[PATCH V2 0/4] arm: dts: k3-am625*: Upgrade kernel dts to v6.7-rc1
Hi, rev 2 of the series to sync am62 with v6.7-rc1.
Changes: - picked up reviews, tested tags. - minor commit message correction in patch #4.
Boot logs: https://gist.github.com/nmenon/d62c4795c6d3d40c83ba36d1cd047c42
WARNING: This will have a minor conflict (binman) with: https://lore.kernel.org/u-boot/20231104080137.9628-1-nm@ti.com/
I haven't had a chance to test this out on verdin (only build tested) - going to depend on any checks folks can provide.
V1: https://lore.kernel.org/all/20231113145919.1928812-1-nm@ti.com/
Nishanth Menon (4): arm: dts: k3-am625*: Sync with kernel v6.7-rc1 arm: dts: k3-am625: Drop SoC provided bootph params from board u-boot/r5 dtsi arm: dts: k3-am625-beagleplay-u-boot: drop duplicate bootph-nodes arm: dts: k3-am625-sk-r5/u-boot: Drop duplicate bootph-nodes
arch/arm/dts/k3-am62-main.dtsi | 12 +- arch/arm/dts/k3-am62-mcu.dtsi | 2 + arch/arm/dts/k3-am62-verdin-wifi.dtsi | 6 + arch/arm/dts/k3-am62-verdin.dtsi | 1 + arch/arm/dts/k3-am62-wakeup.dtsi | 2 + arch/arm/dts/k3-am62.dtsi | 3 + arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi | 110 ------------- arch/arm/dts/k3-am625-beagleplay.dts | 34 +++- arch/arm/dts/k3-am625-r5-beagleplay.dts | 9 -- arch/arm/dts/k3-am625-r5-sk.dts | 21 +-- arch/arm/dts/k3-am625-sk-u-boot.dtsi | 145 ------------------ arch/arm/dts/k3-am625-sk.dts | 27 ++++ arch/arm/dts/k3-am625-verdin-r5.dts | 9 -- .../dts/k3-am625-verdin-wifi-dev-u-boot.dtsi | 55 +------ arch/arm/dts/k3-am62x-sk-common.dtsi | 109 ++++++++++++- 15 files changed, 197 insertions(+), 348 deletions(-)
Sync with kernel v6.7-rc1 and sync up the u-boot dts files accordingly.
Tested-by: Dhruva Gole d-gole@ti.com Signed-off-by: Nishanth Menon nm@ti.com --- Changes since v1: - just tested-by tag.
V1: https://lore.kernel.org/r/20231113145919.1928812-2-nm@ti.com
arch/arm/dts/k3-am62-main.dtsi | 12 ++- arch/arm/dts/k3-am62-mcu.dtsi | 2 + arch/arm/dts/k3-am62-verdin-wifi.dtsi | 6 ++ arch/arm/dts/k3-am62-verdin.dtsi | 1 + arch/arm/dts/k3-am62-wakeup.dtsi | 2 + arch/arm/dts/k3-am62.dtsi | 3 + arch/arm/dts/k3-am625-beagleplay.dts | 34 +++++++- arch/arm/dts/k3-am625-sk.dts | 27 +++++++ arch/arm/dts/k3-am62x-sk-common.dtsi | 109 +++++++++++++++++++++++++- 9 files changed, 193 insertions(+), 3 deletions(-)
diff --git a/arch/arm/dts/k3-am62-main.dtsi b/arch/arm/dts/k3-am62-main.dtsi index 284b90c94da8..e5c64c86d1d5 100644 --- a/arch/arm/dts/k3-am62-main.dtsi +++ b/arch/arm/dts/k3-am62-main.dtsi @@ -81,7 +81,8 @@ };
dmss: bus@48000000 { - compatible = "simple-mfd"; + bootph-all; + compatible = "simple-bus"; #address-cells = <2>; #size-cells = <2>; dma-ranges; @@ -90,6 +91,7 @@ ti,sci-dev-id = <25>;
secure_proxy_main: mailbox@4d000000 { + bootph-all; compatible = "ti,am654-secure-proxy"; #mbox-cells = <1>; reg-names = "target_data", "rt", "scfg"; @@ -165,6 +167,7 @@ };
dmsc: system-controller@44043000 { + bootph-all; compatible = "ti,k2g-sci"; ti,host-id = <12>; mbox-names = "rx", "tx"; @@ -174,16 +177,19 @@ reg = <0x00 0x44043000 0x00 0xfe0>;
k3_pds: power-controller { + bootph-all; compatible = "ti,sci-pm-domain"; #power-domain-cells = <2>; };
k3_clks: clock-controller { + bootph-all; compatible = "ti,k2g-sci-clk"; #clock-cells = <2>; };
k3_reset: reset-controller { + bootph-all; compatible = "ti,sci-reset"; #reset-cells = <2>; }; @@ -202,6 +208,7 @@ };
secure_proxy_sa3: mailbox@43600000 { + bootph-pre-ram; compatible = "ti,am654-secure-proxy"; #mbox-cells = <1>; reg-names = "target_data", "rt", "scfg"; @@ -217,6 +224,7 @@ };
main_pmx0: pinctrl@f4000 { + bootph-all; compatible = "pinctrl-single"; reg = <0x00 0xf4000 0x00 0x2ac>; #pinctrl-cells = <1>; @@ -225,12 +233,14 @@ };
main_esm: esm@420000 { + bootph-pre-ram; compatible = "ti,j721e-esm"; reg = <0x00 0x420000 0x00 0x1000>; ti,esm-pins = <160>, <161>, <162>, <163>, <177>, <178>; };
main_timer0: timer@2400000 { + bootph-all; compatible = "ti,am654-timer"; reg = <0x00 0x2400000 0x00 0x400>; interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>; diff --git a/arch/arm/dts/k3-am62-mcu.dtsi b/arch/arm/dts/k3-am62-mcu.dtsi index 80a3e1db26a9..0e0b234581c6 100644 --- a/arch/arm/dts/k3-am62-mcu.dtsi +++ b/arch/arm/dts/k3-am62-mcu.dtsi @@ -7,6 +7,7 @@
&cbass_mcu { mcu_pmx0: pinctrl@4084000 { + bootph-all; compatible = "pinctrl-single"; reg = <0x00 0x04084000 0x00 0x88>; #pinctrl-cells = <1>; @@ -15,6 +16,7 @@ };
mcu_esm: esm@4100000 { + bootph-pre-ram; compatible = "ti,j721e-esm"; reg = <0x00 0x4100000 0x00 0x1000>; ti,esm-pins = <0>, <1>, <2>, <85>; diff --git a/arch/arm/dts/k3-am62-verdin-wifi.dtsi b/arch/arm/dts/k3-am62-verdin-wifi.dtsi index 90ddc71bcd30..a6808b10c7b2 100644 --- a/arch/arm/dts/k3-am62-verdin-wifi.dtsi +++ b/arch/arm/dts/k3-am62-verdin-wifi.dtsi @@ -35,5 +35,11 @@ &main_uart5 { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart5>; + uart-has-rtscts; status = "okay"; + + bluetooth { + compatible = "nxp,88w8987-bt"; + fw-init-baudrate = <3000000>; + }; }; diff --git a/arch/arm/dts/k3-am62-verdin.dtsi b/arch/arm/dts/k3-am62-verdin.dtsi index 40992e7e4c30..5db52f237253 100644 --- a/arch/arm/dts/k3-am62-verdin.dtsi +++ b/arch/arm/dts/k3-am62-verdin.dtsi @@ -1061,6 +1061,7 @@ vddc-supply = <®_1v2_dsi>; vddmipi-supply = <®_1v2_dsi>; vddio-supply = <®_1v8_dsi>; + status = "disabled";
dsi_bridge_ports: ports { #address-cells = <1>; diff --git a/arch/arm/dts/k3-am62-wakeup.dtsi b/arch/arm/dts/k3-am62-wakeup.dtsi index eae052887186..fef76f52a52e 100644 --- a/arch/arm/dts/k3-am62-wakeup.dtsi +++ b/arch/arm/dts/k3-am62-wakeup.dtsi @@ -7,6 +7,7 @@
&cbass_wakeup { wkup_conf: syscon@43000000 { + bootph-all; compatible = "syscon", "simple-mfd"; reg = <0x00 0x43000000 0x00 0x20000>; #address-cells = <1>; @@ -14,6 +15,7 @@ ranges = <0x0 0x00 0x43000000 0x20000>;
chipid: chipid@14 { + bootph-all; compatible = "ti,am654-chipid"; reg = <0x14 0x4>; }; diff --git a/arch/arm/dts/k3-am62.dtsi b/arch/arm/dts/k3-am62.dtsi index 11f14eef2d44..f1e15206e1ce 100644 --- a/arch/arm/dts/k3-am62.dtsi +++ b/arch/arm/dts/k3-am62.dtsi @@ -47,6 +47,7 @@ };
cbass_main: bus@f0000 { + bootph-all; compatible = "simple-bus"; #address-cells = <2>; #size-cells = <2>; @@ -86,6 +87,7 @@ <0x00 0x43000000 0x00 0x43000000 0x00 0x00020000>;
cbass_mcu: bus@4000000 { + bootph-all; compatible = "simple-bus"; #address-cells = <2>; #size-cells = <2>; @@ -93,6 +95,7 @@ };
cbass_wakeup: bus@b00000 { + bootph-all; compatible = "simple-bus"; #address-cells = <2>; #size-cells = <2>; diff --git a/arch/arm/dts/k3-am625-beagleplay.dts b/arch/arm/dts/k3-am625-beagleplay.dts index 7cfdf562b53b..9a6bd0a3c94f 100644 --- a/arch/arm/dts/k3-am625-beagleplay.dts +++ b/arch/arm/dts/k3-am625-beagleplay.dts @@ -46,6 +46,7 @@ };
memory@80000000 { + bootph-pre-ram; device_type = "memory"; /* 2G RAM */ reg = <0x00000000 0x80000000 0x00000000 0x80000000>; @@ -58,7 +59,7 @@
ramoops: ramoops@9ca00000 { compatible = "ramoops"; - reg = <0x00 0x9c700000 0x00 0x00100000>; + reg = <0x00 0x9ca00000 0x00 0x00100000>; record-size = <0x8000>; console-size = <0x8000>; ftrace-size = <0x00>; @@ -83,6 +84,7 @@ };
vsys_5v0: regulator-1 { + bootph-all; compatible = "regulator-fixed"; regulator-name = "vsys_5v0"; regulator-min-microvolt = <5000000>; @@ -93,6 +95,7 @@
vdd_3v3: regulator-2 { /* output of TLV62595DMQR-U12 */ + bootph-all; compatible = "regulator-fixed"; regulator-name = "vdd_3v3"; regulator-min-microvolt = <3300000>; @@ -118,6 +121,7 @@
vdd_3v3_sd: regulator-4 { /* output of TPS22918DBVR-U21 */ + bootph-all; pinctrl-names = "default"; pinctrl-0 = <&vdd_3v3_sd_pins_default>;
@@ -132,6 +136,7 @@ };
vdd_sd_dv: regulator-5 { + bootph-all; compatible = "regulator-gpio"; regulator-name = "sd_hs200_switch"; pinctrl-names = "default"; @@ -146,9 +151,11 @@ };
leds { + bootph-all; compatible = "gpio-leds";
led-0 { + bootph-all; gpios = <&main_gpio0 3 GPIO_ACTIVE_HIGH>; linux,default-trigger = "heartbeat"; function = LED_FUNCTION_HEARTBEAT; @@ -156,6 +163,7 @@ };
led-1 { + bootph-all; gpios = <&main_gpio0 4 GPIO_ACTIVE_HIGH>; linux,default-trigger = "disk-activity"; function = LED_FUNCTION_DISK_ACTIVITY; @@ -163,16 +171,19 @@ };
led-2 { + bootph-all; gpios = <&main_gpio0 5 GPIO_ACTIVE_HIGH>; function = LED_FUNCTION_CPU; };
led-3 { + bootph-all; gpios = <&main_gpio0 6 GPIO_ACTIVE_HIGH>; function = LED_FUNCTION_LAN; };
led-4 { + bootph-all; gpios = <&main_gpio0 9 GPIO_ACTIVE_HIGH>; function = LED_FUNCTION_WLAN; }; @@ -245,6 +256,7 @@
&main_pmx0 { gpio0_pins_default: gpio0-default-pins { + bootph-all; pinctrl-single,pins = < AM62X_IOPAD(0x0004, PIN_INPUT, 7) /* (G25) OSPI0_LBCLKO.GPIO0_1 */ AM62X_IOPAD(0x0008, PIN_INPUT, 7) /* (J24) OSPI0_DQS.GPIO0_2 */ @@ -264,6 +276,7 @@ };
vdd_sd_dv_pins_default: vdd-sd-default-pins { + bootph-all; pinctrl-single,pins = < AM62X_IOPAD(0x0244, PIN_OUTPUT, 7) /* (C17) MMC1_SDWP.GPIO1_49 */ >; @@ -283,6 +296,7 @@ };
local_i2c_pins_default: local-i2c-default-pins { + bootph-all; pinctrl-single,pins = < AM62X_IOPAD(0x01e0, PIN_INPUT_PULLUP, 0) /* (B16) I2C0_SCL */ AM62X_IOPAD(0x01e4, PIN_INPUT_PULLUP, 0) /* (A16) I2C0_SDA */ @@ -321,6 +335,7 @@ };
emmc_pins_default: emmc-default-pins { + bootph-all; pinctrl-single,pins = < AM62X_IOPAD(0x0220, PIN_INPUT, 0) /* (Y3) MMC0_CMD */ AM62X_IOPAD(0x0218, PIN_INPUT, 0) /* (AB1) MMC0_CLK */ @@ -336,12 +351,14 @@ };
vdd_3v3_sd_pins_default: vdd-3v3-sd-default-pins { + bootph-all; pinctrl-single,pins = < AM62X_IOPAD(0x01c4, PIN_INPUT, 7) /* (B14) SPI0_D1_GPIO1_19 */ >; };
sd_pins_default: sd-default-pins { + bootph-all; pinctrl-single,pins = < AM62X_IOPAD(0x023c, PIN_INPUT, 0) /* (A21) MMC1_CMD */ AM62X_IOPAD(0x0234, PIN_INPUT, 0) /* (B22) MMC1_CLK */ @@ -418,6 +435,7 @@ };
mikrobus_gpio_pins_default: mikrobus-gpio-default-pins { + bootph-all; pinctrl-single,pins = < AM62X_IOPAD(0x019c, PIN_INPUT, 7) /* (B18) MCASP0_AXR1.GPIO1_9 */ AM62X_IOPAD(0x01a0, PIN_INPUT, 7) /* (E18) MCASP0_AXR0.GPIO1_10 */ @@ -426,6 +444,7 @@ };
console_pins_default: console-default-pins { + bootph-all; pinctrl-single,pins = < AM62X_IOPAD(0x01c8, PIN_INPUT, 0) /* (D14) UART0_RXD */ AM62X_IOPAD(0x01cc, PIN_OUTPUT, 0) /* (E14) UART0_TXD */ @@ -597,6 +616,7 @@ };
&main_gpio0 { + bootph-all; pinctrl-names = "default"; pinctrl-0 = <&gpio0_pins_default>; gpio-line-names = "BL_EN_3V3", "SPE_PO_EN", "RTC_INT", /* 0-2 */ @@ -616,6 +636,7 @@ };
&main_gpio1 { + bootph-all; pinctrl-names = "default"; pinctrl-0 = <&mikrobus_gpio_pins_default>; gpio-line-names = "", "", "", "", "", /* 0-4 */ @@ -633,6 +654,7 @@ };
&main_i2c0 { + bootph-all; pinctrl-names = "default"; pinctrl-0 = <&local_i2c_pins_default>; clock-frequency = <400000>; @@ -651,6 +673,7 @@ };
tps65219: pmic@30 { + bootph-all; compatible = "ti,tps65219"; reg = <0x30>; buck1-supply = <&vsys_5v0>; @@ -801,6 +824,7 @@ };
&sdhci0 { + bootph-all; pinctrl-names = "default"; pinctrl-0 = <&emmc_pins_default>; ti,driver-strength-ohm = <50>; @@ -810,6 +834,7 @@
&sdhci1 { /* SD/MMC */ + bootph-all; pinctrl-names = "default"; pinctrl-0 = <&sd_pins_default>;
@@ -850,6 +875,7 @@ };
&main_uart0 { + bootph-all; pinctrl-names = "default"; pinctrl-0 = <&console_pins_default>; status = "okay"; @@ -870,6 +896,12 @@ pinctrl-names = "default"; pinctrl-0 = <&wifi_debug_uart_pins_default>; status = "okay"; + + mcu { + compatible = "ti,cc1352p7"; + reset-gpios = <&main_gpio0 72 GPIO_ACTIVE_LOW>; + vdds-supply = <&vdd_3v3>; + }; };
&dss { diff --git a/arch/arm/dts/k3-am625-sk.dts b/arch/arm/dts/k3-am625-sk.dts index 7c98c1b855d1..b18092497c9a 100644 --- a/arch/arm/dts/k3-am625-sk.dts +++ b/arch/arm/dts/k3-am625-sk.dts @@ -31,6 +31,7 @@
vmain_pd: regulator-0 { /* TPS65988 PD CONTROLLER OUTPUT */ + bootph-all; compatible = "regulator-fixed"; regulator-name = "vmain_pd"; regulator-min-microvolt = <5000000>; @@ -41,6 +42,7 @@
vcc_5v0: regulator-1 { /* Output of LM34936 */ + bootph-all; compatible = "regulator-fixed"; regulator-name = "vcc_5v0"; regulator-min-microvolt = <5000000>; @@ -52,6 +54,7 @@
vcc_3v3_sys: regulator-2 { /* output of LM61460-Q1 */ + bootph-all; compatible = "regulator-fixed"; regulator-name = "vcc_3v3_sys"; regulator-min-microvolt = <3300000>; @@ -63,6 +66,7 @@
vdd_mmc1: regulator-3 { /* TPS22918DBVR */ + bootph-all; compatible = "regulator-fixed"; regulator-name = "vdd_mmc1"; regulator-min-microvolt = <3300000>; @@ -75,6 +79,7 @@
vdd_sd_dv: regulator-4 { /* Output of TLV71033 */ + bootph-all; compatible = "regulator-gpio"; regulator-name = "tlv71033"; pinctrl-names = "default"; @@ -102,6 +107,7 @@
&main_pmx0 { main_rgmii2_pins_default: main-rgmii2-default-pins { + bootph-all; pinctrl-single,pins = < AM62X_IOPAD(0x184, PIN_INPUT, 0) /* (AE23) RGMII2_RD0 */ AM62X_IOPAD(0x188, PIN_INPUT, 0) /* (AB20) RGMII2_RD1 */ @@ -119,6 +125,7 @@ };
ospi0_pins_default: ospi0-default-pins { + bootph-all; pinctrl-single,pins = < AM62X_IOPAD(0x000, PIN_OUTPUT, 0) /* (H24) OSPI0_CLK */ AM62X_IOPAD(0x02c, PIN_OUTPUT, 0) /* (F23) OSPI0_CSn0 */ @@ -135,20 +142,32 @@ };
vdd_sd_dv_pins_default: vdd-sd-dv-default-pins { + bootph-all; pinctrl-single,pins = < AM62X_IOPAD(0x07c, PIN_OUTPUT, 7) /* (P25) GPMC0_CLK.GPIO0_31 */ >; };
main_gpio1_ioexp_intr_pins_default: main-gpio1-ioexp-intr-default-pins { + bootph-all; pinctrl-single,pins = < AM62X_IOPAD(0x01d4, PIN_INPUT, 7) /* (B15) UART0_RTSn.GPIO1_23 */ >; }; };
+&main_gpio0 { + bootph-all; +}; + +&main_gpio1 { + bootph-all; +}; + &main_i2c1 { + bootph-all; exp1: gpio@22 { + bootph-all; compatible = "ti,tca6424"; reg = <0x22>; gpio-controller; @@ -207,12 +226,18 @@ }; };
+&fss { + bootph-all; +}; + &ospi0 { + bootph-all; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&ospi0_pins_default>;
flash@0 { + bootph-all; compatible = "jedec,spi-nor"; reg = <0x0>; spi-tx-bus-width = <8>; @@ -225,6 +250,7 @@ cdns,read-delay = <4>;
partitions { + bootph-all; compatible = "fixed-partitions"; #address-cells = <1>; #size-cells = <1>; @@ -260,6 +286,7 @@ };
partition@3fc0000 { + bootph-pre-ram; label = "ospi.phypattern"; reg = <0x3fc0000 0x40000>; }; diff --git a/arch/arm/dts/k3-am62x-sk-common.dtsi b/arch/arm/dts/k3-am62x-sk-common.dtsi index 34c8ffc553ec..19f57ead4ebd 100644 --- a/arch/arm/dts/k3-am62x-sk-common.dtsi +++ b/arch/arm/dts/k3-am62x-sk-common.dtsi @@ -28,6 +28,7 @@ };
memory@80000000 { + bootph-pre-ram; device_type = "memory"; /* 2G RAM */ reg = <0x00000000 0x80000000 0x00000000 0x80000000>; @@ -114,11 +115,23 @@ clocks = <&tlv320_mclk>; }; }; + + hdmi0: connector-hdmi { + compatible = "hdmi-connector"; + label = "hdmi"; + type = "a"; + port { + hdmi_connector_in: endpoint { + remote-endpoint = <&sii9022_out>; + }; + }; + }; };
&main_pmx0 { /* First pad number is ALW package and second is AMC package */ main_uart0_pins_default: main-uart0-default-pins { + bootph-all; pinctrl-single,pins = < AM62X_IOPAD(0x1c8, PIN_INPUT, 0) /* (D14/A13) UART0_RXD */ AM62X_IOPAD(0x1cc, PIN_OUTPUT, 0) /* (E14/E11) UART0_TXD */ @@ -126,6 +139,7 @@ };
main_uart1_pins_default: main-uart1-default-pins { + bootph-pre-ram; pinctrl-single,pins = < AM62X_IOPAD(0x194, PIN_INPUT, 2) /* (B19/B18) MCASP0_AXR3.UART1_CTSn */ AM62X_IOPAD(0x198, PIN_OUTPUT, 2) /* (A19/B17) MCASP0_AXR2.UART1_RTSn */ @@ -156,6 +170,7 @@ };
main_mmc0_pins_default: main-mmc0-default-pins { + bootph-all; pinctrl-single,pins = < AM62X_IOPAD(0x220, PIN_INPUT, 0) /* (Y3/V3) MMC0_CMD */ AM62X_IOPAD(0x218, PIN_INPUT, 0) /* (AB1/Y1) MMC0_CLK */ @@ -171,6 +186,7 @@ };
main_mmc1_pins_default: main-mmc1-default-pins { + bootph-all; pinctrl-single,pins = < AM62X_IOPAD(0x23c, PIN_INPUT, 0) /* (A21/C18) MMC1_CMD */ AM62X_IOPAD(0x234, PIN_INPUT, 0) /* (B22/A20) MMC1_CLK */ @@ -196,6 +212,7 @@ };
main_rgmii1_pins_default: main-rgmii1-default-pins { + bootph-all; pinctrl-single,pins = < AM62X_IOPAD(0x14c, PIN_INPUT, 0) /* (AB17/W15) RGMII1_RD0 */ AM62X_IOPAD(0x150, PIN_INPUT, 0) /* (AC17/Y16) RGMII1_RD1 */ @@ -226,10 +243,44 @@ AM62X_IOPAD(0x084, PIN_INPUT, 2) /* (L23/K20) GPMC0_ADVN_ALE.MCASP1_AXR2 */ >; }; + + main_dss0_pins_default: main-dss0-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x100, PIN_OUTPUT, 0) /* (AC25) VOUT0_VSYNC */ + AM62X_IOPAD(0x0f8, PIN_OUTPUT, 0) /* (AB24) VOUT0_HSYNC */ + AM62X_IOPAD(0x104, PIN_OUTPUT, 0) /* (AC24) VOUT0_PCLK */ + AM62X_IOPAD(0x0fc, PIN_OUTPUT, 0) /* (Y20) VOUT0_DE */ + AM62X_IOPAD(0x0b8, PIN_OUTPUT, 0) /* (U22) VOUT0_DATA0 */ + AM62X_IOPAD(0x0bc, PIN_OUTPUT, 0) /* (V24) VOUT0_DATA1 */ + AM62X_IOPAD(0x0c0, PIN_OUTPUT, 0) /* (W25) VOUT0_DATA2 */ + AM62X_IOPAD(0x0c4, PIN_OUTPUT, 0) /* (W24) VOUT0_DATA3 */ + AM62X_IOPAD(0x0c8, PIN_OUTPUT, 0) /* (Y25) VOUT0_DATA4 */ + AM62X_IOPAD(0x0cc, PIN_OUTPUT, 0) /* (Y24) VOUT0_DATA5 */ + AM62X_IOPAD(0x0d0, PIN_OUTPUT, 0) /* (Y23) VOUT0_DATA6 */ + AM62X_IOPAD(0x0d4, PIN_OUTPUT, 0) /* (AA25) VOUT0_DATA7 */ + AM62X_IOPAD(0x0d8, PIN_OUTPUT, 0) /* (V21) VOUT0_DATA8 */ + AM62X_IOPAD(0x0dc, PIN_OUTPUT, 0) /* (W21) VOUT0_DATA9 */ + AM62X_IOPAD(0x0e0, PIN_OUTPUT, 0) /* (V20) VOUT0_DATA10 */ + AM62X_IOPAD(0x0e4, PIN_OUTPUT, 0) /* (AA23) VOUT0_DATA11 */ + AM62X_IOPAD(0x0e8, PIN_OUTPUT, 0) /* (AB25) VOUT0_DATA12 */ + AM62X_IOPAD(0x0ec, PIN_OUTPUT, 0) /* (AA24) VOUT0_DATA13 */ + AM62X_IOPAD(0x0f0, PIN_OUTPUT, 0) /* (Y22) VOUT0_DATA14 */ + AM62X_IOPAD(0x0f4, PIN_OUTPUT, 0) /* (AA21) VOUT0_DATA15 */ + AM62X_IOPAD(0x05c, PIN_OUTPUT, 1) /* (R24) GPMC0_AD8.VOUT0_DATA16 */ + AM62X_IOPAD(0x060, PIN_OUTPUT, 1) /* (R25) GPMC0_AD9.VOUT0_DATA17 */ + AM62X_IOPAD(0x064, PIN_OUTPUT, 1) /* (T25) GPMC0_AD10.VOUT0_DATA18 */ + AM62X_IOPAD(0x068, PIN_OUTPUT, 1) /* (R21) GPMC0_AD11.VOUT0_DATA19 */ + AM62X_IOPAD(0x06c, PIN_OUTPUT, 1) /* (T22) GPMC0_AD12.VOUT0_DATA20 */ + AM62X_IOPAD(0x070, PIN_OUTPUT, 1) /* (T24) GPMC0_AD13.VOUT0_DATA21 */ + AM62X_IOPAD(0x074, PIN_OUTPUT, 1) /* (U25) GPMC0_AD14.VOUT0_DATA22 */ + AM62X_IOPAD(0x078, PIN_OUTPUT, 1) /* (U24) GPMC0_AD15.VOUT0_DATA23 */ + >; + }; };
&mcu_pmx0 { wkup_uart0_pins_default: wkup-uart0-default-pins { + bootph-pre-ram; pinctrl-single,pins = < AM62X_MCU_IOPAD(0x02c, PIN_INPUT, 0) /* (C6/A7) WKUP_UART0_CTSn */ AM62X_MCU_IOPAD(0x030, PIN_OUTPUT, 0) /* (A4/B4) WKUP_UART0_RTSn */ @@ -241,12 +292,14 @@
&wkup_uart0 { /* WKUP UART0 is used by DM firmware */ + bootph-pre-ram; status = "reserved"; pinctrl-names = "default"; pinctrl-0 = <&wkup_uart0_pins_default>; };
&main_uart0 { + bootph-all; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&main_uart0_pins_default>; @@ -254,6 +307,7 @@
&main_uart1 { /* Main UART1 is used by TIFS firmware */ + bootph-pre-ram; status = "reserved"; pinctrl-names = "default"; pinctrl-0 = <&main_uart1_pins_default>; @@ -300,7 +354,7 @@ status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&main_i2c1_pins_default>; - clock-frequency = <400000>; + clock-frequency = <100000>;
tlv320aic3106: audio-codec@1b { #sound-dai-cells = <0>; @@ -313,9 +367,40 @@ IOVDD-supply = <&vcc_3v3_sys>; DRVDD-supply = <&vcc_3v3_sys>; }; + + sii9022: bridge-hdmi@3b { + compatible = "sil,sii9022"; + reg = <0x3b>; + interrupt-parent = <&exp1>; + interrupts = <16 IRQ_TYPE_EDGE_FALLING>; + #sound-dai-cells = <0>; + sil,i2s-data-lanes = < 0 >; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + + sii9022_in: endpoint { + remote-endpoint = <&dpi1_out>; + }; + }; + + port@1 { + reg = <1>; + + sii9022_out: endpoint { + remote-endpoint = <&hdmi_connector_in>; + }; + }; + }; + }; };
&sdhci0 { + bootph-all; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&main_mmc0_pins_default>; @@ -325,6 +410,7 @@
&sdhci1 { /* SD/MMC */ + bootph-all; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&main_mmc1_pins_default>; @@ -333,21 +419,25 @@ };
&cpsw3g { + bootph-all; pinctrl-names = "default"; pinctrl-0 = <&main_rgmii1_pins_default>; };
&cpsw_port1 { + bootph-all; phy-mode = "rgmii-rxid"; phy-handle = <&cpsw3g_phy0>; };
&cpsw3g_mdio { + bootph-all; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&main_mdio1_pins_default>;
cpsw3g_phy0: ethernet-phy@0 { + bootph-all; reg = <0>; ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>; @@ -410,3 +500,20 @@ tx-num-evt = <32>; rx-num-evt = <32>; }; + +&dss { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&main_dss0_pins_default>; +}; + +&dss_ports { + /* VP2: DPI Output */ + port@1 { + reg = <1>; + + dpi1_out: endpoint { + remote-endpoint = <&sii9022_in>; + }; + }; +};
For the series, applied to u-boot/next, thanks!
k3-am62* SoC dtsi files now provide the following:
bootph-all: dmss secure_proxy_main dmsc k3_pds k3_clks k3_reset main_pmx0 main_timer0 mcu_pmx0 wkup_conf chipid
bootph-pre-ram: secure_proxy_sa3 main_esm mcu_esm
Drop these from board r5 and u-boot.dtsi files as these are duplicate in them now.
Acked-by: Francesco Dolcini francesco.dolcini@toradex.com Tested-by: Dhruva Gole d-gole@ti.com Signed-off-by: Nishanth Menon nm@ti.com --- Changes since v1: - just picked up acks and tested tags
V1: https://lore.kernel.org/r/20231113145919.1928812-3-nm@ti.com
arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi | 54 ------------------ arch/arm/dts/k3-am625-r5-beagleplay.dts | 9 --- arch/arm/dts/k3-am625-r5-sk.dts | 9 --- arch/arm/dts/k3-am625-sk-u-boot.dtsi | 53 ------------------ arch/arm/dts/k3-am625-verdin-r5.dts | 9 --- .../dts/k3-am625-verdin-wifi-dev-u-boot.dtsi | 55 +------------------ 6 files changed, 2 insertions(+), 187 deletions(-)
diff --git a/arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi b/arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi index d6c6baa5518b..6f3a31558b20 100644 --- a/arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi +++ b/arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi @@ -47,59 +47,17 @@ }; };
-&cbass_main { - bootph-all; -}; - &main_timer0 { clock-frequency = <25000000>; - bootph-all; -}; - -&dmss { - bootph-all; -}; - -&secure_proxy_main { - bootph-all; -}; - -&dmsc { - bootph-all; -}; - -&k3_pds { - bootph-all; -}; - -&k3_clks { - bootph-all; -}; - -&k3_reset { - bootph-all; };
&dmsc { - bootph-all; k3_sysreset: sysreset-controller { compatible = "ti,sci-sysreset"; bootph-all; }; };
-&wkup_conf { - bootph-all; -}; - -&chipid { - bootph-all; -}; - -&main_pmx0 { - bootph-all; -}; - &main_uart0 { bootph-all; }; @@ -108,18 +66,6 @@ bootph-all; };
-&cbass_mcu { - bootph-all; -}; - -&cbass_wakeup { - bootph-all; -}; - -&mcu_pmx0 { - bootph-all; -}; - &main_i2c0 { bootph-all; }; diff --git a/arch/arm/dts/k3-am625-r5-beagleplay.dts b/arch/arm/dts/k3-am625-r5-beagleplay.dts index 9c9d0570592a..1f450f55c1d2 100644 --- a/arch/arm/dts/k3-am625-r5-beagleplay.dts +++ b/arch/arm/dts/k3-am625-r5-beagleplay.dts @@ -54,12 +54,7 @@ ti,secure-host; };
-&mcu_esm { - bootph-pre-ram; -}; - &secure_proxy_sa3 { - bootph-pre-ram; /* We require this for boot handshake */ status = "okay"; }; @@ -73,10 +68,6 @@ }; };
-&main_esm { - bootph-pre-ram; -}; - &main_pktdma { ti,sci = <&dm_tifs>; }; diff --git a/arch/arm/dts/k3-am625-r5-sk.dts b/arch/arm/dts/k3-am625-r5-sk.dts index bf219226b974..55420b2f2c15 100644 --- a/arch/arm/dts/k3-am625-r5-sk.dts +++ b/arch/arm/dts/k3-am625-r5-sk.dts @@ -55,20 +55,11 @@ ti,secure-host; };
-&main_esm { - bootph-pre-ram; -}; - &cbass_main { sysctrler: sysctrler { compatible = "ti,am654-system-controller"; diff --git a/arch/arm/dts/k3-am625-sk-u-boot.dtsi b/arch/arm/dts/k3-am625-sk-u-boot.dtsi index 7ae5e01f7c7f..dcf7c7652d31 100644 --- a/arch/arm/dts/k3-am625-sk-u-boot.dtsi +++ b/arch/arm/dts/k3-am625-sk-u-boot.dtsi @@ -25,49 +25,8 @@ bootph-all; };
-&cbass_main { - bootph-all; -}; - &main_timer0 { clock-frequency = <25000000>; - bootph-all; -}; - -&dmss { - bootph-all; -}; - -&secure_proxy_main { - bootph-all; -}; - -&dmsc { - bootph-all; -}; - -&k3_pds { - bootph-all; -}; - -&k3_clks { - bootph-all; -}; - -&k3_reset { - bootph-all; -}; - -&wkup_conf { - bootph-all; -}; - -&chipid { - bootph-all; -}; - -&main_pmx0 { - bootph-all; };
&main_uart0 { @@ -78,18 +37,6 @@ bootph-all; };
-&cbass_mcu { - bootph-all; -}; - -&cbass_wakeup { - bootph-all; -}; - -&mcu_pmx0 { - bootph-all; -}; - &sdhci1 { bootph-all; }; diff --git a/arch/arm/dts/k3-am625-verdin-r5.dts b/arch/arm/dts/k3-am625-verdin-r5.dts index 0cae9c577732..305d199678b3 100644 --- a/arch/arm/dts/k3-am625-verdin-r5.dts +++ b/arch/arm/dts/k3-am625-verdin-r5.dts @@ -69,16 +69,7 @@ ti,secure-host; };
-&main_esm { - bootph-pre-ram; -}; - -&mcu_esm { - bootph-pre-ram; -}; - &secure_proxy_sa3 { - bootph-pre-ram; /* We require this for boot handshake */ status = "okay"; }; diff --git a/arch/arm/dts/k3-am625-verdin-wifi-dev-u-boot.dtsi b/arch/arm/dts/k3-am625-verdin-wifi-dev-u-boot.dtsi index 75cb60b57d79..86e2d111f541 100644 --- a/arch/arm/dts/k3-am625-verdin-wifi-dev-u-boot.dtsi +++ b/arch/arm/dts/k3-am625-verdin-wifi-dev-u-boot.dtsi @@ -21,25 +21,8 @@ }; };
-&cbass_main { - bootph-all; - - timer@2400000 { - clock-frequency = <25000000>; - bootph-all; - }; -}; - -&cbass_mcu { - bootph-all; -}; - -&cbass_wakeup { - bootph-all; -}; - -&chipid { - bootph-all; +&main_timer0 { + clock-frequency = <25000000>; };
&main_bcdma { @@ -98,34 +81,16 @@ };
&dmsc { - bootph-all; - k3_sysreset: sysreset-controller { compatible = "ti,sci-sysreset"; bootph-all; }; };
-&dmss { - bootph-all; -}; - &fss { bootph-all; };
-&k3_clks { - bootph-all; -}; - -&k3_pds { - bootph-all; -}; - -&k3_reset { - bootph-all; -}; - &main_gpio0 { bootph-all; }; @@ -156,10 +121,6 @@ }; };
-&main_pmx0 { - bootph-all; -}; - /* Verdin UART_3, used as the Linux console */ &main_uart0 { bootph-all; @@ -170,10 +131,6 @@ bootph-all; };
-&mcu_pmx0 { - bootph-all; -}; - &pinctrl_ctrl_sleep_moci { bootph-all; }; @@ -210,18 +167,10 @@ status = "disabled"; };
-&secure_proxy_main { - bootph-all; -}; - &verdin_ctrl_sleep_moci { bootph-all; };
-&wkup_conf { - bootph-all; -}; - /* Verdin UART_2 */ &wkup_uart0 { bootph-all;
Kernel dts import now provides bootph-all and bootph-pre-ram properties for the properties we have been overriding so far. Drop the same.
Reviewed-by: Dhruva Gole d-gole@ti.com Tested-by: Dhruva Gole d-gole@ti.com Signed-off-by: Nishanth Menon nm@ti.com --- Changes since v1: - tested and reviewed tags
V1: https://lore.kernel.org/r/20231113145919.1928812-4-nm@ti.com arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi | 56 -------------------- 1 file changed, 56 deletions(-)
diff --git a/arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi b/arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi index 6f3a31558b20..7f8468f298f0 100644 --- a/arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi +++ b/arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi @@ -13,36 +13,26 @@ tick-timer = &main_timer0; };
- memory@80000000 { - bootph-all; - }; - /* Keep the LEDs on by default to indicate life */ leds { - bootph-all; led-0 { default-state = "on"; - bootph-all; };
led-1 { default-state = "on"; - bootph-all; };
led-2 { default-state = "on"; - bootph-all; };
led-3 { default-state = "on"; - bootph-all; };
led-4 { default-state = "on"; - bootph-all; }; }; }; @@ -58,45 +48,7 @@ }; };
-&main_uart0 { - bootph-all; -}; - -&console_pins_default { - bootph-all; -}; - -&main_i2c0 { - bootph-all; -}; - -&local_i2c_pins_default { - bootph-all; -}; - -&gpio0_pins_default { - bootph-all; -}; - -&main_gpio0 { - bootph-all; -}; - -&main_gpio1 { - bootph-all; -}; - -&sdhci0 { - /* EMMC */ - bootph-all; -}; - -&emmc_pins_default { - bootph-all; -}; - &sd_pins_default { - bootph-all; /* Force to use SDCD card detect pin */ pinctrl-single,pins = < AM62X_IOPAD(0x023c, PIN_INPUT, 0) /* (A21) MMC1_CMD */ @@ -109,14 +61,6 @@ >; };
-&tps65219 { - bootph-all; -}; - -&sdhci1 { - bootph-all; -}; - #ifdef CONFIG_TARGET_AM625_A53_EVM
#define SPL_AM625_BEAGLEPLAY_DTB "spl/dts/k3-am625-beagleplay.dtb"
While at this enable the DM and TIFS UARTs for programming pinmux since they are marked reserved by board.dts
Reviewed-by: Dhruva Gole d-gole@ti.com Tested-by: Dhruva Gole d-gole@ti.com Signed-off-by: Nishanth Menon nm@ti.com --- Changes: - capitalize TIFS and UART. - pick up reviewed and tested tags
V1: https://lore.kernel.org/r/20231113145919.1928812-5-nm@ti.com arch/arm/dts/k3-am625-r5-sk.dts | 12 +--- arch/arm/dts/k3-am625-sk-u-boot.dtsi | 92 ---------------------------- 2 files changed, 2 insertions(+), 102 deletions(-)
diff --git a/arch/arm/dts/k3-am625-r5-sk.dts b/arch/arm/dts/k3-am625-r5-sk.dts index 55420b2f2c15..6b9f40e55581 100644 --- a/arch/arm/dts/k3-am625-r5-sk.dts +++ b/arch/arm/dts/k3-am625-r5-sk.dts @@ -69,22 +69,14 @@ }; };
-&wkup_uart0_pins_default { - bootph-pre-ram; -}; - -&main_uart1_pins_default { - bootph-pre-ram; -}; - /* WKUP UART0 is used for DM firmware logs */ &wkup_uart0 { - bootph-pre-ram; + status = "okay"; };
/* Main UART1 is used for TIFS firmware logs */ &main_uart1 { - bootph-pre-ram; + status = "okay"; };
&ospi0 { diff --git a/arch/arm/dts/k3-am625-sk-u-boot.dtsi b/arch/arm/dts/k3-am625-sk-u-boot.dtsi index dcf7c7652d31..fa778b0ff4c1 100644 --- a/arch/arm/dts/k3-am625-sk-u-boot.dtsi +++ b/arch/arm/dts/k3-am625-sk-u-boot.dtsi @@ -8,71 +8,14 @@
/ { chosen { - stdout-path = "serial2:115200n8"; tick-timer = &main_timer0; }; - - aliases { - mmc1 = &sdhci1; - }; - - memory@80000000 { - bootph-all; - }; -}; - -&main_conf { - bootph-all; };
&main_timer0 { clock-frequency = <25000000>; };
-&main_uart0 { - bootph-all; -}; - -&main_uart0_pins_default { - bootph-all; -}; - -&sdhci1 { - bootph-all; -}; - -&main_mmc1_pins_default { - bootph-all; -}; - -&fss { - bootph-all; -}; - -&ospi0_pins_default { - bootph-all; -}; - -&ospi0 { - bootph-all; - - flash@0 { - bootph-all; - - partitions { - bootph-all; - - partition@3fc0000 { - bootph-all; - }; - }; - }; -}; - -&inta_main_dmss { - bootph-all; -}; - &main_bcdma { reg = <0x00 0x485c0100 0x00 0x100>, <0x00 0x4c000000 0x00 0x20000>, @@ -100,41 +43,6 @@ bootph-all; };
-&cpsw3g_mdio { - bootph-all; -}; - -&cpsw3g_phy0 { - bootph-all; -}; - -&cpsw3g_phy1 { - bootph-all; -}; - -&main_rgmii1_pins_default { - bootph-all; -}; - -&main_rgmii2_pins_default { - bootph-all; -}; - -&phy_gmii_sel { - bootph-all; -}; - -&cpsw3g { - bootph-all; - ethernet-ports { - bootph-all; - }; -}; - -&cpsw_port1 { - bootph-all; -}; - &cpsw_port2 { status = "disabled"; };
Changes:
for this series:
Reviewed-by: Roger Quadros rogerq@kernel.org
Hi Nishanth
For the whole series:
Tested-by: Marcel Ziswiler marcel.ziswiler@toradex.com
Changes:
Thanks!
Cheers
Marcel
Hi Nishanth,
Thank you for the series.
Changes:
Boot tested eMMC boot on AM62 SK EVM.
Tested-by: Mattijs Korpershoek mkorpershoek@baylibre.com # am625 sk
-- 2.40.0
participants (5)
Marcel Ziswiler
Mattijs Korpershoek
Nishanth Menon
Roger Quadros
