +#define DDRPLL_N (OSC-1) #define DDRPLL_M2 1
extern void pll_init(void);
Queued up for u-boot-ti/master, thanks!
Steve Sakoman
