[U-Boot] AM335x: env_{flash,nowhere} compile conflict
I'm struggling to work out why I get the following compile error:-
arm-linux-ld.bfd -r -o /home/mpfj/uboot/u-boot/spl/common/libcommon.o /home/mpfj/uboot/u-boot/spl/common/cmd_nvedit.o /home/mpfj/uboot/u-boot/spl/common/console.o /home/mpfj/uboot/u-boot/spl/common/dlmalloc.o /home/mpfj/uboot/u-boot/spl/common/env_common.o /home/mpfj/uboot/u-boot/spl/common/env_flash.o /home/mpfj/uboot/u-boot/spl/common/env_nowhere.o /home/mpfj/uboot/u-boot/spl/common/image-fdt.o /home/mpfj/uboot/u-boot/spl/common/image.o /home/mpfj/uboot/u-boot/spl/common/memsize.o /home/mpfj/uboot/u-boot/spl/common/miiphyutil.o /home/mpfj/uboot/u-boot/spl/common/stdio.o /home/mpfj/uboot/u-boot/spl/common/xyzModem.o /home/mpfj/uboot/u-boot/spl/common/env_nowhere.o: In function `env_relocate_spec': /home/mpfj/uboot/u-boot/common/env_nowhere.c:38: multiple definition of `env_relocate_spec' /home/mpfj/uboot/u-boot/spl/common/env_flash.o:/home/mpfj/uboot/u-boot/common/env_flash.c:321: first defined here /home/mpfj/uboot/u-boot/spl/common/env_nowhere.o: In function `env_init': /home/mpfj/uboot/u-boot/common/env_nowhere.c:47: multiple definition of `env_init' /home/mpfj/uboot/u-boot/spl/common/env_flash.o:/home/mpfj/uboot/u-boot/common/env_flash.c:78: first defined here /home/mpfj/uboot/u-boot/spl/common/env_nowhere.o: In function `env_relocate_spec': /home/mpfj/uboot/u-boot/common/env_nowhere.c:38: multiple definition of `env_ptr' /home/mpfj/uboot/u-boot/spl/common/env_flash.o:(.data.env_ptr+0x0): first defined here make[3]: *** [/home/mpfj/uboot/u-boot/spl/common/libcommon.o] Error 1 make[3]: Leaving directory `/home/mpfj/uboot/u-boot/common' make[2]: *** [/home/mpfj/uboot/u-boot/spl/common/libcommon.o] Error 2 make[2]: Leaving directory `/home/mpfj/uboot/u-boot/spl' make[1]: *** [spl/u-boot-spl.bin] Error 2 make[1]: Leaving directory `/home/mpfj/uboot/u-boot' make: *** [nanobone_sdboot] Error 2
I have 2 custom entries in the boards.cfg file:-
nanobone arm armv7 nanobone newflow am33xx nanobone:NOR_BOOT nanobone_sdboot arm armv7 nanobone newflow am33xx nanobone:SD_BOOT
My nanobone.h file is attached.
I'd appreciate it is someone could tell me why env_nowhere.o is being compiled in even though CONFIG_ENV_IS_NOWHERE is not defined.
Cheers Mark J.
Mark Jackson
