[GIT PULL] xilinx patches for v2021.07
Hi Tom,
please pull these changes. There is nothing controversial. I will likely send another pull request with stuff which have been sent recently.
Gitlab CI doesn't show any issue.
Thanks, Michal
The following changes since commit d8eafb16c85bc3b5d85d7ba8ebb1438cc0ae168f:
Prepare v2021.04-rc5 (2021-03-29 17:20:13 -0400)
git@source.denx.de:u-boot/custodians/u-boot-microblaze.git tags/xilinx-for-v2021.07
for you to fetch changes up to c5465684b9c74780fdeb30568c586d824eafd75c:
xilinx: Enable efi debug command (2021-03-30 12:03:25 +0200)
---------------------------------------------------------------- Xilinx changes for v2021.07
net: - Fix gem PCS support
spi: - Small trivial fixes
zynq: - Enable time/timer commands - Update bitmain platform - Several DT changes
zynqmp: - Update clock driver - mini config alignments - Add/update psu_init for zcu208/zcu216/zc1275 - Several DT changes - Enable efi debug command (also for Versal)
---------------------------------------------------------------- Amit Kumar Mahapatra (2): arm64: zynqmp: Update device tree properties for nand flash arm64: zynqmp: Rename clocks as per the Arasan NAND driver
Ashok Reddy Soma (3): xilinx: zynq: Enable time and timer commands arm64: zynqmp: Increase size of malloc pool arm64: zynqmp: Add emmc specific parameters
Michal Simek (8): arm64: zynqmp: Add missing psu inits for zcu208/216 arm64: zynqmp: Add idt 8a34001 chip to zcu208/zcu216 arm64: zynqmp: Update psu_init for zcu1275 xilinx: Sync DTs with Linux kernel ARM: bitmain: Enable nand and smcc drivers ARM: bitmain: Enable legacy u-boot format ARM: bitmain: Enable saving variables to SD card xilinx: Enable efi debug command
Robert Hancock (1): net: gem: Fix setting PCS auto-negotiation state
T Karthik Reddy (2): clk: zynqmp: Fix clk dump values spi: xilinx_spi: Trivial fixes in axi qspi driver
arch/arm/dts/bitmain-antminer-s9.dts | 8 + arch/arm/dts/zynq-zc702.dts | 2 +- arch/arm/dts/zynq-zturn-common.dtsi | 2 +- arch/arm/dts/zynq-zybo-z7.dts | 2 +- arch/arm/dts/zynqmp-clk-ccf.dtsi | 16 +- arch/arm/dts/zynqmp-g-a2197-00-revA.dts | 3 - arch/arm/dts/zynqmp-m-a2197-01-revA.dts | 3 - arch/arm/dts/zynqmp-mini-emmc0.dts | 2 + arch/arm/dts/zynqmp-mini-emmc1.dts | 2 + arch/arm/dts/zynqmp-zc1232-revA.dts | 2 - arch/arm/dts/zynqmp-zc1751-xm015-dc1.dts | 19 +- arch/arm/dts/zynqmp-zc1751-xm016-dc2.dts | 8 + arch/arm/dts/zynqmp-zc1751-xm018-dc4.dts | 2 +- arch/arm/dts/zynqmp-zcu100-revC.dts | 48 ++-- arch/arm/dts/zynqmp-zcu102-revA.dts | 106 ++++++--- arch/arm/dts/zynqmp-zcu104-revA.dts | 44 +++- arch/arm/dts/zynqmp-zcu104-revC.dts | 44 +++- arch/arm/dts/zynqmp-zcu106-revA.dts | 96 +++++++- arch/arm/dts/zynqmp-zcu111-revA.dts | 78 +++++-- arch/arm/dts/zynqmp-zcu208-revA.dts | 63 ++++- arch/arm/dts/zynqmp-zcu216-revA.dts | 63 ++++- arch/arm/dts/zynqmp.dtsi | 156 +++---------- board/xilinx/zynqmp/zynqmp-zcu1275-revB/psu_init_gpl.c | 230 +++++++++++------- board/xilinx/zynqmp/zynqmp-zcu208-revA/psu_init_gpl.c | 1880 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ board/xilinx/zynqmp/zynqmp-zcu216-revA/psu_init_gpl.c | 1882 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ configs/bitmain_antminer_s9_defconfig | 2 + configs/xilinx_versal_virt_defconfig | 1 + configs/xilinx_zynq_virt_defconfig | 2 + configs/xilinx_zynqmp_mini_emmc0_defconfig | 2 + configs/xilinx_zynqmp_mini_emmc1_defconfig | 2 + configs/xilinx_zynqmp_virt_defconfig | 1 + drivers/clk/clk_zynqmp.c | 251 +++++++++++++------- drivers/net/zynq_gem.c | 25 +- drivers/spi/xilinx_spi.c | 8 +- include/dt-bindings/dma/xlnx-zynqmp-dpdma.h | 16 ++ 35 files changed, 4637 insertions(+), 434 deletions(-) create mode 100644 board/xilinx/zynqmp/zynqmp-zcu208-revA/psu_init_gpl.c create mode 100644 board/xilinx/zynqmp/zynqmp-zcu216-revA/psu_init_gpl.c create mode 100644 include/dt-bindings/dma/xlnx-zynqmp-dpdma.h
On Wed, Mar 31, 2021 at 03:06:03PM +0200, Michal Simek wrote:
Hi Tom,
Thanks, Michal
Michal Simek
