[U-Boot-Users] [PATCH] PPC405EP Set EMAC noise filter bits
This bug was introduced with commit aee747f19b460a0e9da20ff21e90fdaac1cec359 which enabled CFG_4xx_GPIO_TABLE for PPC405 and unintentionally disabled the setting of the emac noise filter bits for PPC405EP when CFG_4xx_GPIO_TABLE is set.
Signed-off-by: Markus Brunner super.firetwister@gmail.com ---
diff --git a/cpu/ppc4xx/cpu_init.c b/cpu/ppc4xx/cpu_init.c index 5d15e2f..5ed439d 100644 --- a/cpu/ppc4xx/cpu_init.c +++ b/cpu/ppc4xx/cpu_init.c @@ -135,6 +135,7 @@ cpu_init_f (void) #if defined (CFG_GPIO0_TCR) out32(GPIO0_TCR, CFG_GPIO0_TCR); /* enable output driver for outputs */ #endif +#endif /* CONFIG_405E? !CFG_4xx_GPIO_TABLE */
#if defined (CONFIG_405EP) /* @@ -147,7 +148,6 @@ cpu_init_f (void) */ mtdcr(cpc0_pci, mfdcr(cpc0_pci) | CPC0_PCI_HOST_CFG_EN | CPC0_PCI_ARBIT_EN); #endif /* CONFIG_405EP */ -#endif /* CONFIG_405EP */
#if defined(CFG_4xx_GPIO_TABLE) gpio_set_chip_configuration();
Applied to u-boot-ppc4xx locally. Thanks.
Best regards, Stefan
Markus Brunner
Stefan Roese
