[U-Boot] [PATCH 1/2] efi_loader: Optimize GOP switch
We usually try to compile for size, not for speed. Unfortunately with the more powerful GOP infrastructure to handle all sorts of GOP operations, we end up slowing down our copying hot path quite a lot.
So this patch moves the 4 possible GOP operation modes into separate functions which call a common function again. The end result of that is more optimized code that can properly do constant propagation throughout its switch() statements and thus removes compares in the hot path.
Signed-off-by: Alexander Graf agraf@suse.de --- lib/efi_loader/efi_gop.c | 160 +++++++++++++++++++++++++++++++++++++---------- 1 file changed, 126 insertions(+), 34 deletions(-)
diff --git a/lib/efi_loader/efi_gop.c b/lib/efi_loader/efi_gop.c index ac92109f16..bbdf34e1dd 100644 --- a/lib/efi_loader/efi_gop.c +++ b/lib/efi_loader/efi_gop.c @@ -77,42 +77,24 @@ static inline u16 efi_blt_col_to_vid16(struct efi_gop_pixel *blt) (u16)(blt->blue >> 3); }
-/* - * Copy rectangle. - * - * This function implements the Blt service of the EFI_GRAPHICS_OUTPUT_PROTOCOL. - * See the Unified Extensible Firmware Interface (UEFI) specification for - * details. - * - * @this: EFI_GRAPHICS_OUTPUT_PROTOCOL - * @buffer: pixel buffer - * @sx: source x-coordinate - * @sy: source y-coordinate - * @dx: destination x-coordinate - * @dy: destination y-coordinate - * @width: width of rectangle - * @height: height of rectangle - * @delta: length in bytes of a line in the pixel buffer (optional) - * @return: status code - */ -efi_status_t EFIAPI gop_blt(struct efi_gop *this, struct efi_gop_pixel *buffer, - u32 operation, efi_uintn_t sx, - efi_uintn_t sy, efi_uintn_t dx, - efi_uintn_t dy, efi_uintn_t width, - efi_uintn_t height, efi_uintn_t delta) +static __always_inline efi_status_t gop_blt_int(struct efi_gop *this, + struct efi_gop_pixel *buffer, + u32 operation, efi_uintn_t sx, + efi_uintn_t sy, efi_uintn_t dx, + efi_uintn_t dy, + efi_uintn_t width, + efi_uintn_t height, + efi_uintn_t delta) { struct efi_gop_obj *gopobj = container_of(this, struct efi_gop_obj, ops); efi_uintn_t i, j, linelen; u32 *fb32 = gopobj->fb; u16 *fb16 = gopobj->fb;
- EFI_ENTRY("%p, %p, %u, %zu, %zu, %zu, %zu, %zu, %zu, %zu", this, - buffer, operation, sx, sy, dx, dy, width, height, delta); - if (delta) { /* Check for 4 byte alignment */ if (delta & 3) - return EFI_EXIT(EFI_INVALID_PARAMETER); + return EFI_INVALID_PARAMETER; linelen = delta >> 2; } else { linelen = width; @@ -124,16 +106,16 @@ efi_status_t EFIAPI gop_blt(struct efi_gop *this, struct efi_gop_pixel *buffer, break; case EFI_BLT_BUFFER_TO_VIDEO: if (sx + width > linelen) - return EFI_EXIT(EFI_INVALID_PARAMETER); + return EFI_INVALID_PARAMETER; break; case EFI_BLT_VIDEO_TO_BLT_BUFFER: case EFI_BLT_VIDEO_TO_VIDEO: if (sx + width > gopobj->info.width || sy + height > gopobj->info.height) - return EFI_EXIT(EFI_INVALID_PARAMETER); + return EFI_INVALID_PARAMETER; break; default: - return EFI_EXIT(EFI_INVALID_PARAMETER); + return EFI_INVALID_PARAMETER; }
/* Check destination rectangle */ @@ -143,11 +125,11 @@ efi_status_t EFIAPI gop_blt(struct efi_gop *this, struct efi_gop_pixel *buffer, case EFI_BLT_VIDEO_TO_VIDEO: if (dx + width > gopobj->info.width || dy + height > gopobj->info.height) - return EFI_EXIT(EFI_INVALID_PARAMETER); + return EFI_INVALID_PARAMETER; break; case EFI_BLT_VIDEO_TO_BLT_BUFFER: if (dx + width > linelen) - return EFI_EXIT(EFI_INVALID_PARAMETER); + return EFI_INVALID_PARAMETER; break; }
@@ -185,7 +167,7 @@ efi_status_t EFIAPI gop_blt(struct efi_gop *this, struct efi_gop_pixel *buffer, (i + sy) + j + sx]); break; default: - return EFI_EXIT(EFI_UNSUPPORTED); + return EFI_UNSUPPORTED; } break; } @@ -217,13 +199,123 @@ efi_status_t EFIAPI gop_blt(struct efi_gop *this, struct efi_gop_pixel *buffer, efi_blt_col_to_vid16(&pix); break; default: - return EFI_EXIT(EFI_UNSUPPORTED); + return EFI_UNSUPPORTED; } break; } } }
+ return EFI_SUCCESS; +} + +/* + * Gcc can't optimize our BLT function well, but we need to make sure that + * our 2-dimensional loop gets executed very quickly, otherwise the system + * will feel slow. + * + * By manually putting all obvious branch targets into functions which call + * our generic blt function with constants, the compiler can successfully + * optimize for speed. + */ +static efi_status_t gop_blt_video_fill(struct efi_gop *this, + struct efi_gop_pixel *buffer, + u32 foo, efi_uintn_t sx, + efi_uintn_t sy, efi_uintn_t dx, + efi_uintn_t dy, efi_uintn_t width, + efi_uintn_t height, efi_uintn_t delta) +{ + return gop_blt_int(this, buffer, EFI_BLT_VIDEO_FILL, sx, sy, dx, + dy, width, height, delta); +} + +static efi_status_t gop_blt_buf_to_vid(struct efi_gop *this, + struct efi_gop_pixel *buffer, + u32 foo, efi_uintn_t sx, + efi_uintn_t sy, efi_uintn_t dx, + efi_uintn_t dy, efi_uintn_t width, + efi_uintn_t height, efi_uintn_t delta) +{ + return gop_blt_int(this, buffer, EFI_BLT_BUFFER_TO_VIDEO, sx, sy, dx, + dy, width, height, delta); +} + +static efi_status_t gop_blt_vid_to_vid(struct efi_gop *this, + struct efi_gop_pixel *buffer, + u32 foo, efi_uintn_t sx, + efi_uintn_t sy, efi_uintn_t dx, + efi_uintn_t dy, efi_uintn_t width, + efi_uintn_t height, efi_uintn_t delta) +{ + return gop_blt_int(this, buffer, EFI_BLT_VIDEO_TO_VIDEO, sx, sy, dx, + dy, width, height, delta); +} + +static efi_status_t gop_blt_vid_to_buf(struct efi_gop *this, + struct efi_gop_pixel *buffer, + u32 foo, efi_uintn_t sx, + efi_uintn_t sy, efi_uintn_t dx, + efi_uintn_t dy, efi_uintn_t width, + efi_uintn_t height, efi_uintn_t delta) +{ + return gop_blt_int(this, buffer, EFI_BLT_VIDEO_TO_BLT_BUFFER, sx, sy, + dx, dy, width, height, delta); +} + +/* + * Copy rectangle. + * + * This function implements the Blt service of the EFI_GRAPHICS_OUTPUT_PROTOCOL. + * See the Unified Extensible Firmware Interface (UEFI) specification for + * details. + * + * @this: EFI_GRAPHICS_OUTPUT_PROTOCOL + * @buffer: pixel buffer + * @sx: source x-coordinate + * @sy: source y-coordinate + * @dx: destination x-coordinate + * @dy: destination y-coordinate + * @width: width of rectangle + * @height: height of rectangle + * @delta: length in bytes of a line in the pixel buffer (optional) + * @return: status code + */ +efi_status_t EFIAPI gop_blt(struct efi_gop *this, struct efi_gop_pixel *buffer, + u32 operation, efi_uintn_t sx, + efi_uintn_t sy, efi_uintn_t dx, + efi_uintn_t dy, efi_uintn_t width, + efi_uintn_t height, efi_uintn_t delta) +{ + efi_status_t ret = EFI_INVALID_PARAMETER; + + EFI_ENTRY("%p, %p, %u, %zu, %zu, %zu, %zu, %zu, %zu, %zu", this, + buffer, operation, sx, sy, dx, dy, width, height, delta); + + /* Allow for compiler optimization */ + switch (operation) { + case EFI_BLT_VIDEO_FILL: + ret = gop_blt_video_fill(this, buffer, operation, sx, sy, dx, + dy, width, height, delta); + break; + case EFI_BLT_BUFFER_TO_VIDEO: + ret = gop_blt_buf_to_vid(this, buffer, operation, sx, sy, dx, + dy, width, height, delta); + break; + case EFI_BLT_VIDEO_TO_VIDEO: + ret = gop_blt_vid_to_vid(this, buffer, operation, sx, sy, dx, + dy, width, height, delta); + break; + case EFI_BLT_VIDEO_TO_BLT_BUFFER: + ret = gop_blt_vid_to_buf(this, buffer, operation, sx, sy, dx, + dy, width, height, delta); + break; + default: + ret = EFI_UNSUPPORTED; + } + + if (ret != EFI_SUCCESS) + return EFI_EXIT(ret); + #ifdef CONFIG_DM_VIDEO video_sync_all(); #else
The GOP path was optimized, but still not as fast as it should be. Let's push it even further by trimming the hot path into simple 32bit load/store operations for buf->vid 32bpp operations.
Signed-off-by: Alexander Graf agraf@suse.de --- lib/efi_loader/efi_gop.c | 176 ++++++++++++++++++++++++++++++----------------- 1 file changed, 114 insertions(+), 62 deletions(-)
diff --git a/lib/efi_loader/efi_gop.c b/lib/efi_loader/efi_gop.c index bbdf34e1dd..7b76e49ab0 100644 --- a/lib/efi_loader/efi_gop.c +++ b/lib/efi_loader/efi_gop.c @@ -78,18 +78,20 @@ static inline u16 efi_blt_col_to_vid16(struct efi_gop_pixel *blt) }
static __always_inline efi_status_t gop_blt_int(struct efi_gop *this, - struct efi_gop_pixel *buffer, + struct efi_gop_pixel *bufferp, u32 operation, efi_uintn_t sx, efi_uintn_t sy, efi_uintn_t dx, efi_uintn_t dy, efi_uintn_t width, efi_uintn_t height, - efi_uintn_t delta) + efi_uintn_t delta, + efi_uintn_t vid_bpp) { struct efi_gop_obj *gopobj = container_of(this, struct efi_gop_obj, ops); - efi_uintn_t i, j, linelen; + efi_uintn_t i, j, linelen, slineoff = 0, dlineoff, swidth, dwidth; u32 *fb32 = gopobj->fb; u16 *fb16 = gopobj->fb; + struct efi_gop_pixel *buffer = __builtin_assume_aligned(bufferp, 4);
if (delta) { /* Check for 4 byte alignment */ @@ -133,6 +135,37 @@ static __always_inline efi_status_t gop_blt_int(struct efi_gop *this, break; }
+ /* Calculate line width */ + switch (operation) { + case EFI_BLT_BUFFER_TO_VIDEO: + swidth = linelen; + break; + case EFI_BLT_VIDEO_TO_BLT_BUFFER: + case EFI_BLT_VIDEO_TO_VIDEO: + swidth = gopobj->info.width; + if (!vid_bpp) + return EFI_UNSUPPORTED; + break; + case EFI_BLT_VIDEO_FILL: + swidth = 0; + break; + } + + switch (operation) { + case EFI_BLT_BUFFER_TO_VIDEO: + case EFI_BLT_VIDEO_FILL: + case EFI_BLT_VIDEO_TO_VIDEO: + dwidth = gopobj->info.width; + if (!vid_bpp) + return EFI_UNSUPPORTED; + break; + case EFI_BLT_VIDEO_TO_BLT_BUFFER: + dwidth = linelen; + break; + } + + slineoff = swidth * sy; + dlineoff = dwidth * dy; for (i = 0; i < height; i++) { for (j = 0; j < width; j++) { struct efi_gop_pixel pix; @@ -143,70 +176,65 @@ static __always_inline efi_status_t gop_blt_int(struct efi_gop *this, pix = *buffer; break; case EFI_BLT_BUFFER_TO_VIDEO: - pix = buffer[linelen * (i + sy) + j + sx]; + pix = buffer[slineoff + j + sx]; break; case EFI_BLT_VIDEO_TO_BLT_BUFFER: case EFI_BLT_VIDEO_TO_VIDEO: - switch (gopobj->bpix) { -#ifdef CONFIG_DM_VIDEO - case VIDEO_BPP32: -#else - case LCD_COLOR32: -#endif + if (vid_bpp == 32) pix = *(struct efi_gop_pixel *)&fb32[ - gopobj->info.width * - (i + sy) + j + sx]; - break; -#ifdef CONFIG_DM_VIDEO - case VIDEO_BPP16: -#else - case LCD_COLOR16: -#endif + slineoff + j + sx]; + else pix = efi_vid16_to_blt_col(fb16[ - gopobj->info.width * - (i + sy) + j + sx]); - break; - default: - return EFI_UNSUPPORTED; - } + slineoff + j + sx]); break; }
/* Write destination pixel */ switch (operation) { case EFI_BLT_VIDEO_TO_BLT_BUFFER: - buffer[linelen * (i + dy) + j + dx] = pix; + buffer[dlineoff + j + dx] = pix; break; case EFI_BLT_BUFFER_TO_VIDEO: case EFI_BLT_VIDEO_FILL: case EFI_BLT_VIDEO_TO_VIDEO: - switch (gopobj->bpix) { + if (vid_bpp == 32) + fb32[dlineoff + j + dx] = *(u32 *)&pix; + else + fb16[dlineoff + j + dx] = + efi_blt_col_to_vid16(&pix); + break; + } + } + slineoff += swidth; + dlineoff += dwidth; + } + + return EFI_SUCCESS; +} + +static efi_uintn_t gop_get_bpp(struct efi_gop *this) +{ + struct efi_gop_obj *gopobj = container_of(this, struct efi_gop_obj, ops); + efi_uintn_t vid_bpp = 0; + + switch (gopobj->bpix) { #ifdef CONFIG_DM_VIDEO - case VIDEO_BPP32: + case VIDEO_BPP32: #else - case LCD_COLOR32: + case LCD_COLOR32: #endif - fb32[gopobj->info.width * - (i + dy) + j + dx] = *(u32 *)&pix; - break; + vid_bpp = 32; + break; #ifdef CONFIG_DM_VIDEO - case VIDEO_BPP16: + case VIDEO_BPP16: #else - case LCD_COLOR16: + case LCD_COLOR16: #endif - fb16[gopobj->info.width * - (i + dy) + j + dx] = - efi_blt_col_to_vid16(&pix); - break; - default: - return EFI_UNSUPPORTED; - } - break; - } - } + vid_bpp = 16; + break; }
- return EFI_SUCCESS; + return vid_bpp; }
/* @@ -223,21 +251,33 @@ static efi_status_t gop_blt_video_fill(struct efi_gop *this, u32 foo, efi_uintn_t sx, efi_uintn_t sy, efi_uintn_t dx, efi_uintn_t dy, efi_uintn_t width, - efi_uintn_t height, efi_uintn_t delta) + efi_uintn_t height, efi_uintn_t delta, + efi_uintn_t vid_bpp) { return gop_blt_int(this, buffer, EFI_BLT_VIDEO_FILL, sx, sy, dx, - dy, width, height, delta); + dy, width, height, delta, vid_bpp); }
-static efi_status_t gop_blt_buf_to_vid(struct efi_gop *this, - struct efi_gop_pixel *buffer, - u32 foo, efi_uintn_t sx, - efi_uintn_t sy, efi_uintn_t dx, - efi_uintn_t dy, efi_uintn_t width, - efi_uintn_t height, efi_uintn_t delta) +static efi_status_t gop_blt_buf_to_vid16(struct efi_gop *this, + struct efi_gop_pixel *buffer, + u32 foo, efi_uintn_t sx, + efi_uintn_t sy, efi_uintn_t dx, + efi_uintn_t dy, efi_uintn_t width, + efi_uintn_t height, efi_uintn_t delta) { return gop_blt_int(this, buffer, EFI_BLT_BUFFER_TO_VIDEO, sx, sy, dx, - dy, width, height, delta); + dy, width, height, delta, 16); +} + +static efi_status_t gop_blt_buf_to_vid32(struct efi_gop *this, + struct efi_gop_pixel *buffer, + u32 foo, efi_uintn_t sx, + efi_uintn_t sy, efi_uintn_t dx, + efi_uintn_t dy, efi_uintn_t width, + efi_uintn_t height, efi_uintn_t delta) +{ + return gop_blt_int(this, buffer, EFI_BLT_BUFFER_TO_VIDEO, sx, sy, dx, + dy, width, height, delta, 32); }
static efi_status_t gop_blt_vid_to_vid(struct efi_gop *this, @@ -245,10 +285,11 @@ static efi_status_t gop_blt_vid_to_vid(struct efi_gop *this, u32 foo, efi_uintn_t sx, efi_uintn_t sy, efi_uintn_t dx, efi_uintn_t dy, efi_uintn_t width, - efi_uintn_t height, efi_uintn_t delta) + efi_uintn_t height, efi_uintn_t delta, + efi_uintn_t vid_bpp) { return gop_blt_int(this, buffer, EFI_BLT_VIDEO_TO_VIDEO, sx, sy, dx, - dy, width, height, delta); + dy, width, height, delta, vid_bpp); }
static efi_status_t gop_blt_vid_to_buf(struct efi_gop *this, @@ -256,10 +297,11 @@ static efi_status_t gop_blt_vid_to_buf(struct efi_gop *this, u32 foo, efi_uintn_t sx, efi_uintn_t sy, efi_uintn_t dx, efi_uintn_t dy, efi_uintn_t width, - efi_uintn_t height, efi_uintn_t delta) + efi_uintn_t height, efi_uintn_t delta, + efi_uintn_t vid_bpp) { return gop_blt_int(this, buffer, EFI_BLT_VIDEO_TO_BLT_BUFFER, sx, sy, - dx, dy, width, height, delta); + dx, dy, width, height, delta, vid_bpp); }
/* @@ -287,27 +329,37 @@ efi_status_t EFIAPI gop_blt(struct efi_gop *this, struct efi_gop_pixel *buffer, efi_uintn_t height, efi_uintn_t delta) { efi_status_t ret = EFI_INVALID_PARAMETER; + efi_uintn_t vid_bpp;
EFI_ENTRY("%p, %p, %u, %zu, %zu, %zu, %zu, %zu, %zu, %zu", this, buffer, operation, sx, sy, dx, dy, width, height, delta);
+ vid_bpp = gop_get_bpp(this); + /* Allow for compiler optimization */ switch (operation) { case EFI_BLT_VIDEO_FILL: ret = gop_blt_video_fill(this, buffer, operation, sx, sy, dx, - dy, width, height, delta); + dy, width, height, delta, vid_bpp); break; case EFI_BLT_BUFFER_TO_VIDEO: - ret = gop_blt_buf_to_vid(this, buffer, operation, sx, sy, dx, - dy, width, height, delta); + /* This needs to be super-fast, so duplicate for 16/32bpp */ + if (vid_bpp == 32) + ret = gop_blt_buf_to_vid32(this, buffer, operation, sx, + sy, dx, dy, width, height, + delta); + else + ret = gop_blt_buf_to_vid16(this, buffer, operation, sx, + sy, dx, dy, width, height, + delta); break; case EFI_BLT_VIDEO_TO_VIDEO: ret = gop_blt_vid_to_vid(this, buffer, operation, sx, sy, dx, - dy, width, height, delta); + dy, width, height, delta, vid_bpp); break; case EFI_BLT_VIDEO_TO_BLT_BUFFER: ret = gop_blt_vid_to_buf(this, buffer, operation, sx, sy, dx, - dy, width, height, delta); + dy, width, height, delta, vid_bpp); break; default: ret = EFI_UNSUPPORTED;
efi_uintn_t delta)
efi_uintn_t delta,
{ struct efi_gop_obj *gopobj = container_of(this, struct efi_gop_obj, ops);efi_uintn_t vid_bpp)
- /* Calculate line width */
- switch (operation) {
- case EFI_BLT_BUFFER_TO_VIDEO:
swidth = linelen;
break;
- case EFI_BLT_VIDEO_TO_BLT_BUFFER:
- case EFI_BLT_VIDEO_TO_VIDEO:
if (!vid_bpp)
break;
- case EFI_BLT_VIDEO_FILL:
swidth = 0;
break;
if (!vid_bpp)
break;
dwidth = linelen;
break;
- slineoff = swidth * sy;
- dlineoff = dwidth * dy; for (i = 0; i < height; i++) { for (j = 0; j < width; j++) { struct efi_gop_pixel pix;
case VIDEO_BPP32:
-#else
case LCD_COLOR32:
-#endif
(i + sy) + j + sx];
break;
case VIDEO_BPP16:
-#else
case LCD_COLOR16:
-#endif
slineoff + j + sx];
Shouldn't we eliminate this conversion for EFI_BLT_VIDEO_TO_VIDEO?
break;
default:
slineoff + j + sx]); break; } /* Write destination pixel */ switch (operation) { case EFI_BLT_VIDEO_TO_BLT_BUFFER:
does buffer[dlineoff + j + dx] = pix; break; case EFI_BLT_BUFFER_TO_VIDEO: case EFI_BLT_VIDEO_FILL: case EFI_BLT_VIDEO_TO_VIDEO:
if (vid_bpp == 32)
else
Same here.
The following problem is not introduced by your patch series so it should not stop you from merging the patches:
For EFI_BLT_VIDEO_TO_VIDEO the spec does not define how to copy overlapping rectangles. The iteration direction makes a big difference here.
I think we should do overlapping copies always in a way that keeps the contents of the source rectangle. Currently we corrupt it when
sy == dy && sx < dx < sx + width || sy < dy < dy + height.
For dy > sy we should iterate bottom to top. For dx > sy && dy == sy we should iterate right to left.
Best regards
Heinrich
break;
slineoff += swidth;
dlineoff += dwidth;
- struct efi_gop_obj *gopobj = container_of(this, struct efi_gop_obj, ops);
- efi_uintn_t vid_bpp = 0;
- switch (gopobj->bpix) { #ifdef CONFIG_DM_VIDEO
case VIDEO_BPP32:
- case VIDEO_BPP32: #else
case LCD_COLOR32:
- case LCD_COLOR32: #endif
break;
vid_bpp = 32;
#ifdef CONFIG_DM_VIDEObreak;
case VIDEO_BPP16:
- case VIDEO_BPP16: #else
case LCD_COLOR16:
- case LCD_COLOR16: #endif
break;
default:
break;
vid_bpp = 16;
}break;
return vid_bpp; }
{ return gop_blt_int(this, buffer, EFI_BLT_VIDEO_FILL, sx, sy, dx,efi_uintn_t vid_bpp)
}dy, width, height, delta, vid_bpp);
{ return gop_blt_int(this, buffer, EFI_BLT_BUFFER_TO_VIDEO, sx, sy, dx,efi_uintn_t height, efi_uintn_t delta)
{ return gop_blt_int(this, buffer, EFI_BLT_VIDEO_TO_VIDEO, sx, sy, dx,efi_uintn_t vid_bpp)
{ return gop_blt_int(this, buffer, EFI_BLT_VIDEO_TO_BLT_BUFFER, sx, sy,efi_uintn_t vid_bpp)
break; case EFI_BLT_BUFFER_TO_VIDEO:dy, width, height, delta, vid_bpp);
if (vid_bpp == 32)
delta);
else
break; case EFI_BLT_VIDEO_TO_VIDEO: ret = gop_blt_vid_to_vid(this, buffer, operation, sx, sy, dx,delta);
break; case EFI_BLT_VIDEO_TO_BLT_BUFFER: ret = gop_blt_vid_to_buf(this, buffer, operation, sx, sy, dx,dy, width, height, delta, vid_bpp);
break; default: ret = EFI_UNSUPPORTED;dy, width, height, delta, vid_bpp);
<snip />
Best regards
Heinrich
EDK has said logic in CorebootPayloadPkg/FbGop/FbGop.c.
Regards
Heinrich
Thanks, applied to efi-next
Alex
Alex
Alexander Graf
