[PATCH] spi: spi-mem: s/dummy/data buswidth check in dtr_supports_op()
This should have been op->data.buswidth instead as we check for octal bus width for the data related ops Also add explanation for why there is checks for 8D even data bytes
Cc: Pratyush Yadav pratyush@kernel.org Signed-off-by: Dhruva Gole d-gole@ti.com ---
Address Pratyush Yadav's comments from here: https://lore.kernel.org/u-boot/20221106224617.2ievqx37mcvqntdr@yadavpratyush...
drivers/spi/spi-mem.c | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/drivers/spi/spi-mem.c b/drivers/spi/spi-mem.c index 8e8995fc537f..57a36f31a5d3 100644 --- a/drivers/spi/spi-mem.c +++ b/drivers/spi/spi-mem.c @@ -181,8 +181,12 @@ bool spi_mem_dtr_supports_op(struct spi_slave *slave, if (op->dummy.nbytes && op->dummy.buswidth == 8 && op->dummy.nbytes % 2) return false;
+ /* + * Transactions of odd length do not make sense for 8D-8D-8D mode + * because a byte is transferred in just half a cycle. + */ if (op->data.dir != SPI_MEM_NO_DATA && - op->dummy.buswidth == 8 && op->data.nbytes % 2) + op->data.buswidth == 8 && op->data.nbytes % 2) return false;
return spi_mem_check_buswidth(slave, op);
Reviewed-by: Pratyush Yadav ptyadav@amazon.de
op->data.buswidth == 8 && op->data.nbytes % 2) return false; return spi_mem_check_buswidth(slave, op);
-- 2.25.1
Dhruva Gole
Pratyush Yadav
